[U-Boot] [PATCH] AT91 rework: fix TOP9000 files to build again
Fix EMK TOP9000 board to build again: - changes required due to ATMEL rework
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- board/emk/top9000/top9000.c | 64 +++++++++++++++++++++++------------------- include/configs/top9000.h | 30 ++++++++++---------- 2 files changed, 50 insertions(+), 44 deletions(-)
diff --git a/board/emk/top9000/top9000.c b/board/emk/top9000/top9000.c index 73dd706..3964bf1 100644 --- a/board/emk/top9000/top9000.c +++ b/board/emk/top9000/top9000.c @@ -31,7 +31,8 @@ #include <mmc.h> #include <i2c.h> #include <spi.h> -#include <asm/arch/at91sam9260.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> @@ -39,35 +40,35 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/at91_shdwn.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> -#include <asm/arch/hardware.h>
DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_CMD_NAND static void nand_hw_init(void) { + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; unsigned long csa;
- /* Enable CS3 */ - csa = at91_sys_read(AT91_MATRIX_EBICSA); - at91_sys_write(AT91_MATRIX_EBICSA, - csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + /* Assign CS3 to NAND/SmartMedia Interface */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa);
/* Configure SMC CS3 for NAND/SmartMedia */ - at91_sys_write(AT91_SMC_SETUP(3), - AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | - AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), - AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | - AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); - at91_sys_write(AT91_SMC_CYCLE(3), - AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); - at91_sys_write(AT91_SMC_MODE(3), - AT91_SMC_READMODE | AT91_SMC_WRITEMODE | - AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | - AT91_SMC_TDF_(2)); + writel( AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel( AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel( AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5), + &smc->cs[3].cycle); + writel( AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(2), + &smc->cs[3].mode);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -80,8 +81,10 @@ static void nand_hw_init(void) #ifdef CONFIG_MACB static void macb_hw_init(void) { + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + /* Enable EMAC clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer);
/* Initialize EMAC=MACB hardware */ at91_macb_hw_init(); @@ -92,14 +95,16 @@ static void macb_hw_init(void) /* this is a weak define that we are overriding */ int board_mmc_init(bd_t *bd) { + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + /* Enable MCI clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_MCI); + writel(1 << ATMEL_ID_MCI, &pmc->pcer);
/* Initialize MCI hardware */ at91_mci_hw_init();
/* This calls the atmel_mmc_init in gen_atmel_mci.c */ - return atmel_mci_init((void *)AT91_BASE_MCI); + return atmel_mci_init((void *)ATMEL_BASE_MCI); }
/* this is a weak define that we are overriding */ @@ -120,7 +125,8 @@ int board_mmc_getcd(u8 *cd, struct mmc *mmc)
int board_early_init_f(void) { - struct at91_shdwn *shdwn = (struct at91_shdwn *)AT91_SHDWN_BASE; + struct at91_shdwn *shdwn = (struct at91_shdwn *)ATMEL_BASE_SHDWN; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* * make sure the board can be powered on by @@ -130,9 +136,9 @@ int board_early_init_f(void) &shdwn->mr);
/* Enable clocks for all PIOs */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOA); - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOB); - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + writel( (1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC), + &pmc->pcer);
/* set SCL0 and SDA0 to open drain */ at91_set_pio_output(I2C0_PORT, SCL0_PIN, 1); @@ -159,7 +165,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_serial_hw_init(); + at91_seriald_hw_init(); #ifdef CONFIG_CMD_NAND nand_hw_init(); #endif @@ -211,7 +217,7 @@ int board_eth_init(bd_t *bis) int num = 0; #ifdef CONFIG_MACB rc = macb_eth_initialize(0, - (void *)AT91_EMAC_BASE, + (void *)ATMEL_BASE_EMAC0, CONFIG_SYS_PHY_ID); if (!rc) num++; diff --git a/include/configs/top9000.h b/include/configs/top9000.h index 5f0160d..5bca6e1 100644 --- a/include/configs/top9000.h +++ b/include/configs/top9000.h @@ -38,6 +38,10 @@ #ifndef __CONFIG_H #define __CONFIG_H
+/* SoC must be defined first, before hardware.h is included */ +#define CONFIG_AT91SAM9XE +#include <asm/hardware.h> + /* * Warning: changing CONFIG_SYS_TEXT_BASE requires * adapting the initial boot program. @@ -61,17 +65,11 @@ #define CONFIG_CMD_CACHE
/* ARM asynchronous clock */ -#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* 18.432 MHz xtal */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* main clock xtal */ #define CONFIG_SYS_HZ 1000
-/* SoC */ -#define CONFIG_ARM926EJS /* ARM926EJS Core */ -#define CONFIG_AT91FAMILY /* it's a member of AT91 */ -#define CONFIG_AT91SAM9260 /* Atmel AT91SAM9260 based SoC */ -#define CONFIG_AT91SAM9XE - /* Misc CPU related */ -#define CONFIG_AT91_LEGACY #define CONFIG_ARCH_CPU_INIT #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ @@ -83,12 +81,14 @@ #define CONFIG_AT91RESET_EXTRST /* assert external reset */
/* general purpose I/O */ +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ #define CONFIG_ATMEL_USART -#define CONFIG_USART3 /* USART 3 is DBGU !!! */ +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 }
@@ -123,7 +123,7 @@ * with u-boot commands */ # define CONFIG_AT91_EFLASH -# define CONFIG_SYS_FLASH_BASE 0x200000 +# define CONFIG_SYS_FLASH_BASE ATMEL_BASE_FLASH # define CONFIG_SYS_MAX_FLASH_SECT 32 # define CONFIG_SYS_MAX_FLASH_BANKS 1 # define CONFIG_SYS_FLASH_PROTECTION @@ -159,10 +159,10 @@ * Initialized before u-boot gets started. */ #define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 #define CONFIG_SYS_SDRAM_SIZE 0x08000000 #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END 0x21e00000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x01e00000) #define CONFIG_SYS_LOAD_ADDR \ (CONFIG_SYS_SDRAM_BASE + 0x01000000) /* @@ -171,7 +171,7 @@ * that address while providing maximum stack area below. */ #define CONFIG_SYS_INIT_SP_ADDR \ - (0x00300000 + 0x4000 - GENERATED_GBL_DATA_SIZE) + (ATMEL_BASE_SRAM + 0x4000 - GENERATED_GBL_DATA_SIZE)
/* * NAND flash: 256 MB (optional) @@ -184,7 +184,7 @@ */ #define CONFIG_NAND_ATMEL #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 #define CONFIG_SYS_NAND_DBW_8 #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) @@ -197,7 +197,7 @@ #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT -#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE #define CONFIG_SYS_USB_OHCI_SLOT_NAME "top9000" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE
Dear Reinhard Meyer,
Applied to u-boot-atmel/master (after fixing whitespace errors), thanks.
Reinhard Meyer
