[U-Boot] [PATCH v2 1/1] arm/ls102xa:add hwconfig setting to support disable unused devices.
DEVDISRn registers provides a mechanism for gating clocks of IP blocks that are not used. Here we implement hwconfig option to allow users to disable unused peripherals on the board.
For ex. If eSDHC/qDMA/eDMA are unused and with disabled status in dts, User can enable CONFIG_FSL_DEVICE_DISABLE and set "devdis:esdhc,qdma,edma" in hwconfig, thus ESDHC controller & eDMA/qDMA will be clock gated to save more power.
Signed-off-by: Zhuoyu Zhang Zhuoyu.Zhang@freescale.com --- arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h | 52 ++++++++++++++++++++++ board/freescale/ls1021aqds/ls1021aqds.c | 5 +++ board/freescale/ls1021atwr/ls1021atwr.c | 5 +++ drivers/misc/Makefile | 1 + drivers/misc/fsl_devdis.c | 29 ++++++++++++ include/configs/ls1021aqds.h | 4 +- include/configs/ls1021atwr.h | 4 +- include/fsl_devdis.h | 18 ++++++++ 8 files changed, 116 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h create mode 100644 drivers/misc/fsl_devdis.c create mode 100644 include/fsl_devdis.h
diff --git a/arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h b/arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h new file mode 100644 index 0000000..3e9e9ea --- /dev/null +++ b/arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h @@ -0,0 +1,52 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_LS102XA_DEVDIS_H_ +#define __FSL_LS102XA_DEVDIS_H_ + +#include <fsl_devdis.h> + +const struct devdis_table devdis_tbl[] = { + { "pbl", 0x0, 0x80000000 }, /* PBL */ + { "esdhc", 0x0, 0x20000000 }, /* eSDHC */ + { "qdma", 0x0, 0x800000 }, /* qDMA */ + { "edma", 0x0, 0x400000 }, /* eDMA */ + { "usb3", 0x0, 0x84000 }, /* USB3.0 controller and PHY*/ + { "usb2", 0x0, 0x40000 }, /* USB2.0 controller */ + { "sata", 0x0, 0x8000 }, /* SATA */ + { "sec", 0x0, 0x200 }, /* SEC */ + { "dcu", 0x0, 0x2 }, /* Display controller Unit */ + { "qe", 0x0, 0x1 }, /* QUICC Engine */ + { "etsec1", 0x1, 0x80000000 }, /* eTSEC1 controller */ + { "etesc2", 0x1, 0x40000000 }, /* eTSEC2 controller */ + { "etsec3", 0x1, 0x20000000 }, /* eTSEC3 controller */ + { "pex1", 0x2, 0x80000000 }, /* PCIE controller 1 */ + { "pex2", 0x2, 0x40000000 }, /* PCIE controller 2 */ + { "duart1", 0x3, 0x20000000 }, /* DUART1 */ + { "duart2", 0x3, 0x10000000 }, /* DUART2 */ + { "qspi", 0x3, 0x8000000 }, /* QSPI */ + { "ddr", 0x4, 0x80000000 }, /* DDR */ + { "ocram1", 0x4, 0x8000000 }, /* OCRAM1 */ + { "ifc", 0x4, 0x800000 }, /* IFC */ + { "gpio", 0x4, 0x400000 }, /* GPIO */ + { "dbg", 0x4, 0x200000 }, /* DBG */ + { "can1", 0x4, 0x80000 }, /* FlexCAN1 */ + { "can2_4", 0x4, 0x40000 }, /* FlexCAN2_3_4 */ + { "ftm2_8", 0x4, 0x20000 }, /* FlexTimer2_3_4_5_6_7_8 */ + { "secmon", 0x4, 0x4000 }, /* Security Monitor */ + { "wdog1_2", 0x4, 0x400 }, /* WatchDog1_2 */ + { "i2c2_3", 0x4, 0x200 }, /* I2C2_3 */ + { "sai1_4", 0x4, 0x100 }, /* SAI1_2_3_4 */ + { "lpuart2_6", 0x4, 0x80 }, /* LPUART2_3_4_5_6 */ + { "dspi1_2", 0x4, 0x40 }, /* DSPI1_2 */ + { "asrc", 0x4, 0x20 }, /* ASRC */ + { "spdif", 0x4, 0x10 }, /* SPDIF */ + { "i2c1", 0x4, 0x4 }, /* I2C1 */ + { "lpuart1", 0x4, 0x2 }, /* LPUART1 */ + { "ftm1", 0x4, 0x1 }, /* FlexTimer1 */ +}; + +#endif diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index d6ef6ba..a1c10cf 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -12,12 +12,14 @@ #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> +#include <asm/arch/ls102xa_devdis.h> #include <hwconfig.h> #include <mmc.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> #include <fsl_sec.h> #include <spl.h> +#include <fsl_devdis.h>
#include "../common/sleep.h" #include "../common/qixis.h" @@ -530,6 +532,9 @@ int misc_init_r(void) else if (hwconfig("sdhc")) config_board_mux(MUX_TYPE_SDHC);
+#ifdef CONFIG_FSL_DEVICE_DISABLE + device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl)); +#endif #ifdef CONFIG_FSL_CAAM return sec_init(); #endif diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b7458a9..5ebe781 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -12,6 +12,7 @@ #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> +#include <asm/arch/ls102xa_devdis.h> #include <hwconfig.h> #include <mmc.h> #include <fsl_esdhc.h> @@ -21,6 +22,7 @@ #include <fsl_mdio.h> #include <tsec.h> #include <fsl_sec.h> +#include <fsl_devdis.h> #include <spl.h> #include "../common/sleep.h" #ifdef CONFIG_U_QE @@ -651,6 +653,9 @@ int board_init(void) #if defined(CONFIG_MISC_INIT_R) int misc_init_r(void) { +#ifdef CONFIG_FSL_DEVICE_DISABLE + device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl)); +#endif #ifndef CONFIG_QSPI_BOOT config_board_mux(); #endif diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 5218b91..8d0fc3c 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -35,3 +35,4 @@ obj-$(CONFIG_FSL_IFC) += fsl_ifc.o obj-$(CONFIG_FSL_SEC_MON) += fsl_sec_mon.o obj-$(CONFIG_PCA9551_LED) += pca9551_led.o obj-$(CONFIG_RESET) += reset-uclass.o +obj-$(CONFIG_FSL_DEVICE_DISABLE) += fsl_devdis.o diff --git a/drivers/misc/fsl_devdis.c b/drivers/misc/fsl_devdis.c new file mode 100644 index 0000000..d9c36e2 --- /dev/null +++ b/drivers/misc/fsl_devdis.c @@ -0,0 +1,29 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * Author: Zhuoyu Zhang Zhuoyu.Zhang@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <hwconfig.h> +#include <fsl_devdis.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch-ls102xa/immap_ls102xa.h> +#include <asm/arch-ls102xa/config.h> +#include <linux/compiler.h> + +void device_disable(const struct devdis_table *tbl, uint32_t num) +{ + int i; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + /* + * Extract hwconfig from environment and disable unused device. + */ + for (i = 0; i < ARRAY_SIZE(tbl); i++) { + if (hwconfig_sub("devdis", tbl[i].name)) + setbits_be32(&gur->devdisr + tbl[i].offset, + tbl[i].mask); + } +} + diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 0871a71..f8710ed 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -567,7 +567,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_TIMER_CLK_FREQ 12500000
#define CONFIG_HWCONFIG -#define HWCONFIG_BUFFER_SIZE 128 +#define HWCONFIG_BUFFER_SIZE 256 + +#define CONFIG_FSL_DEVICE_DISABLE
#define CONFIG_BOOTDELAY 3
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index df7af3c..56e5808 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -415,7 +415,9 @@ #define CONFIG_TIMER_CLK_FREQ 12500000
diff --git a/include/fsl_devdis.h b/include/fsl_devdis.h new file mode 100644 index 0000000..02415fe --- /dev/null +++ b/include/fsl_devdis.h @@ -0,0 +1,18 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_DEVDIS_H_ +#define __FSL_DEVDIS_H_ + +struct devdis_table { + char name[32]; + u32 offset; + u32 mask; +}; + +void device_disable(const struct devdis_table *tbl, uint32_t num); + +#endif
What's the change since v1? You missed change log.
York
Hi, York
Alison help me find out a macro definition mistake, v2 just correct this mistake. I will resend it again and add change-log in.
Zhuoyu
-----Original Message----- From: Sun York-R58495 Sent: Saturday, August 15, 2015 12:07 AM To: Zhang Zhuoyu-B46552 Cc: u-boot@lists.denx.de; Jin Zhengxiong-R64188; Wang Huan-B18965 Subject: Re: [PATCH v2 1/1] arm/ls102xa:add hwconfig setting to support disable unused devices.
York
York Sun
Zhang Z.Y.
Zhuoyu Zhang
