[U-Boot] [PATCH 0/2] Add fix for Pine64 gigabit throughput issues
The Pine64 has a known issue on gigabit links (see [1]); some boards suffer significant packet loss on Gigabit links. This patch sets the magical bits in CONFREG on the RTL8211E PHY to turn off the internal delay and do some other undocumented stuff.
[1] https://forum.pine64.org/showthread.php?tid=835&pid=19704#pid19704
Kyle Evans (2): net: phy: Add PHY_RTL8211E_PINE64_GIGABIT_FIX for realtek phys Configs: Use the newly added PHY_RTL8211E_PINE64_GIGABIT_FIX
configs/pine64_plus_defconfig | 2 ++ drivers/net/phy/Kconfig | 10 ++++++++++ drivers/net/phy/realtek.c | 34 ++++++++++++++++++++++++++++++++++ 3 files changed, 46 insertions(+)
Setting PHY_RTL8211E_PINE64_GIGABIT_FIX forces internal rx/tx delays off on the PHY, as well as flipping some magical undocumented bits. The magic number comes from the Pine64 engineering team, presumably as a proxy from Realtek. This configuration fixes the throughput on some Pine64 models. Packet loss of up to 60-70% has been observed without this.
Signed-off-by: Kyle Evans kevans@FreeBSD.org --- drivers/net/phy/Kconfig | 10 ++++++++++ drivers/net/phy/realtek.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 44 insertions(+)
diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index e32f1eb1c0..ad648a889d 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -114,6 +114,16 @@ config PHY_NATSEMI config PHY_REALTEK bool "Realtek Ethernet PHYs support"
+config RTL8211E_PINE64_GIGABIT_FIX + bool "Fix gigabit throughput on some Pine64+ models" + depends on PHY_REALTEK + help + Configure the Realtek RTL8211E found on some Pine64+ models differently to + fix throughput on Gigabit links, turning off all internal delays in the + process. The settings that this touches are not documented in the CONFREG + section of the RTL8211E datasheet, but come from Realtek by way of the + Pine64 engineering team. + config RTL8211X_PHY_FORCE_MASTER bool "Ethernet PHY RTL8211x: force 1000BASE-T master mode" depends on PHY_REALTEK diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index 6d917f86f4..d5c2a46c67 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -13,6 +13,7 @@ #include <phy.h>
#define PHY_RTL8211x_FORCE_MASTER BIT(1) +#define PHY_RTL8211E_PINE64_GIGABIT_FIX BIT(2)
#define PHY_AUTONEGOTIATE_TIMEOUT 5000
@@ -47,6 +48,13 @@ #define MIIM_RTL8211F_PHYSTAT_SPDDONE 0x0800 #define MIIM_RTL8211F_PHYSTAT_LINK 0x0004
+#define MIIM_RTL8211E_CONFREG 0x1c +#define MIIM_RTL8211E_CONFREG_TXD 0x0002 +#define MIIM_RTL8211E_CONFREG_RXD 0x0004 +#define MIIM_RTL8211E_CONFREG_MAGIC 0xb400 /* Undocumented */ + +#define MIIM_RTL8211E_EXT_PAGE_SELECT 0x1e + #define MIIM_RTL8211F_PAGE_SELECT 0x1f #define MIIM_RTL8211F_TX_DELAY 0x100 #define MIIM_RTL8211F_LCR 0x10 @@ -60,6 +68,15 @@ static int rtl8211b_probe(struct phy_device *phydev) return 0; }
+static int rtl8211e_probe(struct phy_device *phydev) +{ +#ifdef CONFIG_RTL8211E_PINE64_GIGABIT_FIX + phydev->flags |= PHY_RTL8211E_PINE64_GIGABIT_FIX; +#endif + + return 0; +} + /* RealTek RTL8211x */ static int rtl8211x_config(struct phy_device *phydev) { @@ -81,6 +98,22 @@ static int rtl8211x_config(struct phy_device *phydev) reg |= MIIM_RTL8211x_CTRL1000T_MASTER; phy_write(phydev, MDIO_DEVAD_NONE, MII_CTRL1000, reg); } + if (phydev->flags & PHY_RTL8211E_PINE64_GIGABIT_FIX) { + unsigned int reg; + + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211F_PAGE_SELECT, + 7); + phy_write(phydev, MDIO_DEVAD_NONE, + MIIM_RTL8211E_EXT_PAGE_SELECT, 0xa4); + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211E_CONFREG); + /* Ensure both internal delays are turned off */ + reg &= ~(MIIM_RTL8211E_CONFREG_TXD | MIIM_RTL8211E_CONFREG_RXD); + /* Flip the magic undocumented bits */ + reg |= MIIM_RTL8211E_CONFREG_MAGIC; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211E_CONFREG, reg); + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211F_PAGE_SELECT, + 0); + } /* read interrupt status just to clear it */ phy_read(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211x_PHY_INER);
@@ -279,6 +312,7 @@ static struct phy_driver RTL8211E_driver = { .uid = 0x1cc915, .mask = 0xffffff, .features = PHY_GBIT_FEATURES, + .probe = &rtl8211e_probe, .config = &rtl8211x_config, .startup = &rtl8211e_startup, .shutdown = &genphy_shutdown,
Hi Kyle,
https://patchwork.ozlabs.org/patch/873752/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
The Pine64+ uses a generic PHY driver, so flip it over to using the Realtek PHY driver to actually apply the RTL8211e fix.
Signed-off-by: Kyle Evans kevans@FreeBSD.org --- configs/pine64_plus_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 01ed23844b..149311f2c4 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -14,3 +14,5 @@ CONFIG_OF_LIST="sun50i-a64-pine64 sun50i-a64-pine64-plus" CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_PHY_REALTEK=y +CONFIG_RTL8211E_PINE64_GIGABIT_FIX=y
Hi Kyle,
https://patchwork.ozlabs.org/patch/873751/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
thanks for picking this up!
(CC:ing Icenowy, who was engaged in a Linux fix for this issue last year [2][3]. It's Chinese New Year though, so not sure how quickly she will answer).
Do you have a faulty board at hand? What is the actual effect in U-Boot? IIRC the bug "just" causes a slower connection in Gigabit mode, I am not sure we care so much in U-Boot? Or is it actually packages dropped, which is much more annoying without TCP covering up for this?
So if I remember the discussion correctly, this workaround affects the performance of the "good" boards. Have you checked this? There was a discussion last year [2][3] about how to fix this in Linux, which definitely involved some DT property (ideally in the PHY node). This would allow people to turn this on and off depending on their particular board. I am not sure this discussion lead anywhere, though, it might be a good idea to warm this up again.
Cheers, Andre.
[2] https://marc.info/?l=devicetree&m=149281711105621 [3] https://marc.info/?l=linux-netdev&m=150337466923103
On Thu, Feb 15, 2018 at 3:32 PM, André Przywara andre.przywara@arm.com wrote:
I do. =) My board in particular sees 60-70% packet loss without this, making netboot incredibly unreliable.
Unfortunately, I do not have a good board to test with, so I've no idea what it ends up doing to performance. for them.
I think rgmii-txid is actually not right for this. As an aside, I've pulled this value from [1]. The value they ended up going with (as seen in this patch and in [1]) turns off both TXID and RXID (IIRC, from the realtek documentation for this PHY), leaving us with just plain ol' "rgmii" with no internal delay at all. [1] also applies it unconditionally for pine64.
[1] https://github.com/longsleep/linux-pine64/commit/ffe3ca5be7682bbeb0fdadede29...
On Thu, Feb 15, 2018 at 9:32 PM, André Przywara andre.przywara@arm.com wrote:
So I have a "bad" board, the fix upstream took it from "basically not working at all" to vaguely but not with great speed be able to transfer data.
I've just tested this patch series on that board and was getting around 7MBps on Linux too. So presumably what ever bits that are being tweaked by this patch in u-boot aren't reset when the linux driver loads and it improved performance on Linux for me too.
From a netboot (untested) I would think this would be useful too.
Either way for the series: Tested-by: Peter Robinson pbrobinson@gmail.com
I'd like to dredge this one up again, since it's been a couple months and I still run this patch locally. =)
It does hurt measured performance, but for the broken set of boards this is absolutely necessary to function on a Gigabit link and it doesn't look like this broken set is really a minority given the number of complaints I've seen.
Thanks,
Kyle Evans
I see it upstream in master: http://git.denx.de/?p=u-boot.git;a=commit;h=dfa1a74045c930ec3935f748b0969f9d... http://git.denx.de/?p=u-boot.git;a=commit;h=66526e70381dbaad58533cfbd7bce07c...
What else is needed?
Ah, sorry about this, then. =) Clearly I need to grow a new pair of eyeballs and stop browsing out-of-date source trees.
was in at least 2018.05-rc2
participants (5)
André Przywara
Joe Hershberger
kevans@FreeBSD.org
Kyle Evans
Peter Robinson
