[U-Boot] [PATCH v6 1/1] socfpga: Adding configuration for development kit
Separating the configuration file for Virtual Target and real hardware Cyclone V development kit
Signed-off-by: Chin Liang See clsee@altera.com Reviewed-by: Pavel Machek pavel@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Pavel Machek pavel@denx.de Cc: Dinh Nguyen dinguyen@altera.com Cc: Tom Rini trini@ti.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- Changes for v6: - Re-shuffle the change list Changes for v5: - Added Reviewed-by: Pavel Machek - Cc: Tom Rini Changes for v4: - Added change log for each revision change Changes for v3: - Fixed the long subject of the patch Changes for v2: - Fixed the word wrap issue within patch --- include/configs/socfpga_cyclone5.h | 28 +++++++++++++++++++++------- 1 file changed, 21 insertions(+), 7 deletions(-)
diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index b5a7a9a..06aeba6 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -11,6 +11,8 @@ /* * High level configuration */ +/* Virtual target or real hardware */ +#define CONFIG_SOCFPGA_VIRTUAL_TARGET
#define CONFIG_ARMV7 #define CONFIG_L2_OFF @@ -21,11 +23,12 @@ #define CONFIG_SINGLE_BOOTLOADER #define CONFIG_SOCFPGA
+/* base address for .text section */ +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET #define CONFIG_SYS_TEXT_BASE 0x08000040 -#define V_NS16550_CLK 1000000 -#define CONFIG_BAUDRATE 57600 -#define CONFIG_SYS_HZ 1000 -#define CONFIG_TIMER_CLOCK_KHZ 2400 +#else +#define CONFIG_SYS_TEXT_BASE 0x01000040 +#endif #define CONFIG_SYS_LOAD_ADDR 0x7fc0
/* Console I/O Buffer Size */ @@ -154,7 +157,7 @@ /* SDRAM Bank #1 */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* SDRAM memory size */ -#define PHYS_SDRAM_1_SIZE 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x40000000
#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_START 0x00000000 @@ -170,8 +173,13 @@ #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 UART0_BASE - #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET +#define V_NS16550_CLK 1000000 +#else +#define V_NS16550_CLK 100000000 +#endif +#define CONFIG_BAUDRATE 115200
/* * FLASH @@ -184,9 +192,15 @@ /* This timer use eosc1 where the clock frequency is fixed * throughout any condition */ #define CONFIG_SYS_TIMERBASE SOCFPGA_OSC1TIMER0_ADDRESS - /* reload value when timer count to zero */ #define TIMER_LOAD_VAL 0xFFFFFFFF +/* Timer info */ +#define CONFIG_SYS_HZ 1000 +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET +#define CONFIG_TIMER_CLOCK_KHZ 2400 +#else +#define CONFIG_TIMER_CLOCK_KHZ 25000 +#endif
#define CONFIG_ENV_IS_NOWHERE
Hi!
Albert, Tom.... this patch has been here for a week, without any comments. As far as I can tell, it is pretty much perfect. Can we get any comments on it, or (better), get it applied?
If you excuse one extra newline at end of file, [PATCH v6 1/1] socfpga: Creating driver for Reset Manager is in good shape too, and applying it would be nice.
Thanks, Pavel
Changes for v6:
Changes for v5:
- Cc: Tom Rini
Changes for v4:
Changes for v3:
Changes for v2:
- High level configuration
- FLASH
- throughout any condition */
Hi!
Another week passed, and nothing happens. Is there just slow holiday time, or are we doing something wrong?
Thanks, Pavel
Thanks, Pavel
Changes for v6:
Changes for v5:
- Cc: Tom Rini
Changes for v4:
Changes for v3:
Changes for v2:
- FLASH
On Thu, Aug 22, 2013 at 01:05:42PM +0200, Pavel Machek wrote:
Hi!
I believe Albert is on holiday right now and it needs to come in via his tree. Sorry/thanks!
Hi guys,
Wonder any updates on this? We plan to send the new patches only once these existing patches are accepted. Appreciate for your helps again.
Chin Liang
On Thu, 2013-08-22 at 13:05 +0200, ZY - pavel wrote:
Hi!
Thanks, Pavel
Thanks, Pavel
Hi!
Albert seems to be back, perhaps he'll us how he wants us to proceed?
Thanks, Pavel
Hi Pavel,
On Thu, 2013-09-05 at 13:10 +0200, ZY - pavel wrote:
Hi!
Yup, I saw his posting again. Hope we can hear from Albert soon on these patches. Thanks
Chin Liang
Thanks, Pavel
Hi Chin,
Changes for v6:
Changes for v5:
- Cc: Tom Rini
Changes for v4:
Changes for v3:
Changes for v2:
- FLASH
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Chin Liang See
Pavel Machek
