[U-Boot] [PATCHv2] cmd: Kconfig: Add a Kconfig options for a few CMD
Add the following CMD options to Kconfig:
CMD_BOOTZ CMD_ASKENV CMD_GREPENV CMD_USB_MASS_STORAGE CMD_FAT CMD_MII CMD_CACHE CMD_DFU CMD_EXT2 CMD_EXT4 CMD_EXT4_WRITE CMD_FS_GENERIC CMD_MMC
Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- v2: remove an extra CMD_DFU --- cmd/Kconfig | 72 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index fe8b4f0..ec7c054 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -160,6 +160,11 @@ config CMD_BOOTM help Boot an application image from the memory.
+config CMD_BOOTZ + bool "bootz" + help + Boot the Linux zImage + config CMD_BOOTEFI bool "bootefi" depends on EFI_LOADER @@ -210,6 +215,11 @@ endmenu
menu "Environment commands"
+config CMD_ASKENV + bool "ask for env variable" + help + Ask for environment variable + config CMD_EXPORTENV bool "env export" default y @@ -228,6 +238,11 @@ config CMD_EDITENV help Edit environment variable.
+config CMD_GREPENV + bool "search env" + help + Allow for searching environment variables + config CMD_SAVEENV bool "saveenv" default y @@ -341,6 +356,11 @@ config CMD_ARMFLASH help ARM Ltd reference designs flash partition access
+config CMD_MMC + bool "mmc" + help + MMC memory mapped support. + config CMD_NAND bool "nand" help @@ -366,6 +386,19 @@ config CMD_USB help USB support.
+config CMD_DFU + depends on CMD_USB + bool "dfu" + help + Enables the command "dfu" which is used to have U-Boot create a DFU + class device via USB. + +config CMD_USB_MASS_STORAGE + depends on CMD_USB + bool "UMS usb mass storage" + help + USB mass storage support + config CMD_FPGA bool "fpga" default y @@ -454,6 +487,11 @@ config CMD_NFS help Boot image via network using NFS protocol.
+config CMD_MII + bool "mii" + help + Enable MII utility commands. + config CMD_PING bool "ping" help @@ -508,6 +546,11 @@ config CMD_BLOCK_CACHE during development, but also allows the cache to be disabled when it might hurt performance (e.g. when using the ums command).
+config CMD_CACHE + bool "icache or dcache" + help + Enable the "icache" and "dcache" commands + config CMD_TIME bool "time" help @@ -612,4 +655,33 @@ config CMD_TPM_TEST
endmenu
+menu "Filesystem commands" +config CMD_EXT2 + bool "ext2 command support" + help + Enables EXT2 FS command + +config CMD_EXT4 + bool "ext4 command support" + help + Enables EXT4 FS command + +config CMD_EXT4_WRITE + depends on CMD_EXT4 + bool "ext4 write command support" + help + Enables EXT4 FS write command + +config CMD_FAT + bool "FAT command support" + help + Support for the FAT fs + +config CMD_FS_GENERIC + bool "filesystem commands" + help + Enables filesystem commands (e.g. load, ls) that work for multiple + fs types. +endmenu + endmenu
Hi Dinh,
Can you convert existing users with moveconfig.py?
Hi Simon,
On 04/21/2016 09:13 AM, Simon Glass wrote:
Hi Dinh,
Yes, I started doing the moveconfig, starting with ARM, but I saw Tom's message to hold off because it might conflict with his work. I'll be happy to do the moveconfig, when I get Tom's OK to move ahead.
Dinh
On Thu, Apr 21, 2016 at 09:18:59AM -0500, Dinh Nguyen wrote:
Hi Simon,
Hi Dinh,
The problem with doing moveconfig.py is that it does get conflict happy so easily. My intention with this patch at least is to set things up locally so I can do that and test it here, then push, to make life a bit easier.
Hi Simon,
Hi Dinh,
I am making progress on this front but there's much that had not already been converted, so I'm taking care of that first.
Update the config.h and defconfig files for the commands that 8e3c036 converted over to Kconfig
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-bcmcygnus/configs.h | 1 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - arch/arm/mach-kirkwood/include/mach/config.h | 2 -- arch/arm/mach-mvebu/include/mach/config.h | 1 - configs/10m50_defconfig | 1 + configs/3c120_defconfig | 1 + configs/A10-OLinuXino-Lime_defconfig | 7 +++++++ configs/A10s-OLinuXino-M_defconfig | 7 +++++++ configs/A13-OLinuXinoM_defconfig | 7 +++++++ configs/A13-OLinuXino_defconfig | 9 +++++++++ configs/A20-OLinuXino-Lime2_defconfig | 7 +++++++ configs/A20-OLinuXino-Lime_defconfig | 7 +++++++ configs/A20-OLinuXino_MICRO_defconfig | 7 +++++++ configs/A20-Olimex-SOM-EVB_defconfig | 7 +++++++ configs/Ainol_AW1_defconfig | 7 +++++++ configs/Ampe_A76_defconfig | 7 +++++++ configs/Auxtek-T003_defconfig | 7 +++++++ configs/Auxtek-T004_defconfig | 7 +++++++ configs/B4420QDS_NAND_defconfig | 3 +++ configs/B4420QDS_SPIFLASH_defconfig | 3 +++ configs/B4420QDS_defconfig | 3 +++ configs/B4860QDS_NAND_defconfig | 3 +++ configs/B4860QDS_SECURE_BOOT_defconfig | 3 +++ configs/B4860QDS_SPIFLASH_defconfig | 3 +++ configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 3 +++ configs/B4860QDS_defconfig | 3 +++ configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 3 +++ configs/BSC9131RDB_NAND_defconfig | 3 +++ configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 3 +++ configs/BSC9131RDB_SPIFLASH_defconfig | 3 +++ configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 4 ++++ configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 4 ++++ configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 4 ++++ configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 4 ++++ .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 4 ++++ .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 4 ++++ .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 4 ++++ .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 4 ++++ configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 4 ++++ configs/Bananapi_defconfig | 7 +++++++ configs/Bananapro_defconfig | 7 +++++++ configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_defconfig | 8 ++++++++ configs/CPCI4052_defconfig | 2 ++ configs/CSQ_CS908_defconfig | 7 +++++++ configs/Chuwi_V7_CW0825_defconfig | 7 +++++++ configs/Colombus_defconfig | 7 +++++++ configs/Cubieboard2_defconfig | 7 +++++++ configs/Cubieboard_defconfig | 7 +++++++ configs/Cubietruck_defconfig | 9 +++++++++ configs/Cubietruck_plus_defconfig | 7 +++++++ configs/Cyrus_P5020_defconfig | 5 +++++ configs/Cyrus_P5040_defconfig | 5 +++++ configs/Empire_electronix_d709_defconfig | 7 +++++++ configs/Hummingbird_A31_defconfig | 7 +++++++ configs/Hyundai_A7HD_defconfig | 7 +++++++ configs/Itead_Ibox_A20_defconfig | 7 +++++++ configs/Lamobo_R1_defconfig | 7 +++++++ configs/Linksprite_pcDuino3_Nano_defconfig | 7 +++++++ configs/Linksprite_pcDuino3_defconfig | 7 +++++++ configs/Linksprite_pcDuino_defconfig | 7 +++++++ configs/M5208EVBE_defconfig | 2 ++ configs/M52277EVB_defconfig | 1 + configs/M52277EVB_stmicro_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 2 ++ configs/M5235EVB_defconfig | 2 ++ configs/M5249EVB_defconfig | 1 + configs/M5253DEMO_defconfig | 3 +++ configs/M5253EVBE_defconfig | 3 +++ configs/M5272C3_defconfig | 2 ++ configs/M5275EVB_defconfig | 2 ++ configs/M5282EVB_defconfig | 2 ++ configs/M53017EVB_defconfig | 2 ++ configs/M5329AFEE_defconfig | 2 ++ configs/M5329BFEE_defconfig | 2 ++ configs/M5373EVB_defconfig | 2 ++ configs/M54418TWR_defconfig | 2 ++ configs/M54418TWR_nand_mii_defconfig | 2 ++ configs/M54418TWR_nand_rmii_defconfig | 2 ++ configs/M54418TWR_nand_rmii_lowfreq_defconfig | 2 ++ configs/M54418TWR_serial_mii_defconfig | 2 ++ configs/M54418TWR_serial_rmii_defconfig | 2 ++ configs/M54451EVB_defconfig | 2 ++ configs/M54451EVB_stmicro_defconfig | 2 ++ configs/M54455EVB_a66_defconfig | 4 ++++ configs/M54455EVB_defconfig | 4 ++++ configs/M54455EVB_i66_defconfig | 4 ++++ configs/M54455EVB_intel_defconfig | 4 ++++ configs/M54455EVB_stm33_defconfig | 4 ++++ configs/M5475AFE_defconfig | 2 ++ configs/M5475BFE_defconfig | 2 ++ configs/M5475CFE_defconfig | 2 ++ configs/M5475DFE_defconfig | 2 ++ configs/M5475EFE_defconfig | 2 ++ configs/M5475FFE_defconfig | 2 ++ configs/M5475GFE_defconfig | 2 ++ configs/M5485AFE_defconfig | 2 ++ configs/M5485BFE_defconfig | 2 ++ configs/M5485CFE_defconfig | 2 ++ configs/M5485DFE_defconfig | 2 ++ configs/M5485EFE_defconfig | 2 ++ configs/M5485FFE_defconfig | 2 ++ configs/M5485GFE_defconfig | 2 ++ configs/M5485HFE_defconfig | 2 ++ configs/MIP405T_defconfig | 3 +++ configs/MIP405_defconfig | 3 +++ configs/MK808C_defconfig | 7 +++++++ configs/MPC8308RDB_defconfig | 3 +++ configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 2 ++ configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_ATM_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC832XEMDS_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 3 +++ configs/MPC8349ITX_defconfig | 3 +++ configs/MPC837XEMDS_HOST_defconfig | 4 ++++ configs/MPC837XEMDS_defconfig | 4 ++++ configs/MPC837XERDB_defconfig | 4 ++++ configs/MPC8536DS_36BIT_defconfig | 4 ++++ configs/MPC8536DS_SDCARD_defconfig | 4 ++++ configs/MPC8536DS_SPIFLASH_defconfig | 4 ++++ configs/MPC8536DS_defconfig | 4 ++++ configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 2 ++ configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 4 ++++ configs/MPC8569MDS_defconfig | 4 ++++ configs/MPC8572DS_36BIT_defconfig | 2 ++ configs/MPC8572DS_defconfig | 2 ++ configs/MPC8610HPCD_defconfig | 2 ++ configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MSI_Primo73_defconfig | 7 +++++++ configs/MSI_Primo81_defconfig | 7 +++++++ configs/Marsboard_A10_defconfig | 7 +++++++ configs/Mele_A1000G_quad_defconfig | 7 +++++++ configs/Mele_A1000_defconfig | 7 +++++++ configs/Mele_I7_defconfig | 7 +++++++ configs/Mele_M3_defconfig | 7 +++++++ configs/Mele_M5_defconfig | 7 +++++++ configs/Mele_M9_defconfig | 7 +++++++ configs/Merrii_A80_Optimus_defconfig | 7 +++++++ configs/Mini-X_defconfig | 7 +++++++ configs/MiniFAP_defconfig | 4 ++++ configs/O2D300_defconfig | 2 ++ configs/O2DNT2_RAMBOOT_defconfig | 2 ++ configs/O2DNT2_defconfig | 2 ++ configs/O2D_defconfig | 2 ++ configs/O2I_defconfig | 2 ++ configs/O2MNT_O2M110_defconfig | 2 ++ configs/O2MNT_O2M112_defconfig | 2 ++ configs/O2MNT_O2M113_defconfig | 2 ++ configs/O2MNT_defconfig | 2 ++ configs/O3DNT_defconfig | 2 ++ configs/Orangepi_defconfig | 7 +++++++ configs/Orangepi_mini_defconfig | 7 +++++++ configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_NAND_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 4 ++++ .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_NAND_defconfig | 4 ++++ configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_NOR_defconfig | 4 ++++ configs/P1010RDB-PA_SDCARD_defconfig | 4 ++++ configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_SPIFLASH_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 4 ++++ .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_NAND_defconfig | 4 ++++ configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_NOR_defconfig | 4 ++++ configs/P1010RDB-PB_SDCARD_defconfig | 4 ++++ configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_SPIFLASH_defconfig | 4 ++++ configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1020MBG-PC_36BIT_defconfig | 4 ++++ configs/P1020MBG-PC_SDCARD_defconfig | 4 ++++ configs/P1020MBG-PC_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_defconfig | 4 ++++ configs/P1020RDB-PC_NAND_defconfig | 4 ++++ configs/P1020RDB-PC_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PC_defconfig | 4 ++++ configs/P1020RDB-PD_NAND_defconfig | 4 ++++ configs/P1020RDB-PD_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PD_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PD_defconfig | 4 ++++ configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1020UTM-PC_36BIT_defconfig | 4 ++++ configs/P1020UTM-PC_SDCARD_defconfig | 4 ++++ configs/P1020UTM-PC_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_defconfig | 4 ++++ configs/P1021RDB-PC_NAND_defconfig | 4 ++++ configs/P1021RDB-PC_SDCARD_defconfig | 4 ++++ configs/P1021RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P1021RDB-PC_defconfig | 4 ++++ configs/P1022DS_36BIT_NAND_defconfig | 4 ++++ configs/P1022DS_36BIT_SDCARD_defconfig | 4 ++++ configs/P1022DS_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1022DS_36BIT_defconfig | 4 ++++ configs/P1022DS_NAND_defconfig | 4 ++++ configs/P1022DS_SDCARD_defconfig | 4 ++++ configs/P1022DS_SPIFLASH_defconfig | 4 ++++ configs/P1022DS_defconfig | 4 ++++ configs/P1023RDB_defconfig | 3 +++ configs/P1024RDB_36BIT_defconfig | 4 ++++ configs/P1024RDB_NAND_defconfig | 4 ++++ configs/P1024RDB_SDCARD_defconfig | 4 ++++ configs/P1024RDB_SPIFLASH_defconfig | 4 ++++ configs/P1024RDB_defconfig | 4 ++++ configs/P1025RDB_36BIT_defconfig | 4 ++++ configs/P1025RDB_NAND_defconfig | 4 ++++ configs/P1025RDB_SDCARD_defconfig | 4 ++++ configs/P1025RDB_SPIFLASH_defconfig | 4 ++++ configs/P1025RDB_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_defconfig | 4 ++++ configs/P2020RDB-PC_NAND_defconfig | 4 ++++ configs/P2020RDB-PC_SDCARD_defconfig | 4 ++++ configs/P2020RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P2020RDB-PC_defconfig | 4 ++++ configs/P2041RDB_NAND_defconfig | 5 +++++ configs/P2041RDB_SDCARD_defconfig | 5 +++++ configs/P2041RDB_SECURE_BOOT_defconfig | 5 +++++ configs/P2041RDB_SPIFLASH_defconfig | 5 +++++ configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P2041RDB_defconfig | 5 +++++ configs/P3041DS_NAND_SECURE_BOOT_defconfig | 5 +++++ configs/P3041DS_NAND_defconfig | 5 +++++ configs/P3041DS_SDCARD_defconfig | 5 +++++ configs/P3041DS_SECURE_BOOT_defconfig | 5 +++++ configs/P3041DS_SPIFLASH_defconfig | 5 +++++ configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P3041DS_defconfig | 5 +++++ configs/P4080DS_SDCARD_defconfig | 5 +++++ configs/P4080DS_SECURE_BOOT_defconfig | 5 +++++ configs/P4080DS_SPIFLASH_defconfig | 5 +++++ configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P4080DS_defconfig | 5 +++++ configs/P5020DS_NAND_SECURE_BOOT_defconfig | 5 +++++ configs/P5020DS_NAND_defconfig | 5 +++++ configs/P5020DS_SDCARD_defconfig | 5 +++++ configs/P5020DS_SECURE_BOOT_defconfig | 5 +++++ configs/P5020DS_SPIFLASH_defconfig | 5 +++++ configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P5020DS_defconfig | 5 +++++ configs/P5040DS_NAND_SECURE_BOOT_defconfig | 5 +++++ configs/P5040DS_NAND_defconfig | 5 +++++ configs/P5040DS_SDCARD_defconfig | 5 +++++ configs/P5040DS_SECURE_BOOT_defconfig | 5 +++++ configs/P5040DS_SPIFLASH_defconfig | 5 +++++ configs/P5040DS_defconfig | 5 +++++ configs/PIP405_defconfig | 3 +++ configs/PLU405_defconfig | 2 ++ configs/PMC405DE_defconfig | 1 + configs/PMC440_defconfig | 2 ++ configs/Sinlinx_SinA31s_defconfig | 7 +++++++ configs/Sinlinx_SinA33_defconfig | 7 +++++++ configs/Sinovoip_BPI_M2_defconfig | 7 +++++++ configs/Sinovoip_BPI_M3_defconfig | 7 +++++++ configs/T1023RDB_NAND_defconfig | 5 +++++ configs/T1023RDB_SDCARD_defconfig | 5 +++++ configs/T1023RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1023RDB_SPIFLASH_defconfig | 5 +++++ configs/T1023RDB_defconfig | 5 +++++ configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 5 +++++ configs/T1024QDS_DDR4_defconfig | 5 +++++ configs/T1024QDS_NAND_defconfig | 5 +++++ configs/T1024QDS_SDCARD_defconfig | 5 +++++ configs/T1024QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T1024QDS_SPIFLASH_defconfig | 5 +++++ configs/T1024QDS_defconfig | 5 +++++ configs/T1024RDB_NAND_defconfig | 5 +++++ configs/T1024RDB_SDCARD_defconfig | 5 +++++ configs/T1024RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1024RDB_SPIFLASH_defconfig | 5 +++++ configs/T1024RDB_defconfig | 5 +++++ configs/T1040D4RDB_NAND_defconfig | 5 +++++ configs/T1040D4RDB_SDCARD_defconfig | 5 +++++ configs/T1040D4RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1040D4RDB_SPIFLASH_defconfig | 5 +++++ configs/T1040D4RDB_defconfig | 5 +++++ configs/T1040QDS_DDR4_defconfig | 5 +++++ configs/T1040QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T1040QDS_defconfig | 5 +++++ configs/T1040RDB_NAND_defconfig | 5 +++++ configs/T1040RDB_SDCARD_defconfig | 5 +++++ configs/T1040RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1040RDB_SPIFLASH_defconfig | 5 +++++ configs/T1040RDB_defconfig | 5 +++++ configs/T1042D4RDB_NAND_defconfig | 5 +++++ configs/T1042D4RDB_SDCARD_defconfig | 5 +++++ configs/T1042D4RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1042D4RDB_SPIFLASH_defconfig | 5 +++++ configs/T1042D4RDB_defconfig | 5 +++++ configs/T1042RDB_PI_NAND_defconfig | 5 +++++ configs/T1042RDB_PI_SDCARD_defconfig | 5 +++++ configs/T1042RDB_PI_SPIFLASH_defconfig | 5 +++++ configs/T1042RDB_PI_defconfig | 5 +++++ configs/T1042RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1042RDB_defconfig | 5 +++++ configs/T2080QDS_NAND_defconfig | 5 +++++ configs/T2080QDS_SDCARD_defconfig | 5 +++++ configs/T2080QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T2080QDS_SPIFLASH_defconfig | 5 +++++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/T2080QDS_defconfig | 5 +++++ configs/T2080RDB_NAND_defconfig | 4 ++++ configs/T2080RDB_SDCARD_defconfig | 4 ++++ configs/T2080RDB_SECURE_BOOT_defconfig | 4 ++++ configs/T2080RDB_SPIFLASH_defconfig | 4 ++++ configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 4 ++++ configs/T2080RDB_defconfig | 4 ++++ configs/T2081QDS_NAND_defconfig | 5 +++++ configs/T2081QDS_SDCARD_defconfig | 5 +++++ configs/T2081QDS_SPIFLASH_defconfig | 5 +++++ configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/T2081QDS_defconfig | 5 +++++ configs/T4160QDS_NAND_defconfig | 5 +++++ configs/T4160QDS_SDCARD_defconfig | 5 +++++ configs/T4160QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T4160QDS_defconfig | 5 +++++ configs/T4160RDB_defconfig | 5 +++++ configs/T4240QDS_NAND_defconfig | 5 +++++ configs/T4240QDS_SDCARD_defconfig | 5 +++++ configs/T4240QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/T4240QDS_defconfig | 5 +++++ configs/T4240RDB_SDCARD_defconfig | 5 +++++ configs/T4240RDB_defconfig | 5 +++++ configs/TQM5200S_HIGHBOOT_defconfig | 4 ++++ configs/TQM5200S_defconfig | 4 ++++ configs/TQM5200_B_HIGHBOOT_defconfig | 4 ++++ configs/TQM5200_B_defconfig | 4 ++++ configs/TQM5200_STK100_defconfig | 4 ++++ configs/TQM5200_defconfig | 4 ++++ configs/TQM823L_LCD_defconfig | 2 ++ configs/TQM823L_defconfig | 2 ++ configs/TQM823M_defconfig | 2 ++ configs/TQM834x_defconfig | 2 ++ configs/TQM850L_defconfig | 2 ++ configs/TQM850M_defconfig | 2 ++ configs/TQM855L_defconfig | 2 ++ configs/TQM855M_defconfig | 2 ++ configs/TQM860L_defconfig | 2 ++ configs/TQM860M_defconfig | 2 ++ configs/TQM862L_defconfig | 2 ++ configs/TQM862M_defconfig | 2 ++ configs/TQM866M_defconfig | 2 ++ configs/TQM885D_defconfig | 3 +++ configs/TTTech_defconfig | 2 ++ configs/TWR-P1025_defconfig | 4 ++++ configs/UCP1020_SPIFLASH_defconfig | 4 ++++ configs/UCP1020_defconfig | 4 ++++ configs/UTOO_P66_defconfig | 7 +++++++ configs/VCMA9_defconfig | 2 ++ configs/VOM405_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 7 +++++++ configs/Wits_Pro_A20_DKT_defconfig | 7 +++++++ configs/Wobo_i5_defconfig | 7 +++++++ configs/Yones_Toptech_BD1078_defconfig | 7 +++++++ configs/Yones_Toptech_BS1078_V2_defconfig | 7 +++++++ configs/a3m071_defconfig | 2 ++ configs/a4m072_defconfig | 2 ++ configs/a4m2k_defconfig | 2 ++ configs/ac14xx_defconfig | 2 ++ configs/acadia_defconfig | 3 +++ configs/adp-ag101p_defconfig | 4 ++++ configs/alt_defconfig | 7 +++++++ configs/am335x_baltos_defconfig | 9 +++++++++ configs/am335x_boneblack_defconfig | 10 ++++++++++ configs/am335x_boneblack_vboot_defconfig | 10 ++++++++++ configs/am335x_evm_defconfig | 10 ++++++++++ configs/am335x_evm_nor_defconfig | 10 ++++++++++ configs/am335x_evm_norboot_defconfig | 10 ++++++++++ configs/am335x_evm_spiboot_defconfig | 10 ++++++++++ configs/am335x_evm_usbspl_defconfig | 10 ++++++++++ configs/am335x_gp_evm_defconfig | 10 ++++++++++ configs/am335x_igep0033_defconfig | 9 +++++++++ configs/am335x_sl50_defconfig | 9 +++++++++ configs/am3517_crane_defconfig | 3 +++ configs/am3517_evm_defconfig | 9 +++++++++ configs/am437x_gp_evm_defconfig | 10 ++++++++++ configs/am437x_sk_evm_defconfig | 10 ++++++++++ configs/am43xx_evm_defconfig | 10 ++++++++++ configs/am43xx_evm_ethboot_defconfig | 10 ++++++++++ configs/am43xx_evm_qspiboot_defconfig | 10 ++++++++++ configs/am43xx_evm_usbhost_boot_defconfig | 10 ++++++++++ configs/am57xx_evm_defconfig | 9 +++++++++ configs/am57xx_evm_nodt_defconfig | 9 +++++++++ configs/amcore_defconfig | 1 + configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 1 + configs/apalis_t30_defconfig | 10 ++++++++++ configs/apf27_defconfig | 6 ++++++ configs/apx4devkit_defconfig | 5 +++++ configs/arches_defconfig | 4 ++++ configs/aria_defconfig | 2 ++ configs/aristainetos2_defconfig | 9 +++++++++ configs/aristainetos2b_defconfig | 9 +++++++++ configs/aristainetos_defconfig | 9 +++++++++ configs/armadillo-800eva_defconfig | 2 ++ configs/arndale_defconfig | 9 +++++++++ configs/astro_mcf5373l_defconfig | 1 + configs/at91rm9200ek_defconfig | 3 +++ configs/at91rm9200ek_ram_defconfig | 3 +++ configs/at91sam9260ek_dataflash_cs0_defconfig | 2 ++ configs/at91sam9260ek_dataflash_cs1_defconfig | 2 ++ configs/at91sam9260ek_nandflash_defconfig | 2 ++ configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9263ek_dataflash_defconfig | 3 +++ configs/at91sam9263ek_nandflash_defconfig | 3 +++ configs/at91sam9263ek_norflash_boot_defconfig | 3 +++ configs/at91sam9263ek_norflash_defconfig | 3 +++ configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 3 +++ configs/at91sam9g20ek_2mmc_nandflash_defconfig | 3 +++ configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 ++ configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 ++ configs/at91sam9g20ek_nandflash_defconfig | 2 ++ configs/at91sam9m10g45ek_mmc_defconfig | 3 +++ configs/at91sam9m10g45ek_nandflash_defconfig | 3 +++ configs/at91sam9n12ek_mmc_defconfig | 3 +++ configs/at91sam9n12ek_nandflash_defconfig | 3 +++ configs/at91sam9n12ek_spiflash_defconfig | 3 +++ configs/at91sam9rlek_dataflash_defconfig | 3 +++ configs/at91sam9rlek_mmc_defconfig | 3 +++ configs/at91sam9rlek_nandflash_defconfig | 3 +++ configs/at91sam9x5ek_dataflash_defconfig | 3 +++ configs/at91sam9x5ek_mmc_defconfig | 3 +++ configs/at91sam9x5ek_nandflash_defconfig | 3 +++ configs/at91sam9x5ek_spiflash_defconfig | 3 +++ configs/at91sam9xeek_dataflash_cs0_defconfig | 2 ++ configs/at91sam9xeek_dataflash_cs1_defconfig | 2 ++ configs/at91sam9xeek_nandflash_defconfig | 2 ++ configs/atngw100_defconfig | 4 ++++ configs/atngw100mkii_defconfig | 5 +++++ configs/atstk1002_defconfig | 4 ++++ configs/axm_defconfig | 1 + configs/axs101_defconfig | 2 ++ configs/axs103_defconfig | 2 ++ configs/ba10_tv_box_defconfig | 7 +++++++ configs/bamboo_defconfig | 6 ++++++ configs/bayleybay_defconfig | 6 ++++++ configs/bcm11130_defconfig | 5 +++++ configs/bcm11130_nand_defconfig | 5 +++++ configs/bcm28155_ap_defconfig | 5 +++++ configs/bcm28155_w1d_defconfig | 5 +++++ configs/bcm911360_entphn-ns_defconfig | 5 +++++ configs/bcm911360_entphn_defconfig | 5 +++++ configs/bcm911360k_defconfig | 5 +++++ configs/bcm958300k-ns_defconfig | 5 +++++ configs/bcm958300k_defconfig | 5 +++++ configs/bcm958305k_defconfig | 5 +++++ configs/bcm958622hr_defconfig | 4 ++++ configs/bct-brettl2_defconfig | 2 ++ configs/beaver_defconfig | 10 ++++++++++ configs/bf518f-ezbrd_defconfig | 5 +++++ configs/bf526-ezbrd_defconfig | 4 ++++ configs/bf527-ad7160-eval_defconfig | 4 ++++ configs/bf527-ezkit-v2_defconfig | 4 ++++ configs/bf527-ezkit_defconfig | 4 ++++ configs/bf527-sdp_defconfig | 1 + configs/bf533-ezkit_defconfig | 1 + configs/bf533-stamp_defconfig | 1 + configs/bf537-minotaur_defconfig | 1 + configs/bf537-pnav_defconfig | 2 ++ configs/bf537-srv1_defconfig | 1 + configs/bf537-stamp_defconfig | 5 +++++ configs/bf538f-ezkit_defconfig | 1 + configs/bf548-ezkit_defconfig | 4 ++++ configs/bf561-acvilon_defconfig | 2 ++ configs/bf561-ezkit_defconfig | 1 + configs/bf609-ezkit_defconfig | 5 +++++ configs/bg0900_defconfig | 3 +++ configs/birdland_bav335a_defconfig | 11 +++++++++++ configs/birdland_bav335b_defconfig | 11 +++++++++++ configs/blackstamp_defconfig | 1 + configs/blackvme_defconfig | 2 ++ configs/br4_defconfig | 2 ++ configs/bubinga_defconfig | 3 +++ configs/caddy2_defconfig | 1 + configs/cairo_defconfig | 9 +++++++++ configs/calimain_defconfig | 2 ++ configs/cam5200_defconfig | 2 ++ configs/cam5200_niosflash_defconfig | 2 ++ configs/canmb_defconfig | 2 ++ configs/canyonlands_defconfig | 6 ++++++ configs/cardhu_defconfig | 8 ++++++++ configs/cgtqmx6eval_defconfig | 11 +++++++++++ configs/charon_defconfig | 4 ++++ configs/chromebook_jerry_defconfig | 8 ++++++++ configs/chromebook_link_defconfig | 5 +++++ configs/chromebook_samus_defconfig | 5 +++++ configs/chromebox_panther_defconfig | 5 +++++ configs/clearfog_defconfig | 8 ++++++++ configs/cm-bf527_defconfig | 2 ++ configs/cm-bf533_defconfig | 1 + configs/cm-bf537e_defconfig | 5 +++++ configs/cm-bf537u_defconfig | 4 ++++ configs/cm-bf548_defconfig | 1 + configs/cm-bf561_defconfig | 1 + configs/cm5200_defconfig | 3 +++ configs/cm_fx6_defconfig | 9 +++++++++ configs/cm_t335_defconfig | 9 +++++++++ configs/cm_t3517_defconfig | 5 +++++ configs/cm_t35_defconfig | 5 +++++ configs/cm_t43_defconfig | 9 +++++++++ configs/cm_t54_defconfig | 9 +++++++++ configs/colibri_pxa270_defconfig | 3 +++ configs/colibri_t20_defconfig | 11 +++++++++++ configs/colibri_t30_defconfig | 10 ++++++++++ configs/colibri_vf_defconfig | 9 +++++++++ configs/colorfly_e708_q1_defconfig | 7 +++++++ configs/conga-qeval20-qa3-e3845_defconfig | 6 ++++++ .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 4 ++++ configs/controlcenterd_36BIT_SDCARD_defconfig | 4 ++++ .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 5 +++++ configs/corvus_defconfig | 2 ++ configs/cougarcanyon2_defconfig | 5 +++++ configs/crownbay_defconfig | 6 ++++++ configs/d2net_v2_defconfig | 3 +++ configs/da850_am18xxevm_defconfig | 5 +++++ configs/da850evm_defconfig | 5 +++++ configs/da850evm_direct_nor_defconfig | 2 ++ configs/dalmore_defconfig | 10 ++++++++++ configs/db-88f6720_defconfig | 6 ++++++ configs/db-88f6820-gp_defconfig | 7 +++++++ configs/db-mv784mp-gp_defconfig | 6 ++++++ configs/defconfig | 21 +++++++++++++++++++++ configs/devconcenter_defconfig | 6 ++++++ configs/devkit3250_defconfig | 3 +++ configs/devkit8000_defconfig | 4 ++++ configs/difrnce_dit4350_defconfig | 7 +++++++ configs/digsy_mtc_RAMBOOT_defconfig | 4 ++++ configs/digsy_mtc_defconfig | 4 ++++ configs/digsy_mtc_rev5_RAMBOOT_defconfig | 4 ++++ configs/digsy_mtc_rev5_defconfig | 4 ++++ configs/dlvision-10g_defconfig | 3 +++ configs/dlvision_defconfig | 3 +++ configs/dnp5370_defconfig | 1 + configs/dns325_defconfig | 3 +++ configs/dockstar_defconfig | 3 +++ configs/dra72_evm_defconfig | 10 ++++++++++ configs/dra74_evm_defconfig | 10 ++++++++++ configs/dra7xx_evm_defconfig | 10 ++++++++++ configs/dra7xx_evm_qspiboot_defconfig | 10 ++++++++++ configs/dra7xx_evm_uart3_defconfig | 10 ++++++++++ configs/draco_defconfig | 6 ++++++ configs/dragonboard410c_defconfig | 7 +++++++ configs/dreamplug_defconfig | 4 ++++ configs/ds414_defconfig | 3 +++ configs/dserve_dsrv9703c_defconfig | 7 +++++++ configs/duovero_defconfig | 9 +++++++++ configs/e2220-1170_defconfig | 9 +++++++++ configs/ea20_defconfig | 2 ++ configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/eco5pk_defconfig | 5 +++++ configs/ecovec_defconfig | 3 +++ configs/edb9315a_defconfig | 4 ++++ configs/edminiv2_defconfig | 1 + configs/efi-x86_defconfig | 5 +++++ configs/espt_defconfig | 1 + configs/ethernut5_defconfig | 6 ++++++ configs/evb-rk3036_defconfig | 8 ++++++++ configs/firefly-rk3288_defconfig | 8 ++++++++ configs/flea3_defconfig | 2 ++ configs/fo300_defconfig | 4 ++++ configs/ga10h_v1_1_defconfig | 7 +++++++ configs/galileo_defconfig | 6 ++++++ configs/gdppc440etx_defconfig | 4 ++++ configs/ge_b450v3_defconfig | 10 ++++++++++ configs/ge_b650v3_defconfig | 10 ++++++++++ configs/ge_b850v3_defconfig | 10 ++++++++++ configs/glacier_defconfig | 4 ++++ configs/glacier_ramboot_defconfig | 4 ++++ configs/goflexhome_defconfig | 4 ++++ configs/gose_defconfig | 7 +++++++ configs/gplugd_defconfig | 4 ++++ configs/grasshopper_defconfig | 1 + configs/gt90h_v4_defconfig | 7 +++++++ configs/guruplug_defconfig | 5 +++++ configs/gwventana_defconfig | 10 ++++++++++ configs/h8_homlet_v2_defconfig | 7 +++++++ configs/haleakala_defconfig | 3 +++ configs/harmony_defconfig | 8 ++++++++ configs/highbank_defconfig | 6 ++++++ configs/hikey_defconfig | 7 +++++++ configs/hrcon_defconfig | 3 +++ configs/hrcon_dh_defconfig | 3 +++ configs/i12-tvbox_defconfig | 7 +++++++ configs/iNet_3F_defconfig | 7 +++++++ configs/iNet_3W_defconfig | 7 +++++++ configs/iNet_86VS_defconfig | 7 +++++++ configs/ib62x0_defconfig | 4 ++++ configs/ibf-dsp561_defconfig | 1 + configs/icnova-a20-swac_defconfig | 7 +++++++ configs/icon_defconfig | 6 ++++++ configs/iconnect_defconfig | 3 +++ configs/ids8313_defconfig | 1 + configs/igep0020_defconfig | 10 ++++++++++ configs/igep0020_nand_defconfig | 10 ++++++++++ configs/igep0030_defconfig | 10 ++++++++++ configs/igep0030_nand_defconfig | 10 ++++++++++ configs/igep0032_defconfig | 10 ++++++++++ configs/inet1_defconfig | 7 +++++++ configs/inet97fv2_defconfig | 7 +++++++ configs/inet98v_rev2_defconfig | 7 +++++++ configs/inet9f_rev03_defconfig | 7 +++++++ configs/inetspace_v2_defconfig | 3 +++ configs/inka4x0_defconfig | 2 ++ configs/intip_defconfig | 6 ++++++ configs/io64_defconfig | 3 +++ configs/io_defconfig | 3 +++ configs/iocon_defconfig | 4 ++++ configs/ip04_defconfig | 1 + configs/ipam390_defconfig | 2 ++ configs/ipek01_defconfig | 2 ++ configs/jesurun_q5_defconfig | 7 +++++++ configs/jetson-tk1_defconfig | 10 ++++++++++ configs/k2e_evm_defconfig | 8 ++++++++ configs/k2g_evm_defconfig | 9 +++++++++ configs/k2hk_evm_defconfig | 8 ++++++++ configs/k2l_evm_defconfig | 8 ++++++++ configs/katmai_defconfig | 6 ++++++ configs/kc1_defconfig | 7 +++++++ configs/kilauea_defconfig | 3 +++ configs/km_kirkwood_128m16_defconfig | 3 +++ configs/km_kirkwood_defconfig | 3 +++ configs/km_kirkwood_pci_defconfig | 3 +++ configs/kmcoge4_defconfig | 3 +++ configs/kmcoge5ne_defconfig | 3 +++ configs/kmcoge5un_defconfig | 3 +++ configs/kmeter1_defconfig | 3 +++ configs/kmlion1_defconfig | 3 +++ configs/kmnusa_defconfig | 3 +++ configs/kmopti2_defconfig | 3 +++ configs/kmsugp1_defconfig | 3 +++ configs/kmsupx5_defconfig | 3 +++ configs/kmsuv31_defconfig | 3 +++ configs/kmtegr1_defconfig | 3 +++ configs/kmtepr2_defconfig | 3 +++ configs/kmvect1_defconfig | 3 +++ configs/koelsch_defconfig | 7 +++++++ configs/kwb_defconfig | 4 ++++ configs/kylin-rk3036_defconfig | 8 ++++++++ configs/kzm9g_defconfig | 2 ++ configs/lager_defconfig | 7 +++++++ configs/legoev3_defconfig | 5 +++++ configs/ls1021aqds_ddr4_nor_defconfig | 6 ++++++ configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 6 ++++++ configs/ls1021aqds_nand_defconfig | 6 ++++++ configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 6 ++++++ configs/ls1021aqds_nor_defconfig | 6 ++++++ configs/ls1021aqds_nor_lpuart_defconfig | 6 ++++++ configs/ls1021aqds_qspi_defconfig | 6 ++++++ configs/ls1021aqds_sdcard_ifc_defconfig | 6 ++++++ configs/ls1021aqds_sdcard_qspi_defconfig | 6 ++++++ configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 6 ++++++ configs/ls1021atwr_nor_defconfig | 6 ++++++ configs/ls1021atwr_nor_lpuart_defconfig | 6 ++++++ configs/ls1021atwr_qspi_defconfig | 6 ++++++ configs/ls1021atwr_sdcard_ifc_defconfig | 6 ++++++ configs/ls1021atwr_sdcard_qspi_defconfig | 6 ++++++ configs/ls1043aqds_defconfig | 7 +++++++ configs/ls1043aqds_lpuart_defconfig | 7 +++++++ configs/ls1043aqds_nand_defconfig | 7 +++++++ configs/ls1043aqds_nor_ddr3_defconfig | 7 +++++++ configs/ls1043aqds_qspi_defconfig | 7 +++++++ configs/ls1043aqds_sdcard_ifc_defconfig | 7 +++++++ configs/ls1043aqds_sdcard_qspi_defconfig | 7 +++++++ configs/ls1043ardb_SECURE_BOOT_defconfig | 5 +++++ configs/ls1043ardb_defconfig | 5 +++++ configs/ls1043ardb_nand_defconfig | 5 +++++ configs/ls1043ardb_sdcard_defconfig | 5 +++++ configs/ls2080a_emu_defconfig | 3 +++ configs/ls2080a_simu_defconfig | 5 +++++ configs/ls2080aqds_SECURE_BOOT_defconfig | 6 ++++++ configs/ls2080aqds_defconfig | 6 ++++++ configs/ls2080aqds_nand_defconfig | 6 ++++++ configs/ls2080ardb_SECURE_BOOT_defconfig | 6 ++++++ configs/ls2080ardb_defconfig | 6 ++++++ configs/ls2080ardb_nand_defconfig | 6 ++++++ configs/lschlv2_defconfig | 5 +++++ configs/lsxhl_defconfig | 5 +++++ configs/luan_defconfig | 4 ++++ configs/lwmon5_defconfig | 3 +++ configs/m28evk_defconfig | 9 +++++++++ configs/m53evk_defconfig | 8 ++++++++ configs/ma5d4evk_defconfig | 10 ++++++++++ configs/makalu_defconfig | 3 +++ configs/marsboard_defconfig | 9 +++++++++ configs/maxbcm_defconfig | 1 + configs/mcx_defconfig | 5 +++++ configs/mecp5123_defconfig | 3 +++ configs/medcom-wide_defconfig | 8 ++++++++ configs/meesc_dataflash_defconfig | 1 + configs/meesc_defconfig | 1 + configs/mgcoge3ne_defconfig | 3 +++ configs/mgcoge3un_defconfig | 3 +++ configs/mgcoge_defconfig | 3 +++ configs/microblaze-generic_defconfig | 2 ++ configs/minnowmax_defconfig | 6 ++++++ configs/mixtile_loftq_defconfig | 7 +++++++ configs/mk802_a10s_defconfig | 7 +++++++ configs/mk802_defconfig | 7 +++++++ configs/mk802ii_defconfig | 7 +++++++ configs/motionpro_defconfig | 3 +++ configs/mpc5121ads_defconfig | 4 ++++ configs/mpc5121ads_rev2_defconfig | 4 ++++ configs/mpc8308_p1m_defconfig | 1 + configs/mpr2_defconfig | 1 + configs/ms7720se_defconfig | 2 ++ configs/mt_ventoux_defconfig | 5 +++++ configs/munices_defconfig | 1 + configs/mx23_olinuxino_defconfig | 4 ++++ configs/mx23evk_defconfig | 5 +++++ configs/mx25pdk_defconfig | 6 ++++++ configs/mx28evk_auart_console_defconfig | 8 ++++++++ configs/mx28evk_defconfig | 8 ++++++++ configs/mx28evk_nand_defconfig | 8 ++++++++ configs/mx28evk_spi_defconfig | 8 ++++++++ configs/mx31pdk_defconfig | 2 ++ configs/mx35pdk_defconfig | 6 ++++++ configs/mx51evk_defconfig | 4 ++++ configs/mx53ard_defconfig | 4 ++++ configs/mx53evk_defconfig | 3 +++ configs/mx53loco_defconfig | 6 ++++++ configs/mx53smd_defconfig | 3 +++ configs/mx6cuboxi_defconfig | 9 +++++++++ configs/mx6dlarm2_defconfig | 9 +++++++++ configs/mx6dlarm2_lpddr2_defconfig | 9 +++++++++ configs/mx6dlsabreauto_defconfig | 11 +++++++++++ configs/mx6dlsabresd_defconfig | 11 +++++++++++ configs/mx6qarm2_defconfig | 9 +++++++++ configs/mx6qarm2_lpddr2_defconfig | 9 +++++++++ configs/mx6qpsabreauto_defconfig | 11 +++++++++++ configs/mx6qsabreauto_defconfig | 11 +++++++++++ configs/mx6qsabrelite_defconfig | 10 ++++++++++ configs/mx6qsabresd_defconfig | 11 +++++++++++ configs/mx6sabresd_spl_defconfig | 9 +++++++++ configs/mx6slevk_defconfig | 9 +++++++++ configs/mx6slevk_spinor_defconfig | 9 +++++++++ configs/mx6slevk_spl_defconfig | 9 +++++++++ configs/mx6sxsabreauto_defconfig | 9 +++++++++ configs/mx6sxsabresd_defconfig | 9 +++++++++ configs/mx6sxsabresd_spl_defconfig | 9 +++++++++ configs/mx6ul_14x14_evk_defconfig | 8 ++++++++ configs/mx6ul_9x9_evk_defconfig | 8 ++++++++ configs/mx7dsabresd_defconfig | 10 ++++++++++ configs/nas220_defconfig | 4 ++++ configs/neo_defconfig | 3 +++ configs/net2big_v2_defconfig | 3 +++ configs/netspace_lite_v2_defconfig | 3 +++ configs/netspace_max_v2_defconfig | 3 +++ configs/netspace_mini_v2_defconfig | 3 +++ configs/netspace_v2_defconfig | 3 +++ configs/nitrogen6dl2g_defconfig | 10 ++++++++++ configs/nitrogen6dl_defconfig | 10 ++++++++++ configs/nitrogen6q2g_defconfig | 10 ++++++++++ configs/nitrogen6q_defconfig | 10 ++++++++++ configs/nitrogen6s1g_defconfig | 10 ++++++++++ configs/nitrogen6s_defconfig | 10 ++++++++++ configs/nokia_rx51_defconfig | 4 ++++ configs/novena_defconfig | 10 ++++++++++ configs/nsa310s_defconfig | 4 ++++ configs/nyan-big_defconfig | 10 ++++++++++ configs/odroid-xu3_defconfig | 11 +++++++++++ configs/odroid_defconfig | 11 +++++++++++ configs/omap3_beagle_defconfig | 10 ++++++++++ configs/omap3_evm_defconfig | 4 ++++ configs/omap3_evm_quick_mmc_defconfig | 2 ++ configs/omap3_ha_defconfig | 4 ++++ configs/omap3_logic_defconfig | 10 ++++++++++ configs/omap3_overo_defconfig | 10 ++++++++++ configs/omap3_pandora_defconfig | 10 ++++++++++ configs/omap3_zoom1_defconfig | 9 +++++++++ configs/omap4_panda_defconfig | 9 +++++++++ configs/omap4_sdp4430_defconfig | 9 +++++++++ configs/omap5_uevm_defconfig | 10 ++++++++++ configs/omapl138_lcdk_defconfig | 5 +++++ configs/openrd_base_defconfig | 4 ++++ configs/openrd_client_defconfig | 4 ++++ configs/openrd_ultimate_defconfig | 4 ++++ configs/openrisc-generic_defconfig | 1 + configs/orangepi_2_defconfig | 7 +++++++ configs/orangepi_one_defconfig | 7 +++++++ configs/orangepi_pc_defconfig | 7 +++++++ configs/orangepi_plus_defconfig | 7 +++++++ configs/origen_defconfig | 11 +++++++++++ configs/ot1200_defconfig | 9 +++++++++ configs/ot1200_spl_defconfig | 9 +++++++++ configs/p2371-0000_defconfig | 9 +++++++++ configs/p2371-2180_defconfig | 9 +++++++++ configs/p2571_defconfig | 9 +++++++++ configs/paz00_defconfig | 8 ++++++++ configs/pb1000_defconfig | 1 + configs/pcm030_LOWBOOT_defconfig | 1 + configs/pcm030_defconfig | 1 + configs/pcm051_rev1_defconfig | 9 +++++++++ configs/pcm051_rev3_defconfig | 9 +++++++++ configs/pcm052_defconfig | 4 ++++ configs/pdm360ng_defconfig | 2 ++ configs/peach-pi_defconfig | 9 +++++++++ configs/peach-pit_defconfig | 9 +++++++++ configs/pengwyn_defconfig | 9 +++++++++ configs/pepper_defconfig | 9 +++++++++ configs/pic32mzdask_defconfig | 7 +++++++ configs/picosam9g45_defconfig | 3 +++ configs/pine64_plus_defconfig | 6 ++++++ configs/platinum_picon_defconfig | 9 +++++++++ configs/platinum_titanium_defconfig | 9 +++++++++ configs/plutux_defconfig | 8 ++++++++ configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 3 +++ configs/polaroid_mid2809pxe04_defconfig | 7 +++++++ configs/porter_defconfig | 7 +++++++ configs/portl2_defconfig | 3 +++ configs/pov_protab2_ips9_defconfig | 7 +++++++ configs/pr1_defconfig | 2 ++ configs/pxm2_defconfig | 7 +++++++ configs/q8_a13_tablet_defconfig | 7 +++++++ configs/q8_a23_tablet_800x480_defconfig | 7 +++++++ configs/q8_a33_tablet_1024x600_defconfig | 7 +++++++ configs/q8_a33_tablet_800x480_defconfig | 7 +++++++ configs/qemu-ppce500_defconfig | 3 +++ configs/qemu-x86_defconfig | 5 +++++ configs/qemu_mips64_defconfig | 2 ++ configs/qemu_mips64el_defconfig | 2 ++ configs/qemu_mips_defconfig | 2 ++ configs/qemu_mipsel_defconfig | 2 ++ configs/r0p7734_defconfig | 1 + configs/r2dplus_defconfig | 2 ++ configs/r7-tv-dongle_defconfig | 7 +++++++ configs/r7780mp_defconfig | 1 + configs/rainier_defconfig | 5 +++++ configs/rainier_ramboot_defconfig | 5 +++++ configs/rastaban_defconfig | 6 ++++++ configs/redwood_defconfig | 4 ++++ configs/riotboard_defconfig | 9 +++++++++ configs/rock2_defconfig | 8 ++++++++ configs/rpi_2_defconfig | 7 +++++++ configs/rpi_3_32b_defconfig | 7 +++++++ configs/rpi_3_defconfig | 6 ++++++ configs/rpi_defconfig | 7 +++++++ configs/rsk7203_defconfig | 1 + configs/rut_defconfig | 7 +++++++ configs/s5p_goni_defconfig | 7 +++++++ configs/s5pc210_universal_defconfig | 11 +++++++++++ configs/sama5d2_xplained_mmc_defconfig | 3 +++ configs/sama5d2_xplained_spiflash_defconfig | 3 +++ configs/sama5d3_xplained_mmc_defconfig | 6 ++++++ configs/sama5d3_xplained_nandflash_defconfig | 6 ++++++ configs/sama5d3xek_mmc_defconfig | 4 ++++ configs/sama5d3xek_nandflash_defconfig | 4 ++++ configs/sama5d3xek_spiflash_defconfig | 4 ++++ configs/sama5d4_xplained_mmc_defconfig | 3 +++ configs/sama5d4_xplained_nandflash_defconfig | 3 +++ configs/sama5d4_xplained_spiflash_defconfig | 3 +++ configs/sama5d4ek_mmc_defconfig | 3 +++ configs/sama5d4ek_nandflash_defconfig | 3 +++ configs/sama5d4ek_spiflash_defconfig | 3 +++ configs/sandbox_defconfig | 9 +++++++++ configs/sansa_fuze_plus_defconfig | 4 ++++ configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8349_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8548_defconfig | 1 + configs/sc_sps_1_defconfig | 5 +++++ configs/seaboard_defconfig | 8 ++++++++ configs/secomx6quq7_defconfig | 9 +++++++++ configs/sequoia_defconfig | 5 +++++ configs/sequoia_ramboot_defconfig | 5 +++++ configs/sh7752evb_defconfig | 3 +++ configs/sh7753evb_defconfig | 3 +++ configs/sh7757lcr_defconfig | 3 +++ configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 2 ++ configs/sh7785lcr_defconfig | 2 ++ configs/sheevaplug_defconfig | 6 ++++++ configs/silk_defconfig | 7 +++++++ configs/smartweb_defconfig | 2 ++ configs/smdk2410_defconfig | 3 +++ configs/smdk5250_defconfig | 9 +++++++++ configs/smdk5420_defconfig | 9 +++++++++ configs/smdkc100_defconfig | 2 ++ configs/smdkv310_defconfig | 9 +++++++++ configs/snapper9260_defconfig | 2 ++ configs/snapper9g20_defconfig | 2 ++ configs/sniper_defconfig | 7 +++++++ configs/snow_defconfig | 9 +++++++++ configs/socfpga_arria5_defconfig | 12 ++++++++++++ configs/socfpga_cyclone5_defconfig | 12 ++++++++++++ configs/socfpga_de0_nano_soc_defconfig | 12 ++++++++++++ configs/socfpga_mcvevk_defconfig | 12 ++++++++++++ configs/socfpga_sockit_defconfig | 12 ++++++++++++ configs/socfpga_socrates_defconfig | 12 ++++++++++++ configs/socfpga_sr1500_defconfig | 10 ++++++++++ configs/socrates_defconfig | 2 ++ configs/spear300_defconfig | 1 + configs/spear300_nand_defconfig | 1 + configs/spear300_usbtty_defconfig | 1 + configs/spear300_usbtty_nand_defconfig | 1 + configs/spear310_defconfig | 1 + configs/spear310_nand_defconfig | 1 + configs/spear310_pnor_defconfig | 1 + configs/spear310_usbtty_defconfig | 1 + configs/spear310_usbtty_nand_defconfig | 1 + configs/spear310_usbtty_pnor_defconfig | 1 + configs/spear320_defconfig | 1 + configs/spear320_nand_defconfig | 1 + configs/spear320_pnor_defconfig | 1 + configs/spear320_usbtty_defconfig | 1 + configs/spear320_usbtty_nand_defconfig | 1 + configs/spear320_usbtty_pnor_defconfig | 1 + configs/spear600_defconfig | 1 + configs/spear600_nand_defconfig | 1 + configs/spear600_usbtty_defconfig | 1 + configs/spear600_usbtty_nand_defconfig | 1 + configs/spring_defconfig | 9 +++++++++ configs/stout_defconfig | 7 +++++++ configs/strider_con_defconfig | 3 +++ configs/strider_cpu_defconfig | 3 +++ configs/sunxi_Gemei_G9_defconfig | 7 +++++++ configs/suvd3_defconfig | 3 +++ configs/sycamore_defconfig | 3 +++ configs/t3corp_defconfig | 4 ++++ configs/tao3530_defconfig | 4 ++++ configs/taurus_defconfig | 2 ++ configs/tbs2910_defconfig | 10 ++++++++++ configs/tcm-bf518_defconfig | 2 ++ configs/tcm-bf537_defconfig | 5 +++++ configs/tec-ng_defconfig | 8 ++++++++ configs/tec_defconfig | 8 ++++++++ configs/theadorable_debug_defconfig | 7 +++++++ configs/theadorable_defconfig | 6 ++++++ configs/thuban_defconfig | 6 ++++++ configs/ti814x_evm_defconfig | 5 +++++ configs/ti816x_evm_defconfig | 3 +++ configs/titanium_defconfig | 9 +++++++++ configs/tqma6q_mba6_mmc_defconfig | 9 +++++++++ configs/tqma6q_mba6_spi_defconfig | 9 +++++++++ configs/tqma6s_mba6_mmc_defconfig | 9 +++++++++ configs/tqma6s_mba6_spi_defconfig | 9 +++++++++ configs/tqma6s_wru4_mmc_defconfig | 9 +++++++++ configs/trats2_defconfig | 11 +++++++++++ configs/trats_defconfig | 11 +++++++++++ configs/tricorder_defconfig | 3 +++ configs/tricorder_flash_defconfig | 3 +++ configs/trimslice_defconfig | 8 ++++++++ configs/ts4800_defconfig | 4 ++++ configs/tseries_mmc_defconfig | 6 ++++++ configs/tseries_nand_defconfig | 5 +++++ configs/tseries_spi_defconfig | 6 ++++++ configs/tuge1_defconfig | 3 +++ configs/tuxx1_defconfig | 3 +++ configs/twister_defconfig | 5 +++++ configs/udoo_defconfig | 9 +++++++++ configs/uniphier_ld4_sld8_defconfig | 3 +++ configs/uniphier_pro4_defconfig | 3 +++ configs/uniphier_pxs2_ld6b_defconfig | 3 +++ configs/uniphier_sld3_defconfig | 3 +++ configs/usbarmory_defconfig | 7 +++++++ configs/v38b_defconfig | 2 ++ configs/vct_platinum_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/venice2_defconfig | 10 ++++++++++ configs/ventana_defconfig | 8 ++++++++ configs/vexpress_aemv8a_dram_defconfig | 3 +++ configs/vexpress_aemv8a_juno_defconfig | 3 +++ configs/vexpress_aemv8a_semi_defconfig | 3 +++ configs/vexpress_ca15_tc2_defconfig | 7 +++++++ configs/vexpress_ca5x2_defconfig | 7 +++++++ configs/vexpress_ca9x4_defconfig | 7 +++++++ configs/vf610twr_defconfig | 4 ++++ configs/vf610twr_nand_defconfig | 4 ++++ configs/vinco_defconfig | 4 ++++ configs/vme8349_defconfig | 1 + configs/walnut_defconfig | 3 +++ configs/wandboard_defconfig | 9 +++++++++ configs/warp7_defconfig | 9 +++++++++ configs/warp_defconfig | 10 ++++++++++ configs/whistler_defconfig | 8 ++++++++ configs/woodburn_defconfig | 5 +++++ configs/woodburn_sd_defconfig | 5 +++++ configs/work_92105_defconfig | 1 + configs/wtk_defconfig | 2 ++ configs/x600_defconfig | 4 ++++ configs/xfi3_defconfig | 4 ++++ configs/xilinx-ppc405-generic_defconfig | 2 ++ configs/xilinx-ppc440-generic_defconfig | 2 ++ configs/xilinx_zynqmp_ep_defconfig | 8 ++++++++ configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 8 ++++++++ configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 7 +++++++ configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 7 +++++++ configs/xilinx_zynqmp_zcu102_defconfig | 8 ++++++++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 8 ++++++++ configs/xpedite1000_defconfig | 2 ++ configs/xpedite517x_defconfig | 2 ++ configs/xpedite520x_defconfig | 2 ++ configs/xpedite537x_defconfig | 2 ++ configs/xpedite550x_defconfig | 2 ++ configs/xpress_defconfig | 9 +++++++++ configs/xpress_spl_defconfig | 9 +++++++++ configs/yellowstone_defconfig | 4 ++++ configs/yosemite_defconfig | 6 ++++++ configs/yucca_defconfig | 4 ++++ configs/zipitz2_defconfig | 4 ++++ configs/zmx25_defconfig | 2 ++ configs/zynq_microzed_defconfig | 9 +++++++++ configs/zynq_picozed_defconfig | 9 +++++++++ configs/zynq_zc702_defconfig | 9 +++++++++ configs/zynq_zc706_defconfig | 9 +++++++++ configs/zynq_zc770_xm010_defconfig | 8 ++++++++ configs/zynq_zc770_xm011_defconfig | 2 ++ configs/zynq_zc770_xm012_defconfig | 2 ++ configs/zynq_zc770_xm013_defconfig | 2 ++ configs/zynq_zed_defconfig | 9 +++++++++ configs/zynq_zybo_defconfig | 9 +++++++++ include/config_cmd_all.h | 7 ------- include/config_distro_defaults.h | 7 ------- include/config_fallbacks.h | 1 - include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/B4860QDS.h | 3 --- include/configs/BSC9131RDB.h | 3 --- include/configs/BSC9132QDS.h | 4 ---- include/configs/C29XPCIE.h | 1 - include/configs/CPCI4052.h | 2 -- include/configs/M5208EVBE.h | 2 -- include/configs/M52277EVB.h | 1 - include/configs/M5235EVB.h | 2 -- include/configs/M5249EVB.h | 1 - include/configs/M5253DEMO.h | 3 --- include/configs/M5253EVBE.h | 3 --- include/configs/M5272C3.h | 2 -- include/configs/M5275EVB.h | 2 -- include/configs/M5282EVB.h | 2 -- include/configs/M53017EVB.h | 2 -- include/configs/M5329EVB.h | 2 -- include/configs/M5373EVB.h | 2 -- include/configs/M54418TWR.h | 2 -- include/configs/M54451EVB.h | 2 -- include/configs/M54455EVB.h | 4 ---- include/configs/M5475EVB.h | 2 -- include/configs/M5485EVB.h | 2 -- include/configs/MIP405.h | 3 --- include/configs/MPC8308RDB.h | 3 --- include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 2 -- include/configs/MPC8323ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349ITX.h | 3 --- include/configs/MPC837XEMDS.h | 5 ----- include/configs/MPC837XERDB.h | 5 ----- include/configs/MPC8536DS.h | 5 ----- include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 2 -- include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8560ADS.h | 1 - include/configs/MPC8568MDS.h | 1 - include/configs/MPC8569MDS.h | 4 ---- include/configs/MPC8572DS.h | 2 -- include/configs/MPC8610HPCD.h | 2 -- include/configs/MPC8641HPCN.h | 1 - include/configs/P1010RDB.h | 4 ---- include/configs/P1022DS.h | 6 ------ include/configs/P1023RDB.h | 4 ---- include/configs/P2041RDB.h | 8 -------- include/configs/PIP405.h | 3 --- include/configs/PLU405.h | 2 -- include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 2 -- include/configs/T102xQDS.h | 7 ------- include/configs/T102xRDB.h | 6 ------ include/configs/T1040QDS.h | 7 ------- include/configs/T104xRDB.h | 7 ------- include/configs/T208xQDS.h | 7 ------- include/configs/T208xRDB.h | 6 ------ include/configs/T4240QDS.h | 5 ----- include/configs/T4240RDB.h | 8 -------- include/configs/TQM5200.h | 5 ----- include/configs/TQM823L.h | 2 -- include/configs/TQM823M.h | 2 -- include/configs/TQM834x.h | 2 -- include/configs/TQM850L.h | 2 -- include/configs/TQM850M.h | 2 -- include/configs/TQM855L.h | 2 -- include/configs/TQM855M.h | 2 -- include/configs/TQM860L.h | 2 -- include/configs/TQM860M.h | 2 -- include/configs/TQM862L.h | 2 -- include/configs/TQM862M.h | 2 -- include/configs/TQM866M.h | 2 -- include/configs/TQM885D.h | 3 --- include/configs/UCP1020.h | 5 ----- include/configs/VCMA9.h | 2 -- include/configs/VOM405.h | 1 - include/configs/a3m071.h | 2 -- include/configs/a4m072.h | 2 -- include/configs/ac14xx.h | 3 --- include/configs/adp-ag101p.h | 4 ---- include/configs/alt.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/am3517_crane.h | 4 ---- include/configs/am3517_evm.h | 9 --------- include/configs/am43xx_evm.h | 4 ---- include/configs/am57xx_evm.h | 1 - include/configs/amcc-common.h | 4 ---- include/configs/amcore.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/apalis_t30.h | 1 - include/configs/apf27.h | 6 ------ include/configs/apx4devkit.h | 5 ----- include/configs/aria.h | 2 -- include/configs/aristainetos-common.h | 1 - include/configs/armadillo-800eva.h | 2 -- include/configs/astro_mcf5373l.h | 1 - include/configs/at91-sama5_common.h | 1 - include/configs/at91rm9200ek.h | 4 ---- include/configs/at91sam9260ek.h | 4 ---- include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 9 --------- include/configs/at91sam9m10g45ek.h | 4 ---- include/configs/at91sam9n12ek.h | 3 --- include/configs/at91sam9rlek.h | 4 ---- include/configs/at91sam9x5ek.h | 4 ---- include/configs/atngw100.h | 4 ---- include/configs/atngw100mkii.h | 5 ----- include/configs/atstk1002.h | 4 ---- include/configs/axs101.h | 2 -- include/configs/baltos.h | 1 - include/configs/bamboo.h | 2 -- include/configs/bav335x.h | 2 -- include/configs/bayleybay.h | 1 - include/configs/bcm28155_ap.h | 5 ----- include/configs/bcm_ep_board.h | 5 ----- include/configs/beaver.h | 1 - include/configs/bf537-minotaur.h | 1 - include/configs/bf537-srv1.h | 1 - include/configs/bf561-acvilon.h | 1 - include/configs/bf609-ezkit.h | 1 - include/configs/bfin_adi_common.h | 8 -------- include/configs/bg0900.h | 3 --- include/configs/blackstamp.h | 1 - include/configs/blackvme.h | 2 -- include/configs/calimain.h | 3 --- include/configs/canmb.h | 2 -- include/configs/canyonlands.h | 2 -- include/configs/cardhu.h | 1 - include/configs/cgtqmx6eval.h | 4 ---- include/configs/clearfog.h | 7 ------- include/configs/cm5200.h | 3 --- include/configs/cm_fx6.h | 1 - include/configs/cm_t35.h | 5 ----- include/configs/cm_t3517.h | 5 ----- include/configs/cobra5272.h | 2 -- include/configs/colibri_pxa270.h | 1 - include/configs/colibri_t20.h | 3 --- include/configs/colibri_t30.h | 1 - include/configs/colibri_vf.h | 11 ----------- include/configs/conga-qeval20-qa3-e3845.h | 1 - include/configs/controlcenterd.h | 4 ---- include/configs/corenet_ds.h | 7 ------- include/configs/corvus.h | 3 --- include/configs/crownbay.h | 1 - include/configs/cyrus.h | 7 ------- include/configs/da850evm.h | 6 ------ include/configs/dalmore.h | 1 - include/configs/db-88f6720.h | 5 ----- include/configs/db-88f6820-gp.h | 6 ------ include/configs/db-mv784mp-gp.h | 5 ----- include/configs/dbau1x00.h | 2 -- include/configs/devkit3250.h | 3 --- include/configs/devkit8000.h | 4 ---- include/configs/digsy_mtc.h | 4 ---- include/configs/dnp5370.h | 2 -- include/configs/dockstar.h | 3 --- include/configs/dra7xx_evm.h | 2 -- include/configs/draco.h | 1 - include/configs/dragonboard410c.h | 2 -- include/configs/dreamplug.h | 2 -- include/configs/e2220-1170.h | 1 - include/configs/ea20.h | 3 --- include/configs/eb_cpu5282.h | 1 - include/configs/ecovec.h | 3 --- include/configs/edb93xx.h | 6 ------ include/configs/edminiv2.h | 1 - include/configs/espt.h | 1 - include/configs/ethernut5.h | 6 ------ include/configs/exynos-common.h | 4 ---- include/configs/exynos4-common.h | 2 -- include/configs/flea3.h | 2 -- include/configs/galileo.h | 1 - include/configs/ge_bx50v3.h | 8 -------- include/configs/goflexhome.h | 2 -- include/configs/gose.h | 1 - include/configs/gplugd.h | 5 ----- include/configs/gr_ep2s60.h | 2 -- include/configs/grasshopper.h | 1 - include/configs/gw_ventana.h | 2 -- include/configs/harmony.h | 1 - include/configs/hikey.h | 2 -- include/configs/hrcon.h | 3 --- include/configs/ib62x0.h | 2 -- include/configs/icon.h | 2 -- include/configs/iconnect.h | 3 --- include/configs/ids8313.h | 1 - include/configs/imx27lite-common.h | 5 ----- include/configs/inka4x0.h | 2 -- include/configs/intip.h | 2 -- include/configs/iocon.h | 1 - include/configs/ipam390.h | 3 --- include/configs/ipek01.h | 2 -- include/configs/jetson-tk1.h | 1 - include/configs/k2g_evm.h | 1 - include/configs/katmai.h | 2 -- include/configs/kc1.h | 2 -- include/configs/km/keymile-common.h | 3 --- include/configs/km/km_arm.h | 1 - include/configs/koelsch.h | 1 - include/configs/kwb.h | 4 ---- include/configs/kzm9g.h | 2 -- include/configs/lacie_kw.h | 2 -- include/configs/lager.h | 1 - include/configs/legoev3.h | 5 ----- include/configs/ls1021aqds.h | 8 -------- include/configs/ls1021atwr.h | 8 -------- include/configs/ls1043a_common.h | 3 --- include/configs/ls1043aqds.h | 6 ------ include/configs/ls1043ardb.h | 2 -- include/configs/ls2080a_common.h | 3 --- include/configs/ls2080a_simu.h | 2 -- include/configs/ls2080aqds.h | 6 ------ include/configs/ls2080ardb.h | 5 ----- include/configs/lsxl.h | 4 ---- include/configs/lwmon5.h | 3 --- include/configs/m28evk.h | 9 --------- include/configs/m53evk.h | 8 -------- include/configs/ma5d4evk.h | 10 ---------- include/configs/manroland/common.h | 2 -- include/configs/mcx.h | 6 ------ include/configs/mecp5123.h | 4 ---- include/configs/medcom-wide.h | 1 - include/configs/meesc.h | 2 -- include/configs/microblaze-generic.h | 5 ----- include/configs/minnowmax.h | 1 - include/configs/motionpro.h | 3 --- include/configs/mpc5121ads.h | 4 ---- include/configs/mpc8308_p1m.h | 1 - include/configs/mpr2.h | 1 - include/configs/ms7720se.h | 2 -- include/configs/munices.h | 1 - include/configs/mv-common.h | 2 -- include/configs/mv-plug-common.h | 3 --- include/configs/mx23_olinuxino.h | 4 ---- include/configs/mx23evk.h | 5 ----- include/configs/mx25pdk.h | 7 ------- include/configs/mx28evk.h | 8 -------- include/configs/mx31pdk.h | 2 -- include/configs/mx35pdk.h | 6 ------ include/configs/mx51evk.h | 6 ------ include/configs/mx53ard.h | 6 ------ include/configs/mx53evk.h | 3 --- include/configs/mx53loco.h | 8 -------- include/configs/mx53smd.h | 4 ---- include/configs/mx6_common.h | 8 -------- include/configs/mx6cuboxi.h | 1 - include/configs/mx6qarm2.h | 1 - include/configs/mx6sabre_common.h | 3 --- include/configs/mx6slevk.h | 1 - include/configs/mx6sxsabreauto.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 2 -- include/configs/mx7_common.h | 7 ------- include/configs/mx7dsabresd.h | 3 --- include/configs/nas220.h | 4 ---- include/configs/nitrogen6x.h | 2 -- include/configs/nokia_rx51.h | 5 ----- include/configs/novena.h | 2 -- include/configs/nsa310s.h | 2 -- include/configs/nyan-big.h | 1 - include/configs/o2dnt-common.h | 2 -- include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 4 ---- include/configs/omap3_beagle.h | 3 --- include/configs/omap3_evm.h | 4 ---- include/configs/omap3_evm_common.h | 1 - include/configs/omap3_evm_quick_mmc.h | 2 -- include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 3 --- include/configs/omap3_overo.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 6 ------ include/configs/openrd.h | 2 -- include/configs/openrisc-generic.h | 2 -- include/configs/origen.h | 3 --- include/configs/ot1200.h | 1 - include/configs/p1_p2_rdb_pc.h | 4 ---- include/configs/p1_twr.h | 4 ---- include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/paz00.h | 1 - include/configs/pb1x00.h | 2 -- include/configs/pcm030.h | 1 - include/configs/pcm052.h | 5 ----- include/configs/pdm360ng.h | 2 -- include/configs/pengwyn.h | 2 -- include/configs/pic32mzdask.h | 8 -------- include/configs/picosam9g45.h | 4 ---- include/configs/platinum.h | 1 - include/configs/plutux.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 3 --- include/configs/porter.h | 1 - include/configs/pxa-common.h | 2 -- include/configs/qemu-mips.h | 2 -- include/configs/qemu-mips64.h | 2 -- include/configs/qemu-ppce500.h | 3 --- include/configs/r0p7734.h | 1 - include/configs/r2dplus.h | 2 -- include/configs/r7780mp.h | 1 - include/configs/rastaban.h | 1 - include/configs/rcar-gen2-common.h | 6 ------ include/configs/rk3036_common.h | 7 ------- include/configs/rk3288_common.h | 7 ------- include/configs/rpi.h | 1 - include/configs/rsk7203.h | 1 - include/configs/s5p_goni.h | 8 -------- include/configs/sama5d2_xplained.h | 2 -- include/configs/sama5d3_xplained.h | 5 ----- include/configs/sama5d3xek.h | 3 --- include/configs/sama5d4_xplained.h | 2 -- include/configs/sama5d4ek.h | 2 -- include/configs/sandbox.h | 6 ------ include/configs/sansa_fuze_plus.h | 4 ---- include/configs/sbc8349.h | 1 - include/configs/sbc8548.h | 1 - include/configs/sc_sps_1.h | 6 ------ include/configs/seaboard.h | 1 - include/configs/secomx6quq7.h | 1 - include/configs/sequoia.h | 1 - include/configs/sh7752evb.h | 3 --- include/configs/sh7753evb.h | 3 --- include/configs/sh7757lcr.h | 3 --- include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 2 -- include/configs/sheevaplug.h | 1 - include/configs/siemens-am33x-common.h | 7 ------- include/configs/silk.h | 1 - include/configs/smartweb.h | 2 -- include/configs/smdk2410.h | 3 --- include/configs/smdkc100.h | 2 -- include/configs/smdkv310.h | 2 -- include/configs/snapper9260.h | 2 -- include/configs/sniper.h | 2 -- include/configs/socfpga_arria5_socdk.h | 13 ------------- include/configs/socfpga_cyclone5_socdk.h | 13 ------------- include/configs/socfpga_de0_nano_soc.h | 13 ------------- include/configs/socfpga_mcvevk.h | 13 ------------- include/configs/socfpga_sockit.h | 13 ------------- include/configs/socfpga_socrates.h | 13 ------------- include/configs/socfpga_sr1500.h | 12 ------------ include/configs/socrates.h | 2 -- include/configs/spear-common.h | 1 - include/configs/stout.h | 1 - include/configs/strider.h | 3 --- include/configs/sunxi-common.h | 3 --- include/configs/t4qds.h | 3 --- include/configs/tam3517-common.h | 5 ----- include/configs/tao3530.h | 4 ---- include/configs/taurus.h | 3 --- include/configs/tbs2910.h | 2 -- include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/tegra-common-post.h | 13 ------------- include/configs/tegra-common-usb-gadget.h | 2 -- include/configs/tegra-common.h | 1 - include/configs/theadorable.h | 6 ------ include/configs/thuban.h | 1 - include/configs/ti814x_evm.h | 5 ----- include/configs/ti816x_evm.h | 3 --- include/configs/ti_am335x_common.h | 1 - include/configs/ti_armv7_common.h | 8 -------- include/configs/ti_armv7_keystone2.h | 1 - include/configs/titanium.h | 1 - include/configs/tqma6.h | 2 -- include/configs/tricorder.h | 3 --- include/configs/trimslice.h | 1 - include/configs/ts4800.h | 6 ------ include/configs/tseries.h | 6 ------ include/configs/udoo.h | 1 - include/configs/uniphier.h | 3 --- include/configs/usb_a9263.h | 1 - include/configs/usbarmory.h | 1 - include/configs/v38b.h | 3 --- include/configs/vct.h | 5 ----- include/configs/ve8313.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/vexpress_aemv8a.h | 3 --- include/configs/vexpress_common.h | 1 - include/configs/vf610twr.h | 5 ----- include/configs/vinco.h | 3 --- include/configs/vme8349.h | 1 - include/configs/wandboard.h | 1 - include/configs/warp.h | 2 -- include/configs/warp7.h | 2 -- include/configs/whistler.h | 1 - include/configs/woodburn_common.h | 6 ------ include/configs/work_92105.h | 1 - include/configs/x600.h | 4 ---- include/configs/x86-common.h | 6 ------ include/configs/xfi3.h | 4 ---- include/configs/xilinx-ppc.h | 2 -- include/configs/xilinx_zynqmp.h | 9 --------- include/configs/xpedite1000.h | 2 -- include/configs/xpedite517x.h | 2 -- include/configs/xpedite520x.h | 2 -- include/configs/xpedite537x.h | 2 -- include/configs/xpedite550x.h | 2 -- include/configs/xpress.h | 3 --- include/configs/yosemite.h | 2 -- include/configs/zipitz2.h | 4 ---- include/configs/zmx25.h | 2 -- include/configs/zynq-common.h | 9 --------- 1493 files changed, 5146 insertions(+), 1299 deletions(-) create mode 100644 configs/defconfig
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index fd51531..1275164 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -30,6 +30,5 @@ #define CONFIG_PHY_BROADCOM #define CONFIG_PHY_RESET_DELAY 10000 /* PHY reset delay in us*/
-#define CONFIG_CMD_MII
#endif /* __ARCH_CONFIGS_H */ diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index ab4b697..267bd17 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -90,7 +90,6 @@ #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_ERRATUM_A008407
diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index 0c4309f..60b60aa 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -80,7 +80,6 @@ * Ethernet Driver configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_CMD_MII #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_MII /* expose smi ove miiphy interface */ #define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ @@ -102,7 +101,6 @@ */ #ifdef CONFIG_CMD_IDE #define __io -#define CONFIG_CMD_EXT2 #define CONFIG_MVSATA_IDE #define CONFIG_IDE_PREINIT #define CONFIG_MVSATA_IDE_USE_PORT1 diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index b8a8c62..4df70d7 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -77,7 +77,6 @@ * Ethernet Driver configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_CMD_MII #define CONFIG_MII /* expose smi ove miiphy interface */ #if !defined(CONFIG_ARMADA_375) #define CONFIG_MVNETA /* Enable Marvell Gbe Controller Driver */ diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index d4b768d..4f85c22 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ALTERA_PIO=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index 5fdaee0..c145caf 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ALTERA_PIO=y diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index b4d7d84..d7725e4 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -10,12 +10,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 7baff24..c39daf1 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -11,11 +11,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index e03d9a8..955b6cf 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -15,11 +15,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 1ac88a4..d2d0cbd 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -17,12 +17,21 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 7a1f2a8..546c84c 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -10,12 +10,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 3093395..5dc4ba3 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -8,12 +8,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index da76a97..e952562 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -11,11 +11,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 7c9150e..cecf4c2 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -13,12 +13,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 3ff15f8..7479f7f 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -15,10 +15,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-ainol-aw1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index e68e747..fde84ac 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -17,10 +17,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 1b3d01d..45539c1 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 8edb572..52dfdf2 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -7,11 +7,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index bcffc47..369afbb 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -8,11 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 6208567..408e84e 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -7,11 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index 300461b..bab96ca 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -7,11 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index f7ff204..10fe1d0 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -8,11 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 75cf823..5e754eb 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -8,11 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index e9c045e..fca6f5a 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -7,11 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index b7ebc98..e833e0c 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,15 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 3420443..cd27638 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -7,11 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index fdf4954..cdfccbe 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -14,7 +14,10 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index 7c3683a..555e446 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -14,7 +14,10 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 831e024..014916c 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -13,7 +13,10 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index c365a45..941fe75 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -13,7 +13,10 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index f766e05..ae8271b 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index 100f1bf..502ba3c 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index 433b62d..d60c0c1 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 2eb85d1..43fa804 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index f0bb1cd..adc42c5 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index f521407..d591a37 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -7,11 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 2708794..034109e 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index df67271..c804b4f 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -7,11 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 072c2e5..49609b7 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index f3d96b3..a64db9b 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -7,11 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index 231dab0..0850d84 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index c775caa..7d7ecd2 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -7,11 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index 2fb85e9..a46d8d7 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index 89f7aa5..3ef15fc 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -7,11 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index 43ccad1..307813c 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 09421e0..aef5e7b 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -7,11 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index f7db498..fd6b8de 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -9,12 +9,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 74c7446..ae38583 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -11,12 +11,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO4_VOLT=2500 diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index d342640..726e08e 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,NAND" CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index 5bedcb4..032be47 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SECURE_BOOT" CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index f74c103..a450c60 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index 541ae65..c50234c 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 7c50ea9..c16559d 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT" CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 4ef1840..0eca229 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -9,10 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_I2C=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_MUSB_GADGET=y diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index c00ca1f..25818bd 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -9,6 +9,8 @@ CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index a0ed7a0..ab6f329 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index ec30918..080bfbd 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -15,12 +15,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-chuwi-v7-cw0825" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 078243e..6380a22 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -19,12 +19,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 0a1f6cd..683f7f9 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -8,11 +8,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 3f3f812..f8c7107 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -8,10 +8,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 9eff740..0d43c53 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -13,12 +13,21 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 5a15a58..b5959ee 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -16,12 +16,19 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_AXP_FLDO1_VOLT=1200 diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index b60c569..78e94ab 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5020" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index 0d86a8f..f03d738 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5040" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 7daafb8..7cc162b 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -18,10 +18,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 5b221c3..f424557 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -11,11 +11,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index b9f7f0e..4ff0a6b 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -16,10 +16,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 3959bae..f4832a7 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -8,11 +8,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index f6cae6b..1227994 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,SATAPWR=SUNXI_GPB(3)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 69a082c..3b0d8cf 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -10,11 +10,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 8eeff7b..28768ec 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -8,11 +8,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 4a09f29..11bb709 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -8,10 +8,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 55841e6..8cee863 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_M5208EVBE=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M52277EVB_defconfig b/configs/M52277EVB_defconfig index d3519dd..93e39b4 100644 --- a/configs/M52277EVB_defconfig +++ b/configs/M52277EVB_defconfig @@ -9,5 +9,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M52277EVB_stmicro_defconfig b/configs/M52277EVB_stmicro_defconfig index b978c02..b63386d 100644 --- a/configs/M52277EVB_stmicro_defconfig +++ b/configs/M52277EVB_stmicro_defconfig @@ -8,5 +8,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index 6bbacf3..ffb709c 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -7,4 +7,6 @@ CONFIG_SYS_EXTRA_OPTIONS="NORFLASH_PS32BIT" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index 979d78c..0885727 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -7,4 +7,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index 9bc8da9..f06379f 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_TEXT_BASE=0xffe00000 CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_CACHE=y diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index 8c4678b..fc29e30 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -3,3 +3,6 @@ CONFIG_TARGET_M5253DEMO=y CONFIG_SYS_TEXT_BASE=0xFF800000 # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/M5253EVBE_defconfig b/configs/M5253EVBE_defconfig index 2e82cce..15c22df 100644 --- a/configs/M5253EVBE_defconfig +++ b/configs/M5253EVBE_defconfig @@ -3,3 +3,6 @@ CONFIG_TARGET_M5253EVBE=y CONFIG_SYS_TEXT_BASE=0xFFE00000 # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index efcadd6..585ea17 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -5,4 +5,6 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index dec9e63..cd75118 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -7,4 +7,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 7aa36d9..df12b3a 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -5,4 +5,6 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index c63acd9..b9a4fde 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_M53017EVB=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 51d0ba2..dc90334 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -5,4 +5,6 @@ CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=0" CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index cb79dbd..2850e3a 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -5,4 +5,6 @@ CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index 52175cf..9b63e54 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -5,4 +5,6 @@ CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index fac2fda..be7a37f 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index a013ac8..c04e9ca 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index c29618c..3f454e9 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index 522a150..2206554 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index 2301738..244fc73 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index fac2fda..be7a37f 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54451EVB_defconfig b/configs/M54451EVB_defconfig index 36fa4ea..5f354a8 100644 --- a/configs/M54451EVB_defconfig +++ b/configs/M54451EVB_defconfig @@ -10,6 +10,8 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54451EVB_stmicro_defconfig b/configs/M54451EVB_stmicro_defconfig index e526b46..c43c49d 100644 --- a/configs/M54451EVB_stmicro_defconfig +++ b/configs/M54451EVB_stmicro_defconfig @@ -9,6 +9,8 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_a66_defconfig b/configs/M54455EVB_a66_defconfig index c8ba38c..8e1bcbf 100644 --- a/configs/M54455EVB_a66_defconfig +++ b/configs/M54455EVB_a66_defconfig @@ -9,6 +9,10 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index e362886..705b5ae 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -10,6 +10,10 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_i66_defconfig b/configs/M54455EVB_i66_defconfig index 714c080..a1dd018 100644 --- a/configs/M54455EVB_i66_defconfig +++ b/configs/M54455EVB_i66_defconfig @@ -9,6 +9,10 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_intel_defconfig b/configs/M54455EVB_intel_defconfig index e17382e..3a17303 100644 --- a/configs/M54455EVB_intel_defconfig +++ b/configs/M54455EVB_intel_defconfig @@ -9,6 +9,10 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index ce2dd81..52441d4 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -9,6 +9,10 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M5475AFE_defconfig b/configs/M5475AFE_defconfig index 2131e0e..3bad5d0 100644 --- a/configs/M5475AFE_defconfig +++ b/configs/M5475AFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5475BFE_defconfig b/configs/M5475BFE_defconfig index ead78c8..d3ff58b 100644 --- a/configs/M5475BFE_defconfig +++ b/configs/M5475BFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5475CFE_defconfig b/configs/M5475CFE_defconfig index 04a31fd..670bda5 100644 --- a/configs/M5475CFE_defconfig +++ b/configs/M5475CFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5475DFE_defconfig b/configs/M5475DFE_defconfig index 242acc8..4a49e90 100644 --- a/configs/M5475DFE_defconfig +++ b/configs/M5475DFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5475EFE_defconfig b/configs/M5475EFE_defconfig index 3641a55..8e90823 100644 --- a/configs/M5475EFE_defconfig +++ b/configs/M5475EFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5475FFE_defconfig b/configs/M5475FFE_defconfig index c0d1c5e..e26b1fe 100644 --- a/configs/M5475FFE_defconfig +++ b/configs/M5475FFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5475GFE_defconfig b/configs/M5475GFE_defconfig index 57c5770..e79d991 100644 --- a/configs/M5475GFE_defconfig +++ b/configs/M5475GFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485AFE_defconfig b/configs/M5485AFE_defconfig index 917d4bd..abdf504 100644 --- a/configs/M5485AFE_defconfig +++ b/configs/M5485AFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485BFE_defconfig b/configs/M5485BFE_defconfig index 1dc119a..0708f18 100644 --- a/configs/M5485BFE_defconfig +++ b/configs/M5485BFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485CFE_defconfig b/configs/M5485CFE_defconfig index 73c4d8a..de2c9f1 100644 --- a/configs/M5485CFE_defconfig +++ b/configs/M5485CFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485DFE_defconfig b/configs/M5485DFE_defconfig index 46ea740..cc93f81 100644 --- a/configs/M5485DFE_defconfig +++ b/configs/M5485DFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485EFE_defconfig b/configs/M5485EFE_defconfig index f2ae822..d084d58 100644 --- a/configs/M5485EFE_defconfig +++ b/configs/M5485EFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485FFE_defconfig b/configs/M5485FFE_defconfig index f2b3f62..0e1b285 100644 --- a/configs/M5485FFE_defconfig +++ b/configs/M5485FFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485GFE_defconfig b/configs/M5485GFE_defconfig index 83f39b0..66e5316 100644 --- a/configs/M5485GFE_defconfig +++ b/configs/M5485GFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/M5485HFE_defconfig b/configs/M5485HFE_defconfig index 2e5bda4..9ec6c45 100644 --- a/configs/M5485HFE_defconfig +++ b/configs/M5485HFE_defconfig @@ -6,4 +6,6 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index c2bc17c..0d0c029 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -6,5 +6,8 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index c243de8..aa23499 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -6,5 +6,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index f8bf52a..ca61e5c 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -6,10 +6,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-mk808c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 0ae4c7f..9e6f50b 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -6,9 +6,12 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index 96c9d54..978e231 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index 1d004fe..35db541 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 893657e..63c6d7b 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index cb3c686..a3d5294 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 97e7672..dfb41f0 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -7,6 +7,8 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 7f6156c..cf2f655 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8323ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y diff --git a/configs/MPC832XEMDS_ATM_defconfig b/configs/MPC832XEMDS_ATM_defconfig index 759165d..0c85f40 100644 --- a/configs/MPC832XEMDS_ATM_defconfig +++ b/configs/MPC832XEMDS_ATM_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index 08f1a41..e9cf0c8 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_33M,PQ_MDS_PIB=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index 43d121c..9272431 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_66M,PQ_MDS_PIB=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index 079d017..d807884 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCISLAVE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y diff --git a/configs/MPC832XEMDS_defconfig b/configs/MPC832XEMDS_defconfig index cf38f89..8900665 100644 --- a/configs/MPC832XEMDS_defconfig +++ b/configs/MPC832XEMDS_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index 988e33a..60561cf 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index 2506e77..fb7485c 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -10,5 +10,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index 80eb01b..65edb63 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -11,5 +11,8 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index 4c8cfce..358656e 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -11,5 +11,8 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index b459a40..0e09e77 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -5,9 +5,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XEMDS_defconfig b/configs/MPC837XEMDS_defconfig index 687fcfa..f7ad159 100644 --- a/configs/MPC837XEMDS_defconfig +++ b/configs/MPC837XEMDS_defconfig @@ -4,8 +4,12 @@ CONFIG_TARGET_MPC837XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index a1982e5..1b2c787 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_MPC837XERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index c70ec54..40d1a3a 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -5,10 +5,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 4343d40..c6afe45 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -5,10 +5,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 003099d..eafa11c 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -5,10 +5,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index a746dbe..0ae81ef 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -4,10 +4,14 @@ CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 4e8b93d..ddc3b5b 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index 1c2316f..a340c8b 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 83c0191..06569e2 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -6,7 +6,9 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_RTL8139=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 06edf18..d038267 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 3b89bda..a42d991 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 21819a3..3a730f9 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index e2de2a2..86db71c 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index d09370e..485e987 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 142d8bf..5ec3712 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 8968ee8..daacef7 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -5,8 +5,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="ATM" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index efbb008..26ab184 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -4,8 +4,12 @@ CONFIG_TARGET_MPC8569MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index b2c5a70..1720d9e 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -9,7 +9,9 @@ CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index c55289a..63cf745 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -8,7 +8,9 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 38e2034..6883249 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -7,6 +7,8 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index b8dede6..c85ddfe 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -9,5 +9,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 98bf168..d71369e 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -8,5 +8,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index d335173..a9d5aae 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -11,9 +11,16 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-primo73" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 3169c92..14db5ae 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -14,11 +14,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-primo81" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y CONFIG_VIDEO_LCD_SSD2828_TX_CLK=27 diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 626fb4c..cb9ca3b 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -6,11 +6,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 2665a64..bae638f 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index b8c8f78..9311799 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -8,10 +8,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 82d91da..831578e 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index ba59216..d628c7c 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -11,11 +11,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 725554d..35df225 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -10,11 +10,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,STATUSLED=234" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index 8d298f8..8a4980e 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 47a12a4..842db29 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -9,8 +9,15 @@ CONFIG_MMC0_CD_PIN="PH18" CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index ab2835c..102b96c 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -7,11 +7,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index d9e609c..bad6a39 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MINIFAP" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2D300_defconfig b/configs/O2D300_defconfig index 929e381..f7d7f00 100644 --- a/configs/O2D300_defconfig +++ b/configs/O2D300_defconfig @@ -6,5 +6,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_RAMBOOT_defconfig b/configs/O2DNT2_RAMBOOT_defconfig index 181a69e..31e309f 100644 --- a/configs/O2DNT2_RAMBOOT_defconfig +++ b/configs/O2DNT2_RAMBOOT_defconfig @@ -10,5 +10,7 @@ CONFIG_AUTOBOOT_STOP_STR="++++++++++" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_defconfig b/configs/O2DNT2_defconfig index 9e45ecd..eb65c22 100644 --- a/configs/O2DNT2_defconfig +++ b/configs/O2DNT2_defconfig @@ -9,5 +9,7 @@ CONFIG_AUTOBOOT_STOP_STR="++++++++++" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2D_defconfig b/configs/O2D_defconfig index f79b3e5..67a7757 100644 --- a/configs/O2D_defconfig +++ b/configs/O2D_defconfig @@ -6,5 +6,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2I_defconfig b/configs/O2I_defconfig index b40b709..7a29872 100644 --- a/configs/O2I_defconfig +++ b/configs/O2I_defconfig @@ -6,5 +6,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M110_defconfig b/configs/O2MNT_O2M110_defconfig index 9327068..4f35c2e 100644 --- a/configs/O2MNT_O2M110_defconfig +++ b/configs/O2MNT_O2M110_defconfig @@ -7,5 +7,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M112_defconfig b/configs/O2MNT_O2M112_defconfig index de360dc..77d1879 100644 --- a/configs/O2MNT_O2M112_defconfig +++ b/configs/O2MNT_O2M112_defconfig @@ -7,5 +7,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M113_defconfig b/configs/O2MNT_O2M113_defconfig index 4425621..6d91a11 100644 --- a/configs/O2MNT_O2M113_defconfig +++ b/configs/O2MNT_O2M113_defconfig @@ -7,5 +7,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_defconfig b/configs/O2MNT_defconfig index b3a656a..e135f93 100644 --- a/configs/O2MNT_defconfig +++ b/configs/O2MNT_defconfig @@ -6,5 +6,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/O3DNT_defconfig b/configs/O3DNT_defconfig index 0fb75c5..b6bc88e 100644 --- a/configs/O3DNT_defconfig +++ b/configs/O3DNT_defconfig @@ -6,5 +6,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 3631181..212f98c 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -12,11 +12,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 9734edf..148b4fa 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -14,11 +14,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index c959a2e..af6a4be 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 6c8bcfd..5ed93a1 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index 6338a08..2c05f6e 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index d084188..4dbff83 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 2de562f..f421b22 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index 148748d..f0a74fd 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index acf03c6..6bd7dcb 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 788fe9e..b8968a8 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index d6138f9..551b9db 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index b0df9d2..7d8ebfe 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index fd8508a..6fd23ac 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 4e047f7..1f29b11 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index 3a74a15..6da92e4 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 8a124ef..fa7cab8 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index 94c5b29..860bc6a 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 1e7e5c3..23d938b 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index a6efbba..5bc446b 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 4971dcb..7b83294 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index f86a05b..234645e 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index b02b1d3..7adcca8 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 1bfba42..c455059 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 75b064f..45f54f7 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 259c443..7d6de18 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 11bc5e3..629fbbb 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index b26fbcb..8f44aee 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 2c88ee8..37ebca3 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 80f1daf..6d6edd1 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f79e913..d21afae 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index 553e5da..a0e4471 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -8,9 +8,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,SDCARD,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index a93663f..d209581 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -7,9 +7,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index 9c3a6f7..d07ed43 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -8,9 +8,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index 9133731..0fe87d1 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -7,9 +7,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index d22bac7..735c53f 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index e046e40..953552d 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index dc6d861..ec94e06 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index a486593..044e739 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index cc2a569..3bd72f0 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index a7c00df..a9a659c 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 08286f7..f01dbc3 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 6a8bc3c..37e14da 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 23e05d5..63faa06 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 872a247..255b8e2 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 82a318e..61a635a 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index f5e8a1b..f8e633a 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index 442d43a..d6775d9 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -8,9 +8,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index 0f4519c..054e9fc 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -7,9 +7,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index 93fe60c..b0553ef 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -8,9 +8,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index 6118f0f..36f7366 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -7,9 +7,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index 108b467..b24f8ec 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index b17a3a0..8f618ae 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index 83027ad..70e4d44 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 1d76a55..e119bef 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 622ed59..772a313 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 72d5835..9206cc7 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 2fff1ab..85c03aa 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 341f905..ae78a8e 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index a57882f..af98b8e 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index edb6476..0ea0201 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index c54094e..4093449 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index 6b6811d..24e8678 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index c7e2cfd..cbc3d76 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 7e321a4..8c36f58 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 4f68c00..1c7b323 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index 2b1925f..b5dee33 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -6,10 +6,14 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index cc31300..bdf91d2 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -8,7 +8,10 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index 13546c3..bcc0aed 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index b80d2d9..dc74708 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index 5250e16..a59ddde 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index 2ba4ceb..9993593 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 4feecb5..8f723c6 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index 6e5b913..5285f79 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index cef9432..ec6038c 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 0949ae1..6ba76fa 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index 35fbc67..86b9cd7 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index b1afcc0..f7ce9b6 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 19dee97..21d98e3 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index a48bdb9..ce42c82 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index abcb328..c8f86e2 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index ec3d1e2..a6a01e8 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 9faa181..0f10e08 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -9,10 +9,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index d463d9d..8649e52 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index f8f3f14..1764f2c 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -8,10 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 84338ce..b9610e4 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -7,10 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 8e3df02..d4b1c55 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 02401e6..a36e731 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 568e44d..4d40511 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 85c45f2..c2dbd98 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index db34b71..3dbf5a3 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 91da52a..aea98c6 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -6,11 +6,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index 16b8770..d5b1c12 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index aed8b9c..dfe0e17 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index e8910b9..a8e2131 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index 6abde1b..13e2fed 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index ed37b05..901c373 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index 6882a6d..f9285a8 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index e8fa833..d648d97 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -6,11 +6,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index e3f6724..aaa97f7 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index eb89714..437e05a 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index c8eb351..a3f0d85 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index 23353c7..7059c81 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 3a2e976..752a6c6 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -6,11 +6,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index c2112fa..2ecb0b8 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index 61b4f21..c26e729 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index c823f05..acc617e 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index d220264..24d4f17 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index df41373..3e97ee0 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index b831253..f381326 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index 8efb577..d7145ae 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -6,11 +6,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index fd3ccfa..0495c4d 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 068cb68..9be5ff1 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index c3149d8..6675164 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index 4828534..552d93a 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 1793865..2caec57 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index ed72c24..07e67c8 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -6,11 +6,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index c9fb9d4..fe88739 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -6,5 +6,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index 9fe4dc4..c1795a4 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -9,6 +9,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/PMC405DE_defconfig b/configs/PMC405DE_defconfig index ccbd7b3..8f60d87 100644 --- a/configs/PMC405DE_defconfig +++ b/configs/PMC405DE_defconfig @@ -9,6 +9,7 @@ CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index f80410f..4d060ab 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -10,6 +10,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 2fdb844..4136841 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -13,11 +13,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 011dfd6..03cef97 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -7,8 +7,15 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index b39164b..dc781db 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 878d22f..13dbb98 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -16,11 +16,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_USB_EHCI_HCD=y diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 0957dc3..9a916c9 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -9,13 +9,18 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index f9dd7db..2c41d03 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -9,13 +9,18 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index 9577fe2..e3cf48d 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index e0b3ae1..5ce9ed9 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -9,13 +9,18 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index ec0609f..44c9584 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -7,12 +7,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index ef01c2e..6c4505f 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index f3235bf..0af7eab 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 2be1046..efdcbeb 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 1bca42a..12a0376 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index b22bba8..84da583 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index a9bea77..03d009f 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 622e560..a70963f 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index ecd027f..a012f3d 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 77e93b4..d7cce8b 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 68ac112..ceae6cf 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 3443db8..1359aad 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index d11b954..7ffacd4 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -7,12 +7,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index 3fb702d..a07a59a 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index acfa55f..e4c095e 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 777c448..a2c1495 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index c1e16b2..9a78aa9 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index 3d1040e..f2415d9 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 8399ec8..df9e295 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index a7998bb..7f889c7 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 9c21b33..f93f0b9 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 6ed2f86..023dc37 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 10dfd33..bacb060 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index b9bb5be..9d6d9fb 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index f33805b..b5a050c 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 8dcf3e5..a50f177 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 4620e54..f70d5ce 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 54ffb94..4f21813 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 0ca5bb0..07bdcf6 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index ba4b274..a49d32d 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 488923e..23f83e6 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 3a52ea9..1935dad 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index c3d7cf6..f093e92 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 0b608a9..f7126e5 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index aa66095..f0aed08 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index dbb5bb6..0057e22 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 09b5bf5..8905b6c 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 51d452b..2459eba 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 33da1b4..b937af4 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index ba7f61d..049819e 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index c1c7e42..8634477 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 6753118..40c871e 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 36dc163..795a3f0 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 147ce69..c6e0710 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -9,11 +9,15 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index ebbb9e1..51caeeb 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -9,11 +9,15 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index d57cc6d..f4190af 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -9,11 +9,15 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SECURE_BOOT" CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 8bac4a0..9d4821d 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -9,11 +9,15 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index ad5ce54..0a15e05 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -10,11 +10,15 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 20ccc45..955b394 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -8,11 +8,15 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080" CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index 1589d31..0b0e120 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index fa04188..bffca40 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 0100ad9..fc8f1f5 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig index 17e95d2..ed075eb 100644 --- a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index ce8453f..844fe10 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index 20fd55a..92b0391 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index cc056d5..2a30e11 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index 4483184..37aac2a 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index b4533ab..3b13a34 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 5a90b2b..3523fe1 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index 423f4ed..c2a16fd 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index eceac1a..3ec6c75 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index dde4f56..18c8e67 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index eea72e3..c590410 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -8,12 +8,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index 1c38761..afb665d 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 2c1847f..85fd13b 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -8,11 +8,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 9af072d..21e22be 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -7,11 +7,16 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/TQM5200S_HIGHBOOT_defconfig b/configs/TQM5200S_HIGHBOOT_defconfig index 1269e39..7adc71c 100644 --- a/configs/TQM5200S_HIGHBOOT_defconfig +++ b/configs/TQM5200S_HIGHBOOT_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200S_defconfig b/configs/TQM5200S_defconfig index d8a724a..f098954 100644 --- a/configs/TQM5200S_defconfig +++ b/configs/TQM5200S_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,TQM5200S" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index abecdb4..70eb383 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,SYS_TEXT_BASE=0xFFF00000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index 86e8572..6734495 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 7592cc5..d0adb77 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="STK52XX_REV100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 90821b3..4456361 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -3,11 +3,15 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index b60d087..9bf21f5 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -4,7 +4,9 @@ CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,NEC_NL6448BC20" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_defconfig b/configs/TQM823L_defconfig index 28ad9e1..9f3218b 100644 --- a/configs/TQM823L_defconfig +++ b/configs/TQM823L_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823M_defconfig b/configs/TQM823M_defconfig index c569b24..9a0ba9d 100644 --- a/configs/TQM823M_defconfig +++ b/configs/TQM823M_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM823M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index f8d9df8..00dd80d 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -4,9 +4,11 @@ CONFIG_TARGET_TQM834X=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/TQM850L_defconfig b/configs/TQM850L_defconfig index 9e71d16..088ed6d 100644 --- a/configs/TQM850L_defconfig +++ b/configs/TQM850L_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM850L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850M_defconfig b/configs/TQM850M_defconfig index 77a9a6c..ab3c44b 100644 --- a/configs/TQM850M_defconfig +++ b/configs/TQM850M_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM850M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855L_defconfig b/configs/TQM855L_defconfig index 4d443c5..6ece068 100644 --- a/configs/TQM855L_defconfig +++ b/configs/TQM855L_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM855L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855M_defconfig b/configs/TQM855M_defconfig index 344da70..9940f96 100644 --- a/configs/TQM855M_defconfig +++ b/configs/TQM855M_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM855M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860L_defconfig b/configs/TQM860L_defconfig index 6c47c3e..4aec4ff 100644 --- a/configs/TQM860L_defconfig +++ b/configs/TQM860L_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM860L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860M_defconfig b/configs/TQM860M_defconfig index 2a65fd9..12b090a 100644 --- a/configs/TQM860M_defconfig +++ b/configs/TQM860M_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM860M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862L_defconfig b/configs/TQM862L_defconfig index e20def2..41737a3 100644 --- a/configs/TQM862L_defconfig +++ b/configs/TQM862L_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM862L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862M_defconfig b/configs/TQM862M_defconfig index 61a993f..642dd02 100644 --- a/configs/TQM862M_defconfig +++ b/configs/TQM862M_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM862M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM866M_defconfig b/configs/TQM866M_defconfig index e3ca7c7..3d0bf8c 100644 --- a/configs/TQM866M_defconfig +++ b/configs/TQM866M_defconfig @@ -3,7 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM866M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM885D_defconfig b/configs/TQM885D_defconfig index 5b8b869..2238cdd 100644 --- a/configs/TQM885D_defconfig +++ b/configs/TQM885D_defconfig @@ -3,9 +3,12 @@ CONFIG_8xx=y CONFIG_TARGET_TQM885D=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index 2c823db..df4efa4 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -4,7 +4,9 @@ CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ104V7DS01" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index 40d22fb..8d2f2e6 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -7,9 +7,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TWR_P1025" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index d532e5f..bd976fe 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -10,13 +10,17 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b" +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 3472c07..0e21822 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -10,13 +10,17 @@ CONFIG_SYS_PROMPT="B$ " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b" +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index bad17c3..948107c 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -21,11 +21,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-utoo-p66" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig index 8bf5717..4c2df57 100644 --- a/configs/VCMA9_defconfig +++ b/configs/VCMA9_defconfig @@ -7,3 +7,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y diff --git a/configs/VOM405_defconfig b/configs/VOM405_defconfig index 3f80c58..8fb023a 100644 --- a/configs/VOM405_defconfig +++ b/configs/VOM405_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index f25a296..d754ccd 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -14,11 +14,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 6eaa9d6..4a7dbdb 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -13,11 +13,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 84200e8..0b40b83 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -8,10 +8,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 3163ca8..fab74f4 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -20,10 +20,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-yones-toptech-bd1078" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 440fd54..71f01db 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -17,10 +17,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-yones-toptech-bs1078-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/a3m071_defconfig b/configs/a3m071_defconfig index b47e308..97e4fc5 100644 --- a/configs/a3m071_defconfig +++ b/configs/a3m071_defconfig @@ -8,7 +8,9 @@ CONFIG_HUSH_PARSER=y CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_CACHE=y CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index c724993..5111bc0 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -10,6 +10,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m2k_defconfig b/configs/a4m2k_defconfig index 7bbecf3..fc344c5 100644 --- a/configs/a4m2k_defconfig +++ b/configs/a4m2k_defconfig @@ -9,7 +9,9 @@ CONFIG_HUSH_PARSER=y CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_CACHE=y CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/ac14xx_defconfig b/configs/ac14xx_defconfig index d839fc8..36fb7af 100644 --- a/configs/ac14xx_defconfig +++ b/configs/ac14xx_defconfig @@ -4,8 +4,10 @@ CONFIG_TARGET_AC14XX=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_PROMPT="ac14xx> " +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index d98ff2d..31889fa 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -3,10 +3,13 @@ CONFIG_4xx=y CONFIG_TARGET_ACADIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 8a2f7de..6daefcc 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -1,6 +1,10 @@ CONFIG_NDS32=y CONFIG_TARGET_ADP_AG101P=y CONFIG_SYS_PROMPT="NDS32 # " +CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index a23d59f..bfa243f 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_ALT=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -20,8 +22,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index ea6e0f9..78f55cc 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -8,15 +8,24 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 7cd15dd..d310e0b 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -10,16 +10,26 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DFU_TFTP=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 0231eed..903f518 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -13,16 +13,26 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index fade82f..62f26b5 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -10,16 +10,26 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 6dc4e25..f230671 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -7,15 +7,25 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 239b607..3fbc07b 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -4,15 +4,25 @@ CONFIG_NOR=y CONFIG_NOR_BOOT=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 896f060..65d88d8 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -6,16 +6,26 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SPI_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index f6b173f..eee5e9b 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -6,16 +6,26 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND,SPL_USBETH_SUPPORT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig index b069e3c..d7f126e 100644 --- a/configs/am335x_gp_evm_defconfig +++ b/configs/am335x_gp_evm_defconfig @@ -7,16 +7,26 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_igep0033_defconfig b/configs/am335x_igep0033_defconfig index 424018a..d6022a3 100644 --- a/configs/am335x_igep0033_defconfig +++ b/configs/am335x_igep0033_defconfig @@ -4,13 +4,22 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index dbc44b1..c227ef4 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -6,13 +6,22 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index b860870..a8b8465 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_PROMPT="AM3517_CRANE # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -14,4 +15,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index fa169fa..d400c35 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -6,9 +6,12 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AM3517_EVM # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -16,6 +19,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am437x_gp_evm_defconfig b/configs/am437x_gp_evm_defconfig index d634fbd..03b02ac 100644 --- a/configs/am437x_gp_evm_defconfig +++ b/configs/am437x_gp_evm_defconfig @@ -8,16 +8,26 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/am437x_sk_evm_defconfig b/configs/am437x_sk_evm_defconfig index 66b88a1..48ec91f 100644 --- a/configs/am437x_sk_evm_defconfig +++ b/configs/am437x_sk_evm_defconfig @@ -10,16 +10,26 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DMA=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index fd97124..a6ae011 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -3,16 +3,26 @@ CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 3065710..662556a 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -3,16 +3,26 @@ CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_ETH_SUPPORT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index e92d918..00fa6be 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -2,16 +2,26 @@ CONFIG_ARM=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index f6f6375..e3d6b57 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -3,16 +3,26 @@ CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_USB_HOST_SUPPORT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 608f172..8fc3ebb 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -8,15 +8,24 @@ CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 32a94b3..47d103b 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -3,14 +3,23 @@ CONFIG_OMAP54XX=y CONFIG_TARGET_BEAGLE_X15=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index 25826ca..f169fd3 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -9,4 +9,5 @@ CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index 5c15b71..5192032 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -16,4 +16,5 @@ CONFIG_TARGET_AP325RXA=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ap_sh4a_4a_defconfig b/configs/ap_sh4a_4a_defconfig index df7c344..77a0aa5 100644 --- a/configs/ap_sh4a_4a_defconfig +++ b/configs/ap_sh4a_4a_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index dcf1a3e..40a65d2 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -7,16 +7,26 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra30-apalis" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis T30 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_E1000=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 2945e91..88912e5 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -4,9 +4,15 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="BIOS> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 92e3046..0df8ac0 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -4,9 +4,14 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/arches_defconfig b/configs/arches_defconfig index 64adfd7..e05a64c 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -5,9 +5,13 @@ CONFIG_ARCHES=y CONFIG_DEFAULT_DEVICE_TREE="arches" CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_SYS_NS16550=y diff --git a/configs/aria_defconfig b/configs/aria_defconfig index 1c8c8a7..fb3257b 100644 --- a/configs/aria_defconfig +++ b/configs/aria_defconfig @@ -3,8 +3,10 @@ CONFIG_MPC512X=y CONFIG_TARGET_ARIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 8a75880..0f68eba 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -4,14 +4,23 @@ CONFIG_TARGET_ARISTAINETOS2=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 623f7b8..2457513 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -4,14 +4,23 @@ CONFIG_TARGET_ARISTAINETOS2B=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index ae5ade4..ad2bf08 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -4,14 +4,23 @@ CONFIG_TARGET_ARISTAINETOS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 06a7630..1224da4 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARMADILLO_800EVA=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -18,6 +19,7 @@ CONFIG_TARGET_ARMADILLO_800EVA=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 259cb22..0cd529e 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -8,15 +8,24 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_SOUND=y CONFIG_I2S=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 118f96b..9888c7e 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -6,3 +6,4 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 3776bda..bea73a5 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -3,9 +3,12 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 0c69da8..8012531 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -4,9 +4,12 @@ CONFIG_TARGET_AT91RM9200EK=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 014cb95..d8ec7f1 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index a755103..eb17f91 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index bb65e89..26ffd97 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index e196e8a..4e8dfa1 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 4c26cc1..c5684f2 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 34e6ff1..0fba314 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 2978f2d..b09395f 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -5,13 +5,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 2978f2d..b09395f 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -5,13 +5,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 6e30d94..dd46a68 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -5,13 +5,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 5b35645..25b9a17 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -5,13 +5,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_BOOT_NORFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index cca6b13..3cdce9b 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -5,13 +5,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index ef1af38..9ff65b5 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index d5c9a98..76c3b15 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 7de00c6..7438b86 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index db0af22..0cded82 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -4,13 +4,16 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 7bb5fd5..ddfce14 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -4,13 +4,16 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index c7b5faf..8ce99ee 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 4f89b50..9ed2b84 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 063284d..f8f6afb 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 663433d..c931af2 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -6,13 +6,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index e1a1bfc..4aeca48 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -6,13 +6,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 4f429cc..2c4a81a 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -4,14 +4,17 @@ CONFIG_TARGET_AT91SAM9N12EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_MMC" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 4b27ab3..726d811 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -5,14 +5,17 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 25f5a35..d0cff22 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -5,14 +5,17 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_SPIFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 6dc8dbc..dda3edf 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -5,12 +5,15 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_DATAFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index dcf8ec6..c300438 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -5,12 +5,15 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_MMC" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 3e825aa..6b033fb 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -5,12 +5,15 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index c4a0808..56aa2a0 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 62756f6..db501c5 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index aad7e85..7f0b1a4 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -5,15 +5,18 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 310de74..f7a4d16 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -5,15 +5,18 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 861c3ff..0ded2ab 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 2b8fa1b..7995419 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 2a1fde8..c859cb6 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9260EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set @@ -13,4 +14,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/atngw100_defconfig b/configs/atngw100_defconfig index 02f6f97..685d5ac 100644 --- a/configs/atngw100_defconfig +++ b/configs/atngw100_defconfig @@ -7,11 +7,15 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/atngw100mkii_defconfig b/configs/atngw100mkii_defconfig index b45c426..c392df7 100644 --- a/configs/atngw100mkii_defconfig +++ b/configs/atngw100mkii_defconfig @@ -7,10 +7,15 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/atstk1002_defconfig b/configs/atstk1002_defconfig index 47c1a35..bd37d2e 100644 --- a/configs/atstk1002_defconfig +++ b/configs/atstk1002_defconfig @@ -7,7 +7,11 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index fbdd4f2..ba43e35 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TAURUS=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2068,BOARD_AXM" # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index b79dd3c..85af09e 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -7,10 +7,12 @@ CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_SYS_PROMPT="AXS# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index a208a27..aa9bf33 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -7,10 +7,12 @@ CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_SYS_PROMPT="AXS# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 863169a..b61b15c 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -11,11 +11,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index de5a857..b0f6bb3 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -3,11 +3,17 @@ CONFIG_4xx=y CONFIG_TARGET_BAMBOO=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 4c03856..ce1f519 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -26,6 +27,11 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index aaeb555..b8ec8ac 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -2,13 +2,18 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index f693095..6021fd2 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -2,13 +2,18 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 75fbe46..bfd519e 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -1,13 +1,18 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 299ffa0..1911122 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -2,13 +2,18 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="BCM_SF2_ETH,BCM_SF2_ETH_GMAC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index 68109d8..d8a30d1 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -2,10 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index 6cf2186..205db1e 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -2,10 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index ec7370f..bcb24b4 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -2,10 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index b939927..527f4a5 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -2,10 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index ec7370f..bcb24b4 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -2,10 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index ec7370f..bcb24b4 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -2,10 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index e149735..6d06b4e 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -2,9 +2,13 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bct-brettl2_defconfig b/configs/bct-brettl2_defconfig index c7e223a..3e61a3f 100644 --- a/configs/bct-brettl2_defconfig +++ b/configs/bct-brettl2_defconfig @@ -5,6 +5,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index f0921e8..b9323c2 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -7,19 +7,29 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra30-beaver" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index 41f1490..0b6f517 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -1,14 +1,19 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF518F_EZBRD=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf526-ezbrd_defconfig b/configs/bf526-ezbrd_defconfig index 614a137..85c2a6b 100644 --- a/configs/bf526-ezbrd_defconfig +++ b/configs/bf526-ezbrd_defconfig @@ -7,9 +7,13 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/bf527-ad7160-eval_defconfig b/configs/bf527-ad7160-eval_defconfig index 793ccfe..b5f5f5d 100644 --- a/configs/bf527-ad7160-eval_defconfig +++ b/configs/bf527-ad7160-eval_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_AD7160_EVAL=y # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -8,6 +9,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf527-ezkit-v2_defconfig b/configs/bf527-ezkit-v2_defconfig index 9035165..ff797f8 100644 --- a/configs/bf527-ezkit-v2_defconfig +++ b/configs/bf527-ezkit-v2_defconfig @@ -8,9 +8,13 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_LIB_RAND=y diff --git a/configs/bf527-ezkit_defconfig b/configs/bf527-ezkit_defconfig index 0b63ece..eff2a12 100644 --- a/configs/bf527-ezkit_defconfig +++ b/configs/bf527-ezkit_defconfig @@ -6,9 +6,13 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_NET_TFTP_VARS is not set CONFIG_SPI_FLASH=y diff --git a/configs/bf527-sdp_defconfig b/configs/bf527-sdp_defconfig index a15b92b..5137293 100644 --- a/configs/bf527-sdp_defconfig +++ b/configs/bf527-sdp_defconfig @@ -8,6 +8,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/bf533-ezkit_defconfig b/configs/bf533-ezkit_defconfig index 84def80..6b2395a 100644 --- a/configs/bf533-ezkit_defconfig +++ b/configs/bf533-ezkit_defconfig @@ -7,5 +7,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/bf533-stamp_defconfig b/configs/bf533-stamp_defconfig index af9ebd2..ef23ea7 100644 --- a/configs/bf533-stamp_defconfig +++ b/configs/bf533-stamp_defconfig @@ -8,6 +8,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y # CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/bf537-minotaur_defconfig b/configs/bf537-minotaur_defconfig index b7e11af..7c17cbb 100644 --- a/configs/bf537-minotaur_defconfig +++ b/configs/bf537-minotaur_defconfig @@ -8,6 +8,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf537-pnav_defconfig b/configs/bf537-pnav_defconfig index 9190de8..cb01bc1 100644 --- a/configs/bf537-pnav_defconfig +++ b/configs/bf537-pnav_defconfig @@ -6,9 +6,11 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf537-srv1_defconfig b/configs/bf537-srv1_defconfig index 49a6fed..f8288d9 100644 --- a/configs/bf537-srv1_defconfig +++ b/configs/bf537-srv1_defconfig @@ -8,6 +8,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf537-stamp_defconfig b/configs/bf537-stamp_defconfig index dc61dfd..15e5254 100644 --- a/configs/bf537-stamp_defconfig +++ b/configs/bf537-stamp_defconfig @@ -1,14 +1,19 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_STAMP=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/bf538f-ezkit_defconfig b/configs/bf538f-ezkit_defconfig index 5ca81e8..2c71498 100644 --- a/configs/bf538f-ezkit_defconfig +++ b/configs/bf538f-ezkit_defconfig @@ -8,5 +8,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y # CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/bf548-ezkit_defconfig b/configs/bf548-ezkit_defconfig index c7277f2..6d398ac 100644 --- a/configs/bf548-ezkit_defconfig +++ b/configs/bf548-ezkit_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF548_EZKIT=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -10,6 +11,9 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf561-acvilon_defconfig b/configs/bf561-acvilon_defconfig index 7e5d007..3ecdd9f 100644 --- a/configs/bf561-acvilon_defconfig +++ b/configs/bf561-acvilon_defconfig @@ -8,8 +8,10 @@ CONFIG_CMD_SPI=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf561-ezkit_defconfig b/configs/bf561-ezkit_defconfig index 987b58a..1e99b4b 100644 --- a/configs/bf561-ezkit_defconfig +++ b/configs/bf561-ezkit_defconfig @@ -6,5 +6,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/bf609-ezkit_defconfig b/configs/bf609-ezkit_defconfig index 71e8406..68788a6 100644 --- a/configs/bf609-ezkit_defconfig +++ b/configs/bf609-ezkit_defconfig @@ -1,12 +1,17 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF609_EZKIT=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 1388370..709dfab 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -2,13 +2,16 @@ CONFIG_ARM=y CONFIG_TARGET_BG0900=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 14c0ce3..44ed671 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -5,16 +5,27 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index aebf7f1..861bdcf 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -5,16 +5,27 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/blackstamp_defconfig b/configs/blackstamp_defconfig index 2415b43..679aee1 100644 --- a/configs/blackstamp_defconfig +++ b/configs/blackstamp_defconfig @@ -6,5 +6,6 @@ CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/blackvme_defconfig b/configs/blackvme_defconfig index c6b87b2..808cc3d 100644 --- a/configs/blackvme_defconfig +++ b/configs/blackvme_defconfig @@ -5,6 +5,8 @@ CONFIG_TARGET_BLACKVME=y CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/br4_defconfig b/configs/br4_defconfig index 0ca6567..db5d915 100644 --- a/configs/br4_defconfig +++ b/configs/br4_defconfig @@ -9,9 +9,11 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bubinga_defconfig b/configs/bubinga_defconfig index facf9fd..d570d41 100644 --- a/configs/bubinga_defconfig +++ b/configs/bubinga_defconfig @@ -3,9 +3,12 @@ CONFIG_4xx=y CONFIG_TARGET_BUBINGA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index b375453..2eefd15 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="CADDY2" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 96f8ea0..a8775f3 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -4,15 +4,24 @@ CONFIG_TARGET_OMAP3_CAIRO=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Cairo # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 1f88b66..5f6bc5c 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -5,8 +5,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Calimain > " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR="\x0b" +CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/cam5200_defconfig b/configs/cam5200_defconfig index da6f1d5..7224588 100644 --- a/configs/cam5200_defconfig +++ b/configs/cam5200_defconfig @@ -4,10 +4,12 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CAM5200,TQM5200S,TQM5200_B" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/cam5200_niosflash_defconfig b/configs/cam5200_niosflash_defconfig index ef63089..00d8045 100644 --- a/configs/cam5200_niosflash_defconfig +++ b/configs/cam5200_niosflash_defconfig @@ -4,10 +4,12 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/canmb_defconfig b/configs/canmb_defconfig index 5caea0d..8d3b476 100644 --- a/configs/canmb_defconfig +++ b/configs/canmb_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_CANMB=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_SNTP=y diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index d95fe73..aac031b 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -5,12 +5,18 @@ CONFIG_CANYONLANDS=y CONFIG_DEFAULT_DEVICE_TREE="canyonlands" CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 42e0b2c..979b693 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -7,9 +7,11 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra30-cardhu" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -19,7 +21,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index d164d1a..68cf2ac 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -5,15 +5,26 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index f391963..ea50729 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -3,11 +3,15 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index ef0e95b..25ead92 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -10,17 +10,25 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-jerry" CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" CONFIG_REGMAP=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 8088f0c..91e902f 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -27,6 +27,11 @@ CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 20ea99a..238eeac 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -26,6 +26,11 @@ CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index e18c3c7..245f164 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -23,6 +23,11 @@ CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 9ecf08e..0fde640 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -4,8 +4,10 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CLEARFOG=y CONFIG_DEFAULT_DEVICE_TREE="armada-388-clearfog" CONFIG_SPL=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -13,8 +15,14 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_DEBUG_UART=y diff --git a/configs/cm-bf527_defconfig b/configs/cm-bf527_defconfig index a9dafeb..072483a 100644 --- a/configs/cm-bf527_defconfig +++ b/configs/cm-bf527_defconfig @@ -4,8 +4,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf533_defconfig b/configs/cm-bf533_defconfig index 14b959c..1fb91b2 100644 --- a/configs/cm-bf533_defconfig +++ b/configs/cm-bf533_defconfig @@ -5,5 +5,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/cm-bf537e_defconfig b/configs/cm-bf537e_defconfig index 6366048..c65a703 100644 --- a/configs/cm-bf537e_defconfig +++ b/configs/cm-bf537e_defconfig @@ -1,12 +1,17 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537E=y +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf537u_defconfig b/configs/cm-bf537u_defconfig index 67b04d1..b030a27 100644 --- a/configs/cm-bf537u_defconfig +++ b/configs/cm-bf537u_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537U=y +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y @@ -8,5 +9,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index 90187bd..1355dd4 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -7,6 +7,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y # CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/cm-bf561_defconfig b/configs/cm-bf561_defconfig index 086a05a..b6e711e 100644 --- a/configs/cm-bf561_defconfig +++ b/configs/cm-bf561_defconfig @@ -5,5 +5,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/cm5200_defconfig b/configs/cm5200_defconfig index 7f854f9..c7df400 100644 --- a/configs/cm5200_defconfig +++ b/configs/cm5200_defconfig @@ -2,11 +2,14 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_CM5200=y CONFIG_OF_BOARD_SETUP=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 13612f7..4193764 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -6,11 +6,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-FX6 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -19,6 +22,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index bf8d21e..1b29331 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -3,12 +3,21 @@ CONFIG_TARGET_CM_T335=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T335 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 774e259..72283a6 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -3,8 +3,10 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_CM_T3517=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3517 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -12,6 +14,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 32d73ec..9a7b205 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -4,8 +4,10 @@ CONFIG_TARGET_CM_T35=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -13,5 +15,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index e9494dd..c926a3a 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -5,8 +5,11 @@ CONFIG_DM_GPIO=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T43 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -15,7 +18,13 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index a372aa3..bcab16b 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -5,8 +5,11 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T54 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -14,6 +17,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index 6926104..0bcb9a2 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -5,9 +5,12 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index c174b9c..a3b2a3c 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -7,16 +7,27 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T20 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 24f0763..c920b39 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -7,16 +7,26 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra30-colibri" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T30 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 9e37e21..df17f2e 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -7,14 +7,23 @@ CONFIG_DEFAULT_DEVICE_TREE="vf610-colibri" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_IS_IN_NAND,IMX_NAND" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index 95d55be..655a0e7 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -17,11 +17,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-colorfly-e708-q1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO2_VOLT=1800 CONFIG_USB_MUSB_HOST=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index a802bbd..5186345 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -26,6 +27,11 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index aa53c60..7cc9a6e 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -9,11 +9,15 @@ CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD,DEVELOP" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TPM=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index e4de7aa..ee7739a 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -9,11 +9,15 @@ CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TPM=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index 59072cc..be8174b 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH,DEVELOP" # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TPM=y CONFIG_DM=y diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index b1e3a80..74b5266 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH" # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TPM=y CONFIG_DM=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index e614122..2fa11fd 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -18,6 +18,11 @@ CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 44fb275..37488dd 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -6,10 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,MACH_TYPE=2066,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 60a6727..78bda52 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -14,6 +14,11 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 5d0079e..7c6b692 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -14,6 +14,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -24,6 +25,11 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 8f85ca0..0b77b1b 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -11,7 +11,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 8772ec8..8fd51ad 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -5,12 +5,17 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 64bed91..866d187 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -6,12 +6,17 @@ CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 2105ebf..0bb2d37 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -4,9 +4,11 @@ CONFIG_TARGET_DA850EVM=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_ASKENV=y CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index a2a6e23..75eaad8 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -7,19 +7,29 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra114-dalmore" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 802e684..e9ba1ef 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -14,8 +14,14 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index c656c94..7ad3bb6 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-gp" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -13,8 +14,14 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 373773d..44f64fd 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -14,8 +14,14 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/defconfig b/configs/defconfig new file mode 100644 index 0000000..abd5ced --- /dev/null +++ b/configs/defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_OMAP34XX=y +CONFIG_TARGET_DEVKIT8000=y +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_SYS_NS16550=y +CONFIG_OF_LIBFDT=y diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index 5d55c49..5449cff 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -5,11 +5,17 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DEVCONCENTER" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index b659da6..eca6e86 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -12,7 +12,10 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 0e1cfc5..c8021c6 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -6,10 +6,14 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 214a1ae..2b6dba8 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -17,10 +17,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index ad8292f..67fda76 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -14,5 +14,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index e87618f..e05583f 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -12,5 +12,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index cd24c16..424c214 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -14,5 +14,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index e617acc..4579ab6 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -14,5 +14,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index 5565bb8..1ebfd23 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -8,9 +8,12 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dlvision_defconfig b/configs/dlvision_defconfig index 6554fb3..7b28d1d 100644 --- a/configs/dlvision_defconfig +++ b/configs/dlvision_defconfig @@ -6,8 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dnp5370_defconfig b/configs/dnp5370_defconfig index 1da61c1..b6d3b74 100644 --- a/configs/dnp5370_defconfig +++ b/configs/dnp5370_defconfig @@ -2,5 +2,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_DNP5370=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index ac236cd..a3d053d 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -7,6 +7,9 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 2fecf39..6ae447c 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -7,6 +7,9 @@ CONFIG_SYS_PROMPT="DockStar> " CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dra72_evm_defconfig b/configs/dra72_evm_defconfig index 9b5cd78..00c6ac3 100644 --- a/configs/dra72_evm_defconfig +++ b/configs/dra72_evm_defconfig @@ -11,16 +11,26 @@ CONFIG_DEFAULT_DEVICE_TREE="dra72-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/dra74_evm_defconfig b/configs/dra74_evm_defconfig index 47fd428..a11dcd5 100644 --- a/configs/dra74_evm_defconfig +++ b/configs/dra74_evm_defconfig @@ -10,16 +10,26 @@ CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 41cdbbf..b6458ae 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -5,16 +5,26 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/dra7xx_evm_qspiboot_defconfig b/configs/dra7xx_evm_qspiboot_defconfig index 15e94a0..8ebfe49 100644 --- a/configs/dra7xx_evm_qspiboot_defconfig +++ b/configs/dra7xx_evm_qspiboot_defconfig @@ -6,16 +6,26 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/dra7xx_evm_uart3_defconfig b/configs/dra7xx_evm_uart3_defconfig index ccc2124..54c7ba9 100644 --- a/configs/dra7xx_evm_uart3_defconfig +++ b/configs/dra7xx_evm_uart3_defconfig @@ -7,16 +7,26 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="SPL_YMODEM_SUPPORT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index bfee48a..0a437ed 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -7,15 +7,21 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 68b5de4..2566ded 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -6,11 +6,18 @@ CONFIG_SYS_PROMPT="dragonboard410c => " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_CLK=y CONFIG_MSM_GPIO=y CONFIG_PM8916_GPIO=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index c6b3b53..d293e30 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -8,7 +8,11 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index fb5d916..4d3cb34 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -13,8 +13,11 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 254440f..b0791b9 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -15,10 +15,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 41f669b..ad564e4 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -4,8 +4,11 @@ CONFIG_TARGET_DUOVERO=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="duovero # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -13,6 +16,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index c23a298..eb01dec 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -8,16 +8,25 @@ CONFIG_SYS_PROMPT="Tegra210 (E2220-1170) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 2c0f1e8..d6e51f8 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EA20=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_SPI=y @@ -11,6 +12,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 5dcf4ec..55d5552 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_PROMPT="\nEB+CPU5282> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index a714458..e204ba2 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xF0000418" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index 33dcc7b..467a0a1 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -7,10 +7,15 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ECO5-PK # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ecovec_defconfig b/configs/ecovec_defconfig index 93ad9ba..0066c7d 100644 --- a/configs/ecovec_defconfig +++ b/configs/ecovec_defconfig @@ -18,6 +18,9 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index c56f90a..91ba24f 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -3,8 +3,12 @@ CONFIG_TARGET_EDB93XX=y CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="EDB9315A> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index d2a36e5..fa7c1b5 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -7,4 +7,5 @@ CONFIG_SYS_PROMPT="EDMiniV2> " CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 1954717..412c2bc 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -14,6 +14,11 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM_PCI=y diff --git a/configs/espt_defconfig b/configs/espt_defconfig index 9d491cf..78e319c 100644 --- a/configs/espt_defconfig +++ b/configs/espt_defconfig @@ -16,6 +16,7 @@ CONFIG_TARGET_ESPT=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 7739473..579efd3 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -5,7 +5,9 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -13,9 +15,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CDP=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index d5ff72f..4dd4586 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -6,14 +6,22 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 1c7155f..0995f9b 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -8,17 +8,25 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" CONFIG_REGMAP=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index b51bff8..298888c 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -7,4 +7,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index f2ea59b..babfaf4 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -4,11 +4,15 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index c5f943d..03cdb17 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -19,11 +19,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index b1038d6..17b1458 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -10,6 +10,7 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -20,6 +21,11 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index 336d602..eacd4bb 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -5,9 +5,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 62aa0cd..ffa0440 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -2,14 +2,24 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B450V3=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index bfe9de1..b039c24 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -2,14 +2,24 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B650V3=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index bc34fdf..d9c8acd 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -2,14 +2,24 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B850V3=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index 4e85e13..6d0dabe 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -5,11 +5,15 @@ CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index 3b72ecb..e7e1287 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -6,11 +6,15 @@ CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/canyonlands/u-boot-ram.lds" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 2bdea8c..ee02469 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -7,6 +7,10 @@ CONFIG_SYS_PROMPT="GoFlexHome> " CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 6e3de27..9f6589a 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_GOSE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -19,8 +21,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 3b99683..2bdd0e7 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_GPLUGD=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y @@ -8,7 +9,10 @@ CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/grasshopper_defconfig b/configs/grasshopper_defconfig index 8dc1b63..25b9c4e 100644 --- a/configs/grasshopper_defconfig +++ b/configs/grasshopper_defconfig @@ -7,6 +7,7 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 723a4f2..c11aed8 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -18,10 +18,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 453afb0..0baf3a3 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -2,12 +2,17 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_GURUPLUG=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index e0d5acd..9959ef4 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -11,14 +11,24 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Ventana > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 066f353..7c731b3 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -12,11 +12,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-allwinner-h8homlet-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 6ee9a30..c90eff4 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -4,9 +4,12 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="HALEAKALA" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index c706bfa..129a72b 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -7,16 +7,24 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index b853a4e..56bf948 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -6,9 +6,15 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds...\nPress <s> to stop or <d> to delay\n" CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 32b5c65..f5660ea 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -2,8 +2,15 @@ CONFIG_ARM=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index af6d28f..32d0486 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -8,8 +8,11 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index c060a07..657826a 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -7,7 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="HRCON_DH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index e552f5d..266015a 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -8,11 +8,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 871811e..e9ec810 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -15,10 +15,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3f" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index b57d5bc..64da00f 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -15,10 +15,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3w" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index e1a678a..8b64678 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -14,10 +14,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 22ef1a6..265114f 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -3,12 +3,16 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_IB62X0=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ib62x0 => " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ibf-dsp561_defconfig b/configs/ibf-dsp561_defconfig index 7237cfe..5ce6abc 100644 --- a/configs/ibf-dsp561_defconfig +++ b/configs/ibf-dsp561_defconfig @@ -6,4 +6,5 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_LIB_RAND=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index d9b65b8..d432ff0 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -15,11 +15,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index ccf465d..d32bbc4 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -3,10 +3,16 @@ CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index cd6fbb2..44a474e 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -6,6 +6,9 @@ CONFIG_SYS_PROMPT="iconnect => " # CONFIG_CMD_FLASH is not set CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 08867e7..794b85e 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 6d1dd01..66dd93f 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -4,14 +4,24 @@ CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0020_nand_defconfig b/configs/igep0020_nand_defconfig index 05037f7..7535d10 100644 --- a/configs/igep0020_nand_defconfig +++ b/configs/igep0020_nand_defconfig @@ -4,14 +4,24 @@ CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 40150c2..3ab5c69 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -4,13 +4,23 @@ CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_nand_defconfig b/configs/igep0030_nand_defconfig index 821e058..cdab71b 100644 --- a/configs/igep0030_nand_defconfig +++ b/configs/igep0030_nand_defconfig @@ -4,13 +4,23 @@ CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 1374be2..d609d89 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -4,14 +4,24 @@ CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 8e64ef6..b0f244d 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -15,11 +15,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index ca7c260..a953795 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -14,10 +14,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet97fv2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index badf78b..dace876 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -17,10 +17,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index c7fc889..35d9d7c 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -14,10 +14,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet9f-rev03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 79f2144..483703a 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -11,7 +11,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/inka4x0_defconfig b/configs/inka4x0_defconfig index e465e1b..506a8f8 100644 --- a/configs/inka4x0_defconfig +++ b/configs/inka4x0_defconfig @@ -7,3 +7,5 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/intip_defconfig b/configs/intip_defconfig index b2d1b0b..512d4a8 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -7,11 +7,17 @@ CONFIG_SYS_EXTRA_OPTIONS="INTIB" CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/io64_defconfig b/configs/io64_defconfig index f387a71..afc5a83 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -7,9 +7,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/io_defconfig b/configs/io_defconfig index f7351a0..1bb9248 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index 5675808..2e66b94 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -7,9 +7,13 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ip04_defconfig b/configs/ip04_defconfig index b872dea..b944b07 100644 --- a/configs/ip04_defconfig +++ b/configs/ip04_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 3f771ea..cee6988 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -5,8 +5,10 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index d8ff177..e0b4390 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -7,4 +7,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 99189b2..79f3cfb 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index d123be0..7b04a0c 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -7,19 +7,29 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra124-jetson-tk1" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 1d8cc82..044a9bf 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -7,7 +7,9 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2E EVM # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_SF=y @@ -16,7 +18,13 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index ee6f335..d0b45ce 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -6,8 +6,11 @@ CONFIG_DEFAULT_DEVICE_TREE="k2g-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -15,7 +18,13 @@ CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 4864d09..3975e80 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -7,7 +7,9 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2HK EVM # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_SF=y @@ -16,7 +18,13 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 7e60dff..844dd57 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -7,7 +7,9 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2L EVM # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_SF=y @@ -16,7 +18,13 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/katmai_defconfig b/configs/katmai_defconfig index db79d95..b3e61f8 100644 --- a/configs/katmai_defconfig +++ b/configs/katmai_defconfig @@ -3,10 +3,16 @@ CONFIG_4xx=y CONFIG_TARGET_KATMAI=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 13e8412..add96a8 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -4,15 +4,22 @@ CONFIG_TARGET_KC1=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="kc1 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index 9048227..f85cfbb 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -4,9 +4,12 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="KILAUEA" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 4ac1501..24413a1 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index a617759..991fe1d 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 6dda308..11c1b71 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 82ea876..03e69f3 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -11,10 +11,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 85bee4e..bdf98a4 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 6edcab6..3d1b986 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 1f9b461..6256bb4 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index b589ae8..7911445 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -11,10 +11,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index fb52ab0..f5f36b7 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index eed0155..14fb873 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index 4d4cc50..ef965ea 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 8728c35..33dab62 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 262b004..92d2787 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index b311c48..b450499 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index e049219..a27a9ef 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmvect1_defconfig b/configs/kmvect1_defconfig index e24ce97..2d74209 100644 --- a/configs/kmvect1_defconfig +++ b/configs/kmvect1_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 2b681fe..5c45f7b 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_KOELSCH=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -20,8 +22,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/kwb_defconfig b/configs/kwb_defconfig index c07e1e5..30558e7 100644 --- a/configs/kwb_defconfig +++ b/configs/kwb_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_BOOTM is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_GO is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -14,6 +15,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -24,6 +26,8 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETCONSOLE=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index 3f26874..50fbe65 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -6,14 +6,22 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index 6a16d8c..e3902ce 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -2,8 +2,10 @@ CONFIG_ARM=y CONFIG_RMOBILE=y CONFIG_TARGET_KZM9G=y CONFIG_SYS_PROMPT="KZM-A9-GT# " +CONFIG_CMD_BOOTZ=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index e3eeabf..c262117 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_LAGER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -19,8 +21,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 89b3f9d..d080f05 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -6,12 +6,17 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds - press 'l' to stop...\n" CONFIG_AUTOBOOT_STOP_STR="l" # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 5976cb2..6feb581 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -6,13 +6,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 5ba935b..563af48 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -6,13 +6,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index ac042b5..0786f20 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -5,13 +5,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 5610e06..243fcdd 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -5,13 +5,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 6947d3f..3cecdfe 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -5,13 +5,19 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index ab4fc54..75b763e 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -6,13 +6,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 924d323..c47fbce 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -6,15 +6,21 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 667bedc..61ab251 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -4,13 +4,19 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index a50fe68..bb88743 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -5,15 +5,21 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 2ee3b91..a5cbb22 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -5,13 +5,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index a1bfbc1..465054f 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -5,13 +5,19 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 34a8569..e96e31a 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -6,13 +6,19 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 571550b..987638c 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -6,15 +6,21 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 2f76715..df4d428 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -5,12 +5,18 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 9c4e2da..583325d 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -7,14 +7,20 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index da0577b..346faf4 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -7,13 +7,20 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index e65e07f..2c6ac35 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -8,13 +8,20 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 441eb2c..cc8d8fa 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -8,13 +8,20 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 4b8c4f4..7d0646c 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -6,13 +6,20 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 8c72836..8ea1416 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -7,14 +7,21 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,QSPI_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 86f6ac2..7e5949d 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -8,13 +8,20 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 84b75f5..609fd63 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -8,14 +8,21 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 3c6bcfe..cacee2f 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -7,11 +7,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index b74adfb..49d0740 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -7,11 +7,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 8076ffa..d240cde 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -8,11 +8,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 4133fc3..f853685 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -8,11 +8,16 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 1e56c08..f9b4eac 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -10,6 +10,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_I2C=y @@ -18,7 +19,9 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index c3429a0..728fa25 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -10,16 +10,21 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index f3f2467..216559c 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -10,12 +10,18 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A, SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 05e33d1..854630a 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -10,12 +10,18 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index ac30219..4f385a1 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -7,11 +7,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 13d09d0..41d30a6 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -10,12 +10,18 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A, SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index b2e3464..2b775cd 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -10,12 +10,18 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index f27bf6b..0f184c0 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -7,11 +7,17 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index da8f1a1..4af7e5d 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y @@ -10,7 +11,11 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 3068617..5bcd367 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y @@ -10,7 +11,11 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/luan_defconfig b/configs/luan_defconfig index ec443f9..e0fa805 100644 --- a/configs/luan_defconfig +++ b/configs/luan_defconfig @@ -3,9 +3,13 @@ CONFIG_4xx=y CONFIG_TARGET_LUAN=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 9999f45..64794a1 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -4,11 +4,14 @@ CONFIG_TARGET_LWMON5=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 54829a9..c598c72 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -4,14 +4,23 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 1e9450d..62496c3 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -5,9 +5,17 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index adda7fb..81a6700 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -5,15 +5,25 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index a153e4d..8f7baea 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -3,9 +3,12 @@ CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 02bad1e..6e7b326 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -3,14 +3,23 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 3319d3f..7a5eeba 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 67bc80c..ab814cc 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -8,13 +8,18 @@ CONFIG_SYS_PROMPT="mcx # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y diff --git a/configs/mecp5123_defconfig b/configs/mecp5123_defconfig index c2e45de..9597482 100644 --- a/configs/mecp5123_defconfig +++ b/configs/mecp5123_defconfig @@ -3,8 +3,11 @@ CONFIG_MPC512X=y CONFIG_TARGET_MECP5123=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index e5fb0cc..02eb704 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -8,16 +8,24 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 2c2df2e..3d295f5 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index a0bf894..aac7cc5 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/mgcoge3ne_defconfig b/configs/mgcoge3ne_defconfig index 5dd0856..d404c8b 100644 --- a/configs/mgcoge3ne_defconfig +++ b/configs/mgcoge3ne_defconfig @@ -8,7 +8,10 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index f1735c0..484abbe 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mgcoge_defconfig b/configs/mgcoge_defconfig index 86de799..2cc8f44 100644 --- a/configs/mgcoge_defconfig +++ b/configs/mgcoge_defconfig @@ -8,7 +8,10 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 39c2ad2..8c7e4b7 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -9,10 +9,12 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot-mONStR> " +CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index a46b37a..9930d56 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -26,6 +27,11 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 74486a1..9a44466 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -10,11 +10,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index e1dc927..5e545d0 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -8,11 +8,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 35f0bfa..a76a699 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -7,11 +7,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 90addf4..bdfb597 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -5,10 +5,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802ii" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index 6e568d4..eaaa5ed 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -6,8 +6,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_defconfig b/configs/mpc5121ads_defconfig index 73bf67f..34935ad 100644 --- a/configs/mpc5121ads_defconfig +++ b/configs/mpc5121ads_defconfig @@ -3,9 +3,13 @@ CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_rev2_defconfig b/configs/mpc5121ads_rev2_defconfig index 7df336c..664d949 100644 --- a/configs/mpc5121ads_rev2_defconfig +++ b/configs/mpc5121ads_rev2_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MPC5121ADS_REV2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index 29d7d61..1f28c08 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -7,6 +7,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpr2_defconfig b/configs/mpr2_defconfig index 6a832c7..a8dbfc5 100644 --- a/configs/mpr2_defconfig +++ b/configs/mpr2_defconfig @@ -18,5 +18,6 @@ CONFIG_TARGET_MPR2=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index 55d480a..2ef3105 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -18,5 +18,7 @@ CONFIG_TARGET_MS7720SE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index a4933f4..dda0daa 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -7,12 +7,17 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y diff --git a/configs/munices_defconfig b/configs/munices_defconfig index 6dd615b..eabfe1e 100644 --- a/configs/munices_defconfig +++ b/configs/munices_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_MUNICES=y CONFIG_OF_BOARD_SETUP=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 59daea6..e201abb 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -4,8 +4,12 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index cc7157e..b1bd634 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -2,11 +2,16 @@ CONFIG_ARM=y CONFIG_TARGET_MX23EVK=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx25pdk_defconfig b/configs/mx25pdk_defconfig index 66bff20..1c1afd8 100644 --- a/configs/mx25pdk_defconfig +++ b/configs/mx25pdk_defconfig @@ -2,10 +2,16 @@ CONFIG_ARM=y CONFIG_TARGET_MX25PDK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 12a4011..8738f59 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -3,14 +3,22 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index d425a30..de8a297 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -4,14 +4,22 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index e591a37..83ff3a3 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -3,14 +3,22 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 2aa8f1b..906d3da 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -3,14 +3,22 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index bcb85a1..e1bb561 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -1,8 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_MX31PDK=y CONFIG_SPL=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 486e7d9..e6cc065 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -1,10 +1,16 @@ CONFIG_ARM=y CONFIG_TARGET_MX35PDK=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index b9b8d24..0b3b232 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -2,10 +2,14 @@ CONFIG_ARM=y CONFIG_TARGET_MX51EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index b4d821e..500b39c 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -2,8 +2,12 @@ CONFIG_ARM=y CONFIG_TARGET_MX53ARD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53evk_defconfig b/configs/mx53evk_defconfig index 9dec972..45f5e45 100644 --- a/configs/mx53evk_defconfig +++ b/configs/mx53evk_defconfig @@ -3,8 +3,11 @@ CONFIG_TARGET_MX53EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53evk/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 2e34ccb..da9aa4f 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -2,9 +2,15 @@ CONFIG_ARM=y CONFIG_TARGET_MX53LOCO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53smd_defconfig b/configs/mx53smd_defconfig index 3d85014..c24aec6 100644 --- a/configs/mx53smd_defconfig +++ b/configs/mx53smd_defconfig @@ -3,8 +3,11 @@ CONFIG_TARGET_MX53SMD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53smd/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 40ad38f..9d06940 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -4,12 +4,21 @@ CONFIG_TARGET_MX6CUBOXI=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index a7554b7..eb30bf6 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -3,11 +3,20 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,DDR_MB=2048" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index af2c985..dc52b9b 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -3,11 +3,20 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,MX6DL_LPDDR2,DDR_MB=512" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index 12157ba..de925d9 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -3,14 +3,25 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 01c8122..2fcc088 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -3,14 +3,25 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index ff4af17..391da69 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -3,11 +3,20 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,DDR_MB=2048" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index 5e02437..af3b9b0 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -3,11 +3,20 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,MX6DQ_LPDDR2,DDR_MB=512" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index ee56d4e..6212540 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -3,13 +3,24 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 0e24307..250411d 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -3,14 +3,25 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index a19556d..66575b8 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 1b69092..7456cf3 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -3,14 +3,25 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 7be6374..8d5e289 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -4,14 +4,23 @@ CONFIG_TARGET_MX6SABRESD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 47cf613..9f29b15 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -3,15 +3,24 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index b5de314..a43de4a 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -3,15 +3,24 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL,SYS_BOOT_SPINOR" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index b3f5c93..2efd833 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -4,13 +4,22 @@ CONFIG_TARGET_MX6SLEVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 17ad20e..8a4c7d5 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -3,16 +3,25 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabreauto/imximage.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 954201b..55093c9 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -3,15 +3,24 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 8d3cae3..f01fd3b 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -4,14 +4,23 @@ CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index a241e88..dee1ef0 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -4,12 +4,20 @@ CONFIG_TARGET_MX6UL_14X14_EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 88ef332..644fd20 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -4,12 +4,20 @@ CONFIG_TARGET_MX6UL_9X9_EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 05da67b..fd86546 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -6,18 +6,28 @@ CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 0d5a683..f904e12 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="nas220> " CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/neo_defconfig b/configs/neo_defconfig index cdfb432..e306d68 100644 --- a/configs/neo_defconfig +++ b/configs/neo_defconfig @@ -6,8 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index d35458f..f930e47 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -11,7 +11,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 9090518..7917336 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -11,7 +11,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 6cb311e..55978f2 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -11,7 +11,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 90af1c7..67b142d 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -10,7 +10,10 @@ CONFIG_CMD_SF=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 1de1308..8199bbd 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -11,7 +11,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index af8c8bb..cc86e3f 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 1896e44..05dcea2 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 8de9ea0..2de93a4 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index e08020d..a5f57f6 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index a67e01c..fdd444e 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index f5f5519..daace52 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -3,16 +3,26 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 60106b3..6eb01ea 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -8,10 +8,14 @@ CONFIG_AUTOBOOT_KEYED=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SAVEENV is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 90db4ff..69e5ea9 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -5,14 +5,24 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index ddd9004..51da5ad 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -3,12 +3,16 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NSA310S=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nsa310s => " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 40032df..262042d 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -9,23 +9,33 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Nyan-big) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_CROS_EC_KEYB=y CONFIG_CMD_CROS_EC=y CONFIG_CROS_EC=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 942e8be..8995cc2 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -8,15 +8,26 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DM_I2C_COMPAT=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index a32fb56..ff3b339 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -8,18 +8,29 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Odroid # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM_I2C_COMPAT=y CONFIG_DM_PMIC=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index e2ffc7b..78f71d6 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -4,14 +4,24 @@ CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index d02b47a..1a9f207 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -6,11 +6,15 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP3_EVM # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/omap3_evm_quick_mmc_defconfig b/configs/omap3_evm_quick_mmc_defconfig index 1af2b45..3385d67 100644 --- a/configs/omap3_evm_quick_mmc_defconfig +++ b/configs/omap3_evm_quick_mmc_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_PROMPT="OMAP3_EVM # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set @@ -24,4 +25,5 @@ CONFIG_SYS_PROMPT="OMAP3_EVM # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index e609988..5f0dece 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -7,11 +7,15 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 6062e5f..3226247 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -6,15 +6,25 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP Logic # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index a1df368..6189296 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -4,9 +4,12 @@ CONFIG_TARGET_OMAP3_OVERO=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Overo # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -15,6 +18,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 67d4dd7..ec50417 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -3,9 +3,12 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_PANDORA=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Pandora # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set @@ -14,6 +17,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index afb2286..db2aafc 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -2,15 +2,24 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_ZOOM1=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 06450c3..406f0ac 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -3,8 +3,11 @@ CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_PANDA=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -12,6 +15,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 6ca4baf..c5d6d61 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -3,8 +3,11 @@ CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_SDP4430=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y @@ -12,6 +15,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index f242d55..f67676f 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -3,15 +3,25 @@ CONFIG_OMAP54XX=y CONFIG_TARGET_OMAP5_UEVM=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_DWC3=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 57bef31..4d5e8a0 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -5,10 +5,15 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 79f6eda..7001921 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_OPENRD=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_BASE" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 12b9046..fd53c78 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_OPENRD=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_CLIENT" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index b640560..52b9a5b 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_OPENRD=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_ULTIMATE" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/openrisc-generic_defconfig b/configs/openrisc-generic_defconfig index d8a3b4c..a476ba7 100644 --- a/configs/openrisc-generic_defconfig +++ b/configs/openrisc-generic_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_OPENRISC_GENERIC=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 7e0be1e..f33ac36 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -11,11 +11,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 6a36955..de6e9c8 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -10,9 +10,16 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 98bbbc2..7bade8f 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -9,11 +9,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 07ed4b5..2df5859 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -13,11 +13,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11)" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 666e206..b1740dc 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -5,13 +5,24 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ORIGEN # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index b839c76..c604340 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -3,14 +3,23 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_OT1200=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/bachmann/ot1200/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 0b0330b..b5791ad 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -4,14 +4,23 @@ CONFIG_TARGET_OT1200=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index ae3105a..d27fd6d 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -9,16 +9,25 @@ CONFIG_SYS_PROMPT="Tegra210 (P2371-0000) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 6ee99d1..4e365b5 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -9,16 +9,25 @@ CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index b2a76a5..2b3c5c6 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -9,16 +9,25 @@ CONFIG_SYS_PROMPT="Tegra210 (P2571) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index f807990..0fe43b1 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -7,16 +7,24 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-paz00" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/pb1000_defconfig b/configs/pb1000_defconfig index d2f9258..6aa2c43 100644 --- a/configs/pb1000_defconfig +++ b/configs/pb1000_defconfig @@ -12,5 +12,6 @@ CONFIG_SYS_PROMPT="Pb1x00 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/pcm030_LOWBOOT_defconfig b/configs/pcm030_LOWBOOT_defconfig index cc8f2a8..dbfaea1 100644 --- a/configs/pcm030_LOWBOOT_defconfig +++ b/configs/pcm030_LOWBOOT_defconfig @@ -6,4 +6,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFF000000" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm030_defconfig b/configs/pcm030_defconfig index 25482e2..6d25884 100644 --- a/configs/pcm030_defconfig +++ b/configs/pcm030_defconfig @@ -6,4 +6,5 @@ CONFIG_SYS_PROMPT="uboot> " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 909a157..7f29119 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -3,8 +3,11 @@ CONFIG_TARGET_PCM051=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="REV1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -12,7 +15,13 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index d9f5c48..eff099c 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -3,8 +3,11 @@ CONFIG_TARGET_PCM051=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="REV3" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -12,7 +15,13 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 7226f56..db8ebdd 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -5,12 +5,16 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="pcm052" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index ad9d9c7..c352195 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -5,8 +5,10 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index b718650..c8c74c0 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -8,7 +8,9 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pi # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -16,12 +18,19 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 68bacc0..c5fbf8c 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -8,7 +8,9 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pit # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -16,12 +18,19 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 4698b2e..3eba3ce 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -2,15 +2,24 @@ CONFIG_ARM=y CONFIG_TARGET_PENGWYN=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index bee3477..4a46f24 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -3,13 +3,22 @@ CONFIG_TARGET_PEPPER=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="pepper# " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 750fefd..9547d48 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -14,13 +14,20 @@ CONFIG_LOOPW=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index e4f8265..723466f 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -6,13 +6,16 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index a2e0b26..0494a9f 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -9,6 +9,12 @@ CONFIG_DEFAULT_DEVICE_TREE="pine64_plus" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 703f43a..9676a99 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -5,13 +5,22 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6DL" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="picon > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 1064baf..f3de3fc 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -5,13 +5,22 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="titanium > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 9c698f8..ed519a0 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -8,16 +8,24 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index a73d6ed..cb10fa3 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -12,3 +12,4 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index c97ac16..37629ba 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -12,3 +12,4 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 9dcc20c..0949e1f 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -11,3 +11,4 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 11cf100..2b3b4c8 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -7,6 +7,9 @@ CONFIG_SYS_PROMPT="PogoE02> " CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index 7a7651e..cedbf53 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -18,10 +18,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 2edfeaf..2f819f5 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_PORTER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -20,8 +22,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/portl2_defconfig b/configs/portl2_defconfig index c2ad41b..87fd221 100644 --- a/configs/portl2_defconfig +++ b/configs/portl2_defconfig @@ -7,10 +7,13 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 605d589..aad9619 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -15,10 +15,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/pr1_defconfig b/configs/pr1_defconfig index f087b3f..e7cf5e8 100644 --- a/configs/pr1_defconfig +++ b/configs/pr1_defconfig @@ -9,9 +9,11 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index df371f7..8655665 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -8,15 +8,22 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 48a37cd..97232ce 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -17,10 +17,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index ded6ffc..79dcc33 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -18,10 +18,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index a4eb5c5..ff29e81 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -18,10 +18,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index dc820ea..d87700c 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -18,10 +18,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index e474494..f7f3fb0 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -6,10 +6,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 2e891e2..53b1ff6 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -21,6 +21,11 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_CPU=y CONFIG_SPI_FLASH=y diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index 3d9ef12..0826a0c 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -8,5 +8,7 @@ CONFIG_SYS_PROMPT="qemu-mips64 # " # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index 9eb93ef..f70ebc3 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -9,5 +9,7 @@ CONFIG_SYS_PROMPT="qemu-mips64el # " # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index cc440f8..bb09796 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -6,5 +6,7 @@ CONFIG_SYS_PROMPT="qemu-mips # " # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index 3fa84ab..19e6c7d 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -7,5 +7,7 @@ CONFIG_SYS_PROMPT="qemu-mipsel # " # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r0p7734_defconfig b/configs/r0p7734_defconfig index 91926d4..5214923 100644 --- a/configs/r0p7734_defconfig +++ b/configs/r0p7734_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index f4df61a..bd553be 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -2,4 +2,6 @@ CONFIG_SH=y CONFIG_TARGET_R2DPLUS=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index a067693..4e1c393 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -7,11 +7,18 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 7d8cb38..ad6f2f0 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -18,4 +18,5 @@ CONFIG_TARGET_R7780MP=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index 6684bd9..27998f3 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -4,9 +4,14 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 0679959..6ebdb38 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -4,9 +4,14 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 73b3b36..ec89f05 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -7,15 +7,21 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/redwood_defconfig b/configs/redwood_defconfig index afdb0ed..89c129f 100644 --- a/configs/redwood_defconfig +++ b/configs/redwood_defconfig @@ -3,9 +3,13 @@ CONFIG_4xx=y CONFIG_TARGET_REDWOOD=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index cbd97d7..60a06ab 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -3,14 +3,23 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 4bfd7c8..fd32fb5 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -8,17 +8,25 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" CONFIG_REGMAP=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index b8f99aa..a26f767 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -4,12 +4,19 @@ CONFIG_TARGET_RPI_2=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index bf0ca97..922e01b 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -4,12 +4,19 @@ CONFIG_TARGET_RPI_3_32B=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index c823d0e..bff92df 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -6,10 +6,16 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 9ddd6bc..fc512b9 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -4,12 +4,19 @@ CONFIG_TARGET_RPI=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rsk7203_defconfig b/configs/rsk7203_defconfig index 40adf42..b63ad4e 100644 --- a/configs/rsk7203_defconfig +++ b/configs/rsk7203_defconfig @@ -17,5 +17,6 @@ CONFIG_TARGET_RSK7203=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index e2993cb..406eaf3 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -8,15 +8,22 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 2e2cc2a..c35287d 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -7,11 +7,18 @@ CONFIG_SYS_PROMPT="Goni # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index f28b928..638b728 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -4,15 +4,26 @@ CONFIG_TARGET_S5PC210_UNIVERSAL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-universal_c210" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Universal # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 05efce5..7fd37d6 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D2_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 1b6649c..de4e6bc 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D2_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_SERIALFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 7de3247..189a3e9 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -4,12 +4,18 @@ CONFIG_TARGET_SAMA5D3_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 8c61615..16e3f22 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -4,12 +4,18 @@ CONFIG_TARGET_SAMA5D3_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 9795c0c..8d3c3cf 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -4,13 +4,17 @@ CONFIG_TARGET_SAMA5D3XEK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index f77145a..8e15286 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -4,13 +4,17 @@ CONFIG_TARGET_SAMA5D3XEK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 08773f5..ffbafae 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -4,13 +4,17 @@ CONFIG_TARGET_SAMA5D3XEK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_SERIALFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 3d020b5..1ea5cda 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D4_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index f93bbdb..5384917 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D4_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 7b231d9..b709cf6 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D4_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 356aebc..45128e9 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D4EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index a599251..9c1c232 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D4EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index a328c8c..59eb4dd 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -4,15 +4,18 @@ CONFIG_TARGET_SAMA5D4EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index cc04361..afdf4a3 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -18,8 +18,11 @@ CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MX_CYCLIC=y @@ -35,6 +38,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CDP=y CONFIG_CMD_SNTP=y @@ -48,6 +52,11 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_NETCONSOLE=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 73c2762..9dd60b7 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -5,10 +5,14 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index b55d644..60bb817 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_33M" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index 3de150d..6c0fd99 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_66M" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index f311a2d..e22c70a 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 649e36e..6d5b3f6 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI,33,PCIE" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index f0e3982..8ecb126 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI,33" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index ce6d600..bbea0cb 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI,66,PCIE" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index 5e37927..f146b2d 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_EXTRA_OPTIONS="PCI,66" CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index fa6e61e..3dea198 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 097748a..4b73506 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -4,8 +4,13 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 5c72a09..3f8648d 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -7,9 +7,11 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-seaboard" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -17,7 +19,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 0da341f..2c57714 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -7,9 +7,18 @@ CONFIG_SECOMX6_2GB=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SECO MX6Q uQ7 U-Boot > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index ecda85b..66d6a1a 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -4,10 +4,15 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 1c3a0b9..5c548ff 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -4,10 +4,15 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index 5a77fe0..07594d1 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -11,14 +11,17 @@ CONFIG_TARGET_SH7752EVB=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index 0dd488f..5e7a9c9 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -10,14 +10,17 @@ CONFIG_TARGET_SH7753EVB=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index b75fd84..fafba4c 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -11,14 +11,17 @@ CONFIG_TARGET_SH7757LCR=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 983f2a2..cc20fbd 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -16,6 +16,7 @@ CONFIG_TARGET_SH7763RDP=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index ab2cff7..cc31e1c 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -19,4 +19,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index 059f5f7..d7724b3 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -18,4 +18,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index a51abc7..71ce49c 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -2,12 +2,18 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_SHEEVAPLUG=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index acad1d6..0beef09 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_SILK=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -20,8 +22,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index e526653..2ec6e48 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -13,9 +13,11 @@ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig index 39375de..702b36c 100644 --- a/configs/smdk2410_defconfig +++ b/configs/smdk2410_defconfig @@ -6,3 +6,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index e46fcae..5d88391 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -8,7 +8,9 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -16,11 +18,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 39b329a..40de7c1 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -8,7 +8,9 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -16,8 +18,15 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index 01a3eb0..a989e24 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -7,3 +7,5 @@ CONFIG_SYS_PROMPT="SMDKC100 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 19662c8..b8638e2 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -5,12 +5,21 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4210-smdkv310" CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDKV310 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index f45243d..2f8dd50 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -17,4 +17,6 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 5458b48..f725693 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -16,4 +16,6 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 444a78a..1b313c4 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -4,15 +4,22 @@ CONFIG_TARGET_SNIPER=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="sniper # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 3a53d26..97133df 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -8,7 +8,9 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="snow # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -16,13 +18,20 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index a64a1e2..9a7c091 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -10,15 +10,27 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index caa3999..ac81854 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -10,15 +10,27 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 9a8dbaa..405d9d4 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -10,15 +10,27 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 5e3d09c..3615490 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -10,15 +10,27 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 823c512..bdc8e6b 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -10,15 +10,27 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index ae6c23e..b64ea15 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -10,15 +10,27 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index d29027c..c4b215a 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -10,16 +10,26 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index fe491b5..aa4bbb6 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -10,7 +10,9 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index 7e40037..af2f544 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear300" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 51e9358..6c53e1f 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear300,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index 5ce8720..6827701 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear300,usbtty" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index 1fa6223..477a226 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear300,usbtty,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index 5f8feee..0991f8e 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear310" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index a070f36..ef30a67 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear310,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index 5802684..6cfe220 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear310,FLASH_PNOR" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index b39f1e0..c0d8edf 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear310,usbtty" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index 8188314..e9d14ce 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear310,usbtty,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index 581dfb1..2e46e64 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear310,usbtty,FLASH_PNOR" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index 558bdb8..8dba79a 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear320" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index d9fcd6a..7f33c78 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear320,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index 3aff58c..f7d3725 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear320,FLASH_PNOR" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index 75855bc..9e41253 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear320,usbtty" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index f0f46c2..e61c74e 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear320,usbtty,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index a4aab03..7410093 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear320,usbtty,FLASH_PNOR" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index fac6a3c..f0e041f 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -7,6 +7,7 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index 8f421b7..cc4067d 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear600,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index 8b8f28d..df21355 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear600,usbtty" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index f0ce802..48140aa 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="spear600,usbtty,nand" CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 2af8184..b720e04 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -8,7 +8,9 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="spring # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -16,13 +18,20 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index d4d1d89..a8f59ca 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -4,12 +4,14 @@ CONFIG_TARGET_STOUT=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -19,8 +21,13 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 316ceaf..985aab8 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -10,8 +10,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 77f4fc1..2766104 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -10,8 +10,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 3cae955..3677da7 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -12,10 +12,17 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-gemei-g9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index 3ab8901..ac6a9e2 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sycamore_defconfig b/configs/sycamore_defconfig index c462fa2..9fdb2b3 100644 --- a/configs/sycamore_defconfig +++ b/configs/sycamore_defconfig @@ -3,9 +3,12 @@ CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/t3corp_defconfig b/configs/t3corp_defconfig index 0deda13..c5562c9 100644 --- a/configs/t3corp_defconfig +++ b/configs/t3corp_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_T3CORP=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 9b096cc..6d0877d 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -7,11 +7,15 @@ CONFIG_SYS_PROMPT="TAO-3530 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 00bd63f..20f33a8 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -5,12 +5,14 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2067,BOARD_TAURUS" CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 1841e93..dc69b39 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -4,15 +4,25 @@ CONFIG_TARGET_TBS2910=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y diff --git a/configs/tcm-bf518_defconfig b/configs/tcm-bf518_defconfig index 91e0f75..cc46a52 100644 --- a/configs/tcm-bf518_defconfig +++ b/configs/tcm-bf518_defconfig @@ -5,8 +5,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/tcm-bf537_defconfig b/configs/tcm-bf537_defconfig index b39e260..576dc6a 100644 --- a/configs/tcm-bf537_defconfig +++ b/configs/tcm-bf537_defconfig @@ -1,12 +1,17 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF537=y +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 8ed7809..b710229 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -8,9 +8,11 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -20,7 +22,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 240f11e..2055101 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -8,16 +8,24 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TEC) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 1eb4b10..8358757 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" CONFIG_SPL=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y @@ -18,8 +19,14 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index e9e6290..157985f 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" CONFIG_SPL=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y @@ -15,7 +16,12 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 0437874..f9391f2 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -7,15 +7,21 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 2208e9a..e41e2a4 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -4,9 +4,14 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 03365fc..4eb7923 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -5,6 +5,9 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="u-boot/ti816x# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 9e38f5d..4d16ef6 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -4,13 +4,22 @@ CONFIG_TARGET_TITANIUM=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/barco/titanium/imximage.cfg" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Titanium > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index b5492a9..22b16a1 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -5,15 +5,24 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 69cf92e..715db21 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -6,15 +6,24 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index 40a6f42..824cd2b 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -6,15 +6,24 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index b141f16..058bb89 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -7,15 +7,24 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index 92cc5c9..e348960 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -11,11 +11,20 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password in %d seconds to stop autoboot\n" CONFIG_AUTOBOOT_ENCRYPTION=y CONFIG_AUTOBOOT_STOP_STR_SHA256="36a9e7f1c95b82ffb99743e0c5c4ce95d83c9a430aac59f84ef3cbfab6145068" +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_PCA9551_LED=y CONFIG_OF_LIBFDT=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 693d845..c2ed8c8 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -7,15 +7,26 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats2 # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 66a11c9..46bfc4e 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -6,15 +6,26 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 21d0bbf..25c499a 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -7,10 +7,13 @@ CONFIG_SYS_PROMPT="OMAP3 Tricorder # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 1dfff4d..200fbe1 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -7,10 +7,13 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 8e8618e..67857a5 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -7,9 +7,11 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -19,7 +21,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index 3a7fa63..7d8953d 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -1,9 +1,13 @@ CONFIG_ARM=y CONFIG_TARGET_TS4800=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y diff --git a/configs/tseries_mmc_defconfig b/configs/tseries_mmc_defconfig index 5abd7f0..4b4cfd2 100644 --- a/configs/tseries_mmc_defconfig +++ b/configs/tseries_mmc_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -12,6 +13,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -22,6 +24,10 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETCONSOLE=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/tseries_nand_defconfig b/configs/tseries_nand_defconfig index 19d9004..1485aaa 100644 --- a/configs/tseries_nand_defconfig +++ b/configs/tseries_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -23,6 +24,10 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETCONSOLE=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/tseries_spi_defconfig b/configs/tseries_spi_defconfig index ae93795..a68cfac 100644 --- a/configs/tseries_spi_defconfig +++ b/configs/tseries_spi_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -12,6 +13,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -24,6 +26,10 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETCONSOLE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 97fb231..475cf47 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 3a03ecb..e2d86d9 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -8,8 +8,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 83cf623..ffbc025 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -7,12 +7,17 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="twister => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index af48888..81c32cd 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -4,10 +4,19 @@ CONFIG_TARGET_UDOO=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index a6862db..22615a6 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -6,8 +6,10 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-ld4-ref" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -17,6 +19,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_GPIO_UNIPHIER=y CONFIG_MMC_UNIPHIER=y diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig index 7d50f1c..18f4caf 100644 --- a/configs/uniphier_pro4_defconfig +++ b/configs/uniphier_pro4_defconfig @@ -5,8 +5,10 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro4-ref" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -16,6 +18,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_GPIO_UNIPHIER=y CONFIG_MMC_UNIPHIER=y diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index 747aeb8..cf6d3e4 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -6,8 +6,10 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-proxstream2-vodka" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -17,6 +19,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_GPIO_UNIPHIER=y CONFIG_MMC_UNIPHIER=y diff --git a/configs/uniphier_sld3_defconfig b/configs/uniphier_sld3_defconfig index f779ded..0965019 100644 --- a/configs/uniphier_sld3_defconfig +++ b/configs/uniphier_sld3_defconfig @@ -5,8 +5,10 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-sld3-ref" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -16,6 +18,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_GPIO_UNIPHIER=y CONFIG_MMC_UNIPHIER=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index 215e87b..17e208b 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -2,11 +2,18 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_TARGET_USBARMORY=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/v38b_defconfig b/configs/v38b_defconfig index 3dadfcc..4dd2612 100644 --- a/configs/v38b_defconfig +++ b/configs/v38b_defconfig @@ -5,4 +5,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index b889976..ed27d85 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -8,5 +8,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index 597f764..82708f0 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -11,5 +11,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 68c4af1..29d16e3 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -8,5 +8,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index 1d73069..31b89e3 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -11,5 +11,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 4243848..4ae3550 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 5749d1c..17a6000 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -7,19 +7,29 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra124-venice2" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index cbb17c9..97b13a1 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -7,16 +7,24 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-ventana" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index 644a207..989f068 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -17,7 +17,10 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 7bae9c9..c70851f 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -17,7 +17,10 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 2006176..b0a2f67 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -17,7 +17,10 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 981352b..ccc9b0d 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -3,18 +3,25 @@ CONFIG_TARGET_VEXPRESS_CA15_TC2=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index 76a6bd1..d75ee7a 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -3,18 +3,25 @@ CONFIG_TARGET_VEXPRESS_CA5X2=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 1248222..0da0a7e 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -3,18 +3,25 @@ CONFIG_TARGET_VEXPRESS_CA9X4=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 4504af2..c014294 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -5,13 +5,17 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 26b045a..d50ad90 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -5,13 +5,17 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 57d0169..e79cc4d 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -4,15 +4,19 @@ CONFIG_TARGET_VINCO=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="vinco => " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 323b416..887afdf 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -6,6 +6,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/walnut_defconfig b/configs/walnut_defconfig index c462fa2..9fdb2b3 100644 --- a/configs/walnut_defconfig +++ b/configs/walnut_defconfig @@ -3,9 +3,12 @@ CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index e03a1d9..195c99b 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -4,13 +4,22 @@ CONFIG_TARGET_WANDBOARD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 29c5e91..e1b0c07 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -6,10 +6,19 @@ CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp7/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index aa15c81..3f9bb25 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -3,14 +3,24 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_WARP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index a6d1438..ca753a4 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -7,9 +7,11 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-whistler" CONFIG_OF_SYSTEM_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Whistler) # " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set @@ -17,7 +19,13 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index ddbd697..b4660cd 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -2,9 +2,14 @@ CONFIG_ARM=y CONFIG_TARGET_WOODBURN=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index d801c3b..bb1ef0a 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -4,9 +4,14 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 12df37b..5663b2f 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SYS_NS16550=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index 8c163fb..9341087 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -4,7 +4,9 @@ CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ065T9DR51U" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y +CONFIG_CMD_EXT2=y CONFIG_OF_LIBFDT=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 05d2f35..1a07b9d 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -12,7 +12,11 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y CONFIG_USE_TINY_PRINTF=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 5f25633..59e1014 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -4,10 +4,14 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index 9d4b137..6c021d7 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -8,10 +8,12 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="xlx-ppc405:/# " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y CONFIG_XILINX_UARTLITE=y diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index 4f814a6..ab0ea5a 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -7,10 +7,12 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="board:/# " +CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_OF_EMBED=y CONFIG_NETCONSOLE=y CONFIG_SYS_NS16550=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 48d95c1..b185593 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -18,8 +18,10 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set @@ -27,9 +29,15 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_I2C_CADENCE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 598da20..cc08b03 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -12,14 +12,22 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_I2C_CADENCE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 81170dc..14d24a0 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -14,12 +14,19 @@ CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_I2C_CADENCE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index a9b68de..e1e11b7 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -11,12 +11,19 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_SYS_I2C_CADENCE=y CONFIG_DM_MMC=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index 05c5cdd..6f1cff8 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -11,14 +11,22 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_MMC=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index f6767f3..a8982a0 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -11,14 +11,22 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_MMC=y diff --git a/configs/xpedite1000_defconfig b/configs/xpedite1000_defconfig index 13e0069..4c0e58e 100644 --- a/configs/xpedite1000_defconfig +++ b/configs/xpedite1000_defconfig @@ -4,9 +4,11 @@ CONFIG_TARGET_XPEDITE1000=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 81eb5f8..b0e92e0 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -6,9 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 77386f5..4a328cd 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -6,9 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index a4dcd78..e0fe947 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -6,9 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index 113d16d..e16c8c8 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -6,10 +6,12 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index fc13e9d..59a3138 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -3,10 +3,19 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_XPRESS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ccv/xpress/imximage.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 9c2bcc5..ad0cddb 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -4,10 +4,19 @@ CONFIG_TARGET_XPRESS=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index 2f1cea2..00992e0 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -4,9 +4,13 @@ CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YELLOWSTONE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index fdede36..3a803f6 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -4,10 +4,16 @@ CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YOSEMITE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yucca_defconfig b/configs/yucca_defconfig index edf1b45..e219fd2 100644 --- a/configs/yucca_defconfig +++ b/configs/yucca_defconfig @@ -3,9 +3,13 @@ CONFIG_4xx=y CONFIG_TARGET_YUCCA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index 22bdbd3..f350387 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -3,10 +3,14 @@ CONFIG_TARGET_ZIPITZ2=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index 0578850..9368610 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -10,3 +10,5 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 748c160..7c66247 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -10,13 +10,22 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index cd41af0..b46ab44 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -7,12 +7,21 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 8471e10..052679a 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -9,14 +9,23 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 99ddf3c..3539f05 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -10,14 +10,23 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 50724b5..6a4726c 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -11,12 +11,20 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index a80dd11..46dd6be 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -15,7 +15,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index dbb0d13..12f0e2c 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -13,7 +13,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index be7c425..8c7efe5 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -15,7 +15,9 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index f3c7e1c..7976e07 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -10,13 +10,22 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 9063010..cd222c5 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -10,14 +10,23 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 4054900..ed502a1 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -13,12 +13,9 @@ * Alphabetical list of all possible commands. */
-#define CONFIG_CMD_ASKENV /* ask for env variable */ #define CONFIG_CMD_BEDBUG /* Include BedBug Debugger */ #define CONFIG_CMD_BMP /* BMP support */ -#define CONFIG_CMD_BOOTZ /* boot zImage */ #define CONFIG_CMD_BSP /* Board Specific functions */ -#define CONFIG_CMD_CACHE /* icache, dcache */ #define CONFIG_CMD_CLK /* Clock support */ #define CONFIG_CMD_DATE /* support for RTC, date/time...*/ #define CONFIG_CMD_DIAG /* Diagnostics */ @@ -26,8 +23,6 @@ #define CONFIG_CMD_DOC /* Disk-On-Chip Support */ #define CONFIG_CMD_DTT /* Digital Therm and Thermostat */ #define CONFIG_CMD_EEPROM /* EEPROM read/write support */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_FDC /* Floppy Disk Support */ #define CONFIG_CMD_FUSE /* Device fuse support */ #define CONFIG_CMD_GETTIME /* Get time since boot */ @@ -39,8 +34,6 @@ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */ #define CONFIG_CMD_KGDB /* kgdb */ #define CONFIG_CMD_MFSL /* FSL support for Microblaze */ -#define CONFIG_CMD_MII /* MII support */ -#define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_MTDPARTS /* mtd parts support */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_ONENAND /* OneNAND support */ diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index a0e490b..766a212 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -43,14 +43,7 @@
#ifdef CONFIG_ARM64 #define CONFIG_CMD_BOOTI -#else -#define CONFIG_CMD_BOOTZ #endif -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_MII #define CONFIG_CMD_PXE
#define CONFIG_CMDLINE_EDITING diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index e3c222e..2666191 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -96,7 +96,6 @@ #ifndef CONFIG_CMDLINE #undef CONFIG_CMDLINE_EDITING #undef CONFIG_SYS_LONGHELP -#undef CONFIG_CMD_ASKENV #undef CONFIG_MENU #endif
diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index 2076ef0..7eb9e98 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -33,7 +33,6 @@ * NET options */ #define CONFIG_SYS_RX_ETH_BUFFER 0 -#define CONFIG_CMD_MII #define CONFIG_PHY_GIGE #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN #define CONFIG_PHY_MARVELL diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index 802ac75..6489de3 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -36,7 +36,6 @@ * NET options */ #define CONFIG_SYS_RX_ETH_BUFFER 0 -#define CONFIG_CMD_MII #define CONFIG_PHY_GIGE #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN #define CONFIG_PHY_MARVELL diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index a9c6272..94c8253 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -736,9 +736,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -763,7 +761,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #endif #endif
diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 07070cd..b092933 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -314,10 +314,7 @@ extern unsigned long get_sdram_size(void); * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_DOS_PARTITION #define CONFIG_CMD_REGINFO
diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 1eb2ff6..3a73379 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -498,7 +498,6 @@ combinations. this should be removed later
#define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC @@ -555,12 +554,9 @@ combinations. this should be removed later #define CONFIG_CMD_DATE #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 1600417..4d14c8b 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -471,7 +471,6 @@ */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index de6ff7f..b66b3ff 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -68,9 +68,7 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_IRQ #define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT #define CONFIG_CMD_DATE -#define CONFIG_CMD_MII #define CONFIG_CMD_BSP #define CONFIG_CMD_EEPROM
diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index cc7aeb8..2b2e4e7 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -22,8 +22,6 @@ #define CONFIG_WATCHDOG_TIMEOUT 5000
/* Command line configuration */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#define CONFIG_MCFFEC diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 133f15c..85b1c15 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -37,7 +37,6 @@ #define CONFIG_BOOTP_HOSTNAME
/* Command line configuration */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_REGINFO diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index b5d49b5..bacd8e0 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -35,8 +35,6 @@ #define CONFIG_BOOTP_HOSTNAME
/* Command line configuration */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO
diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index e29cb24..735c4da 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -39,7 +39,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE
#define CONFIG_SYS_LONGHELP /* undef to save memory */
diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index ada212c..7c06fce 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -39,9 +39,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE
#ifdef CONFIG_CMD_IDE diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index e5aa1c7..d14f979 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -48,9 +48,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE
/* ATA */ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index fcb0587..0753dc3 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -56,8 +56,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII
#define CONFIG_BOOTDELAY 5 #define CONFIG_MCFFEC diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 5f3ec3f..1709ccc 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -55,8 +55,6 @@ #define CONFIG_BOOTP_HOSTNAME
/* Available command configuration */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII
#define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 3442723..8131ea0 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -47,8 +47,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII
#define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index c90ea27..81e28f0 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -27,9 +27,7 @@ #define CONFIG_WATCHDOG_TIMEOUT 5000
/* Command line configuration */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#define CONFIG_SYS_UNIFY_CACHE diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 0e0e109..661063c 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -27,9 +27,7 @@ #define CONFIG_WATCHDOG_TIMEOUT 5000 /* timeout in milliseconds, max timeout is 6.71sec */
#ifdef CONFIG_NANDFLASH_SIZE diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index 39733f9..f0cf715 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -27,9 +27,7 @@ #define CONFIG_WATCHDOG_TIMEOUT 3360 /* timeout in ms, max is 3.36 sec */
#ifdef CONFIG_NANDFLASH_SIZE diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 933b8cd..e10c3e1 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -38,11 +38,9 @@ #define CONFIG_BOOTP_HOSTNAME
/* Command line configuration */ -#define CONFIG_CMD_CACHE #undef CONFIG_CMD_DATE #undef CONFIG_CMD_JFFS2 #undef CONFIG_CMD_UBI -#define CONFIG_CMD_MII #undef CONFIG_CMD_NAND #define CONFIG_CMD_REGINFO
diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 3b01bd6..00bdbd1 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -39,10 +39,8 @@ #define CONFIG_BOOTP_HOSTNAME
/* Command line configuration */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #undef CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* Network configuration */ diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 8a7cea5..f32dd36 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -39,13 +39,9 @@ #define CONFIG_BOOTP_HOSTNAME
/* Command line configuration */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #undef CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO
diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index ff8420f..5fa9683 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -29,9 +29,7 @@ #define CONFIG_WATCHDOG_TIMEOUT 5000 /* timeout in milliseconds, max timeout is 6.71sec */
/* Command line configuration */ -#define CONFIG_CMD_CACHE #undef CONFIG_CMD_DATE -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO
diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 9c83d17..9a23e22 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -29,9 +29,7 @@ #define CONFIG_WATCHDOG_TIMEOUT 5000 /* timeout in milliseconds, max timeout is 6.71sec */
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 7c4509f..75a26ed 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -47,14 +47,11 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SAVES diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 422f223..e3e3b44 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -31,9 +31,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ESDHC_USE_PIO
-#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -430,7 +428,6 @@ * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 4b7a773..fda894e 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -475,7 +475,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_PCI
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index d29519d..41b40cb 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -425,7 +425,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -458,7 +457,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_PCI
diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index f815b20..5c40e5b 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -327,7 +327,6 @@ * Command line configuration. */ #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_ASKENV
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 38bb613..4a1cebb 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -409,7 +409,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index b3a3bc5..3518b3f 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -476,7 +476,6 @@ * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_MII
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 9b3c6ea..8161903 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -487,7 +487,6 @@ boards, we say we have two, but don't display a message if we find only one. */ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_IRQ #define CONFIG_CMD_SDRAM @@ -495,7 +494,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) \ || defined(CONFIG_USB_STORAGE) #define CONFIG_DOS_PARTITION - #define CONFIG_CMD_FAT #define CONFIG_SUPPORT_VFAT #endif
@@ -508,7 +506,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
#if defined(CONFIG_SATA_SIL3114) || defined(CONFIG_USB_STORAGE) - #define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_PCI diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 7f26ecb..28ed9c0 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -445,7 +445,6 @@ extern int board_pci_host_broken(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -478,7 +477,6 @@ extern int board_pci_host_broken(void); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE
#if defined(CONFIG_PCI) @@ -496,10 +494,7 @@ extern int board_pci_host_broken(void); #define CONFIG_FSL_ESDHC #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ebf30e7..fa131e2 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -456,7 +456,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -489,7 +488,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE
#if defined(CONFIG_PCI) @@ -507,10 +505,7 @@ #define CONFIG_FSL_ESDHC #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index f22ba9b..8cc7f02 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -549,7 +549,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#if defined(CONFIG_TSEC_ENET) @@ -617,7 +616,6 @@ * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
@@ -632,7 +630,6 @@ #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #endif
@@ -651,8 +648,6 @@ #endif
diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 4f49633..d827d2a 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -354,7 +354,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 435bdc8..6202dff 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -368,14 +368,12 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI - #define CONFIG_CMD_EXT2 #endif
/* diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 0fdf939..dd07dc4 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -480,7 +480,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 56f6ef5..c68e1d8 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -351,7 +351,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index c049d8d..fb76dd1 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -378,7 +378,6 @@ #endif
#if defined(CONFIG_ETHER_ON_FCC) - #define CONFIG_CMD_MII #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index d42191b..09e32eb 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -372,7 +372,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 37156cb..923159b 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -466,7 +466,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
@@ -482,10 +481,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_FSL_ESDHC #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 00db9b7..9144f32 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -572,13 +572,11 @@ */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI -#define CONFIG_CMD_EXT2 #endif
/* diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index b6539b8..88ca4f3 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -446,12 +446,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII
#define CONFIG_WATCHDOG /* watchdog enabled */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index b2e2f36..3569849 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -613,7 +613,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI - #define CONFIG_CMD_EXT2 #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 87726a4..5719e86 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -718,7 +718,6 @@ extern unsigned long get_sdram_size(void);
#define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC @@ -789,15 +788,12 @@ extern unsigned long get_sdram_size(void); #define CONFIG_CMD_DATE #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) \ || defined(CONFIG_FSL_SATA) -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 5a7bef9..8b29951 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -552,20 +552,16 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #endif
@@ -659,7 +655,6 @@ */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -677,7 +672,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT #endif #endif
diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 74cb57d..fcbe288 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -253,7 +253,6 @@ extern unsigned long get_clock_freq(void); * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) @@ -271,9 +270,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif #endif diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 43709e8..b7a08e0 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -568,7 +568,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -601,9 +600,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI @@ -622,18 +619,13 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #endif
-#define CONFIG_CMD_EXT2 - #define CONFIG_MMC
#ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 7d7e2d0..4bd06a4 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -39,15 +39,12 @@ */ #define CONFIG_CMD_IDE #define CONFIG_CMD_PCI -#define CONFIG_CMD_CACHE #define CONFIG_CMD_IRQ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_REGINFO #define CONFIG_CMD_FDC #define CONFIG_CMD_SCSI -#define CONFIG_CMD_FAT #define CONFIG_CMD_DATE -#define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SAVES #define CONFIG_CMD_BSP diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index a868ec9..71a0375 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -61,10 +61,8 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_IRQ #define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT #define CONFIG_CMD_NAND #define CONFIG_CMD_DATE -#define CONFIG_CMD_MII #define CONFIG_CMD_EEPROM
#define CONFIG_MAC_PARTITION diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index 03c8fb9..a622578 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -58,7 +58,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index e5555cc..005fa2a 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -271,8 +271,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 22f42f0..12260aa 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -667,7 +667,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -680,7 +679,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #endif
/* @@ -690,10 +688,7 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -830,9 +825,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 7b6625f..74274ca 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -673,7 +673,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #endif
/* @@ -683,10 +682,7 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -829,9 +825,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index da06bfd..4c1175d 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -548,7 +548,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -563,7 +562,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #endif #endif
@@ -573,10 +571,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif @@ -703,9 +698,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index e58691b..9a3965f 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -606,7 +606,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -621,7 +620,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #endif #endif
@@ -630,10 +628,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -769,9 +764,7 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_CMD_DATE #endif #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 6f81368..85df388 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -713,7 +713,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -723,7 +722,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #define CONFIG_HAS_FSL_DR_USB #endif
@@ -731,15 +729,12 @@ unsigned long get_board_ddr_clk(void); * SDHC */ #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif @@ -770,9 +765,7 @@ unsigned long get_board_ddr_clk(void); * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 508c896..5e2d659 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -674,7 +674,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
/* @@ -684,7 +683,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #define CONFIG_HAS_FSL_DR_USB #endif
@@ -692,14 +690,11 @@ unsigned long get_board_ddr_clk(void); * SDHC */ #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -727,7 +722,6 @@ unsigned long get_board_ddr_clk(void); * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 1ff6309..276428f 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -506,7 +506,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -528,7 +527,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #define CONFIG_HAS_FSL_DR_USB
#define CONFIG_MMC @@ -537,10 +535,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_ESDHC_DETECT_QUIRK \ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 495c09c..a0cce85 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -282,7 +282,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -301,9 +300,7 @@ * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI @@ -707,7 +704,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -723,7 +719,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #define CONFIG_HAS_FSL_DR_USB
#define CONFIG_MMC @@ -732,10 +727,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index d542d2a..42ebcf0 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -128,7 +128,6 @@ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_OHCI_BE_CONTROLLER #define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT
#undef CONFIG_SYS_USB_OHCI_BOARD_INIT #define CONFIG_SYS_USB_OHCI_CPU_INIT @@ -161,11 +160,9 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO #define CONFIG_CMD_BSP
@@ -181,8 +178,6 @@ #if defined(CONFIG_CHARON) || defined(CONFIG_FO300) || \ defined(CONFIG_MINIFAP) || defined(CONFIG_STK52XX) #define CONFIG_CMD_IDE - #define CONFIG_CMD_FAT - #define CONFIG_CMD_EXT2 #endif
#if defined(CONFIG_CHARON) || defined(CONFIG_FO300) || \ diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 304dc09..395805c 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -103,9 +103,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 72cd1e4..ec36637 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -101,9 +101,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 24ed057..2aac682 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -285,12 +285,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 2ed1539..00c0cc3 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -92,9 +92,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 469cd3f..ca26024 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -92,9 +92,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index eb0077b..39cf02e 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -94,9 +94,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index b504713..30bfb8a 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -123,9 +123,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index dfddd03..abe49b9 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -94,9 +94,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 2733849..48252c4 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -94,9 +94,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 9f09319..a73395a 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -97,9 +97,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index e76cb64..3db6fa1 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -97,9 +97,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 0d84ac7..76c8f7a 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -137,9 +137,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index 778fcf5..88b97ab 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -133,12 +133,9 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE -#define CONFIG_CMD_MII
/* * Miscellaneous configurable options diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index ccdfafa..4ae61ca 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -468,10 +468,8 @@ * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO #define CONFIG_CMD_ERRATA #define CONFIG_CMD_CRAMFS @@ -498,15 +496,12 @@ #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_MMC_SPI #define CONFIG_CMD_MMC_SPI #define CONFIG_GENERIC_MMC #endif
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) || defined(CONFIG_FSL_SATA) -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 5d7874b..4e349d5 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -48,7 +48,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_REGINFO #define CONFIG_CMD_DATE @@ -202,7 +201,6 @@ #define MULTI_PURPOSE_SOCKET_ADDR 0x08000000
/* File system */ -#define CONFIG_CMD_FAT #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS #define CONFIG_CMD_JFFS2 diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index 405ac0d..d401d3e 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -60,7 +60,6 @@ */ #define CONFIG_CMD_BSP #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_EEPROM
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index 47e35c5..e0c92d0 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -45,8 +45,6 @@ * Command line configuration. */ #define CONFIG_CMD_BSP -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_SERVERIP diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index 09216d1..ee1bff8 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -92,9 +92,7 @@ * Command line configuration. */ #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE -#define CONFIG_CMD_MII #define CONFIG_CMD_DISPLAY
#if defined(CONFIG_PCI) diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index efd63a0..bcf6942 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -392,13 +392,10 @@ #define CONFIG_LOADS_ECHO 1 #define CONFIG_SYS_LOADS_BAUD_CHANGE 1
-#define CONFIG_CMD_ASKENV #define CONFIG_CMD_EEPROM #undef CONFIG_CMD_FUSE #undef CONFIG_CMD_IDE -#undef CONFIG_CMD_EXT2 #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 95fc41e..7b9470c 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -103,19 +103,15 @@ * SD (MMC) controller */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_DOS_PARTITION #define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
/* diff --git a/include/configs/alt.h b/include/configs/alt.h index b8b9644..3a81c49 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -90,7 +90,6 @@ /* MMCIF */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC
#define CONFIG_SH_MMCIF #define CONFIG_SH_MMCIF_ADDR 0xee200000 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index bee6b83..cd8923d 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -348,7 +348,6 @@ #ifndef CONFIG_SPL_BUILD #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC -#define CONFIG_CMD_DFU #define DFU_ALT_INFO_MMC \ "dfu_alt_info_mmc=" \ "boot part 0 1;" \ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index cbfe1bd..822e1c8 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -103,7 +103,6 @@
#define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE -#define CONFIG_CMD_FAT
#ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL @@ -127,11 +126,8 @@ #endif /* CONFIG_USB_AM35X */
/* commands to include */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */
-#define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 2cbf04e..6f83870 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -119,16 +119,7 @@
/* commands to include */ #define CONFIG_CMD_NAND -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_PART -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_MMC #define CONFIG_CMD_MTDPARTS
/* I2C */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 59a9749..5b49988 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -11,8 +11,6 @@
#define CONFIG_AM43XX
-#define CONFIG_CMD_FAT - #define CONFIG_BOARD_LATE_INIT #define CONFIG_ARCH_CPU_INIT #define CONFIG_SYS_CACHELINE_SIZE 32 @@ -149,7 +147,6 @@ /* USB Device Firmware Update support */ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_RAM -#define CONFIG_CMD_DFU
#define CONFIG_DFU_MMC #define DFU_ALT_INFO_MMC \ @@ -320,7 +317,6 @@
#ifndef CONFIG_SPL_BUILD /* CPSW Ethernet */ -#define CONFIG_CMD_MII #define CONFIG_MII #define CONFIG_BOOTP_DEFAULT #define CONFIG_BOOTP_DNS diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 099ecdd..32d7d4d 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -54,7 +54,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_CMD_MII #define CONFIG_DRIVER_TI_CPSW /* Driver for IP block */ #define CONFIG_MII /* Required in net/eth.c */ #define CONFIG_PHY_GIGE /* per-board part of CPSW */ diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index 89093bd..9fa4d16 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -50,15 +50,11 @@ /* * Commands */ -#define CONFIG_CMD_ASKENV #if defined(CONFIG_440) -#define CONFIG_CMD_CACHE #endif #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 3ef7257..e819185 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -22,7 +22,6 @@ #define CONFIG_BOOTCOMMAND "bootm ffc20000"
#undef CONFIG_CMD_AES -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DIAG
/* undef to save memory */ diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index fdcbf31..ae58ec8 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -16,7 +16,6 @@
#define CONFIG_CMD_SDRAM #define CONFIG_CMD_IDE -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION
#define CONFIG_BAUDRATE 38400 diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index d458705..be8feed 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -18,7 +18,6 @@ #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_TEXT_BASE 0x8BFC0000
-#define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV
diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index 9c09087..514e9ee 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -31,7 +31,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/apf27.h b/include/configs/apf27.h index f8c91f8..2291647 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -65,16 +65,10 @@ /* * U-Boot Commands */ -#define CONFIG_CMD_ASKENV /* ask for env variable */ #define CONFIG_CMD_BSP /* Board Specific functions */ -#define CONFIG_CMD_CACHE /* icache, dcache */ #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_IMX_FUSE /* imx iim fuse */ -#define CONFIG_CMD_MII /* MII support */ -#define CONFIG_CMD_MMC #define CONFIG_CMD_MTDPARTS /* MTD partition support */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index 1f7ef8f..bb29f3f 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -24,12 +24,7 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND
/* Memory configuration */ diff --git a/include/configs/aria.h b/include/configs/aria.h index b69e08e..2d32da1 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -402,12 +402,10 @@ #define CONFIG_LOADS_ECHO 1 #define CONFIG_SYS_LOADS_BAUD_CHANGE 1
-#define CONFIG_CMD_ASKENV #define CONFIG_CMD_EEPROM #undef CONFIG_CMD_FUSE #undef CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 8154b2e..d87d40c 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -29,7 +29,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index e1fe7e6..681b4e7 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -18,8 +18,6 @@
#define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_MII -#define CONFIG_CMD_BOOTZ
#define BOARD_LATE_INIT
diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 6660eb0..b08276f 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -59,7 +59,6 @@
/* Define which commands should be available at u-boot command prompt */
-#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #if ENABLE_JFFS #define CONFIG_CMD_JFFS2 diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index e260867..dc955b2 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -30,7 +30,6 @@ #define CONFIG_DISPLAY_CPUINFO
#define CONFIG_ENV_VARS_UBOOT_CONFIG -#define CONFIG_CMD_BOOTZ
/* general purpose I/O */ #define CONFIG_AT91_GPIO diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index ee3712c..2979b25 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -58,8 +58,6 @@
#define CONFIG_BOARD_EARLY_INIT_F
-#define CONFIG_CMD_BOOTZ - /* * Memory Configuration */ @@ -119,8 +117,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII
/* * Network Driver Setting diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 2a5301f..9db8d12 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -45,8 +45,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_CMD_BOOTZ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO @@ -77,7 +75,6 @@ * Command line configuration. */ #define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_FAT
/* * SDRAM: 1 bank, min 32, max 128 MB @@ -128,7 +125,6 @@ #define AT91_SPI_CLK 15000000 #else /* Enable MMC. The MCCK is conflicted with DataFlash */ -#define CONFIG_CMD_MMC #endif
#ifdef CONFIG_AT91SAM9G20EK diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 82f90f2..b369624 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -143,7 +143,6 @@ #endif #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index c7fac7f..f248049 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -45,8 +45,6 @@
-#define CONFIG_CMD_BOOTZ - /* * Hardware drivers */ @@ -92,7 +90,6 @@ * Command line configuration. */ #define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_MMC
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 @@ -118,11 +115,6 @@ #define CONFIG_GENERIC_ATMEL_MCI #endif
-/* FAT */ -#ifdef CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif - /* NOR flash, if populated */ #ifdef CONFIG_SYS_USE_NORFLASH #define CONFIG_SYS_FLASH_CFI 1 @@ -287,7 +279,6 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1 -#define CONFIG_CMD_FAT 1
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 8bc5144..18eb01d 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -30,8 +30,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_CMD_BOOTZ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO @@ -103,7 +101,6 @@ #endif
/* MMC */ -#define CONFIG_CMD_MMC
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC @@ -112,7 +109,6 @@ #endif
#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index fdebcc2..2f8c377 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -67,10 +67,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_NAND -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT
#define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE 0x20000000 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 6a03923..d178d9d 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -31,8 +31,6 @@
-#define CONFIG_CMD_BOOTZ - #define CONFIG_ATMEL_LEGACY #define CONFIG_AT91_GPIO 1 #define CONFIG_AT91_GPIO_PULLUP 1 @@ -111,13 +109,11 @@ #endif
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_GENERIC_ATMEL_MCI -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index fd87bb7..251094e 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -26,8 +26,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_CMD_BOOTZ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO @@ -66,8 +64,6 @@ * Command line configuration. */ #define CONFIG_CMD_NAND -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT
/* * define CONFIG_USB_EHCI to enable USB Hi-Speed (aka 2.0) diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index a18a2c9..e6f6125 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -80,11 +80,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART #define CONFIG_MACB diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index 09e193e..fb12632 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -99,12 +99,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MMC -#define CONFIG_CMD_MII
#define CONFIG_ATMEL_USART #define CONFIG_MACB diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 62f01a7..9a647d8 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -101,11 +101,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART #define CONFIG_MACB diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 006ddb3..1bd4729 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -105,8 +105,6 @@ /* * Commands still not supported in Kconfig */ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 27ab8f7..4f3909a 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -304,7 +304,6 @@ #define CONFIG_PHY_ADDR 0 #define CONFIG_PHY_SMSC #define CONFIG_MII -#define CONFIG_CMD_MII #define CONFIG_PHY_ATHEROS
/* NAND support */ diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index d231f7a..784bfef 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -185,8 +185,6 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM
diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 377fa94..e391c91 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -461,7 +461,6 @@ DEFAULT_LINUX_BOOT_ENV \ #endif
#ifdef CONFIG_USB_MUSB_GADGET -#define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE #endif /* CONFIG_USB_MUSB_GADGET */
@@ -480,7 +479,6 @@ DEFAULT_LINUX_BOOT_ENV \ #ifndef CONFIG_SPL_BUILD #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC -#define CONFIG_CMD_DFU #define DFU_ALT_INFO_MMC \ "dfu_alt_info_mmc=" \ "boot part 0 1;" \ diff --git a/include/configs/bayleybay.h b/include/configs/bayleybay.h index 92326e1..8f31436 100644 --- a/include/configs/bayleybay.h +++ b/include/configs/bayleybay.h @@ -30,7 +30,6 @@ #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SDMA -#define CONFIG_CMD_MMC
/* Environment configuration */ #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index b9e9dcc..889e5db 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -124,11 +124,6 @@ #define CONFIG_BOOTCOMMAND ""
/* Commands */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC -#define CONFIG_CMD_BOOTZ #define CONFIG_FAT_WRITE
/* Fastboot and USB OTG */ diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index 4ac4faf..d5888e8 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -80,9 +80,6 @@ #define CONFIG_MX_CYCLIC
/* Commands */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE
/* SHA hashing */ @@ -93,8 +90,6 @@
/* Enable Time Command */
-#define CONFIG_CMD_BOOTZ - /* Misc utility code */ #define CONFIG_BOUNCE_BUFFER #define CONFIG_CRC32_VERIFY diff --git a/include/configs/beaver.h b/include/configs/beaver.h index 44e3621..a1c2002 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -31,7 +31,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index a351d1b..43a9032 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -136,7 +136,6 @@ #endif
#define CONFIG_CMD_BOOTLDR -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE
#define CONFIG_BOOTCOMMAND "run ramboot" diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index cbe752a..7055366 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -139,7 +139,6 @@ #endif
#define CONFIG_BOOTCOMMAND "run flashboot" diff --git a/include/configs/bf561-acvilon.h b/include/configs/bf561-acvilon.h index c36be03..76b891b 100644 --- a/include/configs/bf561-acvilon.h +++ b/include/configs/bf561-acvilon.h @@ -71,7 +71,6 @@ * Network Settings */ #define ADI_CMDS_NETWORK 1 -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT
diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index a62038e..4deb2d2 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -72,7 +72,6 @@ #define CONFIG_PHY_ADDR 1 #define CONFIG_DW_PORTS 1 #define CONFIG_DW_ALTDESCRIPTOR -#define CONFIG_CMD_MII #define CONFIG_MII
/* i2c Settings */ diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 1b35a86..88d2ae9 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -17,18 +17,13 @@ # define CONFIG_BOOTP_RANDOM_DELAY # define CONFIG_KEEP_SERVERADDR # ifdef CONFIG_BFIN_MAC -# define CONFIG_CMD_MII # endif # endif # ifdef CONFIG_LIBATA -# define CONFIG_CMD_FAT # define CONFIG_CMD_SATA # define CONFIG_DOS_PARTITION # endif # ifdef CONFIG_MMC -# define CONFIG_CMD_EXT2 -# define CONFIG_CMD_FAT -# define CONFIG_CMD_MMC # define CONFIG_DOS_PARTITION # define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 # endif @@ -36,8 +31,6 @@ # define CONFIG_CMD_MMC_SPI # endif # ifdef CONFIG_USB -# define CONFIG_CMD_EXT2 -# define CONFIG_CMD_FAT # define CONFIG_CMD_USB_STORAGE # define CONFIG_DOS_PARTITION # endif @@ -66,7 +59,6 @@ # define CONFIG_JFFS2_SUMMARY # endif # define CONFIG_CMD_BOOTLDR -# define CONFIG_CMD_CACHE # define CONFIG_CMD_CPLBINFO # define CONFIG_CMD_KGDB # define CONFIG_CMD_LDRINFO diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index e48be7a..6a5bc12 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -14,9 +14,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS
diff --git a/include/configs/blackstamp.h b/include/configs/blackstamp.h index 515ed77..6eb83a0 100644 --- a/include/configs/blackstamp.h +++ b/include/configs/blackstamp.h @@ -103,7 +103,6 @@ #define CONFIG_ENV_OVERWRITE 1
#define CONFIG_CMD_BOOTLDR -#define CONFIG_CMD_CACHE #define CONFIG_CMD_CPLBINFO #define CONFIG_CMD_DATE
diff --git a/include/configs/blackvme.h b/include/configs/blackvme.h index ef90603..ba90830 100644 --- a/include/configs/blackvme.h +++ b/include/configs/blackvme.h @@ -74,7 +74,6 @@ */ #define CONFIG_DRIVER_AX88180 1 #define AX88180_BASE 0x2c000000 -#define CONFIG_CMD_MII /* enable probing PHY */
#define CONFIG_HOSTNAME blackvme /* Bfin board */ #define CONFIG_IPADDR 169.254.144.145 /* Bfin board */ @@ -150,7 +149,6 @@ #define CONFIG_AUTO_COMPLETE 1
/* diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 37adede..506ad88 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -308,13 +308,10 @@ * U-Boot commands */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DIAG -#define CONFIG_CMD_MII #define CONFIG_CMD_SAVES
#ifndef CONFIG_DRIVER_TI_EMAC -#undef CONFIG_CMD_MII #endif
/* additions for new relocation code, must added to all boards */ diff --git a/include/configs/canmb.h b/include/configs/canmb.h index 028d0a2..31fe5f6 100644 --- a/include/configs/canmb.h +++ b/include/configs/canmb.h @@ -48,10 +48,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_IMMAP -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index ad9f418..e68e342 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -382,8 +382,6 @@ #elif defined(CONFIG_CANYONLANDS) #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index 85fd327..7107b72 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -34,7 +34,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 57dfdde..dd03936 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -70,7 +70,6 @@ #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
/* USB Configs */ -#define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -85,11 +84,9 @@
#define CONFIG_USBD_HS
/* USB Device Firmware Update support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_DFU_SF @@ -130,7 +127,6 @@ #define CONFIG_LIBATA
/* Ethernet */ -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 991121d..ffaeedb 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -25,14 +25,7 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_MMC #define CONFIG_CMD_PCI
/* I2C */ diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index cdb8931..99182f4 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -23,13 +23,10 @@ /* * Supported commands */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BSP #define CONFIG_CMD_DATE #define CONFIG_CMD_DIAG -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index b36ba14..9a12552 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -18,7 +18,6 @@ #define CONFIG_MACH_TYPE 4273
/* CMD */ -#define CONFIG_CMD_GREPENV
/* MMC */ #define CONFIG_SYS_FSL_USDHC_NUM 3 diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index aca9288..5d58116 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -106,9 +106,6 @@ #define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* commands to include */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS @@ -117,7 +114,6 @@ "1920k(u-boot),256k(u-boot-env),"\ "4m(kernel),-(fs)"
#define CONFIG_SYS_NO_FLASH @@ -191,7 +187,6 @@ "nand read ${loadaddr} 2a0000 400000; " \ "bootm ${loadaddr}\0" \
-#define CONFIG_CMD_BOOTZ #define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \ "if run loadbootscript; then " \ diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 1bedea7..7cedb67 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -119,9 +119,6 @@ #define CONFIG_USB_STORAGE
/* commands to include */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS @@ -130,7 +127,6 @@ "1920k(u-boot),256k(u-boot-env),"\ "4m(kernel),-(fs)"
#define CONFIG_SYS_NO_FLASH @@ -199,7 +195,6 @@ "nand read ${loadaddr} 2a0000 400000; " \ "bootm ${loadaddr}\0" \
-#define CONFIG_CMD_BOOTZ #define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \ "if run loadbootscript; then " \ diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index b291ba4..509c8b42 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -120,8 +120,6 @@ * Command line configuration. */
-#undef CONFIG_CMD_MII - #ifdef CONFIG_MCFFEC # define CONFIG_MII 1 # define CONFIG_MII_INIT 1 diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index c38d888..5dffc9e 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -54,7 +54,6 @@ * Bootloader Components Configuration */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_MMC
/* I2C support */ #ifdef CONFIG_SYS_I2C diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index 01fc13d..c15f0cb 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -30,7 +30,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* USB host support */ #define CONFIG_USB_EHCI @@ -76,7 +75,6 @@ #define CONFIG_ENV_SIZE (SZ_64K)
/* UBI */ -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS /* increases size by almost 60 KB */ #define CONFIG_LZO @@ -84,7 +82,6 @@ #define CONFIG_RBTREE
/* Debug commands */ -#define CONFIG_CMD_CACHE
/* Miscellaneous commands */ #define CONFIG_FAT_WRITE diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index a34da80..7e98166 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -31,7 +31,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index ea33e7a..50f7c21 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -43,7 +43,6 @@ #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_VERSION_VARIABLE #define CONFIG_BAUDRATE 115200 -#define CONFIG_CMD_ASKENV
/* NAND support */ #define CONFIG_CMD_NAND @@ -69,21 +68,15 @@
-#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT4 #define CONFIG_DOS_PARTITION
#define CONFIG_RBTREE #define CONFIG_LZO -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_UBI #define CONFIG_MTD_UBI_FASTMAP #define CONFIG_CMD_UBIFS /* increases size by almost 60 KB */
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET1_BASE_ADDR @@ -213,8 +206,6 @@ #define CONFIG_ENV_OFFSET (12 * 64 * 2048) #endif
-#define CONFIG_CMD_BOOTZ - #define CONFIG_SYS_NO_FLASH
#define CONFIG_SYS_CACHELINE_SIZE 32 @@ -233,7 +224,6 @@ #define CONFIG_TRDX_PID_COLIBRI_VF50IT 0x0019
/* USB DFU */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_DFU_MMC @@ -242,6 +232,5 @@ /* USB Storage */ #define CONFIG_USB_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE -#define CONFIG_CMD_USB_MASS_STORAGE
#endif /* __CONFIG_H */ diff --git a/include/configs/conga-qeval20-qa3-e3845.h b/include/configs/conga-qeval20-qa3-e3845.h index 556d44e..4c37d5e 100644 --- a/include/configs/conga-qeval20-qa3-e3845.h +++ b/include/configs/conga-qeval20-qa3-e3845.h @@ -32,7 +32,6 @@ #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SDMA -#define CONFIG_CMD_MMC
#undef CONFIG_USB_MAX_CONTROLLER_COUNT #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 9d1c6ae..1bb8d93 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -224,7 +224,6 @@ */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC
#define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR @@ -377,10 +376,7 @@ #ifndef CONFIG_TRAILBLAZER
#define CONFIG_CMD_ERRATA -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 1ab2efb..96f17d3 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -579,7 +579,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -611,9 +610,7 @@ * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -631,17 +628,13 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #endif
diff --git a/include/configs/corvus.h b/include/configs/corvus.h index fffcd95..8b3c715 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -39,8 +39,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_CMD_BOOTZ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO @@ -115,7 +113,6 @@ #define CONFIG_MTD_PARTITIONS
/* DFU class support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_SYS_DFU_DATA_BUF_SIZE (SZ_1M) diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h index 432f2f6..49ed3ef 100644 --- a/include/configs/crownbay.h +++ b/include/configs/crownbay.h @@ -32,7 +32,6 @@ #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SDMA -#define CONFIG_CMD_MMC
/* Environment configuration */ #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index d1927b5..4280c9c 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -413,7 +413,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -433,9 +432,7 @@ * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -453,7 +450,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 #define CONFIG_EHCI_IS_TDI #define CONFIG_USB_KEYBOARD #define CONFIG_SYS_STDIO_DEREGISTER @@ -467,10 +463,7 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 9466332..af220fe 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -285,9 +285,7 @@ * U-Boot commands */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DIAG -#define CONFIG_CMD_MII #define CONFIG_CMD_SAVES
#ifdef CONFIG_CMD_BDI @@ -295,7 +293,6 @@ #endif
#ifdef CONFIG_USE_NAND @@ -336,9 +333,6 @@ */ #ifdef CONFIG_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC #endif
#ifndef CONFIG_DIRECT_NOR_BOOT diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index 40dc35c..82b1f2c 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -27,7 +27,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index f8454cf..01c7895 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -24,12 +24,7 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index d31e74f..d84dde3 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -25,13 +25,7 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_MMC #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI
diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 66b723d..d6acbbc 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -26,12 +26,7 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index f9f30b1..eb0a87c 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -73,8 +73,6 @@ * Command line configuration. */ #undef CONFIG_CMD_BEDBUG -#undef CONFIG_CMD_FAT -#undef CONFIG_CMD_MII
#ifdef CONFIG_DBAU1550
diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 4114f9e..913b948 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -82,7 +82,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ADDR 0x1F #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN -#define CONFIG_CMD_MII
/* * NOR Flash @@ -126,7 +125,6 @@ #define CONFIG_USB_OHCI_LPC32XX #define CONFIG_USB_ISP1301_I2C_ADDR 0x2d #define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT
/* * U-Boot General Configurations @@ -174,7 +172,6 @@ /* * U-Boot Commands */ -#define CONFIG_CMD_CACHE
/* * Boot Linux diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 6acd2fe..5112ef3 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -99,12 +99,8 @@ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */
-#undef CONFIG_CMD_ASKENV -#undef CONFIG_CMD_BOOTZ #undef CONFIG_SUPPORT_RAW_INITRD #undef CONFIG_FAT_WRITE -#undef CONFIG_CMD_EXT4 -#undef CONFIG_CMD_FS_GENERIC
/* BOOTP/DHCP options */ #define CONFIG_BOOTP_SUBNETMASK diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 0bf5088..18804d4 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -101,15 +101,11 @@ #ifdef CONFIG_VIDEO #define CONFIG_CMD_BMP #endif -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SAVES diff --git a/include/configs/dnp5370.h b/include/configs/dnp5370.h index c0c0de9..0a7bc8a 100644 --- a/include/configs/dnp5370.h +++ b/include/configs/dnp5370.h @@ -53,8 +53,6 @@ #define CONFIG_PHY_ADDR 0 #define CONFIG_RMII 1
-#define CONFIG_CMD_MII - #endif
/* diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index e54321b..cd05857 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -30,7 +30,6 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND /* * mv-common.h should be defined after CMD configs since it used them @@ -87,8 +86,6 @@ /* * File system */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 8d6ed05..79b6c09 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -148,7 +148,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_CMD_MII #define CONFIG_DRIVER_TI_CPSW /* Driver for IP block */ #define CONFIG_MII /* Required in net/eth.c */ #define CONFIG_PHY_GIGE /* per-board part of CPSW */ @@ -224,7 +223,6 @@ /* USB Device Firmware Update support */ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_RAM -#define CONFIG_CMD_DFU
#define CONFIG_DFU_MMC #define CONFIG_DFU_RAM diff --git a/include/configs/draco.h b/include/configs/draco.h index 2d4a45d..8aee25b 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -33,7 +33,6 @@ "led1=64,0,1\0"
#undef CONFIG_DOS_PARTITION -#undef CONFIG_CMD_FAT
diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index 42fb0f3..d32889d 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -59,11 +59,9 @@ #define CONFIG_MD5
/* Extra Commands */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV #define CONFIG_CMD_GPT #define CONFIG_CMD_MD5SUM -#define CONFIG_CMD_MMC /* Enable that for switching of boot partitions */ /* Disabled by default as some sub-commands can brick eMMC */ /*#define CONFIG_SUPPORT_EMMC_BOOT */ diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 0b7d89b..c78c949 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -39,8 +39,6 @@ /* * Commands configuration */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
/* * mv-plug-common.h should be defined after CMD configs since it used them diff --git a/include/configs/e2220-1170.h b/include/configs/e2220-1170.h index 3a7f490..9de1179 100644 --- a/include/configs/e2220-1170.h +++ b/include/configs/e2220-1170.h @@ -25,7 +25,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/ea20.h b/include/configs/ea20.h index b52f34b..d4f3cfa 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -143,9 +143,7 @@ * U-Boot commands */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DIAG -#define CONFIG_CMD_MII #define CONFIG_CMD_SAVES
#ifdef CONFIG_CMD_BDI @@ -153,7 +151,6 @@ #endif
/* NAND Setup */ diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 861f2ac..521e3cf 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -66,7 +66,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_DATE #define CONFIG_CMD_LED -#define CONFIG_CMD_MII
#define CONFIG_MCFTMR
diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 3ab1803..2ac7757 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -30,11 +30,8 @@ #define CONFIG_ECOVEC_ROMIMAGE_ADDR 0xA0040000 #define CONFIG_SYS_TEXT_BASE 0x8FFC0000
-#define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
#define CONFIG_USB_STORAGE #define CONFIG_DOS_PARTITION diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index c64d119..174cdf3 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -238,7 +238,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SPI -#define CONFIG_CMD_MMC #define CONFIG_MMC_SPI_NPOWER_EGPIO 9 #endif
@@ -250,12 +249,7 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ep93xx-ohci" #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x80020000
-#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT - #define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_CMD_BOOTZ
/* Define to disable flash configuration*/ /* #define CONFIG_EP93XX_NO_FLASH_CFG */ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 4444bc9..99d16b0 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -157,7 +157,6 @@ #define __io #define CONFIG_IDE_PREINIT #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 /* ED Mini V has an IDE-compatible SATA connector for port 1 */ #define CONFIG_MVSATA_IDE #define CONFIG_MVSATA_IDE_USE_PORT1 diff --git a/include/configs/espt.h b/include/configs/espt.h index ed92865..3d67376 100644 --- a/include/configs/espt.h +++ b/include/configs/espt.h @@ -18,7 +18,6 @@ * Command line configuration. */ #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_MII #define CONFIG_CMD_ENV
#define CONFIG_BOOTDELAY -1 diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index cfb009c..94fee54 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -88,18 +88,12 @@
/* Command line configuration */ #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND
#ifndef MINIMAL_LOADER -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BSP -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC #define CONFIG_CMD_REISER #define CONFIG_CMD_SAVES #define CONFIG_CMD_UBI diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 0a2d610..f97f03c 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -26,7 +26,6 @@ #define CONFIG_USE_ARCH_MEMSET
/* Keep L2 Cache Disabled */ -#define CONFIG_CMD_CACHE
/* input clock of PLL: 24MHz input clock */ #define CONFIG_SYS_CLK_FREQ 24000000 @@ -57,10 +56,7 @@ #define CONFIG_PWM
/* Command definition*/ -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT4_WRITE #define CONFIG_FAT_WRITE -#define CONFIG_CMD_FS_GENERIC
#define CONFIG_CMD_PART #define CONFIG_PARTITION_UUIDS diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index 8522a79..fbe0fa9 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -24,7 +24,6 @@
#undef CONFIG_CMD_ONENAND #undef CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_DFU #define CONFIG_CMD_GPT
/* TIZEN THOR downloader support */ @@ -46,7 +45,6 @@
#define CONFIG_USB_GADGET_DWC2_OTG_PHY
/* Common environment variables */ diff --git a/include/configs/flea3.h b/include/configs/flea3.h index e74aa68..7400870 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -78,9 +78,7 @@ #define CONFIG_BOOTP_DNS
-#define CONFIG_CMD_MII #define CONFIG_NET_RETRY_COUNT 100
#define CONFIG_BOOTDELAY 3 diff --git a/include/configs/galileo.h b/include/configs/galileo.h index 14a42b1..2f1f6d4 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -40,7 +40,6 @@ #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SDMA -#define CONFIG_CMD_MMC
/* 10/100M Ethernet support */ #define CONFIG_DESIGNWARE_ETH diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index bf8e55c..47c4ec2 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -73,15 +73,11 @@ #define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
/* USB Configs */ -#define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -97,7 +93,6 @@ #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_DOWNLOAD -#define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_GADGET_MASS_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_USB_GADGET_VBUS_DRAW 2 @@ -106,7 +101,6 @@ #define CONFIG_G_DNL_MANUFACTURER "Advantech"
/* Networking Configs */ -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -132,7 +126,6 @@
/* Command definition */ #define CONFIG_CMD_BMODE -#define CONFIG_CMD_BOOTZ
#define CONFIG_LOADADDR 0x12000000 #define CONFIG_SYS_TEXT_BASE 0x17800000 @@ -296,7 +289,6 @@ #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
#ifndef CONFIG_SYS_DCACHE_OFF -#define CONFIG_CMD_CACHE #endif
#define CONFIG_SYS_FSL_USDHC_NUM 3 diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index d0432ad..ffbe660 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -52,11 +52,9 @@ #define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_CMD_ENV -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_IDE #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT4 #define CONFIG_SYS_MVFS /* Picks up Filesystem from mv-common.h */
/* diff --git a/include/configs/gose.h b/include/configs/gose.h index 4e29825..230be31 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -96,7 +96,6 @@
/* SDHI */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_SH_SDHI_FREQ 97500000
diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 638fad1..40ec030 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -52,8 +52,6 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
/* Disable DCACHE */ #define CONFIG_SYS_DCACHE_OFF @@ -71,7 +69,6 @@
/* PHY configuration */ #define CONFIG_MII -#define CONFIG_CMD_MII #define CONFIG_RESET_PHY_R /* 88E3015 register definition */ #define PHY_LED_PAR_SEL_REG 22 @@ -108,8 +105,6 @@ #define CONFIG_ENV_SIZE 0x4000 #define CONFIG_ENV_OFFSET 0x07C000
-#define CONFIG_CMD_ASKENV - #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ARMADA100 diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index 563b205..94eb7ac 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -60,8 +60,6 @@ /* USB support */ #if USE_GRUSB #define CONFIG_USB_UHCI -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_USB_STORAGE /* Enable needed helper functions */ #define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 8e0cff9..83f1d73 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -93,7 +93,6 @@ * Command line configuration. */ /* add useful commands */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_REGINFO
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 58598c3..e11629c 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -149,7 +149,6 @@ #define CONFIG_POWER_LTC3676_I2C_ADDR 0x3c
/* Various command support */ -#define CONFIG_CMD_MII #define CONFIG_CMD_BMODE /* set eFUSE shadow for a boot dev and reset */ #define CONFIG_CMD_HDMIDETECT /* detect HDMI output device */ #define CONFIG_CMD_GSC @@ -185,7 +184,6 @@ #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
/* USB Mass Storage Gadget */ -#define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE
/* Framebuffer and LCD */ diff --git a/include/configs/harmony.h b/include/configs/harmony.h index aa0f38c..d3ab10e 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -30,7 +30,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/hikey.h b/include/configs/hikey.h index d08ab1d..114a6d1 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -82,13 +82,11 @@ #define CONFIG_DWMMC #define CONFIG_HIKEY_DWMMC #define CONFIG_BOUNCE_BUFFER -#define CONFIG_CMD_MMC
#define CONFIG_FS_EXT4
/* Command line configuration */ #define CONFIG_MENU -#define CONFIG_CMD_CACHE #define CONFIG_CMD_UNZIP #define CONFIG_CMD_ENV
diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index d59d21f..9f02a65 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -35,10 +35,8 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
-#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2
#define CONFIG_CMD_FPGAD #define CONFIG_CMD_IOLOOP @@ -533,7 +531,6 @@ void fpga_control_clear(unsigned int bus, int pin); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index 57b1a43..ab23607 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -35,9 +35,7 @@ */ #define CONFIG_SYS_NO_FLASH /* declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_IDE -#define CONFIG_CMD_MII
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/icon.h b/include/configs/icon.h index d42e6f0..7e9e7e6 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -167,8 +167,6 @@ */ #define CONFIG_CMD_CHIP_CONFIG #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM #ifdef CONFIG_VIDEO diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index c156bd3..f0d4250 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_NO_FLASH /* declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS #define CONFIG_CMD_ENV -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND
/* @@ -95,8 +94,6 @@ /* * File system */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index da4cba7..04515ba 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -414,7 +414,6 @@ * U-Boot environment setup */ #define CONFIG_CMD_NAND -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_JFFS2 diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index c03e566..b8ee44d 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -171,13 +171,8 @@ /* * U-Boot commands */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DIAG -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND
#define CONFIG_BOOTDELAY 5 diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 282cc25..0d4f292 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -80,8 +80,6 @@ * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_PCI
diff --git a/include/configs/intip.h b/include/configs/intip.h index 6f48b4b..f3db077 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -281,8 +281,6 @@ #define CONFIG_CMD_CHIP_CONFIG #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM
diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 4d1f309..43688c7 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -61,7 +61,6 @@ /* * Commands additional to the ones defined in amcc-common.h */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_FPGAD #undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_IRQ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 3675099..b2a6e7f 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -250,9 +250,7 @@ * U-Boot commands */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DIAG -#define CONFIG_CMD_MII #define CONFIG_CMD_SAVES
#ifdef CONFIG_CMD_BDI @@ -260,7 +258,6 @@ #endif
#define CONFIG_CMD_NAND diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 636f6bd..55ed656 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -106,10 +106,8 @@ #define CONFIG_CMD_BMP /* BMP support */ #endif #define CONFIG_CMD_DATE /* support for RTC, date/time...*/ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_IDE /* IDE harddisk support */ #define CONFIG_CMD_IRQ /* irqinfo */ -#define CONFIG_CMD_MII /* MII support */ #define CONFIG_CMD_PCI /* pciinfo */
#define CONFIG_SYS_LOWBOOT 1 diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 30ef13f..953c088 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -29,7 +29,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index a2d2646..3f98510 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -63,7 +63,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_CMD_MMC
#undef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_IS_IN_FAT diff --git a/include/configs/katmai.h b/include/configs/katmai.h index f5dddae..9513c6d 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -175,8 +175,6 @@ #define CONFIG_CMD_CHIP_CONFIG #define CONFIG_CMD_DATE #define CONFIG_CMD_ECCTEST -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM
diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 30be533..b08cf21 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -94,8 +94,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC
-#define CONFIG_CMD_MMC - /* * Power */ diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index dd0cec4..9f76034 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -13,11 +13,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DEFAULTENV_VARS -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IMMAP -#define CONFIG_CMD_MII #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MTDPARTS diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index fdd293f..25db704 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -158,7 +158,6 @@ */ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_MII /* expose smi ove miiphy interface */ -#define CONFIG_CMD_MII /* to debug mdio phy config */ #define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index 685f0e5..121fe3f 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -96,7 +96,6 @@
/* SD */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_SH_SDHI_FREQ 97500000
diff --git a/include/configs/kwb.h b/include/configs/kwb.h index 4ec4e33..bcb9e7e 100644 --- a/include/configs/kwb.h +++ b/include/configs/kwb.h @@ -48,7 +48,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_CMD_MMC #define CONFIG_SUPPORT_EMMC_BOOT /* RAW SD card / eMMC locations. */ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /*addr. 0x60000 */ @@ -115,7 +114,6 @@ BUR_COMMON_ENV \ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_CMD_BOOTZ
/* USB configuration */ #define CONFIG_USB_MUSB_DSPS @@ -140,9 +138,7 @@ BUR_COMMON_ENV \ */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE -#define CONFIG_CMD_FS_GENERIC #endif /* CONFIG_MMC, ... */
#endif /* __CONFIG_KWB_H__ */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index bf283fe..710629b 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -28,8 +28,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT -#define CONFIG_CMD_BOOTZ
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "root=/dev/null console=ttySC4,115200" diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 18cd4bb..9b2c575 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -148,8 +148,6 @@ /* * File systems support */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
/* * Console configuration diff --git a/include/configs/lager.h b/include/configs/lager.h index ad8b12f..9971ad8 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -88,7 +88,6 @@
/* MMC */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC
#define CONFIG_SH_MMCIF diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 54563e3..1aad97d 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -208,9 +208,7 @@ /* * U-Boot commands */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DIAG -#define CONFIG_CMD_MII #define CONFIG_CMD_SAVES
#ifdef CONFIG_CMD_BDI @@ -233,9 +231,6 @@ */ #ifdef CONFIG_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC #endif
/* additions for new relocation code, must added to all boards */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 3cbb522..3796395 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -412,11 +412,9 @@ unsigned long get_board_ddr_clk(void); * MMC */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC
/* SPI */ @@ -460,7 +458,6 @@ unsigned long get_board_ddr_clk(void);
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_XHCI_USB) #define CONFIG_USB_STORAGE -#define CONFIG_CMD_EXT2 #endif
/* @@ -557,8 +554,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_PCI #endif
-#define CONFIG_CMD_MII - #define CONFIG_CMDLINE_TAG #define CONFIG_CMDLINE_EDITING
@@ -603,7 +598,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_CMD_GREPENV #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
@@ -654,8 +648,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
-#define CONFIG_CMD_BOOTZ - #define CONFIG_MISC_INIT_R
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1fd9e03..3e32128 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -65,7 +65,6 @@
/* @@ -299,11 +298,9 @@ * MMC */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC
/* SPI */ @@ -406,8 +403,6 @@ #define CONFIG_CMD_PCI #endif
@@ -448,7 +443,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
@@ -497,8 +491,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index d84c734..54968b5 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -174,14 +174,11 @@ #endif
/* Command line configuration */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV
/* MMC */ #define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 3bdece7..d71a229 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -109,8 +109,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
@@ -396,7 +394,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_EXT2 #endif
/* @@ -409,7 +406,6 @@ unsigned long get_board_ddr_clk(void); (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
@@ -456,8 +452,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_SIZE 0x20000 #endif
-#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_MII #define CONFIG_CMDLINE_TAG
#include <asm/fsl_secure_boot.h> diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 7c662a3..6d35be2 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -246,7 +246,6 @@ /* FMan */ #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_FMAN_ENET -#define CONFIG_CMD_MII #define CONFIG_PHYLIB #define CONFIG_PHYLIB_10G #define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ @@ -284,7 +283,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_EXT2 #endif
#include <asm/fsl_secure_boot.h> diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 8b75088..8e0b472 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -210,10 +210,7 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_PCIE_MEM_SIZE 0x40000000 /* 1G */
/* Command line configuration */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII
/* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index 924011c..bc0d678 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -131,11 +131,9 @@ /* MMC */ #define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 3ec4bb6..2d7567f 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -45,8 +45,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
@@ -324,11 +322,9 @@ unsigned long get_board_ddr_clk(void); /* MMC */ #define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -352,7 +348,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_MEMAC #define CONFIG_PHYLIB #define CONFIG_PHYLIB_10G -#define CONFIG_CMD_MII #define CONFIG_PHY_VITESSE #define CONFIG_PHY_REALTEK #define CONFIG_PHY_TERANETICS @@ -394,7 +389,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_EXT2
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 8ba0512..5bec509 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -63,8 +63,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
@@ -306,11 +304,9 @@ unsigned long get_board_sys_clk(void); /* MMC */ #define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
@@ -326,7 +322,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_EXT2
/* Initial environment variables */ #undef CONFIG_EXTRA_ENV_SETTINGS diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 094a7e2..e878cbe 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -49,12 +49,8 @@ /* * Commands configuration */ -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE -#define CONFIG_CMD_FS_GENERIC
#define CONFIG_DOS_PARTITION #define CONFIG_EFI_PARTITION diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 3dc59e4..d5082fa 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -400,13 +400,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SDRAM
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 2070f33..428128d 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -20,18 +20,9 @@ #define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
-#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMP -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_VIDEO diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 9ababa3..4349357 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -28,16 +28,8 @@ #define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
-#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMP #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_CMD_SATA diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 2429e3a..fb14463 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -23,16 +23,6 @@ #define CONFIG_FAT_WRITE /*#define CONFIG_LCD*/
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC - /* * Memory configurations */ diff --git a/include/configs/manroland/common.h b/include/configs/manroland/common.h index 20457f6..8d4a8cd 100644 --- a/include/configs/manroland/common.h +++ b/include/configs/manroland/common.h @@ -26,8 +26,6 @@ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_DTT #define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII
/* * 8-symbol LED display (can be accessed with 'display' command) diff --git a/include/configs/mcx.h b/include/configs/mcx.h index d12f291..3dbd920 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -108,15 +108,10 @@ #define CONFIG_USB_ETHER_MCS7830
/* commands to include */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */
#define CONFIG_CMD_DATE -#define CONFIG_CMD_MMC /* MMC support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS #define CONFIG_RBTREE @@ -135,7 +130,6 @@ #define CONFIG_RTC_DS1337 #define CONFIG_SYS_I2C_RTC_ADDR 0x68
-#define CONFIG_CMD_MII /* * Board NAND Info. */ diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index cca7c33..9262f72 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -290,15 +290,11 @@ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO #define CONFIG_CMD_EEPROM #define CONFIG_CMD_DATE #undef CONFIG_CMD_FUSE #undef CONFIG_CMD_IDE -#undef CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_DOS_PARTITION
diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index 8a24cfb..f3a6a86 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -23,7 +23,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/meesc.h b/include/configs/meesc.h index d65a4cd..f71b662 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -56,8 +56,6 @@ #define CONFIG_DISPLAY_CPUINFO /* display cpu info and speed */ #define CONFIG_PREBOOT /* enable preboot variable */
-#define CONFIG_CMD_BOOTZ - /* * Hardware drivers */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index cdaf828..801d674 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -172,14 +172,11 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_IRQ #define CONFIG_CMD_MFSL
#if defined(CONFIG_DCACHE) || defined(CONFIG_ICACHE) -# define CONFIG_CMD_CACHE #else -# undef CONFIG_CMD_CACHE #endif
#if defined(FLASH) @@ -274,7 +271,6 @@
#if defined(CONFIG_XILINX_AXIEMAC) # define CONFIG_MII 1 -# define CONFIG_CMD_MII 1 # define CONFIG_PHY_GIGE 1 # define CONFIG_SYS_FAULT_ECHO_LINK_DOWN 1 # define CONFIG_PHY_ATHEROS 1 @@ -289,7 +285,6 @@ # define CONFIG_PHY_VITESSE 1 #else # undef CONFIG_MII -# undef CONFIG_CMD_MII #endif
/* SPL part */ diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 93d34e9..674d1f6 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -32,7 +32,6 @@ #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SDMA -#define CONFIG_CMD_MMC
#undef CONFIG_USB_MAX_CONTROLLER_COUNT #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index f4b0e34..62919e9 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -34,16 +34,13 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BEDBUG #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_IMMAP #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 2179f60..e0c9a98 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -408,13 +408,10 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#undef CONFIG_CMD_FUSE @@ -455,7 +452,6 @@ #define CONFIG_MAC_PARTITION #define CONFIG_ISO_PARTITION
-#define CONFIG_CMD_FAT #define CONFIG_SUPPORT_VFAT
#endif /* defined(CONFIG_CMD_IDE) */ diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 149f365..66e1a45 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -388,7 +388,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ diff --git a/include/configs/mpr2.h b/include/configs/mpr2.h index 3ac4b0b..3f2bfa4 100644 --- a/include/configs/mpr2.h +++ b/include/configs/mpr2.h @@ -11,7 +11,6 @@ #define __MPR2_H
/* Supported commands */ -#define CONFIG_CMD_CACHE
/* Default environment variables */ #define CONFIG_BAUDRATE 115200 diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 5b6880b..27ed1d5 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -13,10 +13,8 @@ #define CONFIG_MS7720SE 1
#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_CACHE #define CONFIG_CMD_PCMCIA #define CONFIG_CMD_IDE -#define CONFIG_CMD_EXT2
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200" diff --git a/include/configs/munices.h b/include/configs/munices.h index 438497e..efbd447 100644 --- a/include/configs/munices.h +++ b/include/configs/munices.h @@ -26,7 +26,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_IMMAP #define CONFIG_CMD_REGINFO
diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index 674aa0a..6d4bbd1 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -138,9 +138,7 @@ * File system */ #ifdef CONFIG_SYS_MVFS -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS #define CONFIG_RBTREE diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h index 116c821..bf583d0 100644 --- a/include/configs/mv-plug-common.h +++ b/include/configs/mv-plug-common.h @@ -23,7 +23,6 @@ #ifdef CONFIG_SYS_MVFS #define CONFIG_BZIP2 #define CONFIG_LZMA -#define CONFIG_CMD_BOOTZ #endif /* CONFIG_SYS_MVFS */
/* @@ -33,12 +32,10 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_ENV #define CONFIG_CMD_IDE -#define CONFIG_CMD_MII
/* * Extra file system */ -#define CONFIG_CMD_EXT4
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index 705bee8..1bdbe4b 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -15,11 +15,7 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_LED -#define CONFIG_CMD_MMC
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index 4936733..542f1f4 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -18,11 +18,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC -#define CONFIG_CMD_BOOTZ #define CONFIG_VIDEO
/* Memory configuration */ diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index cc86c94..c63887b 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -82,11 +82,6 @@ #define CONFIG_SYS_LONGHELP
/* U-Boot commands */ -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
/* Ethernet */ #define CONFIG_FEC_MXC @@ -122,8 +117,6 @@
/* Ethernet Configs */
-#define CONFIG_CMD_MII - #define CONFIG_BOOTDELAY 1
#define CONFIG_LOADADDR 0x81000000 /* loadaddr env var */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 36a5063..b3c03b3 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -20,15 +20,7 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_VIDEO diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 797eb09..3f63007 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -79,10 +79,8 @@ /*********************************************************** * Command definition ***********************************************************/ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND -#define CONFIG_CMD_BOOTZ
diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 5f4142a..aed0939 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -78,24 +78,18 @@ /* * Command definition */ -#define CONFIG_CMD_BOOTZ #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_DNS
#define CONFIG_CMD_NAND -#define CONFIG_CMD_CACHE
-#define CONFIG_CMD_MII #define CONFIG_NET_RETRY_COUNT 100 #define CONFIG_CMD_DATE
#define CONFIG_USB_STORAGE -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION #define CONFIG_EFI_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 2f75f2b..23b8b46 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -72,9 +72,7 @@
#define CONFIG_MMC
-#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
/* @@ -86,10 +84,7 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
-#define CONFIG_CMD_MII - /* USB Configs */ -#define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX5 #define CONFIG_USB_STORAGE @@ -122,7 +117,6 @@ /*********************************************************** * Command definition ***********************************************************/ -#define CONFIG_CMD_BOOTZ
diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 48b4dca..e697261 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -31,8 +31,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO
-#define CONFIG_CMD_BOOTZ - #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR_AXI #define CONFIG_NAND_MXC @@ -59,17 +57,13 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
#define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
/* Eth Configs */ #define CONFIG_HAS_ETH1 #define CONFIG_MII
-#define CONFIG_CMD_MII - /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 46f93b9..feb5580 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -56,9 +56,7 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
/* Eth Configs */ @@ -68,7 +66,6 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
/* Miscellaneous commands */ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 8d2581a..8743ddc 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -41,11 +41,7 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 2
#define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION
/* Eth Configs */ @@ -55,10 +51,7 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
-#define CONFIG_CMD_MII - /* USB Configs */ -#define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX5 #define CONFIG_USB_STORAGE @@ -92,7 +85,6 @@ #define CONFIG_BAUDRATE 115200
/* Command definition */ -#define CONFIG_CMD_BOOTZ #define CONFIG_SUPPORT_RAW_INITRD
#define CONFIG_BOOTDELAY 1 diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index f5019c2..9c76678 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -47,9 +47,7 @@ #define CONFIG_SYS_FSL_ESDHC_NUM 1
/* Eth Configs */ @@ -60,8 +58,6 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
-#define CONFIG_CMD_MII - /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index ffd13ca..17b6c48 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -69,14 +69,8 @@ #define CONFIG_BAUDRATE 115200
/* Filesystems and image support */ -#define CONFIG_CMD_BOOTZ #define CONFIG_SUPPORT_RAW_INITRD -#define CONFIG_CMD_FS_GENERIC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP @@ -87,7 +81,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
/* GPIO */ @@ -95,7 +88,6 @@
/* MMC */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER #define CONFIG_FSL_ESDHC diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 70760a1..d64323e 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -27,7 +27,6 @@
/* Ethernet Configuration */ #define CONFIG_FEC_MXC -#define CONFIG_CMD_MII #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_XCV_TYPE RGMII diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index 60c07cf..eb89031 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC4_BASE_ADDR #define CONFIG_SYS_FSL_USDHC_NUM 2
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index d777666..1ee880d 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -24,7 +24,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -232,7 +231,6 @@ #ifndef CONFIG_SPL #define CONFIG_USBD_HS
#define CONFIG_USB_FUNCTION_FASTBOOT @@ -242,7 +240,6 @@ #define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* USB Device Firmware Update support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_DFU_SF diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index cc73684..d53e416 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -45,7 +45,6 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 9617e24..d771f9d 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -148,7 +148,6 @@ #define CONFIG_APBH_DMA_BURST8
/* Network */ -#define CONFIG_CMD_MII
#define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 71b9fe3..183a759 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -161,7 +161,6 @@ #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
/* Network */ -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index fa79d48..15976f7 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -184,11 +184,9 @@ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_BMODE
#define CONFIG_FSL_QSPI diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index bf6bae6..3c9a794 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -44,12 +44,7 @@ #define CONFIG_BAUDRATE 115200
/* Filesystems and image support */ -#define CONFIG_CMD_BOOTZ #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP @@ -60,7 +55,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
/* GPIO */ @@ -71,7 +65,6 @@
/* MMC */ #define CONFIG_MMC -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER #define CONFIG_FSL_ESDHC diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 5f63a1f..ece8a03 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -27,7 +27,6 @@ #define CONFIG_CSF_SIZE 0x4000
/* Network */ -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define CONFIG_FEC_XCV_TYPE RGMII @@ -252,11 +251,9 @@
/* USB Device Firmware Update support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_DFU_RAM diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 96ee7ec..dc8e265 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -44,7 +44,6 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_DATE #define CONFIG_CMD_IDE @@ -110,9 +109,6 @@ /* * File system */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_JFFS2_NAND #define CONFIG_JFFS2_LZO diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 9f16da7..b651eb3 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -64,7 +64,6 @@ #define CONFIG_LIBATA #endif
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -320,7 +319,6 @@ #define CONFIG_PCIE_IMX #endif
#define CONFIG_USB_FUNCTION_FASTBOOT diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index c6353e0..0fbbce6 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -124,11 +124,6 @@ #define CONFIG_SYS_NO_FLASH
/* commands to include */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_EXT4 /* EXT4 Support */ -#define CONFIG_CMD_FAT /* FAT support */ - -#define CONFIG_CMD_MMC /* MMC support */
#define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 8b6e93e..cfb92d6 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -19,11 +19,9 @@ #include "mx6_common.h"
/* U-Boot Commands */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMODE #define CONFIG_CMD_EEPROM #define CONFIG_FAT_WRITE -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA #define CONFIG_VIDEO diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 4510b16..1987164 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -26,9 +26,7 @@ /* commands configuration */ #define CONFIG_SYS_NO_FLASH /* declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS -#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_IDE -#define CONFIG_CMD_MII
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index 49e5eae..056f518 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -28,7 +28,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 1b06719..16fa046 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -76,8 +76,6 @@ * Supported commands */ #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII #ifdef CONFIG_PCI #define CONFIG_CMD_PCI #endif diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 3e2bcec..12b7dc5 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -46,7 +46,6 @@ #define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_SYS_CONSOLE_IS_IN_ENV
-#define CONFIG_CMD_BOOTZ #define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index e52d7ba..5196d58 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -24,8 +24,6 @@
#define TZPC_BASE_OFFSET 0x10000
-#define CONFIG_CMD_MMC - #define CONFIG_NR_DRAM_BANKS 8 #define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ /* Reserve the last 22 MiB for the secure firmware */ @@ -50,7 +48,6 @@ /* DFU */ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC -#define CONFIG_CMD_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300 #define DFU_MANIFEST_POLL_TIMEOUT 25000 @@ -65,7 +62,6 @@ #define CONFIG_G_DNL_UMS_VENDOR_NUM 0x0525 #define CONFIG_G_DNL_UMS_PRODUCT_NUM 0xA4A5 #define CONFIG_USB_FUNCTION_MASS_STORAGE -#define CONFIG_CMD_USB_MASS_STORAGE
/* FIXME: MUST BE REMOVED AFTER TMU IS TURNED ON */ #undef CONFIG_EXYNOS_TMU diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index d7e6c37..4dbe2b6 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -87,9 +87,6 @@ #define CONFIG_OMAP3_GPIO_6 /* GPIO160..191 is in GPIO bank 6 */
/* commands to include */ -#define CONFIG_CMD_ASKENV - -#define CONFIG_CMD_CACHE
#define MTDIDS_DEFAULT "nand0=nand" #define MTDPARTS_DEFAULT "mtdparts=nand:512k(x-loader),"\ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 8048ce8..9dbca1c 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -24,13 +24,9 @@ * Supported U-Boot commands * ---------------------------------------------------------------------------- */ -#define CONFIG_CMD_ASKENV
/* ---------------------------------------------------------------------------- diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index 99dab5f..01336ff 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -149,7 +149,6 @@
#define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE -#define CONFIG_CMD_FAT
#ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL diff --git a/include/configs/omap3_evm_quick_mmc.h b/include/configs/omap3_evm_quick_mmc.h index 23a8a07..a93a2fa 100644 --- a/include/configs/omap3_evm_quick_mmc.h +++ b/include/configs/omap3_evm_quick_mmc.h @@ -19,8 +19,6 @@ * Supported U-Boot commands * ---------------------------------------------------------------------------- */ -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT
/* * Board revision is detected by probing the Ethernet chip. diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index cfe7012..5da50a5 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -69,7 +69,6 @@ #define CONFIG_USBD_MANUFACTURER "Texas Instruments" #define CONFIG_USBD_PRODUCT_NAME "IGEP"
-#define CONFIG_CMD_CACHE #ifdef CONFIG_BOOT_ONENAND #define CONFIG_CMD_ONENAND /* ONENAND support */ #endif diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index ab83714..055dcb7 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -64,9 +64,6 @@
/* commands to include */ #define CONFIG_CMD_NAND -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */
diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 5db5dcf..c066eae 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -56,7 +56,6 @@ #define CONFIG_OMAP3_GPIO_6 /* GPIO160..191 is in GPIO Bank 6 */
/* commands to include */ -#define CONFIG_CMD_CACHE
#ifdef CONFIG_NAND #define CONFIG_CMD_UBI /* UBI-formated MTD partition support */ diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 803f4b8..380ec12 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -57,7 +57,6 @@ #define CONFIG_SERIAL3 3
/* commands to include */ -#define CONFIG_CMD_CACHE /* Cache control */
/* * Board NAND Info. diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index a794662..86cefa3 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -101,7 +101,6 @@ /* USB Device Firmware Update support */ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_RAM -#define CONFIG_CMD_DFU
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index be93ca3..f3287e3 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -210,16 +210,13 @@ * U-Boot commands */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DIAG -#define CONFIG_CMD_MII #define CONFIG_CMD_SAVES #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif
#ifndef CONFIG_DRIVER_TI_EMAC -#undef CONFIG_CMD_MII #endif
#ifdef CONFIG_USE_NAND @@ -253,9 +250,6 @@
#ifdef CONFIG_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC #undef CONFIG_ENV_IS_IN_MMC #endif
diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 6eb7e6e..4defa7e 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -46,8 +46,6 @@ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS #define CONFIG_CMD_ENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_IDE
diff --git a/include/configs/openrisc-generic.h b/include/configs/openrisc-generic.h index ffed6c5..dfb8d3a 100644 --- a/include/configs/openrisc-generic.h +++ b/include/configs/openrisc-generic.h @@ -116,8 +116,6 @@ #define CONFIG_CMD_IRQ #define CONFIG_CMD_BSP
-#define CONFIG_CMD_MII - #define CONFIG_LMB
/* diff --git a/include/configs/origen.h b/include/configs/origen.h index 4f14357..1fa2f4d 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -50,9 +50,6 @@ #define S5P_CHECK_DIDLE 0xBAD00000 #define S5P_CHECK_LPA 0xABAD0000
-#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_BOOTZ #define CONFIG_SUPPORT_RAW_INITRD
/* MMC SPL */ diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 9b5c369..891abce 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -88,7 +88,6 @@ #define CONFIG_SPL_SPI_LOAD #endif
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index fba61a4..596193d 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -868,7 +868,6 @@ * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_REGINFO
@@ -896,14 +895,11 @@ #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #endif
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) \ || defined(CONFIG_FSL_SATA) -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index bba75ab..f2959c9 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -401,7 +401,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
/* @@ -424,14 +423,11 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #endif
diff --git a/include/configs/p2371-0000.h b/include/configs/p2371-0000.h index c4a5799..e5dcb25 100644 --- a/include/configs/p2371-0000.h +++ b/include/configs/p2371-0000.h @@ -25,7 +25,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index 3bf3b56..6133d3f 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -25,7 +25,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/p2571.h b/include/configs/p2571.h index 95d2d63..4c75a26 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -26,7 +26,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/paz00.h b/include/configs/paz00.h index e7b084a..0e65032 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -26,7 +26,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index b1fd2b8..caf75a6 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -168,9 +168,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII
-#undef CONFIG_CMD_FAT #undef CONFIG_CMD_IDE #undef CONFIG_CMD_BEDBUG
diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index f503520..0007c50 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -53,7 +53,6 @@ Serial console configuration #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 356cd79..494524d 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -76,12 +76,9 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -258,6 +255,4 @@ #define CONFIG_ENV_OFFSET_REDUND 0xC0000 #endif
-#define CONFIG_CMD_BOOTZ - #endif diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index ff3f53d..3b6c7dc 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -380,10 +380,8 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#undef CONFIG_CMD_FUSE diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 155f589..1f33bc6 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -163,7 +163,6 @@
-#define CONFIG_CMD_ASKENV /* monitor functions : ask for env variable */ #define CONFIG_VERSION_VARIABLE /* monitor functions : u-boot version */ #define CONFIG_CMD_DIAG /* monitor functions : Diagnostics */
@@ -214,7 +213,6 @@ #define CONFIG_NET_MULTI
/* Network */ -#define CONFIG_CMD_MII #define CONFIG_PHYLIB #define CONFIG_PHY_RESET 1 #define CONFIG_PHY_NATSEMI diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index fccfb48..108c6a2 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -82,8 +82,6 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_ARP_TIMEOUT 500 /* millisec */
-#define CONFIG_CMD_MII - /* * BOOTP options */ @@ -98,7 +96,6 @@ #define CONFIG_SDHCI #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC
/*-------------------------------------------------- * USB Configuration @@ -115,15 +112,10 @@ #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_FAT #define CONFIG_FAT_WRITE -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_PART -#define CONFIG_CMD_FAT
/* EXT4 FS */ #define CONFIG_FS_EXT4 -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE
/* ------------------------------------------------- * Environment diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 118316b..44ffd6d 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -33,8 +33,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_CMD_BOOTZ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO @@ -96,7 +94,6 @@ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
/* MMC */ -#define CONFIG_CMD_MMC
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC @@ -105,7 +102,6 @@ #endif
#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/platinum.h b/include/configs/platinum.h index 4f78a3d..627e1a7 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -22,7 +22,6 @@ */
#define CONFIG_CMD_BMODE -#define CONFIG_CMD_MII #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 0f79472..617f927 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -23,7 +23,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index dcfc774..39af5c0 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -181,7 +181,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_NAND 1
/* SDRAM */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 92d080e..111e0f5 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -195,7 +195,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_NAND 1
/* SDRAM */ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index a6472fb..facba38 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -70,7 +70,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_NAND 1
#define CONFIG_CMD_JFFS2 1 diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 731b9de..6393ff3 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -33,7 +33,6 @@ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS #define CONFIG_CMD_ENV -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND
/* @@ -82,8 +81,6 @@ /* * File system */ -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS diff --git a/include/configs/porter.h b/include/configs/porter.h index 1e7f48d..929eede 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -90,7 +90,6 @@
diff --git a/include/configs/pxa-common.h b/include/configs/pxa-common.h index 7295687..375515e 100644 --- a/include/configs/pxa-common.h +++ b/include/configs/pxa-common.h @@ -26,8 +26,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_PXA_MMC_GENERIC -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index 4b0f98b..a7cd003 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -45,8 +45,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
#define CONFIG_DRIVER_NE2000 #define CONFIG_DRIVER_NE2000_BASE 0xb4000300 diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index b998052..394382c 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -45,8 +45,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
#define CONFIG_DRIVER_NE2000 #define CONFIG_DRIVER_NE2000_BASE 0xffffffffb4000300 diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 15f906a..73b3771 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -128,7 +128,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void);
#define CONFIG_LBA48 #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2
/* * Environment @@ -142,8 +141,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); /* * Command line configuration. */ -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ
#ifdef CONFIG_PCI diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index f19898f..437ea92 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -18,7 +18,6 @@ #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_TEXT_BASE 0x8FFC0000
-#define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV
diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index daf7e22..bf81d2b 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -11,10 +11,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_PCI #define CONFIG_CMD_IDE -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #define CONFIG_CMD_SH_ZIMAGEBOOT
diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index 8add5f8..6097dc2 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -22,7 +22,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_PCI #define CONFIG_CMD_IDE -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION
#define CONFIG_SCIF_CONSOLE 1 diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index aa130a1..47d2379 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -36,7 +36,6 @@ "led5=63,0,1\0"
#undef CONFIG_DOS_PARTITION -#undef CONFIG_CMD_FAT
diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index c814189..337ba02 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -15,12 +15,6 @@
#define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_MII -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE
#define CONFIG_SYS_THUMB_BUILD
diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index a5ab569..1bdcf9d 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -45,22 +45,15 @@ /* MMC/SD IP block */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC #define CONFIG_SDHCI #define CONFIG_DWMMC #define CONFIG_BOUNCE_BUFFER
#define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FS_GENERIC #define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
-#define CONFIG_CMD_CACHE - #define CONFIG_SYS_SDRAM_BASE 0x60000000 #define CONFIG_NR_DRAM_BANKS 1 #define SDRAM_BANK_SIZE (512UL << 20UL) diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index c1ea280..8a81397 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -51,17 +51,12 @@ /* MMC/SD IP block */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC #define CONFIG_SDHCI #define CONFIG_DWMMC #define CONFIG_BOUNCE_BUFFER
@@ -78,8 +73,6 @@ #define CONFIG_SPL_RAM_SUPPORT #define CONFIG_SPL_DRIVERS_MISC_SUPPORT
-#define CONFIG_CMD_CACHE - #define CONFIG_SYS_SDRAM_BASE 0 #define CONFIG_NR_DRAM_BANKS 1 #define SDRAM_BANK_SIZE (2UL << 30) diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 0fd040f..af58182 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -144,7 +144,6 @@ #define CONFIG_COMMAND_HISTORY
/* Commands */ -#define CONFIG_CMD_MMC #define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
diff --git a/include/configs/rsk7203.h b/include/configs/rsk7203.h index c7ef864..1e4166c 100644 --- a/include/configs/rsk7203.h +++ b/include/configs/rsk7203.h @@ -15,7 +15,6 @@ #define CONFIG_RSK7203 1
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200" diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 916895a..afea884 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -62,11 +62,8 @@
#define CONFIG_SYS_NO_FLASH 1
-#define CONFIG_CMD_CACHE #define CONFIG_CMD_REGINFO #define CONFIG_CMD_ONENAND -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU #define CONFIG_CMD_GPT
/* USB Composite download gadget - g_dnl */ @@ -231,10 +228,6 @@
#define CONFIG_DOS_PARTITION 1
-#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE - /* write support for filesystems */ #define CONFIG_FAT_WRITE #define CONFIG_EXT4_WRITE @@ -267,7 +260,6 @@
#define CONFIG_SYS_MAX_I2C_BUS 7 #define CONFIG_USB_GADGET_DWC2_OTG_PHY -#define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE
#endif /* __CONFIG_H */ diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index bdb39a3..f9a8f6f 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -51,7 +51,6 @@ #undef CONFIG_CMD_NAND
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC @@ -78,7 +77,6 @@ #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2 XPlained"
diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index ee3e34d..55615ea 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -77,11 +77,9 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_MACB_SEARCH_PHY #define CONFIG_RGMII -#define CONFIG_CMD_MII #define CONFIG_PHYLIB
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC @@ -105,10 +103,7 @@ #endif
#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE #endif
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index c4ad3c4..1e721a9 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -108,13 +108,11 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_MACB_SEARCH_PHY #define CONFIG_RGMII -#define CONFIG_CMD_MII #define CONFIG_PHYLIB #define CONFIG_PHY_MICREL #define CONFIG_PHY_MICREL_KSZ9021
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC @@ -143,7 +141,6 @@ #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D3xEK"
#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE #endif
diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index a81766a..8d141a9 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -62,7 +62,6 @@ #endif
#ifdef CONFIG_CMD_MMC #define CONFIG_MMC @@ -86,7 +85,6 @@ #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D4EK"
diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 339fcf1..4b19080 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -62,7 +62,6 @@ #endif
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 0bdb73a..9790a14 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -39,15 +39,11 @@ #define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_CBFS #define CONFIG_CMD_CRAMFS #define CONFIG_CMD_PART #define CONFIG_DOS_PARTITION #define CONFIG_HOST_MAX_DEVICES 4 -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MD5SUM
#define CONFIG_CMD_GPT @@ -138,8 +134,6 @@
#define CONFIG_CMD_ENV_FLAGS #define CONFIG_CMD_ENV_CALLBACK -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_ASKENV
#define CONFIG_BOOTARGS ""
diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index f6e07b4..0c8ecc1 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -14,10 +14,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MMC #define CONFIG_VIDEO
/* Memory configuration */ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index fc22134..6c0932a 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -406,7 +406,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 19601e7..bbd1a63 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -523,7 +523,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index 9ec8417..42237d3 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -19,12 +19,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC - /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 54aeb5b..4c01966 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -35,7 +35,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/secomx6quq7.h b/include/configs/secomx6quq7.h index e1c0e9a..51b88a4 100644 --- a/include/configs/secomx6quq7.h +++ b/include/configs/secomx6quq7.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* Ethernet Configuration */ -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 7ca7afa..d34811f 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -230,7 +230,6 @@ */ #define CONFIG_CMD_CHIP_CONFIG #define CONFIG_CMD_DTT -#define CONFIG_CMD_FAT #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index 58f9540..80997a4 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -16,13 +16,10 @@ #define CONFIG_SYS_TEXT_BASE 0x5ff80000 #define CONFIG_SYS_LDSCRIPT "board/renesas/sh7752evb/u-boot.lds"
-#define CONFIG_CMD_MII #define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #define CONFIG_MAC_PARTITION
diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 540d36c..248435b 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -16,13 +16,10 @@ #define CONFIG_SYS_TEXT_BASE 0x5ff80000 #define CONFIG_SYS_LDSCRIPT "board/renesas/sh7753evb/u-boot.lds"
diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 298d3a2..547b500 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -17,12 +17,9 @@ #define CONFIG_SYS_TEXT_BASE 0x8ef80000 #define CONFIG_SYS_LDSCRIPT "board/renesas/sh7757lcr/u-boot.lds"
-#define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #define CONFIG_MAC_PARTITION
diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 9f6fe0e..9f1e6d7 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -18,7 +18,6 @@ * Command line configuration. */ #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_MII #define CONFIG_CMD_JFFS2
#define CONFIG_BOOTDELAY -1 diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 1d7fced..bd4c6bd 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -18,8 +18,6 @@ #define CONFIG_CMD_SH_ZIMAGEBOOT
#define CONFIG_USB_STORAGE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #define CONFIG_MAC_PARTITION
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 2019156..fa76a25 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -24,7 +24,6 @@ /* * Commands configuration */ -#define CONFIG_CMD_MMC
/* * Standard filesystems diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index aecd06f..dfc928d 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -39,8 +39,6 @@ #define CONFIG_SYS_CACHELINE_SIZE 64
/* commands to include */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE
#define CONFIG_ENV_VARS_UBOOT_CONFIG #ifndef CONFIG_SPL_BUILD @@ -85,10 +83,7 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
#define CONFIG_SPI #define CONFIG_OMAP3_SPI @@ -239,7 +234,6 @@ /* USB Device Firmware Update support */ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND -#define CONFIG_CMD_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1 << 20) #define DFU_MANIFEST_POLL_TIMEOUT 25000
@@ -272,7 +266,6 @@ #define CONFIG_MII #define CONFIG_PHY_GIGE #define CONFIG_PHYLIB -#define CONFIG_CMD_MII #define CONFIG_BOOTP_DEFAULT #define CONFIG_BOOTP_DNS #define CONFIG_BOOTP_DNS2 diff --git a/include/configs/silk.h b/include/configs/silk.h index a3790f0..dca0623 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -91,7 +91,6 @@ /* MMCIF */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC #define CONFIG_SH_MMCIF #define CONFIG_SH_MMCIF_ADDR 0xee200000 #define CONFIG_SH_MMCIF_CLK 48000000 diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 4daab98..40b0cd2 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -169,7 +169,6 @@ #define CONFIG_USB_GADGET_AT91
/* DFU class support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_1M @@ -215,7 +214,6 @@ /* Command line & features configuration */
#define CONFIG_CMD_NAND -#define CONFIG_CMD_FAT
#ifdef CONFIG_MACB #else diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index f009343..c5c0c2c 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -73,7 +73,6 @@ * Command line configuration. */ #define CONFIG_CMD_BSP -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND #define CONFIG_CMD_REGINFO @@ -170,8 +169,6 @@ /* * File system */ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS #define CONFIG_CMD_MTDPARTS diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index e1c7c67..0f1a1ec 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -67,10 +67,8 @@ ***********************************************************/ #undef CONFIG_CMD_NAND
-#define CONFIG_CMD_CACHE #define CONFIG_CMD_REGINFO #define CONFIG_CMD_ONENAND -#define CONFIG_CMD_FAT #define CONFIG_CMD_MTDPARTS
#define CONFIG_BOOTDELAY 3 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 0c21deb..efb18ff 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -14,10 +14,8 @@ #undef CONFIG_BOARD_COMMON #undef CONFIG_USB_GADGET_DWC2_OTG #undef CONFIG_USB_GADGET_DWC2_OTG_PHY -#undef CONFIG_CMD_USB_MASS_STORAGE #undef CONFIG_REVISION_TAG #undef CONFIG_CMD_THOR_DOWNLOAD -#undef CONFIG_CMD_DFU
/* High Level Configuration Options */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index bff49b1..16aefc2 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -145,8 +145,6 @@ #define CONFIG_SYS_MALLOC_LEN (1 << 20)
/* Command line configuration */ -#define CONFIG_CMD_FAT -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO diff --git a/include/configs/sniper.h b/include/configs/sniper.h index eb53a21..fb348a5 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -102,8 +102,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC
-#define CONFIG_CMD_MMC - /* * Power */ diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 6cdf38b..ca7f8a2 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -14,19 +14,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCDK */
diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index bf75e0f..a2da7d4 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -14,19 +14,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 90592a8..fdddfa3 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -14,19 +14,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB */
diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index f1cfe21..f0fb43a 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -14,19 +14,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on MCV */
diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 7ac5889..675f5d1 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -14,19 +14,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index e2ed253..79c16ce 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -14,19 +14,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCrates */
diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index fb98546..efa9e42 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -16,18 +16,6 @@
-/* U-Boot Commands */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SR1500 */
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index cf1e904..4ed524b 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -308,9 +308,7 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #undef CONFIG_CMD_EEPROM -#define CONFIG_CMD_EXT2 /* EXT2 Support */ #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 269ce7e..c4b6234 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -101,7 +101,6 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_ENV #define CONFIG_CMD_SAVES -#define CONFIG_CMD_MII
/* * Default Environment Varible definitions diff --git a/include/configs/stout.h b/include/configs/stout.h index 70fedf1..d21c3cb 100644 --- a/include/configs/stout.h +++ b/include/configs/stout.h @@ -94,7 +94,6 @@
/* Module stop status bits */ diff --git a/include/configs/strider.h b/include/configs/strider.h index a5b2223..5803b66 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -35,10 +35,8 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
-#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2
#define CONFIG_SYS_ALT_MEMTEST
@@ -506,7 +504,6 @@ int fpga_gpio_get(unsigned int bus, int pin); /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index bd16ff9..2406115 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -140,7 +140,6 @@ /* mmc config */ #ifdef CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC #define CONFIG_MMC_SUNXI #define CONFIG_MMC_SUNXI_SLOT 0 #define CONFIG_ENV_IS_IN_MMC @@ -347,7 +346,6 @@ extern int soft_i2c_gpio_scl; #endif
#ifdef CONFIG_USB_FUNCTION_DFU -#define CONFIG_CMD_DFU #define CONFIG_DFU_RAM #endif
@@ -366,7 +364,6 @@ extern int soft_i2c_gpio_scl; #endif
#ifdef CONFIG_USB_FUNCTION_MASS_STORAGE -#define CONFIG_CMD_USB_MASS_STORAGE #endif
#ifdef CONFIG_USB_KEYBOARD diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index f77e63c..af61f21 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -237,7 +237,6 @@ #define CONFIG_LBA48 #define CONFIG_CMD_SATA #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_FMAN_ENET @@ -256,9 +255,7 @@ * Command line configuration. */ #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_MII
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index ef9e22e..efdc706 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -96,11 +96,6 @@ #define CONFIG_USB_STORAGE
/* commands to include */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_EEPROM
diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 38f3446..4d66dd2 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -92,9 +92,6 @@ #define CONFIG_OMAP3_GPIO_6 /* GPIO160..191 is in GPIO bank 6 */
/* commands to include */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define MTDIDS_DEFAULT "nand0=nand" @@ -102,7 +99,6 @@ "1920k(u-boot),128k(u-boot-env),"\ "4m(kernel),-(fs)"
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 946bfd4..321fb47 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -49,8 +49,6 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_CMD_BOOTZ - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO @@ -131,7 +129,6 @@ #define CONFIG_USB_GADGET_AT91
/* DFU class support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_SYS_DFU_DATA_BUF_SIZE (SZ_1M) diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index bd4d98e..ec0bf05 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -67,7 +67,6 @@
/* Ethernet */ #define CONFIG_FEC_MXC -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -121,7 +120,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB_MASS_STORAGE #ifdef CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USBD_HS #define CONFIG_USB_FUNCTION_MASS_STORAGE diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index d131c17..d7f1a7c 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -24,7 +24,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/tec.h b/include/configs/tec.h index 976f9c1..a90af06 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -23,7 +23,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index a1daf8c..b206ce4 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -125,7 +125,6 @@ #undef CONFIG_TEGRA_MMC #endif #ifdef CONFIG_CMD_MMC -#undef CONFIG_CMD_MMC #endif
/* remove partitions/filesystems */ @@ -135,18 +134,6 @@ #ifdef CONFIG_EFI_PARTITION #undef CONFIG_EFI_PARTITION #endif -#ifdef CONFIG_CMD_FS_GENERIC -#undef CONFIG_CMD_FS_GENERIC -#endif -#ifdef CONFIG_CMD_EXT4 -#undef CONFIG_CMD_EXT4 -#endif -#ifdef CONFIG_CMD_EXT2 -#undef CONFIG_CMD_EXT2 -#endif -#ifdef CONFIG_CMD_FAT -#undef CONFIG_CMD_FAT -#endif #ifdef CONFIG_FS_EXT4 #undef CONFIG_FS_EXT4 #endif diff --git a/include/configs/tegra-common-usb-gadget.h b/include/configs/tegra-common-usb-gadget.h index 18851ca..3e3eeea 100644 --- a/include/configs/tegra-common-usb-gadget.h +++ b/include/configs/tegra-common-usb-gadget.h @@ -13,12 +13,10 @@ #define CONFIG_CI_UDC_HAS_HOSTPC /* USB mass storage protocol */ #define CONFIG_USB_FUNCTION_MASS_STORAGE -#define CONFIG_CMD_USB_MASS_STORAGE /* DFU protocol */ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_1M #define CONFIG_SYS_DFU_MAX_FILE_SIZE SZ_32M -#define CONFIG_CMD_DFU #ifdef CONFIG_MMC #define CONFIG_DFU_MMC #endif diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index b07ee56..92d4dd8 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -137,7 +137,6 @@
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> -#define CONFIG_CMD_EXT4_WRITE #define CONFIG_FAT_WRITE #endif
diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index a5a7fae..1caa858 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -23,13 +23,7 @@ /* * Commands configuration */ -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_SATA
/* diff --git a/include/configs/thuban.h b/include/configs/thuban.h index 077422f..5fed55d 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -29,7 +29,6 @@ "led1=64,0,1\0"
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 4dfbd82..09f8e8f 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -37,7 +37,6 @@ #define CONFIG_INITRD_TAG /* for ramdisk support */
/* commands to include */ -#define CONFIG_CMD_ASKENV #define CONFIG_VERSION_VARIABLE
#define CONFIG_BOOTDELAY 1 /* negative for no autoboot */ @@ -122,10 +121,7 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
/** * Physical Memory Map @@ -210,7 +206,6 @@ #undef CONFIG_USE_IRQ
/* Ethernet */ -#define CONFIG_CMD_MII #define CONFIG_DRIVER_TI_CPSW #define CONFIG_MII #define CONFIG_BOOTP_DNS diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 83b745a..2e84dd2 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -62,10 +62,7 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2
diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 049b92a..bcd56fc 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -30,7 +30,6 @@
#ifndef CONFIG_SPL_BUILD /* Network defines. */ -#define CONFIG_CMD_MII #define CONFIG_BOOTP_DNS /* Configurable parts of CMD_DHCP */ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 6d77e78..7db0881 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -115,7 +115,6 @@ /* MMC/SD IP block */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_MMC
/* McSPI IP block */ #define CONFIG_SPI @@ -168,8 +167,6 @@ #define CONFIG_CMD_MTDPARTS #endif
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ #define CONFIG_SUPPORT_RAW_INITRD
/* @@ -178,11 +175,7 @@ */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FS_GENERIC #define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART #endif @@ -302,6 +295,5 @@ #endif
#endif /* __CONFIG_TI_ARMV7_COMMON_H__ */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index ceebffb..2c9028c 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -314,7 +314,6 @@ #undef CONFIG_SPL_EXT_SUPPORT #undef CONFIG_MMC #undef CONFIG_GENERIC_MMC -#undef CONFIG_CMD_MMC
/* And no support for GPIO, yet.. */ #undef CONFIG_SPL_GPIO_SUPPORT diff --git a/include/configs/titanium.h b/include/configs/titanium.h index 94b2f27..c6ba017 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -41,7 +41,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 1
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 439a4fd..badb955 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -97,8 +97,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */
-#define CONFIG_CMD_MII - #define CONFIG_FEC_MXC #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_PHYLIB diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 2514e88..855d789 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -146,9 +146,6 @@ #define CONFIG_SYS_NAND_MAX_ECCPOS 56
/* commands to include */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */ diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index b763eec..b761640 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -31,7 +31,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in SPI */ #define CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 7dc7443..aa0605f 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -64,9 +64,7 @@
#define CONFIG_MMC
/* @@ -81,8 +79,6 @@ #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 0
-#define CONFIG_CMD_MII - /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE /* disable vendor parameters protection (serial#, ethaddr) */ #define CONFIG_CONS_INDEX 1 /* use UART0 : used by serial driver */ @@ -92,8 +88,6 @@ * Command definition ***********************************************************/
-#define CONFIG_CMD_BOOTZ - /* Environment variables */
#define CONFIG_BOOTDELAY 1 diff --git a/include/configs/tseries.h b/include/configs/tseries.h index e73bc83..b6a1ae0 100644 --- a/include/configs/tseries.h +++ b/include/configs/tseries.h @@ -46,7 +46,6 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_CMD_BOOTZ /*#define CONFIG_MACH_TYPE 3589*/ #define CONFIG_MACH_TYPE 0xFFFFFFFF /* TODO: check with kernel*/
@@ -55,7 +54,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC - #define CONFIG_CMD_MMC #define CONFIG_SUPPORT_EMMC_BOOT /* RAW SD card / eMMC locations. */ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /*addr. 0x60000 */ @@ -299,13 +297,9 @@ MMCARGS */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FS_GENERIC #endif /* CONFIG_MMC, ... */
#endif /* ! __CONFIG_TSERIES_H__ */ diff --git a/include/configs/udoo.h b/include/configs/udoo.h index 4437700..fba78d0 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -41,7 +41,6 @@
/* Network support */
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 1d740d0..0b90152 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -123,12 +123,10 @@ /* USB */ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 4 -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE #define CONFIG_DOS_PARTITION
/* SD/MMC */ -#define CONFIG_CMD_MMC #define CONFIG_SUPPORT_EMMC_BOOT #define CONFIG_GENERIC_MMC
@@ -175,7 +173,6 @@ "bootm $fit_addr_r\0" \ "__nfsboot=run tftpboot\0" #else -#define CONFIG_CMD_BOOTZ #define CONFIG_BOOTFILE "zImage" #define LINUXBOOT_ENV_SETTINGS \ "fdt_addr=0x00100000\0" \ diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 2202d98..d118928 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -113,7 +113,6 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT #endif
#define CONFIG_SYS_LOAD_ADDR 0x22000000 diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index d23674c..8568663 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -45,7 +45,6 @@ #define CONFIG_BAUDRATE 115200
/* SD/MMC */ -#define CONFIG_CMD_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_ESDHC_NUM 1 diff --git a/include/configs/v38b.h b/include/configs/v38b.h index c8cc842..9a113f4 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -84,15 +84,12 @@ /* * Command line configuration. */ -#define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_DIAG #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_DATE -#define CONFIG_CMD_FAT
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
diff --git a/include/configs/vct.h b/include/configs/vct.h index 679cd74..6489e08 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -97,7 +97,6 @@ */ #if (defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM)) && \ !defined(CONFIG_VCT_SMALL_IMAGE) -#define CONFIG_CMD_FAT #endif
#if defined(CONFIG_CMD_USB) @@ -276,15 +275,11 @@ int vct_gpio_get(int pin); * (NOR/OneNAND) usage and Linux kernel booting. */ #if defined(CONFIG_VCT_SMALL_IMAGE) -#undef CONFIG_CMD_ASKENV #undef CONFIG_CMD_BEDBUG -#undef CONFIG_CMD_CACHE #undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_FAT #undef CONFIG_CMD_IRQ #undef CONFIG_CMD_LOADY -#undef CONFIG_CMD_MII #undef CONFIG_CMD_REGINFO #undef CONFIG_CMD_STRINGS #undef CONFIG_CMD_TERMINAL diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 59bf2b3..2425ebf 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -320,7 +320,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 diff --git a/include/configs/venice2.h b/include/configs/venice2.h index f413f40..1d24437 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -26,7 +26,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/ventana.h b/include/configs/ventana.h index 5c2fe9b..cdf50e3 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -24,7 +24,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* Environment in eMMC, at the end of 2nd "boot sector" */ #define CONFIG_ENV_IS_IN_MMC diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index a7e1195..1b5fc2e 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -134,13 +134,10 @@ /* Command line configuration */ #define CONFIG_MENU /*#define CONFIG_MENU_SHOW*/ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_BOOTI #define CONFIG_CMD_UNZIP #define CONFIG_CMD_PXE #define CONFIG_CMD_ENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
/* BOOTP options */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 67379fd..6dc8f25 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -153,7 +153,6 @@ #define CONFIG_SYS_SERIAL1 V2M_UART1
#define CONFIG_MMC 1 -#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_ARM_PL180_MMCI #define CONFIG_ARM_PL180_MMCI_BASE V2M_MMCI diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index d8c45de..b240613 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -77,12 +77,9 @@
-#define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -267,6 +264,4 @@ #define CONFIG_ENV_OFFSET 0x180000 #endif
-#define CONFIG_CMD_BOOTZ - #endif diff --git a/include/configs/vinco.h b/include/configs/vinco.h index b0737e7..35fe9de 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -54,7 +54,6 @@ #endif
#ifdef CONFIG_CMD_MMC #define CONFIG_SUPPORT_EMMC_BOOT @@ -87,12 +86,10 @@ #define CONFIG_USBNET_MANUFACTURER "L+G VInCo"
/* Ethernet Hardware */ -#define CONFIG_CMD_MII #define CONFIG_PHY_SMSC #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index f9e6a8d..732d091 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -347,7 +347,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_SYS_RTC_BUS_NUM 0x01 #define CONFIG_SYS_I2C_RTC_ADDR 0x32 diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 7898a81..99f5c0c 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -55,7 +55,6 @@ #define CONFIG_MXC_USB_FLAGS 0
/* Ethernet Configuration */ -#define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/warp.h b/include/configs/warp.h index 42b728a..4a8e270 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -75,10 +75,8 @@
-#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 8c72178..4dfcd28 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -133,7 +133,6 @@ #define CONFIG_USB_GADGET_DUALSPEED
#define CONFIG_USB_GADGET -#define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_USB_GADGET_VBUS_DRAW 2 @@ -143,7 +142,6 @@ #define CONFIG_G_DNL_MANUFACTURER "FSL"
/* USB Device Firmware Update support */ -#define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M diff --git a/include/configs/whistler.h b/include/configs/whistler.h index a5cd38b..9c194d5 100644 --- a/include/configs/whistler.h +++ b/include/configs/whistler.h @@ -28,7 +28,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC -#define CONFIG_CMD_MMC
/* * Environment in eMMC, at the end of 2nd "boot sector". Note: This assumes diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index af6cbe4..a4ae304 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -89,15 +89,9 @@ #define CONFIG_BOOTP_DNS
-#define CONFIG_CMD_MII - -#define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION #define CONFIG_EFI_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT
#define CONFIG_MXC_GPIO
diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index c59688c..b81b6ff 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -63,7 +63,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ADDR 0 #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN -#define CONFIG_CMD_MII /* FIXME: remove "Waiting for PHY auto negotiation to complete..." message */
/* diff --git a/include/configs/x600.h b/include/configs/x600.h index 265d710..d7da0b2 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -109,13 +109,9 @@ /* * Command support defines */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_ENV -#define CONFIG_CMD_FAT #define CONFIG_CMD_FPGA_LOADMK -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_MII #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND #define CONFIG_CMD_SAVES diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index c72ae72..a2822e0 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -84,8 +84,6 @@ #ifdef CONFIG_SYS_COREBOOT #define CONFIG_CMD_CBFS #endif -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE #define CONFIG_PARTITION_UUIDS
#define CONFIG_SYS_CONSOLE_INFO_QUIET @@ -97,7 +95,6 @@ * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_FPGA_LOADMK #define CONFIG_CMD_IO #define CONFIG_CMD_IRQ @@ -105,9 +102,6 @@ #define CONFIG_CMD_GETTIME #define CONFIG_CMD_SCSI
-#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 - #define CONFIG_CMD_ZBOOT
#define CONFIG_BOOTARGS \ diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 8d5ea48..4d68c21 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -14,10 +14,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
/* Memory configuration */ diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 3ab8eab..067cfa6 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -24,8 +24,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
/*Cmd*/ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DIAG #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index be43aa6..fe9c719 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -63,16 +63,10 @@
/* Command line configuration */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC #define CONFIG_DOS_PARTITION #define CONFIG_EFI_PARTITION #define CONFIG_MP
-#define CONFIG_CMD_MII - /* BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE #define CONFIG_BOOTP_BOOTPATH @@ -89,7 +83,6 @@ # define CONFIG_MMC # define CONFIG_GENERIC_MMC # define CONFIG_SDHCI -# define CONFIG_CMD_MMC # ifndef CONFIG_ZYNQ_SDHCI_MAX_FREQ # define CONFIG_ZYNQ_SDHCI_MAX_FREQ 200000000 # endif @@ -97,7 +90,6 @@
#if defined(CONFIG_ZYNQ_SDHCI) || defined(CONFIG_ZYNQMP_USB) # define CONFIG_FAT_WRITE -# define CONFIG_CMD_EXT4_WRITE #endif
#ifdef CONFIG_NAND_ARASAN @@ -125,7 +117,6 @@ #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_RAM #define CONFIG_USB_CABLE_CHECK -#define CONFIG_CMD_DFU #define CONFIG_CMD_THOR_DOWNLOAD #define CONFIG_USB_FUNCTION_THOR #define CONFIG_THOR_RESET_OFF diff --git a/include/configs/xpedite1000.h b/include/configs/xpedite1000.h index f707f57..9838fbf 100644 --- a/include/configs/xpedite1000.h +++ b/include/configs/xpedite1000.h @@ -180,12 +180,10 @@ extern void out32(unsigned int, unsigned long); /* * Command configuration */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_PCI
/* diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index d7e696e..af02efb 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -511,7 +511,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_DS4510 #define CONFIG_CMD_DS4510_INFO @@ -519,7 +518,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 09f0c3f..d1847ac 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -297,11 +297,9 @@ /* * Command configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 1946bb9..a1c5826 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -366,14 +366,12 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_DS4510 #define CONFIG_CMD_DS4510_INFO #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 3aa21eb..02685ca 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -352,12 +352,10 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Command configuration. */ -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO diff --git a/include/configs/xpress.h b/include/configs/xpress.h index 9a0aac5..4625daf 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -75,9 +75,7 @@ #define CONFIG_SYS_MMC_ENV_PART 1 /* boot parition */ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC2 */
-#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_BMODE -#define CONFIG_CMD_CACHE
/* USB Configs */ #define CONFIG_USB_EHCI @@ -90,7 +88,6 @@
#define CONFIG_FEC_MXC #define CONFIG_MII -#define CONFIG_CMD_MII #define CONFIG_FEC_ENET_DEV 0 #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x0 diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index 37f7a07..03cad10 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -193,8 +193,6 @@ #define CONFIG_CMD_PCI
#ifdef CONFIG_440EP - #define CONFIG_CMD_FAT - #define CONFIG_CMD_EXT2 #endif
/*----------------------------------------------------------------------- diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 81de228..fcd7772 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -59,8 +59,6 @@ * Bootloader Components Configuration */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_MMC -#define CONFIG_CMD_CACHE
/* * MMC Card Configuration @@ -70,8 +68,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #endif
diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 72c6c0a..264bb63 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -75,12 +75,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_CACHE
/* * Additional command */ -#define CONFIG_CMD_FAT
/* * USB diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 4f49ba8..a3e4aec 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -16,7 +16,6 @@ #endif
/* Cache options */ -#define CONFIG_CMD_CACHE #define CONFIG_SYS_CACHELINE_SIZE 32
#define CONFIG_SYS_L2CACHE_OFF @@ -84,7 +83,6 @@ # define CONFIG_MMC # define CONFIG_GENERIC_MMC # define CONFIG_SDHCI -# define CONFIG_CMD_MMC # define CONFIG_ZYNQ_SDHCI_MAX_FREQ 52000000 #endif
@@ -100,7 +98,6 @@ # define CONFIG_USB_FUNCTION_DFU # define CONFIG_DFU_RAM # define CONFIG_USB_CABLE_CHECK -# define CONFIG_CMD_DFU # define CONFIG_CMD_THOR_DOWNLOAD # define CONFIG_THOR_RESET_OFF # define CONFIG_USB_FUNCTION_THOR @@ -139,13 +136,8 @@
#if defined(CONFIG_ZYNQ_SDHCI) || defined(CONFIG_ZYNQ_USB) # define CONFIG_SUPPORT_VFAT -# define CONFIG_CMD_FAT -# define CONFIG_CMD_EXT2 # define CONFIG_FAT_WRITE # define CONFIG_DOS_PARTITION -# define CONFIG_CMD_EXT4 -# define CONFIG_CMD_EXT4_WRITE -# define CONFIG_CMD_FS_GENERIC #endif
#if defined(CONFIG_ZYNQ_I2C0) || defined(CONFIG_ZYNQ_I2C1) @@ -303,7 +295,6 @@ #define CONFIG_SYS_LDSCRIPT "arch/arm/mach-zynq/u-boot.lds"
/* Commands */ -#define CONFIG_CMD_MII
/* SPL part */ #define CONFIG_CMD_SPL
On Mon, Apr 25, 2016 at 03:12:36PM -0400, Tom Rini wrote:
Update the config.h and defconfig files for the commands that 8e3c036 converted over to Kconfig
Signed-off-by: Tom Rini trini@konsulko.com
On Thu, Apr 21, 2016 at 09:05:23AM -0500, Dinh Nguyen wrote:
Add the following CMD options to Kconfig:
CMD_BOOTZ CMD_ASKENV CMD_GREPENV CMD_USB_MASS_STORAGE CMD_FAT CMD_MII CMD_CACHE CMD_DFU CMD_EXT2 CMD_EXT4 CMD_EXT4_WRITE CMD_FS_GENERIC CMD_MMC
Signed-off-by: Dinh Nguyen dinguyen@kernel.org
Dinh Nguyen
Dinh Nguyen
