[U-Boot] [PATCH] cmd_flash.c: fix warning: unused variable 'addr_first'/'addr_last'
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_flash.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_flash.c b/common/cmd_flash.c index 9f27ab0..bc651fa 100644 --- a/common/cmd_flash.c +++ b/common/cmd_flash.c @@ -467,18 +467,18 @@ int do_protect (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) flash_info_t *info; ulong bank; int i, n, sect_first, sect_last; -#endif /* CONFIG_SYS_NO_FLASH */ ulong addr_first, addr_last; - int p; +#endif /* CONFIG_SYS_NO_FLASH */ #if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_CMD_MTDPARTS) struct mtd_device *dev; struct part_info *part; u8 dev_type, dev_num, pnum; #endif - int rcode = 0; #ifdef CONFIG_HAS_DATAFLASH int status; #endif + int p; + int rcode = 0;
if (argc < 3) { cmd_usage(cmdtp);
