[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 8b485ba12b0defa0c4ed3559789250238f8331a8:
Merge branch 'u-boot/master' into u-boot-arm/master (2013-07-25 17:57:46 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to fdce7b633a1de24456226b18527cc7900c34282a:
gpio: omap5-uevm: Configure the tca6424 gpio expander (2013-07-30 09:21:42 -0400)
---------------------------------------------------------------- Andreas Bießmann (1): omap3/sys_info: fix printout of OMAP36XX L3 freqency
Christian Riesch (1): da850evm: Use clrbits function with correct endianess
Dan Murphy (2): gpio: tca642x: Add the tca642x gpio expander driver gpio: omap5-uevm: Configure the tca6424 gpio expander
Heiko Schocher (1): net, phy, cpsw: fix gigabit register access
Justin Waters (6): am335x_evm: Make NAND support modular am335x_evm: Add command line editing am335x_evm: Rework bootcmd to handle two MMC devs Add additional MLO images to .gitignore am335x_evm: Add support for eMMC environment am335x_evm: Add am335x_boneblack variant
Lokesh Vutla (1): ARM: DRA7xx: Lock DPLL_GMAC
Mugunthan V N (6): drivers: net: cpsw: remove hard coding bd ram for cpsw drivers: net: cpsw: Enable statistics for all port ARM: DRA7xx: Enable GMAC clock control ARM: DRA7xx: Add CPSW support to DRA7xx EVM ARM: DRA7xx: Add CPSW and MDIO pinmux support ARM: DRA7xx: Enable CPSW Ethernet support
Nishanth Menon (6): omap3_beagle: remove JFFS2 support. omap3_beagle: replace uImage.beagle with generic uImage beagleboard: remove RevB support for BeagleBoard Xm omap3_beagle: enable CMD_FS_GENERIC and simplify load of image/ramdisk omap3_beagle: support findfdt and loadfdt for devicetree support omap3_beagle: support booting from zImage and device tree as last option
Stefan Roese (1): arm: omap3: spl: Fix problem with 8bit NAND devices
Steve Kipisz (2): am335x_evm: Add support for the NOR module on the memory cape am335x_evm: Add support to boot from NOR.
Tom Rini (12): spl_mmc.c: Detect missing kernel image in RAW MMC README.falcon: Note how we determine if we can boot the OS or not am335x_evm: Correct DFU ALT settings for falcon mode am335x_evm: Update eMMC falcon mode locations am335x_evm: Correct CONFIG_CMD_SPL_WRITE_SIZE am335x_evm: Add basic README board/ti/am335x/README: Document NAND programming am335x_evm: Drop useless CONFIG_ENV_IS_NOWHERE am335x_evm: Update SPI_BOOT support, add MTDPARTS info am335x_evm: Rework board_is_foo() checks am33xx: Correct gpmc_cfg->irqstatus/enable board/ti/am335x/README: Document NOR programming
.gitignore | 2 +- arch/arm/cpu/armv7/am33xx/board.c | 2 +- arch/arm/cpu/armv7/am33xx/emif4.c | 6 +- arch/arm/cpu/armv7/am33xx/mem.c | 8 +- arch/arm/cpu/armv7/omap-common/clocks-common.c | 18 ++ arch/arm/cpu/armv7/omap3/mem.c | 12 + arch/arm/cpu/armv7/omap3/sys_info.c | 6 +- arch/arm/cpu/armv7/omap5/hw_data.c | 18 +- arch/arm/cpu/armv7/omap5/prcm-regs.c | 7 + arch/arm/include/asm/arch-am33xx/mem.h | 9 + arch/arm/include/asm/arch-omap5/cpu.h | 6 + arch/arm/include/asm/arch-omap5/omap.h | 26 ++ arch/arm/include/asm/omap_common.h | 10 + board/davinci/da8xxevm/da850evm.c | 14 +- board/ti/am335x/Makefile | 2 +- board/ti/am335x/README | 160 ++++++++++++ board/ti/am335x/board.c | 121 +++++---- board/ti/am335x/board.h | 31 +++ board/ti/am335x/mux.c | 65 ++++- board/ti/am335x/u-boot.lds | 117 +++++++++ board/ti/beagle/beagle.c | 28 +- board/ti/beagle/beagle.h | 3 +- board/ti/dra7xx/evm.c | 150 ++++++++++- board/ti/dra7xx/mux_data.h | 14 + board/ti/omap5_uevm/evm.c | 22 ++ board/ti/omap5_uevm/mux_data.h | 2 + board/ti/ti814x/evm.c | 1 + boards.cfg | 17 +- common/spl/spl_mmc.c | 4 + doc/README.falcon | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/tca642x.c | 333 ++++++++++++++++++++++++ drivers/net/cpsw.c | 7 +- drivers/net/phy/phy.c | 6 +- include/configs/am335x_evm.h | 225 ++++++++++------ include/configs/dra7xx_evm.h | 19 ++ include/configs/omap3_beagle.h | 44 +++- include/configs/omap5_uevm.h | 5 + include/cpsw.h | 1 + include/tca642x.h | 69 +++++ 40 files changed, 1387 insertions(+), 206 deletions(-) create mode 100644 board/ti/am335x/README create mode 100644 board/ti/am335x/u-boot.lds create mode 100644 drivers/gpio/tca642x.c create mode 100644 include/tca642x.h
Thanks!
Hi Tom,
On Tue, 30 Jul 2013 09:29:55 -0400, Tom Rini trini@ti.com wrote:
Hello,
Thanks!
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
