[U-Boot] [PULL] u-boot-usb/master
The following changes since commit ab77f24119e80257de4ab017b877f92f96980562:
Merge branch 'master' of git://git.denx.de/u-boot-ti (2015-01-16 10:25:01 -0500)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 119339759266b81af1aa8883702b6b651d7752dd:
usb: eth: asix88179: add ability to modify MAC address (2015-01-18 12:31:36 +0100)
---------------------------------------------------------------- Alex Sadovsky (1): usb: gadget: pxa25x_udc: fix use-before-initialized bug
Hans de Goede (13): USB: make "usb start" start usb only once config_distro_bootcmd.h: Remove unnecessary magic to avoid repeated USB scans usb: Add an interval parameter to create_int_queue usb: Fix usb_kbd_deregister when console-muxing is used usb: Do not log an error when no devices is plugged into a root-hub-less hcd musb-new: Add register defines for different reg layout on sunxi musb-new: Add sunxi musb controller support musb-new: Use time based timeouts rather then cpu-cycles based timeouts musb-new: Fix interrupt transfers not working musb-new: Fix reset sequence when in host mode musb-new: Properly remove a transfer from the schedule on timeout musb-new: Add urb and hep parameters to construct_urb musb-new: Add interrupt queue support
Rene Griessl (1): usb: eth: asix88179: add ability to modify MAC address
Stefan Roese (2): usb: gadget: composite: Fix NULL pointer crash in USB compliance test usb: gadget: f_dfu: Add get_alt function to pass the USB compliance test
common/cmd_usb.c | 48 +++++++++++------- common/usb.c | 11 +++-- common/usb_kbd.c | 10 +++- drivers/usb/eth/asix88179.c | 14 ++++++ drivers/usb/gadget/composite.c | 8 +++ drivers/usb/gadget/f_dfu.c | 8 +++ drivers/usb/gadget/pxa25x_udc.c | 4 +- drivers/usb/host/ehci-hcd.c | 4 +- drivers/usb/musb-new/Makefile | 1 + drivers/usb/musb-new/musb_host.c | 12 +++-- drivers/usb/musb-new/musb_host.h | 1 + drivers/usb/musb-new/musb_regs.h | 92 ++++++++++++++++++++++++++++++++++ drivers/usb/musb-new/musb_uboot.c | 178 +++++++++++++++++++++++++++++++++++++++++++++++------------------- drivers/usb/musb-new/sunxi.c | 279 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/musb-new/usb-compat.h | 1 + include/config_distro_bootcmd.h | 12 +---- include/usb.h | 14 ++++-- 17 files changed, 602 insertions(+), 95 deletions(-) create mode 100644 drivers/usb/musb-new/sunxi.c
