[U-Boot] [PATCH 1/3] configs: ls2085aqds: Enable DSPI flash support for LS2085AQDS
Enable DSPI flash related configurations.
Signed-off-by: Haikun Wang haikun.wang@freescale.com --- include/configs/ls2085aqds.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/include/configs/ls2085aqds.h b/include/configs/ls2085aqds.h index e488ac8..bf5ea51 100644 --- a/include/configs/ls2085aqds.h +++ b/include/configs/ls2085aqds.h @@ -273,6 +273,15 @@ unsigned long get_board_ddr_clk(void); /* I2C bus multiplexer */ #define I2C_MUX_CH_DEFAULT 0x8
+/* SPI */ +#ifdef CONFIG_FSL_DSPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_SST +#define CONFIG_SPI_FLASH_EON +#endif + /* * MMC */
Enable DSPI flash related configurations for LS2085ARDB.
Signed-off-by: Haikun Wang haikun.wang@freescale.com --- include/configs/ls2085ardb.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/ls2085ardb.h b/include/configs/ls2085ardb.h index 600261e..8cd3bf7 100644 --- a/include/configs/ls2085ardb.h +++ b/include/configs/ls2085ardb.h @@ -245,6 +245,14 @@ unsigned long get_board_sys_clk(void); /* I2C bus multiplexer */ #define I2C_MUX_CH_DEFAULT 0x8
+/* SPI */ +#ifdef CONFIG_FSL_DSPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_BAR +#endif + /* * RTC configuration */
Freescale DSPI driver has been converted to Driver Model. The new driver is depended on OF_CONTROL, DM, DM_SPI. This patch enable FSL_DSPI and its dependence configure options.
Signed-off-by: Haikun Wang haikun.wang@freescale.com --- configs/ls2085aqds_defconfig | 7 +++++++ configs/ls2085ardb_defconfig | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/configs/ls2085aqds_defconfig b/configs/ls2085aqds_defconfig index fd208b18..00b062b 100644 --- a/configs/ls2085aqds_defconfig +++ b/configs/ls2085aqds_defconfig @@ -1,4 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS2085AQDS=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2085a-qds" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls2085ardb_defconfig b/configs/ls2085ardb_defconfig index 308e935..c7dae4b 100644 --- a/configs/ls2085ardb_defconfig +++ b/configs/ls2085ardb_defconfig @@ -1,4 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS2085ARDB=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2085a-rdb" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y
Applied to u-boot-fsl-qoriq master branch with subject fix.
York
This set is applied to u-boot-fsl-qoriq master branch with subject fix.
York
Haikun Wang
York Sun
