[U-Boot] Conflicting commits for seaboard USB keyboard handling
Hello,
It seems like two commits 5ddcc38b (in u-boot, committed by Marek) 29f3e3f2 (in u-boot-arm, committed by Tom from u-boot-tegra) are conflicting on the seaboard configuration header file for USB (and possibly other areas).
Tom, can you look into it (and involve whoever is needed) and provide a pull request with a fix, the same way I asked Stefano and Minkyu for the same?
Thanks in advance!
Amicalement,
Will do.
On Sat, Dec 8, 2012 at 11:03 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hello,
Thanks in advance!
Amicalement,
Albert.
Albert,
On Mon, Dec 10, 2012 at 9:25 AM, Tom Warren twarren.nvidia@gmail.com wrote:
Will do.
Hello,
Looking at Allen's commit, it only added CONFIG_USB_KEYBOARD (plus a comment) to seaboard.h. That should be conflict-free with my rename of TEGRA20_ to TEGRA_ in seaboard.h. Looking at Allen's patchset (which is marked 'Awaiting upstream' in Patchwork, BTW), you can see that my patch had already been applied to Allen's source (CONFIG_TEGRA_KEYBOARD instead of CONFIG_TEGRA20_KEYBOARD precedes Allen's CONFIG_USB_KEYBOARD in seaboard.h).
I pulled TOT u-boot/master, and both commits seem to be just fine for seaboard.h. It builds fine, too.
Can you be more explicit about the exact conflict, including which exact repos & branches you are merging when you see the conflict?
Thanks,
Tom
Thanks in advance!
Amicalement,
Albert.
On Mon, Dec 10, 2012 at 08:59:59AM -0800, Tom Warren wrote:
Albert,
Will do.
Hello,
I can see the conflict if I checkout u-boot-arm/master and then merge u-boot-tegra/next and u-boot/master. If we pull the following commit from u-boot/master into u-boot-tegra/next it helps:
5ddcc38 tegra: Enable USB keyboard
There's still a conflict between the LCD config file changes and the USB keyboard config file changes, but it's pretty straightforward to resolve.
-Allen
u-boot-arm/master and u-boot-tegra/next should have the same base commit (b8a7c46), so merging them isn't a big deal, and goes smoothly for me. If I then take u-boot/master and merge it, I see a conflict in drivers/power/power_fls.c and include/configs/mx35pdk.h and mx53loco.h, but no problems with Tegra code. I could resolve those conflicts and continue with the rebase, but ...
Correct me if I'm wrong, but u-boot-tegra and u-boot-usb are both pulled into u-boot-arm, and (I thought) u-boot-arm is then (or eventually) pulled into u-boot/master. I don't pull from u-boot-usb (or any other 'sub' repo), since that would appear to create conflicts when Albert pulls into u-boot-arm. I also don't pull from u-boot/master, since it's essentially 2 levels above me.
Albert - if you can, please show me exactly what fetch/merge or rebase command sequence is failing for you. I'm still not clear on what the exact merge conflict error is, nor how to fix it. Or Allen, if you have better visibility into exactly what the merge conflict is w/Tegra that I'm just not seeing, maybe you could provide either a patchset that'll fix it or steps I can take to do the same.
Thanks,
Tom
Albert,
Will do.
Hello,
-Allen
nvpublic
Albert,
Hello,
One possible problem is that I've got new commits ready in u-boot-tegra/next that were almost ready for a pull request, so I copied them over to my tegra/master branch and pushed to u-boot-tegra/master on denx. I assumed that once I got the 'applied to u-boot-arm/master' response from you, that I could stage the next pull request. But if you (or Allen) are pulling from u-boot-tegra/master )or /next), you're gonna get commits that haven't been merged into u-boot-arm/master.
I can push the older tegra/master branch back to denx.de (the one that I requested a pull from on Nov 19th) if that'll help. But I'm not sure how it would help, since all those commits should have been present in u-boot-arm/master (from my pull request) when you went to merge w/u-boot/master.
So I'm still not seeing how the conflict arose, or what the path is to fixing it.
Tom
On Mon, Dec 10, 2012 at 01:51:40PM -0800, Tom Warren wrote:
Albert,
Hello,
The conflict came from my config file changes for tegra USB keyboard which went up to u-boot/master through Marek's tree becasue they depend on my USB DMA alignment fix which was not a tegra change. There are subsequent changes in both the tegra and arm trees that were not based on that change, so they now conflict when attempting to merge back into u-boot/master.
It's trivial for me to resolve the conflict since I have context on the changes. I see that there are other merge conflicts between u-boot/master and u-boot-arm/master though, so I'm not sure how to proceed. Albert do you just want me to post merged versions of the two files that conflict, so you know how to resolve the conflict during your merge?
Hi Allen,
Albert,
Hello,
I would like you to post a pull request that would fix the two file conflicts; I have asked other people to fix other merge conflicts. I will merge all fix branches in one go (so that u-boot-arm keeps building clean) once all fix branches are available.
Amicalement,
Allen,
If you come up with patches to fix the seaboard config files, I can add them to my copy of u-boot-tegra/master, push it to denx, and generate a pull request for Albert if you want.
Tom
On Sat, Dec 15, 2012 at 9:41 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Allen,
Albert,
Hello,
Amicalement,
Albert.
On Mon, Dec 17, 2012 at 02:13:29PM -0800, Tom Warren wrote:
Allen,
The conflicting changes have already been merged to u-boot-arm/master, Albert were you planning to replay the merge of the already merged tegra patches?
-Allen
Tom
Hi Allen,
Albert,
Hello,
Amicalement,
Albert.
Allen,
Allen,
Sorry, but I don't see any new merges since the FETCH_HEAD I listed below, i.e. u-boot-arm/master still appears to be @ b8a7c46 for me (git pull in u-boot-arm repo, and git fetch git://git.denx.de/u-boot-arm master in my tegra repo).
What am I missing?
Tom
-Allen
Tom
Hi Allen,
Albert,
On Sat, Dec 8, 2012 at 11:03 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote: > Hello, > > It seems like two commits 5ddcc38b (in u-boot, committed by Marek) > 29f3e3f2 (in u-boot-arm, committed by Tom from u-boot-tegra) are > conflicting on the seaboard configuration header file for USB (and > possibly other areas).
Amicalement,
Albert.
-- nvpublic
On Tue, Dec 18, 2012 at 08:43:18AM -0800, Tom Warren wrote:
Allen,
Allen,
What am I missing?
The conflict happened prior to that point. In particular this is the first conflicting patch:
4576c6e tegra: Enable display/lcd support on Seaboard
(and then all the patches that touch tegra config files after that which need to be rebased)
-Allen
Tom
-Allen
Tom
Hi Allen,
Albert,
> On Sat, Dec 8, 2012 at 11:03 PM, Albert ARIBAUD > albert.u.boot@aribaud.net wrote: >> Hello, >> >> It seems like two commits 5ddcc38b (in u-boot, committed by Marek) >> 29f3e3f2 (in u-boot-arm, committed by Tom from u-boot-tegra) are >> conflicting on the seaboard configuration header file for USB (and >> possibly other areas).
Amicalement,
Albert.
-- nvpublic
Allen,
Allen,
Allen,
What am I missing?
-Allen
OK, sorry, I mistook the 'conflicting changes have already been merged' to mean that you've fixed the conflicts and Albert had merged them.
Where are we on getting a set of patches that fix the conflicts into either u-boot-tegra, u-boot-arm, or ????.
I'm sitting on a new pull request for some Tegra20 tweaks and the baseline Tegra30 support patches that I'd like to get in sooner than later.
Thanks,
Tom
Tom
-Allen
Tom
Hi Allen,
On Mon, Dec 10, 2012 at 01:51:40PM -0800, Tom Warren wrote: > Albert, > > > On Sat, Dec 8, 2012 at 11:03 PM, Albert ARIBAUD > > albert.u.boot@aribaud.net wrote: > >> Hello, > >> > >> It seems like two commits 5ddcc38b (in u-boot, committed by Marek) > >> 29f3e3f2 (in u-boot-arm, committed by Tom from u-boot-tegra) are > >> conflicting on the seaboard configuration header file for USB (and > >> possibly other areas). > > One possible problem is that I've got new commits ready in > u-boot-tegra/next that were almost ready for a pull request, so I > copied them over to my tegra/master branch and pushed to > u-boot-tegra/master on denx. I assumed that once I got the 'applied > to u-boot-arm/master' response from you, that I could stage the next > pull request. But if you (or Allen) are pulling from > u-boot-tegra/master )or /next), you're gonna get commits that haven't > been merged into u-boot-arm/master. > > I can push the older tegra/master branch back to denx.de (the one that > I requested a pull from on Nov 19th) if that'll help. But I'm not > sure how it would help, since all those commits should have been > present in u-boot-arm/master (from my pull request) when you went to > merge w/u-boot/master. > > So I'm still not seeing how the conflict arose, or what the path is to > fixing it. >
Amicalement,
Albert.
-- nvpublic
-- nvpublic
On Tue, Dec 18, 2012 at 03:59:36PM -0800, Tom Warren wrote:
Allen,
Allen,
Allen,
What am I missing?
-Allen
Whatever the fix is, it will need to go in before:
or I can amend that change to resolve the conflict. Either way will require replaying the tegra patches that were already merged into u-boot-arm. Albert, is that what you want to do?
The other alternative is I could provide the conflict resolved files or instructions for how to resolve.
Albert's suggestion of providing a new pull request won't help as the conflicting changes are already in the u-boot-arm tree.
-Allen
Thanks,
Tom
Tom
-Allen
Tom
Hi Allen,
On Tue, 11 Dec 2012 11:02:09 -0800, Allen Martin amartin@nvidia.com wrote: > On Mon, Dec 10, 2012 at 01:51:40PM -0800, Tom Warren wrote: > > Albert, > > > > > On Sat, Dec 8, 2012 at 11:03 PM, Albert ARIBAUD > > > albert.u.boot@aribaud.net wrote: > > >> Hello, > > >> > > >> It seems like two commits 5ddcc38b (in u-boot, committed by Marek) > > >> 29f3e3f2 (in u-boot-arm, committed by Tom from u-boot-tegra) are > > >> conflicting on the seaboard configuration header file for USB (and > > >> possibly other areas). > > > > One possible problem is that I've got new commits ready in > > u-boot-tegra/next that were almost ready for a pull request, so I > > copied them over to my tegra/master branch and pushed to > > u-boot-tegra/master on denx. I assumed that once I got the 'applied > > to u-boot-arm/master' response from you, that I could stage the next > > pull request. But if you (or Allen) are pulling from > > u-boot-tegra/master )or /next), you're gonna get commits that haven't > > been merged into u-boot-arm/master. > > > > I can push the older tegra/master branch back to denx.de (the one that > > I requested a pull from on Nov 19th) if that'll help. But I'm not > > sure how it would help, since all those commits should have been > > present in u-boot-arm/master (from my pull request) when you went to > > merge w/u-boot/master. > > > > So I'm still not seeing how the conflict arose, or what the path is to > > fixing it. > > > > The conflict came from my config file changes for tegra USB keyboard > which went up to u-boot/master through Marek's tree becasue they > depend on my USB DMA alignment fix which was not a tegra change. > There are subsequent changes in both the tegra and arm trees that were > not based on that change, so they now conflict when attempting to > merge back into u-boot/master. > > It's trivial for me to resolve the conflict since I have context on > the changes. I see that there are other merge conflicts between > u-boot/master and u-boot-arm/master though, so I'm not sure how to > proceed. Albert do you just want me to post merged versions of the > two files that conflict, so you know how to resolve the conflict > during your merge?
Amicalement,
Albert.
-- nvpublic
-- nvpublic
On 12/18/2012 06:08 PM, Allen Martin wrote: ...
Aren't the two sets of files that conflict those that are already in u-boot/master and u-boot-arm/master? If so, only Albert can resolve the conflict, by doing a merge. I already did that merge locally a while back in order to pick up the changes from both branches, and it didn't seem hard; what's the problem here? If Allen can push out a branch for Albert to use as an example to make sure he gets the correct merge result, that seems like a very simple solution.
Hi Stephen,
On Tue, 18 Dec 2012 23:04:09 -0700, Stephen Warren swarren@wwwdotorg.org wrote:
There are several sources of conflicts in merging u-boot into u-boot-arm. I want all conflicts resolved by the persons who are best suited for resolving properly, then I'll merge all resolutions together.
Amicalement,
On Wed, Dec 19, 2012 at 11:37:26AM -0800, Albert ARIBAUD wrote:
Hi Stephen,
Hi Albert, I did a merge of u-boot/master into u-boot-arm/master and resolved the conflicts and I've pushed the result to:
git://github.com/arm000/u-boot.git branch: u-boot-arm-merge-resolved
I resolved all the conflicts, but the only ones I claim I did correctly were the changes to:
include/configs/seaboard.h include/configs/tegra-common-post.h
the other conflicts were not related to tegra.
If you want a new pull request, you'll first have to unroll the previously merged tegra patches from u-boot-arm/master so I can give you a conflict free merge request.
-Allen
Hi Allen,
Thanks Allen, this branch is what I wanted exactly -- I don't want to ask for a rollback. As soon as I am sure about the samsung branch, I'll merge all "fix" branches into ARM.
-Allen
nvpublic
Amicalement,
On Wed, Dec 19, 2012 at 02:42:24PM -0800, Albert ARIBAUD wrote:
Hi Allen,
Ok, let me know if you have any problems resolving and I'll try to help the best I can.
Tom, you'll need to rebase u-boot-tegra/next on top of this, and there will be conflicts when you do. I've resolved those as well for reference and pushed to:
git://github.com/arm000/u-boot.git branch: u-boot-tegra-next-rebased
-Allen
Hi Allen,
-Allen
Thanks, Allen, I probably won't get to this before the holiday break, but I'll pick it up next year and see where we're at. Appreciate your help with this.
Albert - if you need anything from me, it'll have to be today or tomorrow, or next year.
Tom
-- nvpublic
Hi Tom,
On Mon, 10 Dec 2012 14:15:10 -0700, Tom Warren twarren.nvidia@gmail.com wrote:
As for what I did, it was simply to try and merge u-boot-tegra into u-boot-arm.
Regarding u-boot-usb, it is not usually pulled into u-boot-arm; but if it was needed by, and pulled into, u-boot-tegra, then it would have automatically been pulled into u-boot-arm when I fetched u-boot-tegra, and merged when I did the merge. Would it not?
Amicalement,
Albert,
On Thu, Dec 13, 2012 at 12:20 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Tom,
U-boot-tegra/master is synced up with u-boot-arm/master, i.e. both are at top commit b8a7c46.
git fetch git://git.denx.de/u-boot-arm master shows a FETCH_HEAD of
b8a7c467960ffb4d5a5e1eef5f7783fb6f594542 branch 'master' of git://git.denx.de/u-boot-arm
which is the top commit of my current u-boot-tegra/master on denx.de.
So merging the two should be seamless and pain-free.
As to u-boot-usb, I made a mistaken assumption that you pull it into u-boot-arm because I saw commits with:
Merge master of u-boot-usb.git
in the commit log, but those came from u-boot/master, not from you. My bad.
I don't (and won't) pull from any other repo into u-boot-tegra, except when I merge w/my 'parent', u-boot-arm/master, just before I issue a pull request to you. I'm at the very bottom of the chain, and only feed into your repo, with no one feeding into mine (except when I merge w/you, of course, to stay in sync).
Allen has offered to resolve the conflict with his USB patches in seaboard.h and tegra-common.h. Please work with him to get a patchset that can be applied to the ARM or USB repos to resolve this problem. IMO, u-boot-tegra/master is OK as is and not the source of the conflict (correct me if I'm wrong).
Thanks,
Tom
Amicalement,
Albert.
Albert ARIBAUD
Allen Martin
Stephen Warren
Tom Warren
