[U-Boot] [PATCH 0/6] Remove calls from net drivers to legacy miiphy_register() entry-point
This is an effort to migrate closer to the phylib approach so that a new DM approach can be developed from a single starting point. The more of this legacy code can be removed, the easier it will be to move forward.
Joe Hershberger (6): common: Always include errno.h in common.h scripts: Add a cocci patch for miiphy_register net: mii: Use spatch to update miiphy_register net: mii: Changes not made by spatch net: mii: Fix changes made by spatch net: mii: Clean up legacy glue that is not used
arch/m68k/include/asm/fec.h | 9 +- arch/mips/mach-au1x00/au1x00_eth.c | 27 ++++-- arch/powerpc/cpu/mpc8260/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc8xx/fec.c | 44 ++++++--- arch/powerpc/cpu/ppc4xx/miiphy.c | 11 +-- board/gdsys/405ep/io.c | 13 ++- board/gdsys/405ep/iocon.c | 27 +++++- board/gdsys/405ex/io64.c | 25 ++++- board/gdsys/mpc8308/hrcon.c | 27 +++++- board/gdsys/mpc8308/strider.c | 27 +++++- common/miiphyutil.c | 73 --------------- drivers/net/4xx_enet.c | 20 ++-- drivers/net/armada100_fec.c | 35 ++++--- drivers/net/at91_emac.c | 30 ++++-- drivers/net/bcm-sf2-eth-gmac.c | 18 ++-- drivers/net/bcm-sf2-eth.c | 12 ++- drivers/net/bcm-sf2-eth.h | 8 +- drivers/net/bfin_mac.c | 45 ++++++--- drivers/net/davinci_emac.c | 34 +++++-- drivers/net/eepro100.c | 36 +++++--- drivers/net/enc28j60.c | 28 ++++-- drivers/net/ep93xx_eth.c | 44 ++++++--- drivers/net/fsl_mcdmafec.c | 13 ++- drivers/net/ftmac110.c | 37 +++++--- drivers/net/lpc32xx_eth.c | 54 +++++------ drivers/net/macb.c | 32 +++++-- drivers/net/mcffec.c | 13 ++- drivers/net/mcfmii.c | 19 ++-- drivers/net/mpc512x_fec.c | 34 +++++-- drivers/net/mpc5xxx_fec.c | 34 +++++-- drivers/net/mvgbe.c | 35 +++++-- drivers/net/phy/miiphybb.c | 25 ++--- drivers/net/sh_eth.c | 12 ++- drivers/net/smc911x.c | 35 +++++-- drivers/qe/uec.c | 34 ++++--- include/common.h | 1 + include/miiphy.h | 20 +--- scripts/coccinelle/net/mdio_register.cocci | 142 +++++++++++++++++++++++++++++ 39 files changed, 787 insertions(+), 372 deletions(-) create mode 100644 scripts/coccinelle/net/mdio_register.cocci
We want people using errnos for errors instead of -1, so make it easy by always including the definition of all the errnos.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com ---
include/common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/common.h b/include/common.h index f9f4605..3feaae6 100644 --- a/include/common.h +++ b/include/common.h @@ -16,6 +16,7 @@ typedef volatile unsigned short vu_short; typedef volatile unsigned char vu_char;
#include <config.h> +#include <errno.h> #include <asm-offsets.h> #include <linux/bitops.h> #include <linux/types.h>
On Mon, Apr 4, 2016 at 5:07 PM, Joe Hershberger joe.hershberger@ni.com wrote:
Many Ethernet drivers still use the legacy miiphy API to register their mdio interface for access to the mdio commands.
This semantic patch will convert the drivers from the legacy adapter API to the more modern alloc/register API.
scripts/coccinelle/net/mdio_register.cocci | 142 +++++++++++++++++++++++++++++ 1 file changed, 142 insertions(+) create mode 100644 scripts/coccinelle/net/mdio_register.cocci
diff --git a/scripts/coccinelle/net/mdio_register.cocci b/scripts/coccinelle/net/mdio_register.cocci new file mode 100644 index 0000000..100f102 --- /dev/null +++ b/scripts/coccinelle/net/mdio_register.cocci @@ -0,0 +1,142 @@ +/// Use mdio_alloc and mdio_register instead of miiphy_register +/// +//# Stop using the oldest mii interface in drivers +// +// Confidence: High +// Copyright: (C) 2016 Joe Hershberger. GPLv2. +// Comments: +// Options: --include-headers --recursive-includes --local-includes -I include + +@ mii_reg @ +expression devname; +identifier readfunc, writefunc; +@@ + ++ int retval; +- miiphy_register(devname, readfunc, writefunc); ++ struct mii_dev *mdiodev = mdio_alloc(); ++ if (!mdiodev) return -ENOMEM; ++ strncpy(mdiodev->name, devname, MDIO_NAME_LEN); ++ mdiodev->read = readfunc; ++ mdiodev->write = writefunc; ++ ++ retval = mdio_register(mdiodev); ++ if (retval < 0) return retval; + +@ update_read_sig @ +identifier mii_reg.readfunc; +identifier name0, addr0, reg0, output; +type addrT, outputT; +@@ + +- readfunc ( +- const char *name0, +- addrT addr0, +- addrT reg0, +- outputT *output +- ) ++ readfunc ( ++ struct mii_dev *bus, ++ int addr0, ++ int devad, ++ int reg0 ++ ) + { + ... + } + +@ update_read_impl @ +identifier mii_reg.readfunc; +identifier update_read_sig.output; +type update_read_sig.outputT; +constant c; +identifier retvar; +expression E; +@@ + + readfunc (...) + { ++ outputT output = 0; + ... +( +- return 0; ++ return *output; +| + return c; +| +- return retvar; ++ if (retvar < 0) ++ return retvar; ++ return *output; +| +- return E; ++ int retval = E; ++ if (retval < 0) ++ return retval; ++ return *output; +) + } + +@ update_read_impl2 @ +identifier mii_reg.readfunc; +identifier update_read_sig.output; +@@ + + readfunc (...) + { + <... +( +- *output ++ output +| +- output ++ &output +) + ...> + } + +@ update_read_name @ +identifier mii_reg.readfunc; +identifier update_read_sig.name0; +@@ + readfunc (...) { + <... +- name0 ++ bus->name + ...> + } + +@ update_write_sig @ +identifier mii_reg.writefunc; +identifier name0, addr0, reg0, value0; +type addrT, valueT; +typedef u16; +@@ + +- writefunc ( +- const char *name0, +- addrT addr0, +- addrT reg0, +- valueT value0 +- ) ++ writefunc ( ++ struct mii_dev *bus, ++ int addr0, ++ int devad, ++ int reg0, ++ u16 value0 ++ ) + { + ... + } + +@ update_write_name @ +identifier mii_reg.writefunc; +identifier update_write_sig.name0; +@@ + writefunc (...) { + <... +- name0 ++ bus->name + ...> + }
Run scripts/coccinelle/net/mdio_register.cocci on the U-Boot code base.
arch/mips/mach-au1x00/au1x00_eth.c | 27 +++++++++++++++------- arch/powerpc/cpu/mpc8260/ether_fcc.c | 13 +++++++++-- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 13 +++++++++-- arch/powerpc/cpu/mpc8xx/fec.c | 38 +++++++++++++++++++----------- board/gdsys/405ep/io.c | 13 +++++++++-- board/gdsys/405ep/iocon.c | 27 ++++++++++++++++++---- board/gdsys/405ex/io64.c | 26 +++++++++++++++++---- board/gdsys/mpc8308/hrcon.c | 27 ++++++++++++++++++---- board/gdsys/mpc8308/strider.c | 27 ++++++++++++++++++---- drivers/net/4xx_enet.c | 13 +++++++++-- drivers/net/armada100_fec.c | 35 +++++++++++++++++++--------- drivers/net/at91_emac.c | 30 ++++++++++++++++-------- drivers/net/bfin_mac.c | 24 +++++++++++++++---- drivers/net/davinci_emac.c | 27 ++++++++++++++++++---- drivers/net/eepro100.c | 36 +++++++++++++++++++---------- drivers/net/enc28j60.c | 28 ++++++++++++++++------ drivers/net/ep93xx_eth.c | 45 +++++++++++++++++++++++++----------- drivers/net/fsl_mcdmafec.c | 13 +++++++++-- drivers/net/ftmac110.c | 37 ++++++++++++++++++++--------- drivers/net/lpc32xx_eth.c | 31 ++++++++++++++++++------- drivers/net/macb.c | 32 +++++++++++++++++-------- drivers/net/mcffec.c | 13 +++++++++-- drivers/net/mpc512x_fec.c | 34 ++++++++++++++++++++------- drivers/net/mpc5xxx_fec.c | 34 ++++++++++++++++++++------- drivers/net/mvgbe.c | 35 ++++++++++++++++++++-------- drivers/net/sh_eth.c | 12 +++++++++- drivers/net/smc911x.c | 33 ++++++++++++++++++++------ drivers/qe/uec.c | 34 ++++++++++++++++++--------- 28 files changed, 572 insertions(+), 185 deletions(-)
diff --git a/arch/mips/mach-au1x00/au1x00_eth.c b/arch/mips/mach-au1x00/au1x00_eth.c index 9216860..1e823bd 100644 --- a/arch/mips/mach-au1x00/au1x00_eth.c +++ b/arch/mips/mach-au1x00/au1x00_eth.c @@ -73,9 +73,10 @@ mac_fifo_t mac_fifo[NO_OF_FIFOS]; #define MAX_WAIT 1000
#if defined(CONFIG_CMD_MII) -int au1x00_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short * value) +int au1x00_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg + ) { + unsigned short value = 0; volatile u32 *mii_control_reg = (volatile u32*)(ETH0_BASE+MAC_MII_CNTRL); volatile u32 *mii_data_reg = (volatile u32*)(ETH0_BASE+MAC_MII_DATA); u32 mii_control; @@ -102,12 +103,13 @@ int au1x00_miiphy_read(const char *devname, unsigned char addr, return -1; } } - *value = *mii_data_reg; - return 0; + value = *mii_data_reg; + return value; }
-int au1x00_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int au1x00_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value + ) { volatile u32 *mii_control_reg = (volatile u32*)(ETH0_BASE+MAC_MII_CNTRL); volatile u32 *mii_data_reg = (volatile u32*)(ETH0_BASE+MAC_MII_DATA); @@ -290,8 +292,17 @@ int au1x00_enet_initialize(bd_t *bis){ eth_register(dev);
#if defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - au1x00_miiphy_read, au1x00_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = au1x00_miiphy_read; + mdiodev->write = au1x00_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 1; diff --git a/arch/powerpc/cpu/mpc8260/ether_fcc.c b/arch/powerpc/cpu/mpc8260/ether_fcc.c index 9bb395e..81abca6 100644 --- a/arch/powerpc/cpu/mpc8260/ether_fcc.c +++ b/arch/powerpc/cpu/mpc8260/ether_fcc.c @@ -379,8 +379,17 @@ int fec_initialize(bd_t *bis)
#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ && defined(CONFIG_BITBANGMII) - miiphy_register(dev->name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif }
diff --git a/arch/powerpc/cpu/mpc85xx/ether_fcc.c b/arch/powerpc/cpu/mpc85xx/ether_fcc.c index 14358ae..ac729d7 100644 --- a/arch/powerpc/cpu/mpc85xx/ether_fcc.c +++ b/arch/powerpc/cpu/mpc85xx/ether_fcc.c @@ -441,8 +441,17 @@ int fec_initialize(bd_t *bis)
diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index ea4ab3a..b2cac82 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -47,10 +47,11 @@ DECLARE_GLOBAL_DATA_PTR; static int mii_discover_phy(struct eth_device *dev); #endif
-int fec8xx_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -int fec8xx_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int fec8xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg + ); +int fec8xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value + );
static struct ether_fcc_info_s { @@ -170,8 +171,17 @@ int fec_initialize(bd_t *bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - fec8xx_miiphy_read, fec8xx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = fec8xx_miiphy_read; + mdiodev->write = fec8xx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif } return 1; @@ -894,9 +904,10 @@ void mii_init (void) * Otherwise they hang in mii_send() !!! Sorry! *****************************************************************************/
-int fec8xx_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int fec8xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg + ) { + unsigned short value = 0; short rdreg; /* register working value */
#ifdef MII_DEBUG @@ -904,15 +915,16 @@ int fec8xx_miiphy_read(const char *devname, unsigned char addr, #endif rdreg = mii_send(mk_mii_read(addr, reg));
- *value = rdreg; + value = rdreg; #ifdef MII_DEBUG - printf ("0x%04x\n", *value); + printf ("0x%04x\n", value); #endif - return 0; + return value; }
-int fec8xx_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int fec8xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value + ) { #ifdef MII_DEBUG printf ("miiphy_write(0x%x) @ 0x%x = ", reg, addr); diff --git a/board/gdsys/405ep/io.c b/board/gdsys/405ep/io.c index 03d796c..81b4965 100644 --- a/board/gdsys/405ep/io.c +++ b/board/gdsys/405ep/io.c @@ -172,8 +172,17 @@ int last_stage_init(void)
print_fpga_info();
- miiphy_register(CONFIG_SYS_GBIT_MII_BUSNAME, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII_BUSNAME, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
for (k = 0; k < 32; ++k) configure_gbit_phy(k); diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index 7484624..7db0e29 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -405,8 +405,17 @@ int last_stage_init(void) }
if (!legacy && (feature_carrier_speed == CARRIER_SPEED_1G)) { - miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, - bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[0].name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { if ((mux_ch == 1) && !ch0_rgmii2_present) continue; @@ -437,8 +446,18 @@ int last_stage_init(void) print_fpga_info(k, false); osd_probe(k); if (feature_carrier_speed == CARRIER_SPEED_1G) { - miiphy_register(bb_miiphy_buses[k].name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[k].name, + MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; setup_88e1518(bb_miiphy_buses[k].name, 0); } } diff --git a/board/gdsys/405ex/io64.c b/board/gdsys/405ex/io64.c index 3a075c4..6a83788 100644 --- a/board/gdsys/405ex/io64.c +++ b/board/gdsys/405ex/io64.c @@ -246,8 +246,17 @@ int last_stage_init(void) /* setup Gbit PHYs */ puts("TRANS: "); puts(str_phys); - miiphy_register(CONFIG_SYS_GBIT_MII_BUSNAME, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII_BUSNAME, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
for (k = 0; k < 32; ++k) { configure_gbit_phy(CONFIG_SYS_GBIT_MII_BUSNAME, k); @@ -255,8 +264,17 @@ int last_stage_init(void) putc(slash[k % 8]); }
- miiphy_register(CONFIG_SYS_GBIT_MII1_BUSNAME, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII1_BUSNAME, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
for (k = 0; k < 32; ++k) { configure_gbit_phy(CONFIG_SYS_GBIT_MII1_BUSNAME, k); diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index 880b638..f55893f 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -162,8 +162,17 @@ int last_stage_init(void) }
if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, - bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[0].name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { if ((mux_ch == 1) && !ch0_rgmii2_present) continue; @@ -199,8 +208,18 @@ int last_stage_init(void) osd_probe(k + 4); #endif if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[k].name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[k].name, + MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; setup_88e1514(bb_miiphy_buses[k].name, 0); } } diff --git a/board/gdsys/mpc8308/strider.c b/board/gdsys/mpc8308/strider.c index eee582b..3d11af7 100644 --- a/board/gdsys/mpc8308/strider.c +++ b/board/gdsys/mpc8308/strider.c @@ -175,8 +175,17 @@ int last_stage_init(void) }
if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, - bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[0].name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { if ((mux_ch == 1) && !ch0_sgmii2_present) continue; @@ -233,8 +242,18 @@ int last_stage_init(void) dp501_probe(k, false); #endif if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[k].name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[k].name, + MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; setup_88e1514(bb_miiphy_buses[k].name, 0); } } diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index 3c30f42..6fe8ba6 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -2015,8 +2015,17 @@ int ppc_4xx_eth_initialize (bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - emac4xx_miiphy_read, emac4xx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = emac4xx_miiphy_read; + mdiodev->write = emac4xx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
if (0 == virgin) { diff --git a/drivers/net/armada100_fec.c b/drivers/net/armada100_fec.c index e6a6252..801d0bc 100644 --- a/drivers/net/armada100_fec.c +++ b/drivers/net/armada100_fec.c @@ -57,18 +57,20 @@ static int armdfec_phy_timeout(u32 *reg, u32 flag, int cond) return !timeout; }
-static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, - u16 *value) +static int smi_reg_read(struct mii_dev *bus, int phy_addr, int devad, + int phy_reg + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 value = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct armdfec_device *darmdfec = to_darmdfec(dev); struct armdfec_reg *regs = darmdfec->regs; u32 val;
if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { val = readl(®s->phyadr); - *value = val & 0x1f; - return 0; + value = val & 0x1f; + return value; }
/* check parameters */ @@ -99,15 +101,16 @@ static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, return -1; } val = readl(®s->smi); - *value = val & 0xffff; + value = val & 0xffff;
-static int smi_reg_write(const char *devname, - u8 phy_addr, u8 phy_reg, u16 value) +static int smi_reg_write(struct mii_dev *bus, int phy_addr, int devad, + int phy_reg, u16 value + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct armdfec_device *darmdfec = to_darmdfec(dev); struct armdfec_reg *regs = darmdfec->regs;
@@ -711,7 +714,17 @@ int armada100_fec_register(unsigned long base_addr) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, smi_reg_read, smi_reg_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = smi_reg_read; + mdiodev->write = smi_reg_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif return 0;
diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index 9151600..d2b4b22 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -159,23 +159,25 @@ at91_emac_t *get_emacbase_by_name(const char *devname) return (at91_emac_t *) netdev->iobase; }
-int at91emac_mii_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int at91emac_mii_read(struct mii_dev *bus, int addr, int devad, int reg + ) { + unsigned short value = 0; at91_emac_t *emac;
- emac = get_emacbase_by_name(devname); - at91emac_read(emac , addr, reg, value); - return 0; + emac = get_emacbase_by_name(bus->name); + at91emac_read(emac , addr, reg, &value); + return value; }
-int at91emac_mii_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int at91emac_mii_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value + ) { at91_emac_t *emac;
- emac = get_emacbase_by_name(devname); + emac = get_emacbase_by_name(bus->name); at91emac_write(emac, addr, reg, value); return 0; } @@ -502,7 +504,17 @@ int at91emac_register(bd_t *bis, unsigned long iobase) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, at91emac_mii_read, at91emac_mii_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = at91emac_mii_read; + mdiodev->write = at91emac_mii_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif return 1; } diff --git a/drivers/net/bfin_mac.c b/drivers/net/bfin_mac.c index 61cb1b0..26b19d5 100644 --- a/drivers/net/bfin_mac.c +++ b/drivers/net/bfin_mac.c @@ -72,18 +72,22 @@ static int bfin_miiphy_wait(void) return 0; }
-static int bfin_miiphy_read(const char *devname, uchar addr, uchar reg, ushort *val) +static int bfin_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg + ) { + ushort val = 0; if (bfin_miiphy_wait()) return 1; bfin_write_EMAC_STAADD(SET_PHYAD(addr) | SET_REGAD(reg) | STABUSY); if (bfin_miiphy_wait()) return 1; - *val = bfin_read_EMAC_STADAT(); - return 0; + val = bfin_read_EMAC_STADAT(); + return val; }
-static int bfin_miiphy_write(const char *devname, uchar addr, uchar reg, ushort val) +static int bfin_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 val + ) { if (bfin_miiphy_wait()) return 1; @@ -113,7 +117,17 @@ int bfin_EMAC_initialize(bd_t *bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, bfin_miiphy_read, bfin_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = bfin_miiphy_read; + mdiodev->write = bfin_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 0; diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index b030498..127f53c 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -390,12 +390,20 @@ static int gen_auto_negotiate(int phy_addr)
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -static int davinci_mii_phy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value) +static int davinci_mii_phy_read(struct mii_dev *bus, int addr, int devad, + int reg + ) { - return(davinci_eth_phy_read(addr, reg, value) ? 0 : 1); + unsigned short value = 0; + int retval = (davinci_eth_phy_read(addr, reg, &value) ? 0 : 1); + if (retval < 0) + return retval; + return value; }
-static int davinci_mii_phy_write(const char *devname, unsigned char addr, unsigned char reg, unsigned short value) +static int davinci_mii_phy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value + ) { return(davinci_eth_phy_write(addr, reg, value) ? 0 : 1); } @@ -883,8 +891,17 @@ int davinci_emac_initialize(void)
debug("Ethernet PHY: %s\n", phy[i].name);
- miiphy_register(phy[i].name, davinci_mii_phy_read, - davinci_mii_phy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, phy[i].name, MDIO_NAME_LEN); + mdiodev->read = davinci_mii_phy_read; + mdiodev->write = davinci_mii_phy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; }
#if defined(CONFIG_DRIVER_TI_EMAC_USE_RMII) && \ diff --git a/drivers/net/eepro100.c b/drivers/net/eepro100.c index d4a6386..874d2e8 100644 --- a/drivers/net/eepro100.c +++ b/drivers/net/eepro100.c @@ -334,34 +334,37 @@ static struct eth_device* verify_phyaddr (const char *devname, return dev; }
-static int eepro100_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +static int eepro100_miiphy_read(struct mii_dev *bus, int addr, int devad, + int reg + ) { + unsigned short value = 0; struct eth_device *dev;
- dev = verify_phyaddr(devname, addr); + dev = verify_phyaddr(bus->name, addr); if (dev == NULL) return -1;
- if (get_phyreg(dev, addr, reg, value) != 0) { - printf("%s: mii read timeout!\n", devname); + if (get_phyreg(dev, addr, reg, &value) != 0) { + printf("%s: mii read timeout!\n", bus->name); return -1; }
-static int eepro100_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +static int eepro100_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value + ) { struct eth_device *dev;
if (set_phyreg(dev, addr, reg, value) != 0) { - printf("%s: mii write timeout!\n", devname); + printf("%s: mii write timeout!\n", bus->name); return -1; }
@@ -451,8 +454,17 @@ int eepro100_initialize (bd_t * bis)
#if defined (CONFIG_MII) || defined(CONFIG_CMD_MII) /* register mii command access routines */ - miiphy_register(dev->name, - eepro100_miiphy_read, eepro100_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = eepro100_miiphy_read; + mdiodev->write = eepro100_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
card_number++; diff --git a/drivers/net/enc28j60.c b/drivers/net/enc28j60.c index 59ea11c..3a6afcf 100644 --- a/drivers/net/enc28j60.c +++ b/drivers/net/enc28j60.c @@ -742,9 +742,11 @@ static int enc_initcheck(enc_dev_t *enc, const enum enc_initstate requiredstate) * * This function is registered with miiphy_register(). */ -int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) +int enc_miiphy_read(struct mii_dev *bus, int phy_adr, int devad, int reg + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 value = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); enc_dev_t *enc;
if (!dev || phy_adr != 0) @@ -757,9 +759,9 @@ int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) enc_release_bus(enc); return -1; } - *value = enc_phy_read(enc, reg); + value = enc_phy_read(enc, reg); enc_release_bus(enc); - return 0; + return value; }
/* @@ -767,9 +769,11 @@ int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) * * This function is registered with miiphy_register(). */ -int enc_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) +int enc_miiphy_write(struct mii_dev *bus, int phy_adr, int devad, int reg, + u16 value + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); enc_dev_t *enc;
if (!dev || phy_adr != 0) @@ -958,7 +962,17 @@ int enc28j60_initialize(unsigned int bus, unsigned int cs, sprintf(dev->name, "enc%i.%i", bus, cs); eth_register(dev); #if defined(CONFIG_CMD_MII) - miiphy_register(dev->name, enc_miiphy_read, enc_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = enc_miiphy_read; + mdiodev->write = enc_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif return 0; } diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c index a3721c5..592f565 100644 --- a/drivers/net/ep93xx_eth.c +++ b/drivers/net/ep93xx_eth.c @@ -30,10 +30,12 @@ #define GET_REGS(eth_dev) (GET_PRIV(eth_dev)->regs)
/* ep93xx_miiphy ops forward declarations */ -static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short * const value); -static int ep93xx_miiphy_write(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short const value); +static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, + int reg + ); +static int ep93xx_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value + );
#if defined(EP93XX_MAC_DEBUG) /** @@ -421,7 +423,17 @@ eth_send_out: #if defined(CONFIG_MII) int ep93xx_miiphy_initialize(bd_t * const bd) { - miiphy_register("ep93xx_eth0", ep93xx_miiphy_read, ep93xx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, "ep93xx_eth0", MDIO_NAME_LEN); + mdiodev->read = ep93xx_miiphy_read; + mdiodev->write = ep93xx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; return 0; } #endif @@ -542,9 +554,11 @@ eth_init_done: /** * Read a 16-bit value from an MII register. */ -static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short * const value) +static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, + int reg + ) { + unsigned short value = 0; struct mac_regs *mac = (struct mac_regs *)MAC_BASE; int ret = -1; uint32_t self_ctl; @@ -552,10 +566,10 @@ static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, debug("+ep93xx_miiphy_read");
/* Parameter checks */ - BUG_ON(dev == NULL); + BUG_ON(bus->name == NULL); BUG_ON(addr > MII_ADDRESS_MAX); BUG_ON(reg > MII_REGISTER_MAX); - BUG_ON(value == NULL); + BUG_ON(&value == NULL);
/* * Save the current SelfCTL register value. Set MAC to suppress @@ -579,7 +593,7 @@ static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, while (readl(&mac->miists) & MIISTS_BUSY) ; /* noop */
- *value = (unsigned short)readl(&mac->miidata); + value = (unsigned short)readl(&mac->miidata);
/* Restore the saved SelfCTL value and return. */ writel(self_ctl, &mac->selfctl); @@ -588,14 +602,17 @@ static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, /* Fall through */
debug("-ep93xx_miiphy_read"); - return ret; + if (ret < 0) + return ret; + return value; }
/** * Write a 16-bit value to an MII register. */ -static int ep93xx_miiphy_write(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short const value) +static int ep93xx_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value + ) { struct mac_regs *mac = (struct mac_regs *)MAC_BASE; int ret = -1; @@ -604,7 +621,7 @@ static int ep93xx_miiphy_write(const char * const dev, unsigned char const addr, debug("+ep93xx_miiphy_write");
diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index 792534b..15a3ce0 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -556,8 +556,17 @@ int mcdmafec_initialize(bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - mcffec_miiphy_read, mcffec_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = mcffec_miiphy_read; + mdiodev->write = mcffec_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
if (i > 0) diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index 4f17015..706451d 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -364,32 +364,37 @@ static int ftmac110_recv(struct eth_device *dev)
-static int ftmac110_mdio_read( - const char *devname, uint8_t addr, uint8_t reg, uint16_t *value) +static int ftmac110_mdio_read(struct mii_dev *bus, int addr, int devad, + int reg + ) { + uint16_t value = 0; int ret = 0; struct eth_device *dev;
- dev = eth_get_dev_by_name(devname); + dev = eth_get_dev_by_name(bus->name); if (dev == NULL) { - printf("%s: no such device\n", devname); + printf("%s: no such device\n", bus->name); ret = -1; } else { - *value = mdio_read(dev, addr, reg); + value = mdio_read(dev, addr, reg); }
-static int ftmac110_mdio_write( - const char *devname, uint8_t addr, uint8_t reg, uint16_t value) +static int ftmac110_mdio_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value + ) { int ret = 0; struct eth_device *dev;
- dev = eth_get_dev_by_name(devname); + dev = eth_get_dev_by_name(bus->name); if (dev == NULL) { - printf("%s: no such device\n", devname); + printf("%s: no such device\n", bus->name); ret = -1; } else { mdio_write(dev, addr, reg, value); @@ -468,7 +473,17 @@ int ftmac110_initialize(bd_t *bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, ftmac110_mdio_read, ftmac110_mdio_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = ftmac110_mdio_read; + mdiodev->write = ftmac110_mdio_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
card_nr++; diff --git a/drivers/net/lpc32xx_eth.c b/drivers/net/lpc32xx_eth.c index 6cc273c..6bdfe5c 100644 --- a/drivers/net/lpc32xx_eth.c +++ b/drivers/net/lpc32xx_eth.c @@ -226,9 +226,12 @@ DECLARE_GLOBAL_DATA_PTR; * * Returns 16bit phy register value, or 0xffff on error */ -static int mii_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 *data) +static int mii_reg_read(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 data = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct lpc32xx_eth_device *dlpc32xx_eth = to_lpc32xx_eth(dev); struct lpc32xx_eth_registers *regs = dlpc32xx_eth->regs; u32 mind_reg; @@ -270,12 +273,12 @@ static int mii_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 *data) return -EFAULT; }
- *data = (u16) readl(®s->mrdd); + data = (u16) readl(®s->mrdd);
debug("%s:(adr %d, off %d) => %04x\n", __func__, phy_adr, - reg_ofs, *data); + reg_ofs, data);
- return 0; + return data; }
/* @@ -284,9 +287,11 @@ static int mii_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 *data) * Returns 0 if write succeed, -EINVAL on bad parameters * -ETIME on timeout */ -static int mii_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) +static int mii_reg_write(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs, u16 data + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct lpc32xx_eth_device *dlpc32xx_eth = to_lpc32xx_eth(dev); struct lpc32xx_eth_registers *regs = dlpc32xx_eth->regs; u32 mind_reg; @@ -645,7 +650,17 @@ int lpc32xx_eth_initialize(bd_t *bis) #if defined(CONFIG_PHYLIB) lpc32xx_eth_phylib_init(dev, CONFIG_PHY_ADDR); #elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, mii_reg_read, mii_reg_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = mii_reg_read; + mdiodev->write = mii_reg_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 0; diff --git a/drivers/net/macb.c b/drivers/net/macb.c index be0659a..98f4f8e 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -190,29 +190,33 @@ void __weak arch_get_mdio_control(const char *name)
#if defined(CONFIG_CMD_MII) || defined(CONFIG_PHYLIB)
-int macb_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) +int macb_miiphy_read(struct mii_dev *bus, int phy_adr, int devad, int reg + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 value = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct macb_device *macb = to_macb(dev);
if (macb->phy_addr != phy_adr) return -1;
- arch_get_mdio_control(devname); - *value = macb_mdio_read(macb, reg); + arch_get_mdio_control(bus->name); + value = macb_mdio_read(macb, reg);
-int macb_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) +int macb_miiphy_write(struct mii_dev *bus, int phy_adr, int devad, int reg, + u16 value + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct macb_device *macb = to_macb(dev);
- arch_get_mdio_control(devname); + arch_get_mdio_control(bus->name); macb_mdio_write(macb, reg, value);
return 0; @@ -795,7 +799,17 @@ int macb_eth_initialize(int id, void *regs, unsigned int phy_addr) eth_register(netdev);
#if defined(CONFIG_CMD_MII) || defined(CONFIG_PHYLIB) - miiphy_register(netdev->name, macb_miiphy_read, macb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, netdev->name, MDIO_NAME_LEN); + mdiodev->read = macb_miiphy_read; + mdiodev->write = macb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; macb->bus = miiphy_get_dev_by_name(netdev->name); #endif return 0; diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index fd73099..e1b06b2 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -595,8 +595,17 @@ int mcffec_initialize(bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - mcffec_miiphy_read, mcffec_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = mcffec_miiphy_read; + mdiodev->write = mcffec_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif if (i > 0) fec_info[i - 1].next = &fec_info[i]; diff --git a/drivers/net/mpc512x_fec.c b/drivers/net/mpc512x_fec.c index e850672..efcae99 100644 --- a/drivers/net/mpc512x_fec.c +++ b/drivers/net/mpc512x_fec.c @@ -22,8 +22,12 @@ DECLARE_GLOBAL_DATA_PTR; #error "CONFIG_MII has to be defined!" #endif
-int fec512x_miiphy_read(const char *devname, u8 phyAddr, u8 regAddr, u16 * retVal); -int fec512x_miiphy_write(const char *devname, u8 phyAddr, u8 regAddr, u16 data); +int fec512x_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr + ); +int fec512x_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data + ); int mpc512x_fec_init_phy(struct eth_device *dev, bd_t * bis);
static uchar rx_buff[FEC_BUFFER_SIZE]; @@ -639,8 +643,17 @@ int mpc512x_fec_initialize (bd_t * bis) eth_register (dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register (dev->name, - fec512x_miiphy_read, fec512x_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = fec512x_miiphy_read; + mdiodev->write = fec512x_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
/* Clean up space FEC's MIB and FIFO RAM ...*/ @@ -670,8 +683,11 @@ int mpc512x_fec_initialize (bd_t * bis)
/* MII-interface related functions */ /********************************************************************/ -int fec512x_miiphy_read(const char *devname, u8 phyAddr, u8 regAddr, u16 *retVal) +int fec512x_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr + ) { + u16 retVal = 0; volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; volatile fec512x_t *eth = &im->fec; u32 reg; /* convenient holder for the PHY register */ @@ -711,13 +727,15 @@ int fec512x_miiphy_read(const char *devname, u8 phyAddr, u8 regAddr, u16 *retVal /* * it's now safe to read the PHY's register */ - *retVal = (u16) in_be32(ð->mii_data); + retVal = (u16) in_be32(ð->mii_data);
- return 0; + return retVal; }
/********************************************************************/ -int fec512x_miiphy_write(const char *devname, u8 phyAddr, u8 regAddr, u16 data) +int fec512x_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data + ) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; volatile fec512x_t *eth = &im->fec; diff --git a/drivers/net/mpc5xxx_fec.c b/drivers/net/mpc5xxx_fec.c index e13b4cf..9578cfd 100644 --- a/drivers/net/mpc5xxx_fec.c +++ b/drivers/net/mpc5xxx_fec.c @@ -35,8 +35,12 @@ typedef struct { uint8 head[16]; /* MAC header(6 + 6 + 2) + 2(aligned) */ } NBUF;
-int fec5xxx_miiphy_read(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 *retVal); -int fec5xxx_miiphy_write(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 data); +int fec5xxx_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr + ); +int fec5xxx_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data + );
static int mpc5xxx_fec_init_phy(struct eth_device *dev, bd_t * bis);
@@ -917,8 +921,17 @@ int mpc5xxx_fec_initialize(bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register (dev->name, - fec5xxx_miiphy_read, fec5xxx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = fec5xxx_miiphy_read; + mdiodev->write = fec5xxx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
/* @@ -941,8 +954,11 @@ int mpc5xxx_fec_initialize(bd_t * bis)
/* MII-interface related functions */ /********************************************************************/ -int fec5xxx_miiphy_read(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 * retVal) +int fec5xxx_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr + ) { + uint16 retVal = 0; ethernet_regs *eth = (ethernet_regs *)MPC5XXX_FEC; uint32 reg; /* convenient holder for the PHY register */ uint32 phy; /* convenient holder for the PHY */ @@ -977,13 +993,15 @@ int fec5xxx_miiphy_read(const char *devname, uint8 phyAddr, uint8 regAddr, uint1 /* * it's now safe to read the PHY's register */ - *retVal = (uint16) eth->mii_data; + retVal = (uint16) eth->mii_data;
/********************************************************************/ -int fec5xxx_miiphy_write(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 data) +int fec5xxx_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data + ) { ethernet_regs *eth = (ethernet_regs *)MPC5XXX_FEC; uint32 reg; /* convenient holder for the PHY register */ diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index b16be92..92db634 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -48,9 +48,12 @@ DECLARE_GLOBAL_DATA_PTR; * * Returns 16bit phy register value, or 0xffff on error */ -static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) +static int smi_reg_read(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 data = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; u32 smi_reg; @@ -60,8 +63,8 @@ static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) if (phy_adr == MV_PHY_ADR_REQUEST && reg_ofs == MV_PHY_ADR_REQUEST) { /* */ - *data = (u16) (MVGBE_REG_RD(regs->phyadr) & PHYADR_MASK); - return 0; + data = (u16) (MVGBE_REG_RD(regs->phyadr) & PHYADR_MASK); + return data; } /* check parameters */ if (phy_adr > PHYADR_MASK) { @@ -111,12 +114,12 @@ static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) for (timeout = 0; timeout < MVGBE_PHY_SMI_TIMEOUT; timeout++) ;
- *data = (u16) (MVGBE_REG_RD(MVGBE_SMI_REG) & MVGBE_PHY_SMI_DATA_MASK); + data = (u16) (MVGBE_REG_RD(MVGBE_SMI_REG) & MVGBE_PHY_SMI_DATA_MASK);
debug("%s:(adr %d, off %d) value= %04x\n", __func__, phy_adr, reg_ofs, - *data); + data);
/* @@ -125,9 +128,11 @@ static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) * Returns 0 if write succeed, -EINVAL on bad parameters * -ETIME on timeout */ -static int smi_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) +static int smi_reg_write(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs, u16 data + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; u32 smi_reg; @@ -785,7 +790,17 @@ error1: #if defined(CONFIG_PHYLIB) mvgbe_phylib_init(dev, PHY_BASE_ADR + devnum); #elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, smi_reg_read, smi_reg_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = smi_reg_read; + mdiodev->write = smi_reg_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST, MV_PHY_ADR_REQUEST, PHY_BASE_ADR + devnum); diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 443a4da..f6eed6d 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -566,7 +566,17 @@ int sh_eth_initialize(bd_t *bd) eth_register(dev);
bb_miiphy_buses[0].priv = eth; - miiphy_register(dev->name, bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
if (!eth_getenv_enetaddr("ethaddr", dev->enetaddr)) puts("Please set MAC address\n"); diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index c85a178..f6f8e58 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -219,17 +219,26 @@ static int smc911x_rx(struct eth_device *dev)
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* wrapper for smc911x_eth_phy_read */ -static int smc911x_miiphy_read(const char *devname, u8 phy, u8 reg, u16 *val) +static int smc911x_miiphy_read(struct mii_dev *bus, int phy, int devad, + int reg + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); - if (dev) - return smc911x_eth_phy_read(dev, phy, reg, val); + u16 val = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); + if (dev) { + int retval = smc911x_eth_phy_read(dev, phy, reg, &val); + if (retval < 0) + return retval; + return val; + } return -1; } /* wrapper for smc911x_eth_phy_write */ -static int smc911x_miiphy_write(const char *devname, u8 phy, u8 reg, u16 val) +static int smc911x_miiphy_write(struct mii_dev *bus, int phy, int devad, + int reg, u16 val + ) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); if (dev) return smc911x_eth_phy_write(dev, phy, reg, val); return -1; @@ -276,7 +285,17 @@ int smc911x_initialize(u8 dev_num, int base_addr) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, smc911x_miiphy_read, smc911x_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = smc911x_miiphy_read; + mdiodev->write = smc911x_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 1; diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 40cccc2..1295f99 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -623,20 +623,21 @@ static int uec_miiphy_find_dev_by_name(const char *devname) * Returns: * 0 on success */ -static int uec_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +static int uec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg + ) { + unsigned short value = 0; int devindex = 0;
- if (devname == NULL || value == NULL) { + if (bus->name == NULL || &value == NULL) { debug("%s: NULL pointer given\n", __FUNCTION__); } else { - devindex = uec_miiphy_find_dev_by_name(devname); + devindex = uec_miiphy_find_dev_by_name(bus->name); if (devindex >= 0) { - *value = uec_read_phy_reg(devlist[devindex], addr, reg); + value = uec_read_phy_reg(devlist[devindex], addr, reg); } } - return 0; + return value; }
/* @@ -645,15 +646,16 @@ static int uec_miiphy_read(const char *devname, unsigned char addr, * Returns: * 0 on success */ -static int uec_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +static int uec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value + ) { int devindex = 0;
- if (devname == NULL) { + if (bus->name == NULL) { debug("%s: NULL pointer given\n", __FUNCTION__); } else { - devindex = uec_miiphy_find_dev_by_name(devname); + devindex = uec_miiphy_find_dev_by_name(bus->name); if (devindex >= 0) { uec_write_phy_reg(devlist[devindex], addr, reg, value); } @@ -1399,7 +1401,17 @@ int uec_initialize(bd_t *bis, uec_info_t *uec_info) }
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, uec_miiphy_read, uec_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = uec_miiphy_read; + mdiodev->write = uec_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 1;
Hi Joe,
Looks we need more manual nits fixes after running the scripts. See below.
nits: moving ) to the line above. Please fix this globally.
return value;
u16 value
int retval;
nits: adding one blank line to separate. Please fix this globally.
if (!mdiodev)
return -ENOMEM;
if (retval < 0)
return retval;
#endif
return 1;
[snip]
Otherwise, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
If the functions passed to the registration function are not in the same C file (extern) then spatch will not handle the dependent changes.
Make those changes manually.
arch/m68k/include/asm/fec.h | 9 +++++---- arch/powerpc/cpu/ppc4xx/miiphy.c | 11 ++++------- drivers/net/4xx_enet.c | 7 +++---- drivers/net/bcm-sf2-eth-gmac.c | 18 +++++++----------- drivers/net/bcm-sf2-eth.c | 12 +++++++++++- drivers/net/bcm-sf2-eth.h | 8 ++++---- drivers/net/mcfmii.c | 19 ++++++------------- drivers/net/phy/miiphybb.c | 25 ++++++++----------------- include/miiphy.h | 7 +++---- 9 files changed, 51 insertions(+), 65 deletions(-)
diff --git a/arch/m68k/include/asm/fec.h b/arch/m68k/include/asm/fec.h index 6856aac..2799293 100644 --- a/arch/m68k/include/asm/fec.h +++ b/arch/m68k/include/asm/fec.h @@ -15,6 +15,8 @@ #ifndef fec_h #define fec_h
+#include <phy.h> + /* Buffer descriptors used FEC. */ typedef struct cpm_buf_desc { @@ -341,10 +343,9 @@ int fecpin_setclear(struct eth_device *dev, int setclear); void __mii_init(void); uint mii_send(uint mii_cmd); int mii_discover_phy(struct eth_device *dev); -int mcffec_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -int mcffec_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int mcffec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg); +int mcffec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value); #endif
#endif /* fec_h */ diff --git a/arch/powerpc/cpu/ppc4xx/miiphy.c b/arch/powerpc/cpu/ppc4xx/miiphy.c index 10147de..f0fc098 100644 --- a/arch/powerpc/cpu/ppc4xx/miiphy.c +++ b/arch/powerpc/cpu/ppc4xx/miiphy.c @@ -318,8 +318,7 @@ static int emac_miiphy_command(u8 addr, u8 reg, int cmd, u16 value) return 0; }
-int emac4xx_miiphy_read (const char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) +int emac4xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { unsigned long sta_reg; unsigned long emac_reg; @@ -330,17 +329,15 @@ int emac4xx_miiphy_read (const char *devname, unsigned char addr, unsigned char return -1;
sta_reg = in_be32((void *)EMAC0_STACR + emac_reg); - *value = sta_reg >> 16; - - return 0; + return sta_reg >> 16; }
/***********************************************************/ /* write a phy reg and return the value with a rc */ /***********************************************************/
-int emac4xx_miiphy_write (const char *devname, unsigned char addr, unsigned char reg, - unsigned short value) +int emac4xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { return emac_miiphy_command(addr, reg, EMAC_STACR_WRITE, value); } diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index 6fe8ba6..a083024 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -283,10 +283,9 @@ static void mal_err (struct eth_device *dev, unsigned long isr, static void emac_err (struct eth_device *dev, unsigned long isr);
extern int phy_setup_aneg (char *devname, unsigned char addr); -extern int emac4xx_miiphy_read (const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -extern int emac4xx_miiphy_write (const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int emac4xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg); +int emac4xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value);
int board_emac_count(void);
diff --git a/drivers/net/bcm-sf2-eth-gmac.c b/drivers/net/bcm-sf2-eth-gmac.c index 977feec..f2853cf 100644 --- a/drivers/net/bcm-sf2-eth-gmac.c +++ b/drivers/net/bcm-sf2-eth-gmac.c @@ -596,12 +596,10 @@ bool gmac_mii_busywait(unsigned int timeout) return tmp & (1 << GMAC_MII_BUSY_SHIFT); }
-int gmac_miiphy_read(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short *value) +int gmac_miiphy_read(struct mii_dev *bus, int phyaddr, int devad, int reg) { uint32_t tmp = 0; - - (void)devname; + u16 value = 0;
/* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) { @@ -621,18 +619,16 @@ int gmac_miiphy_read(const char *devname, unsigned char phyaddr, return -1; }
- *value = readl(GMAC_MII_DATA_ADDR) & 0xffff; - debug("MII read data 0x%x\n", *value); - return 0; + value = readl(GMAC_MII_DATA_ADDR) & 0xffff; + debug("MII read data 0x%x\n", value); + return value; }
-int gmac_miiphy_write(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short value) +int gmac_miiphy_write(struct mii_dev *bus, int phyaddr, int devad, int reg, + u16 value) { uint32_t tmp = 0;
- (void)devname; - /* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) { error("%s: Prepare MII write: MII/MDIO busy\n", __func__); diff --git a/drivers/net/bcm-sf2-eth.c b/drivers/net/bcm-sf2-eth.c index eab4c1f..8f22492 100644 --- a/drivers/net/bcm-sf2-eth.c +++ b/drivers/net/bcm-sf2-eth.c @@ -244,7 +244,17 @@ int bcm_sf2_eth_register(bd_t *bis, u8 dev_num) eth_register(dev);
#ifdef CONFIG_CMD_MII - miiphy_register(dev->name, eth->miiphy_read, eth->miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = eth->miiphy_read; + mdiodev->write = eth->miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
/* Initialization */ diff --git a/drivers/net/bcm-sf2-eth.h b/drivers/net/bcm-sf2-eth.h index 49a5836..6104aff 100644 --- a/drivers/net/bcm-sf2-eth.h +++ b/drivers/net/bcm-sf2-eth.h @@ -54,10 +54,10 @@ struct eth_info { struct phy_device *port[BCM_ETH_MAX_PORT_NUM]; int port_num;
- int (*miiphy_read)(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short *value); - int (*miiphy_write)(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short value); + int (*miiphy_read)(struct mii_dev *bus, int phyaddr, int devad, + int reg); + int (*miiphy_write)(struct mii_dev *bus, int phyaddr, int devad, + int reg, u16 value);
int (*mac_init)(struct eth_device *dev); int (*enable_mac)(void); diff --git a/drivers/net/mcfmii.c b/drivers/net/mcfmii.c index 17a780c..103e365 100644 --- a/drivers/net/mcfmii.c +++ b/drivers/net/mcfmii.c @@ -277,8 +277,7 @@ void __mii_init(void) * Otherwise they hang in mii_send() !!! Sorry! */
-int mcffec_miiphy_read(const char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) +int mcffec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { short rdreg; /* register working value */
@@ -287,28 +286,22 @@ int mcffec_miiphy_read(const char *devname, unsigned char addr, unsigned char re #endif rdreg = mii_send(mk_mii_read(addr, reg));
- *value = rdreg; - #ifdef MII_DEBUG - printf("0x%04x\n", *value); + printf("0x%04x\n", rdreg); #endif
- return 0; + return rdreg; }
-int mcffec_miiphy_write(const char *devname, unsigned char addr, unsigned char reg, - unsigned short value) +int mcffec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { #ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); + printf("miiphy_write(0x%x) @ 0x%x = 0x%04x\n", reg, addr, value); #endif
mii_send(mk_mii_write(addr, reg, value));
-#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - return 0; }
diff --git a/drivers/net/phy/miiphybb.c b/drivers/net/phy/miiphybb.c index 5cda0b8..af676b9 100644 --- a/drivers/net/phy/miiphybb.c +++ b/drivers/net/phy/miiphybb.c @@ -230,24 +230,18 @@ static void miiphy_pre(struct bb_miiphy_bus *bus, char read, * Returns: * 0 on success */ -int bb_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int bb_miiphy_read(struct mii_dev *miidev, int addr, int devad, int reg) { short rdreg; /* register working value */ int v; int j; /* counter */ struct bb_miiphy_bus *bus;
- bus = bb_miiphy_getbus(devname); + bus = bb_miiphy_getbus(miidev->name); if (bus == NULL) { return -1; }
- if (value == NULL) { - puts("NULL value pointer\n"); - return -1; - } - miiphy_pre (bus, 1, addr, reg);
/* tri-state our MDIO I/O pin so we can read */ @@ -267,8 +261,7 @@ int bb_miiphy_read(const char *devname, unsigned char addr, bus->set_mdc(bus, 1); bus->delay(bus); } - /* There is no PHY, set value to 0xFFFF and return */ - *value = 0xFFFF; + /* There is no PHY, return */ return -1; }
@@ -294,13 +287,11 @@ int bb_miiphy_read(const char *devname, unsigned char addr, bus->set_mdc(bus, 1); bus->delay(bus);
- *value = rdreg; - #ifdef DEBUG - printf ("miiphy_read(0x%x) @ 0x%x = 0x%04x\n", reg, addr, *value); + printf("miiphy_read(0x%x) @ 0x%x = 0x%04x\n", reg, addr, rdreg); #endif
@@ -311,13 +302,13 @@ int bb_miiphy_read(const char *devname, unsigned char addr, * Returns: * 0 on success */ -int bb_miiphy_write (const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int bb_miiphy_write(struct mii_dev *miidev, int addr, int devad, int reg, + u16 value) { struct bb_miiphy_bus *bus; int j; /* counter */
- bus = bb_miiphy_getbus(devname); + bus = bb_miiphy_getbus(miidev->name); if (bus == NULL) { /* Bus not found! */ return -1; diff --git a/include/miiphy.h b/include/miiphy.h index af12274..8a55a13 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -86,10 +86,9 @@ extern struct bb_miiphy_bus bb_miiphy_buses[]; extern int bb_miiphy_buses_num;
void bb_miiphy_init(void); -int bb_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -int bb_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int bb_miiphy_read(struct mii_dev *miidev, int addr, int devad, int reg); +int bb_miiphy_write(struct mii_dev *miidev, int addr, int devad, int reg, + u16 value); #endif
/* phy seed setup */
Hi Joe,
For the 4xx related files:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Hi Joe,
But one nits below.
+#include <phy.h>
u16 value);
#endif
u16 value)
u16 value);
(void)devname;
u16 value = 0; /* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) {
return value;
u16 value)
{ uint32_t tmp = 0;
(void)devname;
int retval;
nits: should have a blank line here.
if (!mdiodev)
return -ENOMEM;
if (retval < 0)
return retval;
#endif
[snip]
Regards, Bin
Some of the changes were a bit too complex.
arch/powerpc/cpu/mpc8xx/fec.c | 6 ++++-- board/gdsys/405ex/io64.c | 3 +-- drivers/net/bfin_mac.c | 21 +++++++++++++++------ drivers/net/davinci_emac.c | 17 +++++++---------- drivers/net/ep93xx_eth.c | 1 - drivers/net/lpc32xx_eth.c | 23 ++--------------------- drivers/net/smc911x.c | 10 ++++------ drivers/qe/uec.c | 2 +- 8 files changed, 34 insertions(+), 49 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index b2cac82..ca373a8 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -6,10 +6,12 @@ */
#include <common.h> -#include <malloc.h> +#include <command.h> #include <commproc.h> +#include <malloc.h> #include <net.h> -#include <command.h> + +#include <phy.h>
diff --git a/board/gdsys/405ex/io64.c b/board/gdsys/405ex/io64.c index 6a83788..848cdde 100644 --- a/board/gdsys/405ex/io64.c +++ b/board/gdsys/405ex/io64.c @@ -264,8 +264,7 @@ int last_stage_init(void) putc(slash[k % 8]); }
- int retval; - struct mii_dev *mdiodev = mdio_alloc(); + mdiodev = mdio_alloc(); if (!mdiodev) return -ENOMEM; strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII1_BUSNAME, MDIO_NAME_LEN); diff --git a/drivers/net/bfin_mac.c b/drivers/net/bfin_mac.c index 26b19d5..1307c80 100644 --- a/drivers/net/bfin_mac.c +++ b/drivers/net/bfin_mac.c @@ -13,6 +13,7 @@ #include <command.h> #include <malloc.h> #include <miiphy.h> +#include <linux/mdio.h> #include <linux/mii.h>
#include <asm/blackfin.h> @@ -128,6 +129,8 @@ int bfin_EMAC_initialize(bd_t *bis) retval = mdio_register(mdiodev); if (retval < 0) return retval; + + dev->priv = mdiodev; #endif
return 0; @@ -236,8 +239,9 @@ static int bfin_EMAC_recv(struct eth_device *dev) static int bfin_miiphy_init(struct eth_device *dev, int *opmode) { const unsigned short pins[] = CONFIG_BFIN_MAC_PINS; - u16 phydat; + int phydat; size_t count; + struct mii_dev *mdiodev = dev->priv;
/* Enable PHY output */ bfin_write_VR_CTL(bfin_read_VR_CTL() | CLKBUFOE); @@ -250,12 +254,15 @@ static int bfin_miiphy_init(struct eth_device *dev, int *opmode) bfin_write_EMAC_SYSCTL(RXDWA | RXCKS | SET_MDCDIV(MDC_FREQ_TO_DIV(CONFIG_PHY_CLOCK_FREQ)));
/* turn on auto-negotiation and wait for link to come up */ - bfin_miiphy_write(dev->name, CONFIG_PHY_ADDR, MII_BMCR, BMCR_ANENABLE); + bfin_miiphy_write(mdiodev, CONFIG_PHY_ADDR, MDIO_DEVAD_NONE, MII_BMCR, + BMCR_ANENABLE); count = 0; while (1) { ++count; - if (bfin_miiphy_read(dev->name, CONFIG_PHY_ADDR, MII_BMSR, &phydat)) - return -1; + phydat = bfin_miiphy_read(mdiodev, CONFIG_PHY_ADDR, + MDIO_DEVAD_NONE, MII_BMSR); + if (phydat < 0) + return phydat; if (phydat & BMSR_LSTATUS) break; if (count > 30000) { @@ -266,8 +273,10 @@ static int bfin_miiphy_init(struct eth_device *dev, int *opmode) }
/* see what kind of link we have */ - if (bfin_miiphy_read(dev->name, CONFIG_PHY_ADDR, MII_LPA, &phydat)) - return -1; + phydat = bfin_miiphy_read(mdiodev, CONFIG_PHY_ADDR, MDIO_DEVAD_NONE, + MII_LPA); + if (phydat < 0) + return phydat; if (phydat & LPA_DUPLEX) *opmode = FDMODE; else diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index 127f53c..ca457b8 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -243,11 +243,10 @@ int davinci_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data)
if (tmp & MDIO_USERACCESS0_ACK) { *data = tmp & 0xffff; - return(1); + return 0; }
- *data = -1; - return(0); + return -EIO; }
/* Write to a PHY register via MDIO inteface. Blocks until operation is complete. */ @@ -268,7 +267,7 @@ int davinci_eth_phy_write(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t data) while (readl(&adap_mdio->USERACCESS0) & MDIO_USERACCESS0_GO) ;
/* PHY functions for a generic PHY */ @@ -391,21 +390,19 @@ static int gen_auto_negotiate(int phy_addr)
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) static int davinci_mii_phy_read(struct mii_dev *bus, int addr, int devad, - int reg - ) + int reg) { unsigned short value = 0; - int retval = (davinci_eth_phy_read(addr, reg, &value) ? 0 : 1); + int retval = davinci_eth_phy_read(addr, reg, &value); if (retval < 0) return retval; return value; }
static int davinci_mii_phy_write(struct mii_dev *bus, int addr, int devad, - int reg, u16 value - ) + int reg, u16 value) { - return(davinci_eth_phy_write(addr, reg, value) ? 0 : 1); + return davinci_eth_phy_write(addr, reg, value); } #endif
diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c index 592f565..8082cf7 100644 --- a/drivers/net/ep93xx_eth.c +++ b/drivers/net/ep93xx_eth.c @@ -569,7 +569,6 @@ static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, BUG_ON(bus->name == NULL); BUG_ON(addr > MII_ADDRESS_MAX); BUG_ON(reg > MII_REGISTER_MAX); - BUG_ON(&value == NULL);
/* * Save the current SelfCTL register value. Set MAC to suppress diff --git a/drivers/net/lpc32xx_eth.c b/drivers/net/lpc32xx_eth.c index 6bdfe5c..8db9886 100644 --- a/drivers/net/lpc32xx_eth.c +++ b/drivers/net/lpc32xx_eth.c @@ -338,25 +338,6 @@ static int mii_reg_write(struct mii_dev *bus, int phy_adr, int devad, } #endif
-#if defined(CONFIG_PHYLIB) -int lpc32xx_eth_phy_read(struct mii_dev *bus, int phy_addr, int dev_addr, - int reg_addr) -{ - u16 data; - int ret; - ret = mii_reg_read(bus->name, phy_addr, reg_addr, &data); - if (ret) - return ret; - return data; -} - -int lpc32xx_eth_phy_write(struct mii_dev *bus, int phy_addr, int dev_addr, - int reg_addr, u16 data) -{ - return mii_reg_write(bus->name, phy_addr, reg_addr, data); -} -#endif - /* * Provide default Ethernet buffers base address if target did not. * Locate buffers in SRAM at 0x00001000 to avoid cache issues and @@ -585,8 +566,8 @@ int lpc32xx_eth_phylib_init(struct eth_device *dev, int phyid) printf("mdio_alloc failed\n"); return -ENOMEM; } - bus->read = lpc32xx_eth_phy_read; - bus->write = lpc32xx_eth_phy_write; + bus->read = mii_reg_read; + bus->write = mii_reg_write; strcpy(bus->name, dev->name);
ret = mdio_register(bus); diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index f6f8e58..feae8c0 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -220,8 +220,7 @@ static int smc911x_rx(struct eth_device *dev) #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* wrapper for smc911x_eth_phy_read */ static int smc911x_miiphy_read(struct mii_dev *bus, int phy, int devad, - int reg - ) + int reg) { u16 val = 0; struct eth_device *dev = eth_get_dev_by_name(bus->name); @@ -231,17 +230,16 @@ static int smc911x_miiphy_read(struct mii_dev *bus, int phy, int devad, return retval; return val; } - return -1; + return -ENODEV; } /* wrapper for smc911x_eth_phy_write */ static int smc911x_miiphy_write(struct mii_dev *bus, int phy, int devad, - int reg, u16 val - ) + int reg, u16 val) { struct eth_device *dev = eth_get_dev_by_name(bus->name); if (dev) return smc911x_eth_phy_write(dev, phy, reg, val); - return -1; + return -ENODEV; } #endif
diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 1295f99..c2bec58 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -629,7 +629,7 @@ static int uec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg unsigned short value = 0; int devindex = 0;
- if (bus->name == NULL || &value == NULL) { + if (bus->name == NULL) { debug("%s: NULL pointer given\n", __FUNCTION__); } else { devindex = uec_miiphy_find_dev_by_name(bus->name);
On Mon, Apr 4, 2016 at 5:07 PM, Joe Hershberger joe.hershberger@ni.com wrote:
Signed-off-by: Joe Hershberger joe.hershberger@ni.com
The cleanup of the legacy mii registration API that's no longer used now that the drivers have been converted to use the (more) modern API.
common/miiphyutil.c | 73 ----------------------------------------------------- include/miiphy.h | 13 ---------- 2 files changed, 86 deletions(-)
diff --git a/common/miiphyutil.c b/common/miiphyutil.c index 7e41957..08aa854 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -65,79 +65,6 @@ void miiphy_init(void) current_mii = NULL; }
-static int legacy_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) -{ - unsigned short val; - int ret; - struct legacy_mii_dev *ldev = bus->priv; - - ret = ldev->read(bus->name, addr, reg, &val); - - return ret ? -1 : (int)val; -} - -static int legacy_miiphy_write(struct mii_dev *bus, int addr, int devad, - int reg, u16 val) -{ - struct legacy_mii_dev *ldev = bus->priv; - - return ldev->write(bus->name, addr, reg, val); -} - -/***************************************************************************** - * - * Register read and write MII access routines for the device <name>. - * This API is now deprecated. Please use mdio_alloc and mdio_register, instead. - */ -void miiphy_register(const char *name, - int (*read)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value), - int (*write)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value)) -{ - struct mii_dev *new_dev; - struct legacy_mii_dev *ldev; - - BUG_ON(strlen(name) >= MDIO_NAME_LEN); - - /* check if we have unique name */ - new_dev = miiphy_get_dev_by_name(name); - if (new_dev) { - printf("miiphy_register: non unique device name '%s'\n", name); - return; - } - - /* allocate memory */ - new_dev = mdio_alloc(); - ldev = malloc(sizeof(*ldev)); - - if (new_dev == NULL || ldev == NULL) { - printf("miiphy_register: cannot allocate memory for '%s'\n", - name); - free(ldev); - mdio_free(new_dev); - return; - } - - /* initalize mii_dev struct fields */ - new_dev->read = legacy_miiphy_read; - new_dev->write = legacy_miiphy_write; - strncpy(new_dev->name, name, MDIO_NAME_LEN); - new_dev->name[MDIO_NAME_LEN - 1] = 0; - ldev->read = read; - ldev->write = write; - new_dev->priv = ldev; - - debug("miiphy_register: added '%s', read=0x%08lx, write=0x%08lx\n", - new_dev->name, ldev->read, ldev->write); - - /* add it to the list */ - list_add_tail(&new_dev->link, &mii_devs); - - if (!current_mii) - current_mii = new_dev; -} - struct mii_dev *mdio_alloc(void) { struct mii_dev *bus; diff --git a/include/miiphy.h b/include/miiphy.h index 8a55a13..83141b4 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -21,13 +21,6 @@ #include <net.h> #include <phy.h>
-struct legacy_mii_dev { - int (*read)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); - int (*write)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); -}; - int miiphy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value); int miiphy_write(const char *devname, unsigned char addr, unsigned char reg, @@ -44,12 +37,6 @@ int miiphy_link(const char *devname, unsigned char addr);
void miiphy_init(void);
-void miiphy_register(const char *devname, - int (*read)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value), - int (*write)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value)); - int miiphy_set_current_dev(const char *devname); const char *miiphy_get_current_dev(void); struct mii_dev *mdio_get_current_dev(void);
Hi Joe,
On 4 April 2016 at 03:07, Joe Hershberger joe.hershberger@ni.com wrote:
This is an effort to migrate closer to the phylib approach so that a new DM approach can be developed from a single starting point. The more of this legacy code can be removed, the easier it will be to move forward.
Sounds good!
Joe Hershberger (6): common: Always include errno.h in common.h scripts: Add a cocci patch for miiphy_register net: mii: Use spatch to update miiphy_register net: mii: Changes not made by spatch net: mii: Fix changes made by spatch net: mii: Clean up legacy glue that is not used
arch/m68k/include/asm/fec.h | 9 +- arch/mips/mach-au1x00/au1x00_eth.c | 27 ++++-- arch/powerpc/cpu/mpc8260/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc8xx/fec.c | 44 ++++++--- arch/powerpc/cpu/ppc4xx/miiphy.c | 11 +-- board/gdsys/405ep/io.c | 13 ++- board/gdsys/405ep/iocon.c | 27 +++++- board/gdsys/405ex/io64.c | 25 ++++- board/gdsys/mpc8308/hrcon.c | 27 +++++- board/gdsys/mpc8308/strider.c | 27 +++++- common/miiphyutil.c | 73 --------------- drivers/net/4xx_enet.c | 20 ++-- drivers/net/armada100_fec.c | 35 ++++--- drivers/net/at91_emac.c | 30 ++++-- drivers/net/bcm-sf2-eth-gmac.c | 18 ++-- drivers/net/bcm-sf2-eth.c | 12 ++- drivers/net/bcm-sf2-eth.h | 8 +- drivers/net/bfin_mac.c | 45 ++++++--- drivers/net/davinci_emac.c | 34 +++++-- drivers/net/eepro100.c | 36 +++++--- drivers/net/enc28j60.c | 28 ++++-- drivers/net/ep93xx_eth.c | 44 ++++++--- drivers/net/fsl_mcdmafec.c | 13 ++- drivers/net/ftmac110.c | 37 +++++--- drivers/net/lpc32xx_eth.c | 54 +++++------ drivers/net/macb.c | 32 +++++-- drivers/net/mcffec.c | 13 ++- drivers/net/mcfmii.c | 19 ++-- drivers/net/mpc512x_fec.c | 34 +++++-- drivers/net/mpc5xxx_fec.c | 34 +++++-- drivers/net/mvgbe.c | 35 +++++-- drivers/net/phy/miiphybb.c | 25 ++--- drivers/net/sh_eth.c | 12 ++- drivers/net/smc911x.c | 35 +++++-- drivers/qe/uec.c | 34 ++++--- include/common.h | 1 + include/miiphy.h | 20 +--- scripts/coccinelle/net/mdio_register.cocci | 142 +++++++++++++++++++++++++++++ 39 files changed, 787 insertions(+), 372 deletions(-) create mode 100644 scripts/coccinelle/net/mdio_register.cocci
-- 1.7.11.5
This is an effort to migrate closer to the phylib approach so that a new DM approach can be developed from a single starting point. The more of this legacy code that can be removed, the easier it will be to move forward.
Changes in v2: - Added a blank line - Run against the current master which adds one more driver to convert (drivers/net/macb.c) - Use an updated spatch that does not put closing paren on the next line
Joe Hershberger (5): scripts: Add a cocci patch for miiphy_register net: mii: Use spatch to update miiphy_register net: mii: Changes not made by spatch net: mii: Fix changes made by spatch net: mii: Clean up legacy glue that is not used
arch/m68k/include/asm/fec.h | 9 +- arch/mips/mach-au1x00/au1x00_eth.c | 25 +++-- arch/powerpc/cpu/mpc8260/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc8xx/fec.c | 40 +++++--- arch/powerpc/cpu/ppc4xx/miiphy.c | 11 +-- board/gdsys/405ep/io.c | 13 ++- board/gdsys/405ep/iocon.c | 27 +++++- board/gdsys/405ex/io64.c | 25 ++++- board/gdsys/mpc8308/hrcon.c | 27 +++++- board/gdsys/mpc8308/strider.c | 27 +++++- common/miiphyutil.c | 73 --------------- drivers/net/4xx_enet.c | 20 ++-- drivers/net/armada100_fec.c | 33 ++++--- drivers/net/at91_emac.c | 28 ++++-- drivers/net/bcm-sf2-eth-gmac.c | 18 ++-- drivers/net/bcm-sf2-eth.c | 13 ++- drivers/net/bcm-sf2-eth.h | 8 +- drivers/net/bfin_mac.c | 43 ++++++--- drivers/net/davinci_emac.c | 34 +++++-- drivers/net/eepro100.c | 34 ++++--- drivers/net/enc28j60.c | 26 ++++-- drivers/net/ep93xx_eth.c | 40 +++++--- drivers/net/fsl_mcdmafec.c | 13 ++- drivers/net/ftmac110.c | 35 ++++--- drivers/net/lpc32xx_eth.c | 52 +++++------ drivers/net/macb.c | 46 +++++++--- drivers/net/mcffec.c | 13 ++- drivers/net/mcfmii.c | 19 ++-- drivers/net/mpc512x_fec.c | 30 ++++-- drivers/net/mpc5xxx_fec.c | 30 ++++-- drivers/net/mvgbe.c | 33 +++++-- drivers/net/phy/miiphybb.c | 25 ++--- drivers/net/sh_eth.c | 12 ++- drivers/net/smc911x.c | 35 +++++-- drivers/qe/uec.c | 32 ++++--- include/miiphy.h | 20 +--- scripts/coccinelle/net/mdio_register.cocci | 142 +++++++++++++++++++++++++++++ 38 files changed, 762 insertions(+), 375 deletions(-) create mode 100644 scripts/coccinelle/net/mdio_register.cocci
Many Ethernet drivers still use the legacy miiphy API to register their mdio interface for access to the mdio commands.
This semantic patch will convert the drivers from the legacy adapter API to the more modern alloc/register API.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v2: None
scripts/coccinelle/net/mdio_register.cocci | 142 +++++++++++++++++++++++++++++ 1 file changed, 142 insertions(+) create mode 100644 scripts/coccinelle/net/mdio_register.cocci
diff --git a/scripts/coccinelle/net/mdio_register.cocci b/scripts/coccinelle/net/mdio_register.cocci new file mode 100644 index 0000000..100f102 --- /dev/null +++ b/scripts/coccinelle/net/mdio_register.cocci @@ -0,0 +1,142 @@ +/// Use mdio_alloc and mdio_register instead of miiphy_register +/// +//# Stop using the oldest mii interface in drivers +// +// Confidence: High +// Copyright: (C) 2016 Joe Hershberger. GPLv2. +// Comments: +// Options: --include-headers --recursive-includes --local-includes -I include + +@ mii_reg @ +expression devname; +identifier readfunc, writefunc; +@@ + ++ int retval; +- miiphy_register(devname, readfunc, writefunc); ++ struct mii_dev *mdiodev = mdio_alloc(); ++ if (!mdiodev) return -ENOMEM; ++ strncpy(mdiodev->name, devname, MDIO_NAME_LEN); ++ mdiodev->read = readfunc; ++ mdiodev->write = writefunc; ++ ++ retval = mdio_register(mdiodev); ++ if (retval < 0) return retval; + +@ update_read_sig @ +identifier mii_reg.readfunc; +identifier name0, addr0, reg0, output; +type addrT, outputT; +@@ + +- readfunc ( +- const char *name0, +- addrT addr0, +- addrT reg0, +- outputT *output +- ) ++ readfunc ( ++ struct mii_dev *bus, ++ int addr0, ++ int devad, ++ int reg0 ++ ) + { + ... + } + +@ update_read_impl @ +identifier mii_reg.readfunc; +identifier update_read_sig.output; +type update_read_sig.outputT; +constant c; +identifier retvar; +expression E; +@@ + + readfunc (...) + { ++ outputT output = 0; + ... +( +- return 0; ++ return *output; +| + return c; +| +- return retvar; ++ if (retvar < 0) ++ return retvar; ++ return *output; +| +- return E; ++ int retval = E; ++ if (retval < 0) ++ return retval; ++ return *output; +) + } + +@ update_read_impl2 @ +identifier mii_reg.readfunc; +identifier update_read_sig.output; +@@ + + readfunc (...) + { + <... +( +- *output ++ output +| +- output ++ &output +) + ...> + } + +@ update_read_name @ +identifier mii_reg.readfunc; +identifier update_read_sig.name0; +@@ + readfunc (...) { + <... +- name0 ++ bus->name + ...> + } + +@ update_write_sig @ +identifier mii_reg.writefunc; +identifier name0, addr0, reg0, value0; +type addrT, valueT; +typedef u16; +@@ + +- writefunc ( +- const char *name0, +- addrT addr0, +- addrT reg0, +- valueT value0 +- ) ++ writefunc ( ++ struct mii_dev *bus, ++ int addr0, ++ int devad, ++ int reg0, ++ u16 value0 ++ ) + { + ... + } + +@ update_write_name @ +identifier mii_reg.writefunc; +identifier update_write_sig.name0; +@@ + writefunc (...) { + <... +- name0 ++ bus->name + ...> + }
Run scripts/coccinelle/net/mdio_register.cocci on the U-Boot code base.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: - Run against the current master which adds one more driver to convert (drivers/net/macb.c) - Use an updated spatch that does not put closing paren on the next line
arch/mips/mach-au1x00/au1x00_eth.c | 25 +++++++++++++------- arch/powerpc/cpu/mpc8260/ether_fcc.c | 13 ++++++++-- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 13 ++++++++-- arch/powerpc/cpu/mpc8xx/fec.c | 34 ++++++++++++++++---------- board/gdsys/405ep/io.c | 13 ++++++++-- board/gdsys/405ep/iocon.c | 27 +++++++++++++++++---- board/gdsys/405ex/io64.c | 26 ++++++++++++++++---- board/gdsys/mpc8308/hrcon.c | 27 +++++++++++++++++---- board/gdsys/mpc8308/strider.c | 27 +++++++++++++++++---- drivers/net/4xx_enet.c | 13 ++++++++-- drivers/net/armada100_fec.c | 33 +++++++++++++++++--------- drivers/net/at91_emac.c | 28 +++++++++++++++------- drivers/net/bfin_mac.c | 22 +++++++++++++---- drivers/net/davinci_emac.c | 25 ++++++++++++++++---- drivers/net/eepro100.c | 34 ++++++++++++++++---------- drivers/net/enc28j60.c | 26 ++++++++++++++------ drivers/net/ep93xx_eth.c | 41 +++++++++++++++++++++----------- drivers/net/fsl_mcdmafec.c | 13 ++++++++-- drivers/net/ftmac110.c | 35 ++++++++++++++++++--------- drivers/net/lpc32xx_eth.c | 29 ++++++++++++++++------- drivers/net/macb.c | 46 ++++++++++++++++++++++++++---------- drivers/net/mcffec.c | 13 ++++++++-- drivers/net/mpc512x_fec.c | 30 ++++++++++++++++------- drivers/net/mpc5xxx_fec.c | 30 ++++++++++++++++------- drivers/net/mvgbe.c | 33 ++++++++++++++++++-------- drivers/net/sh_eth.c | 12 +++++++++- drivers/net/smc911x.c | 31 ++++++++++++++++++------ drivers/qe/uec.c | 32 ++++++++++++++++--------- 28 files changed, 543 insertions(+), 188 deletions(-)
diff --git a/arch/mips/mach-au1x00/au1x00_eth.c b/arch/mips/mach-au1x00/au1x00_eth.c index 9216860..67f4953 100644 --- a/arch/mips/mach-au1x00/au1x00_eth.c +++ b/arch/mips/mach-au1x00/au1x00_eth.c @@ -73,9 +73,9 @@ mac_fifo_t mac_fifo[NO_OF_FIFOS]; #define MAX_WAIT 1000
#if defined(CONFIG_CMD_MII) -int au1x00_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short * value) +int au1x00_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { + unsigned short value = 0; volatile u32 *mii_control_reg = (volatile u32*)(ETH0_BASE+MAC_MII_CNTRL); volatile u32 *mii_data_reg = (volatile u32*)(ETH0_BASE+MAC_MII_DATA); u32 mii_control; @@ -102,12 +102,12 @@ int au1x00_miiphy_read(const char *devname, unsigned char addr, return -1; } } - *value = *mii_data_reg; - return 0; + value = *mii_data_reg; + return value; }
-int au1x00_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int au1x00_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { volatile u32 *mii_control_reg = (volatile u32*)(ETH0_BASE+MAC_MII_CNTRL); volatile u32 *mii_data_reg = (volatile u32*)(ETH0_BASE+MAC_MII_DATA); @@ -290,8 +290,17 @@ int au1x00_enet_initialize(bd_t *bis){ eth_register(dev);
#if defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - au1x00_miiphy_read, au1x00_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = au1x00_miiphy_read; + mdiodev->write = au1x00_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 1; diff --git a/arch/powerpc/cpu/mpc8260/ether_fcc.c b/arch/powerpc/cpu/mpc8260/ether_fcc.c index a11ad1e..072eb76 100644 --- a/arch/powerpc/cpu/mpc8260/ether_fcc.c +++ b/arch/powerpc/cpu/mpc8260/ether_fcc.c @@ -379,8 +379,17 @@ int fec_initialize(bd_t *bis)
#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ && defined(CONFIG_BITBANGMII) - miiphy_register(dev->name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif }
diff --git a/arch/powerpc/cpu/mpc85xx/ether_fcc.c b/arch/powerpc/cpu/mpc85xx/ether_fcc.c index 51f1bee..7708f05 100644 --- a/arch/powerpc/cpu/mpc85xx/ether_fcc.c +++ b/arch/powerpc/cpu/mpc85xx/ether_fcc.c @@ -441,8 +441,17 @@ int fec_initialize(bd_t *bis)
diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index f1ae358..81bda06 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -47,10 +47,9 @@ DECLARE_GLOBAL_DATA_PTR; static int mii_discover_phy(struct eth_device *dev); #endif
-int fec8xx_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -int fec8xx_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int fec8xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg); +int fec8xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value);
static struct ether_fcc_info_s { @@ -170,8 +169,17 @@ int fec_initialize(bd_t *bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - fec8xx_miiphy_read, fec8xx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = fec8xx_miiphy_read; + mdiodev->write = fec8xx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif } return 1; @@ -894,9 +902,9 @@ void mii_init (void) * Otherwise they hang in mii_send() !!! Sorry! *****************************************************************************/
-int fec8xx_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int fec8xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { + unsigned short value = 0; short rdreg; /* register working value */
#ifdef MII_DEBUG @@ -904,15 +912,15 @@ int fec8xx_miiphy_read(const char *devname, unsigned char addr, #endif rdreg = mii_send(mk_mii_read(addr, reg));
- *value = rdreg; + value = rdreg; #ifdef MII_DEBUG - printf ("0x%04x\n", *value); + printf ("0x%04x\n", value); #endif - return 0; + return value; }
-int fec8xx_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int fec8xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { #ifdef MII_DEBUG printf ("miiphy_write(0x%x) @ 0x%x = ", reg, addr); diff --git a/board/gdsys/405ep/io.c b/board/gdsys/405ep/io.c index 03d796c..81b4965 100644 --- a/board/gdsys/405ep/io.c +++ b/board/gdsys/405ep/io.c @@ -172,8 +172,17 @@ int last_stage_init(void)
print_fpga_info();
- miiphy_register(CONFIG_SYS_GBIT_MII_BUSNAME, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII_BUSNAME, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
for (k = 0; k < 32; ++k) configure_gbit_phy(k); diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index 7484624..7db0e29 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -405,8 +405,17 @@ int last_stage_init(void) }
if (!legacy && (feature_carrier_speed == CARRIER_SPEED_1G)) { - miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, - bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[0].name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { if ((mux_ch == 1) && !ch0_rgmii2_present) continue; @@ -437,8 +446,18 @@ int last_stage_init(void) print_fpga_info(k, false); osd_probe(k); if (feature_carrier_speed == CARRIER_SPEED_1G) { - miiphy_register(bb_miiphy_buses[k].name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[k].name, + MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; setup_88e1518(bb_miiphy_buses[k].name, 0); } } diff --git a/board/gdsys/405ex/io64.c b/board/gdsys/405ex/io64.c index 3a075c4..6a83788 100644 --- a/board/gdsys/405ex/io64.c +++ b/board/gdsys/405ex/io64.c @@ -246,8 +246,17 @@ int last_stage_init(void) /* setup Gbit PHYs */ puts("TRANS: "); puts(str_phys); - miiphy_register(CONFIG_SYS_GBIT_MII_BUSNAME, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII_BUSNAME, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
for (k = 0; k < 32; ++k) { configure_gbit_phy(CONFIG_SYS_GBIT_MII_BUSNAME, k); @@ -255,8 +264,17 @@ int last_stage_init(void) putc(slash[k % 8]); }
- miiphy_register(CONFIG_SYS_GBIT_MII1_BUSNAME, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII1_BUSNAME, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
for (k = 0; k < 32; ++k) { configure_gbit_phy(CONFIG_SYS_GBIT_MII1_BUSNAME, k); diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index 880b638..f55893f 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -162,8 +162,17 @@ int last_stage_init(void) }
if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, - bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[0].name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { if ((mux_ch == 1) && !ch0_rgmii2_present) continue; @@ -199,8 +208,18 @@ int last_stage_init(void) osd_probe(k + 4); #endif if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[k].name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[k].name, + MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; setup_88e1514(bb_miiphy_buses[k].name, 0); } } diff --git a/board/gdsys/mpc8308/strider.c b/board/gdsys/mpc8308/strider.c index 121977d..b8dde5f 100644 --- a/board/gdsys/mpc8308/strider.c +++ b/board/gdsys/mpc8308/strider.c @@ -179,8 +179,17 @@ int last_stage_init(void) }
if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, - bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[0].name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { if ((mux_ch == 1) && !ch0_sgmii2_present) continue; @@ -252,8 +261,18 @@ int last_stage_init(void) dp501_probe(k, false); #endif if (hw_type_cat) { - miiphy_register(bb_miiphy_buses[k].name, - bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, bb_miiphy_buses[k].name, + MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; setup_88e1514(bb_miiphy_buses[k].name, 0); } } diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index bc52ed3..fda7bb3 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -2015,8 +2015,17 @@ int ppc_4xx_eth_initialize (bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - emac4xx_miiphy_read, emac4xx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = emac4xx_miiphy_read; + mdiodev->write = emac4xx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
if (0 == virgin) { diff --git a/drivers/net/armada100_fec.c b/drivers/net/armada100_fec.c index e6a6252..ba2cb1a 100644 --- a/drivers/net/armada100_fec.c +++ b/drivers/net/armada100_fec.c @@ -57,18 +57,19 @@ static int armdfec_phy_timeout(u32 *reg, u32 flag, int cond) return !timeout; }
-static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, - u16 *value) +static int smi_reg_read(struct mii_dev *bus, int phy_addr, int devad, + int phy_reg) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 value = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct armdfec_device *darmdfec = to_darmdfec(dev); struct armdfec_reg *regs = darmdfec->regs; u32 val;
if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { val = readl(®s->phyadr); - *value = val & 0x1f; - return 0; + value = val & 0x1f; + return value; }
/* check parameters */ @@ -99,15 +100,15 @@ static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, return -1; } val = readl(®s->smi); - *value = val & 0xffff; + value = val & 0xffff;
-static int smi_reg_write(const char *devname, - u8 phy_addr, u8 phy_reg, u16 value) +static int smi_reg_write(struct mii_dev *bus, int phy_addr, int devad, + int phy_reg, u16 value) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct armdfec_device *darmdfec = to_darmdfec(dev); struct armdfec_reg *regs = darmdfec->regs;
@@ -711,7 +712,17 @@ int armada100_fec_register(unsigned long base_addr) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, smi_reg_read, smi_reg_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = smi_reg_read; + mdiodev->write = smi_reg_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif return 0;
diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index 9151600..be3d82e 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -159,23 +159,23 @@ at91_emac_t *get_emacbase_by_name(const char *devname) return (at91_emac_t *) netdev->iobase; }
-int at91emac_mii_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int at91emac_mii_read(struct mii_dev *bus, int addr, int devad, int reg) { + unsigned short value = 0; at91_emac_t *emac;
- emac = get_emacbase_by_name(devname); - at91emac_read(emac , addr, reg, value); - return 0; + emac = get_emacbase_by_name(bus->name); + at91emac_read(emac , addr, reg, &value); + return value; }
-int at91emac_mii_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int at91emac_mii_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { at91_emac_t *emac;
- emac = get_emacbase_by_name(devname); + emac = get_emacbase_by_name(bus->name); at91emac_write(emac, addr, reg, value); return 0; } @@ -502,7 +502,17 @@ int at91emac_register(bd_t *bis, unsigned long iobase) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, at91emac_mii_read, at91emac_mii_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = at91emac_mii_read; + mdiodev->write = at91emac_mii_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif return 1; } diff --git a/drivers/net/bfin_mac.c b/drivers/net/bfin_mac.c index 61cb1b0..6d40370 100644 --- a/drivers/net/bfin_mac.c +++ b/drivers/net/bfin_mac.c @@ -72,18 +72,20 @@ static int bfin_miiphy_wait(void) return 0; }
-static int bfin_miiphy_read(const char *devname, uchar addr, uchar reg, ushort *val) +static int bfin_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { + ushort val = 0; if (bfin_miiphy_wait()) return 1; bfin_write_EMAC_STAADD(SET_PHYAD(addr) | SET_REGAD(reg) | STABUSY); if (bfin_miiphy_wait()) return 1; - *val = bfin_read_EMAC_STADAT(); - return 0; + val = bfin_read_EMAC_STADAT(); + return val; }
-static int bfin_miiphy_write(const char *devname, uchar addr, uchar reg, ushort val) +static int bfin_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 val) { if (bfin_miiphy_wait()) return 1; @@ -113,7 +115,17 @@ int bfin_EMAC_initialize(bd_t *bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, bfin_miiphy_read, bfin_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = bfin_miiphy_read; + mdiodev->write = bfin_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 0; diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index b030498..7eda93f 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -390,12 +390,18 @@ static int gen_auto_negotiate(int phy_addr)
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -static int davinci_mii_phy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value) +static int davinci_mii_phy_read(struct mii_dev *bus, int addr, int devad, + int reg) { - return(davinci_eth_phy_read(addr, reg, value) ? 0 : 1); + unsigned short value = 0; + int retval = (davinci_eth_phy_read(addr, reg, &value) ? 0 : 1); + if (retval < 0) + return retval; + return value; }
-static int davinci_mii_phy_write(const char *devname, unsigned char addr, unsigned char reg, unsigned short value) +static int davinci_mii_phy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value) { return(davinci_eth_phy_write(addr, reg, value) ? 0 : 1); } @@ -883,8 +889,17 @@ int davinci_emac_initialize(void)
debug("Ethernet PHY: %s\n", phy[i].name);
- miiphy_register(phy[i].name, davinci_mii_phy_read, - davinci_mii_phy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, phy[i].name, MDIO_NAME_LEN); + mdiodev->read = davinci_mii_phy_read; + mdiodev->write = davinci_mii_phy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; }
#if defined(CONFIG_DRIVER_TI_EMAC_USE_RMII) && \ diff --git a/drivers/net/eepro100.c b/drivers/net/eepro100.c index d4a6386..0f350cb 100644 --- a/drivers/net/eepro100.c +++ b/drivers/net/eepro100.c @@ -334,34 +334,35 @@ static struct eth_device* verify_phyaddr (const char *devname, return dev; }
-static int eepro100_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +static int eepro100_miiphy_read(struct mii_dev *bus, int addr, int devad, + int reg) { + unsigned short value = 0; struct eth_device *dev;
- dev = verify_phyaddr(devname, addr); + dev = verify_phyaddr(bus->name, addr); if (dev == NULL) return -1;
- if (get_phyreg(dev, addr, reg, value) != 0) { - printf("%s: mii read timeout!\n", devname); + if (get_phyreg(dev, addr, reg, &value) != 0) { + printf("%s: mii read timeout!\n", bus->name); return -1; }
-static int eepro100_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +static int eepro100_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value) { struct eth_device *dev;
if (set_phyreg(dev, addr, reg, value) != 0) { - printf("%s: mii write timeout!\n", devname); + printf("%s: mii write timeout!\n", bus->name); return -1; }
@@ -451,8 +452,17 @@ int eepro100_initialize (bd_t * bis)
#if defined (CONFIG_MII) || defined(CONFIG_CMD_MII) /* register mii command access routines */ - miiphy_register(dev->name, - eepro100_miiphy_read, eepro100_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = eepro100_miiphy_read; + mdiodev->write = eepro100_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
card_number++; diff --git a/drivers/net/enc28j60.c b/drivers/net/enc28j60.c index 611eabb..2fe323a 100644 --- a/drivers/net/enc28j60.c +++ b/drivers/net/enc28j60.c @@ -742,9 +742,10 @@ static int enc_initcheck(enc_dev_t *enc, const enum enc_initstate requiredstate) * * This function is registered with miiphy_register(). */ -int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) +int enc_miiphy_read(struct mii_dev *bus, int phy_adr, int devad, int reg) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 value = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); enc_dev_t *enc;
if (!dev || phy_adr != 0) @@ -757,9 +758,9 @@ int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) enc_release_bus(enc); return -1; } - *value = enc_phy_read(enc, reg); + value = enc_phy_read(enc, reg); enc_release_bus(enc); - return 0; + return value; }
/* @@ -767,9 +768,10 @@ int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) * * This function is registered with miiphy_register(). */ -int enc_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) +int enc_miiphy_write(struct mii_dev *bus, int phy_adr, int devad, int reg, + u16 value) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); enc_dev_t *enc;
if (!dev || phy_adr != 0) @@ -958,7 +960,17 @@ int enc28j60_initialize(unsigned int bus, unsigned int cs, sprintf(dev->name, "enc%i.%i", bus, cs); eth_register(dev); #if defined(CONFIG_CMD_MII) - miiphy_register(dev->name, enc_miiphy_read, enc_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = enc_miiphy_read; + mdiodev->write = enc_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif return 0; } diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c index a3721c5..0021911 100644 --- a/drivers/net/ep93xx_eth.c +++ b/drivers/net/ep93xx_eth.c @@ -30,10 +30,10 @@ #define GET_REGS(eth_dev) (GET_PRIV(eth_dev)->regs)
/* ep93xx_miiphy ops forward declarations */ -static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short * const value); -static int ep93xx_miiphy_write(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short const value); +static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, + int reg); +static int ep93xx_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value);
#if defined(EP93XX_MAC_DEBUG) /** @@ -421,7 +421,17 @@ eth_send_out: #if defined(CONFIG_MII) int ep93xx_miiphy_initialize(bd_t * const bd) { - miiphy_register("ep93xx_eth0", ep93xx_miiphy_read, ep93xx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, "ep93xx_eth0", MDIO_NAME_LEN); + mdiodev->read = ep93xx_miiphy_read; + mdiodev->write = ep93xx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; return 0; } #endif @@ -542,9 +552,10 @@ eth_init_done: /** * Read a 16-bit value from an MII register. */ -static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short * const value) +static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, + int reg) { + unsigned short value = 0; struct mac_regs *mac = (struct mac_regs *)MAC_BASE; int ret = -1; uint32_t self_ctl; @@ -552,10 +563,10 @@ static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, debug("+ep93xx_miiphy_read");
/* Parameter checks */ - BUG_ON(dev == NULL); + BUG_ON(bus->name == NULL); BUG_ON(addr > MII_ADDRESS_MAX); BUG_ON(reg > MII_REGISTER_MAX); - BUG_ON(value == NULL); + BUG_ON(&value == NULL);
/* * Save the current SelfCTL register value. Set MAC to suppress @@ -579,7 +590,7 @@ static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, while (readl(&mac->miists) & MIISTS_BUSY) ; /* noop */
- *value = (unsigned short)readl(&mac->miidata); + value = (unsigned short)readl(&mac->miidata);
/* Restore the saved SelfCTL value and return. */ writel(self_ctl, &mac->selfctl); @@ -588,14 +599,16 @@ static int ep93xx_miiphy_read(const char * const dev, unsigned char const addr, /* Fall through */
debug("-ep93xx_miiphy_read"); - return ret; + if (ret < 0) + return ret; + return value; }
/** * Write a 16-bit value to an MII register. */ -static int ep93xx_miiphy_write(const char * const dev, unsigned char const addr, - unsigned char const reg, unsigned short const value) +static int ep93xx_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value) { struct mac_regs *mac = (struct mac_regs *)MAC_BASE; int ret = -1; @@ -604,7 +617,7 @@ static int ep93xx_miiphy_write(const char * const dev, unsigned char const addr, debug("+ep93xx_miiphy_write");
diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index 792534b..15a3ce0 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -556,8 +556,17 @@ int mcdmafec_initialize(bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - mcffec_miiphy_read, mcffec_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = mcffec_miiphy_read; + mdiodev->write = mcffec_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
if (i > 0) diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index 4f17015..8fa767a 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -364,32 +364,35 @@ static int ftmac110_recv(struct eth_device *dev)
-static int ftmac110_mdio_read( - const char *devname, uint8_t addr, uint8_t reg, uint16_t *value) +static int ftmac110_mdio_read(struct mii_dev *bus, int addr, int devad, + int reg) { + uint16_t value = 0; int ret = 0; struct eth_device *dev;
- dev = eth_get_dev_by_name(devname); + dev = eth_get_dev_by_name(bus->name); if (dev == NULL) { - printf("%s: no such device\n", devname); + printf("%s: no such device\n", bus->name); ret = -1; } else { - *value = mdio_read(dev, addr, reg); + value = mdio_read(dev, addr, reg); }
-static int ftmac110_mdio_write( - const char *devname, uint8_t addr, uint8_t reg, uint16_t value) +static int ftmac110_mdio_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value) { int ret = 0; struct eth_device *dev;
- dev = eth_get_dev_by_name(devname); + dev = eth_get_dev_by_name(bus->name); if (dev == NULL) { - printf("%s: no such device\n", devname); + printf("%s: no such device\n", bus->name); ret = -1; } else { mdio_write(dev, addr, reg, value); @@ -468,7 +471,17 @@ int ftmac110_initialize(bd_t *bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, ftmac110_mdio_read, ftmac110_mdio_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = ftmac110_mdio_read; + mdiodev->write = ftmac110_mdio_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
card_nr++; diff --git a/drivers/net/lpc32xx_eth.c b/drivers/net/lpc32xx_eth.c index 6cc273c..36af795 100644 --- a/drivers/net/lpc32xx_eth.c +++ b/drivers/net/lpc32xx_eth.c @@ -226,9 +226,11 @@ DECLARE_GLOBAL_DATA_PTR; * * Returns 16bit phy register value, or 0xffff on error */ -static int mii_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 *data) +static int mii_reg_read(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 data = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct lpc32xx_eth_device *dlpc32xx_eth = to_lpc32xx_eth(dev); struct lpc32xx_eth_registers *regs = dlpc32xx_eth->regs; u32 mind_reg; @@ -270,12 +272,12 @@ static int mii_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 *data) return -EFAULT; }
- *data = (u16) readl(®s->mrdd); + data = (u16) readl(®s->mrdd);
debug("%s:(adr %d, off %d) => %04x\n", __func__, phy_adr, - reg_ofs, *data); + reg_ofs, data);
- return 0; + return data; }
/* @@ -284,9 +286,10 @@ static int mii_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 *data) * Returns 0 if write succeed, -EINVAL on bad parameters * -ETIME on timeout */ -static int mii_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) +static int mii_reg_write(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs, u16 data) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct lpc32xx_eth_device *dlpc32xx_eth = to_lpc32xx_eth(dev); struct lpc32xx_eth_registers *regs = dlpc32xx_eth->regs; u32 mind_reg; @@ -645,7 +648,17 @@ int lpc32xx_eth_initialize(bd_t *bis) #if defined(CONFIG_PHYLIB) lpc32xx_eth_phylib_init(dev, CONFIG_PHY_ADDR); #elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, mii_reg_read, mii_reg_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = mii_reg_read; + mdiodev->write = mii_reg_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 0; diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 0835fdc..822907f 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -199,39 +199,41 @@ void __weak arch_get_mdio_control(const char *name)
#if defined(CONFIG_CMD_MII) || defined(CONFIG_PHYLIB)
-int macb_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) +int macb_miiphy_read(struct mii_dev *bus, int phy_adr, int devad, int reg) { + u16 value = 0; #ifdef CONFIG_DM_ETH - struct udevice *dev = eth_get_dev_by_name(devname); + struct udevice *dev = eth_get_dev_by_name(bus->name); struct macb_device *macb = dev_get_priv(dev); #else - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct macb_device *macb = to_macb(dev); #endif
if (macb->phy_addr != phy_adr) return -1;
- arch_get_mdio_control(devname); - *value = macb_mdio_read(macb, reg); + arch_get_mdio_control(bus->name); + value = macb_mdio_read(macb, reg);
-int macb_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) +int macb_miiphy_write(struct mii_dev *bus, int phy_adr, int devad, int reg, + u16 value) { #ifdef CONFIG_DM_ETH - struct udevice *dev = eth_get_dev_by_name(devname); + struct udevice *dev = eth_get_dev_by_name(bus->name); struct macb_device *macb = dev_get_priv(dev); #else - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct macb_device *macb = to_macb(dev); #endif
- arch_get_mdio_control(devname); + arch_get_mdio_control(bus->name); macb_mdio_write(macb, reg, value);
return 0; @@ -862,7 +864,17 @@ int macb_eth_initialize(int id, void *regs, unsigned int phy_addr) eth_register(netdev);
#if defined(CONFIG_CMD_MII) || defined(CONFIG_PHYLIB) - miiphy_register(netdev->name, macb_miiphy_read, macb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, netdev->name, MDIO_NAME_LEN); + mdiodev->read = macb_miiphy_read; + mdiodev->write = macb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; macb->bus = miiphy_get_dev_by_name(netdev->name); #endif return 0; @@ -937,7 +949,17 @@ static int macb_eth_probe(struct udevice *dev)
_macb_eth_initialize(macb); #if defined(CONFIG_CMD_MII) || defined(CONFIG_PHYLIB) - miiphy_register(dev->name, macb_miiphy_read, macb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = macb_miiphy_read; + mdiodev->write = macb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; macb->bus = miiphy_get_dev_by_name(dev->name); #endif
diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index fd73099..e1b06b2 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -595,8 +595,17 @@ int mcffec_initialize(bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, - mcffec_miiphy_read, mcffec_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = mcffec_miiphy_read; + mdiodev->write = mcffec_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif if (i > 0) fec_info[i - 1].next = &fec_info[i]; diff --git a/drivers/net/mpc512x_fec.c b/drivers/net/mpc512x_fec.c index e850672..b3746fb 100644 --- a/drivers/net/mpc512x_fec.c +++ b/drivers/net/mpc512x_fec.c @@ -22,8 +22,10 @@ DECLARE_GLOBAL_DATA_PTR; #error "CONFIG_MII has to be defined!" #endif
-int fec512x_miiphy_read(const char *devname, u8 phyAddr, u8 regAddr, u16 * retVal); -int fec512x_miiphy_write(const char *devname, u8 phyAddr, u8 regAddr, u16 data); +int fec512x_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr); +int fec512x_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data); int mpc512x_fec_init_phy(struct eth_device *dev, bd_t * bis);
static uchar rx_buff[FEC_BUFFER_SIZE]; @@ -639,8 +641,17 @@ int mpc512x_fec_initialize (bd_t * bis) eth_register (dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register (dev->name, - fec512x_miiphy_read, fec512x_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = fec512x_miiphy_read; + mdiodev->write = fec512x_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
/* Clean up space FEC's MIB and FIFO RAM ...*/ @@ -670,8 +681,10 @@ int mpc512x_fec_initialize (bd_t * bis)
/* MII-interface related functions */ /********************************************************************/ -int fec512x_miiphy_read(const char *devname, u8 phyAddr, u8 regAddr, u16 *retVal) +int fec512x_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr) { + u16 retVal = 0; volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; volatile fec512x_t *eth = &im->fec; u32 reg; /* convenient holder for the PHY register */ @@ -711,13 +724,14 @@ int fec512x_miiphy_read(const char *devname, u8 phyAddr, u8 regAddr, u16 *retVal /* * it's now safe to read the PHY's register */ - *retVal = (u16) in_be32(ð->mii_data); + retVal = (u16) in_be32(ð->mii_data);
- return 0; + return retVal; }
/********************************************************************/ -int fec512x_miiphy_write(const char *devname, u8 phyAddr, u8 regAddr, u16 data) +int fec512x_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; volatile fec512x_t *eth = &im->fec; diff --git a/drivers/net/mpc5xxx_fec.c b/drivers/net/mpc5xxx_fec.c index e13b4cf..d75e858 100644 --- a/drivers/net/mpc5xxx_fec.c +++ b/drivers/net/mpc5xxx_fec.c @@ -35,8 +35,10 @@ typedef struct { uint8 head[16]; /* MAC header(6 + 6 + 2) + 2(aligned) */ } NBUF;
-int fec5xxx_miiphy_read(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 *retVal); -int fec5xxx_miiphy_write(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 data); +int fec5xxx_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr); +int fec5xxx_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data);
static int mpc5xxx_fec_init_phy(struct eth_device *dev, bd_t * bis);
@@ -917,8 +919,17 @@ int mpc5xxx_fec_initialize(bd_t * bis) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register (dev->name, - fec5xxx_miiphy_read, fec5xxx_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = fec5xxx_miiphy_read; + mdiodev->write = fec5xxx_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
/* @@ -941,8 +952,10 @@ int mpc5xxx_fec_initialize(bd_t * bis)
/* MII-interface related functions */ /********************************************************************/ -int fec5xxx_miiphy_read(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 * retVal) +int fec5xxx_miiphy_read(struct mii_dev *bus, int phyAddr, int devad, + int regAddr) { + uint16 retVal = 0; ethernet_regs *eth = (ethernet_regs *)MPC5XXX_FEC; uint32 reg; /* convenient holder for the PHY register */ uint32 phy; /* convenient holder for the PHY */ @@ -977,13 +990,14 @@ int fec5xxx_miiphy_read(const char *devname, uint8 phyAddr, uint8 regAddr, uint1 /* * it's now safe to read the PHY's register */ - *retVal = (uint16) eth->mii_data; + retVal = (uint16) eth->mii_data;
/********************************************************************/ -int fec5xxx_miiphy_write(const char *devname, uint8 phyAddr, uint8 regAddr, uint16 data) +int fec5xxx_miiphy_write(struct mii_dev *bus, int phyAddr, int devad, + int regAddr, u16 data) { ethernet_regs *eth = (ethernet_regs *)MPC5XXX_FEC; uint32 reg; /* convenient holder for the PHY register */ diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index b16be92..a1c7ea0 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -48,9 +48,11 @@ DECLARE_GLOBAL_DATA_PTR; * * Returns 16bit phy register value, or 0xffff on error */ -static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) +static int smi_reg_read(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs) { - struct eth_device *dev = eth_get_dev_by_name(devname); + u16 data = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; u32 smi_reg; @@ -60,8 +62,8 @@ static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) if (phy_adr == MV_PHY_ADR_REQUEST && reg_ofs == MV_PHY_ADR_REQUEST) { /* */ - *data = (u16) (MVGBE_REG_RD(regs->phyadr) & PHYADR_MASK); - return 0; + data = (u16) (MVGBE_REG_RD(regs->phyadr) & PHYADR_MASK); + return data; } /* check parameters */ if (phy_adr > PHYADR_MASK) { @@ -111,12 +113,12 @@ static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) for (timeout = 0; timeout < MVGBE_PHY_SMI_TIMEOUT; timeout++) ;
- *data = (u16) (MVGBE_REG_RD(MVGBE_SMI_REG) & MVGBE_PHY_SMI_DATA_MASK); + data = (u16) (MVGBE_REG_RD(MVGBE_SMI_REG) & MVGBE_PHY_SMI_DATA_MASK);
debug("%s:(adr %d, off %d) value= %04x\n", __func__, phy_adr, reg_ofs, - *data); + data);
/* @@ -125,9 +127,10 @@ static int smi_reg_read(const char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) * Returns 0 if write succeed, -EINVAL on bad parameters * -ETIME on timeout */ -static int smi_reg_write(const char *devname, u8 phy_adr, u8 reg_ofs, u16 data) +static int smi_reg_write(struct mii_dev *bus, int phy_adr, int devad, + int reg_ofs, u16 data) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; u32 smi_reg; @@ -785,7 +788,17 @@ error1: #if defined(CONFIG_PHYLIB) mvgbe_phylib_init(dev, PHY_BASE_ADR + devnum); #elif defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, smi_reg_read, smi_reg_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = smi_reg_read; + mdiodev->write = smi_reg_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; /* Set phy address of the port */ miiphy_write(dev->name, MV_PHY_ADR_REQUEST, MV_PHY_ADR_REQUEST, PHY_BASE_ADR + devnum); diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 2fa2016..79c1db2 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -566,7 +566,17 @@ int sh_eth_initialize(bd_t *bd) eth_register(dev);
bb_miiphy_buses[0].priv = eth; - miiphy_register(dev->name, bb_miiphy_read, bb_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = bb_miiphy_read; + mdiodev->write = bb_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval;
if (!eth_getenv_enetaddr("ethaddr", dev->enetaddr)) puts("Please set MAC address\n"); diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index c85a178..c788f3b 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -219,17 +219,24 @@ static int smc911x_rx(struct eth_device *dev)
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) /* wrapper for smc911x_eth_phy_read */ -static int smc911x_miiphy_read(const char *devname, u8 phy, u8 reg, u16 *val) +static int smc911x_miiphy_read(struct mii_dev *bus, int phy, int devad, + int reg) { - struct eth_device *dev = eth_get_dev_by_name(devname); - if (dev) - return smc911x_eth_phy_read(dev, phy, reg, val); + u16 val = 0; + struct eth_device *dev = eth_get_dev_by_name(bus->name); + if (dev) { + int retval = smc911x_eth_phy_read(dev, phy, reg, &val); + if (retval < 0) + return retval; + return val; + } return -1; } /* wrapper for smc911x_eth_phy_write */ -static int smc911x_miiphy_write(const char *devname, u8 phy, u8 reg, u16 val) +static int smc911x_miiphy_write(struct mii_dev *bus, int phy, int devad, + int reg, u16 val) { - struct eth_device *dev = eth_get_dev_by_name(devname); + struct eth_device *dev = eth_get_dev_by_name(bus->name); if (dev) return smc911x_eth_phy_write(dev, phy, reg, val); return -1; @@ -276,7 +283,17 @@ int smc911x_initialize(u8 dev_num, int base_addr) eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, smc911x_miiphy_read, smc911x_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = smc911x_miiphy_read; + mdiodev->write = smc911x_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 1; diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 40cccc2..d838520 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -623,20 +623,20 @@ static int uec_miiphy_find_dev_by_name(const char *devname) * Returns: * 0 on success */ -static int uec_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +static int uec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { + unsigned short value = 0; int devindex = 0;
- if (devname == NULL || value == NULL) { + if (bus->name == NULL || &value == NULL) { debug("%s: NULL pointer given\n", __FUNCTION__); } else { - devindex = uec_miiphy_find_dev_by_name(devname); + devindex = uec_miiphy_find_dev_by_name(bus->name); if (devindex >= 0) { - *value = uec_read_phy_reg(devlist[devindex], addr, reg); + value = uec_read_phy_reg(devlist[devindex], addr, reg); } } - return 0; + return value; }
/* @@ -645,15 +645,15 @@ static int uec_miiphy_read(const char *devname, unsigned char addr, * Returns: * 0 on success */ -static int uec_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +static int uec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { int devindex = 0;
- if (devname == NULL) { + if (bus->name == NULL) { debug("%s: NULL pointer given\n", __FUNCTION__); } else { - devindex = uec_miiphy_find_dev_by_name(devname); + devindex = uec_miiphy_find_dev_by_name(bus->name); if (devindex >= 0) { uec_write_phy_reg(devlist[devindex], addr, reg, value); } @@ -1399,7 +1399,17 @@ int uec_initialize(bd_t *bis, uec_info_t *uec_info) }
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - miiphy_register(dev->name, uec_miiphy_read, uec_miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = uec_miiphy_read; + mdiodev->write = uec_miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
return 1;
If the functions passed to the registration function are not in the same C file (extern) then spatch will not handle the dependent changes.
Make those changes manually.
For the 4xx related files: Acked-by: Stefan Roese sr@denx.de Reviewed-by: Bin Meng bmeng.cn@gmail.com
arch/m68k/include/asm/fec.h | 9 +++++---- arch/powerpc/cpu/ppc4xx/miiphy.c | 11 ++++------- drivers/net/4xx_enet.c | 7 +++---- drivers/net/bcm-sf2-eth-gmac.c | 18 +++++++----------- drivers/net/bcm-sf2-eth.c | 13 ++++++++++++- drivers/net/bcm-sf2-eth.h | 8 ++++---- drivers/net/mcfmii.c | 19 ++++++------------- drivers/net/phy/miiphybb.c | 25 ++++++++----------------- include/miiphy.h | 7 +++---- 9 files changed, 52 insertions(+), 65 deletions(-)
diff --git a/arch/m68k/include/asm/fec.h b/arch/m68k/include/asm/fec.h index 6856aac..2799293 100644 --- a/arch/m68k/include/asm/fec.h +++ b/arch/m68k/include/asm/fec.h @@ -15,6 +15,8 @@ #ifndef fec_h #define fec_h
+#include <phy.h> + /* Buffer descriptors used FEC. */ typedef struct cpm_buf_desc { @@ -341,10 +343,9 @@ int fecpin_setclear(struct eth_device *dev, int setclear); void __mii_init(void); uint mii_send(uint mii_cmd); int mii_discover_phy(struct eth_device *dev); -int mcffec_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -int mcffec_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int mcffec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg); +int mcffec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value); #endif
#endif /* fec_h */ diff --git a/arch/powerpc/cpu/ppc4xx/miiphy.c b/arch/powerpc/cpu/ppc4xx/miiphy.c index 10147de..f0fc098 100644 --- a/arch/powerpc/cpu/ppc4xx/miiphy.c +++ b/arch/powerpc/cpu/ppc4xx/miiphy.c @@ -318,8 +318,7 @@ static int emac_miiphy_command(u8 addr, u8 reg, int cmd, u16 value) return 0; }
-int emac4xx_miiphy_read (const char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) +int emac4xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { unsigned long sta_reg; unsigned long emac_reg; @@ -330,17 +329,15 @@ int emac4xx_miiphy_read (const char *devname, unsigned char addr, unsigned char return -1;
sta_reg = in_be32((void *)EMAC0_STACR + emac_reg); - *value = sta_reg >> 16; - - return 0; + return sta_reg >> 16; }
/***********************************************************/ /* write a phy reg and return the value with a rc */ /***********************************************************/
-int emac4xx_miiphy_write (const char *devname, unsigned char addr, unsigned char reg, - unsigned short value) +int emac4xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { return emac_miiphy_command(addr, reg, EMAC_STACR_WRITE, value); } diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index fda7bb3..b718481 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -283,10 +283,9 @@ static void mal_err (struct eth_device *dev, unsigned long isr, static void emac_err (struct eth_device *dev, unsigned long isr);
extern int phy_setup_aneg (char *devname, unsigned char addr); -extern int emac4xx_miiphy_read (const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -extern int emac4xx_miiphy_write (const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int emac4xx_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg); +int emac4xx_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value);
int board_emac_count(void);
diff --git a/drivers/net/bcm-sf2-eth-gmac.c b/drivers/net/bcm-sf2-eth-gmac.c index 977feec..f2853cf 100644 --- a/drivers/net/bcm-sf2-eth-gmac.c +++ b/drivers/net/bcm-sf2-eth-gmac.c @@ -596,12 +596,10 @@ bool gmac_mii_busywait(unsigned int timeout) return tmp & (1 << GMAC_MII_BUSY_SHIFT); }
-int gmac_miiphy_read(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short *value) +int gmac_miiphy_read(struct mii_dev *bus, int phyaddr, int devad, int reg) { uint32_t tmp = 0; - - (void)devname; + u16 value = 0;
/* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) { @@ -621,18 +619,16 @@ int gmac_miiphy_read(const char *devname, unsigned char phyaddr, return -1; }
- *value = readl(GMAC_MII_DATA_ADDR) & 0xffff; - debug("MII read data 0x%x\n", *value); - return 0; + value = readl(GMAC_MII_DATA_ADDR) & 0xffff; + debug("MII read data 0x%x\n", value); + return value; }
-int gmac_miiphy_write(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short value) +int gmac_miiphy_write(struct mii_dev *bus, int phyaddr, int devad, int reg, + u16 value) { uint32_t tmp = 0;
- (void)devname; - /* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) { error("%s: Prepare MII write: MII/MDIO busy\n", __func__); diff --git a/drivers/net/bcm-sf2-eth.c b/drivers/net/bcm-sf2-eth.c index eab4c1f..e274736 100644 --- a/drivers/net/bcm-sf2-eth.c +++ b/drivers/net/bcm-sf2-eth.c @@ -244,7 +244,18 @@ int bcm_sf2_eth_register(bd_t *bis, u8 dev_num) eth_register(dev);
#ifdef CONFIG_CMD_MII - miiphy_register(dev->name, eth->miiphy_read, eth->miiphy_write); + int retval; + struct mii_dev *mdiodev = mdio_alloc(); + + if (!mdiodev) + return -ENOMEM; + strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); + mdiodev->read = eth->miiphy_read; + mdiodev->write = eth->miiphy_write; + + retval = mdio_register(mdiodev); + if (retval < 0) + return retval; #endif
/* Initialization */ diff --git a/drivers/net/bcm-sf2-eth.h b/drivers/net/bcm-sf2-eth.h index 49a5836..6104aff 100644 --- a/drivers/net/bcm-sf2-eth.h +++ b/drivers/net/bcm-sf2-eth.h @@ -54,10 +54,10 @@ struct eth_info { struct phy_device *port[BCM_ETH_MAX_PORT_NUM]; int port_num;
- int (*miiphy_read)(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short *value); - int (*miiphy_write)(const char *devname, unsigned char phyaddr, - unsigned char reg, unsigned short value); + int (*miiphy_read)(struct mii_dev *bus, int phyaddr, int devad, + int reg); + int (*miiphy_write)(struct mii_dev *bus, int phyaddr, int devad, + int reg, u16 value);
int (*mac_init)(struct eth_device *dev); int (*enable_mac)(void); diff --git a/drivers/net/mcfmii.c b/drivers/net/mcfmii.c index 17a780c..103e365 100644 --- a/drivers/net/mcfmii.c +++ b/drivers/net/mcfmii.c @@ -277,8 +277,7 @@ void __mii_init(void) * Otherwise they hang in mii_send() !!! Sorry! */
-int mcffec_miiphy_read(const char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) +int mcffec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { short rdreg; /* register working value */
@@ -287,28 +286,22 @@ int mcffec_miiphy_read(const char *devname, unsigned char addr, unsigned char re #endif rdreg = mii_send(mk_mii_read(addr, reg));
- *value = rdreg; - #ifdef MII_DEBUG - printf("0x%04x\n", *value); + printf("0x%04x\n", rdreg); #endif
- return 0; + return rdreg; }
-int mcffec_miiphy_write(const char *devname, unsigned char addr, unsigned char reg, - unsigned short value) +int mcffec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 value) { #ifdef MII_DEBUG - printf("miiphy_write(0x%x) @ 0x%x = ", reg, addr); + printf("miiphy_write(0x%x) @ 0x%x = 0x%04x\n", reg, addr, value); #endif
mii_send(mk_mii_write(addr, reg, value));
-#ifdef MII_DEBUG - printf("0x%04x\n", value); -#endif - return 0; }
diff --git a/drivers/net/phy/miiphybb.c b/drivers/net/phy/miiphybb.c index 5cda0b8..af676b9 100644 --- a/drivers/net/phy/miiphybb.c +++ b/drivers/net/phy/miiphybb.c @@ -230,24 +230,18 @@ static void miiphy_pre(struct bb_miiphy_bus *bus, char read, * Returns: * 0 on success */ -int bb_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int bb_miiphy_read(struct mii_dev *miidev, int addr, int devad, int reg) { short rdreg; /* register working value */ int v; int j; /* counter */ struct bb_miiphy_bus *bus;
- bus = bb_miiphy_getbus(devname); + bus = bb_miiphy_getbus(miidev->name); if (bus == NULL) { return -1; }
- if (value == NULL) { - puts("NULL value pointer\n"); - return -1; - } - miiphy_pre (bus, 1, addr, reg);
/* tri-state our MDIO I/O pin so we can read */ @@ -267,8 +261,7 @@ int bb_miiphy_read(const char *devname, unsigned char addr, bus->set_mdc(bus, 1); bus->delay(bus); } - /* There is no PHY, set value to 0xFFFF and return */ - *value = 0xFFFF; + /* There is no PHY, return */ return -1; }
@@ -294,13 +287,11 @@ int bb_miiphy_read(const char *devname, unsigned char addr, bus->set_mdc(bus, 1); bus->delay(bus);
- *value = rdreg; - #ifdef DEBUG - printf ("miiphy_read(0x%x) @ 0x%x = 0x%04x\n", reg, addr, *value); + printf("miiphy_read(0x%x) @ 0x%x = 0x%04x\n", reg, addr, rdreg); #endif
@@ -311,13 +302,13 @@ int bb_miiphy_read(const char *devname, unsigned char addr, * Returns: * 0 on success */ -int bb_miiphy_write (const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int bb_miiphy_write(struct mii_dev *miidev, int addr, int devad, int reg, + u16 value) { struct bb_miiphy_bus *bus; int j; /* counter */
- bus = bb_miiphy_getbus(devname); + bus = bb_miiphy_getbus(miidev->name); if (bus == NULL) { /* Bus not found! */ return -1; diff --git a/include/miiphy.h b/include/miiphy.h index af12274..8a55a13 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -86,10 +86,9 @@ extern struct bb_miiphy_bus bb_miiphy_buses[]; extern int bb_miiphy_buses_num;
void bb_miiphy_init(void); -int bb_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -int bb_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); +int bb_miiphy_read(struct mii_dev *miidev, int addr, int devad, int reg); +int bb_miiphy_write(struct mii_dev *miidev, int addr, int devad, int reg, + u16 value); #endif
/* phy seed setup */
Some of the changes were a bit too complex.
Changes in v2: None
arch/powerpc/cpu/mpc8xx/fec.c | 6 ++++-- board/gdsys/405ex/io64.c | 3 +-- drivers/net/bfin_mac.c | 21 +++++++++++++++------ drivers/net/davinci_emac.c | 11 +++++------ drivers/net/ep93xx_eth.c | 1 - drivers/net/lpc32xx_eth.c | 23 ++--------------------- drivers/net/smc911x.c | 4 ++-- drivers/qe/uec.c | 2 +- 8 files changed, 30 insertions(+), 41 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index 81bda06..0940906 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -6,10 +6,12 @@ */
#include <common.h> -#include <malloc.h> +#include <command.h> #include <commproc.h> +#include <malloc.h> #include <net.h> -#include <command.h> + +#include <phy.h>
diff --git a/board/gdsys/405ex/io64.c b/board/gdsys/405ex/io64.c index 6a83788..848cdde 100644 --- a/board/gdsys/405ex/io64.c +++ b/board/gdsys/405ex/io64.c @@ -264,8 +264,7 @@ int last_stage_init(void) putc(slash[k % 8]); }
- int retval; - struct mii_dev *mdiodev = mdio_alloc(); + mdiodev = mdio_alloc(); if (!mdiodev) return -ENOMEM; strncpy(mdiodev->name, CONFIG_SYS_GBIT_MII1_BUSNAME, MDIO_NAME_LEN); diff --git a/drivers/net/bfin_mac.c b/drivers/net/bfin_mac.c index 6d40370..26a626b 100644 --- a/drivers/net/bfin_mac.c +++ b/drivers/net/bfin_mac.c @@ -13,6 +13,7 @@ #include <command.h> #include <malloc.h> #include <miiphy.h> +#include <linux/mdio.h> #include <linux/mii.h>
#include <asm/blackfin.h> @@ -126,6 +127,8 @@ int bfin_EMAC_initialize(bd_t *bis) retval = mdio_register(mdiodev); if (retval < 0) return retval; + + dev->priv = mdiodev; #endif
return 0; @@ -234,8 +237,9 @@ static int bfin_EMAC_recv(struct eth_device *dev) static int bfin_miiphy_init(struct eth_device *dev, int *opmode) { const unsigned short pins[] = CONFIG_BFIN_MAC_PINS; - u16 phydat; + int phydat; size_t count; + struct mii_dev *mdiodev = dev->priv;
/* Enable PHY output */ bfin_write_VR_CTL(bfin_read_VR_CTL() | CLKBUFOE); @@ -248,12 +252,15 @@ static int bfin_miiphy_init(struct eth_device *dev, int *opmode) bfin_write_EMAC_SYSCTL(RXDWA | RXCKS | SET_MDCDIV(MDC_FREQ_TO_DIV(CONFIG_PHY_CLOCK_FREQ)));
/* turn on auto-negotiation and wait for link to come up */ - bfin_miiphy_write(dev->name, CONFIG_PHY_ADDR, MII_BMCR, BMCR_ANENABLE); + bfin_miiphy_write(mdiodev, CONFIG_PHY_ADDR, MDIO_DEVAD_NONE, MII_BMCR, + BMCR_ANENABLE); count = 0; while (1) { ++count; - if (bfin_miiphy_read(dev->name, CONFIG_PHY_ADDR, MII_BMSR, &phydat)) - return -1; + phydat = bfin_miiphy_read(mdiodev, CONFIG_PHY_ADDR, + MDIO_DEVAD_NONE, MII_BMSR); + if (phydat < 0) + return phydat; if (phydat & BMSR_LSTATUS) break; if (count > 30000) { @@ -264,8 +271,10 @@ static int bfin_miiphy_init(struct eth_device *dev, int *opmode) }
/* see what kind of link we have */ - if (bfin_miiphy_read(dev->name, CONFIG_PHY_ADDR, MII_LPA, &phydat)) - return -1; + phydat = bfin_miiphy_read(mdiodev, CONFIG_PHY_ADDR, MDIO_DEVAD_NONE, + MII_LPA); + if (phydat < 0) + return phydat; if (phydat & LPA_DUPLEX) *opmode = FDMODE; else diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index 7eda93f..ca457b8 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -243,11 +243,10 @@ int davinci_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data)
if (tmp & MDIO_USERACCESS0_ACK) { *data = tmp & 0xffff; - return(1); + return 0; }
- *data = -1; - return(0); + return -EIO; }
/* Write to a PHY register via MDIO inteface. Blocks until operation is complete. */ @@ -268,7 +267,7 @@ int davinci_eth_phy_write(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t data) while (readl(&adap_mdio->USERACCESS0) & MDIO_USERACCESS0_GO) ;
/* PHY functions for a generic PHY */ @@ -394,7 +393,7 @@ static int davinci_mii_phy_read(struct mii_dev *bus, int addr, int devad, int reg) { unsigned short value = 0; - int retval = (davinci_eth_phy_read(addr, reg, &value) ? 0 : 1); + int retval = davinci_eth_phy_read(addr, reg, &value); if (retval < 0) return retval; return value; @@ -403,7 +402,7 @@ static int davinci_mii_phy_read(struct mii_dev *bus, int addr, int devad, static int davinci_mii_phy_write(struct mii_dev *bus, int addr, int devad, int reg, u16 value) { - return(davinci_eth_phy_write(addr, reg, value) ? 0 : 1); + return davinci_eth_phy_write(addr, reg, value); } #endif
diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c index 0021911..a94191b 100644 --- a/drivers/net/ep93xx_eth.c +++ b/drivers/net/ep93xx_eth.c @@ -566,7 +566,6 @@ static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, BUG_ON(bus->name == NULL); BUG_ON(addr > MII_ADDRESS_MAX); BUG_ON(reg > MII_REGISTER_MAX); - BUG_ON(&value == NULL);
/* * Save the current SelfCTL register value. Set MAC to suppress diff --git a/drivers/net/lpc32xx_eth.c b/drivers/net/lpc32xx_eth.c index 36af795..2dd69f3 100644 --- a/drivers/net/lpc32xx_eth.c +++ b/drivers/net/lpc32xx_eth.c @@ -336,25 +336,6 @@ static int mii_reg_write(struct mii_dev *bus, int phy_adr, int devad, } #endif
-#if defined(CONFIG_PHYLIB) -int lpc32xx_eth_phy_read(struct mii_dev *bus, int phy_addr, int dev_addr, - int reg_addr) -{ - u16 data; - int ret; - ret = mii_reg_read(bus->name, phy_addr, reg_addr, &data); - if (ret) - return ret; - return data; -} - -int lpc32xx_eth_phy_write(struct mii_dev *bus, int phy_addr, int dev_addr, - int reg_addr, u16 data) -{ - return mii_reg_write(bus->name, phy_addr, reg_addr, data); -} -#endif - /* * Provide default Ethernet buffers base address if target did not. * Locate buffers in SRAM at 0x00001000 to avoid cache issues and @@ -583,8 +564,8 @@ int lpc32xx_eth_phylib_init(struct eth_device *dev, int phyid) printf("mdio_alloc failed\n"); return -ENOMEM; } - bus->read = lpc32xx_eth_phy_read; - bus->write = lpc32xx_eth_phy_write; + bus->read = mii_reg_read; + bus->write = mii_reg_write; strcpy(bus->name, dev->name);
ret = mdio_register(bus); diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index c788f3b..feae8c0 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -230,7 +230,7 @@ static int smc911x_miiphy_read(struct mii_dev *bus, int phy, int devad, return retval; return val; } - return -1; + return -ENODEV; } /* wrapper for smc911x_eth_phy_write */ static int smc911x_miiphy_write(struct mii_dev *bus, int phy, int devad, @@ -239,7 +239,7 @@ static int smc911x_miiphy_write(struct mii_dev *bus, int phy, int devad, struct eth_device *dev = eth_get_dev_by_name(bus->name); if (dev) return smc911x_eth_phy_write(dev, phy, reg, val); - return -1; + return -ENODEV; } #endif
diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index d838520..468c92e 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -628,7 +628,7 @@ static int uec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) unsigned short value = 0; int devindex = 0;
- if (bus->name == NULL || &value == NULL) { + if (bus->name == NULL) { debug("%s: NULL pointer given\n", __FUNCTION__); } else { devindex = uec_miiphy_find_dev_by_name(bus->name);
The cleanup of the legacy mii registration API that's no longer used now that the drivers have been converted to use the (more) modern API.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: None
common/miiphyutil.c | 73 ----------------------------------------------------- include/miiphy.h | 13 ---------- 2 files changed, 86 deletions(-)
diff --git a/common/miiphyutil.c b/common/miiphyutil.c index 7e41957..08aa854 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -65,79 +65,6 @@ void miiphy_init(void) current_mii = NULL; }
-static int legacy_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) -{ - unsigned short val; - int ret; - struct legacy_mii_dev *ldev = bus->priv; - - ret = ldev->read(bus->name, addr, reg, &val); - - return ret ? -1 : (int)val; -} - -static int legacy_miiphy_write(struct mii_dev *bus, int addr, int devad, - int reg, u16 val) -{ - struct legacy_mii_dev *ldev = bus->priv; - - return ldev->write(bus->name, addr, reg, val); -} - -/***************************************************************************** - * - * Register read and write MII access routines for the device <name>. - * This API is now deprecated. Please use mdio_alloc and mdio_register, instead. - */ -void miiphy_register(const char *name, - int (*read)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value), - int (*write)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value)) -{ - struct mii_dev *new_dev; - struct legacy_mii_dev *ldev; - - BUG_ON(strlen(name) >= MDIO_NAME_LEN); - - /* check if we have unique name */ - new_dev = miiphy_get_dev_by_name(name); - if (new_dev) { - printf("miiphy_register: non unique device name '%s'\n", name); - return; - } - - /* allocate memory */ - new_dev = mdio_alloc(); - ldev = malloc(sizeof(*ldev)); - - if (new_dev == NULL || ldev == NULL) { - printf("miiphy_register: cannot allocate memory for '%s'\n", - name); - free(ldev); - mdio_free(new_dev); - return; - } - - /* initalize mii_dev struct fields */ - new_dev->read = legacy_miiphy_read; - new_dev->write = legacy_miiphy_write; - strncpy(new_dev->name, name, MDIO_NAME_LEN); - new_dev->name[MDIO_NAME_LEN - 1] = 0; - ldev->read = read; - ldev->write = write; - new_dev->priv = ldev; - - debug("miiphy_register: added '%s', read=0x%08lx, write=0x%08lx\n", - new_dev->name, ldev->read, ldev->write); - - /* add it to the list */ - list_add_tail(&new_dev->link, &mii_devs); - - if (!current_mii) - current_mii = new_dev; -} - struct mii_dev *mdio_alloc(void) { struct mii_dev *bus; diff --git a/include/miiphy.h b/include/miiphy.h index 8a55a13..83141b4 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -21,13 +21,6 @@ #include <net.h> #include <phy.h>
-struct legacy_mii_dev { - int (*read)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); - int (*write)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); -}; - int miiphy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value); int miiphy_write(const char *devname, unsigned char addr, unsigned char reg, @@ -44,12 +37,6 @@ int miiphy_link(const char *devname, unsigned char addr);
void miiphy_init(void);
-void miiphy_register(const char *devname, - int (*read)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value), - int (*write)(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value)); - int miiphy_set_current_dev(const char *devname); const char *miiphy_get_current_dev(void); struct mii_dev *mdio_get_current_dev(void);
On Mon, Aug 08, 2016 at 11:28:36AM -0500, Joe Hershberger wrote:
This is an effort to migrate closer to the phylib approach so that a new DM approach can be developed from a single starting point. The more of this legacy code that can be removed, the easier it will be to move forward.
Hi Joe,
It was nice to see spatch put to work. However davinci_emac crashes U-Boot now. It is an invasive patch so it might take time to check everything is in order, so unless you already have a follow-up series I can send in a trivial patch just now to fix that for davinci_emac.
Karl
Changes in v2:
- Added a blank line
- Run against the current master which adds one more driver to convert (drivers/net/macb.c)
- Use an updated spatch that does not put closing paren on the next line
Joe Hershberger (5): scripts: Add a cocci patch for miiphy_register net: mii: Use spatch to update miiphy_register net: mii: Changes not made by spatch net: mii: Fix changes made by spatch net: mii: Clean up legacy glue that is not used
arch/m68k/include/asm/fec.h | 9 +- arch/mips/mach-au1x00/au1x00_eth.c | 25 +++-- arch/powerpc/cpu/mpc8260/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 13 ++- arch/powerpc/cpu/mpc8xx/fec.c | 40 +++++--- arch/powerpc/cpu/ppc4xx/miiphy.c | 11 +-- board/gdsys/405ep/io.c | 13 ++- board/gdsys/405ep/iocon.c | 27 +++++- board/gdsys/405ex/io64.c | 25 ++++- board/gdsys/mpc8308/hrcon.c | 27 +++++- board/gdsys/mpc8308/strider.c | 27 +++++- common/miiphyutil.c | 73 --------------- drivers/net/4xx_enet.c | 20 ++-- drivers/net/armada100_fec.c | 33 ++++--- drivers/net/at91_emac.c | 28 ++++-- drivers/net/bcm-sf2-eth-gmac.c | 18 ++-- drivers/net/bcm-sf2-eth.c | 13 ++- drivers/net/bcm-sf2-eth.h | 8 +- drivers/net/bfin_mac.c | 43 ++++++--- drivers/net/davinci_emac.c | 34 +++++-- drivers/net/eepro100.c | 34 ++++--- drivers/net/enc28j60.c | 26 ++++-- drivers/net/ep93xx_eth.c | 40 +++++--- drivers/net/fsl_mcdmafec.c | 13 ++- drivers/net/ftmac110.c | 35 ++++--- drivers/net/lpc32xx_eth.c | 52 +++++------ drivers/net/macb.c | 46 +++++++--- drivers/net/mcffec.c | 13 ++- drivers/net/mcfmii.c | 19 ++-- drivers/net/mpc512x_fec.c | 30 ++++-- drivers/net/mpc5xxx_fec.c | 30 ++++-- drivers/net/mvgbe.c | 33 +++++-- drivers/net/phy/miiphybb.c | 25 ++--- drivers/net/sh_eth.c | 12 ++- drivers/net/smc911x.c | 35 +++++-- drivers/qe/uec.c | 32 ++++--- include/miiphy.h | 20 +--- scripts/coccinelle/net/mdio_register.cocci | 142 +++++++++++++++++++++++++++++ 38 files changed, 762 insertions(+), 375 deletions(-) create mode 100644 scripts/coccinelle/net/mdio_register.cocci
-- 1.7.11.5
Hi Karl,
Hi Joe,
That's a bummer. Is it a systemic problem that you expect to affect more drivers or is it something that is likely to only affect davinci?
Yes, please sent a patch to fix it up.
Thanks! -Joe
On Fri, Aug 19, 2016 at 01:48:00PM -0500, Joe Hershberger wrote:
Hi Karl,
Hi Joe,
It is likely to only affect davinci, just a mix up of the internal MDIO accessors return code (not in the changes made by spatch proper).
It would be better in the future in the davinci code to just use the same convention as the mdiodev accessors but I chose a non-invasive quick to check follow-up patch.
Rgds, Karl
participants (6)
Bin Meng
Joe Hershberger
Joe Hershberger
Karl Beldan
Stefan Roese
