[U-Boot] [PATCH v3] qe: fixup the snum for MPC8569 Rev2.0
Since 1.0 and 2.0 use different snum table, we fixup the snum value according to SPRN_SVR.
Signed-off-by: Liu Yu yu.liu@freescale.com --- v3: move code from board to cpu
cpu/mpc85xx/fdt.c | 18 ++++++++++++++++++ 1 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index af0e78e..1d11ab4 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -331,6 +331,23 @@ static void ft_fixup_dpaa_clks(void *blob) #define ft_fixup_dpaa_clks(x) #endif
+#ifdef CONFIG_QE +static void ft_fixup_qe_snum(void *blob) +{ + unsigned int svr; + + svr = mfspr(SPRN_SVR); + if (SVR_SOC_VER(svr) == SVR_8569_E) { + if(IS_SVR_REV(svr, 1, 0)) + do_fixup_by_compat_u32(blob, "fsl,qe", + "fsl,qe-num-snums", 46, 1); + else + do_fixup_by_compat_u32(blob, "fsl,qe", + "fsl,qe-num-snums", 76, 1); + } +} +#endif + void ft_cpu_setup(void *blob, bd_t *bd) { int off; @@ -367,6 +384,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) "bus-frequency", gd->lbc_clk, 1); #ifdef CONFIG_QE ft_qe_setup(blob); + ft_fixup_qe_snum(blob); #endif
#ifdef CONFIG_SYS_NS16550
applied to 85xx
- k
Kumar Gala
Liu Yu
