[U-Boot] Warm reset problems in U-Boot
Dear sir or madam,
We are using an Altera cyclone V SoC FPGA and have a problem on warm reset in the U-Boot environment. I would be very grateful if you could send this e-mail to a responsible person. It is possible to answer in English or German.
Kind regards, Marcel Oehen
Siemens Schweiz AG Mobility Hammerweg 1 8304 Wallisellen, Switzerland Tel.: +41 585 580930 mailto:marcel.oehen@siemens.com, www.siemens.chhttp://www.siemens.ch www.siemens.com/ingenuityforlifehttps://siemens.com/ingenuityforlife
Important notice: This e-mail and any attachment thereof contain corporate proprietary information. If you have received it by mistake, please notify us immediately by reply e-mail and delete this e-mail and its attachments from your system. Thank you.
PROBLEM: After a warm reset, we can not reconfigurate the FPGA over a "Altera Remote Update IP Core" in the uboot environment. If we read or write data from/to the base address 0xc0060000 (0xc0000000 HPS2FPGA AXI Bridge + 0x60000 Remote Update IP Core) we get the message in the uboot console and it is doing a reset:
******************************************************************************** * Error Message ******************************************************************************** data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<0ff9a570>] lr : [<0ff9a565>] sp : 0ff325f8 ip : 00000002 fp : 0ff33868 r10: 0ff33888 r9 : 00000001 r8 : 0ff32f60 r7 : 0ff32616 r6 : 00000000 r5 : 0ff32617 r4 : 00780000 r3 : c0000000 r2 : 00000076 r1 : 0000000a r0 : 00000014 Flags: nzcv IRQs on FIQs off Mode SVC_32 Resetting CPU ...
resetting ...
U-Boot SPL 2013.01.01-svn2322 (Dec 06 2016 - 12:04:55) BOARD : Altera SOCFPGA Cyclone V Board CLOCK: EOSC1 clock 50000 KHz ...... ...... ********************************************************************************
GENERAL INFORMATION: We have all our software images stored in a QSPI flash (Preloader, DeviceTree, Uboot, SW-Image 0, SW-Image1, SW-Image2) except the fpga image is in the EPCQ flash (Addr: 0x0 FPGA-Image0, Addr: 0x780000 FPGA-Image1). After a cold resest the preloader will be loaded after the uboot. The uboot write into the RU_PAGE_SELECT register (base address: 0xc006000C) from the "Altera Remote Update IP Core" the address of the FPGA-Image0 (0x780000) and triggers a reconfiguration with writing "1" into the RU_RECONFIG register. The fpga reconfiguration is working and the kernel is booting one of these 3 software images. When we are doing a reboot (shutdown -r) the device is doing a warm reset. (side note: we had a problem to reboot the device with a 4Bit QSPI flash. We adapted our hardware and resets the QSPI flash with the nRST signal -> We changed the default value to 0x20000 (rstmgr, register counts, name nrstcnt = 0x20000).
WHAT WE TRIED: We tried to reconfigure (cf. "Reconfig FPGA!...") the fpga with a *.rbf stored on the sd card + we disable and enable all bridges. This works fine on a warm and cold reset (cf. "fpga Status register: mode 0x4" -> FPGA in User Mode).
After the console print ("START -------------") we are reading the register from a region global register and from the Altera Remote Update IP core the RU_PAGE_SELECT regsiter write 0x780000 into this register and triggers a reconfiguration. But this works only on a cold reset!
******************************************************************************** * Cold reset start up ******************************************************************************** U-Boot 2013.01.01 (Dec 07 2016 - 14:19:06)
CPU : Altera SOCFPGA Platform BOARD : Altera SOCFPGA Cyclone V Board I2C: ready DRAM: 256 MiB MMC: ALTERA DWMMC: 0 SF: Read data capture delay calibrated to 4 (1 - 7) SF: Detected N25Q00 with page size 65536, total: 134217728 In: serial Out: serial Err: serial Skipped ethaddr assignment due to invalid EMAC address in EEPROM Net: mii0 Warning: failed to set MAC address
Hit any key to stop autoboot: 0 set cycles tmp1: 0x200000a fpga Status register: 0x9c Reconfig FPGA!... ## Starting application at 0x0FF78550 ... ## Application terminated, rc = 0x0 reading output_file_128.rbf 4244820 bytes read in 236 ms (17.2 MiB/s) ## Starting application at 0x0FF78550 ... ## Application terminated, rc = 0x0 done! fpga Status register: mode 0x4 fpga Status register: msel 0x13 Cold reset detected! ENV_NAME_BOOT_MODE: 0 reconfiguration GW factory START ------------- (1xx) RegionGlobal: 0x0 (2xx) RU_PAGE_SELECT: 0x0 (1) epcqGatewareImageAddress: 0x780000 (2*) (2) (3) (4) (5) RU_RECONFIG_TRIGGER_CONDITIONS: 0x4 RU_PAGE_SELECT: 0x0 ********************************************** SND-Settings qspibootimageaddr: 0x400000 snd_statusSoftwareFactory: 0 snd_statusSoftwareUpdated0: 1 snd_statusSoftwareUpdated1: 1 snd_versionSoftwareFactory: - snd_versionSoftwareUpdated0: - snd_versionSoftwareUpdated1: - snd_watchdogOccurred: 0 ********************************************** ## Starting application at 0x0FF78550 ... ## Application terminated, rc = 0x0 SF: Detected N25Q00 with page size 65536, total: 134217728 ## Booting kernel from Legacy Image at 00007fc0 ... Image Name: Linux kernel Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 16114704 Bytes = 15.4 MiB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK ## Flattened Device Tree blob at 00000100 Booting using the fdt blob at 0x00000100 XIP Kernel Image ... OK OK Loading Device Tree to 03ff6000, end 03fff058 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
After a warm reset we have no access to the fpga over the Altera Remote Update IP core, although its the same uboot softwarecode!
******************************************************************************** * WARM reset start up ********************************************************************************
U-Boot SPL 2013.01.01-svn2322 (Dec 06 2016 - 12:04:55) BOARD : Altera SOCFPGA Cyclone V Board CLOCK: EOSC1 clock 50000 KHz CLOCK: EOSC2 clock 50000 KHz CLOCK: F2S_SDR_REF clock 0 KHz CLOCK: F2S_PER_REF clock 0 KHz CLOCK: MPU clock 800 MHz CLOCK: DDR clock 400 MHz CLOCK: UART clock 100000 KHz CLOCK: MMC clock 50000 KHz CLOCK: QSPI clock 400000 KHz RESET: WARM SDRAM: Initializing MMR registers SDRAM: Calibrating PHY SEQ.C: Preparing to start memory calibration SEQ.C: CALIBRATION PASSED SDRAM: 256 MiB SF: Read data capture delay calibrated to 4 (1 - 7) SF: Detected N25Q00 with page size 65536, total: 134217728
Hit any key to stop autoboot: 0 set cycles tmp1: 0x200000a fpga Status register: 0x9c Reconfig FPGA!... ## Starting application at 0x0FF78550 ... ## Application terminated, rc = 0x0 reading output_file_128.rbf 4244820 bytes read in 236 ms (17.2 MiB/s) ## Starting application at 0x0FF78550 ... ## Application terminated, rc = 0x0 done! fpga Status register: mode 0x4 fpga Status register: msel 0x13 Warm reset detected! ENV_NAME_BOOT_MODE: 0 do FPGA reset reconfiguration GW factory START ------------- data abort
resetting ...
Hit any key to stop autoboot: 0 SOCFPGA_CYCLONE5 #
This is the code snippet where the error occurs.
******************************************************************************** * Imported code snippet ********************************************************************************
#define ARU_BASE_ADDRESS 0xc0060000 #define FPGA_BASE_ADDRESS 0xc0000000
printf("START -------------\n"); tmp32 = (uint32_t) ioread32(FPGA_BASEADDRESS); printf("(1xx) RegionGlobal: 0x%x\n", tmp32); printf("(2xx) RU_PAGE_SELECT: 0x%x\n", ioread32(ALTREMOTE_BASE_ADDRESS + RU_PAGE_SELECT));
We have no idea why we have not access to the FPGA over the Altera Remote Update IP Core.
Please let me know if you need more details.
Oehen, Marcel
