[U-Boot] pull request for u-boot-tegra/master info ARM/master
Albert,
Please pull u-boot-tegra/master into ARM/master. Thanks!
./MAKEALL -s tegra AOK, checkpatch.pl is clean, and ./MAKEALL -a arm only shows failures that were already present in ARM/master.
The following changes since commit ab6423cae0323e8db2c8fdd0a99138d93fde2137:
Merge branch 'u-boot/master' into 'u-boot-arm/master' (2014-03-25 10:53:15 +0100)
git://git.denx.de/u-boot-tegra master
for you to fetch changes up to 352580870ca64b23a485a6b2ba6febc240b10904:
ARM: tegra: make all I2C ports open-drain (2014-03-26 15:20:56 -0700)
---------------------------------------------------------------- Stephen Warren (1): ARM: tegra: make all I2C ports open-drain
board/nvidia/dalmore/pinmux-config-dalmore.h | 16 ++++++++-------- board/nvidia/venice2/pinmux-config-venice2.h | 16 ++++++++-------- 2 files changed, 16 insertions(+), 16 deletions(-)
Thanks!
Hi Tom,
Is there something holding you back including my USB changes (v5)?
-- Stefan
Have they all been ACKed? Sorry, been really busy with normal NVIDIA stuff.
If they're ready, I can apply them with Stephen's pinmux changes and send another PR to Albert.
On Wed, Mar 26, 2014 at 4:15 PM, Stefan Agner stefan@agner.ch wrote:
Hi Tom,
-- Stefan
Am 2014-03-28 16:54, schrieb Tom Warren:
They have been ACKed, see http://lists.denx.de/pipermail/u-boot/2014-March/175302.html
and tested by Stephen, http://lists.denx.de/pipermail/u-boot/2014-March/174662.html
That would be great yes.
OK, will do.
Albert - have you pull my latest PR into ARM master yet? Stephen was hoping to get it in before the next release.
I'll send a new PR with the latest patches, but the first PR still needs to go in ASAP.
Tom
stuff. They have been ACKed, see http://lists.denx.de/pipermail/u-boot/2014-March/175302.html
send another PR to Albert. That would be great yes.
Hi Stephen,
On Tue, 01 Apr 2014 10:33:20 -0600, Stephen Warren swarren@wwwdotorg.org wrote:
On 03/26/2014 04:37 PM, Tom Warren wrote:
Albert,
I'd really like this change to make it into 2014.04. Can it please be pulled?
Sorry Stephen, I've been held away from the list for a few days. I am going through the PRs right now.
Amicalement,
Hi Tom,
On Wed, 26 Mar 2014 15:37:07 -0700, Tom Warren twarren.nvidia@gmail.com wrote:
Albert,
Thanks!
Applied to u-boot-arm/master, thanks!
Amicalement,
Thanks, Albert!
Another PR with Stefan and Stephen's latest Tegra changes should be ready before the end of the week.
Tom
On Tue, Apr 1, 2014 at 1:11 PM, Albert ARIBAUD albert.u.boot@aribaud.netwrote:
Hi Tom,
Albert,
only
Thanks!
Amicalement,
Albert.
On 04/01/2014 04:26 PM, Tom Warren wrote:
Thanks, Albert!
Well, those other patches (of mine at least) are probably for the next release, so a PR to Albert probably isn't needed before 2014.04 is released, unless we still have parallel master/next branches in u-boot-arm.git?
Hi Stephen,
On Tue, 01 Apr 2014 17:02:38 -0600, Stephen Warren swarren@wwwdotorg.org wrote:
Thanks, Albert!
Currently master and next are identical in ARM. You can PR to u-boot-arm/next if you would like to.
Amicalement,
Albert ARIBAUD
Stefan Agner
Stephen Warren
Tom Warren
