[U-Boot] [Patch alt] common/cmd_test: Avoid macro expansion
cmd_test.c adds "true" and "false" as new commands. We need to avoid macro expansion for U_BOOT_CMD.
Signed-off-by: York Sun yorksun@freescale.com --- This is alternative patch to fix macro expansion issue for cmd_test.c
common/cmd_test.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/common/cmd_test.c b/common/cmd_test.c index d4ec186..26a84af 100644 --- a/common/cmd_test.c +++ b/common/cmd_test.c @@ -144,6 +144,14 @@ static int do_test(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return expr; }
+#ifdef true +#undef true +#endif + +#ifdef false +#undef false +#endif + U_BOOT_CMD( test, CONFIG_SYS_MAXARGS, 1, do_test, "minimal test like /bin/sh",
Dear Mr.Sun,
We are using freescales bootloader as GPL, but as a Requirement Manager
https://wws.lg.com/global/support/opensource/opensourceList?superOsCategoryI d=CAT00000011&osCategoryId=CAT00000051
I am not sure to what extent we can use your freescale bootloader as GPL. We just use all the codes and call lgboot. Wonder if this is Copy Right Infringement? If we do use these codes don't we have to call this Freescale boot instead Of lgboot?
nandboot/ipl_startup.S nandboot/ipl_startup2.c platform/boot.c drivers/nfc/mxc_nfc.c nandboot/mxc_spl_startup.S
박상현 책임/Best of Regards Sam Park Senior Research Engineer sh1.park@lge.com| www.lge.com Tel:82-31-610-9580 M:82-10-2784-5903 Fax:82-31-610-9631
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of York Sun Sent: Friday, April 05, 2013 6:57 AM To: wd@denx.de Cc: trini@ti.com; u-boot@lists.denx.de; pali.rohar@gmail.com Subject: [U-Boot] [Patch alt] common/cmd_test: Avoid macro expansion
+#ifdef true +#undef true +#endif + +#ifdef false +#undef false +#endif + U_BOOT_CMD( test, CONFIG_SYS_MAXARGS, 1, do_test, "minimal test like /bin/sh", -- 1.7.9.5
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
sh1.park@lge.com
York Sun
