[PATCH] sandbox: disable tracing before unmapping RAM
Currently doing 'reset' command in sandbox with tracing enabled causes SIGSEV
``` Hit any key to stop autoboot: 0 => => => reset resetting ... Segmentation fault (core dumped)
Tracing callback uses RAM buffer for storing tracing reports, but state_uninit() function unmaps whole RAM, which causes SIGSEV on umapped memory inside tracing subsystem.
Fix it by disabling tracing before unmapping memory
Signed-off-by: Pavel Skripkin paskripkin@gmail.com --- arch/sandbox/cpu/state.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index 69da378ab5..d8d5da25b1 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <log.h> #include <os.h> +#include <trace.h> #include <asm/malloc.h> #include <asm/state.h> #include <asm/test.h> @@ -525,6 +526,9 @@ int state_uninit(void) if (state->jumped_fname) os_unlink(state->jumped_fname);
+ /* Disable tracing before unmapping RAM */ + trace_set_enabled(0); + os_free(state->state_fdt); os_free(state->ram_buf); memset(state, '\0', sizeof(*state));
Hi Simon,
Simon Glass sjg@chromium.org says:
Thank you for review!
+Tom, I guess?
@Tom, could you, please, pick following patch?
https://lists.denx.de/pipermail/u-boot/2023-April/515192.html
With regards, Pavel Skripkin
On Tue, Apr 25, 2023 at 04:43:19PM +0300, Pavel Skripkin wrote:
Hi Simon,
+Tom, I guess?
Simon takes sandbox patches himself and I've assigned this to him in patchwork, thanks for submitting the patch.
Hi Tom,
Tom Rini trini@konsulko.com says:
Ah, sorry for noise then. I am just unfamiliar with u-boot development process.
Thank you!
Hi Tom,
Thank you!
Applied to u-boot-dm, thanks!
Hi Pavel,
On Fri, 28 Apr 2023 at 13:20, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Thank you!
Note, I had to add a check for tracing being enabled, to avoid build errors.
Regards, SImon
Pavel Skripkin
