[U-Boot] [PATCH] mx27: Make the UART port number explicit
mx27_uart_init_pins does the IOMUX setting for UART1 port.
Change the function name to make the UART port number explicit.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx27/generic.c | 2 +- arch/arm/include/asm/arch-mx27/imx-regs.h | 2 +- board/logicpd/imx27lite/imx27lite.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx27/generic.c b/arch/arm/cpu/arm926ejs/mx27/generic.c index 27642bf..222a8e9 100644 --- a/arch/arm/cpu/arm926ejs/mx27/generic.c +++ b/arch/arm/cpu/arm926ejs/mx27/generic.c @@ -271,7 +271,7 @@ void imx_gpio_mode(int gpio_mode) }
#ifdef CONFIG_MXC_UART -void mx27_uart_init_pins(void) +void mx27_uart1_init_pins(void) { int i; unsigned int mode[] = { diff --git a/arch/arm/include/asm/arch-mx27/imx-regs.h b/arch/arm/include/asm/arch-mx27/imx-regs.h index 8f40aa7..b4b2fe6 100644 --- a/arch/arm/include/asm/arch-mx27/imx-regs.h +++ b/arch/arm/include/asm/arch-mx27/imx-regs.h @@ -29,7 +29,7 @@ extern void imx_gpio_mode (int gpio_mode);
#ifdef CONFIG_MXC_UART -extern void mx27_uart_init_pins(void); +extern void mx27_uart1_init_pins(void); #endif /* CONFIG_MXC_UART */
#ifdef CONFIG_FEC_MXC diff --git a/board/logicpd/imx27lite/imx27lite.c b/board/logicpd/imx27lite/imx27lite.c index 6eb5cc2..cc341f8 100644 --- a/board/logicpd/imx27lite/imx27lite.c +++ b/board/logicpd/imx27lite/imx27lite.c @@ -38,7 +38,7 @@ int board_init (void) gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
#ifdef CONFIG_MXC_UART - mx27_uart_init_pins(); + mx27_uart1_init_pins(); #endif #ifdef CONFIG_FEC_MXC mx27_fec_init_pins();
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
