[U-Boot] [PATCH 0/5] Convert Pico i.MX7 to DM
This series introduce DM Conversion for Pico i.MX7 Som and variant boards
Joris Offouga (5): Arm: imx7d-pico: Import all Linux device tree for Pico i.MX7D SOM pico-imx7d: defconfig: Add DT file hooks pico-imx7d: defconfig Enable DM gpio pinctrl and pinctrl_imx7 pico-imx7d: Convert DM MMC pico-imx7d: Increase u-boot size for dfu request
arch/arm/dts/imx7d-pico-hobbit.dts | 105 ++++ arch/arm/dts/imx7d-pico-pi.dts | 93 ++++ arch/arm/dts/imx7d-pico.dtsi | 590 +++++++++++++++++++++++ board/technexion/pico-imx7d/pico-imx7d.c | 42 +- board/technexion/pico-imx7d/spl.c | 38 ++ configs/pico-hobbit-imx7d_defconfig | 7 +- configs/pico-imx7d_defconfig | 7 +- configs/pico-pi-imx7d_defconfig | 7 +- include/configs/pico-imx7d.h | 2 +- 9 files changed, 848 insertions(+), 43 deletions(-) create mode 100644 arch/arm/dts/imx7d-pico-hobbit.dts create mode 100644 arch/arm/dts/imx7d-pico-pi.dts create mode 100644 arch/arm/dts/imx7d-pico.dtsi
This patch imports the Linux kernel base board imx7d-pico.dtsi, pi board imx7d-pico-pi.dts and hobbit board imx7d-pico-hobbit.dts from Linux v5.1-rc1.
Signed-off-by: Joris Offouga offougajoris@gmail.com --- arch/arm/dts/imx7d-pico-hobbit.dts | 105 ++++++ arch/arm/dts/imx7d-pico-pi.dts | 93 +++++ arch/arm/dts/imx7d-pico.dtsi | 586 +++++++++++++++++++++++++++++ 3 files changed, 784 insertions(+) create mode 100644 arch/arm/dts/imx7d-pico-hobbit.dts create mode 100644 arch/arm/dts/imx7d-pico-pi.dts create mode 100644 arch/arm/dts/imx7d-pico.dtsi
diff --git a/arch/arm/dts/imx7d-pico-hobbit.dts b/arch/arm/dts/imx7d-pico-hobbit.dts new file mode 100644 index 0000000000..98604f0fa6 --- /dev/null +++ b/arch/arm/dts/imx7d-pico-hobbit.dts @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// +// Copyright 2017 NXP + +#include "imx7d-pico.dtsi" + +/ { + model = "TechNexion PICO-IMX7D Board using Hobbit baseboard"; + compatible = "technexion,imx7d-pico-hobbit", "fsl,imx7d"; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led { + label = "gpio-led"; + gpios = <&gpio2 13 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "imx7-sgtl5000"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&dailink_master>; + simple-audio-card,frame-master = <&dailink_master>; + simple-audio-card,cpu { + sound-dai = <&sai1>; + }; + + dailink_master: simple-audio-card,codec { + sound-dai = <&sgtl5000>; + clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>; + }; + }; +}; + +&i2c1 { + sgtl5000: codec@a { + #sound-dai-cells = <0>; + reg = <0x0a>; + compatible = "fsl,sgtl5000"; + clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>; + VDDA-supply = <®_2p5v>; + VDDIO-supply = <®_vref_1v8>; + }; +}; + +&i2c4 { + status = "okay"; + + adc081c: adc@50 { + compatible = "ti,adc081c"; + reg = <0x50>; + vref-supply = <®_3p3v>; + }; +}; + +&ecspi3 { + ads7846@0 { + reg = <0>; + compatible = "ti,ads7846"; + interrupt-parent = <&gpio2>; + interrupts = <7 0>; + spi-max-frequency = <1000000>; + pendown-gpio = <&gpio2 7 0>; + vcc-supply = <®_3p3v>; + ti,x-min = /bits/ 16 <0>; + ti,x-max = /bits/ 16 <4095>; + ti,y-min = /bits/ 16 <0>; + ti,y-max = /bits/ 16 <4095>; + ti,pressure-max = /bits/ 16 <1024>; + ti,x-plate-ohms = /bits/ 16 <90>; + ti,y-plate-ohms = /bits/ 16 <90>; + ti,debounce-max = /bits/ 16 <70>; + ti,debounce-tol = /bits/ 16 <3>; + ti,debounce-rep = /bits/ 16 <2>; + ti,settle-delay-usec = /bits/ 16 <150>; + wakeup-source; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX7D_PAD_EPDC_DATA00__GPIO2_IO0 0x14 + MX7D_PAD_EPDC_DATA01__GPIO2_IO1 0x14 + MX7D_PAD_EPDC_DATA02__GPIO2_IO2 0x14 + MX7D_PAD_EPDC_DATA03__GPIO2_IO3 0x14 + MX7D_PAD_EPDC_DATA05__GPIO2_IO5 0x14 + MX7D_PAD_EPDC_DATA12__GPIO2_IO12 0x14 + MX7D_PAD_EPDC_DATA07__GPIO2_IO7 0x14 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX7D_PAD_EPDC_DATA13__GPIO2_IO13 0x14 + >; + }; +}; \ No newline at end of file diff --git a/arch/arm/dts/imx7d-pico-pi.dts b/arch/arm/dts/imx7d-pico-pi.dts new file mode 100644 index 0000000000..66ca59045f --- /dev/null +++ b/arch/arm/dts/imx7d-pico-pi.dts @@ -0,0 +1,93 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// +// Copyright 2017 NXP + +#include "imx7d-pico.dtsi" + +/ { + model = "TechNexion PICO-IMX7D Board and PI baseboard"; + compatible = "technexion,imx7d-pico-pi", "fsl,imx7d"; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led { + label = "gpio-led"; + gpios = <&gpio2 6 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "imx7-sgtl5000"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&dailink_master>; + simple-audio-card,frame-master = <&dailink_master>; + simple-audio-card,cpu { + sound-dai = <&sai1>; + }; + + dailink_master: simple-audio-card,codec { + sound-dai = <&sgtl5000>; + clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>; + }; + }; +}; + +&i2c1 { + sgtl5000: codec@a { + #sound-dai-cells = <0>; + reg = <0x0a>; + compatible = "fsl,sgtl5000"; + clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>; + VDDA-supply = <®_2p5v>; + VDDIO-supply = <®_vref_1v8>; + }; +}; + +&i2c4 { + polytouch: touchscreen@38 { + compatible = "edt,edt-ft5x06"; + reg = <0x38>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_touchscreen>; + interrupt-parent = <&gpio2>; + interrupts = <13 IRQ_TYPE_EDGE_FALLING>; + reset-gpios = <&gpio2 4 GPIO_ACTIVE_LOW>; + touchscreen-size-x = <800>; + touchscreen-size-y = <480>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX7D_PAD_EPDC_DATA00__GPIO2_IO0 0x14 + MX7D_PAD_EPDC_DATA01__GPIO2_IO1 0x14 + MX7D_PAD_EPDC_DATA02__GPIO2_IO2 0x14 + MX7D_PAD_EPDC_DATA03__GPIO2_IO3 0x14 + MX7D_PAD_EPDC_DATA05__GPIO2_IO5 0x14 + MX7D_PAD_EPDC_DATA12__GPIO2_IO12 0x14 + MX7D_PAD_EPDC_DATA07__GPIO2_IO7 0x14 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX7D_PAD_EPDC_DATA06__GPIO2_IO6 0x14 + >; + }; + + pinctrl_touchscreen: touchscreengrp { + fsl,pins = < + MX7D_PAD_EPDC_DATA04__GPIO2_IO4 0x14 + MX7D_PAD_EPDC_DATA13__GPIO2_IO13 0x14 + >; + }; + +}; \ No newline at end of file diff --git a/arch/arm/dts/imx7d-pico.dtsi b/arch/arm/dts/imx7d-pico.dtsi new file mode 100644 index 0000000000..d1a4079570 --- /dev/null +++ b/arch/arm/dts/imx7d-pico.dtsi @@ -0,0 +1,586 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// +// Copyright 2017 NXP + +/dts-v1/; + +#include "imx7d.dtsi" + + +/ { + /* Will be filled by the bootloader */ + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0>; + }; + + reg_wlreg_on: regulator-wlreg_on { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_wlreg_on>; + regulator-name = "wlreg_on"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 16 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_2p5v: regulator-2p5v { + compatible = "regulator-fixed"; + regulator-name = "2P5V"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-always-on; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_usb_otg1_vbus: regulator-usb-otg1-vbus { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg1_pwr>; + compatible = "regulator-fixed"; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 5 GPIO_ACTIVE_LOW>; + }; + + reg_usb_otg2_vbus: regulator-usb-otg2-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_otg2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_vref_1v8: regulator-vref-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vref-1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + usdhc2_pwrseq: usdhc2_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&clks IMX7D_CLKO2_ROOT_DIV>; + clock-names = "ext_clock"; + }; +}; + +&clks { + assigned-clocks = <&clks IMX7D_CLKO2_ROOT_SRC>, + <&clks IMX7D_CLKO2_ROOT_DIV>; + assigned-clock-parents = <&clks IMX7D_CKIL>; + assigned-clock-rates = <0>, <32768>; +}; + +&ecspi3 { + cs-gpios = <&gpio4 11 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi3>; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + assigned-clocks = <&clks IMX7D_ENET1_TIME_ROOT_SRC>, + <&clks IMX7D_ENET1_TIME_ROOT_CLK>; + assigned-clock-parents = <&clks IMX7D_PLL_ENET_MAIN_100M_CLK>; + assigned-clock-rates = <0>, <100000000>; + phy-mode = "rgmii"; + phy-handle = <ðphy0>; + fsl,magic-packet; + phy-reset-gpios = <&gpio6 11 GPIO_ACTIVE_LOW>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + status = "okay"; + }; + }; +}; + +&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_can1>; + status = "okay"; +}; + +&flexcan2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_can2>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; + + pmic: pfuze3000@8 { + compatible = "fsl,pfuze3000"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1a { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + /* use sw1c_reg to align with pfuze100/pfuze200 */ + sw1c_reg: sw1b { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1475000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1850000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3a_reg: sw3 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1650000>; + regulator-boot-on; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen2_reg: vldo2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vccsd { + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen4_reg: v33 { + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vldo4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&sai1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai1>; + assigned-clocks = <&clks IMX7D_SAI1_ROOT_SRC>, + <&clks IMX7D_SAI1_ROOT_CLK>; + assigned-clock-parents = <&clks IMX7D_PLL_AUDIO_POST_DIV>; + assigned-clock-rates = <0>, <24576000>; + status = "okay"; +}; + + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "okay"; +}; + +&pwm2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm2>; + status = "okay"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; +}; + +&pwm4 { /* Backlight */ + status = "okay"; +}; + +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart5>; + assigned-clocks = <&clks IMX7D_UART5_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_PLL_SYS_MAIN_240M_CLK>; + status = "okay"; +}; + +&uart6 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart6>; + assigned-clocks = <&clks IMX7D_UART6_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_OSC_24M_CLK>; + uart-has-rtscts; + status = "okay"; +}; + +&uart7 { /* Bluetooth */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart7>; + assigned-clocks = <&clks IMX7D_UART7_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_PLL_SYS_MAIN_240M_CLK>; + uart-has-rtscts; + status = "okay"; +}; + +&usbotg1 { + vbus-supply = <®_usb_otg1_vbus>; + status = "okay"; +}; + +&usbotg2 { + vbus-supply = <®_usb_otg2_vbus>; + dr_mode = "host"; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + cd-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; + bus-width = <4>; + tuning-step = <2>; + vmmc-supply = <®_3p3v>; + wakeup-source; + no-1-8-v; + keep-power-in-suspend; + status = "okay"; +}; + +&usdhc2 { /* Wifi SDIO */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2 &pinctrl_wifi_clk>; + no-1-8-v; + non-removable; + keep-power-in-suspend; + wakeup-source; + vmmc-supply = <®_wlreg_on>; + mmc-pwrseq = <&usdhc2_pwrseq>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + assigned-clocks = <&clks IMX7D_USDHC3_ROOT_CLK>; + assigned-clock-rates = <400000000>; + bus-width = <8>; + no-1-8-v; + fsl,tuning-step = <2>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_ecspi3: ecspi3grp { + fsl,pins = < + MX7D_PAD_I2C1_SCL__ECSPI3_MISO 0x2 + MX7D_PAD_I2C1_SDA__ECSPI3_MOSI 0x2 + MX7D_PAD_I2C2_SCL__ECSPI3_SCLK 0x2 + MX7D_PAD_I2C2_SDA__GPIO4_IO11 0x14 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX7D_PAD_UART1_TX_DATA__I2C1_SDA 0x4000007f + MX7D_PAD_UART1_RX_DATA__I2C1_SCL 0x4000007f + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX7D_PAD_UART2_TX_DATA__I2C2_SDA 0x4000007f + MX7D_PAD_UART2_RX_DATA__I2C2_SCL 0x4000007f + >; + }; + + pinctrl_enet1: enet1grp { + fsl,pins = < + MX7D_PAD_SD2_CD_B__ENET1_MDIO 0x3 + MX7D_PAD_SD2_WP__ENET1_MDC 0x3 + MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC 0x1 + MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 0x1 + MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 0x1 + MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 0x1 + MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 0x1 + MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL 0x1 + MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC 0x1 + MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 0x1 + MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 0x1 + MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 0x1 + MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 0x1 + MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL 0x1 + MX7D_PAD_SD3_RESET_B__GPIO6_IO11 0x1 /* Ethernet reset */ + >; + }; + + pinctrl_can1: can1frp { + fsl,pins = < + MX7D_PAD_SAI1_RX_DATA__FLEXCAN1_RX 0x59 + MX7D_PAD_SAI1_TX_BCLK__FLEXCAN1_TX 0x59 + >; + }; + + pinctrl_can2: can2frp { + fsl,pins = < + MX7D_PAD_SAI1_TX_SYNC__FLEXCAN2_RX 0x59 + MX7D_PAD_SAI1_TX_DATA__FLEXCAN2_TX 0x59 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX7D_PAD_SAI1_RX_BCLK__I2C4_SDA 0x4000007f + MX7D_PAD_SAI1_RX_SYNC__I2C4_SCL 0x4000007f + >; + }; + + pinctrl_pwm1: pwm1 { + fsl,pins = < + MX7D_PAD_GPIO1_IO08__PWM1_OUT 0x7f + >; + }; + + pinctrl_pwm2: pwm2 { + fsl,pins = < + MX7D_PAD_GPIO1_IO09__PWM2_OUT 0x7f + >; + }; + + pinctrl_pwm3: pwm3 { + fsl,pins = < + MX7D_PAD_GPIO1_IO10__PWM3_OUT 0x7f + >; + }; + + pinctrl_reg_wlreg_on: regregongrp { + fsl,pins = < + MX7D_PAD_ECSPI1_SCLK__GPIO4_IO16 0x59 + >; + }; + + pinctrl_sai1: sai1grp { + fsl,pins = < + MX7D_PAD_ENET1_RX_CLK__SAI1_TX_BCLK 0x1f + MX7D_PAD_ENET1_CRS__SAI1_TX_SYNC 0x1f + MX7D_PAD_ENET1_COL__SAI1_TX_DATA0 0x30 + MX7D_PAD_ENET1_TX_CLK__SAI1_RX_DATA0 0x1f + >; + }; + + pinctrl_uart5: uart5grp { + fsl,pins = < + MX7D_PAD_I2C4_SDA__UART5_DCE_TX 0x79 + MX7D_PAD_I2C4_SCL__UART5_DCE_RX 0x79 + >; + }; + + pinctrl_uart6: uart6grp { + fsl,pins = < + MX7D_PAD_EPDC_DATA08__UART6_DCE_RX 0x79 + MX7D_PAD_EPDC_DATA09__UART6_DCE_TX 0x79 + MX7D_PAD_EPDC_DATA10__UART6_DCE_RTS 0x79 + MX7D_PAD_EPDC_DATA11__UART6_DCE_CTS 0x79 + >; + }; + + pinctrl_uart7: uart7grp { + fsl,pins = < + MX7D_PAD_ECSPI2_MOSI__UART7_DCE_TX 0x79 + MX7D_PAD_ECSPI2_SCLK__UART7_DCE_RX 0x79 + MX7D_PAD_ECSPI2_SS0__UART7_DCE_CTS 0x79 + MX7D_PAD_ECSPI2_MISO__UART7_DCE_RTS 0x79 + >; + }; + + pinctrl_usbotg1_pwr: usbotg_pwr { + fsl,pins = < + MX7D_PAD_UART3_TX_DATA__GPIO4_IO5 0x14 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX7D_PAD_SD1_CMD__SD1_CMD 0x59 + MX7D_PAD_SD1_CLK__SD1_CLK 0x19 + MX7D_PAD_SD1_DATA0__SD1_DATA0 0x59 + MX7D_PAD_SD1_DATA1__SD1_DATA1 0x59 + MX7D_PAD_SD1_DATA2__SD1_DATA2 0x59 + MX7D_PAD_SD1_DATA3__SD1_DATA3 0x59 + MX7D_PAD_SD1_CD_B__GPIO5_IO0 0x15 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp_100mhz { + fsl,pins = < + MX7D_PAD_SD1_CMD__SD1_CMD 0x5a + MX7D_PAD_SD1_CLK__SD1_CLK 0x1a + MX7D_PAD_SD1_DATA0__SD1_DATA0 0x5a + MX7D_PAD_SD1_DATA1__SD1_DATA1 0x5a + MX7D_PAD_SD1_DATA2__SD1_DATA2 0x5a + MX7D_PAD_SD1_DATA3__SD1_DATA3 0x5a + MX7D_PAD_SD1_CD_B__GPIO5_IO0 0x15 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp_200mhz { + fsl,pins = < + MX7D_PAD_SD1_CMD__SD1_CMD 0x5b + MX7D_PAD_SD1_CLK__SD1_CLK 0x1b + MX7D_PAD_SD1_DATA0__SD1_DATA0 0x5b + MX7D_PAD_SD1_DATA1__SD1_DATA1 0x5b + MX7D_PAD_SD1_DATA2__SD1_DATA2 0x5b + MX7D_PAD_SD1_DATA3__SD1_DATA3 0x5b + MX7D_PAD_SD1_CD_B__GPIO5_IO0 0x15 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX7D_PAD_SD2_CMD__SD2_CMD 0x59 + MX7D_PAD_SD2_CLK__SD2_CLK 0x19 + MX7D_PAD_SD2_DATA0__SD2_DATA0 0x59 + MX7D_PAD_SD2_DATA1__SD2_DATA1 0x59 + MX7D_PAD_SD2_DATA2__SD2_DATA2 0x59 + MX7D_PAD_SD2_DATA3__SD2_DATA3 0x59 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x59 + MX7D_PAD_SD3_CLK__SD3_CLK 0x19 + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x59 + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x59 + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x59 + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x59 + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x59 + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x59 + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x59 + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x59 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp_100mhz { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x5a + MX7D_PAD_SD3_CLK__SD3_CLK 0x1a + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x5a + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x5a + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x5a + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x5a + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x5a + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x5a + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x5a + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x5a + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp_200mhz { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x5b + MX7D_PAD_SD3_CLK__SD3_CLK 0x1b + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x5b + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x5b + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x5b + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x5b + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x5b + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x5b + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x5b + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x5b + >; + }; +}; + +&iomuxc_lpsr { + pinctrl_wifi_clk: wificlkgrp { + fsl,pins = < + MX7D_PAD_LPSR_GPIO1_IO03__CCM_CLKO2 0x7d + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX7D_PAD_LPSR_GPIO1_IO00__WDOG1_WDOG_B 0x74 + >; + }; +}; \ No newline at end of file
Tested-by: Fabio Estevam festevam@gmail.com
The dtb files are not included on the Makefile, so if we try to build the image it fails.
This is not necessary since we are using the CONFIG_DEFAULT_FDT_FILE.
Sorry indeed it must be added I will send a v2 with this change
Best Regards,
Joris
This patch adds DT file hooks for Pico i.MX7D SOM and variant boards
Signed-off-by: Joris Offouga offougajoris@gmail.com --- configs/pico-hobbit-imx7d_defconfig | 3 ++- configs/pico-imx7d_defconfig | 3 ++- configs/pico-pi-imx7d_defconfig | 3 ++- 3 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index f58d5171ba..75eab28aba 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -16,6 +16,8 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-hobbit.dtb" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-hoobit" CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y @@ -58,4 +60,3 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_VIDEO=y -CONFIG_OF_LIBFDT=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 7e13923cb4..13704941cf 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -16,6 +16,8 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="ask" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y @@ -58,4 +60,3 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_VIDEO=y -CONFIG_OF_LIBFDT=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index c8ac2ffd5f..05d5fe5175 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -16,6 +16,8 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-pi.dtb" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y @@ -58,4 +60,3 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_VIDEO=y -CONFIG_OF_LIBFDT=y
This patch is necessary for convert this board to dm driver model
DM GPIO requires gpio_request() to be called explicitly before doing any gpio operation
Signed-off-by: Joris Offouga offougajoris@gmail.com --- board/technexion/pico-imx7d/pico-imx7d.c | 4 +++- configs/pico-hobbit-imx7d_defconfig | 3 +++ configs/pico-imx7d_defconfig | 3 +++ configs/pico-pi-imx7d_defconfig | 3 +++ 4 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index 767d13dfe5..3b9be45587 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -165,7 +165,7 @@ static iomux_v3_cfg_t const fec1_pads[] = { static void setup_iomux_fec(void) { imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); - + gpio_request(FEC1_RST_GPIO, "phy_rst"); gpio_direction_output(FEC1_RST_GPIO, 0); udelay(500); gpio_set_value(FEC1_RST_GPIO, 1); @@ -291,6 +291,8 @@ static iomux_v3_cfg_t const lcd_pads[] = { void setup_lcd(void) { imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); + gpio_request(IMX_GPIO_NR(1, 11), "lcd_brightness"); + gpio_request(IMX_GPIO_NR(1, 6), "lcd_enable"); /* Set Brightness to high */ gpio_direction_output(IMX_GPIO_NR(1, 11) , 1); /* Set LCD enable to high */ diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 75eab28aba..a830aa85a2 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -27,6 +27,9 @@ CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_CMD_BOOTMENU=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_DM_GPIO=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_DFU=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 13704941cf..54d7da8768 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -27,6 +27,9 @@ CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_CMD_BOOTMENU=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_DM_GPIO=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_DFU=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 05d5fe5175..662492aae1 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -27,6 +27,9 @@ CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_CMD_BOOTMENU=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_DM_GPIO=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_DFU=y
This patch enable convert DM MMC for imx7d-pico board and variant.
Before the DM conversion only usdhc3 was enabled and therefore it appeared as MMC 0 to u-boot. After enabling MMC DM though usdhc3 defaults to MMC 2, which left unattended would drive changes to existing pico-pi bootscripts and environment variables that rely on mmc 0.
Setup the alias of mmc0 and usdhc3 so that existing pico-imx7d boot code will work unmodified.
When converting to DM_MMC it is necessary that SPL initializes eMMC by itself, so move the original eMMC initialization from U-Boot proper to SPL.
Signed-off-by: Joris Offouga offougajoris@gmail.com Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/imx7d-pico.dtsi | 4 +++ board/technexion/pico-imx7d/pico-imx7d.c | 38 ------------------------ board/technexion/pico-imx7d/spl.c | 38 ++++++++++++++++++++++++ configs/pico-hobbit-imx7d_defconfig | 1 + configs/pico-imx7d_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 1 + 6 files changed, 45 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/imx7d-pico.dtsi b/arch/arm/dts/imx7d-pico.dtsi index d1a4079570..9f1fe683db 100644 --- a/arch/arm/dts/imx7d-pico.dtsi +++ b/arch/arm/dts/imx7d-pico.dtsi @@ -8,6 +8,10 @@
/ { + aliases { + mmc0 = &usdhc3; + }; + /* Will be filled by the bootloader */ memory@80000000 { device_type = "memory"; diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index 3b9be45587..e63b19df6e 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -13,10 +13,8 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/io.h> #include <common.h> -#include <fsl_esdhc.h> #include <i2c.h> #include <miiphy.h> -#include <mmc.h> #include <netdev.h> #include <usb.h> #include <power/pmic.h> @@ -28,9 +26,6 @@ DECLARE_GLOBAL_DATA_PTR; #define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | \ PAD_CTL_PUS_PU100KOHM | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ - PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) - #define ENET_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) #define ENET_PAD_CTRL_MII (PAD_CTL_DSE_3P3V_32OHM)
@@ -126,20 +121,6 @@ static iomux_v3_cfg_t const uart5_pads[] = { MX7D_PAD_I2C4_SDA__UART5_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), };
-static iomux_v3_cfg_t const usdhc3_emmc_pads[] = { - MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_GPIO1_IO14__GPIO1_IO14 | MUX_PAD_CTRL(USDHC_PAD_CTRL), -}; - #ifdef CONFIG_FEC_MXC static iomux_v3_cfg_t const fec1_pads[] = { MX7D_PAD_SD2_CD_B__ENET1_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), @@ -224,25 +205,6 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads)); }
-static struct fsl_esdhc_cfg usdhc_cfg[1] = { - {USDHC3_BASE_ADDR}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - /* Assume uSDHC3 emmc is always present */ - return 1; -} - -int board_mmc_init(bd_t *bis) -{ - imx_iomux_v3_setup_multiple_pads( - usdhc3_emmc_pads, ARRAY_SIZE(usdhc3_emmc_pads)); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - - return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -} - int board_early_init_f(void) { setup_iomux_uart(); diff --git a/board/technexion/pico-imx7d/spl.c b/board/technexion/pico-imx7d/spl.c index 8c3443875d..92a46463db 100644 --- a/board/technexion/pico-imx7d/spl.c +++ b/board/technexion/pico-imx7d/spl.c @@ -5,11 +5,15 @@ * Author: Richard Hu richard.hu@technexion.com */
+#include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/crm_regs.h> +#include <asm/arch/mx7-pins.h> #include <asm/arch/sys_proto.h> #include <asm/arch-mx7/mx7-ddr.h> +#include <asm/mach-imx/iomux-v3.h> #include <asm/gpio.h> +#include <fsl_esdhc.h> #include <spl.h>
#if defined(CONFIG_SPL_BUILD) @@ -119,4 +123,38 @@ void board_init_f(ulong dummy) void reset_cpu(ulong addr) { } + +#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ + PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) + +static iomux_v3_cfg_t const usdhc3_pads[] = { + MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_GPIO1_IO14__GPIO1_IO14 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC3_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + /* Assume uSDHC3 emmc is always present */ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} #endif diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index a830aa85a2..918e4b9ec0 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y +CONFIG_DM_MMC=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 54d7da8768..818032ef18 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_BOOTMENU=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_DFU=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 662492aae1..926e70e9f6 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y +CONFIG_DM_MMC=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y
After DM conversion, the size of U-Boot binary to increase. Previous size is 480K after DM Conversion the new size is 557K So it's necessary to increase the dfu request for store u-boot-dtb.img in eMMC.
Signed-off-by: Joris Offouga offougajoris@gmail.com --- include/configs/pico-imx7d.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 0f6d6b7894..04d316f113 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -46,7 +46,7 @@ #define CONFIG_DFU_ENV_SETTINGS \ "dfu_alt_info=" \ "spl raw 0x2 0x400;" \ - "u-boot raw 0x8a 0x400;" \ + "u-boot raw 0x8a 0x1000;" \ "/boot/zImage ext4 0 1;" \ "/boot/imx7d-pico-hobbit.dtb ext4 0 1;" \ "/boot/imx7d-pico-pi.dtb ext4 0 1;" \
Fabio Estevam
Joris Offouga
Otavio Salvador
