[PATCH] driver: pwm: pwm-imx: fix probing on imx6
U-Boot 2024.07 drops on aristainetos2 board the following warning:
Failed to enable per_clk
and bootlogo is not seen on LVDS display.
This patch uses old behaviour for systems without clock framework if CONFIG_CLK is not enabled.
Fixes: bfc778cb93a3 ("driver: pwm: pwm-imx: get and enable per/ipg clock using dm")
Signed-off-by: Heiko Schocher hs@denx.de ---
drivers/pwm/pwm-imx.c | 56 ++++++++++++++++++++++++------------------- 1 file changed, 31 insertions(+), 25 deletions(-)
diff --git a/drivers/pwm/pwm-imx.c b/drivers/pwm/pwm-imx.c index 8fbb40cc276..0237ee70977 100644 --- a/drivers/pwm/pwm-imx.c +++ b/drivers/pwm/pwm-imx.c @@ -160,7 +160,11 @@ int pwm_dm_imx_get_parms(struct imx_pwm_priv *priv, int period_ns, { unsigned long long c;
- c = clk_get_rate(&priv->per_clk); + if (IS_ENABLED(CONFIG_CLK)) + c = clk_get_rate(&priv->per_clk); + else + c = CFG_IMX6_PWM_PER_CLK; + c = c * period_ns; do_div(c, 1000000000); *period_c = c; @@ -227,43 +231,45 @@ static int imx_pwm_set_enable(struct udevice *dev, uint channel, bool enable)
static int imx_pwm_of_to_plat(struct udevice *dev) { - int ret; + int __maybe_unused ret; struct imx_pwm_priv *priv = dev_get_priv(dev);
priv->regs = dev_read_addr_ptr(dev);
- ret = clk_get_by_name(dev, "per", &priv->per_clk); - if (ret) { - printf("Failed to get per_clk\n"); - return ret; - } - - ret = clk_get_by_name(dev, "ipg", &priv->ipg_clk); - if (ret) { - printf("Failed to get ipg_clk\n"); - return ret; + if (IS_ENABLED(CONFIG_CLK)) { + ret = clk_get_by_name(dev, "per", &priv->per_clk); + if (ret) { + printf("Failed to get per_clk\n"); + return ret; + } + + ret = clk_get_by_name(dev, "ipg", &priv->ipg_clk); + if (ret) { + printf("Failed to get ipg_clk\n"); + return ret; + } } - return 0; }
static int imx_pwm_probe(struct udevice *dev) { - int ret; + int __maybe_unused ret; struct imx_pwm_priv *priv = dev_get_priv(dev);
- ret = clk_enable(&priv->per_clk); - if (ret) { - printf("Failed to enable per_clk\n"); - return ret; - } - - ret = clk_enable(&priv->ipg_clk); - if (ret) { - printf("Failed to enable ipg_clk\n"); - return ret; + if (IS_ENABLED(CONFIG_CLK)) { + ret = clk_enable(&priv->per_clk); + if (ret) { + printf("Failed to enable per_clk\n"); + return ret; + } + + ret = clk_enable(&priv->ipg_clk); + if (ret) { + printf("Failed to enable ipg_clk\n"); + return ret; + } } - return 0; }
Hi Heiko,
- if (IS_ENABLED(CONFIG_CLK))
Can we please use if (CONFIG_IS_ENABLED(CLK)) ? So it will also work with SPL. Thanks!
-- Anatolij
Hello Anatolij,
On 07.08.24 11:28, Anatolij Gustschin wrote:
Hi Heiko,
Yep, of course, changed locally... wait for some more comments before posting v2.
bye, Heiko
Anatolij Gustschin
Heiko Schocher
