[U-Boot] Clarification ECC bytes
Hello all,
I'm rebasing our internal code over v2017.11 and I found an unexpected change in drivers/mtd/nand/nand_base.c:
In the function nand_scan_tail: ----- (...) case NAND_ECC_SOFT_BCH: (...) /* * Board driver should supply ecc.size and ecc.strength values * to select how many bits are correctable. Otherwise, default * to 4 bits for large page devices. */ if (!ecc->size && (mtd->oobsize >= 64)) { ecc->size = 512; ecc->strength = 4; }
/* See nand_bch_init() for details. */ ecc->bytes = 0; ecc->priv = nand_bch_init(mtd); -----
This means that ecc->bytes = 0 is overwritting the board driver supplied value. Actually, back in v2014.03, that specific line (ecc->bytes = 0) did not exit. I also checked today in v2018.07 and master, and this potential bug is still there.
Could someone kindly help me here? Removing this line is safe? Or I'm missing something?
Thanks in advance, Fernando
Dear Fernando,
In message CAK3Qp=Uwwr62hg50LXdQ+44Z5wetxvNxZZVDCqkN_tPTsdjb3Q@mail.gmail.com you wrote:
In such cases it is always a good idea to run "git blame" to find out where the code is coming from...
git blame says this comes from
commit ceee07b65875bb01bef55cba06940ef7afc1afba Author: Scott Wood oss@buserror.net Date: Mon May 30 13:57:58 2016 -0500
mtd: nand: Sync with Linux v4.6
Updates the NAND code to match Linux v4.6. The previous sync was from Linux v4.1 in commit d3963721d93fafa.
Note that none of the individual NAND drivers tracked Linux closely enough to be synced themselves, other than manually applying a few cross-tree changes.
Signed-off-by: Scott Wood oss@buserror.net Tested-by: Heiko Schocher hs@denx.de
Thanks for your reply.
Following your suggestion, should I ask Scott Wood? In some mailing lists we are advised not to directly send emails, if not invited.
Regards, Fernando
On Wed, Jul 18, 2018 at 4:03 PM, Wolfgang Denk wd@denx.de wrote:
Dear Fernando,
mtd: nand: Sync with Linux v4.6 Updates the NAND code to match Linux v4.6. The previous sync was from Linux v4.1 in commit d3963721d93fafa. Note that none of the individual NAND drivers tracked Linux closely enough to be synced themselves, other than manually applying a few cross-tree changes. Signed-off-by: Scott Wood <oss@buserror.net> Tested-by: Heiko Schocher <hs@denx.de>
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de That's their goal, remember, a goal that's really contrary to that of the programmer or administrator. We just want to get our jobs done. $Bill just wants to become $$Bill. These aren't even marginallly congruent. -- Tom Christiansen in 6jhtqk$qls$1@csnews.cs.colorado.edu
Fernando AE
