[U-Boot] [PATCH RESEND] DW SPI: Get clock value from Device Tree
Add option to set spi controller clock frequency via device tree using standard clock bindings. Old way of setting spi controller clock frequency (via implementation of 'cm_get_spi_controller_clk_hz' function in platform specific code) remains supported.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- Resending due to previously sent one was discarded by mailing list.
drivers/spi/designware_spi.c | 68 +++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 67 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 5aa507b..c70697e 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -11,6 +11,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <malloc.h> @@ -94,6 +95,7 @@ struct dw_spi_priv { void __iomem *regs; unsigned int freq; /* Default frequency */ unsigned int mode; + unsigned long bus_clk_rate;
int bits_per_word; u8 cs; /* chip select pin */ @@ -176,14 +178,78 @@ static void spi_hw_init(struct dw_spi_priv *priv) debug("%s: fifo_len=%d\n", __func__, priv->fifo_len); }
+/* + * cm_get_spi_controller_clk_hz function is old way to set spi controller + * frequency. If it isn't implemented and spi controller frequency isn't set via + * device tree we will get into next default function. + */ +__weak unsigned int cm_get_spi_controller_clk_hz(void) +{ + error("SPI clock is defined neither via device tree nor via cm_get_spi_controller_clk_hz!"); + + return 0; +} + +static int dw_spi_of_get_clk(struct udevice *bus) +{ +#if CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(CLK) + struct dw_spi_priv *priv = dev_get_priv(bus); + unsigned long clk_rate; + struct clk clk; + int ret; + + ret = clk_get_by_index(bus, 0, &clk); + if (ret) + return -EINVAL; + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) + return ret; + + clk_rate = clk_get_rate(&clk); + if (!clk_rate) + return -EINVAL; + + priv->bus_clk_rate = clk_rate; + + clk_free(&clk); + + return 0; +#endif + + return -ENOSYS; +} + +static int dw_spi_get_clk(struct udevice *bus) +{ + struct dw_spi_priv *priv = dev_get_priv(bus); + + /* Firstly try to get clock frequency from device tree */ + if (!dw_spi_of_get_clk(bus)) + return 0; + + /* In case of failure rollback to cm_get_spi_controller_clk_hz */ + priv->bus_clk_rate = cm_get_spi_controller_clk_hz(); + + if (!priv->bus_clk_rate) + return -EINVAL; + + return 0; +} + static int dw_spi_probe(struct udevice *bus) { struct dw_spi_platdata *plat = dev_get_platdata(bus); struct dw_spi_priv *priv = dev_get_priv(bus); + int ret;
priv->regs = plat->regs; priv->freq = plat->frequency;
+ ret = dw_spi_get_clk(bus); + if (ret) + return ret; + /* Currently only bits_per_word == 8 supported */ priv->bits_per_word = 8;
@@ -369,7 +435,7 @@ static int dw_spi_set_speed(struct udevice *bus, uint speed) spi_enable_chip(priv, 0);
/* clk_div doesn't support odd number */ - clk_div = cm_get_spi_controller_clk_hz() / speed; + clk_div = priv->bus_clk_rate / speed; clk_div = (clk_div + 1) & 0xfffe; dw_writel(priv, DW_SPI_BAUDR, clk_div);
Maybe you have any comments or remarks about this patch? And if you don't could you please apply it.
Thanks!
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 5aa507b..c70697e 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -11,6 +11,7 @@ */ #include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <malloc.h> @@ -94,6 +95,7 @@ struct dw_spi_priv { void __iomem *regs; unsigned int freq; /* Default frequency */ unsigned int mode;
- unsigned long bus_clk_rate;
int bits_per_word; u8 cs; /* chip select pin */ @@ -176,14 +178,78 @@ static void spi_hw_init(struct dw_spi_priv *priv) debug("%s: fifo_len=%d\n", __func__, priv->fifo_len); } +/*
- cm_get_spi_controller_clk_hz function is old way to set spi controller
- frequency. If it isn't implemented and spi controller frequency isn't set via
- device tree we will get into next default function.
- error("SPI clock is defined neither via device tree nor via cm_get_spi_controller_clk_hz!");
- struct dw_spi_priv *priv = dev_get_priv(bus);
- unsigned long clk_rate;
- struct clk clk;
- int ret;
- ret = clk_get_by_index(bus, 0, &clk);
- if (ret)
return -EINVAL;
- ret = clk_enable(&clk);
- if (ret && ret != -ENOSYS)
return ret;
- clk_rate = clk_get_rate(&clk);
- if (!clk_rate)
return -EINVAL;
- priv->bus_clk_rate = clk_rate;
- clk_free(&clk);
- return -ENOSYS;
- /* Firstly try to get clock frequency from device tree */
- if (!dw_spi_of_get_clk(bus))
- /* In case of failure rollback to cm_get_spi_controller_clk_hz */
- priv->bus_clk_rate = cm_get_spi_controller_clk_hz();
- if (!priv->bus_clk_rate)
return -EINVAL;
- int ret;
- ret = dw_spi_get_clk(bus);
- if (ret)
return ret;
/* Currently only bits_per_word == 8 supported */ priv->bits_per_word = 8; @@ -369,7 +435,7 @@ static int dw_spi_set_speed(struct udevice *bus, uint speed) spi_enable_chip(priv, 0); /* clk_div doesn't support odd number */
- clk_div = priv->bus_clk_rate / speed;
On Tue, Sep 26, 2017 at 6:40 PM, Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com wrote:
unsigned long bus_clk_rate; int bits_per_word; u8 cs; /* chip select pin */
struct clk clk;
int ret;
if (ret)
return -EINVAL;
return ret;
if (!clk_rate)
return -EINVAL;
Use bus_clk_rate instead of local clk_rate and disable the clk if it can't get the rate.
clk_free(&clk);
return -ENOSYS;
Why weak function, we can just return with error message since weak does the same job
thanks!
Hi Jagan, Thanks for respond, my comments are given inline.
Add option to set spi controller clock frequency via device tree using standard clock bindings. Old way of setting spi controller clock frequency (via implementation of 'cm_get_spi_controller_clk_hz' function in platform specific code) remains supported. Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 5aa507b..c70697e 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -11,6 +11,7 @@ +/*
+ return 0; +}
I used weak function for backward compatibility with the previous driver version: The previous driver version used cm_get_spi_controller_clk_hz() function which is set outside of designware_spi.c You can look at arch/arm/mach-socfpga/clock_manager_arria10.c arch/arm/mach-socfpga/clock_manager_gen5.c ... as examples.
So I define cm_get_spi_controller_clk_hz as weak in this driver to handle both use cases: 1) We set frequency via device tree and cm_get_spi_controller_clk_hz is NOT defined outside of designware_spi.c (new way) 2) We set frequency using cm_get_spi_controller_clk_hz, which is defined outside of designware_spi.c (old way)
I guess it is OK? -- Eugeniy Paltsev
Eugeniy Paltsev
Jagan Teki
