Hi Tom,
The following changes since commit 493fd3363f6da6a784514657d689c7cda0f390d5:
nokia_rx51: Remove platform (2023-09-04 21:14:32 -0400)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to dfe08374943c0e898fcfaf7327f69e0fb56b7d23:
risc-v: implement DBCN based debug console (2023-09-05 10:53:55 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/17650 ----------------------------------------------------------------
+ Implement OpenSBI DBCN extension for early debug console + Fixes for VisionFive2 board + Fix timer missing + Fix L2 LIM issue + Enable PCIE auto enumeration to support USB and NVMe by default + Set eth0 mac address properly + Add __noreturn attribute to spl_invoke_opensbi
---------------------------------------------------------------- Chanho Park (1): spl: add __noreturn attribute to spl_invoke_opensbi function
Heinrich Schuchardt (2): risc-v: implement DBCN write byte risc-v: implement DBCN based debug console
Seung-Woo Kim (1): eeprom: starfive: set eth0 mac address properly
Shengyu Qu (6): configs: starfive: Enable PCIE auto enum and NVME/USB stuff for Starfive Visionfive 2 doc: board: starfive: Add more info about supported driver Kconfig: Add SPL_SYS_MALLOC_CLEAR_ON_INIT dlmalloc: Add support for SPL_SYS_MALLOC_CLEAR_ON_INIT riscv: cpu: jh7110: Imply SPL_SYS_MALLOC_CLEAR_ON_INIT configs: starfive: Disable SYS_MALLOC_CLEAR_ON_INIT by default
Torsten Duwe (2): riscv: allow riscv timer to be instantiated via device tree riscv: jh7110: enable riscv,timer in the device tree
Kconfig | 11 +++++++++ arch/riscv/cpu/jh7110/Kconfig | 1 + arch/riscv/dts/jh7110.dtsi | 9 +++++++ arch/riscv/include/asm/sbi.h | 1 + arch/riscv/lib/sbi.c | 16 +++++++++++++ .../starfive/visionfive2/visionfive2-i2c-eeprom.c | 2 +- common/dlmalloc.c | 6 ++--- common/spl/spl_opensbi.c | 7 +++--- configs/starfive_visionfive2_defconfig | 10 +++++++- doc/board/starfive/visionfive2.rst | 2 ++ drivers/serial/Kconfig | 5 +++- drivers/serial/serial_sbi.c | 20 ++++++++++++++++ drivers/timer/riscv_timer.c | 28 ++++++++++++++++++++-- include/spl.h | 2 +- 14 files changed, 108 insertions(+), 12 deletions(-)
Best regards, Leo
On Tue, Sep 05, 2023 at 11:30:34AM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
