[U-Boot] [PATCH] vexpress: disable cci ace slave ports when booting in non-sec/hyp mode
Commit f225d39d3093 ("vexpress: Check TC2 firmware support before defaulting to nonsec booting") added support to check if the firmware on TC2 is configured appropriately before booting in nonsec/hyp mode.
However when booting in non-secure/hyp mode, CCI control must be done in secure firmware and can't be done in non-secure/hyp mode. In order to ensure that, this patch disables the cci slave port inteface so that it is not accessed at all.
Cc: Jon Medhurst tixy@linaro.org Signed-off-by: Sudeep Holla sudeep.holla@arm.com --- board/armltd/vexpress/vexpress_tc2.c | 47 ++++++++++++++++++++++++++++++++++++ configs/vexpress_ca15_tc2_defconfig | 1 + 2 files changed, 48 insertions(+)
This change is needed to avoid the kernel panic while attempting to access CCI ports when booting in non-sec/HYP mode. The kernel patches to fix this are available @[1]
Regards, Sudeep
[1] http://www.spinics.net/lists/arm-kernel/msg533715.html
diff --git a/board/armltd/vexpress/vexpress_tc2.c b/board/armltd/vexpress/vexpress_tc2.c index ebb41a8833ab..25bbba7a8590 100644 --- a/board/armltd/vexpress/vexpress_tc2.c +++ b/board/armltd/vexpress/vexpress_tc2.c @@ -8,6 +8,9 @@ */
#include <asm/io.h> +#include <asm/u-boot.h> +#include <common.h> +#include <libfdt.h>
#define SCC_BASE 0x7fff0000
@@ -31,3 +34,47 @@ bool armv7_boot_nonsec_default(void) return (readl((u32 *)(SCC_BASE + 0x700)) & ((1 << 12) | (1 << 13))) == 0; #endif } + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *fdt, bd_t *bd) +{ + int offset, tmp, len; + const struct fdt_property *prop; + const char *cci_compatible = "arm,cci-400-ctrl-if"; + + if (!armv7_boot_nonsec_default()) + return 0; /* Do nothing */ + + offset = fdt_path_offset(fdt, "/cpus"); + if (offset < 0) { + printf("couldn't find /cpus\n"); + return offset; + } + + /* delete cci-control-port in each cpu node */ + for (tmp = fdt_first_subnode(fdt, offset); tmp >= 0; + tmp = fdt_next_subnode(fdt, tmp)) + fdt_delprop(fdt, tmp, "cci-control-port"); + + /* disable all ace cci slave ports */ + offset = fdt_node_offset_by_prop_value(fdt, offset, "compatible", + cci_compatible, 20); + while (offset > 0) { + prop = fdt_get_property(fdt, offset, "interface-type", + &len); + if (!prop) + continue; + if (len < 4) + continue; + if (strcmp(prop->data, "ace")) + continue; + + fdt_setprop_string(fdt, offset, "status", "disabled"); + + offset = fdt_node_offset_by_prop_value(fdt, offset, "compatible", + cci_compatible, 20); + } + + return 0; +} +#endif /* CONFIG_OF_BOARD_SETUP */ diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 2f141dda06c6..5154803b7c65 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA15_TC2=y +CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set -- 2.7.4
Ah, that'd be a great reason for me to update the 2.5 year old u-boot that lives on my TC2!
Acked-by: Marc Zyngier marc.zyngier@arm.com
M.
That's just testing the default not whether the board is actually going to boot in nonsec (hyp) mode or not, which also also depends on environment variables. So you probably want instead to call armv7_boot_nonsec() here. That function only exists if CONFIG_ARMV7_NONSEC is defined, so the 'if' statement above probably wants to be something like...
#ifdef CONFIG_ARMV7_NONSEC if (!armv7_boot_nonsec()) return 0; #else return 0; #endif /* We only get here if board will boot in nonsec mode */
Ah ok, wasn't aware of that. Thanks for pointing that out.
OK, will update accordingly.
Cc: Jon Medhurst tixy@linaro.org Acked-by: Marc Zyngier marc.zyngier@arm.com Signed-off-by: Sudeep Holla sudeep.holla@arm.com --- board/armltd/vexpress/vexpress_tc2.c | 52 ++++++++++++++++++++++++++++++++++++ configs/vexpress_ca15_tc2_defconfig | 1 + 2 files changed, 53 insertions(+)
Regards, Sudeep
v1->v2: - Fix compilation with !CONFIG_ARMV7_NONSEC(Thanks to Tixy)
diff --git a/board/armltd/vexpress/vexpress_tc2.c b/board/armltd/vexpress/vexpress_tc2.c index ebb41a8833ab..c7adf950f579 100644 --- a/board/armltd/vexpress/vexpress_tc2.c +++ b/board/armltd/vexpress/vexpress_tc2.c @@ -7,7 +7,11 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <asm/armv7.h> #include <asm/io.h> +#include <asm/u-boot.h> +#include <common.h> +#include <libfdt.h>
@@ -31,3 +35,51 @@ bool armv7_boot_nonsec_default(void) return (readl((u32 *)(SCC_BASE + 0x700)) & ((1 << 12) | (1 << 13))) == 0; #endif } + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *fdt, bd_t *bd) +{ + int offset, tmp, len; + const struct fdt_property *prop; + const char *cci_compatible = "arm,cci-400-ctrl-if"; + +#ifdef CONFIG_ARMV7_NONSEC + if (!armv7_boot_nonsec()) + return 0; +#else + return 0; +#endif + /* Booting in nonsec mode, disable CCI access */ + offset = fdt_path_offset(fdt, "/cpus"); + if (offset < 0) { + printf("couldn't find /cpus\n"); + return offset; + } + + /* delete cci-control-port in each cpu node */ + for (tmp = fdt_first_subnode(fdt, offset); tmp >= 0; + tmp = fdt_next_subnode(fdt, tmp)) + fdt_delprop(fdt, tmp, "cci-control-port"); + + /* disable all ace cci slave ports */ + offset = fdt_node_offset_by_prop_value(fdt, offset, "compatible", + cci_compatible, 20); + while (offset > 0) { + prop = fdt_get_property(fdt, offset, "interface-type", + &len); + if (!prop) + continue; + if (len < 4) + continue; + if (strcmp(prop->data, "ace")) + continue; + + fdt_setprop_string(fdt, offset, "status", "disabled"); + + offset = fdt_node_offset_by_prop_value(fdt, offset, "compatible", + cci_compatible, 20); + } + + return 0; +} +#endif /* CONFIG_OF_BOARD_SETUP */ diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 2f141dda06c6..5154803b7c65 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA15_TC2=y +CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set -- 2.7.4
This works for me (unsurprisingly) when booting in secure mode. What kernel and firmware config do I need to use for non-sec mode? I tried vexpress_defconfig, with bits 12 and 13 cleared in SCC: 0x700 but I get nothing out the console after "Starting kernel ..."
I just flipped bit 12 and 13 in SCC: 0x700 to switch between MCPM/secure and HYP/non-secure mode. All other images/settings remain the same.
So IIUC, with vexpress_defconfig + above SCC change you are seeing a hand, I will check that. I am using multi_v7_defconfig.
+ the patches from Lorenzo fixing MCPM code in the kernel [1] as mentioned first email carrying this patch.
Acked-by: Jon Medhurst tixy@linaro.org Tested-by: Jon Medhurst tixy@linaro.org
Regards, Sudeep
v1->v2:
- int offset, tmp, len;
- const struct fdt_property *prop;
- const char *cci_compatible = "arm,cci-400-ctrl-if";
- if (!armv7_boot_nonsec())
+#else
- /* Booting in nonsec mode, disable CCI access */
- offset = fdt_path_offset(fdt, "/cpus");
- if (offset < 0) {
return offset;
- /* delete cci-control-port in each cpu node */
- for (tmp = fdt_first_subnode(fdt, offset); tmp >= 0;
- /* disable all ace cci slave ports */
- offset = fdt_node_offset_by_prop_value(fdt, offset, "compatible",
- while (offset > 0) {
&len);
if (!prop)
continue;
if (len < 4)
continue;
continue;
2.7.4
So, can I assume the missing kernel patches to be reason for boot hang ? Just wanted to know if I need to investigate that any further ?
Sorry, yes they were the reason and no further investigation needed. I remembered getting nonsec mode working some month's ago without such patches, but I remember now that was by disabling MCPM in the kernel.
This morning I tried these U-Boot patches successfully with: - Upstream vexpress_defconfig kernel booting with 'sec' mode - That kernel with Lorenzo's patches in both 'sec' and 'nonsec' - As above with CONFIG_BL_SWITCHER enabled
When booting in nonsec I also verified the device-tree modifications made by this patch by seeing the following files existed and contained the word 'disabled'...
/proc/device-tree/cci@2c090000/slave-if@4000/status /proc/device-tree/cci@2c090000/slave-if@5000/status
That was very detailed :), thanks for testing and confirming. I too did similar examination and didn't find anything odd so far.
Cc: Jon Medhurst tixy@linaro.org Acked-by: Marc Zyngier marc.zyngier@arm.com Signed-off-by: Sudeep Holla sudeep.holla@arm.com Acked-by: Jon Medhurst tixy@linaro.org Tested-by: Jon Medhurst tixy@linaro.org
Jon Medhurst (Tixy)
Marc Zyngier
Sudeep Holla
