[PATCH v6 00/19] riscv: Add Sipeed Maix support
This patch series adds support for Sipeed Maix boards and the Kendryte K210 CPU. Currently, only the Maix Bit V2.0 is supported, however other models are similar. This series depends on https://patchwork.ozlabs.org/patch/1215327/ (clk: Include missing headers for linux/clk-provider.h).
This will (hopefully) be the last version of this series adding any new functionality, other than that needed to fix the bugs below.
Known Bugs/Limitations: - Accessing the AI ram hangs, limiting available ram to 6M - The MMC cannot be accessed with the dw_spi driver - Trying to boot an image with bootm fails with ERROR: Failed to allocate 0x7d60 bytes below 0x80000000.
To flash u-boot to a maix bit, run kflash -tp /dev/<your tty here> -B bit_mic u-boot-dtb.bin
Boot output should look like the following:
U-Boot 2020.04-rc2-00087-g2221cc09c1-dirty (Feb 28 2020 - 13:53:09 -0500)
DRAM: 8 MiB In: serial@38000000 Out: serial@38000000 Err: serial@38000000 =>
Changes for v6: - Remove spi, pinmux, gpio, led, and wdt support --- to be added in separate patches - Rebase onto master - Clear IPIs before enabling them - Reorganize code so checkpatch errors less
Changes for v5: - Rebase onto master - Add pinconf support - Add gpio support - Store environment in spi flash - Group patches by prefix - Add additional documentation - Add SMP support - Add WDT support
Changes for v4: - Linted several patches - Updated the copyright year for several files - Added tests for syscon-reset, simple-pm-bus, and the pll calc_rate function - Added/updated documentation - Fixed SPI for the nor flash - Fixed PLLs not enabling/setting rate properly - RISCV_PRIV_1_9_1 now (un)defines all diferring CSRs, and also disables VM - More devicetree changes
Changes for v3: - Remove patch to set RV64I as default - Remove patch for a separate sysctl driver - Split off cpu frequency patch into its own series - Reorder support/devicetree patches to come last - Add patch for reset driver - Add simple-pm-bus for busses with their own clocks - Add additional documentation - Reword mcounteren patch to refer to the RISC-V priv spec 1.9.1 - Many devicetree changes - Switch to "make savedefconfig" to generate the config
Changes for v2: - Many bugfixes for the device tree - Modify the config to build without errors - Add support for keeping internal PLL frequencies in-range - Fix several rebase-induced artifacts
Sean Anderson (19): clk: Always use the supplied struct clk clk: Check that ops of composite clock components exist before calling clk: Unconditionally recursively en-/dis-able clocks clk: Add functions to register CCF clock structs clk: Add K210 pll support clk: Add a bypass clock for K210 clk: Add K210 clock support dm: Add support for simple-pm-bus dm: Fix error handling for dev_read_addr_ptr reset: Add generic reset driver lib: Always set errno in hcreate_r riscv: Add headers for asm/global_data.h riscv: Fix race conditions when initializing IPI riscv: Add option to support RISC-V privileged spec 1.9 riscv: Allow use of reset drivers riscv: Try to get cpu frequency from a "clocks" node if it exists riscv: Enable cpu clock if it is present riscv: Add device tree for K210 and Sipeed Maix BitM riscv: Add Sipeed Maix support
MAINTAINERS | 7 + arch/riscv/Kconfig | 14 + arch/riscv/cpu/cpu.c | 15 + arch/riscv/cpu/start.S | 2 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/k210-maix-bit.dts | 47 ++ arch/riscv/dts/k210.dtsi | 599 +++++++++++++++++ arch/riscv/include/asm/csr.h | 40 ++ arch/riscv/include/asm/global_data.h | 2 + arch/riscv/include/asm/smp.h | 43 ++ arch/riscv/lib/andes_plic.c | 34 +- arch/riscv/lib/reset.c | 2 + arch/riscv/lib/sbi_ipi.c | 5 + arch/riscv/lib/sifive_clint.c | 33 +- arch/riscv/lib/smp.c | 56 +- arch/sandbox/dts/test.dts | 21 + arch/sandbox/include/asm/clk.h | 1 + board/sipeed/maix/Kconfig | 48 ++ board/sipeed/maix/MAINTAINERS | 11 + board/sipeed/maix/Makefile | 5 + board/sipeed/maix/maix.c | 54 ++ configs/sandbox_defconfig | 2 + configs/sipeed_maix_bitm_defconfig | 8 + doc/board/index.rst | 1 + doc/board/sipeed/index.rst | 9 + doc/board/sipeed/maix.rst | 298 +++++++++ .../bus/simple-pm-bus.txt | 44 ++ .../mfd/kendryte,k210-sysctl.txt | 33 + .../reset/syscon-reset.txt | 36 ++ doc/imx/clk/ccf.txt | 63 +- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/clk-composite.c | 145 +++-- drivers/clk/clk-divider.c | 62 +- drivers/clk/clk-fixed-factor.c | 3 +- drivers/clk/clk-gate.c | 44 +- drivers/clk/clk-mux.c | 12 +- drivers/clk/clk-uclass.c | 60 +- drivers/clk/imx/clk-gate2.c | 4 +- drivers/clk/imx/clk-imx8mp.c | 2 +- drivers/clk/kendryte/Kconfig | 12 + drivers/clk/kendryte/Makefile | 1 + drivers/clk/kendryte/bypass.c | 270 ++++++++ drivers/clk/kendryte/clk.c | 489 ++++++++++++++ drivers/clk/kendryte/pll.c | 601 ++++++++++++++++++ drivers/core/Kconfig | 7 + drivers/core/Makefile | 1 + drivers/core/read.c | 2 +- drivers/core/simple-pm-bus.c | 56 ++ drivers/cpu/riscv_cpu.c | 39 +- drivers/pinctrl/broadcom/pinctrl-bcm283x.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 2 +- drivers/reset/Kconfig | 5 + drivers/reset/Makefile | 1 + drivers/reset/reset-syscon.c | 80 +++ include/configs/sipeed-maix.h | 24 + include/dm/read.h | 4 +- include/dt-bindings/clock/k210-sysctl.h | 59 ++ include/dt-bindings/mfd/k210-sysctl.h | 38 ++ include/dt-bindings/reset/k210-sysctl.h | 38 ++ include/kendryte/bypass.h | 31 + include/kendryte/clk.h | 35 + include/kendryte/pll.h | 57 ++ include/linux/clk-provider.h | 9 + include/test/export.h | 16 + lib/hashtable.c | 8 +- test/dm/Makefile | 3 + test/dm/k210_pll.c | 96 +++ test/dm/simple-pm-bus.c | 45 ++ test/dm/syscon-reset.c | 58 ++ 70 files changed, 3673 insertions(+), 284 deletions(-) create mode 100644 arch/riscv/dts/k210-maix-bit.dts create mode 100644 arch/riscv/dts/k210.dtsi create mode 100644 board/sipeed/maix/Kconfig create mode 100644 board/sipeed/maix/MAINTAINERS create mode 100644 board/sipeed/maix/Makefile create mode 100644 board/sipeed/maix/maix.c create mode 100644 configs/sipeed_maix_bitm_defconfig create mode 100644 doc/board/sipeed/index.rst create mode 100644 doc/board/sipeed/maix.rst create mode 100644 doc/device-tree-bindings/bus/simple-pm-bus.txt create mode 100644 doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt create mode 100644 doc/device-tree-bindings/reset/syscon-reset.txt create mode 100644 drivers/clk/kendryte/Kconfig create mode 100644 drivers/clk/kendryte/Makefile create mode 100644 drivers/clk/kendryte/bypass.c create mode 100644 drivers/clk/kendryte/clk.c create mode 100644 drivers/clk/kendryte/pll.c create mode 100644 drivers/core/simple-pm-bus.c create mode 100644 drivers/reset/reset-syscon.c create mode 100644 include/configs/sipeed-maix.h create mode 100644 include/dt-bindings/clock/k210-sysctl.h create mode 100644 include/dt-bindings/mfd/k210-sysctl.h create mode 100644 include/dt-bindings/reset/k210-sysctl.h create mode 100644 include/kendryte/bypass.h create mode 100644 include/kendryte/clk.h create mode 100644 include/kendryte/pll.h create mode 100644 include/test/export.h create mode 100644 test/dm/k210_pll.c create mode 100644 test/dm/simple-pm-bus.c create mode 100644 test/dm/syscon-reset.c
CCF clocks should always use the struct clock passed to their methods for extracting the driver-specific clock information struct. Previously, many functions would use the clk->dev->priv if the device was bound. This could cause problems with composite clocks. The individual clocks in a composite clock did not have the ->dev field filled in. This was fine, because the device-specific clock information would be used. However, since there was no ->dev, there was no way to get the parent clock. This caused the recalc_rate method of the CCF divider clock to fail. One option would be to use the clk->priv field to get the composite clock and from there get the appropriate parent device. However, this would tie the implementation to the composite clock. In general, different devices should not rely on the contents of ->priv from another device.
The simple solution to this problem is to just always use the supplied struct clock. The composite clock now fills in the ->dev pointer of its child clocks. This allows child clocks to make calls like clk_get_parent() without issue.
imx avoided the above problem by using a custom get_rate function with composite clocks.
Signed-off-by: Sean Anderson seanga2@gmail.com Acked-by: Lukasz Majewski lukma@denx.de ---
Changes in v4: - Lint
Changes in v3: - Documented new assumptions in the CCF - Wrapped docs to 80 columns
doc/imx/clk/ccf.txt | 63 +++++++++++++++++----------------- drivers/clk/clk-composite.c | 7 ++++ drivers/clk/clk-divider.c | 6 ++-- drivers/clk/clk-fixed-factor.c | 3 +- drivers/clk/clk-gate.c | 6 ++-- drivers/clk/clk-mux.c | 12 +++---- drivers/clk/imx/clk-gate2.c | 4 +-- 7 files changed, 50 insertions(+), 51 deletions(-)
diff --git a/doc/imx/clk/ccf.txt b/doc/imx/clk/ccf.txt index 36b60dc438..e40ac360e8 100644 --- a/doc/imx/clk/ccf.txt +++ b/doc/imx/clk/ccf.txt @@ -1,42 +1,37 @@ Introduction: =============
-This documentation entry describes the Common Clock Framework [CCF] -port from Linux kernel (v5.1.12) to U-Boot. +This documentation entry describes the Common Clock Framework [CCF] port from +Linux kernel (v5.1.12) to U-Boot.
-This code is supposed to bring CCF to IMX based devices (imx6q, imx7 -imx8). Moreover, it also provides some common clock code, which would -allow easy porting of CCF Linux code to other platforms. +This code is supposed to bring CCF to IMX based devices (imx6q, imx7 imx8). +Moreover, it also provides some common clock code, which would allow easy +porting of CCF Linux code to other platforms.
Design decisions: =================
-* U-Boot's driver model [DM] for clk differs from Linux CCF. The most - notably difference is the lack of support for hierarchical clocks and - "clock as a manager driver" (single clock DTS node acts as a starting - point for all other clocks). +* U-Boot's driver model [DM] for clk differs from Linux CCF. The most notably + difference is the lack of support for hierarchical clocks and "clock as a + manager driver" (single clock DTS node acts as a starting point for all other + clocks).
-* The clk_get_rate() caches the previously read data if CLK_GET_RATE_NOCACHE - is not set (no need for recursive access). +* The clk_get_rate() caches the previously read data if CLK_GET_RATE_NOCACHE is + not set (no need for recursive access).
-* On purpose the "manager" clk driver (clk-imx6q.c) is not using large - table to store pointers to clocks - e.g. clk[IMX6QDL_CLK_USDHC2_SEL] = .... - Instead we use udevice's linked list for the same class (UCLASS_CLK). +* On purpose the "manager" clk driver (clk-imx6q.c) is not using large table to + store pointers to clocks - e.g. clk[IMX6QDL_CLK_USDHC2_SEL] = .... Instead we + use udevice's linked list for the same class (UCLASS_CLK).
Rationale: ---------- - When porting the code as is from Linux, one would need ~1KiB of RAM to - store it. This is way too much if we do plan to use this driver in SPL. + When porting the code as is from Linux, one would need ~1KiB of RAM to store + it. This is way too much if we do plan to use this driver in SPL.
* The "central" structure of this patch series is struct udevice and its uclass_priv field contains the struct clk pointer (to the originally created one).
-* Up till now U-Boot's driver model (DM) CLK operates on udevice (main - access to clock is by udevice ops) - In the CCF the access to struct clk (embodying pointer to *dev) is - possible via dev_get_clk_ptr() (it is a wrapper on dev_get_uclass_priv()). - * To keep things simple the struct udevice's uclass_priv pointer is used to store back pointer to corresponding struct clk. However, it is possible to modify clk-uclass.c file and add there struct uc_clk_priv, which would have @@ -45,13 +40,17 @@ Design decisions: setting .per_device_auto_alloc_size = sizeof(struct uc_clk_priv)) the uclass_priv stores the pointer to struct clk.
+* Non-CCF clocks do not have a pointer to a clock in clk->dev->priv. In the case + of composite clocks, clk->dev->priv may not match clk. Drivers should always + use the struct clk which is passed to them, and not clk->dev->priv. + * It is advised to add common clock code (like already added rate and flags) to the struct clk, which is a top level description of the clock.
* U-Boot's driver model already provides the facility to automatically allocate - (via private_alloc_size) device private data (accessible via dev->priv). - It may look appealing to use this feature to allocate private structures for - CCF clk devices e.g. divider (struct clk_divider *divider) for IMX6Q clock. + (via private_alloc_size) device private data (accessible via dev->priv). It + may look appealing to use this feature to allocate private structures for CCF + clk devices e.g. divider (struct clk_divider *divider) for IMX6Q clock.
The above feature had not been used for following reasons: - The original CCF Linux kernel driver is the "manager" for clocks - it @@ -64,21 +63,23 @@ Design decisions:
* I've added the clk_get_parent(), which reads parent's dev->uclass_priv to provide parent's struct clk pointer. This seems the easiest way to get - child/parent relationship for struct clk in U-Boot's udevice based clocks. + child/parent relationship for struct clk in U-Boot's udevice based clocks. In + the future arbitrary parents may be supported by adding a get_parent function + to clk_ops.
* Linux's CCF 'struct clk_core' corresponds to U-Boot's udevice in 'struct clk'. Clock IP block agnostic flags from 'struct clk_core' (e.g. NOCACHE) have been - moved from this struct one level up to 'struct clk'. + moved from this struct one level up to 'struct clk'. Many flags are + unimplemented at the moment.
* For tests the new ./test/dm/clk_ccf.c and ./drivers/clk/clk_sandbox_ccf.c files have been introduced. The latter setups the CCF clock structure for - sandbox by reusing, if possible, generic clock primitives - like divier - and mux. The former file provides code to tests this setup. + sandbox by reusing, if possible, generic clock primitives - like divier and + mux. The former file provides code to tests this setup.
For sandbox new CONFIG_SANDBOX_CLK_CCF Kconfig define has been introduced. - All new primitives added for new architectures must have corresponding test - in the two aforementioned files. - + All new primitives added for new architectures must have corresponding test in + the two aforementioned files.
Testing (sandbox): ================== diff --git a/drivers/clk/clk-composite.c b/drivers/clk/clk-composite.c index 414185031e..2ff1d6b47f 100644 --- a/drivers/clk/clk-composite.c +++ b/drivers/clk/clk-composite.c @@ -147,6 +147,13 @@ struct clk *clk_register_composite(struct device *dev, const char *name, goto err; }
+ if (composite->mux) + composite->mux->dev = clk->dev; + if (composite->rate) + composite->rate->dev = clk->dev; + if (composite->gate) + composite->gate->dev = clk->dev; + return clk;
err: diff --git a/drivers/clk/clk-divider.c b/drivers/clk/clk-divider.c index d79ae367b8..5fe1c3941f 100644 --- a/drivers/clk/clk-divider.c +++ b/drivers/clk/clk-divider.c @@ -72,8 +72,7 @@ unsigned long divider_recalc_rate(struct clk *hw, unsigned long parent_rate,
static ulong clk_divider_recalc_rate(struct clk *clk) { - struct clk_divider *divider = to_clk_divider(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_divider *divider = to_clk_divider(clk); unsigned long parent_rate = clk_get_parent_rate(clk); unsigned int val;
@@ -152,8 +151,7 @@ int divider_get_val(unsigned long rate, unsigned long parent_rate,
static ulong clk_divider_set_rate(struct clk *clk, unsigned long rate) { - struct clk_divider *divider = to_clk_divider(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_divider *divider = to_clk_divider(clk); unsigned long parent_rate = clk_get_parent_rate(clk); int value; u32 val; diff --git a/drivers/clk/clk-fixed-factor.c b/drivers/clk/clk-fixed-factor.c index 2ceb6bb171..0eb24b87fc 100644 --- a/drivers/clk/clk-fixed-factor.c +++ b/drivers/clk/clk-fixed-factor.c @@ -20,8 +20,7 @@
static ulong clk_factor_recalc_rate(struct clk *clk) { - struct clk_fixed_factor *fix = - to_clk_fixed_factor(dev_get_clk_ptr(clk->dev)); + struct clk_fixed_factor *fix = to_clk_fixed_factor(clk); unsigned long parent_rate = clk_get_parent_rate(clk); unsigned long long int rate;
diff --git a/drivers/clk/clk-gate.c b/drivers/clk/clk-gate.c index 6415c2f1b9..b5827dced0 100644 --- a/drivers/clk/clk-gate.c +++ b/drivers/clk/clk-gate.c @@ -45,8 +45,7 @@ */ static void clk_gate_endisable(struct clk *clk, int enable) { - struct clk_gate *gate = to_clk_gate(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_gate *gate = to_clk_gate(clk); int set = gate->flags & CLK_GATE_SET_TO_DISABLE ? 1 : 0; u32 reg;
@@ -88,8 +87,7 @@ static int clk_gate_disable(struct clk *clk)
int clk_gate_is_enabled(struct clk *clk) { - struct clk_gate *gate = to_clk_gate(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_gate *gate = to_clk_gate(clk); u32 reg;
#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) diff --git a/drivers/clk/clk-mux.c b/drivers/clk/clk-mux.c index b9d2ae6778..0502217dc4 100644 --- a/drivers/clk/clk-mux.c +++ b/drivers/clk/clk-mux.c @@ -37,8 +37,7 @@ int clk_mux_val_to_index(struct clk *clk, u32 *table, unsigned int flags, unsigned int val) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk); int num_parents = mux->num_parents;
if (table) { @@ -81,8 +80,7 @@ unsigned int clk_mux_index_to_val(u32 *table, unsigned int flags, u8 index)
u8 clk_mux_get_parent(struct clk *clk) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk); u32 val;
#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) @@ -99,8 +97,7 @@ u8 clk_mux_get_parent(struct clk *clk) static int clk_fetch_parent_index(struct clk *clk, struct clk *parent) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk);
int i;
@@ -117,8 +114,7 @@ static int clk_fetch_parent_index(struct clk *clk,
static int clk_mux_set_parent(struct clk *clk, struct clk *parent) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); + struct clk_mux *mux = to_clk_mux(clk); int index; u32 val; u32 reg; diff --git a/drivers/clk/imx/clk-gate2.c b/drivers/clk/imx/clk-gate2.c index b38890d5ba..40b2d4caab 100644 --- a/drivers/clk/imx/clk-gate2.c +++ b/drivers/clk/imx/clk-gate2.c @@ -39,7 +39,7 @@ struct clk_gate2 {
static int clk_gate2_enable(struct clk *clk) { - struct clk_gate2 *gate = to_clk_gate2(dev_get_clk_ptr(clk->dev)); + struct clk_gate2 *gate = to_clk_gate2(clk); u32 reg;
reg = readl(gate->reg); @@ -52,7 +52,7 @@ static int clk_gate2_enable(struct clk *clk)
static int clk_gate2_disable(struct clk *clk) { - struct clk_gate2 *gate = to_clk_gate2(dev_get_clk_ptr(clk->dev)); + struct clk_gate2 *gate = to_clk_gate2(clk); u32 reg;
clk_composite_ops was shared between all devices in the composite clock driver. If one clock had a feature (such as supporting set_parent) which another clock did not, it could call a null pointer dereference.
This patch does three things 1. It adds null-pointer checks to all composite clock functions. 2. It makes clk_composite_ops const and sets its functions at compile-time. 3. It adds some basic sanity checks to num_parents.
The combined effect of these changes is that any of mux, rate, or gate can be NULL, and composite clocks will still function normally. Previously, at least mux had to exist, since clk_composite_get_parent was used to determine the parent for clk_register.
Changes in v4: - Return ENOTSUPP not ENOSYS with no set_parent
Changes in v3: - Don't return an error code where a no-op would be fine
drivers/clk/clk-composite.c | 57 +++++++++++++++++++++++-------------- 1 file changed, 35 insertions(+), 22 deletions(-)
diff --git a/drivers/clk/clk-composite.c b/drivers/clk/clk-composite.c index 2ff1d6b47f..819bfca2fc 100644 --- a/drivers/clk/clk-composite.c +++ b/drivers/clk/clk-composite.c @@ -24,7 +24,10 @@ static u8 clk_composite_get_parent(struct clk *clk) (struct clk *)dev_get_clk_ptr(clk->dev) : clk); struct clk *mux = composite->mux;
- return clk_mux_get_parent(mux); + if (mux) + return clk_mux_get_parent(mux); + else + return 0; }
static int clk_composite_set_parent(struct clk *clk, struct clk *parent) @@ -34,7 +37,10 @@ static int clk_composite_set_parent(struct clk *clk, struct clk *parent) const struct clk_ops *mux_ops = composite->mux_ops; struct clk *mux = composite->mux;
- return mux_ops->set_parent(mux, parent); + if (mux && mux_ops) + return mux_ops->set_parent(mux, parent); + else + return -ENOTSUPP; }
static unsigned long clk_composite_recalc_rate(struct clk *clk) @@ -44,7 +50,10 @@ static unsigned long clk_composite_recalc_rate(struct clk *clk) const struct clk_ops *rate_ops = composite->rate_ops; struct clk *rate = composite->rate;
- return rate_ops->get_rate(rate); + if (rate && rate_ops) + return rate_ops->get_rate(rate); + else + return clk_get_parent_rate(clk); }
static ulong clk_composite_set_rate(struct clk *clk, unsigned long rate) @@ -54,7 +63,10 @@ static ulong clk_composite_set_rate(struct clk *clk, unsigned long rate) const struct clk_ops *rate_ops = composite->rate_ops; struct clk *clk_rate = composite->rate;
- return rate_ops->set_rate(clk_rate, rate); + if (rate && rate_ops) + return rate_ops->set_rate(clk_rate, rate); + else + return clk_get_rate(clk); }
static int clk_composite_enable(struct clk *clk) @@ -64,7 +76,10 @@ static int clk_composite_enable(struct clk *clk) const struct clk_ops *gate_ops = composite->gate_ops; struct clk *gate = composite->gate;
- return gate_ops->enable(gate); + if (gate && gate_ops) + return gate_ops->enable(gate); + else + return 0; }
static int clk_composite_disable(struct clk *clk) @@ -74,15 +89,12 @@ static int clk_composite_disable(struct clk *clk) const struct clk_ops *gate_ops = composite->gate_ops; struct clk *gate = composite->gate;
- gate_ops->disable(gate); - - return 0; + if (gate && gate_ops) + return gate_ops->disable(gate); + else + return 0; }
-struct clk_ops clk_composite_ops = { - /* This will be set according to clk_register_composite */ -}; - struct clk *clk_register_composite(struct device *dev, const char *name, const char * const *parent_names, int num_parents, struct clk *mux, @@ -96,7 +108,9 @@ struct clk *clk_register_composite(struct device *dev, const char *name, struct clk *clk; struct clk_composite *composite; int ret; - struct clk_ops *composite_ops = &clk_composite_ops; + + if (!num_parents || (num_parents != 1 && !mux)) + return ERR_PTR(-EINVAL);
composite = kzalloc(sizeof(*composite), GFP_KERNEL); if (!composite) @@ -105,8 +119,6 @@ struct clk *clk_register_composite(struct device *dev, const char *name, if (mux && mux_ops) { composite->mux = mux; composite->mux_ops = mux_ops; - if (mux_ops->set_parent) - composite_ops->set_parent = clk_composite_set_parent; mux->data = (ulong)composite; }
@@ -115,11 +127,6 @@ struct clk *clk_register_composite(struct device *dev, const char *name, clk = ERR_PTR(-EINVAL); goto err; } - composite_ops->get_rate = clk_composite_recalc_rate; - - /* .set_rate requires either .round_rate or .determine_rate */ - if (rate_ops->set_rate) - composite_ops->set_rate = clk_composite_set_rate;
composite->rate = rate; composite->rate_ops = rate_ops; @@ -134,8 +141,6 @@ struct clk *clk_register_composite(struct device *dev, const char *name,
composite->gate = gate; composite->gate_ops = gate_ops; - composite_ops->enable = clk_composite_enable; - composite_ops->disable = clk_composite_disable; gate->data = (ulong)composite; }
@@ -161,6 +166,14 @@ err: return clk; }
+static const struct clk_ops clk_composite_ops = { + .set_parent = clk_composite_set_parent, + .get_rate = clk_composite_recalc_rate, + .set_rate = clk_composite_set_rate, + .enable = clk_composite_enable, + .disable = clk_composite_disable, +}; + U_BOOT_DRIVER(clk_composite) = { .name = UBOOT_DM_CLK_COMPOSITE, .id = UCLASS_CLK,
For clocks not in the CCF, their parents will not have UCLASS_CLK, so we just enable them as normal. The enable count is local to the struct clk, but this will never result in the actual en-/dis-able op being called (unless the same struct clk is enabled twice).
For clocks in the CCF, we always traverse up the tree when enabling. Previously, CCF clocks without id set would be skipped, stopping the traversal too early.
Changes in v5: - Clear enable_count on request
Changes in v3: - New
drivers/clk/clk-uclass.c | 60 ++++++++++++++++++---------------------- 1 file changed, 27 insertions(+), 33 deletions(-)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index d497737298..3b711395b8 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -410,6 +410,7 @@ int clk_request(struct udevice *dev, struct clk *clk) ops = clk_dev_ops(dev);
clk->dev = dev; + clk->enable_count = 0;
if (!ops->request) return 0; @@ -522,7 +523,6 @@ int clk_set_parent(struct clk *clk, struct clk *parent) int clk_enable(struct clk *clk) { const struct clk_ops *ops; - struct clk *clkp = NULL; int ret;
debug("%s(clk=%p "%s")\n", __func__, clk, clk->dev->name); @@ -531,32 +531,29 @@ int clk_enable(struct clk *clk) ops = clk_dev_ops(clk->dev);
if (CONFIG_IS_ENABLED(CLK_CCF)) { - /* Take id 0 as a non-valid clk, such as dummy */ - if (clk->id && !clk_get_by_id(clk->id, &clkp)) { - if (clkp->enable_count) { - clkp->enable_count++; - return 0; - } - if (clkp->dev->parent && - device_get_uclass_id(clkp->dev) == UCLASS_CLK) { - ret = clk_enable(dev_get_clk_ptr(clkp->dev->parent)); - if (ret) { - printf("Enable %s failed\n", - clkp->dev->parent->name); - return ret; - } + if (clk->enable_count) { + clk->enable_count++; + return 0; + } + if (clk->dev->parent && + device_get_uclass_id(clk->dev->parent) == UCLASS_CLK) { + ret = clk_enable(dev_get_clk_ptr(clk->dev->parent)); + if (ret) { + printf("Enable %s failed\n", + clk->dev->parent->name); + return ret; } }
if (ops->enable) { ret = ops->enable(clk); if (ret) { - printf("Enable %s failed\n", clk->dev->name); + printf("Enable %s failed (error %d)\n", + clk->dev->name, ret); return ret; } } - if (clkp) - clkp->enable_count++; + clk->enable_count++; } else { if (!ops->enable) return -ENOSYS; @@ -582,7 +579,6 @@ int clk_enable_bulk(struct clk_bulk *bulk) int clk_disable(struct clk *clk) { const struct clk_ops *ops; - struct clk *clkp = NULL; int ret;
debug("%s(clk=%p)\n", __func__, clk); @@ -591,29 +587,27 @@ int clk_disable(struct clk *clk) ops = clk_dev_ops(clk->dev);
if (CONFIG_IS_ENABLED(CLK_CCF)) { - if (clk->id && !clk_get_by_id(clk->id, &clkp)) { - if (clkp->enable_count == 0) { - printf("clk %s already disabled\n", - clkp->dev->name); - return 0; - } - - if (--clkp->enable_count > 0) - return 0; + if (clk->enable_count == 0) { + printf("clk %s already disabled\n", + clk->dev->name); + return 0; }
+ if (--clk->enable_count > 0) + return 0; + if (ops->disable) { ret = ops->disable(clk); if (ret) return ret; }
- if (clkp && clkp->dev->parent && - device_get_uclass_id(clkp->dev) == UCLASS_CLK) { - ret = clk_disable(dev_get_clk_ptr(clkp->dev->parent)); + if (clk->dev->parent && + device_get_uclass_id(clk->dev) == UCLASS_CLK) { + ret = clk_disable(dev_get_clk_ptr(clk->dev->parent)); if (ret) { - printf("Disable %s failed\n", - clkp->dev->parent->name); + printf("Disable %s failed (error %d)\n", + clk->dev->parent->name, ret); return ret; } }
Hi Sean
Changes in v5:
Changes in v4:
- Lint
Changes in v3:
- New
clk->dev = dev;
Lukasz has taged Acked-by in v3. Re: [PATCH v3 03/12] clk: Unconditionally recursively en-/dis-able clocks
This patch shall be fixed and freeze. But you add a new modification (Clear enable_count on request)in v5 and v6. Although it seem to look fine and nothing big deal. I just highlight it here, and if Lukasz have no other comment further. I will pull it via riscv tree later.
Thanks, Rick
struct clk *clkp = NULL; int ret; debug("%s(clk=%p \"%s\")\n", __func__, clk, clk->dev->name);
if (ret) {
return ret;
if (ret) {
return ret; } } if (ops->enable) { ret = ops->enable(clk); if (ret) {
if (clkp)
struct clk *clkp = NULL; int ret; debug("%s(clk=%p)\n", __func__, clk);
clkp->dev->name);
clk->dev->name);
return 0; }
-- 2.25.0
Hi Sean
Changes in v5:
Changes in v4:
- Lint
Changes in v3:
- New
clk->dev = dev;
I have told you in v5, that this patch have conflict with u-boot/master please rebase it. But it still conflict in v6.
https://patchwork.ozlabs.org/patch/1246836/
Applying: clk: Always use the supplied struct clk Applying: clk: Check that ops of composite clock components exist before calling Applying: clk: Unconditionally recursively en-/dis-able clocks error: patch failed: drivers/clk/clk-uclass.c:522 error: drivers/clk/clk-uclass.c: patch does not apply Patch failed at 0003 clk: Unconditionally recursively en-/dis-able clocks The copy of the patch that failed is found in: .git/rebase-apply/patch When you have resolved this problem, run "git am --continue". If you prefer to skip this patch, run "git am --skip" instead. To restore the original branch and stop patching, run "git am --abort".
Thanks, Rick
if (ret) {
return ret;
if (ret) {
if (clkp)
clkp->dev->name);
clk->dev->name);
return 0; }
-- 2.25.0
On 3/10/20 2:51 AM, Rick Chen wrote:
Hi Sean
Changes in v5:
Changes in v4:
- Lint
Changes in v3:
- New
clk->dev = dev;
This was just rebased against u-boot/master. Should I be rebasing against a different branch? The commit I am working off is
$ git show upstream/master commit 1efb9796f80e1394f080be1b4f3173ff108ad1f2 (upstream/master, upstream/WIP/03Mar2020, upstream/HEAD) Merge: 8aad16916d 9aa886cc0b Author: Tom Rini trini@konsulko.com Date: Tue Mar 3 21:48:49 2020 -0500
Merge tag 'dm-pull-3mar20' of git://git.denx.de/u-boot-dm
Fixes for power domain on device removal
Thanks, Rick
if (ret) {
return ret;
if (ret) {
if (clkp)
clkp->dev->name);
clk->dev->name);
return 0; }
-- 2.25.0
Hi Sean
Hi Sean
Changes in v5:
Changes in v4:
- Lint
Changes in v3:
- New
clk->dev = dev;
It is just fine to sync with u-boot/master. Before I send a PR, I shall sync to u-boot/master too.
Thanks, Rick
Merge tag 'dm-pull-3mar20' of git://git.denx.de/u-boot-dm Fixes for power domain on device removal
Thanks, Rick
if (ret) {
return ret;
if (ret) {
if (clkp)
clkp->dev->name);
clk->dev->name);
return 0; }
-- 2.25.0
On 3/10/20 10:09 PM, Rick Chen wrote:
Hi Sean
Hi Sean I have told you in v5, that this patch have conflict with u-boot/master please rebase it. But it still conflict in v6.
Thanks, Rick
I think I found the issue. I made a commit to add some more log messages to that file, and it seems to have changed the line numbers. Next patch I will rebase without that commit.
--Sean
This patch adds alternate versions of the clk_*_register functions for use with statically-allocated struct clks. This allows drivers to define clocks at compile-time and register them at run-time without malloc-ing. This increases the size of the binary, but should not affect ram usage (since the clocks now no longer live on the heap).
Signed-off-by: Sean Anderson seanga2@gmail.com ---
Changes in v5: - New
drivers/clk/clk-composite.c | 103 +++++++++++++++++++---------------- drivers/clk/clk-divider.c | 56 +++++++++---------- drivers/clk/clk-gate.c | 38 ++++++++----- include/linux/clk-provider.h | 9 +++ 4 files changed, 112 insertions(+), 94 deletions(-)
diff --git a/drivers/clk/clk-composite.c b/drivers/clk/clk-composite.c index 819bfca2fc..b328c4e5a5 100644 --- a/drivers/clk/clk-composite.c +++ b/drivers/clk/clk-composite.c @@ -95,6 +95,51 @@ static int clk_composite_disable(struct clk *clk) return 0; }
+struct clk *clk_register_composite_struct(const char *name, + const char * const *parent_names, + int num_parents, + struct clk_composite *composite) +{ + int ret; + struct clk *clk; + + if (!num_parents || (num_parents != 1 && !composite->mux)) + return ERR_PTR(-EINVAL); + + if (composite->mux && composite->mux_ops) + composite->mux->data = (ulong)composite; + + if (composite->rate && composite->rate_ops) { + if (!composite->rate_ops->get_rate) + return ERR_PTR(-EINVAL); + + composite->rate->data = (ulong)composite; + } + + if (composite->gate && composite->gate_ops) { + if (!composite->gate_ops->enable || + !composite->gate_ops->disable) + return ERR_PTR(-EINVAL); + + composite->gate->data = (ulong)composite; + } + + clk = &composite->clk; + ret = clk_register(clk, UBOOT_DM_CLK_COMPOSITE, name, + parent_names[clk_composite_get_parent(clk)]); + if (ret) + clk = ERR_PTR(ret); + + if (composite->mux) + composite->mux->dev = clk->dev; + if (composite->rate) + composite->rate->dev = clk->dev; + if (composite->gate) + composite->gate->dev = clk->dev; + + return clk; +} + struct clk *clk_register_composite(struct device *dev, const char *name, const char * const *parent_names, int num_parents, struct clk *mux, @@ -107,62 +152,24 @@ struct clk *clk_register_composite(struct device *dev, const char *name, { struct clk *clk; struct clk_composite *composite; - int ret; - - if (!num_parents || (num_parents != 1 && !mux)) - return ERR_PTR(-EINVAL);
composite = kzalloc(sizeof(*composite), GFP_KERNEL); if (!composite) return ERR_PTR(-ENOMEM);
- if (mux && mux_ops) { - composite->mux = mux; - composite->mux_ops = mux_ops; - mux->data = (ulong)composite; - } + composite->mux = mux; + composite->mux_ops = mux_ops;
- if (rate && rate_ops) { - if (!rate_ops->get_rate) { - clk = ERR_PTR(-EINVAL); - goto err; - } + composite->rate = rate; + composite->rate_ops = rate_ops;
- composite->rate = rate; - composite->rate_ops = rate_ops; - rate->data = (ulong)composite; - } + composite->gate = gate; + composite->gate_ops = gate_ops;
- if (gate && gate_ops) { - if (!gate_ops->enable || !gate_ops->disable) { - clk = ERR_PTR(-EINVAL); - goto err; - } - - composite->gate = gate; - composite->gate_ops = gate_ops; - gate->data = (ulong)composite; - } - - clk = &composite->clk; - ret = clk_register(clk, UBOOT_DM_CLK_COMPOSITE, name, - parent_names[clk_composite_get_parent(clk)]); - if (ret) { - clk = ERR_PTR(ret); - goto err; - } - - if (composite->mux) - composite->mux->dev = clk->dev; - if (composite->rate) - composite->rate->dev = clk->dev; - if (composite->gate) - composite->gate->dev = clk->dev; - - return clk; - -err: - kfree(composite); + clk = clk_register_composite_struct(name, parent_names, num_parents, + composite); + if (IS_ERR(clk)) + kfree(composite); return clk; }
diff --git a/drivers/clk/clk-divider.c b/drivers/clk/clk-divider.c index 5fe1c3941f..747504d0a0 100644 --- a/drivers/clk/clk-divider.c +++ b/drivers/clk/clk-divider.c @@ -178,22 +178,37 @@ const struct clk_ops clk_divider_ops = { .set_rate = clk_divider_set_rate, };
-static struct clk *_register_divider(struct device *dev, const char *name, - const char *parent_name, unsigned long flags, - void __iomem *reg, u8 shift, u8 width, - u8 clk_divider_flags, const struct clk_div_table *table) +struct clk *clk_register_divider_struct(const char *name, + const char *parent_name, + struct clk_divider *div) { - struct clk_divider *div; - struct clk *clk; int ret; + struct clk *clk;
- if (clk_divider_flags & CLK_DIVIDER_HIWORD_MASK) { - if (width + shift > 16) { + if (div->flags & CLK_DIVIDER_HIWORD_MASK) { + if (div->width + div->shift > 16) { pr_warn("divider value exceeds LOWORD field\n"); return ERR_PTR(-EINVAL); } }
+ /* register the clock */ + clk = &div->clk; + + ret = clk_register(clk, UBOOT_DM_CLK_CCF_DIVIDER, name, parent_name); + if (ret) + return ERR_PTR(ret); + return clk; +} + +struct clk *clk_register_divider(struct device *dev, const char *name, + const char *parent_name, unsigned long flags, + void __iomem *reg, u8 shift, u8 width, + u8 clk_divider_flags) +{ + struct clk_divider *div; + struct clk *clk; + /* allocate the divider */ div = kzalloc(sizeof(*div), GFP_KERNEL); if (!div) @@ -204,34 +219,13 @@ static struct clk *_register_divider(struct device *dev, const char *name, div->shift = shift; div->width = width; div->flags = clk_divider_flags; - div->table = table; #if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) div->io_divider_val = *(u32 *)reg; #endif
- /* register the clock */ - clk = &div->clk; - - ret = clk_register(clk, UBOOT_DM_CLK_CCF_DIVIDER, name, parent_name); - if (ret) { - kfree(div); - return ERR_PTR(ret); - } - - return clk; -} - -struct clk *clk_register_divider(struct device *dev, const char *name, - const char *parent_name, unsigned long flags, - void __iomem *reg, u8 shift, u8 width, - u8 clk_divider_flags) -{ - struct clk *clk; - - clk = _register_divider(dev, name, parent_name, flags, reg, shift, - width, clk_divider_flags, NULL); + clk = clk_register_divider_struct(name, parent_name, div); if (IS_ERR(clk)) - return ERR_CAST(clk); + kfree(div); return clk; }
diff --git a/drivers/clk/clk-gate.c b/drivers/clk/clk-gate.c index b5827dced0..82445d2ccb 100644 --- a/drivers/clk/clk-gate.c +++ b/drivers/clk/clk-gate.c @@ -111,6 +111,27 @@ const struct clk_ops clk_gate_ops = { .get_rate = clk_generic_get_rate, };
+struct clk *clk_register_gate_struct(const char *name, const char *parent_name, + struct clk_gate *gate) +{ + int ret; + struct clk *clk; + + if (gate->flags & CLK_GATE_HIWORD_MASK) { + if (gate->bit_idx > 15) { + pr_err("gate bit exceeds LOWORD field\n"); + return ERR_PTR(-EINVAL); + } + } + + clk = &gate->clk; + + ret = clk_register(clk, UBOOT_DM_CLK_GATE, name, parent_name); + if (ret) + return ERR_PTR(ret); + return clk; +} + struct clk *clk_register_gate(struct device *dev, const char *name, const char *parent_name, unsigned long flags, void __iomem *reg, u8 bit_idx, @@ -118,14 +139,6 @@ struct clk *clk_register_gate(struct device *dev, const char *name, { struct clk_gate *gate; struct clk *clk; - int ret; - - if (clk_gate_flags & CLK_GATE_HIWORD_MASK) { - if (bit_idx > 15) { - pr_err("gate bit exceeds LOWORD field\n"); - return ERR_PTR(-EINVAL); - } - }
/* allocate the gate */ gate = kzalloc(sizeof(*gate), GFP_KERNEL); @@ -140,14 +153,9 @@ struct clk *clk_register_gate(struct device *dev, const char *name, gate->io_gate_val = *(u32 *)reg; #endif
- clk = &gate->clk; - - ret = clk_register(clk, UBOOT_DM_CLK_GATE, name, parent_name); - if (ret) { + clk = clk_register_gate_struct(name, parent_name, gate); + if (IS_ERR(clk)) kfree(gate); - return ERR_PTR(ret); - } - return clk; }
diff --git a/include/linux/clk-provider.h b/include/linux/clk-provider.h index 8a20743ad8..8bf8dca0a3 100644 --- a/include/linux/clk-provider.h +++ b/include/linux/clk-provider.h @@ -95,6 +95,8 @@ struct clk *clk_register_gate(struct device *dev, const char *name, const char *parent_name, unsigned long flags, void __iomem *reg, u8 bit_idx, u8 clk_gate_flags, spinlock_t *lock); +struct clk *clk_register_gate_struct(const char *name, const char *parent_name, + struct clk_gate *gate);
struct clk_div_table { unsigned int val; @@ -166,6 +168,10 @@ struct clk *clk_register_composite(struct device *dev, const char *name, struct clk *rate_clk, const struct clk_ops *rate_ops, struct clk *gate_clk, const struct clk_ops *gate_ops, unsigned long flags); +struct clk *clk_register_composite_struct(const char *name, + const char * const *parent_names, + int num_parents, + struct clk_composite *composite);
int clk_register(struct clk *clk, const char *drv_name, const char *name, const char *parent_name); @@ -178,6 +184,9 @@ struct clk *clk_register_divider(struct device *dev, const char *name, const char *parent_name, unsigned long flags, void __iomem *reg, u8 shift, u8 width, u8 clk_divider_flags); +struct clk *clk_register_divider_struct(const char *name, + const char *parent_name, + struct clk_divider *div);
struct clk *clk_register_mux(struct device *dev, const char *name, const char * const *parent_names, u8 num_parents,
Hi Sean
This is a new patch since v5 and still lack of tag of MAINTAINERs. I will prefer to exclude it in the later pull request of riscv tree.
Thanks, Rick
Changes in v5:
- New
int num_parents,
int ret;
struct clk *clk;
if (ret)
clk = ERR_PTR(ret);
if (composite->mux)
return clk;
int ret;
return ERR_PTR(-EINVAL); composite = kzalloc(sizeof(*composite), GFP_KERNEL); if (!composite) return ERR_PTR(-ENOMEM);
goto err;
goto err;
if (ret) {
clk = ERR_PTR(ret);
goto err;
if (composite->mux)
return clk;
-err:
kfree(composite);
composite);
if (IS_ERR(clk))
struct clk *clk;
clk = &div->clk;
if (ret)
return clk;
struct clk *clk;
div->table = table;
clk = &div->clk;
if (ret) {
kfree(div);
return clk;
struct clk *clk;
int ret;
struct clk *clk;
clk = &gate->clk;
if (ret)
return clk;
int ret;
if (bit_idx > 15) {
} /* allocate the gate */ gate = kzalloc(sizeof(*gate), GFP_KERNEL);
clk = &gate->clk;
if (ret) {
return clk;
int num_parents,
struct clk *clk_register_mux(struct device *dev, const char *name, const char * const *parent_names, u8 num_parents, -- 2.25.0
On 3/10/20 3:08 AM, Rick Chen wrote:
Hi Sean
Thanks, Rick
Lukas, can you comment one way or the other on this?
Thanks,
Sean
This pll code is primarily based on the code from the kendryte standalone sdk in lib/drivers/sysctl.c. k210_pll_calc_params is roughly analogous to the algorithm used to set the pll frequency, but it has been completely rewritten to be fixed-point based.
Changes in v6: - Reformat code to reduce checkpatch errors
Changes in v5: - Add function to register from a struct
Changes in v4: - Rename the reference clock to "divider clock", and input clock to "reference clock" to match the upstream documentation. - Add a test for calc_params. This currently resides in test/dm, but perhaps it should be moved to its own directory. - Update MAINTAINERS - Update copyright - Lint
Changes in v3: - Add an option to not include support for setting the pll rate. This saves around 1K in the final executable. - Remove udelays to suppress warnings - Bypass PLL after enabling, instead of before - Check if the PLL is enabled already before doing a reset - Fix bug with locked mask
Changes in v2: - Rename driver to "k210_clk_pll" - Add additional in-line documentation on algorithm and PLLs - Restrict the range of internal VCO and reference frequencies - Don't load driver before relocation - Remove spurious references to mach-k210
drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/kendryte/Kconfig | 12 + drivers/clk/kendryte/Makefile | 1 + drivers/clk/kendryte/pll.c | 601 ++++++++++++++++++++++++++++++++++ include/kendryte/pll.h | 57 ++++ include/test/export.h | 16 + test/dm/Makefile | 1 + test/dm/k210_pll.c | 96 ++++++ 9 files changed, 786 insertions(+) create mode 100644 drivers/clk/kendryte/Kconfig create mode 100644 drivers/clk/kendryte/Makefile create mode 100644 drivers/clk/kendryte/pll.c create mode 100644 include/kendryte/pll.h create mode 100644 include/test/export.h create mode 100644 test/dm/k210_pll.c
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 1992d4a4b4..fb8335267b 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -155,6 +155,7 @@ source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" source "drivers/clk/imx/Kconfig" +source "drivers/clk/kendryte/Kconfig" source "drivers/clk/meson/Kconfig" source "drivers/clk/mvebu/Kconfig" source "drivers/clk/owl/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index e01783391d..d911954581 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_CLK_BOSTON) += clk_boston.o obj-$(CONFIG_CLK_EXYNOS) += exynos/ obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ obj-$(CONFIG_CLK_HSDK) += clk-hsdk-cgu.o +obj-$(CONFIG_CLK_K210) += kendryte/ obj-$(CONFIG_CLK_MPC83XX) += mpc83xx_clk.o obj-$(CONFIG_CLK_OWL) += owl/ obj-$(CONFIG_CLK_RENESAS) += renesas/ diff --git a/drivers/clk/kendryte/Kconfig b/drivers/clk/kendryte/Kconfig new file mode 100644 index 0000000000..7b69c8afaf --- /dev/null +++ b/drivers/clk/kendryte/Kconfig @@ -0,0 +1,12 @@ +config CLK_K210 + bool "Clock support for Kendryte K210" + depends on CLK && CLK_CCF + help + This enables support clock driver for Kendryte K210 platforms. + +config CLK_K210_SET_RATE + bool "Enable setting the Kendryte K210 PLL rate" + depends on CLK_K210 + help + Add functionality to calculate new rates for K210 PLLs. Enabling this + feature adds around 1K to U-Boot's final size. diff --git a/drivers/clk/kendryte/Makefile b/drivers/clk/kendryte/Makefile new file mode 100644 index 0000000000..c56d93ea1c --- /dev/null +++ b/drivers/clk/kendryte/Makefile @@ -0,0 +1 @@ +obj-y += pll.o diff --git a/drivers/clk/kendryte/pll.c b/drivers/clk/kendryte/pll.c new file mode 100644 index 0000000000..699f933afc --- /dev/null +++ b/drivers/clk/kendryte/pll.c @@ -0,0 +1,601 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ +#include <kendryte/pll.h> + +#define LOG_CATEGORY UCLASS_CLK +#include <asm/io.h> +/* For DIV_ROUND_DOWN_ULL, defined in linux/kernel.h */ +#include <div64.h> +#include <dt-bindings/clock/k210-sysctl.h> +#include <linux/bitfield.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <log.h> +#include <serial.h> + +#define CLK_K210_PLL "k210_clk_pll" + +#ifdef CONFIG_CLK_K210_SET_RATE +static int k210_pll_enable(struct clk *clk); +static int k210_pll_disable(struct clk *clk); + +/* + * The PLL included with the Kendryte K210 appears to be a True Circuits, Inc. + * General-Purpose PLL. The logical layout of the PLL with internal feedback is + * approximately the following: + * + * +---------------+ + * |reference clock| + * +---------------+ + * | + * v + * +--+ + * |/r| + * +--+ + * | + * v + * +-------------+ + * |divided clock| + * +-------------+ + * | + * v + * +--------------+ + * |phase detector|<---+ + * +--------------+ | + * | | + * v +--------------+ + * +---+ |feedback clock| + * |VCO| +--------------+ + * +---+ ^ + * | +--+ | + * +--->|/f|---+ + * | +--+ + * v + * +---+ + * |/od| + * +---+ + * | + * v + * +------+ + * |output| + * +------+ + * + * The k210 PLLs have three factors: r, f, and od. Because of the feedback mode, + * the effect of the division by f is to multiply the input frequency. The + * equation for the output rate is + * rate = (rate_in * f) / (r * od). + * Moving knowns to one side of the equation, we get + * rate / rate_in = f / (r * od) + * Rearranging slightly, + * abs_error = abs((rate / rate_in) - (f / (r * od))). + * To get relative, error, we divide by the expected ratio + * error = abs((rate / rate_in) - (f / (r * od))) / (rate / rate_in). + * Simplifying, + * error = abs(1 - f / (r * od)) / (rate / rate_in) + * error = abs(1 - (f * rate_in) / (r * od * rate)) + * Using the constants ratio = rate / rate_in and inv_ratio = rate_in / rate, + * error = abs((f * inv_ratio) / (r * od) - 1) + * This is the error used in evaluating parameters. + * + * r and od are four bits each, while f is six bits. Because r and od are + * multiplied together, instead of the full 256 values possible if both bits + * were used fully, there are only 97 distinct products. Combined with f, there + * are 6208 theoretical settings for the PLL. However, most of these settings + * can be ruled out immediately because they do not have the correct ratio. + * + * In addition to the constraint of approximating the desired ratio, parameters + * must also keep internal pll frequencies within acceptable ranges. The divided + * clock's minimum and maximum frequencies have a ratio of around 128. This + * leaves fairly substantial room to work with, especially since the only + * affected parameter is r. The VCO's minimum and maximum frequency have a ratio + * of 5, which is considerably more restrictive. + * + * The r and od factors are stored in a table. This is to make it easy to find + * the next-largest product. Some products have multiple factorizations, but + * only when one factor has at least a 2.5x ratio to the factors of the other + * factorization. This is because any smaller ratio would not make a difference + * when ensuring the VCO's frequency is within spec. + * + * Throughout the calculation function, fixed point arithmetic is used. Because + * the range of rate and rate_in may be up to 1.75 GHz, or around 2^30, 64-bit + * 32.32 fixed-point numbers are used to represent ratios. In general, to + * implement division, the numerator is first multiplied by 2^32. This gives a + * result where the whole number part is in the upper 32 bits, and the fraction + * is in the lower 32 bits. + * + * In general, rounding is done to the closest integer. This helps find the best + * approximation for the ratio. Rounding in one direction (e.g down) could cause + * the function to miss a better ratio with one of the parameters increased by + * one. + */ + +/* + * The factors table was generated with the following python code: + * + * def p(x, y): + * return (1.0*x/y > 2.5) or (1.0*y/x > 2.5) + * + * factors = {} + * for i in range(1, 17): + * for j in range(1, 17): + * fs = factors.get(i*j) or [] + * if fs == [] or all([ + * (p(i, x) and p(i, y)) or (p(j, x) and p(j, y)) + * for (x, y) in fs]): + * fs.append((i, j)) + * factors[i*j] = fs + * + * for k, l in sorted(factors.items()): + * for v in l: + * print("PACK(%s, %s)," % v) + */ +#define PACK(r, od) (((((r) - 1) & 0xF) << 4) | (((od) - 1) & 0xF)) +#define UNPACK_R(val) ((((val) >> 4) & 0xF) + 1) +#define UNPACK_OD(val) (((val) & 0xF) + 1) +static const u8 factors[] = { + PACK(1, 1), + PACK(1, 2), + PACK(1, 3), + PACK(1, 4), + PACK(1, 5), + PACK(1, 6), + PACK(1, 7), + PACK(1, 8), + PACK(1, 9), + PACK(3, 3), + PACK(1, 10), + PACK(1, 11), + PACK(1, 12), + PACK(3, 4), + PACK(1, 13), + PACK(1, 14), + PACK(1, 15), + PACK(3, 5), + PACK(1, 16), + PACK(4, 4), + PACK(2, 9), + PACK(2, 10), + PACK(3, 7), + PACK(2, 11), + PACK(2, 12), + PACK(5, 5), + PACK(2, 13), + PACK(3, 9), + PACK(2, 14), + PACK(2, 15), + PACK(2, 16), + PACK(3, 11), + PACK(5, 7), + PACK(3, 12), + PACK(3, 13), + PACK(4, 10), + PACK(3, 14), + PACK(4, 11), + PACK(3, 15), + PACK(3, 16), + PACK(7, 7), + PACK(5, 10), + PACK(4, 13), + PACK(6, 9), + PACK(5, 11), + PACK(4, 14), + PACK(4, 15), + PACK(7, 9), + PACK(4, 16), + PACK(5, 13), + PACK(6, 11), + PACK(5, 14), + PACK(6, 12), + PACK(5, 15), + PACK(7, 11), + PACK(6, 13), + PACK(5, 16), + PACK(9, 9), + PACK(6, 14), + PACK(8, 11), + PACK(6, 15), + PACK(7, 13), + PACK(6, 16), + PACK(7, 14), + PACK(9, 11), + PACK(10, 10), + PACK(8, 13), + PACK(7, 15), + PACK(9, 12), + PACK(10, 11), + PACK(7, 16), + PACK(9, 13), + PACK(8, 15), + PACK(11, 11), + PACK(9, 14), + PACK(8, 16), + PACK(10, 13), + PACK(11, 12), + PACK(9, 15), + PACK(10, 14), + PACK(11, 13), + PACK(9, 16), + PACK(10, 15), + PACK(11, 14), + PACK(12, 13), + PACK(10, 16), + PACK(11, 15), + PACK(12, 14), + PACK(13, 13), + PACK(11, 16), + PACK(12, 15), + PACK(13, 14), + PACK(12, 16), + PACK(13, 15), + PACK(14, 14), + PACK(13, 16), + PACK(14, 15), + PACK(14, 16), + PACK(15, 15), + PACK(15, 16), + PACK(16, 16), +}; + +TEST_STATIC int k210_pll_calc_params(u32 rate, u32 rate_in, + struct k210_pll_params *best) +{ + int i; + s64 error, best_error; + u64 ratio, inv_ratio; /* fixed point 32.32 ratio of the rates */ + u64 max_r; + u64 r, f, od; + + /* + * Can't go over 1.75 GHz or under 21.25 MHz due to limitations on the + * VCO frequency. These are not the same limits as below because od can + * reduce the output frequency by 16. + */ + if (rate > 1750000000 || rate < 21250000) + return -EINVAL; + + /* Similar restrictions on the input rate */ + if (rate_in > 1750000000 || rate_in < 13300000) + return -EINVAL; + + ratio = DIV_ROUND_CLOSEST_ULL((u64)rate << 32, rate_in); + inv_ratio = DIV_ROUND_CLOSEST_ULL((u64)rate_in << 32, rate); + /* Can't increase by more than 64 or reduce by more than 256 */ + if (rate > rate_in && ratio > (64ULL << 32)) + return -EINVAL; + else if (rate <= rate_in && inv_ratio > (256ULL << 32)) + return -EINVAL; + + /* + * The divided clock (rate_in / r) must stay between 1.75 GHz and 13.3 + * MHz. There is no minimum, since the only way to get a higher input + * clock than 26 MHz is to use a clock generated by a PLL. Because PLLs + * cannot output frequencies greater than 1.75 GHz, the minimum would + * never be greater than one. + */ + max_r = DIV_ROUND_DOWN_ULL(rate_in, 13300000); + + /* Variables get immediately incremented, so start at -1th iteration */ + i = -1; + f = 0; + r = 0; + od = 0; + best_error = S64_MAX; + error = best_error; + /* do-while here so we always try at least one ratio */ + do { + /* + * Whether we swapped r and od while enforcing frequency limits + */ + bool swapped = false; + u64 last_od = od; + u64 last_r = r; + + /* + * Try the next largest value for f (or r and od) and + * recalculate the other parameters based on that + */ + if (rate > rate_in) { + /* + * Skip factors of the same product if we already tried + * out that product + */ + do { + i++; + r = UNPACK_R(factors[i]); + od = UNPACK_OD(factors[i]); + } while (i + 1 < ARRAY_SIZE(factors) && + r * od == last_r * last_od); + + /* Round close */ + f = (r * od * ratio + BIT(31)) >> 32; + if (f > 64) + f = 64; + } else { + u64 tmp = ++f * inv_ratio; + bool round_up = !!(tmp & BIT(31)); + u32 goal = (tmp >> 32) + round_up; + u32 err, last_err; + + /* Get the next r/od pair in factors */ + while (r * od < goal && i + 1 < ARRAY_SIZE(factors)) { + i++; + r = UNPACK_R(factors[i]); + od = UNPACK_OD(factors[i]); + } + + /* + * This is a case of double rounding. If we rounded up + * above, we need to round down (in cases of ties) here. + * This prevents off-by-one errors resulting from + * choosing X+2 over X when X.Y rounds up to X+1 and + * there is no r * od = X+1. For the converse, when X.Y + * is rounded down to X, we should choose X+1 over X-1. + */ + err = abs(r * od - goal); + last_err = abs(last_r * last_od - goal); + if (last_err < err || (round_up && last_err == err)) { + i--; + r = last_r; + od = last_od; + } + } + + /* + * Enforce limits on internal clock frequencies. If we + * aren't in spec, try swapping r and od. If everything is + * in-spec, calculate the relative error. + */ + while (true) { + /* + * Whether the intermediate frequencies are out-of-spec + */ + bool out_of_spec = false; + + if (r > max_r) { + out_of_spec = true; + } else { + /* + * There is no way to only divide once; we need + * to examine the frequency with and without the + * effect of od. + */ + u64 vco = DIV_ROUND_CLOSEST_ULL(rate_in * f, r); + + if (vco > 1750000000 || vco < 340000000) + out_of_spec = true; + } + + if (out_of_spec) { + if (!swapped) { + u64 tmp = r; + + r = od; + od = tmp; + swapped = true; + continue; + } else { + /* + * Try looking ahead to see if there are + * additional factors for the same + * product. + */ + if (i + 1 < ARRAY_SIZE(factors)) { + u64 new_r, new_od; + + i++; + new_r = UNPACK_R(factors[i]); + new_od = UNPACK_OD(factors[i]); + if (r * od == new_r * new_od) { + r = new_r; + od = new_od; + swapped = false; + continue; + } + i--; + } + break; + } + } + + error = DIV_ROUND_CLOSEST_ULL(f * inv_ratio, r * od); + /* The lower 16 bits are spurious */ + error = abs((error - BIT(32))) >> 16; + + if (error < best_error) { + best->r = r; + best->f = f; + best->od = od; + best_error = error; + } + break; + } + } while (f < 64 && i + 1 < ARRAY_SIZE(factors) && error != 0); + + if (best_error == S64_MAX) + return -EINVAL; + + log_debug("best error %lld\n", best_error); + return 0; +} + +static ulong k210_pll_set_rate(struct clk *clk, ulong rate) +{ + int err; + long long rate_in = clk_get_parent_rate(clk); + struct k210_pll_params params = {}; + struct k210_pll *pll = to_k210_pll(clk); + u32 reg; + + if (rate_in < 0) + return rate_in; + + log_debug("Calculating parameters with rate=%lu and rate_in=%lld\n", + rate, rate_in); + err = k210_pll_calc_params(rate, rate_in, ¶ms); + if (err) + return err; + log_debug("Got r=%u f=%u od=%u\n", params.r, params.f, params.od); + + /* + * Don't use clk_disable as it might not actually disable the pll due to + * refcounting + */ + k210_pll_disable(clk); + + reg = readl(pll->reg); + reg &= ~K210_PLL_CLKR + & ~K210_PLL_CLKF + & ~K210_PLL_CLKOD + & ~K210_PLL_BWADJ; + reg |= FIELD_PREP(K210_PLL_CLKR, params.r - 1) + | FIELD_PREP(K210_PLL_CLKF, params.f - 1) + | FIELD_PREP(K210_PLL_CLKOD, params.od - 1) + | FIELD_PREP(K210_PLL_BWADJ, params.f - 1); + writel(reg, pll->reg); + + err = k210_pll_enable(clk); + if (err) + return err; + + serial_setbrg(); + return clk_get_rate(clk); +} +#endif /* CONFIG_CLK_K210_SET_RATE */ + +static ulong k210_pll_get_rate(struct clk *clk) +{ + long long rate_in = clk_get_parent_rate(clk); + struct k210_pll *pll = to_k210_pll(clk); + u64 r, f, od; + u32 reg = readl(pll->reg); + + if (rate_in < 0 || (reg & K210_PLL_BYPASS)) + return rate_in; + + if (!(reg & K210_PLL_PWRD)) + return 0; + + r = FIELD_GET(K210_PLL_CLKR, reg) + 1; + f = FIELD_GET(K210_PLL_CLKF, reg) + 1; + od = FIELD_GET(K210_PLL_CLKOD, reg) + 1; + + return DIV_ROUND_DOWN_ULL(((u64)rate_in) * f, r * od); +} + +/* + * Wait for the PLL to be locked. If the PLL is not locked, try clearing the + * slip before retrying + */ +static void k210_pll_waitfor_lock(struct k210_pll *pll) +{ + u32 mask = GENMASK(pll->width - 1, 0) << pll->shift; + + while (true) { + u32 reg = readl(pll->lock); + + if ((reg & mask) == mask) + break; + + reg |= BIT(pll->shift + K210_PLL_CLEAR_SLIP); + writel(reg, pll->lock); + } +} + +/* Adapted from sysctl_pll_enable */ +static int k210_pll_enable(struct clk *clk) +{ + struct k210_pll *pll = to_k210_pll(clk); + u32 reg = readl(pll->reg); + + if ((reg | K210_PLL_PWRD) && !(reg | K210_PLL_RESET)) + return 0; + + reg |= K210_PLL_PWRD; + writel(reg, pll->reg); + + /* Ensure reset is low before asserting it */ + reg &= ~K210_PLL_RESET; + writel(reg, pll->reg); + reg |= K210_PLL_RESET; + writel(reg, pll->reg); + nop(); + nop(); + reg &= ~K210_PLL_RESET; + writel(reg, pll->reg); + + k210_pll_waitfor_lock(pll); + + reg &= ~K210_PLL_BYPASS; + writel(reg, pll->reg); + + return 0; +} + +static int k210_pll_disable(struct clk *clk) +{ + struct k210_pll *pll = to_k210_pll(clk); + u32 reg = readl(pll->reg); + + /* + * Bypassing before powering off is important so child clocks don't stop + * working. This is especially important for pll0, the indirect parent + * of the cpu clock. + */ + reg |= K210_PLL_BYPASS; + writel(reg, pll->reg); + + reg &= ~K210_PLL_PWRD; + writel(reg, pll->reg); + return 0; +} + +const struct clk_ops k210_pll_ops = { + .get_rate = k210_pll_get_rate, +#ifdef CONFIG_CLK_K210_SET_RATE + .set_rate = k210_pll_set_rate, +#endif + .enable = k210_pll_enable, + .disable = k210_pll_disable, +}; + +struct clk *k210_register_pll_struct(const char *name, const char *parent_name, + struct k210_pll *pll) +{ + int ret; + struct clk *clk = &pll->clk; + + ret = clk_register(clk, CLK_K210_PLL, name, parent_name); + if (ret) + return ERR_PTR(ret); + return clk; +} + +struct clk *k210_register_pll(const char *name, const char *parent_name, + void __iomem *reg, void __iomem *lock, u8 shift, + u8 width) +{ + struct clk *clk; + struct k210_pll *pll; + + pll = kzalloc(sizeof(*pll), GFP_KERNEL); + if (!pll) + return ERR_PTR(-ENOMEM); + pll->reg = reg; + pll->lock = lock; + pll->shift = shift; + pll->width = width; + + clk = k210_register_pll_struct(name, parent_name, pll); + if (IS_ERR(clk)) + kfree(pll); + return clk; +} + +U_BOOT_DRIVER(k210_pll) = { + .name = CLK_K210_PLL, + .id = UCLASS_CLK, + .ops = &k210_pll_ops, +}; diff --git a/include/kendryte/pll.h b/include/kendryte/pll.h new file mode 100644 index 0000000000..e181b0a9c3 --- /dev/null +++ b/include/kendryte/pll.h @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ +#ifndef K210_PLL_H +#define K210_PLL_H + +#include <clk.h> +#include <test/export.h> + +#define K210_PLL_CLKR GENMASK(3, 0) +#define K210_PLL_CLKF GENMASK(9, 4) +#define K210_PLL_CLKOD GENMASK(13, 10) /* Output Divider */ +#define K210_PLL_BWADJ GENMASK(19, 14) /* BandWidth Adjust */ +#define K210_PLL_RESET BIT(20) +#define K210_PLL_PWRD BIT(21) /* PoWeReD */ +#define K210_PLL_INTFB BIT(22) /* Internal FeedBack */ +#define K210_PLL_BYPASS BIT(23) +#define K210_PLL_TEST BIT(24) +#define K210_PLL_EN BIT(25) +#define K210_PLL_TEST_EN BIT(26) + +#define K210_PLL_LOCK 0 +#define K210_PLL_CLEAR_SLIP 2 +#define K210_PLL_TEST_OUT 3 + +struct k210_pll { + struct clk clk; + void __iomem *reg; /* Base PLL register */ + void __iomem *lock; /* Common PLL lock register */ + u8 shift; /* Offset of bits in lock register */ + u8 width; /* Width of lock bits to test against */ +}; + +#define to_k210_pll(_clk) container_of(_clk, struct k210_pll, clk) + +struct k210_pll_params { + u8 r; + u8 f; + u8 od; +}; + +#ifdef CONFIG_UNIT_TEST +TEST_STATIC int k210_pll_calc_params(u32 rate, u32 rate_in, + struct k210_pll_params *best); +#define nop() +#endif + +extern const struct clk_ops k210_pll_ops; + +struct clk *k210_register_pll_struct(const char *name, const char *parent_name, + struct k210_pll *pll); +struct clk *k210_register_pll(const char *name, const char *parent_name, + void __iomem *reg, void __iomem *lock, u8 shift, + u8 width); + +#endif /* K210_PLL_H */ diff --git a/include/test/export.h b/include/test/export.h new file mode 100644 index 0000000000..afc755a8ff --- /dev/null +++ b/include/test/export.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#ifndef TEST_EXPORT_H +#define TEST_EXPORT_H + +/* Declare something static, unless we are doing unit tests */ +#ifdef CONFIG_UNIT_TEST +#define TEST_STATIC +#else +#define TEST_STATIC static +#endif + +#endif /* TEST_EXPORT_H */ diff --git a/test/dm/Makefile b/test/dm/Makefile index dd1ceff86c..ef6065b60f 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -70,4 +70,5 @@ obj-$(CONFIG_DMA) += dma.o obj-$(CONFIG_DM_MDIO) += mdio.o obj-$(CONFIG_DM_MDIO_MUX) += mdio_mux.o obj-$(CONFIG_DM_RNG) += rng.o +obj-$(CONFIG_CLK_K210_SET_RATE) += k210_pll.o endif diff --git a/test/dm/k210_pll.c b/test/dm/k210_pll.c new file mode 100644 index 0000000000..2c5e026985 --- /dev/null +++ b/test/dm/k210_pll.c @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#include <common.h> +/* For DIV_ROUND_DOWN_ULL, defined in linux/kernel.h */ +#include <div64.h> +#include <dm/test.h> +#include <kendryte/pll.h> +#include <test/ut.h> + +static int dm_test_k210_pll_calc_params(u32 rate, u32 rate_in, + struct k210_pll_params *best) +{ + u64 f, r, od, max_r, inv_ratio; + s64 error, best_error; + + best_error = S64_MAX; + error = best_error; + max_r = min(16ULL, DIV_ROUND_DOWN_ULL(rate_in, 13300000)); + inv_ratio = DIV_ROUND_CLOSEST_ULL((u64)rate_in << 32, rate); + + /* Brute force it */ + for (r = 1; r <= max_r; r++) { + for (f = 1; f <= 64; f++) { + for (od = 1; od <= 16; od++) { + u64 vco = DIV_ROUND_CLOSEST_ULL(rate_in * f, r); + + if (vco > 1750000000 || vco < 340000000) + continue; + + error = DIV_ROUND_CLOSEST_ULL(f * inv_ratio, + r * od); + /* The lower 16 bits are spurious */ + error = abs((error - BIT(32))) >> 16; + if (error < best_error) { + best->r = r; + best->f = f; + best->od = od; + best_error = error; + } + } + } + } + + if (best_error == S64_MAX) + return -EINVAL; + return 0; +} + +static int dm_test_k210_pll_compare(struct k210_pll_params *ours, + struct k210_pll_params *theirs) +{ + return (u32)ours->f * theirs->r * theirs->od != + (u32)theirs->f * ours->r * ours->od; +} + +static int dm_test_k210_pll(struct unit_test_state *uts) +{ + struct k210_pll_params ours, theirs; + + /* General range checks */ + ut_asserteq(-EINVAL, k210_pll_calc_params(0, 26000000, &theirs)); + ut_asserteq(-EINVAL, k210_pll_calc_params(390000000, 0, &theirs)); + ut_asserteq(-EINVAL, k210_pll_calc_params(2000000000, 26000000, + &theirs)); + ut_asserteq(-EINVAL, k210_pll_calc_params(390000000, 2000000000, + &theirs)); + ut_asserteq(-EINVAL, k210_pll_calc_params(1500000000, 20000000, + &theirs)); + + /* Verify we get the same output with brute-force */ + ut_assertok(dm_test_k210_pll_calc_params(390000000, 26000000, &ours)); + ut_assertok(k210_pll_calc_params(390000000, 26000000, &theirs)); + ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); + + ut_assertok(dm_test_k210_pll_calc_params(26000000, 390000000, &ours)); + ut_assertok(k210_pll_calc_params(26000000, 390000000, &theirs)); + ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); + + ut_assertok(dm_test_k210_pll_calc_params(400000000, 26000000, &ours)); + ut_assertok(k210_pll_calc_params(400000000, 26000000, &theirs)); + ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); + + ut_assertok(dm_test_k210_pll_calc_params(27000000, 26000000, &ours)); + ut_assertok(k210_pll_calc_params(27000000, 26000000, &theirs)); + ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); + + ut_assertok(dm_test_k210_pll_calc_params(26000000, 27000000, &ours)); + ut_assertok(k210_pll_calc_params(26000000, 27000000, &theirs)); + ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); + + return 0; +} +DM_TEST(dm_test_k210_pll, 0);
This is a small driver to do a software bypass of a clock if hardware bypass is not working. I have tried to write this in a generic fashion, so that it could be potentially broken out of the kendryte code at some future date. For the K210, it is used to have aclk bypass pll0 and use in0 instead so that the CPU keeps on working.
Changes in v5: - Add function to register from a struct bypass
Changes in v4: - New
drivers/clk/kendryte/Makefile | 2 +- drivers/clk/kendryte/bypass.c | 270 ++++++++++++++++++++++++++++++++++ include/kendryte/bypass.h | 31 ++++ 3 files changed, 302 insertions(+), 1 deletion(-) create mode 100644 drivers/clk/kendryte/bypass.c create mode 100644 include/kendryte/bypass.h
diff --git a/drivers/clk/kendryte/Makefile b/drivers/clk/kendryte/Makefile index c56d93ea1c..47f682fce3 100644 --- a/drivers/clk/kendryte/Makefile +++ b/drivers/clk/kendryte/Makefile @@ -1 +1 @@ -obj-y += pll.o +obj-y += bypass.o pll.o diff --git a/drivers/clk/kendryte/bypass.c b/drivers/clk/kendryte/bypass.c new file mode 100644 index 0000000000..eb3e27d055 --- /dev/null +++ b/drivers/clk/kendryte/bypass.c @@ -0,0 +1,270 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#include <kendryte/bypass.h> + +#include <clk-uclass.h> +#include <linux/clk-provider.h> +#include <linux/err.h> +#define LOG_CATEGORY UCLASS_CLK +#include <log.h> + +#define CLK_K210_BYPASS "k210_clk_bypass" + +/* + * This is a small driver to do a software bypass of a clock if hardware bypass + * is not working. I have tried to write this in a generic fashion, so that it + * could be potentially broken out of the kendryte code at some future date. + * + * Say you have the following clock configuration + * + * +---+ +---+ + * |osc| |pll| + * +---+ +---+ + * ^ + * /| + * / | + * / | + * / | + * / | + * +---+ +---+ + * |clk| |clk| + * +---+ +---+ + * + * But the pll does not have a bypass, so when you configure the pll, the + * configuration needs to change to look like + * + * +---+ +---+ + * |osc| |pll| + * +---+ +---+ + * ^ + * |\ + * | \ + * | \ + * | \ + * | \ + * +---+ +---+ + * |clk| |clk| + * +---+ +---+ + * + * To set this up, create a bypass clock with bypassee=pll and alt=osc. When + * creating the child clocks, set their parent to the bypass clock. After + * creating all the children, call k210_bypass_setchildren(). + */ + +static int k210_bypass_dobypass(struct k210_bypass *bypass) +{ + int ret, i; + + /* + * If we already have saved parents, then the children are already + * bypassed + */ + if (bypass->child_count && bypass->saved_parents[0]) + return 0; + + for (i = 0; i < bypass->child_count; i++) { + struct clk *child = bypass->children[i]; + struct clk *parent = clk_get_parent(child); + + if (IS_ERR(parent)) { + for (; i; i--) + bypass->saved_parents[i] = NULL; + return PTR_ERR(parent); + } + bypass->saved_parents[i] = parent; + } + + for (i = 0; i < bypass->child_count; i++) { + struct clk *child = bypass->children[i]; + + ret = clk_set_parent(child, bypass->alt); + if (ret) { + for (; i; i--) + clk_set_parent(bypass->children[i], + bypass->saved_parents[i]); + for (i = 0; i < bypass->child_count; i++) + bypass->saved_parents[i] = NULL; + return ret; + } + } + + return 0; +} + +static int k210_bypass_unbypass(struct k210_bypass *bypass) +{ + int err, ret, i; + + if (!bypass->child_count && !bypass->saved_parents[0]) { + log_warning("Cannot unbypass children; dobypass not called first\n"); + return 0; + } + + ret = 0; + for (i = 0; i < bypass->child_count; i++) { + err = clk_set_parent(bypass->children[i], + bypass->saved_parents[i]); + if (err) + ret = err; + bypass->saved_parents[i] = NULL; + } + return ret; +} + +static ulong k210_bypass_get_rate(struct clk *clk) +{ + struct k210_bypass *bypass = to_k210_bypass(clk); + const struct clk_ops *ops = bypass->bypassee_ops; + + if (ops->get_rate) + return ops->get_rate(bypass->bypassee); + else + return clk_get_parent_rate(bypass->bypassee); +} + +static ulong k210_bypass_set_rate(struct clk *clk, unsigned long rate) +{ + int ret; + struct k210_bypass *bypass = to_k210_bypass(clk); + const struct clk_ops *ops = bypass->bypassee_ops; + + /* Don't bother bypassing if we aren't going to set the rate */ + if (!ops->set_rate) + return k210_bypass_get_rate(clk); + + ret = k210_bypass_dobypass(bypass); + if (ret) + return ret; + + ret = ops->set_rate(bypass->bypassee, rate); + if (ret < 0) + return ret; + + return k210_bypass_unbypass(bypass); +} + +static int k210_bypass_set_parent(struct clk *clk, struct clk *parent) +{ + struct k210_bypass *bypass = to_k210_bypass(clk); + const struct clk_ops *ops = bypass->bypassee_ops; + + if (ops->set_parent) + return ops->set_parent(bypass->bypassee, parent); + else + return -ENOTSUPP; +} + +/* + * For these next two functions, do the bypassing even if there is no + * en-/-disable function, since the bypassing itself can be observed in between + * calls. + */ +static int k210_bypass_enable(struct clk *clk) +{ + int ret; + struct k210_bypass *bypass = to_k210_bypass(clk); + const struct clk_ops *ops = bypass->bypassee_ops; + + ret = k210_bypass_dobypass(bypass); + if (ret) + return ret; + + if (ops->enable) + ret = ops->enable(bypass->bypassee); + else + ret = 0; + if (ret) + return ret; + + return k210_bypass_unbypass(bypass); +} + +static int k210_bypass_disable(struct clk *clk) +{ + int ret; + struct k210_bypass *bypass = to_k210_bypass(clk); + const struct clk_ops *ops = bypass->bypassee_ops; + + ret = k210_bypass_dobypass(bypass); + if (ret) + return ret; + + if (ops->disable) + return ops->disable(bypass->bypassee); + else + return 0; +} + +static const struct clk_ops k210_bypass_ops = { + .get_rate = k210_bypass_get_rate, + .set_rate = k210_bypass_set_rate, + .set_parent = k210_bypass_set_parent, + .enable = k210_bypass_enable, + .disable = k210_bypass_disable, +}; + +int k210_bypass_set_children(struct clk *clk, struct clk **children, + size_t child_count) +{ + struct k210_bypass *bypass = to_k210_bypass(clk); + + kfree(bypass->saved_parents); + if (child_count) { + bypass->saved_parents = + kcalloc(child_count, sizeof(struct clk *), GFP_KERNEL); + if (!bypass->saved_parents) + return -ENOMEM; + } + bypass->child_count = child_count; + bypass->children = children; + + return 0; +} + +struct clk *k210_register_bypass_struct(const char *name, + const char *parent_name, + struct k210_bypass *bypass) +{ + int ret; + struct clk *clk; + + clk = &bypass->clk; + + ret = clk_register(clk, CLK_K210_BYPASS, name, parent_name); + if (ret) + return ERR_PTR(ret); + + bypass->bypassee->dev = clk->dev; + return clk; +} + +struct clk *k210_register_bypass(const char *name, const char *parent_name, + struct clk *bypassee, + const struct clk_ops *bypassee_ops, + struct clk *alt) +{ + struct clk *clk; + struct k210_bypass *bypass; + + bypass = kzalloc(sizeof(*bypass), GFP_KERNEL); + if (!bypass) + return ERR_PTR(-ENOMEM); + + bypass->bypassee = bypassee; + bypass->bypassee_ops = bypassee_ops; + bypass->alt = alt; + + clk = k210_register_bypass_struct(name, parent_name, bypass); + if (IS_ERR(clk)) + kfree(bypass); + return clk; +} + +U_BOOT_DRIVER(k210_bypass) = { + .name = CLK_K210_BYPASS, + .id = UCLASS_CLK, + .ops = &k210_bypass_ops, +}; diff --git a/include/kendryte/bypass.h b/include/kendryte/bypass.h new file mode 100644 index 0000000000..a081cbd12f --- /dev/null +++ b/include/kendryte/bypass.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ +#ifndef K210_BYPASS_H +#define K210_BYPASS_H + +#include <clk.h> + +struct k210_bypass { + struct clk clk; + struct clk **children; /* Clocks to reparent */ + struct clk **saved_parents; /* Parents saved over en-/dis-able */ + struct clk *bypassee; /* Clock to bypass */ + const struct clk_ops *bypassee_ops; /* Ops of the bypass clock */ + struct clk *alt; /* Clock to set children to when bypassing */ + size_t child_count; +}; + +#define to_k210_bypass(_clk) container_of(_clk, struct k210_bypass, clk) + +int k210_bypass_set_children(struct clk *clk, struct clk **children, + size_t child_count); +struct clk *k210_register_bypass_struct(const char *name, + const char *parent_name, + struct k210_bypass *bypass); +struct clk *k210_register_bypass(const char *name, const char *parent_name, + struct clk *bypassee, + const struct clk_ops *bypassee_ops, + struct clk *alt); +#endif /* K210_BYPASS_H */
Due to the large number of clocks, I decided to use the CCF. The overall structure is modeled after the imx code. Clocks are stored in several arrays. There are some translation macros (FOOIFY()) which allow for more dense packing. A possible improvement could be to only store the parameters we need, instead of the whole CCF struct.
Changes in v6: - Reformat code so checkpatch generates fewer warnings - Give "fictional" clocks their own ids - Rename sysctl CLK_FREQ register to UART_BAUD to better reflect its semantics
Changes in v5: - Don't unmap priv->reg - Remove comment on APB clocks since it has been clarified by Kendryte - Add i2s mclks - Reorder clock ids to be continuous - Rewrite to statically allocate all clocks. This has helped find several bugs (since it is easy to see when a clock has the wrong register). - Fix ACLK sometimes having the wrong parent - Fix SPI3 having the wrong divider - Prevent being probed multiple times on failure
Changes in v4: - Reparent aclk before configuring pll0 - Update copyright - Lint
Changes in v3: - Removed sysctl struct, replacing it with defines. This is to have the same interface to sysctl from C as from the device tree. - Fixed clocks having the same id - Fixed clocks not using the correct register/bits - Aligned the defines in headers
Changes in v2: - Add clk.o to obj-y - Don't probe before relocation
MAINTAINERS | 7 + .../mfd/kendryte,k210-sysctl.txt | 33 ++ drivers/clk/kendryte/Kconfig | 2 +- drivers/clk/kendryte/Makefile | 2 +- drivers/clk/kendryte/clk.c | 489 ++++++++++++++++++ include/dt-bindings/clock/k210-sysctl.h | 59 +++ include/dt-bindings/mfd/k210-sysctl.h | 38 ++ include/kendryte/clk.h | 35 ++ 8 files changed, 663 insertions(+), 2 deletions(-) create mode 100644 doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt create mode 100644 drivers/clk/kendryte/clk.c create mode 100644 include/dt-bindings/clock/k210-sysctl.h create mode 100644 include/dt-bindings/mfd/k210-sysctl.h create mode 100644 include/kendryte/clk.h
diff --git a/MAINTAINERS b/MAINTAINERS index 37ff21a037..27ed9a27d3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -807,6 +807,13 @@ F: arch/riscv/ F: cmd/riscv/ F: tools/prelink-riscv.c
+RISC-V KENDRYTE +M: Sean Anderson seanga2@gmail.com +S: Maintained +F: doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt +F: drivers/clk/kendryte/ +F: include/kendryte/ + RNG M: Sughosh Ganu sughosh.ganu@linaro.org R: Heinrich Schuchardt xypron.glpk@gmx.de diff --git a/doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt b/doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt new file mode 100644 index 0000000000..5b24abcb62 --- /dev/null +++ b/doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt @@ -0,0 +1,33 @@ +Kendryte K210 Sysctl + +This binding describes the K210 sysctl device, which contains many miscellaneous +registers controlling system functionality. This node is a register map and can +be reference by other bindings which need a phandle to the K210 sysctl regmap. + +Required properties: +- compatible: should be + "kendryte,k210-sysctl", "syscon", "simple-mfd" +- reg: address and length of the sysctl registers +- reg-io-width: must be <4> + +Clock sub-node + +This node is a binding for the clock tree driver + +Required properties: +- compatible: should be "kendryte,k210-clk" +- clocks: phandle to the "in0" external oscillator +- #clock-cells: must be <1> + +Example: +sysctl: syscon@50440000 { + compatible = "kendryte,k210-sysctl", "syscon", "simple-mfd"; + reg = <0x50440000 0x100>; + reg-io-width = <4>; + + sysclk: clock-controller { + compatible = "kendryte,k210-clk"; + clocks = <&in0>; + #clock-cells = <1>; + }; +}; diff --git a/drivers/clk/kendryte/Kconfig b/drivers/clk/kendryte/Kconfig index 7b69c8afaf..073fca0781 100644 --- a/drivers/clk/kendryte/Kconfig +++ b/drivers/clk/kendryte/Kconfig @@ -1,6 +1,6 @@ config CLK_K210 bool "Clock support for Kendryte K210" - depends on CLK && CLK_CCF + depends on CLK && CLK_CCF && CLK_COMPOSITE_CCF help This enables support clock driver for Kendryte K210 platforms.
diff --git a/drivers/clk/kendryte/Makefile b/drivers/clk/kendryte/Makefile index 47f682fce3..6fb68253ae 100644 --- a/drivers/clk/kendryte/Makefile +++ b/drivers/clk/kendryte/Makefile @@ -1 +1 @@ -obj-y += bypass.o pll.o +obj-y += bypass.o clk.o pll.o diff --git a/drivers/clk/kendryte/clk.c b/drivers/clk/kendryte/clk.c new file mode 100644 index 0000000000..7eb2f705a0 --- /dev/null +++ b/drivers/clk/kendryte/clk.c @@ -0,0 +1,489 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ +#include <kendryte/clk.h> + +#include <asm/io.h> +#include <dt-bindings/clock/k210-sysctl.h> +#include <dt-bindings/mfd/k210-sysctl.h> +#include <dm.h> +#include <log.h> +#include <mapmem.h> + +#include <kendryte/bypass.h> +#include <kendryte/pll.h> + +static ulong k210_clk_get_rate(struct clk *clk) +{ + struct clk *c; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + return clk_get_rate(c); +} + +static ulong k210_clk_set_rate(struct clk *clk, unsigned long rate) +{ + struct clk *c; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + return clk_set_rate(c, rate); +} + +static int k210_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct clk *c, *p; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + + err = clk_get_by_id(parent->id, &p); + if (err) + return err; + + return clk_set_parent(c, p); +} + +static int k210_clk_endisable(struct clk *clk, bool enable) +{ + struct clk *c; + int err = clk_get_by_id(clk->id, &c); + + if (err) + return err; + return enable ? clk_enable(c) : clk_disable(c); +} + +static int k210_clk_enable(struct clk *clk) +{ + return k210_clk_endisable(clk, true); +} + +static int k210_clk_disable(struct clk *clk) +{ + return k210_clk_endisable(clk, false); +} + +static const struct clk_ops k210_clk_ops = { + .set_rate = k210_clk_set_rate, + .get_rate = k210_clk_get_rate, + .set_parent = k210_clk_set_parent, + .enable = k210_clk_enable, + .disable = k210_clk_disable, +}; + +static const char * const generic_sels[] = { "in0_half", "pll0_half" }; +/* The first clock is in0, which is filled in by k210_clk_probe */ +static const char *aclk_sels[] = { NULL, "pll0_half" }; +static const char *pll2_sels[] = { NULL, "pll0", "pll1" }; + +#define DIV(id, reg, shift, width) DIV_FLAGS(id, reg, shift, width, 0) +#define DIV_LIST \ + DIV_FLAGS(K210_CLK_ACLK, K210_SYSCTL_SEL0, 1, 2, \ + CLK_DIVIDER_POWER_OF_TWO) \ + DIV(K210_CLK_APB0, K210_SYSCTL_SEL0, 3, 3) \ + DIV(K210_CLK_APB1, K210_SYSCTL_SEL0, 6, 3) \ + DIV(K210_CLK_APB2, K210_SYSCTL_SEL0, 9, 3) \ + DIV(K210_CLK_SRAM0, K210_SYSCTL_THR0, 0, 4) \ + DIV(K210_CLK_SRAM1, K210_SYSCTL_THR0, 4, 4) \ + DIV(K210_CLK_AI, K210_SYSCTL_THR0, 8, 4) \ + DIV(K210_CLK_DVP, K210_SYSCTL_THR0, 12, 4) \ + DIV(K210_CLK_ROM, K210_SYSCTL_THR0, 16, 4) \ + DIV(K210_CLK_SPI0, K210_SYSCTL_THR1, 0, 8) \ + DIV(K210_CLK_SPI1, K210_SYSCTL_THR1, 8, 8) \ + DIV(K210_CLK_SPI2, K210_SYSCTL_THR1, 16, 8) \ + DIV(K210_CLK_SPI3, K210_SYSCTL_THR1, 24, 8) \ + DIV(K210_CLK_TIMER0, K210_SYSCTL_THR2, 0, 8) \ + DIV(K210_CLK_TIMER1, K210_SYSCTL_THR2, 8, 8) \ + DIV(K210_CLK_TIMER2, K210_SYSCTL_THR2, 16, 8) \ + DIV(K210_CLK_I2S0, K210_SYSCTL_THR3, 0, 16) \ + DIV(K210_CLK_I2S1, K210_SYSCTL_THR3, 16, 16) \ + DIV(K210_CLK_I2S2, K210_SYSCTL_THR4, 0, 16) \ + DIV(K210_CLK_I2S0_M, K210_SYSCTL_THR4, 16, 8) \ + DIV(K210_CLK_I2S1_M, K210_SYSCTL_THR4, 24, 8) \ + DIV(K210_CLK_I2S2_M, K210_SYSCTL_THR4, 0, 8) \ + DIV(K210_CLK_I2C0, K210_SYSCTL_THR5, 8, 8) \ + DIV(K210_CLK_I2C1, K210_SYSCTL_THR5, 16, 8) \ + DIV(K210_CLK_I2C2, K210_SYSCTL_THR5, 24, 8) \ + DIV(K210_CLK_WDT0, K210_SYSCTL_THR6, 0, 8) \ + DIV(K210_CLK_WDT1, K210_SYSCTL_THR6, 8, 8) + +#define _DIVIFY(id) K210_CLK_DIV_##id +#define DIVIFY(id) _DIVIFY(id) + +enum k210_clk_div_ids { +#define DIV_FLAGS(id, ...) DIVIFY(id), + DIV_LIST +#undef DIV_FLAGS +}; + +static struct clk_divider k210_clk_dividers[] = { +#define DIV_FLAGS(id, _reg, _shift, _width, _flags) \ + [DIVIFY(id)] = { \ + .reg = (void *)(_reg), \ + .shift = (_shift), \ + .width = (_width), \ + .flags = (_flags), \ + }, + DIV_LIST +#undef DIV_FLAGS +}; + +#undef DIV +#undef DIV_LIST + +#define GATE_LIST \ + GATE(K210_CLK_CPU, K210_SYSCTL_EN_CENT, 0) \ + GATE(K210_CLK_SRAM0, K210_SYSCTL_EN_CENT, 1) \ + GATE(K210_CLK_SRAM1, K210_SYSCTL_EN_CENT, 2) \ + GATE(K210_CLK_APB0, K210_SYSCTL_EN_CENT, 3) \ + GATE(K210_CLK_APB1, K210_SYSCTL_EN_CENT, 4) \ + GATE(K210_CLK_APB2, K210_SYSCTL_EN_CENT, 5) \ + GATE(K210_CLK_ROM, K210_SYSCTL_EN_PERI, 0) \ + GATE(K210_CLK_DMA, K210_SYSCTL_EN_PERI, 1) \ + GATE(K210_CLK_AI, K210_SYSCTL_EN_PERI, 2) \ + GATE(K210_CLK_DVP, K210_SYSCTL_EN_PERI, 3) \ + GATE(K210_CLK_FFT, K210_SYSCTL_EN_PERI, 4) \ + GATE(K210_CLK_GPIO, K210_SYSCTL_EN_PERI, 5) \ + GATE(K210_CLK_SPI0, K210_SYSCTL_EN_PERI, 6) \ + GATE(K210_CLK_SPI1, K210_SYSCTL_EN_PERI, 7) \ + GATE(K210_CLK_SPI2, K210_SYSCTL_EN_PERI, 8) \ + GATE(K210_CLK_SPI3, K210_SYSCTL_EN_PERI, 9) \ + GATE(K210_CLK_I2S0, K210_SYSCTL_EN_PERI, 10) \ + GATE(K210_CLK_I2S1, K210_SYSCTL_EN_PERI, 11) \ + GATE(K210_CLK_I2S2, K210_SYSCTL_EN_PERI, 12) \ + GATE(K210_CLK_I2C0, K210_SYSCTL_EN_PERI, 13) \ + GATE(K210_CLK_I2C1, K210_SYSCTL_EN_PERI, 14) \ + GATE(K210_CLK_I2C2, K210_SYSCTL_EN_PERI, 15) \ + GATE(K210_CLK_UART1, K210_SYSCTL_EN_PERI, 16) \ + GATE(K210_CLK_UART2, K210_SYSCTL_EN_PERI, 17) \ + GATE(K210_CLK_UART3, K210_SYSCTL_EN_PERI, 18) \ + GATE(K210_CLK_AES, K210_SYSCTL_EN_PERI, 19) \ + GATE(K210_CLK_FPIOA, K210_SYSCTL_EN_PERI, 20) \ + GATE(K210_CLK_TIMER0, K210_SYSCTL_EN_PERI, 21) \ + GATE(K210_CLK_TIMER1, K210_SYSCTL_EN_PERI, 22) \ + GATE(K210_CLK_TIMER2, K210_SYSCTL_EN_PERI, 23) \ + GATE(K210_CLK_WDT0, K210_SYSCTL_EN_PERI, 24) \ + GATE(K210_CLK_WDT1, K210_SYSCTL_EN_PERI, 25) \ + GATE(K210_CLK_SHA, K210_SYSCTL_EN_PERI, 26) \ + GATE(K210_CLK_OTP, K210_SYSCTL_EN_PERI, 27) \ + GATE(K210_CLK_RTC, K210_SYSCTL_EN_PERI, 29) + +#define _GATEIFY(id) K210_CLK_GATE_##id +#define GATEIFY(id) _GATEIFY(id) + +enum k210_clk_gate_ids { +#define GATE(id, ...) GATEIFY(id), + GATE_LIST +#undef GATE +}; + +static struct clk_gate k210_clk_gates[] = { +#define GATE(id, _reg, _idx) \ + [GATEIFY(id)] = { \ + .reg = (void *)(_reg), \ + .bit_idx = (_idx), \ + }, + GATE_LIST +#undef GATE +}; + +#undef GATE_LIST + +#define MUX(id, reg, shift, width) \ + MUX_PARENTS(id, generic_sels, reg, shift, width) +#define MUX_LIST \ + MUX_PARENTS(K210_CLK_PLL2, pll2_sels, K210_SYSCTL_PLL2, 26, 2) \ + MUX_PARENTS(K210_CLK_ACLK, aclk_sels, K210_SYSCTL_SEL0, 0, 1) \ + MUX(K210_CLK_SPI3, K210_SYSCTL_SEL0, 12, 1) \ + MUX(K210_CLK_TIMER0, K210_SYSCTL_SEL0, 13, 1) \ + MUX(K210_CLK_TIMER1, K210_SYSCTL_SEL0, 14, 1) \ + MUX(K210_CLK_TIMER2, K210_SYSCTL_SEL0, 15, 1) + +#define _MUXIFY(id) K210_CLK_MUX_##id +#define MUXIFY(id) _MUXIFY(id) + +enum k210_clk_mux_ids { +#define MUX_PARENTS(id, ...) MUXIFY(id), + MUX_LIST +#undef MUX_PARENTS +}; + +static struct clk_mux k210_clk_muxes[] = { +#define MUX_PARENTS(id, parents, _reg, _shift, _width) \ + [MUXIFY(id)] = { \ + .parent_names = (const char * const *)(parents), \ + .num_parents = ARRAY_SIZE(parents), \ + .reg = (void *)(_reg), \ + .shift = (_shift), \ + .mask = BIT(_width) - 1, \ + }, + MUX_LIST +#undef MUX_PARENTS +}; + +#undef MUX +#undef MUX_LIST + +static struct k210_pll k210_clk_plls[] = { +#define PLL(_reg, _shift, _width) { \ + .reg = (void *)(_reg), \ + .lock = (void *)K210_SYSCTL_PLL_LOCK, \ + .shift = (_shift), \ + .width = (_width), \ +} + [0] = PLL(K210_SYSCTL_PLL0, 0, 2), + [1] = PLL(K210_SYSCTL_PLL1, 8, 1), + [2] = PLL(K210_SYSCTL_PLL2, 16, 1), +#undef PLL +}; + +#define COMP(id, mux, div, gate) \ + COMP_FULL(id, &(mux)->clk, &clk_mux_ops, \ + &(div)->clk, &clk_divider_ops, \ + &(gate)->clk, &clk_gate_ops) +#define COMP_ID(id) \ + COMP(id, &k210_clk_muxes[MUXIFY(id)], \ + &k210_clk_dividers[DIVIFY(id)], \ + &k210_clk_gates[GATEIFY(id)]) +#define COMP_NOMUX(id, div, gate) \ + COMP_FULL(id, NULL, NULL, \ + &(div)->clk, &clk_divider_ops, \ + &(gate)->clk, &clk_gate_ops) +#define COMP_NOMUX_ID(id) \ + COMP_NOMUX(id, &k210_clk_dividers[DIVIFY(id)], \ + &k210_clk_gates[GATEIFY(id)]) +#define COMP_LIST \ + COMP_FULL(K210_CLK_PLL2, \ + &k210_clk_muxes[MUXIFY(K210_CLK_PLL2)].clk, &clk_mux_ops, \ + &k210_clk_plls[2].clk, &k210_pll_ops, \ + &k210_clk_plls[2].clk, &k210_pll_ops) \ + COMP_FULL(K210_CLK_ACLK, \ + &k210_clk_muxes[MUXIFY(K210_CLK_ACLK)].clk, &clk_mux_ops, \ + &k210_clk_dividers[DIVIFY(K210_CLK_ACLK)].clk, \ + &clk_divider_ops, \ + NULL, NULL) \ + COMP_ID(K210_CLK_SPI3) \ + COMP_ID(K210_CLK_TIMER0) \ + COMP_ID(K210_CLK_TIMER1) \ + COMP_ID(K210_CLK_TIMER2) \ + COMP_NOMUX_ID(K210_CLK_SRAM0) \ + COMP_NOMUX_ID(K210_CLK_SRAM1) \ + COMP_NOMUX_ID(K210_CLK_ROM) \ + COMP_NOMUX_ID(K210_CLK_DVP) \ + COMP_NOMUX_ID(K210_CLK_APB0) \ + COMP_NOMUX_ID(K210_CLK_APB1) \ + COMP_NOMUX_ID(K210_CLK_APB2) \ + COMP_NOMUX_ID(K210_CLK_AI) \ + COMP_NOMUX_ID(K210_CLK_I2S0) \ + COMP_NOMUX_ID(K210_CLK_I2S1) \ + COMP_NOMUX_ID(K210_CLK_I2S2) \ + COMP_NOMUX_ID(K210_CLK_WDT0) \ + COMP_NOMUX_ID(K210_CLK_WDT1) \ + COMP_NOMUX_ID(K210_CLK_SPI0) \ + COMP_NOMUX_ID(K210_CLK_SPI1) \ + COMP_NOMUX_ID(K210_CLK_SPI2) \ + COMP_NOMUX_ID(K210_CLK_I2C0) \ + COMP_NOMUX_ID(K210_CLK_I2C1) \ + COMP_NOMUX_ID(K210_CLK_I2C2) + +#define _COMPIFY(id) K210_CLK_COMP_##id +#define COMPIFY(id) _COMPIFY(id) + +enum k210_clk_comp_ids { +#define COMP_FULL(id, ...) COMPIFY(id), + COMP_LIST +#undef COMP_FULL +}; + +static struct clk_composite k210_clk_comps[] = { +#define COMP_FULL(id, _mux, _mux_ops, _div, _div_ops, _gate, _gate_ops) \ + [COMPIFY(id)] = { \ + .mux = (_mux), \ + .mux_ops = (_mux_ops), \ + .rate = (_div), \ + .rate_ops = (_div_ops), \ + .gate = (_gate), \ + .gate_ops = (_gate_ops), \ + }, + COMP_LIST +#undef COMP_FULL +}; + +#undef COMP +#undef COMP_ID +#undef COMP_NOMUX +#undef COMP_NOMUX_ID +#undef COMP_LIST + +static struct clk *k210_clk_bypass_children = { + &k210_clk_comps[COMPIFY(K210_CLK_ACLK)].clk, +}; + +static struct clk *k210_clk_bypass_saved_parents = { + NULL, +}; + +static struct k210_bypass k210_clk_bypass = { + .bypassee = &k210_clk_plls[0].clk, + .bypassee_ops = &k210_pll_ops, + .children = &k210_clk_bypass_children, + .child_count = 1, + .saved_parents = &k210_clk_bypass_saved_parents, +}; + +static bool probed; + +static int k210_clk_probe(struct udevice *dev) +{ + int ret, i; + const char *in0; + struct clk *in0_clk; + void *base; + + /* Only one instance of this driver allowed */ + if (READ_ONCE(probed)) + return -ENOTSUPP; + + base = dev_read_addr_ptr(dev_get_parent(dev)); + if (!base) + return -EINVAL; + + in0_clk = kzalloc(sizeof(*in0_clk), GFP_KERNEL); + if (!in0_clk) + return -ENOMEM; + + ret = clk_get_by_index(dev, 0, in0_clk); + if (ret) + return ret; + in0 = in0_clk->dev->name; + + WRITE_ONCE(probed, true); + + aclk_sels[0] = in0; + pll2_sels[0] = in0; + + /* Fixup registers to be absolute, rather than relative */ +#define FIXUP_REGS(clocks) \ + for (i = 0; i < ARRAY_SIZE(clocks); i++) \ + clocks[i].reg += (ulong)base + FIXUP_REGS(k210_clk_dividers); + FIXUP_REGS(k210_clk_gates); + FIXUP_REGS(k210_clk_muxes); +#undef FIXUP_REGS + for (i = 0; i < ARRAY_SIZE(k210_clk_plls); i++) { + k210_clk_plls[i].reg += (ulong)base; + k210_clk_plls[i].lock += (ulong)base; + } + + /* + * All PLLs have a broken bypass, but pll0 has the CPU downstream, so we + * need to manually reparent it whenever we configure pll0 + */ + k210_clk_bypass.alt = in0_clk; + clk_dm(K210_CLK_PLL0, + k210_register_bypass_struct("pll0", in0, &k210_clk_bypass)); + clk_dm(K210_CLK_PLL1, + k210_register_pll_struct("pll1", in0, &k210_clk_plls[1])); + /* PLL2 is muxed, so set up a composite clock */ + clk_dm(K210_CLK_PLL2, + clk_register_composite_struct("pll2", pll2_sels, + ARRAY_SIZE(pll2_sels), + &k210_clk_comps[COMPIFY(K210_CLK_PLL2)])); + + /* Half-frequency clocks for "even" dividers */ + clk_dm(K210_CLK_IN0_H, k210_clk_half("in0_half", in0)); + clk_dm(K210_CLK_PLL0_H, k210_clk_half("pll0_half", "pll0")); + clk_dm(K210_CLK_PLL2_H, k210_clk_half("pll2_half", "pll2")); + + /* ACLK has no gate */ + clk_dm(K210_CLK_ACLK, + clk_register_composite_struct("aclk", aclk_sels, + ARRAY_SIZE(aclk_sels), + &k210_clk_comps[COMPIFY(K210_CLK_ACLK)])); + +#define REGISTER_COMP(id, name) \ + clk_dm(id, clk_register_composite_struct(name, generic_sels, \ + ARRAY_SIZE(generic_sels), \ + &k210_clk_comps[COMPIFY(id)])) + REGISTER_COMP(K210_CLK_SPI3, "spi3"); + REGISTER_COMP(K210_CLK_TIMER0, "timer0"); + REGISTER_COMP(K210_CLK_TIMER1, "timer1"); + REGISTER_COMP(K210_CLK_TIMER2, "timer2"); +#undef COMP + + /* Dividing clocks, no mux */ +#define REGISTER_COMP_NOMUX(id, name, _parent) do { \ + const char *parent = _parent; \ + clk_dm(id, \ + clk_register_composite_struct(name, &parent, 1, \ + &k210_clk_comps[COMPIFY(id)])); \ +} while (false) + REGISTER_COMP_NOMUX(K210_CLK_SRAM0, "sram0", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_SRAM1, "sram1", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_ROM, "rom", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_DVP, "dvp", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_APB0, "apb0", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_APB1, "apb1", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_APB2, "apb2", "aclk"); + REGISTER_COMP_NOMUX(K210_CLK_AI, "ai", "pll1"); + REGISTER_COMP_NOMUX(K210_CLK_I2S0, "i2s0", "pll2_half"); + REGISTER_COMP_NOMUX(K210_CLK_I2S1, "i2s1", "pll2_half"); + REGISTER_COMP_NOMUX(K210_CLK_I2S2, "i2s2", "pll2_half"); + REGISTER_COMP_NOMUX(K210_CLK_WDT0, "wdt0", "in0_half"); + REGISTER_COMP_NOMUX(K210_CLK_WDT1, "wdt1", "in0_half"); + REGISTER_COMP_NOMUX(K210_CLK_SPI0, "spi0", "pll0_half"); + REGISTER_COMP_NOMUX(K210_CLK_SPI1, "spi1", "pll0_half"); + REGISTER_COMP_NOMUX(K210_CLK_SPI2, "spi2", "pll0_half"); + REGISTER_COMP_NOMUX(K210_CLK_I2C0, "i2c0", "pll0_half"); + REGISTER_COMP_NOMUX(K210_CLK_I2C1, "i2c1", "pll0_half"); + REGISTER_COMP_NOMUX(K210_CLK_I2C2, "i2c2", "pll0_half"); +#undef REGISTER_COMP_NOMUX + + /* Dividing clocks */ +#define REGISTER_DIV(id, name, parent) clk_dm(id, \ + clk_register_divider_struct(name, parent, \ + &k210_clk_dividers[DIVIFY(id)])) + REGISTER_DIV(K210_CLK_I2S0_M, "i2s0_m", "pll2_half"); + REGISTER_DIV(K210_CLK_I2S1_M, "i2s1_m", "pll2_half"); + REGISTER_DIV(K210_CLK_I2S2_M, "i2s2_m", "pll2_half"); +#undef REGISTER_DIV + + /* Gated clocks */ +#define REGISTER_GATE(id, name, parent) \ + clk_dm(id, clk_register_gate_struct(name, parent, \ + &k210_clk_gates[GATEIFY(id)])) + REGISTER_GATE(K210_CLK_CPU, "cpu", "aclk"); + REGISTER_GATE(K210_CLK_DMA, "dma", "aclk"); + REGISTER_GATE(K210_CLK_FFT, "fft", "aclk"); + REGISTER_GATE(K210_CLK_GPIO, "gpio", "apb0"); + REGISTER_GATE(K210_CLK_UART1, "uart1", "apb0"); + REGISTER_GATE(K210_CLK_UART2, "uart2", "apb0"); + REGISTER_GATE(K210_CLK_UART3, "uart3", "apb0"); + REGISTER_GATE(K210_CLK_FPIOA, "fpioa", "apb0"); + REGISTER_GATE(K210_CLK_SHA, "sha", "apb0"); + REGISTER_GATE(K210_CLK_AES, "aes", "apb1"); + REGISTER_GATE(K210_CLK_OTP, "otp", "apb1"); + REGISTER_GATE(K210_CLK_RTC, "rtc", in0); +#undef REGISTER_GATE + + return 0; +} + +static const struct udevice_id k210_clk_ids[] = { + { .compatible = "kendryte,k210-clk" }, + { }, +}; + +U_BOOT_DRIVER(k210_clk) = { + .name = "k210_clk", + .id = UCLASS_CLK, + .of_match = k210_clk_ids, + .ops = &k210_clk_ops, + .probe = k210_clk_probe, +}; diff --git a/include/dt-bindings/clock/k210-sysctl.h b/include/dt-bindings/clock/k210-sysctl.h new file mode 100644 index 0000000000..0e3ed3fb9f --- /dev/null +++ b/include/dt-bindings/clock/k210-sysctl.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ + +#ifndef CLOCK_K210_SYSCTL_H +#define CLOCK_K210_SYSCTL_H + +/* + * Arbitrary identifiers for clocks. + */ +#define K210_CLK_NONE 0 +#define K210_CLK_IN0_H 1 +#define K210_CLK_PLL0_H 2 +#define K210_CLK_PLL0 3 +#define K210_CLK_PLL1 4 +#define K210_CLK_PLL2 5 +#define K210_CLK_PLL2_H 6 +#define K210_CLK_CPU 7 +#define K210_CLK_SRAM0 8 +#define K210_CLK_SRAM1 9 +#define K210_CLK_APB0 10 +#define K210_CLK_APB1 11 +#define K210_CLK_APB2 12 +#define K210_CLK_ROM 13 +#define K210_CLK_DMA 14 +#define K210_CLK_AI 15 +#define K210_CLK_DVP 16 +#define K210_CLK_FFT 17 +#define K210_CLK_GPIO 18 +#define K210_CLK_SPI0 19 +#define K210_CLK_SPI1 20 +#define K210_CLK_SPI2 21 +#define K210_CLK_SPI3 22 +#define K210_CLK_I2S0 23 +#define K210_CLK_I2S1 24 +#define K210_CLK_I2S2 25 +#define K210_CLK_I2S0_M 26 +#define K210_CLK_I2S1_M 27 +#define K210_CLK_I2S2_M 28 +#define K210_CLK_I2C0 29 +#define K210_CLK_I2C1 30 +#define K210_CLK_I2C2 31 +#define K210_CLK_UART1 32 +#define K210_CLK_UART2 33 +#define K210_CLK_UART3 34 +#define K210_CLK_AES 35 +#define K210_CLK_FPIOA 36 +#define K210_CLK_TIMER0 37 +#define K210_CLK_TIMER1 38 +#define K210_CLK_TIMER2 39 +#define K210_CLK_WDT0 40 +#define K210_CLK_WDT1 41 +#define K210_CLK_SHA 42 +#define K210_CLK_OTP 43 +#define K210_CLK_RTC 44 +#define K210_CLK_ACLK 45 + +#endif /* CLOCK_K210_SYSCTL_H */ diff --git a/include/dt-bindings/mfd/k210-sysctl.h b/include/dt-bindings/mfd/k210-sysctl.h new file mode 100644 index 0000000000..024b055397 --- /dev/null +++ b/include/dt-bindings/mfd/k210-sysctl.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#ifndef K210_SYSCTL_H +#define K210_SYSCTL_H + +/* Taken from kendryte-standalone-sdk/lib/drivers/include/sysctl.h */ +#define K210_SYSCTL_GIT_ID 0x00 /* Git short commit id */ +#define K210_SYSCTL_UART_BAUD 0x04 /* Default UARTHS baud rate */ +#define K210_SYSCTL_PLL0 0x08 /* PLL0 controller */ +#define K210_SYSCTL_PLL1 0x0C /* PLL1 controller */ +#define K210_SYSCTL_PLL2 0x10 /* PLL2 controller */ +#define K210_SYSCTL_PLL_LOCK 0x18 /* PLL lock tester */ +#define K210_SYSCTL_ROM_ERROR 0x1C /* AXI ROM detector */ +#define K210_SYSCTL_SEL0 0x20 /* Clock select controller0 */ +#define K210_SYSCTL_SEL1 0x24 /* Clock select controller1 */ +#define K210_SYSCTL_EN_CENT 0x28 /* Central clock enable */ +#define K210_SYSCTL_EN_PERI 0x2C /* Peripheral clock enable */ +#define K210_SYSCTL_SOFT_RESET 0x30 /* Soft reset ctrl */ +#define K210_SYSCTL_PERI_RESET 0x34 /* Peripheral reset controller */ +#define K210_SYSCTL_THR0 0x38 /* Clock threshold controller 0 */ +#define K210_SYSCTL_THR1 0x3C /* Clock threshold controller 1 */ +#define K210_SYSCTL_THR2 0x40 /* Clock threshold controller 2 */ +#define K210_SYSCTL_THR3 0x44 /* Clock threshold controller 3 */ +#define K210_SYSCTL_THR4 0x48 /* Clock threshold controller 4 */ +#define K210_SYSCTL_THR5 0x4C /* Clock threshold controller 5 */ +#define K210_SYSCTL_THR6 0x50 /* Clock threshold controller 6 */ +#define K210_SYSCTL_MISC 0x54 /* Miscellaneous controller */ +#define K210_SYSCTL_PERI 0x58 /* Peripheral controller */ +#define K210_SYSCTL_SPI_SLEEP 0x5C /* SPI sleep controller */ +#define K210_SYSCTL_RESET_STAT 0x60 /* Reset source status */ +#define K210_SYSCTL_DMA_SEL0 0x64 /* DMA handshake selector */ +#define K210_SYSCTL_DMA_SEL1 0x68 /* DMA handshake selector */ +#define K210_SYSCTL_POWER_SEL 0x6C /* IO Power Mode Select controller */ + +#endif /* K210_SYSCTL_H */ diff --git a/include/kendryte/clk.h b/include/kendryte/clk.h new file mode 100644 index 0000000000..9c6245d468 --- /dev/null +++ b/include/kendryte/clk.h @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ + +#ifndef K210_CLK_H +#define K210_CLK_H + +#define LOG_CATEGORY UCLASS_CLK +#include <linux/types.h> +#include <linux/clk-provider.h> + +static inline struct clk *k210_clk_gate(const char *name, + const char *parent_name, + void __iomem *reg, u8 bit_idx) +{ + return clk_register_gate(NULL, name, parent_name, 0, reg, bit_idx, 0, + NULL); +} + +static inline struct clk *k210_clk_half(const char *name, + const char *parent_name) +{ + return clk_register_fixed_factor(NULL, name, parent_name, 0, 1, 2); +} + +static inline struct clk *k210_clk_div(const char *name, + const char *parent_name, + void __iomem *reg, u8 shift, u8 width) +{ + return clk_register_divider(NULL, name, parent_name, 0, reg, shift, + width, 0); +} + +#endif /* K210_CLK_H */
This type of bus is used in Linux to designate buses which have power domains and/or clocks which need to be enabled before their child devices can be used. Because power domains are automatically enabled before probing in U-Boot, we just need to enable any clocks present.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v5: - Reorder includes (simple pm)
Changes in v4: - Split the bus off into its own driver - Add test - Fix line spacing in Kconfig - Lint
Changes in v3: - New
arch/sandbox/dts/test.dts | 6 ++ arch/sandbox/include/asm/clk.h | 1 + configs/sandbox_defconfig | 1 + .../bus/simple-pm-bus.txt | 44 +++++++++++++++ drivers/core/Kconfig | 7 +++ drivers/core/Makefile | 1 + drivers/core/simple-pm-bus.c | 56 +++++++++++++++++++ test/dm/Makefile | 1 + test/dm/simple-pm-bus.c | 45 +++++++++++++++ 9 files changed, 162 insertions(+) create mode 100644 doc/device-tree-bindings/bus/simple-pm-bus.txt create mode 100644 drivers/core/simple-pm-bus.c create mode 100644 test/dm/simple-pm-bus.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 4a277934a7..96e0b55eed 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -934,6 +934,12 @@ mdio: mdio-test { compatible = "sandbox,mdio"; }; + + pm-bus-test { + compatible = "simple-pm-bus"; + clocks = <&clk_sandbox 4>; + power-domains = <&pwrdom 1>; + }; };
#include "sandbox_pmic.dtsi" diff --git a/arch/sandbox/include/asm/clk.h b/arch/sandbox/include/asm/clk.h index 1573e4a134..c184c4bffc 100644 --- a/arch/sandbox/include/asm/clk.h +++ b/arch/sandbox/include/asm/clk.h @@ -21,6 +21,7 @@ enum sandbox_clk_id { SANDBOX_CLK_ID_I2C, SANDBOX_CLK_ID_UART1, SANDBOX_CLK_ID_UART2, + SANDBOX_CLK_ID_BUS,
SANDBOX_CLK_ID_COUNT, }; diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 45b5475b79..db0d2bbdc7 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -90,6 +90,7 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_DEVRES=y CONFIG_DEBUG_DEVRES=y +CONFIG_SIMPLE_PM_BUS=y CONFIG_ADC=y CONFIG_ADC_SANDBOX=y CONFIG_AXI=y diff --git a/doc/device-tree-bindings/bus/simple-pm-bus.txt b/doc/device-tree-bindings/bus/simple-pm-bus.txt new file mode 100644 index 0000000000..6f15037131 --- /dev/null +++ b/doc/device-tree-bindings/bus/simple-pm-bus.txt @@ -0,0 +1,44 @@ +Simple Power-Managed Bus +======================== + +A Simple Power-Managed Bus is a transparent bus that doesn't need a real +driver, as it's typically initialized by the boot loader. + +However, its bus controller is part of a PM domain, or under the control of a +functional clock. Hence, the bus controller's PM domain and/or clock must be +enabled for child devices connected to the bus (either on-SoC or externally) +to function. + +While "simple-pm-bus" follows the "simple-bus" set of properties, as specified +in the Devicetree Specification, it is not an extension of "simple-bus". + + +Required properties: + - compatible: Must contain at least "simple-pm-bus". + Must not contain "simple-bus". + It's recommended to let this be preceded by one or more + vendor-specific compatible values. + - #address-cells, #size-cells, ranges: Must describe the mapping between + parent address and child address spaces. + +Optional platform-specific properties for clock or PM domain control (at least +one of them is required): + - clocks: Must contain a reference to the functional clock(s), + - power-domains: Must contain a reference to the PM domain. +Please refer to the binding documentation for the clock and/or PM domain +providers for more details. + + +Example: + + bsc: bus@fec10000 { + compatible = "renesas,bsc-sh73a0", "renesas,bsc", + "simple-pm-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x20000000>; + reg = <0xfec10000 0x400>; + interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&zb_clk>; + power-domains = <&pd_a4s>; + }; diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 3b95b5387b..0cd687526e 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -195,6 +195,13 @@ config SPL_SIMPLE_BUS Supports the 'simple-bus' driver, which is used on some systems in SPL.
+config SIMPLE_PM_BUS + bool "Support simple-pm-bus driver" + depends on DM && OF_CONTROL && CLK && POWER_DOMAIN + help + Supports the 'simple-pm-bus' driver, which is used for busses that + have power domains and/or clocks which need to be enabled before use. + config OF_TRANSLATE bool "Translate addresses using fdt_translate_address" depends on DM && OF_CONTROL diff --git a/drivers/core/Makefile b/drivers/core/Makefile index bce7467da1..284af7caaa 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -6,6 +6,7 @@ obj-y += device.o fdtaddr.o lists.o root.o uclass.o util.o obj-$(CONFIG_DEVRES) += devres.o obj-$(CONFIG_$(SPL_)DM_DEVICE_REMOVE) += device-remove.o obj-$(CONFIG_$(SPL_)SIMPLE_BUS) += simple-bus.o +obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_DM) += dump.o obj-$(CONFIG_$(SPL_TPL_)REGMAP) += regmap.o obj-$(CONFIG_$(SPL_TPL_)SYSCON) += syscon-uclass.o diff --git a/drivers/core/simple-pm-bus.c b/drivers/core/simple-pm-bus.c new file mode 100644 index 0000000000..2313bd9a27 --- /dev/null +++ b/drivers/core/simple-pm-bus.c @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> + +/* + * Power domains are taken care of by driver_probe, so we just have to enable + * clocks + */ +static const int simple_pm_bus_probe(struct udevice *dev) +{ + int ret; + struct clk_bulk *bulk = dev_get_priv(dev); + + ret = clk_get_bulk(dev, bulk); + if (ret) + return ret; + + ret = clk_enable_bulk(bulk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + clk_release_bulk(bulk); + return ret; + } + return 0; +} + +static const int simple_pm_bus_remove(struct udevice *dev) +{ + int ret; + struct clk_bulk *bulk = dev_get_priv(dev); + + ret = clk_release_bulk(bulk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) + return ret; + else + return 0; +} + +static const struct udevice_id simple_pm_bus_ids[] = { + { .compatible = "simple-pm-bus" }, + { } +}; + +U_BOOT_DRIVER(simple_pm_bus_drv) = { + .name = "simple_pm_bus", + .id = UCLASS_SIMPLE_BUS, + .of_match = simple_pm_bus_ids, + .probe = simple_pm_bus_probe, + .remove = simple_pm_bus_remove, + .priv_auto_alloc_size = sizeof(struct clk_bulk), + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/test/dm/Makefile b/test/dm/Makefile index ef6065b60f..e0be0d684f 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -71,4 +71,5 @@ obj-$(CONFIG_DM_MDIO) += mdio.o obj-$(CONFIG_DM_MDIO_MUX) += mdio_mux.o obj-$(CONFIG_DM_RNG) += rng.o obj-$(CONFIG_CLK_K210_SET_RATE) += k210_pll.o +obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o endif diff --git a/test/dm/simple-pm-bus.c b/test/dm/simple-pm-bus.c new file mode 100644 index 0000000000..978c7f191e --- /dev/null +++ b/test/dm/simple-pm-bus.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <dm/device-internal.h> +#include <test/ut.h> +#include <asm/clk.h> +#include <asm/power-domain.h> + +/* These must match the ids in the device tree */ +#define TEST_CLOCK_ID 4 +#define TEST_POWER_ID 1 + +static int dm_test_simple_pm_bus(struct unit_test_state *uts) +{ + struct udevice *power; + struct udevice *clock; + struct udevice *bus; + + ut_assertok(uclass_get_device_by_name(UCLASS_POWER_DOMAIN, + "power-domain", &power)); + ut_assertok(uclass_get_device_by_name(UCLASS_CLK, "clk-sbox", + &clock)); + ut_asserteq(0, sandbox_power_domain_query(power, TEST_POWER_ID)); + ut_asserteq(0, sandbox_clk_query_enable(clock, TEST_CLOCK_ID)); + + ut_assertok(uclass_get_device_by_name(UCLASS_SIMPLE_BUS, "pm-bus-test", + &bus)); + ut_asserteq(1, sandbox_power_domain_query(power, TEST_POWER_ID)); + ut_asserteq(1, sandbox_clk_query_enable(clock, TEST_CLOCK_ID)); + + ut_assertok(device_remove(bus, DM_REMOVE_NORMAL)); + /* must re-probe since device_remove also removes the power domain */ + ut_assertok(uclass_get_device_by_name(UCLASS_POWER_DOMAIN, + "power-domain", &power)); + ut_asserteq(0, sandbox_power_domain_query(power, TEST_POWER_ID)); + ut_asserteq(0, sandbox_clk_query_enable(clock, TEST_CLOCK_ID)); + + return 0; +} +DM_TEST(dm_test_simple_pm_bus, DM_TESTF_SCAN_FDT);
dev_read_addr_ptr had different semantics depending on whether OF_LIVE was enabled. This patch converts both implementations to return NULL on error, and converts all call sites which check for FDT_ADDR_T_NONE to check for NULL instead. This patch also removes the call to map_physmem, since we have dev_remap_addr* for those semantics.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v5: - New
drivers/clk/imx/clk-imx8mp.c | 2 +- drivers/core/read.c | 2 +- drivers/pinctrl/broadcom/pinctrl-bcm283x.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 2 +- include/dm/read.h | 4 +++- 5 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index a2693d2f7a..df30f4a087 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -281,7 +281,7 @@ static int imx8mp_clk_probe(struct udevice *dev) clk_dm(IMX8MP_SYS_PLL2_1000M, imx_clk_fixed_factor("sys_pll2_1000m", "sys_pll2_out", 1, 1));
base = dev_read_addr_ptr(dev); - if (base == (void *)FDT_ADDR_T_NONE) + if (!base) return -EINVAL;
clk_dm(IMX8MP_CLK_A53_SRC, imx_clk_mux2("arm_a53_src", base + 0x8000, 24, 3, imx8mp_a53_sels, ARRAY_SIZE(imx8mp_a53_sels))); diff --git a/drivers/core/read.c b/drivers/core/read.c index 1f999b1b31..2a8813fff1 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -154,7 +154,7 @@ void *dev_read_addr_ptr(const struct udevice *dev) { fdt_addr_t addr = dev_read_addr(dev);
- return (addr == FDT_ADDR_T_NONE) ? NULL : map_sysmem(addr, 0); + return (addr == FDT_ADDR_T_NONE) ? NULL : addr; }
void *dev_remap_addr(const struct udevice *dev) diff --git a/drivers/pinctrl/broadcom/pinctrl-bcm283x.c b/drivers/pinctrl/broadcom/pinctrl-bcm283x.c index eb720f09f8..6961536a4d 100644 --- a/drivers/pinctrl/broadcom/pinctrl-bcm283x.c +++ b/drivers/pinctrl/broadcom/pinctrl-bcm283x.c @@ -116,7 +116,7 @@ int bcm283x_pinctl_probe(struct udevice *dev) }
priv->base_reg = dev_read_addr_ptr(dev); - if (priv->base_reg == (void *)FDT_ADDR_T_NONE) { + if (!priv->base_reg) { debug("%s: Failed to get base address\n", __func__); return -EINVAL; } diff --git a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c index c7351f32bb..bd95662ed5 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c +++ b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c @@ -630,7 +630,7 @@ int mtk_pinctrl_common_probe(struct udevice *dev, int ret;
priv->base = dev_read_addr_ptr(dev); - if (priv->base == (void *)FDT_ADDR_T_NONE) + if (!priv->base) return -EINVAL;
priv->soc = soc; diff --git a/include/dm/read.h b/include/dm/read.h index da8c7f25e7..d7183713dd 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -715,7 +715,9 @@ static inline fdt_addr_t dev_read_addr(const struct udevice *dev)
static inline void *dev_read_addr_ptr(const struct udevice *dev) { - return devfdt_get_addr_ptr(dev); + void *addr = devfdt_get_addr_ptr(dev); + + return ((fdt_addr_t)addr == FDT_ADDR_T_NONE) ? NULL : addr; }
static inline fdt_addr_t dev_read_addr_pci(const struct udevice *dev)
This patch adds a generic reset driver. It is designed to be useful when one has a register in a regmap which contains bits that reset other devices. I thought this seemed like a very generic use, so here is a generic driver. The overall structure has been modeled on the syscon-reboot driver.
Changes in v5: - Reorder includes - Include linux/err.h explicitly
Changes in v4: - Added basic test - Fix incorrect usage of regmap_update_bits
arch/sandbox/dts/test.dts | 15 ++++ configs/sandbox_defconfig | 1 + .../reset/syscon-reset.txt | 36 +++++++++ drivers/reset/Kconfig | 5 ++ drivers/reset/Makefile | 1 + drivers/reset/reset-syscon.c | 80 +++++++++++++++++++ test/dm/Makefile | 1 + test/dm/syscon-reset.c | 58 ++++++++++++++ 8 files changed, 197 insertions(+) create mode 100644 doc/device-tree-bindings/reset/syscon-reset.txt create mode 100644 drivers/reset/reset-syscon.c create mode 100644 test/dm/syscon-reset.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 96e0b55eed..6f2fcc64a4 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -940,6 +940,21 @@ clocks = <&clk_sandbox 4>; power-domains = <&pwrdom 1>; }; + + resetc2: syscon-reset { + compatible = "syscon-reset"; + #reset-cells = <1>; + regmap = <&syscon0>; + offset = <1>; + mask = <0x27FFFFFF>; + assert-high = <0>; + }; + + syscon-reset-test { + compatible = "sandbox,misc_sandbox"; + resets = <&resetc2 15>, <&resetc2 30>, <&resetc2 60>; + reset-names = "valid", "no_mask", "out_of_range"; + }; };
#include "sandbox_pmic.dtsi" diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index db0d2bbdc7..787546243d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -191,6 +191,7 @@ CONFIG_DM_RESET=y CONFIG_SANDBOX_RESET=y CONFIG_DM_RNG=y CONFIG_RNG_SANDBOX=y +CONFIG_RESET_SYSCON=y CONFIG_DM_RTC=y CONFIG_RTC_RV8803=y CONFIG_DEBUG_UART_SANDBOX=y diff --git a/doc/device-tree-bindings/reset/syscon-reset.txt b/doc/device-tree-bindings/reset/syscon-reset.txt new file mode 100644 index 0000000000..f136b3d225 --- /dev/null +++ b/doc/device-tree-bindings/reset/syscon-reset.txt @@ -0,0 +1,36 @@ +Generic SYSCON mapped register reset driver + +This is a generic reset driver using syscon to map the reset register. +The reset is generally performed with a write to the reset register +defined by the register map pointed by syscon reference plus the offset and +shifted by the reset specifier/ + +To assert a reset on some device, the equivalent of the following operation is +performed, where reset_id is the reset specifier from the device's resets +property. + + if (BIT(reset_id) & mask) + regmap[offset][reset_id] = assert-high; + +Required properties: +- compatible: should contain "syscon-reset" +- #reset-cells: must be 1 +- regmap: this is phandle to the register map node +- offset: offset in the register map for the reboot register (in bytes) + +Optional properties: +- mask: accept only the reset specifiers defined by the mask (32 bit) +- assert-high: Bit to write when asserting a reset. Defaults to 1. + +Default will be little endian mode, 32 bit access only. + +Example: + + reset-controller { + compatible = "syscon-reset"; + #reset-cells = <1>; + regmap = <&sysctl>; + offset = <0x20>; + mask = <0x27FFFFFF>; + assert-high = <0>; + }; diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 75ccd65799..097bf32b21 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -148,4 +148,9 @@ config RESET_IMX7 help Support for reset controller on i.MX7/8 SoCs.
+config RESET_SYSCON + bool "Enable generic syscon reset driver support" + depends on DM_RESET + help + Support generic syscon mapped register reset devices. endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 0a044d5d8c..433f1eca54 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -23,3 +23,4 @@ obj-$(CONFIG_RESET_MTMIPS) += reset-mtmips.o obj-$(CONFIG_RESET_SUNXI) += reset-sunxi.o obj-$(CONFIG_RESET_HISILICON) += reset-hisilicon.o obj-$(CONFIG_RESET_IMX7) += reset-imx7.o +obj-$(CONFIG_RESET_SYSCON) += reset-syscon.o diff --git a/drivers/reset/reset-syscon.c b/drivers/reset/reset-syscon.c new file mode 100644 index 0000000000..34dfe0bab6 --- /dev/null +++ b/drivers/reset/reset-syscon.c @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Sean Anderson + */ + +#include <common.h> +#include <dm.h> +#include <regmap.h> +#include <reset.h> +#include <reset-uclass.h> +#include <syscon.h> +#include <linux/err.h> + +struct syscon_reset_priv { + struct regmap *regmap; + uint offset; + uint mask; + bool assert_high; +}; + +static int syscon_reset_request(struct reset_ctl *rst) +{ + struct syscon_reset_priv *priv = dev_get_priv(rst->dev); + + if (BIT(rst->id) & priv->mask) + return 0; + else + return -EINVAL; +} + +static int syscon_reset_assert(struct reset_ctl *rst) +{ + struct syscon_reset_priv *priv = dev_get_priv(rst->dev); + + return regmap_update_bits(priv->regmap, priv->offset, BIT(rst->id), + priv->assert_high ? BIT(rst->id) : 0); +} + +static int syscon_reset_deassert(struct reset_ctl *rst) +{ + struct syscon_reset_priv *priv = dev_get_priv(rst->dev); + + return regmap_update_bits(priv->regmap, priv->offset, BIT(rst->id), + priv->assert_high ? 0 : BIT(rst->id)); +} + +static const struct reset_ops syscon_reset_ops = { + .request = syscon_reset_request, + .rst_assert = syscon_reset_assert, + .rst_deassert = syscon_reset_deassert, +}; + +int syscon_reset_probe(struct udevice *dev) +{ + struct syscon_reset_priv *priv = dev_get_priv(dev); + + priv->regmap = syscon_regmap_lookup_by_phandle(dev, "regmap"); + if (IS_ERR(priv->regmap)) + return -ENODEV; + + priv->offset = dev_read_u32_default(dev, "offset", 0); + priv->mask = dev_read_u32_default(dev, "mask", 0); + priv->assert_high = dev_read_u32_default(dev, "assert-high", true); + + return 0; +} + +static const struct udevice_id syscon_reset_ids[] = { + { .compatible = "syscon-reset" }, + { }, +}; + +U_BOOT_DRIVER(syscon_reset) = { + .name = "syscon_reset", + .id = UCLASS_RESET, + .of_match = syscon_reset_ids, + .probe = syscon_reset_probe, + .priv_auto_alloc_size = sizeof(struct syscon_reset_priv), + .ops = &syscon_reset_ops, +}; diff --git a/test/dm/Makefile b/test/dm/Makefile index e0be0d684f..187f288362 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -72,4 +72,5 @@ obj-$(CONFIG_DM_MDIO_MUX) += mdio_mux.o obj-$(CONFIG_DM_RNG) += rng.o obj-$(CONFIG_CLK_K210_SET_RATE) += k210_pll.o obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o +obj-$(CONFIG_RESET_SYSCON) += syscon-reset.o endif diff --git a/test/dm/syscon-reset.c b/test/dm/syscon-reset.c new file mode 100644 index 0000000000..1db0206e00 --- /dev/null +++ b/test/dm/syscon-reset.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <test/ut.h> +#include <asm/test.h> + +/* The following values must match the device tree */ +#define TEST_RESET_REG 1 +#define TEST_RESET_ASSERT_HIGH 0 +#define TEST_RESET_ASSERT (TEST_RESET_ASSERT_HIGH ? (u32)-1 : (u32)0) +#define TEST_RESET_DEASSERT (~TEST_RESET_ASSERT) + +#define TEST_RESET_VALID 15 +#define TEST_RESET_NOMASK 30 +#define TEST_RESET_OUTOFRANGE 60 + +static int dm_test_syscon_reset(struct unit_test_state *uts) +{ + struct regmap *map; + struct reset_ctl rst; + struct udevice *reset; + struct udevice *syscon; + struct udevice *syscon_reset; + uint reg; + + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "syscon-reset-test", + &reset)); + ut_assertok(uclass_get_device_by_name(UCLASS_SYSCON, "syscon@0", + &syscon)); + ut_assertok(uclass_get_device_by_name(UCLASS_RESET, "syscon-reset", + &syscon_reset)); + ut_assertok_ptr((map = syscon_get_regmap(syscon))); + + ut_asserteq(-EINVAL, reset_get_by_name(reset, "no_mask", &rst)); + ut_asserteq(-EINVAL, reset_get_by_name(reset, "out_of_range", &rst)); + ut_assertok(reset_get_by_name(reset, "valid", &rst)); + + sandbox_set_enable_memio(true); + ut_assertok(regmap_write(map, TEST_RESET_REG, TEST_RESET_DEASSERT)); + ut_assertok(reset_assert(&rst)); + ut_assertok(regmap_read(map, TEST_RESET_REG, ®)); + ut_asserteq(TEST_RESET_DEASSERT ^ BIT(TEST_RESET_VALID), reg); + + ut_assertok(reset_deassert(&rst)); + ut_assertok(regmap_read(map, TEST_RESET_REG, ®)); + ut_asserteq(TEST_RESET_DEASSERT, reg); + + return 0; +} +DM_TEST(dm_test_syscon_reset, DM_TESTF_SCAN_FDT);
This could give a confusing error message if it failed and didn't set errno.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
lib/hashtable.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/lib/hashtable.c b/lib/hashtable.c index 907e8a642f..e9ac7e252e 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -109,8 +109,10 @@ int hcreate_r(size_t nel, struct hsearch_data *htab) }
/* There is still another table active. Return with error. */ - if (htab->table != NULL) + if (htab->table != NULL) { + __set_errno(EINVAL); return 0; + }
/* Change nel to the first prime number not smaller as nel. */ nel |= 1; /* make odd */ @@ -123,8 +125,10 @@ int hcreate_r(size_t nel, struct hsearch_data *htab) /* allocate memory and zero out */ htab->table = (struct env_entry_node *)calloc(htab->size + 1, sizeof(struct env_entry_node)); - if (htab->table == NULL) + if (htab->table == NULL) { + __set_errno(ENOMEM); return 0; + }
/* everything went alright */ return 1;
This header depended on bd_t and ulong, but did not include the appropriate headers.
Changes in v4: - Include compiler.h not linux/compiler.h
arch/riscv/include/asm/global_data.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index b74bd7e738..7276d9763f 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -11,6 +11,8 @@ #define __ASM_GBL_DATA_H
#include <asm/smp.h> +#include <asm/u-boot.h> +#include <compiler.h>
/* Architecture-specific global data */ struct arch_global_data {
The IPI code could have race conditions in several places. * Several harts could race on the value of gd->arch->clint/plic * Non-boot harts could race with the main hart on the DM subsystem In addition, if an IPI was pending when U-Boot started, it would cause the IPI handler to jump to address 0.
To address these problems, a new function riscv_init_ipi is introduced. It is called once during arch_cpu_init_dm. Before this point, no riscv_*_ipi functions may be called. Access is synchronized by gd->arch->ipi_ready.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
Changes in v6: - Fix some formatting - Clear IPIs before enabling interrupts instead of using a ipi_ready flag - Only print messages on error in smp code
arch/riscv/cpu/cpu.c | 6 ++++ arch/riscv/cpu/start.S | 2 ++ arch/riscv/include/asm/smp.h | 43 +++++++++++++++++++++++++++ arch/riscv/lib/andes_plic.c | 34 ++++++++------------- arch/riscv/lib/sbi_ipi.c | 5 ++++ arch/riscv/lib/sifive_clint.c | 33 +++++++-------------- arch/riscv/lib/smp.c | 56 ++++++++--------------------------- 7 files changed, 92 insertions(+), 87 deletions(-)
diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c index e457f6acbf..f851374255 100644 --- a/arch/riscv/cpu/cpu.c +++ b/arch/riscv/cpu/cpu.c @@ -96,6 +96,12 @@ int arch_cpu_init_dm(void) csr_write(CSR_SATP, 0); }
+#ifdef CONFIG_SMP + ret = riscv_init_ipi(); + if (ret) + return ret; +#endif + return 0; }
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 6b3ff99c38..e8740c8568 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -67,6 +67,8 @@ _start: #else li t0, SIE_SSIE #endif + /* Clear any pending IPIs */ + csrc MODE_PREFIX(ip), t0 csrs MODE_PREFIX(ie), t0 #endif
diff --git a/arch/riscv/include/asm/smp.h b/arch/riscv/include/asm/smp.h index 74de92ed13..1b428856b2 100644 --- a/arch/riscv/include/asm/smp.h +++ b/arch/riscv/include/asm/smp.h @@ -51,4 +51,47 @@ void handle_ipi(ulong hart); */ int smp_call_function(ulong addr, ulong arg0, ulong arg1, int wait);
+/** + * riscv_init_ipi() - Initialize inter-process interrupt (IPI) driver + * + * Platform code must provide this function. This function is called once after + * the cpu driver is initialized. No other riscv_*_ipi() calls will be made + * before this function is called. + * + * @return 0 if OK, -ve on error + */ +int riscv_init_ipi(void); + +/** + * riscv_send_ipi() - Send inter-processor interrupt (IPI) + * + * Platform code must provide this function. + * + * @hart: Hart ID of receiving hart + * @return 0 if OK, -ve on error + */ +int riscv_send_ipi(int hart); + +/** + * riscv_clear_ipi() - Clear inter-processor interrupt (IPI) + * + * Platform code must provide this function. + * + * @hart: Hart ID of hart to be cleared + * @return 0 if OK, -ve on error + */ +int riscv_clear_ipi(int hart); + +/** + * riscv_get_ipi() - Get status of inter-processor interrupt (IPI) + * + * Platform code must provide this function. + * + * @hart: Hart ID of hart to be checked + * @pending: Pointer to variable with result of the check, + * 1 if IPI is pending, 0 otherwise + * @return 0 if OK, -ve on error + */ +int riscv_get_ipi(int hart, int *pending); + #endif diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c index 20529ab3eb..8484f76386 100644 --- a/arch/riscv/lib/andes_plic.c +++ b/arch/riscv/lib/andes_plic.c @@ -30,20 +30,6 @@ #define SEND_IPI_TO_HART(hart) (0x80 >> (hart))
DECLARE_GLOBAL_DATA_PTR; -static int init_plic(void); - -#define PLIC_BASE_GET(void) \ - do { \ - long *ret; \ - \ - if (!gd->arch.plic) { \ - ret = syscon_get_first_range(RISCV_SYSCON_PLIC); \ - if (IS_ERR(ret)) \ - return PTR_ERR(ret); \ - gd->arch.plic = ret; \ - init_plic(); \ - } \ - } while (0)
static int enable_ipi(int hart) { @@ -93,13 +79,21 @@ static int init_plic(void) return -ENODEV; }
+int riscv_init_ipi(void) +{ + int ret = syscon_get_first_range(RISCV_SYSCON_PLIC); + + if (IS_ERR(ret)) + return PTR_ERR(ret); + gd->arch.plic = ret; + + return init_plic(); +} + int riscv_send_ipi(int hart) { - unsigned int ipi; + unsigned int ipi = (SEND_IPI_TO_HART(hart) << (8 * gd->arch.boot_hart));
- PLIC_BASE_GET(); - - ipi = (SEND_IPI_TO_HART(hart) << (8 * gd->arch.boot_hart)); writel(ipi, (void __iomem *)PENDING_REG(gd->arch.plic, gd->arch.boot_hart));
@@ -110,8 +104,6 @@ int riscv_clear_ipi(int hart) { u32 source_id;
- PLIC_BASE_GET(); - source_id = readl((void __iomem *)CLAIM_REG(gd->arch.plic, hart)); writel(source_id, (void __iomem *)CLAIM_REG(gd->arch.plic, hart));
@@ -120,8 +112,6 @@ int riscv_clear_ipi(int hart)
int riscv_get_ipi(int hart, int *pending) { - PLIC_BASE_GET(); - *pending = readl((void __iomem *)PENDING_REG(gd->arch.plic, gd->arch.boot_hart)); *pending = !!(*pending & SEND_IPI_TO_HART(hart)); diff --git a/arch/riscv/lib/sbi_ipi.c b/arch/riscv/lib/sbi_ipi.c index 9a698ce74e..310d1bd2a4 100644 --- a/arch/riscv/lib/sbi_ipi.c +++ b/arch/riscv/lib/sbi_ipi.c @@ -7,6 +7,11 @@ #include <common.h> #include <asm/sbi.h>
+int riscv_init_ipi(void) +{ + return 0; +} + int riscv_send_ipi(int hart) { ulong mask; diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index 5e0d25720b..78fc6c868d 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -24,22 +24,8 @@
-#define CLINT_BASE_GET(void) \ - do { \ - long *ret; \ - \ - if (!gd->arch.clint) { \ - ret = syscon_get_first_range(RISCV_SYSCON_CLINT); \ - if (IS_ERR(ret)) \ - return PTR_ERR(ret); \ - gd->arch.clint = ret; \ - } \ - } while (0) - int riscv_get_time(u64 *time) { - CLINT_BASE_GET(); - *time = readq((void __iomem *)MTIME_REG(gd->arch.clint));
return 0; @@ -47,17 +33,24 @@ int riscv_get_time(u64 *time)
int riscv_set_timecmp(int hart, u64 cmp) { - CLINT_BASE_GET(); - writeq(cmp, (void __iomem *)MTIMECMP_REG(gd->arch.clint, hart));
return 0; }
+int riscv_init_ipi(void) +{ + long *ret = syscon_get_first_range(RISCV_SYSCON_CLINT); + + if (IS_ERR(ret)) + return PTR_ERR(ret); + gd->arch.clint = ret; + + return 0; +} + int riscv_send_ipi(int hart) { - CLINT_BASE_GET(); - writel(1, (void __iomem *)MSIP_REG(gd->arch.clint, hart));
return 0; @@ -65,8 +58,6 @@ int riscv_send_ipi(int hart)
int riscv_clear_ipi(int hart) { - CLINT_BASE_GET(); - writel(0, (void __iomem *)MSIP_REG(gd->arch.clint, hart));
return 0; @@ -74,8 +65,6 @@ int riscv_clear_ipi(int hart)
int riscv_get_ipi(int hart, int *pending) { - CLINT_BASE_GET(); - *pending = readl((void __iomem *)MSIP_REG(gd->arch.clint, hart));
return 0; diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index 17adb35730..fe992eb00f 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -12,38 +12,6 @@
-/** - * riscv_send_ipi() - Send inter-processor interrupt (IPI) - * - * Platform code must provide this function. - * - * @hart: Hart ID of receiving hart - * @return 0 if OK, -ve on error - */ -extern int riscv_send_ipi(int hart); - -/** - * riscv_clear_ipi() - Clear inter-processor interrupt (IPI) - * - * Platform code must provide this function. - * - * @hart: Hart ID of hart to be cleared - * @return 0 if OK, -ve on error - */ -extern int riscv_clear_ipi(int hart); - -/** - * riscv_get_ipi() - Get status of inter-processor interrupt (IPI) - * - * Platform code must provide this function. - * - * @hart: Hart ID of hart to be checked - * @pending: Pointer to variable with result of the check, - * 1 if IPI is pending, 0 otherwise - * @return 0 if OK, -ve on error - */ -extern int riscv_get_ipi(int hart, int *pending); - static int send_ipi_many(struct ipi_data *ipi, int wait) { ofnode node, cpus; @@ -114,7 +82,6 @@ void handle_ipi(ulong hart) return;
__smp_mb(); - smp_function = (void (*)(ulong, ulong, ulong))gd->arch.ipi[hart].addr; invalidate_icache_all();
@@ -124,7 +91,13 @@ void handle_ipi(ulong hart) */ ret = riscv_clear_ipi(hart); if (ret) { - pr_err("Cannot clear IPI of hart %ld\n", hart); + pr_err("Cannot clear IPI of hart %ld (error %d)\n", hart, ret); + return; + } + + /* Sanity check */ + if (!smp_function) { + pr_err("smp_function is NULL on hart %ld\n", hart); return; }
@@ -133,14 +106,11 @@ void handle_ipi(ulong hart)
int smp_call_function(ulong addr, ulong arg0, ulong arg1, int wait) { - int ret = 0; - struct ipi_data ipi; + struct ipi_data ipi = { + .addr = addr, + .arg0 = arg0, + .arg1 = arg1, + };
- ipi.addr = addr; - ipi.arg0 = arg0; - ipi.arg1 = arg1; - - ret = send_ipi_many(&ipi, wait); - - return ret; + return send_ipi_many(&ipi, wait); }
Hi Sean
- Several harts could race on the value of gd->arch->clint/plic
- Non-boot harts could race with the main hart on the DM subsystem In addition, if an IPI was pending when U-Boot started, it would cause the IPI handler to jump to address 0.
Can you try to clear mip/sip in startup flow before secondary_hart_loop: Maybe it can help to overcome the problem of calling riscv_clear_ipi() before riscv_init_ipi() that you added.
How is the verified result about trying to clear mip/sip in startup flow ? I have asked you twice in v5, but you still have no response about it.
[PATCH v5 27/33] riscv: Fix race conditions when initializing IPI https://patchwork.ozlabs.org/patch/1246864/#2377119
Thanks Rick
Changes in v6:
Changes in v5:
- New
+#ifdef CONFIG_SMP
if (ret)
return ret;
#endif
- riscv_init_ipi() - Initialize inter-process interrupt (IPI) driver
- Platform code must provide this function. This function is called once after
- the cpu driver is initialized. No other riscv_*_ipi() calls will be made
- before this function is called.
- @return 0 if OK, -ve on error
- riscv_send_ipi() - Send inter-processor interrupt (IPI)
- @hart: Hart ID of receiving hart
- riscv_clear_ipi() - Clear inter-processor interrupt (IPI)
- @hart: Hart ID of hart to be cleared
- riscv_get_ipi() - Get status of inter-processor interrupt (IPI)
- @hart: Hart ID of hart to be checked
- @pending: Pointer to variable with result of the check,
do { \
long *ret; \
if (IS_ERR(ret)) \
init_plic(); \
} while (0)
if (IS_ERR(ret))
return init_plic();
unsigned int ipi;
PLIC_BASE_GET();
PLIC_BASE_GET();
PLIC_BASE_GET();
do { \
long *ret; \
if (IS_ERR(ret)) \
} while (0)
CLINT_BASE_GET();
*time = readq((void __iomem *)MTIME_REG(gd->arch.clint)); return 0;
CLINT_BASE_GET();
writeq(cmp, (void __iomem *)MTIMECMP_REG(gd->arch.clint, hart)); return 0;
if (IS_ERR(ret))
CLINT_BASE_GET();
writel(1, (void __iomem *)MSIP_REG(gd->arch.clint, hart)); return 0;
CLINT_BASE_GET();
writel(0, (void __iomem *)MSIP_REG(gd->arch.clint, hart)); return 0;
CLINT_BASE_GET();
*pending = readl((void __iomem *)MSIP_REG(gd->arch.clint, hart)); return 0;
__smp_mb();
return;
/* Sanity check */
int ret = 0;
.addr = addr,
.arg0 = arg0,
.arg1 = arg1,
ipi.addr = addr;
ipi.arg0 = arg0;
ipi.arg1 = arg1;
return ret;
2.25.0
On 3/10/20 4:20 AM, Rick Chen wrote:
Hi Sean
Thanks Rick
I managed to get it working, and this patch incorporates that change. However, I forgot to update the commit message. The original issue I had was related to an accidental change to my config, and not to the clearing of MIP.
--Sean
Hi Sean
Hi Sean
Thanks Rick
So it is not a race condition issue, right ?
Maybe you shall split this into two patchs as below
patch 1 riscv: Clear pending ipi in start code Describe that it can how and what it help to fix the problem you encounter more detail e.g. (Perhaps the prior stage sends an IPI but does not clear it) ...
patch 2 riscv: refine ipi initialize code flow Describe that your motivation and intention more detail e.g. I think the macro approach is a bit confusing, since it's unclear at first glance what function will be initializing the clint/plic. Given U-Boot's otherwise completely SMP-unsafe design, I think it's better to be explicit and conservative in these areas.
It can help us to roll back and debug in the future.
Thanks, Rick
--Sean
On 3/10/20 9:33 PM, Rick Chen wrote:
Hi Sean
Hi Sean
Thanks Rick
It is sort of a race condition? If the IP CSR is not cleared, then we can have a race condition.
Thanks, Rick
This will be split in the next revision.
--Sean
Some older processors (notably the Kendryte K210) use an older version of the RISC-V privileged specification. The primary changes between the old and new are in virtual memory, and in the merging of three separate counter enable CSRs. Using the new CSR on an old processor causes an illegal instruction exception. This patch adds an option to use the old CSRs instead of the new one.
Changes in v6: - Reformat so chechpatch errors less
Changes in v5: - Rename to 1.9 to reflect the spec as implemented by the k210
Changes in v4: - Fixed CSRs not being defined properly (thanks bmeng) - Added ifdefs for all changed CSRs (e.g. for VM) - Also properly disable VM on boot
Changes in v3: - Renamed from "riscv: Add option to disable writes to mcounteren" - Added original functionality back for older priv specs.
Changes in v2: - Moved forward in the patch series
arch/riscv/Kconfig | 10 +++++++++ arch/riscv/cpu/cpu.c | 9 ++++++++ arch/riscv/include/asm/csr.h | 40 ++++++++++++++++++++++++++++++++++++ 3 files changed, 59 insertions(+)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3338b788f8..b7a5757584 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -225,6 +225,16 @@ config XIP config SHOW_REGS bool "Show registers on unhandled exception"
+config RISCV_PRIV_1_9 + bool "Use version 1.9 of the RISC-V priviledged specification" + help + Older versions of the RISC-V priviledged specification had + separate counter enable CSRs for each privilege mode. Writing + to the unified mcounteren CSR on a processor implementing the + old specification will result in an illegal instruction + exception. In addition to counter CSR changes, the way virtual + memory is configured was also changed. + config STACK_SIZE_SHIFT int default 14 diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c index f851374255..3c1836694a 100644 --- a/arch/riscv/cpu/cpu.c +++ b/arch/riscv/cpu/cpu.c @@ -89,11 +89,20 @@ int arch_cpu_init_dm(void) * Enable perf counters for cycle, time, * and instret counters only */ +#ifdef CONFIG_RISCV_PRIV_1_9 + csr_write(CSR_MSCOUNTEREN, GENMASK(2, 0)); + csr_write(CSR_MUCOUNTEREN, GENMASK(2, 0)); +#else csr_write(CSR_MCOUNTEREN, GENMASK(2, 0)); +#endif
/* Disable paging */ if (supports_extension('s')) +#ifdef CONFIG_RISCV_PRIV_1_9 + csr_read_clear(CSR_MSTATUS, SR_VM); +#else csr_write(CSR_SATP, 0); +#endif }
#ifdef CONFIG_SMP diff --git a/arch/riscv/include/asm/csr.h b/arch/riscv/include/asm/csr.h index d1520743a2..1a15089cae 100644 --- a/arch/riscv/include/asm/csr.h +++ b/arch/riscv/include/asm/csr.h @@ -15,7 +15,11 @@ #define SR_SIE _AC(0x00000002, UL) /* Supervisor Interrupt Enable */ #define SR_SPIE _AC(0x00000020, UL) /* Previous Supervisor IE */ #define SR_SPP _AC(0x00000100, UL) /* Previously Supervisor */ +#ifdef CONFIG_RISCV_PRIV_1_9 +#define SR_PUM _AC(0x00040000, UL) /* Protect User Memory Access */ +#else #define SR_SUM _AC(0x00040000, UL) /* Supervisor User Memory Access */ +#endif
#define SR_FS _AC(0x00006000, UL) /* Floating-point Status */ #define SR_FS_OFF _AC(0x00000000, UL) @@ -29,6 +33,22 @@ #define SR_XS_CLEAN _AC(0x00010000, UL) #define SR_XS_DIRTY _AC(0x00018000, UL)
+#ifdef CONFIG_RISCV_PRIV_1_9 +#define SR_VM _AC(0x1F000000, UL) /* Virtualization Management */ +#define SR_VM_MODE_BARE _AC(0x00000000, UL) /* No translation or protection */ +#define SR_VM_MODE_BB _AC(0x01000000, UL) /* Single base-and-bound */ +/* Separate instruction and data base-and-bound */ +#define SR_VM_MODE_BBID _AC(0x02000000, UL) +#ifndef CONFIG_64BIT +#define SR_VM_MODE_32 _AC(0x08000000, UL) +#define SR_VM_MODE SR_VM_MODE_32 +#else +#define SR_VM_MODE_39 _AC(0x09000000, UL) +#define SR_VM_MODE_48 _AC(0x0A000000, UL) +#define SR_VM_MODE SR_VM_MODE_39 +#endif +#endif + #ifndef CONFIG_64BIT #define SR_SD _AC(0x80000000, UL) /* FS/XS dirty */ #else @@ -36,6 +56,7 @@ #endif
/* SATP flags */ +#ifndef CONFIG_RISCV_PRIV_1_9 #ifndef CONFIG_64BIT #define SATP_PPN _AC(0x003FFFFF, UL) #define SATP_MODE_32 _AC(0x80000000, UL) @@ -45,6 +66,7 @@ #define SATP_MODE_39 _AC(0x8000000000000000, UL) #define SATP_MODE SATP_MODE_39 #endif +#endif
/* SCAUSE */ #define SCAUSE_IRQ_FLAG (_AC(1, UL) << (__riscv_xlen - 1)) @@ -88,17 +110,35 @@ #define CSR_SCAUSE 0x142 #define CSR_STVAL 0x143 #define CSR_SIP 0x144 +#ifdef CONFIG_RISCV_PRIV_1_9 +#define CSR_SPTBR 0x180 +#else #define CSR_SATP 0x180 +#endif #define CSR_MSTATUS 0x300 #define CSR_MISA 0x301 #define CSR_MIE 0x304 #define CSR_MTVEC 0x305 +#ifdef CONFIG_RISCV_PRIV_1_9 +#define CSR_MUCOUNTEREN 0x320 +#define CSR_MSCOUNTEREN 0x321 +#define CSR_MHCOUNTEREN 0x322 +#else #define CSR_MCOUNTEREN 0x306 +#endif #define CSR_MSCRATCH 0x340 #define CSR_MEPC 0x341 #define CSR_MCAUSE 0x342 #define CSR_MTVAL 0x343 #define CSR_MIP 0x344 +#ifdef CONFIG_RISCV_PRIV_1_9 +#define CSR_MBASE 0x380 +#define CSR_MBOUND 0x381 +#define CSR_MIBASE 0x382 +#define CSR_MIBOUND 0x383 +#define CSR_MDBASE 0x384 +#define CSR_MDBOUND 0x385 +#endif #define CSR_CYCLEH 0xc80 #define CSR_TIMEH 0xc81 #define CSR_INSTRETH 0xc82
Currently, one cannot use a reset driver on RISC-V. Follow the MIPS example, and disable the default reset handler when the sysreset driver is enabled.
arch/riscv/lib/reset.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/riscv/lib/reset.c b/arch/riscv/lib/reset.c index ce3c1cf872..7622e5df43 100644 --- a/arch/riscv/lib/reset.c +++ b/arch/riscv/lib/reset.c @@ -7,6 +7,7 @@ #include <command.h> #include <hang.h>
+#ifndef CONFIG_SYSRESET int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { printf("resetting ...\n"); @@ -16,3 +17,4 @@ int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 0; } +#endif
Instead of always using the "clock-frequency" property to determine cpu frequency, try using a clock in "clocks" if it exists. This patch also fixes a bug where there could be spurious higher frequencies if sizeof(u32) != sizeof(ulong).
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- This patch was previously sumbitted on its own as https://patchwork.ozlabs.org/patch/1232420/
This patch is the combination of the patches https://patchwork.ozlabs.org/patch/1223933/ https://patchwork.ozlabs.org/patch/1224957/ "riscv: Fix incorrect cpu frequency on RV64" "riscv: Try to get cpu frequency from device tree"
Changes in v5: - Include linux/err.h explicitly - Reword commit message
Changes in v4: - New
drivers/cpu/riscv_cpu.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/drivers/cpu/riscv_cpu.c b/drivers/cpu/riscv_cpu.c index 28ad0aa30f..c6ed060abc 100644 --- a/drivers/cpu/riscv_cpu.c +++ b/drivers/cpu/riscv_cpu.c @@ -3,12 +3,14 @@ * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com */
+#include <clk.h> #include <common.h> #include <cpu.h> #include <dm.h> #include <errno.h> #include <dm/device-internal.h> #include <dm/lists.h> +#include <linux/err.h>
@@ -27,9 +29,24 @@ static int riscv_cpu_get_desc(struct udevice *dev, char *buf, int size)
static int riscv_cpu_get_info(struct udevice *dev, struct cpu_info *info) { + int ret; + struct clk clk; const char *mmu;
- dev_read_u32(dev, "clock-frequency", (u32 *)&info->cpu_freq); + /* Zero out the frequency, in case sizeof(ulong) != sizeof(u32) */ + info->cpu_freq = 0; + + /* First try getting the frequency from the assigned clock */ + ret = clk_get_by_index(dev, 0, &clk); + if (!ret) { + ret = clk_get_rate(&clk); + if (!IS_ERR_VALUE(ret)) + info->cpu_freq = ret; + clk_free(&clk); + } + + if (!info->cpu_freq) + dev_read_u32(dev, "clock-frequency", (u32 *)&info->cpu_freq);
mmu = dev_read_string(dev, "mmu-type"); if (!mmu)
The cpu clock is probably already enabled if we are executing code (though we could be executing from a different core). This patch prevents the cpu clock or its parents from being disabled.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- This patch was previously submitted on its own as https://patchwork.ozlabs.org/patch/1232420/
drivers/cpu/riscv_cpu.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/cpu/riscv_cpu.c b/drivers/cpu/riscv_cpu.c index c6ed060abc..9ce58695aa 100644 --- a/drivers/cpu/riscv_cpu.c +++ b/drivers/cpu/riscv_cpu.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + * Copyright (C) 2020, Sean Anderson seanga2@gmail.com */
#include <clk.h> @@ -117,6 +118,24 @@ static int riscv_cpu_bind(struct udevice *dev) return 0; }
+static int riscv_cpu_probe(struct udevice *dev) +{ + int ret = 0; + struct clk clk; + + /* Get a clock if it exists */ + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return 0; + + ret = clk_enable(&clk); + clk_free(&clk); + if (ret == -ENOSYS || ret == -ENOTSUPP) + return 0; + else + return ret; +} + static const struct cpu_ops riscv_cpu_ops = { .get_desc = riscv_cpu_get_desc, .get_info = riscv_cpu_get_info, @@ -133,6 +152,7 @@ U_BOOT_DRIVER(riscv_cpu) = { .id = UCLASS_CPU, .of_match = riscv_cpu_ids, .bind = riscv_cpu_bind, + .probe = riscv_cpu_probe, .ops = &riscv_cpu_ops, .flags = DM_FLAG_PRE_RELOC, };
Where possible, I have tried to find compatible drivers based on the layout of registers. However, many devices remain untested. All untested devices have been left disabled, but some tentative properties (such as compatible strings, and clocks, interrupts, and resets properties) have been added.
Changes in v6: - Remove spi, gpio, pinmux, wdt, and led bindings - Use consistent capitalization for hex digits
Changes in v5: - Add more compatible strings - Add cache line size - Document CPUs as rocket cores - Flesh out the gpio devices - Add ports for audio and video devices - Add fpioa pinctrl support - Configure pins for MMC on SPI1 - Enable MMC - Fix a couple uart properties (Thanks laanwj) - Reorder ram now that relocation is handled with CONFIG_SYS defines - Enable WDT - Add pinctrl properties - Add gpio support - Add led support - Add assorted AV bindings - Add compatible strings for ram - Use GPIO-based CS for MMC - Limit SPI flash to 50 MHz
Changes in v4: - Set regs sizes to full address range - Remove clock-frequency property from cpus - Add spi-max-frequency to spi devices from documentation - Add more compatible strings for each device - Add AI ram as a separate memory bank. Its clock is disabled on boot, and it cannot be accessed - Reorder memory banks so u-boot relocates higher, leaving more room to load boot images - Add designware ssi CTRL0 field shifts to spi devices - Don't enable the MMC slot - Update copyright - Lint
Changes in v3: - Move this patch to the end of the series - Add a max frequency for spi3 - Remov unused compatible strings from spi-flash@0 - Add s and u to isa string - Fix mmu-type - Remove cache-line size since it is unused (in u-boot) and undocumented (upstream) - Add timer interrupts to clint0 - Round up various registers - Add riscv,max-priority to plic - Add apb* busses, since they have clocks which need to be enabled to access their devices - Change uart compatible strings to "snps,dw-apb-uart", since that appears to match their registers - Add compatible string for wdt* - Add system reset device under sysctl - Add reset device under sysctl
Changes in v2: - Model changed to "Sipeed Maix Bit" to match file name - Value of stdout-path fixed - SD card slot compatible changed to "mmc-spi-slot" - "jedec,spi-nor" added to spi flash compatible list - Aliases for spi busses added - timebase-frequency divided by 50 to match timer speed - cpu-frequency renamed to clock-frequency - CPUX_intc restyled to cpuX_intc - "kendryte,k210-soc" added to soc compatible list for future-proofing - PLIC handle renamed to plic0 from pic0 - K210_RST_SOC removed from sysrst, due to not being located in the reset register - K210_RST_* numbers changed to match their bit offset within the reset register - gpio_controller restyled to gpio-controller - Added a second clock to the dma binding to match what the driver expects - Changed "snps,designware-spi" compatible string to "snps,dw-apb-ssi" to match the correct driver - Added a name to the spi clocks - Added reg-io-width property to spi bindings - Assigned a default parent to K210_CLK_SPI3 - Removed assigned clocks for ACLK and PLLs - Removed u-boot,dm-pre-reloc bindings
arch/riscv/dts/Makefile | 1 + arch/riscv/dts/k210-maix-bit.dts | 47 ++ arch/riscv/dts/k210.dtsi | 599 ++++++++++++++++++++++++ include/dt-bindings/reset/k210-sysctl.h | 38 ++ 4 files changed, 685 insertions(+) create mode 100644 arch/riscv/dts/k210-maix-bit.dts create mode 100644 arch/riscv/dts/k210.dtsi create mode 100644 include/dt-bindings/reset/k210-sysctl.h
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 4f30e6936f..3a6f96c67d 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_SIFIVE_FU540) += hifive-unleashed-a00.dtb +dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb
targets += $(dtb-y)
diff --git a/arch/riscv/dts/k210-maix-bit.dts b/arch/riscv/dts/k210-maix-bit.dts new file mode 100644 index 0000000000..5b32c5fd5f --- /dev/null +++ b/arch/riscv/dts/k210-maix-bit.dts @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ + +/dts-v1/; + +#include "k210.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Sipeed Maix Bit 2.0"; + compatible = "sipeed,maix-bitm", "sipeed,maix-bit", "kendryte,k210"; + + chosen { + stdout-path = "serial0:115200"; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + status = "disabled"; + + simple-audio-card,cpu { + sound-dai = <&i2s0 0>; + }; + + simple-audio-card,codec { + sound-dai = <&mic>; + }; + }; + + mic: mic { + #sound-dai-cells = <0>; + compatible = "memsensing,msm61s4030h0"; + status = "disabled"; + }; +}; + +&uarths0 { + status = "okay"; +}; + +&i2s0 { + #sound-dai-cells = <1>; +}; diff --git a/arch/riscv/dts/k210.dtsi b/arch/riscv/dts/k210.dtsi new file mode 100644 index 0000000000..8b3b872e2f --- /dev/null +++ b/arch/riscv/dts/k210.dtsi @@ -0,0 +1,599 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ + +#include <dt-bindings/clock/k210-sysctl.h> +#include <dt-bindings/mfd/k210-sysctl.h> +#include <dt-bindings/reset/k210-sysctl.h> + +/ { + /* + * Although the K210 is a 64-bit CPU, the address bus is only 32-bits + * wide, and the upper half of all addresses is ignored. + */ + #address-cells = <1>; + #size-cells = <1>; + compatible = "kendryte,k210"; + + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1_0; + serial0 = &uarths0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + spi0 = &spi0; + spi1 = &spi1; + spi2 = &spi2; + spi3 = &spi3; + }; + + clocks { + in0: osc { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <7800000>; + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "kendryte,k210", "sifive,rocket0", "riscv"; + reg = <0>; + riscv,isa = "rv64imafdgc"; + mmu-type = "sv39"; + i-cache-block-size = <64>; + i-cache-size = <0x8000>; + d-cache-block-size = <64>; + d-cache-size = <0x8000>; + clocks = <&sysclk K210_CLK_CPU>; + cpu0_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "kendryte,k210", "sifive,rocket0", "riscv"; + reg = <1>; + riscv,isa = "rv64imafdgc"; + mmu-type = "sv39"; + i-cache-block-size = <64>; + i-cache-size = <0x8000>; + d-cache-block-size = <64>; + d-cache-size = <0x8000>; + clocks = <&sysclk K210_CLK_CPU>; + cpu1_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + }; + + sram0: memory@80000000 { + device_type = "memory"; + compatible = "kendryte,k210-sram"; + reg = <0x80000000 0x400000>; + clocks = <&sysclk K210_CLK_SRAM0>; + }; + + sram1: memory@80400000 { + device_type = "memory"; + reg = <0x80400000 0x200000>; + compatible = "kendryte,k210-sram"; + clocks = <&sysclk K210_CLK_SRAM1>; + }; + + airam: memory@80600000 { + device_type = "memory"; + reg = <0x80600000 0x200000>; + compatible = "kendryte,k210-airam"; + clocks = <&sysclk K210_CLK_PLL1>; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + ai_reserved: ai@80600000 { + reg = <0x80600000 0x200000>; + reusable; + }; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "kendryte,k210-soc", "simple-bus"; + ranges; + interrupt-parent = <&plic0>; + + debug0: debug@0 { + compatible = "kendryte,k210-debug", "riscv,debug"; + reg = <0x0 0x1000>; + }; + + rom0: nvmem@1000 { + reg = <0x1000 0x1000>; + read-only; + }; + + clint0: interrupt-controller@2000000 { + #interrupt-cells = <1>; + compatible = "kendryte,k210-clint", "riscv,clint0"; + reg = <0x2000000 0x1000>; + interrupt-controller; + interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>, + <&cpu1_intc 3>, <&cpu1_intc 7>; + clocks = <&sysclk K210_CLK_CPU>; + }; + + plic0: interrupt-controller@C000000 { + #interrupt-cells = <1>; + compatible = "kendryte,k210-plic", "riscv,plic0"; + reg = <0xC000000 0x4000000>; + interrupt-controller; + interrupts-extended = <&cpu0_intc 9>, <&cpu0_intc 11>, + <&cpu1_intc 9>, <&cpu1_intc 11>; + riscv,ndev = <65>; + riscv,max-priority = <7>; + }; + + uarths0: serial@38000000 { + compatible = "kendryte,k210-uarths", "sifive,uart0"; + reg = <0x38000000 0x1000>; + interrupts = <33>; + clocks = <&sysclk K210_CLK_CPU>; + status = "disabled"; + }; + + gpio0: gpio-controller@38001000 { + #interrupt-cells = <2>; + #gpio-cells = <2>; + compatible = "kendryte,k210-gpiohs", "sifive,gpio0"; + reg = <0x38001000 0x1000>; + interrupt-controller; + interrupts = <34 35 36 37 38 39 40 41 + 42 43 44 45 46 47 48 49 + 50 51 52 53 54 55 56 57 + 58 59 60 61 62 63 64 65>; + gpio-controller; + ngpios = <32>; + status = "disabled"; + }; + + kpu0: ai@40800000 { + compatible = "kendryte,k210-ai"; + reg = <0x40800000 0xc00000>; + interrupts = <25>; + clocks = <&sysclk K210_CLK_AI>; + memory-region = <&ai_reserved>; + status = "disabled"; + }; + + fft0: fft@42000000 { + compatible = "kendryte,k210-fft"; + reg = <0x42000000 0x400000>; + interrupts = <26>; + clocks = <&sysclk K210_CLK_FFT>; + resets = <&sysrst K210_RST_FFT>; + status = "disabled"; + }; + + dmac0: dma-controller@50000000 { + compatible = "kendryte,k210-dmac", "snps,axi-dma-1.01a"; + reg = <0x50000000 0x1000>; + interrupts = <27 28 29 30 31 32>; + clocks = <&sysclk K210_CLK_DMA>, <&sysclk K210_CLK_DMA>; + clock-names = "core-clk", "cfgr-clk"; + resets = <&sysrst K210_RST_DMA>; + dma-channels = <6>; + snps,dma-masters = <2>; + snps,data-width = <5>; + snps,block-size = <0x400000 0x400000 0x400000 + 0x400000 0x400000 0x400000>; + snps,axi-max-burst-len = <256>; + status = "disabled"; + }; + + apb0: bus@50200000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "kendryte,k210-apb", "simple-pm-bus"; + ranges; + clocks = <&sysclk K210_CLK_APB0>; + + gpio1: gpio-controller@50200000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "kendryte,k210-gpio", + "snps,dw-apb-gpio"; + reg = <0x50200000 0x80>; + clocks = <&sysclk K210_CLK_GPIO>; + resets = <&sysrst K210_RST_GPIO>; + status = "disabled"; + + gpio1_0: gpio1@0 { + #gpio-cells = <2>; + #interrupt-cells = <2>; + compatible = "snps,dw-apb-gpio-port"; + reg = <0>; + interrupt-controller; + interrupts = <23>; + gpio-controller; + snps,nr-gpios = <8>; + }; + }; + + uart1: serial@50210000 { + compatible = "kendryte,k210-uart", + "snps,dw-apb-uart"; + reg = <0x50210000 0x100>; + interrupts = <11>; + clocks = <&sysclk K210_CLK_UART1>; + resets = <&sysrst K210_RST_UART1>; + reg-io-width = <4>; + reg-shift = <2>; + dcd-override; + dsr-override; + cts-override; + ri-override; + status = "disabled"; + }; + + uart2: serial@50220000 { + compatible = "kendryte,k210-uart", + "snps,dw-apb-uart"; + reg = <0x50220000 0x100>; + interrupts = <12>; + clocks = <&sysclk K210_CLK_UART2>; + resets = <&sysrst K210_RST_UART2>; + reg-io-width = <4>; + reg-shift = <2>; + dcd-override; + dsr-override; + cts-override; + ri-override; + status = "disabled"; + }; + + uart3: serial@50230000 { + compatible = "kendryte,k210-uart", + "snps,dw-apb-uart"; + reg = <0x50230000 0x100>; + interrupts = <13>; + clocks = <&sysclk K210_CLK_UART3>; + resets = <&sysrst K210_RST_UART3>; + reg-io-width = <4>; + reg-shift = <2>; + dcd-override; + dsr-override; + cts-override; + ri-override; + status = "disabled"; + }; + + spi2: spi@50240000 { + compatible = "kendryte,k120-spislave", + "snps,dw-apb-ssi"; + spi-slave; + reg = <0x50240000 0x100>; + interrupts = <2>; + clocks = <&sysclk K210_CLK_SPI2>; + resets = <&sysrst K210_RST_SPI2>; + spi-max-frequency = <25000000>; + /* + * Likely not the only offset change, but this + * is the only one which is documented. + */ + snps,tmod-offset = <8>; + status = "disabled"; + }; + + i2s0: i2s@50250000 { + compatible = "kendryte,k210-i2s", + "snps,designware-i2s"; + reg = <0x50250000 0x200>; + interrupts = <5>; + clocks = <&sysclk K210_CLK_I2S0>; + clock-names = "i2sclk"; + resets = <&sysrst K210_RST_I2S0>; + status = "disabled"; + }; + + apu0: sound@520250200 { + compatible = "kendryte,k210-apu"; + reg = <0x50250200 0x200>; + status = "disabled"; + }; + + i2s1: i2s@50260000 { + compatible = "kendryte,k210-i2s", + "snps,designware-i2s"; + reg = <0x50260000 0x200>; + interrupts = <6>; + clocks = <&sysclk K210_CLK_I2S1>; + clock-names = "i2sclk"; + resets = <&sysrst K210_RST_I2S1>; + status = "disabled"; + }; + + i2s2: i2s@50270000 { + compatible = "kendryte,k210-i2s", + "snps,designware-i2s"; + reg = <0x50270000 0x200>; + interrupts = <7>; + clocks = <&sysclk K210_CLK_I2S2>; + clock-names = "i2sclk"; + resets = <&sysrst K210_RST_I2S2>; + status = "disabled"; + }; + + i2c0: i2c@50280000 { + compatible = "kendryte,k210-i2c", + "snps,designware-i2c"; + reg = <0x50280000 0x100>; + interrupts = <8>; + clocks = <&sysclk K210_CLK_I2C0>; + resets = <&sysrst K210_RST_I2C0>; + status = "disabled"; + }; + + i2c1: i2c@50290000 { + compatible = "kendryte,k210-i2c", + "snps,designware-i2c"; + reg = <0x50290000 0x100>; + interrupts = <9>; + clocks = <&sysclk K210_CLK_I2C1>; + resets = <&sysrst K210_RST_I2C1>; + status = "disabled"; + }; + + i2c2: i2c@502A0000 { + compatible = "kendryte,k210-i2c", + "snps,designware-i2c"; + reg = <0x502A0000 0x100>; + interrupts = <10>; + clocks = <&sysclk K210_CLK_I2C2>; + resets = <&sysrst K210_RST_I2C2>; + status = "disabled"; + }; + + fpioa: pinmux@502B0000 { + compatible = "kendryte,k210-fpioa"; + reg = <0x502B0000 0x100>; + clocks = <&sysclk K210_CLK_FPIOA>; + resets = <&sysrst K210_RST_FPIOA>; + status = "disabled"; + }; + + sha256: sha256@502C0000 { + compatible = "kendryte,k210-sha256"; + reg = <0x502C0000 0x100>; + clocks = <&sysclk K210_CLK_SHA>; + resets = <&sysrst K210_RST_SHA>; + status = "disabled"; + }; + + timer0: timer@502D0000 { + compatible = "kendryte,k210-timer", + "snps,dw-apb-timer"; + reg = <0x502D0000 0x100>; + interrupts = <14 15>; + clocks = <&sysclk K210_CLK_TIMER0>; + clock-names = "timer"; + resets = <&sysrst K210_RST_TIMER0>; + status = "disabled"; + }; + + timer1: timer@502E0000 { + compatible = "kendryte,k210-timer", + "snps,dw-apb-timer"; + reg = <0x502E0000 0x100>; + interrupts = <16 17>; + clocks = <&sysclk K210_CLK_TIMER1>; + clock-names = "timer"; + resets = <&sysrst K210_RST_TIMER1>; + status = "disabled"; + }; + + timer2: timer@502F0000 { + compatible = "kendryte,k210-timer", + "snps,dw-apb-timer"; + reg = <0x502F0000 0x100>; + interrupts = <18 19>; + clocks = <&sysclk K210_CLK_TIMER2>; + clock-names = "timer"; + resets = <&sysrst K210_RST_TIMER2>; + status = "disabled"; + }; + }; + + apb1: bus@50400000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "kendryte,k210-apb", "simple-pm-bus"; + ranges; + clocks = <&sysclk K210_CLK_APB1>; + + wdt0: watchdog@50400000 { + compatible = "kendryte,k210-wdt", "snps,dw-wdt"; + reg = <0x50400000 0x100>; + interrupts = <21>; + clocks = <&sysclk K210_CLK_WDT0>; + resets = <&sysrst K210_RST_WDT0>; + status = "disabled"; + }; + + wdt1: watchdog@50410000 { + compatible = "kendryte,k210-wdt", "snps,dw-wdt"; + reg = <0x50410000 0x100>; + interrupts = <22>; + clocks = <&sysclk K210_CLK_WDT1>; + resets = <&sysrst K210_RST_WDT1>; + status = "disabled"; + }; + + otp0: nvmem@50420000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "kendryte,k210-otp"; + reg = <0x50420000 0x100>, + <0x88000000 0x20000>; + reg-names = "reg", "mem"; + clocks = <&sysclk K210_CLK_ROM>; + resets = <&sysrst K210_RST_ROM>; + read-only; + status = "disabled"; + + /* Bootloader */ + firmware@00000 { + reg = <0x00000 0xC200>; + }; + + /* + * config string as described in RISC-V + * privileged spec 1.9 + */ + config-1-9@1c000 { + reg = <0x1C000 0x1000>; + }; + + /* + * Device tree containing only registers, + * interrupts, and cpus + */ + fdt@1d000 { + reg = <0x1D000 0x2000>; + }; + + /* CPU/ROM credits */ + credits@1f000 { + reg = <0x1F000 0x1000>; + }; + }; + + dvp0: camera@50430000 { + compatible = "kendryte,k210-dvp"; + reg = <0x50430000 0x100>; + interrupts = <24>; + clocks = <&sysclk K210_CLK_DVP>; + resets = <&sysrst K210_RST_DVP>; + status = "disabled"; + }; + + sysctl: syscon@50440000 { + compatible = "kendryte,k210-sysctl", + "syscon", "simple-mfd"; + reg = <0x50440000 0x100>; + reg-io-width = <4>; + + sysclk: clock-controller { + #clock-cells = <1>; + compatible = "kendryte,k210-clk"; + clocks = <&in0>; + }; + + sysrst: reset-controller { + compatible = "kendryte,k210-rst", + "syscon-reset"; + #reset-cells = <1>; + regmap = <&sysctl>; + offset = <K210_SYSCTL_PERI_RESET>; + mask = <0x27FFFFFF>; + assert-high = <1>; + }; + + reboot { + compatible = "syscon-reboot"; + regmap = <&sysctl>; + offset = <K210_SYSCTL_SOFT_RESET>; + mask = <1>; + value = <1>; + }; + }; + + aes0: aes@50450000 { + compatible = "kendryte,k210-aes"; + reg = <0x50450000 0x100>; + clocks = <&sysclk K210_CLK_AES>; + resets = <&sysrst K210_RST_AES>; + status = "disabled"; + }; + + rtc: rtc@50460000 { + compatible = "kendryte,k210-rtc"; + reg = <0x50460000 0x100>; + clocks = <&in0>; + resets = <&sysrst K210_RST_RTC>; + interrupts = <20>; + status = "disabled"; + }; + }; + + apb2: bus@52000000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "kendryte,k210-apb", "simple-pm-bus"; + ranges; + clocks = <&sysclk K210_CLK_APB2>; + + spi0: spi@52000000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "kendryte,k210-spi", + "snps,dw-apb-ssi"; + reg = <0x52000000 0x100>; + interrupts = <1>; + clocks = <&sysclk K210_CLK_SPI0>; + clock-names = "ssi_clk"; + resets = <&sysrst K210_RST_SPI0>; + spi-max-frequency = <25000000>; + num-cs = <4>; + reg-io-width = <4>; + status = "disabled"; + }; + + spi1: spi@53000000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "kendryte,k210-spi", + "snps,dw-apb-ssi"; + reg = <0x53000000 0x100>; + interrupts = <2>; + clocks = <&sysclk K210_CLK_SPI1>; + clock-names = "ssi_clk"; + resets = <&sysrst K210_RST_SPI1>; + spi-max-frequency = <25000000>; + num-cs = <4>; + reg-io-width = <4>; + status = "disabled"; + }; + + spi3: spi@54000000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "kendryte,k210-spi", + "snps,dw-apb-ssi"; + reg = <0x54000000 0x200>; + interrupts = <4>; + clocks = <&sysclk K210_CLK_SPI3>; + clock-names = "ssi_clk"; + resets = <&sysrst K210_RST_SPI3>; + /* Could possibly go up to 200 MHz */ + spi-max-frequency = <100000000>; + num-cs = <4>; + reg-io-width = <4>; + status = "disabled"; + }; + }; + }; +}; diff --git a/include/dt-bindings/reset/k210-sysctl.h b/include/dt-bindings/reset/k210-sysctl.h new file mode 100644 index 0000000000..12bb3880d9 --- /dev/null +++ b/include/dt-bindings/reset/k210-sysctl.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Sean Anderson seanga2@gmail.com + */ + +#ifndef RESET_K210_SYSCTL_H +#define RESET_K210_SYSCTL_H + +#define K210_RST_ROM 0 +#define K210_RST_DMA 1 +#define K210_RST_AI 2 +#define K210_RST_DVP 3 +#define K210_RST_FFT 4 +#define K210_RST_GPIO 5 +#define K210_RST_SPI0 6 +#define K210_RST_SPI1 7 +#define K210_RST_SPI2 8 +#define K210_RST_SPI3 9 +#define K210_RST_I2S0 10 +#define K210_RST_I2S1 11 +#define K210_RST_I2S2 12 +#define K210_RST_I2C0 13 +#define K210_RST_I2C1 14 +#define K210_RST_I2C2 15 +#define K210_RST_UART1 16 +#define K210_RST_UART2 17 +#define K210_RST_UART3 18 +#define K210_RST_AES 19 +#define K210_RST_FPIOA 20 +#define K210_RST_TIMER0 21 +#define K210_RST_TIMER1 22 +#define K210_RST_TIMER2 23 +#define K210_RST_WDT0 24 +#define K210_RST_WDT1 25 +#define K210_RST_SHA 26 +#define K210_RST_RTC 29 + +#endif /* RESET_K210_SYSCTL_H */
Hi Sean
Changes in v6:
Changes in v5:
- Enable MMC
- Enable WDT
- Add gpio support
- Add led support
Changes in v4:
- Update copyright
- Lint
Changes in v3:
- Fix mmu-type
Changes in v2:
It is not proper to mix them in one patch.
Thanks, Rick
targets += $(dtb-y)
- Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com
+/dts-v1/;
chosen {
sound {
sound-dai = <&mic>;
mic: mic {
+&uarths0 {
status = "okay";
+&i2s0 {
#size-cells = <1>;
aliases {
gpio0 = &gpio0;
gpio1 = &gpio1_0;
serial0 = &uarths0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
spi3 = &spi3;
clocks {
in0: osc {
#clock-cells = <0>;
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
mmu-type = "sv39";
cpu1: cpu@1 {
reg = <1>;
mmu-type = "sv39";
reserved-memory {
#size-cells = <1>;
ranges;
reusable;
soc {
#size-cells = <1>;
ranges;
debug0: debug@0 {
reg = <0x0 0x1000>;
rom0: nvmem@1000 {
read-only;
riscv,ndev = <65>;
interrupts = <33>;
#gpio-cells = <2>;
gpio-controller;
ngpios = <32>;
kpu0: ai@40800000 {
interrupts = <25>;
interrupts = <26>;
dma-channels = <6>;
#size-cells = <1>;
ranges;
#size-cells = <0>;
"snps,dw-apb-gpio";
gpio1_0: gpio1@0 {
#gpio-cells = <2>;
reg = <0>;
interrupts = <23>;
gpio-controller;
"snps,dw-apb-uart";
interrupts = <11>;
reg-io-width = <4>;
reg-shift = <2>;
dcd-override;
dsr-override;
cts-override;
ri-override;
"snps,dw-apb-uart";
interrupts = <12>;
reg-io-width = <4>;
reg-shift = <2>;
dcd-override;
dsr-override;
cts-override;
ri-override;
"snps,dw-apb-uart";
interrupts = <13>;
reg-io-width = <4>;
reg-shift = <2>;
dcd-override;
dsr-override;
cts-override;
ri-override;
"snps,dw-apb-ssi";
spi-slave;
interrupts = <2>;
interrupts = <5>;
interrupts = <6>;
interrupts = <7>;
interrupts = <8>;
interrupts = <9>;
interrupts = <10>;
#size-cells = <1>;
ranges;
interrupts = <21>;
interrupts = <22>;
#size-cells = <1>;
read-only;
/* Bootloader */
firmware@00000 {
config-1-9@1c000 {
fdt@1d000 {
credits@1f000 {
interrupts = <24>;
reg-io-width = <4>;
#clock-cells = <1>;
clocks = <&in0>;
"syscon-reset";
#reset-cells = <1>;
regmap = <&sysctl>;
assert-high = <1>;
reboot {
regmap = <&sysctl>;
mask = <1>;
value = <1>;
rtc: rtc@50460000 {
clocks = <&in0>;
interrupts = <20>;
#size-cells = <1>;
ranges;
#size-cells = <0>;
"snps,dw-apb-ssi";
interrupts = <1>;
num-cs = <4>;
reg-io-width = <4>;
#size-cells = <0>;
"snps,dw-apb-ssi";
interrupts = <2>;
num-cs = <4>;
reg-io-width = <4>;
#size-cells = <0>;
"snps,dw-apb-ssi";
interrupts = <4>;
num-cs = <4>;
reg-io-width = <4>;
- Copyright (C) 2019 Sean Anderson seanga2@gmail.com
2.25.0
On 3/10/20 5:08 AM, Rick Chen wrote:
Hi Sean
Changes in v6:
Changes in v5:
- Enable MMC
- Enable WDT
- Add gpio support
- Add led support
Changes in v4:
- Update copyright
- Lint
Changes in v3:
- Fix mmu-type
Changes in v2:
The bindings and the device trees?
Thanks, Rick
--Sean
Hi Sean
Hi Sean
Changes in v6:
Changes in v5:
- Enable MMC
- Enable WDT
- Add gpio support
- Add led support
Changes in v4:
- Update copyright
- Lint
Changes in v3:
- Fix mmu-type
Changes in v2:
Sorry, there are three k210-sysctl.h and I confuse them.
I thought it shall be put in [PATCH v6 07/19] clk: Add K210 clock support.
Please drop this suggestion.
Thanks, Rick
Thanks, Rick
--Sean
The Sipeed Maix series is a collection of boards built around the RISC-V Kendryte K210 processor. This processor contains several peripherals to accelerate neural network processing and other "ai" tasks. This includes a "KPU" neural network processor, an audio processor supporting beamforming reception, and a digital video port supporting capture and output at VGA resolution. Other peripherals include 8M of sram (accessible with and without caching); remappable pins, including 40 GPIOs; AES, FFT, and SHA256 accelerators; a DMA controller; and I2C, I2S, and SPI controllers. Maix peripherals vary, but include spi flash; on-board usb-serial bridges; ports for cameras, displays, and sd cards; and ESP32 chips. Currently, only the Sipeed Maix Bit V2.0 (bitm) is supported, but the boards are fairly similar.
Documentation for Maix boards is located at http://dl.sipeed.com/MAIX/HDK/. Documentation for the Kendryte K210 is located at https://kendryte.com/downloads/. However, hardware details are rather lacking, so most technical reference has been taken from the standalone sdk located at https://github.com/kendryte/kendryte-standalone-sdk.
Changes in v6: - Remove trailing whitespace from documentation - Remove configuration for spi/pinmux/gpio features - Flesh out documentation some more
Changes in v5: - Configure relocation location with CONFIG_SYS_SDRAM_* - Enable ram clocks - Add pinmux/gpio/led support - Remove (broken) MMC support - Store the environment in flash - Add partitions - Add bootcmd - Add docs for pinctrl and booting
Changes in v4: - Rework documentation to be organized by board mfg not cpu mfg - Update docs to reflect working SPI support - Add proper spi support - Don't define unneecessary macros in config.h - Lower the default stack so it isn't clobbered on relocation - Update MAINTAINERS - Update copyright
Changes in v3: - Reorder to be last in the patch series - Add documentation for the board - Generate defconfig with "make savedefconfig" - Update Kconfig to imply most features we need - Update MAINTAINERS
Changes in v2: - Select CONFIG_SYS_RISCV_NOCOUNTER - Imply CONFIG_CLK_K210 - Remove spurious references to CONFIG_ARCH_K210 - Remove many configs from defconfig where the defaults were fine - Add a few "not set" lines to suppress unneeded defaults - Reduce pre-reloc malloc space, now that clocks initialization happens later
arch/riscv/Kconfig | 4 + board/sipeed/maix/Kconfig | 48 +++++ board/sipeed/maix/MAINTAINERS | 11 ++ board/sipeed/maix/Makefile | 5 + board/sipeed/maix/maix.c | 54 ++++++ configs/sipeed_maix_bitm_defconfig | 8 + doc/board/index.rst | 1 + doc/board/sipeed/index.rst | 9 + doc/board/sipeed/maix.rst | 298 +++++++++++++++++++++++++++++ include/configs/sipeed-maix.h | 24 +++ 10 files changed, 462 insertions(+) create mode 100644 board/sipeed/maix/Kconfig create mode 100644 board/sipeed/maix/MAINTAINERS create mode 100644 board/sipeed/maix/Makefile create mode 100644 board/sipeed/maix/maix.c create mode 100644 configs/sipeed_maix_bitm_defconfig create mode 100644 doc/board/sipeed/index.rst create mode 100644 doc/board/sipeed/maix.rst create mode 100644 include/configs/sipeed-maix.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index b7a5757584..d016dd75d7 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -20,6 +20,9 @@ config TARGET_QEMU_VIRT config TARGET_SIFIVE_FU540 bool "Support SiFive FU540 Board"
+config TARGET_SIPEED_MAIX + bool "Support Sipeed Maix Board" + endchoice
config SYS_ICACHE_OFF @@ -53,6 +56,7 @@ source "board/AndesTech/ax25-ae350/Kconfig" source "board/emulation/qemu-riscv/Kconfig" source "board/microchip/mpfs_icicle/Kconfig" source "board/sifive/fu540/Kconfig" +source "board/sipeed/maix/Kconfig"
# platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" diff --git a/board/sipeed/maix/Kconfig b/board/sipeed/maix/Kconfig new file mode 100644 index 0000000000..8292089fc9 --- /dev/null +++ b/board/sipeed/maix/Kconfig @@ -0,0 +1,48 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + +if TARGET_SIPEED_MAIX + +config SYS_BOARD + default "maix" + +config SYS_VENDOR + default "sipeed" + +config SYS_CPU + default "generic" + +config SYS_CONFIG_NAME + default "sipeed-maix" + +config SYS_TEXT_BASE + default 0x80000000 + +config DEFAULT_DEVICE_TREE + default "k210-maix-bit" + +config NR_CPUS + default 2 + +config NR_DRAM_BANKS + default 3 + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select GENERIC_RISCV + select RISCV_PRIV_1_9 + imply SMP + imply OF_BOARD_SETUP + imply DM_SERIAL + imply SIFIVE_SERIAL + imply SIFIVE_CLINT + imply POWER_DOMAIN + imply SIMPLE_PM_BUS + imply CLK_CCF + imply CLK_COMPOSITE_CCF + imply CLK_K210 + imply DM_RESET + imply RESET_SYSCON + imply SYSRESET + imply SYSRESET_SYSCON +endif diff --git a/board/sipeed/maix/MAINTAINERS b/board/sipeed/maix/MAINTAINERS new file mode 100644 index 0000000000..1f33882e1e --- /dev/null +++ b/board/sipeed/maix/MAINTAINERS @@ -0,0 +1,11 @@ +Sipeed Maix BOARD +M: Sean Anderson seanga2@gmail.com +S: Maintained +F: arch/riscv/dts/k210.dtsi +F: arch/riscv/dts/k210-maix-bit.dts +F: board/sipeed/maix/ +F: configs/sipeed_maix_defconfig +F: doc/board/sipeed/ +F: include/configs/sipeed-maix.h +F: include/dt-bindings/*/k210-sysctl.h +F: test/dm/k210_pll.c diff --git a/board/sipeed/maix/Makefile b/board/sipeed/maix/Makefile new file mode 100644 index 0000000000..4acff5b31e --- /dev/null +++ b/board/sipeed/maix/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2019 Western Digital Corporation or its affiliates. + +obj-y += maix.o diff --git a/board/sipeed/maix/maix.c b/board/sipeed/maix/maix.c new file mode 100644 index 0000000000..c126cb5d67 --- /dev/null +++ b/board/sipeed/maix/maix.c @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Sean Anderson seanga2@gmail.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <fdt_support.h> + +phys_size_t get_effective_memsize(void) +{ + return CONFIG_SYS_SDRAM_SIZE; +} + +int board_init(void) +{ + int ret; + ofnode bank = ofnode_null(); + + /* Enable RAM clocks */ + while (true) { + struct clk clk; + + bank = ofnode_by_prop_value(bank, "device_type", "memory", + sizeof("memory")); + if (ofnode_equal(bank, ofnode_null())) + break; + + ret = clk_get_by_index_nodev(bank, 0, &clk); + if (ret) + continue; + + ret = clk_enable(&clk); + clk_free(&clk); + if (ret) + return ret; + } + return 0; +} + +int ft_board_setup(void *blob, bd_t *bd) +{ + int i; + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + base[i] = bd->bi_dram[i].start; + size[i] = bd->bi_dram[i].size; + } + + return fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS); +} diff --git a/configs/sipeed_maix_bitm_defconfig b/configs/sipeed_maix_bitm_defconfig new file mode 100644 index 0000000000..f48f7f06e9 --- /dev/null +++ b/configs/sipeed_maix_bitm_defconfig @@ -0,0 +1,8 @@ +CONFIG_RISCV=y +CONFIG_TARGET_SIPEED_MAIX=y +CONFIG_ARCH_RV64I=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +# CONFIG_NET is not set +# CONFIG_INPUT is not set +# CONFIG_DM_ETH is not set +# CONFIG_EFI_LOADER is not set diff --git a/doc/board/index.rst b/doc/board/index.rst index d43e536ca3..94f01bb098 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -16,5 +16,6 @@ Board-specific doc renesas/index rockchip/index sifive/index + sipeed/index st/index xilinx/index diff --git a/doc/board/sipeed/index.rst b/doc/board/sipeed/index.rst new file mode 100644 index 0000000000..3518e2d8f4 --- /dev/null +++ b/doc/board/sipeed/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Sipeed +====== + +.. toctree:: + :maxdepth: 2 + + maix diff --git a/doc/board/sipeed/maix.rst b/doc/board/sipeed/maix.rst new file mode 100644 index 0000000000..b11ee0182e --- /dev/null +++ b/doc/board/sipeed/maix.rst @@ -0,0 +1,298 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2020 Sean Anderson seanga2@gmail.com + +Maix Bit +======== + +Several of the Sipeed Maix series of boards cotain the Kendryte K210 processor, +a 64-bit RISC-V CPU. This processor contains several peripherals to accelerate +neural network processing and other "ai" tasks. This includes a "KPU" neural +network processor, an audio processor supporting beamforming reception, and a +digital video port supporting capture and output at VGA resolution. Other +peripherals include 8M of SRAM (accessible with and without caching); remappable +pins, including 40 GPIOs; AES, FFT, and SHA256 accelerators; a DMA controller; +and I2C, I2S, and SPI controllers. Maix peripherals vary, but include spi flash; +on-board usb-serial bridges; ports for cameras, displays, and sd cards; and +ESP32 chips. Currently, only the Sipeed Maix Bit V2.0 (bitm) is supported, but +the boards are fairly similar. + +Documentation for Maix boards is available from +`Sipeed's website http://dl.sipeed.com/MAIX/HDK/`_. +Documentation for the Kendryte K210 is available from +`Kendryte's website https://kendryte.com/downloads/`_. However, hardware +details are rather lacking, so most technical reference has been taken from the +`standalone sdk https://github.com/kendryte/kendryte-standalone-sdk`_. + +Build and boot steps +-------------------- + +To build u-boot, run + +.. code-block:: none + + make sipeed_maix_bitm_defconfig + make CROSS_COMPILE=<your cross compile prefix> + +To flash u-boot to a maix bit, run + +.. code-block:: none + + kflash -tp /dev/<your tty here> -B bit_mic u-boot-dtb.bin + +Boot output should look like the following: + +.. code-block:: none + + U-Boot 2020.04-rc2-00087-g2221cc09c1-dirty (Feb 28 2020 - 13:53:09 -0500) + + DRAM: 8 MiB + In: serial@38000000 + Out: serial@38000000 + Err: serial@38000000 + => + +Loading Images +^^^^^^^^^^^^^^ + +To load a kernel, transfer it over serial. + +.. code-block:: none + + => loady 80000000 1500000 + ## Switch baudrate to 1500000 bps and press ENTER ... + + *** baud: 1500000 + + *** baud: 1500000 *** + ## Ready for binary (ymodem) download to 0x80000000 at 1500000 bps... + C + *** file: loader.bin + $ sz -vv loader.bin + Sending: loader.bin + Bytes Sent:2478208 BPS:72937 + Sending: + Ymodem sectors/kbytes sent: 0/ 0k + Transfer complete + + *** exit status: 0 *** + ## Total Size = 0x0025d052 = 2478162 Bytes + ## Switch baudrate to 115200 bps and press ESC ... + + *** baud: 115200 + + *** baud: 115200 *** + => + +Running Programs +^^^^^^^^^^^^^^^^ + +Binaries +"""""""" + +To run a bare binary, use the ``go`` command: + +.. code-block:: none + + => loady + ## Ready for binary (ymodem) download to 0x80000000 at 115200 bps... + C + *** file: ./examples/standalone/hello_world.bin + $ sz -vv ./examples/standalone/hello_world.bin + Sending: hello_world.bin + Bytes Sent: 4864 BPS:649 + Sending: + Ymodem sectors/kbytes sent: 0/ 0k + Transfer complete + + *** exit status: 0 *** + (CAN) packets, 5 retries + ## Total Size = 0x000012f8 = 4856 Bytes + => go 80000000 + ## Starting application at 0x80000000 ... + Example expects ABI version 9 + Actual U-Boot ABI version 9 + Hello World + argc = 1 + argv[0] = "80000000" + argv[1] = "<NULL>" + Hit any key to exit ... + +Legacy Images +""""""""""""" + +To run legacy images, use the ``bootm`` command: + +.. code-block:: none + + $ tools/mkimage -A riscv -O u-boot -T standalone -C none -a 80000000 -e 80000000 -d examples/standalone/hello_world.bin hello_world.img + Image Name: + Created: Thu Mar 5 12:04:10 2020 + Image Type: RISC-V U-Boot Standalone Program (uncompressed) + Data Size: 4856 Bytes = 4.74 KiB = 0.00 MiB + Load Address: 80000000 + Entry Point: 80000000 + + $ picocom -b 115200 /dev/ttyUSB0i + => loady + ## Ready for binary (ymodem) download to 0x80000000 at 115200 bps... + C + *** file: hello_world.img + $ sz -vv hello_world.img + Sending: hello_world.img + Bytes Sent: 4992 BPS:665 + Sending: + Ymodem sectors/kbytes sent: 0/ 0k + Transfer complete + + *** exit status: 0 *** + CAN) packets, 3 retries + ## Total Size = 0x00001338 = 4920 Bytes + => bootm + ## Booting kernel from Legacy Image at 80000000 ... + Image Name: + Image Type: RISC-V U-Boot Standalone Program (uncompressed) + Data Size: 4856 Bytes = 4.7 KiB + Load Address: 80000000 + Entry Point: 80000000 + Verifying Checksum ... OK + Loading Standalone Program + Example expects ABI version 9 + Actual U-Boot ABI version 9 + Hello World + argc = 0 + argv[0] = "<NULL>" + Hit any key to exit ... + +Over- and Under-clocking +------------------------ + +To change the clock speed of the K210, you will need to enable +``CONFIG_CLK_K210_SET_RATE`` and edit the board's device tree. To do this, add a +section to ``arch/riscv/arch/riscv/dts/k210-maix-bit.dts`` like the following: + +.. code-block:: + + &sysclk { + assigned-clocks = <&sysclk K210_CLK_PLL0>; + assigned-clock-rates = <800000000>; + }; + +There are three PLLs on the K210: PLL0 is the parent of most of the components, +including the CPU and RAM. PLL1 is the parent of the neural network coprocessor. +PLL2 is the parent of the sound processing devices. Note that child clocks of +PLL0 and PLL2 run at *half* the speed of the PLLs. For example, if PLL0 is +running at 800 MHz, then the CPU will run at 400 MHz. This is the example given +above. The CPU can be overclocked to around 600 MHz, and underclocked to 26 MHz. + +It is possible to set PLL2's parent to PLL0. The plls are more accurate when +converting between similar frequencies. This makes it easier to get an accurate +frequency for I2S. As an example, consider sampling an I2S device at 44.1 kHz. +On this device, the I2S serial clock runs at 64 times the sample rate. +Therefore, we would like to run PLL2 at an even multiple of 2.8224 MHz. If +PLL2's parent is IN0, we could use a frequency of 390 MHz (the same as the CPU's +default speed). Dividing by 138 yields a serial clock of about 2.8261 MHz. This +results in a sample rate of 44.158 kHz---around 50 Hz or .1% too fast. If, +instead, we set PLL2's parent to PLL1 running at 390 MHz, and request a rate of +2.8224 * 136 = 383.8464 MHz, the achieved rate is 383.90625 MHz. Dividing by 136 +yields a serial clock of about 2.8228 MHz. This results in a sample rate of +44.107 kHz---just 7 Hz or .02% too fast. This configuration is shown in the +following example: + +.. code-block:: + + &sysclk { + assigned-clocks = <&sysclk K210_CLK_PLL1>, <&sysclk K210_CLK_PLL2>; + assigned-clock-parents = <0>, <&sysclk K210_CLK_PLL1>; + assigned-clock-rates = <390000000>, <383846400>; + }; + +There are a couple of quirks to the PLLs. First, there are more frequency ratios +just above and below 1.0, but there is a small gap around 1.0. To be explicit, +if the input frequency is 100 MHz, it would be impossible to have an output of +99 or 101 MHz. In addition, there is a maximum frequency for the internal VCO, +so higher input/output frequencies will be less accurate than lower ones. + +Technical Details +----------------- + +Boot Sequence +^^^^^^^^^^^^^ + +1. ``RESET`` pin is deasserted. +2. Both harts begin executing at ``0x00001000``. +3. Both harts jump to firmware at ``0x88000000``. +4. One hart is chosen as a boot hart. +5. Firmware reads value of pin ``IO_16`` (ISP). + + * If the pin is low, enter ISP mode. This mode allows loading data to ram, + writing it to flash, and booting from specific addresses. + * If the pin is high, continue boot. +6. Firmware reads the next stage from flash (SPI3) to address ``0x80000000``. + + * If byte 0 is 1, the next stage is decrypted using the built-in AES + accelerator and the one-time programmable, 128-bit AES key. + * Bytes 1 to 4 hold the length of the next stage. + * The SHA-256 sum of the next stage is automatically calculated, and verified + against the 32 bytes following the next stage. +7. The boot hart sends an IPI to the other hart telling it to jump to the next + stage. +8. The boot hart jumps to ``0x80000000``. + +Memory Map +^^^^^^^^^^ + +========== ========= =========== +Address Size Description +========== ========= =========== +0x00000000 0x1000 debug +0x00001000 0x1000 rom +0x02000000 0x1000 clint +0x0C000000 0x4000000 plic +0x38000000 0x1000 uarths +0x38001000 0x1000 gpiohs +0x40000000 0x400000 sram0 (non-cached) +0x40400000 0x200000 sram1 (non-cached) +0x40600000 0x200000 airam (non-cached) +0x40800000 0xC00000 kpu +0x42000000 0x400000 fft +0x50000000 0x1000 dmac +0x50200000 0x200000 apb0 +0x50200000 0x80 gpio +0x50210000 0x100 uart0 +0x50220000 0x100 uart1 +0x50230000 0x100 uart2 +0x50240000 0x100 spi slave +0x50250000 0x200 i2s0 +0x50250200 0x200 apu +0x50260000 0x200 i2s1 +0x50270000 0x200 i2s2 +0x50280000 0x100 i2c0 +0x50290000 0x100 i2c1 +0x502A0000 0x100 i2c2 +0x502B0000 0x100 fpioa +0x502C0000 0x100 sha256 +0x502D0000 0x100 timer0 +0x502E0000 0x100 timer1 +0x502F0000 0x100 timer2 +0x50400000 0x200000 apb1 +0x50400000 0x100 wdt0 +0x50410000 0x100 wdt1 +0x50420000 0x100 otp control +0x50430000 0x100 dvp +0x50440000 0x100 sysctl +0x50450000 0x100 aes +0x50460000 0x100 rtc +0x52000000 0x4000000 apb2 +0x52000000 0x100 spi0 +0x53000000 0x100 spi1 +0x54000000 0x200 spi3 +0x80000000 0x400000 sram0 (cached) +0x80400000 0x200000 sram1 (cached) +0x80600000 0x200000 airam (cached) +0x88000000 0x20000 otp +0x88000000 0xC200 firmware +0x8801C000 0x1000 riscv priv spec 1.9 config +0x8801D000 0x2000 flattened device tree (contains only addresses and + interrupts) +0x8801f000 0x1000 credits +========== ========= =========== diff --git a/include/configs/sipeed-maix.h b/include/configs/sipeed-maix.h new file mode 100644 index 0000000000..a46473fc78 --- /dev/null +++ b/include/configs/sipeed-maix.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019-20 Sean Anderson seanga2@gmail.com + */ + +#ifndef CONFIGS_SIPEED_MAIX_H +#define CONFIGS_SIPEED_MAIX_H + +#include <linux/sizes.h> + +#define CONFIG_SYS_LOAD_ADDR 0x80000000 +/* Start just below the second bank so we don't clobber it during reloc */ +#define CONFIG_SYS_INIT_SP_ADDR 0x803FFFFF +#define CONFIG_SYS_MALLOC_LEN SZ_128K +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +/* Don't relocate into AI ram since it isn't set up yet */ +#define CONFIG_SYS_SDRAM_SIZE (SZ_4M + SZ_2M) + +/* For early init */ +#define K210_SYSCTL_BASE 0x50440000 + +#endif /* CONFIGS_SIPEED_MAIX_H */
Hi Sean
This patch applying fail
Applying: riscv: Add Sipeed Maix support error: patch failed: doc/board/index.rst:16 error: doc/board/index.rst: patch does not apply Patch failed at 0001 riscv: Add Sipeed Maix support The copy of the patch that failed is found in: .git/rebase-apply/patch When you have resolved this problem, run "git am --continue". If you prefer to skip this patch, run "git am --skip" instead. To restore the original branch and stop patching, run "git am --abort".
I have replied to you the same result in v5 [v5,33/33] riscv: Add Sipeed Maix support https://patchwork.ozlabs.org/patch/1246869/#2376311
By the way, you can not mix them (arch, board, configs, doc)together in a patch. arch/riscv/Kconfig board/sipeed/maix/ ... configs/sipeed_maix_bitm_defconfig doc/board/index.rst
Thanks, Rick
Changes in v6:
Changes in v5:
- Enable ram clocks
- Add partitions
- Add bootcmd
Changes in v4:
- Update copyright
Changes in v3:
Changes in v2:
endchoice
+config SYS_BOARD
default "maix"
+config SYS_VENDOR
default "sipeed"
+config SYS_CPU
default "generic"
default 0x80000000
+config NR_CPUS
default 2
default 3
def_bool y
imply SMP
imply DM_SERIAL
imply SIFIVE_SERIAL
imply SIFIVE_CLINT
imply POWER_DOMAIN
imply SIMPLE_PM_BUS
imply CLK_CCF
imply CLK_K210
imply DM_RESET
imply RESET_SYSCON
imply SYSRESET
int ret;
while (true) {
struct clk clk;
sizeof("memory"));
break;
if (ret)
continue;
clk_free(&clk);
if (ret)
return ret;
int i;
- sipeed/index st/index xilinx/index
+Sipeed +======
+.. toctree::
- :maxdepth: 2
- maix
+Maix Bit +========
- make sipeed_maix_bitm_defconfig
- make CROSS_COMPILE=<your cross compile prefix>
- kflash -tp /dev/<your tty here> -B bit_mic u-boot-dtb.bin
- U-Boot 2020.04-rc2-00087-g2221cc09c1-dirty (Feb 28 2020 - 13:53:09 -0500)
- DRAM: 8 MiB
- In: serial@38000000
- Out: serial@38000000
- Err: serial@38000000
- => loady 80000000 1500000
- ## Switch baudrate to 1500000 bps and press ENTER ...
- *** baud: 1500000
- *** baud: 1500000 ***
- ## Ready for binary (ymodem) download to 0x80000000 at 1500000 bps...
- C
- *** file: loader.bin
- $ sz -vv loader.bin
- Sending: loader.bin
- Bytes Sent:2478208 BPS:72937
- Sending:
- Ymodem sectors/kbytes sent: 0/ 0k
- Transfer complete
- *** exit status: 0 ***
- ## Total Size = 0x0025d052 = 2478162 Bytes
- ## Switch baudrate to 115200 bps and press ESC ...
- *** baud: 115200
- *** baud: 115200 ***
+Binaries +""""""""
- => loady
- ## Ready for binary (ymodem) download to 0x80000000 at 115200 bps...
- C
- *** file: ./examples/standalone/hello_world.bin
- $ sz -vv ./examples/standalone/hello_world.bin
- Sending: hello_world.bin
- Bytes Sent: 4864 BPS:649
- Sending:
- Transfer complete
- (CAN) packets, 5 retries
- ## Total Size = 0x000012f8 = 4856 Bytes
- => go 80000000
- ## Starting application at 0x80000000 ...
- Example expects ABI version 9
- Actual U-Boot ABI version 9
- Hello World
- argc = 1
- argv[0] = "80000000"
- argv[1] = "<NULL>"
- Hit any key to exit ...
- $ tools/mkimage -A riscv -O u-boot -T standalone -C none -a 80000000 -e 80000000 -d examples/standalone/hello_world.bin hello_world.img
- Image Name:
- Created: Thu Mar 5 12:04:10 2020
- Image Type: RISC-V U-Boot Standalone Program (uncompressed)
- Data Size: 4856 Bytes = 4.74 KiB = 0.00 MiB
- Load Address: 80000000
- Entry Point: 80000000
- $ picocom -b 115200 /dev/ttyUSB0i
- => loady
- C
- *** file: hello_world.img
- $ sz -vv hello_world.img
- Sending: hello_world.img
- Bytes Sent: 4992 BPS:665
- Sending:
- Transfer complete
- CAN) packets, 3 retries
- ## Total Size = 0x00001338 = 4920 Bytes
- => bootm
- ## Booting kernel from Legacy Image at 80000000 ...
Image Name:
- Hello World
- argc = 0
- argv[0] = "<NULL>"
+.. code-block::
- &sysclk {
+.. code-block::
- &sysclk {
- If the pin is low, enter ISP mode. This mode allows loading data to ram,
- If the pin is high, continue boot.
- If byte 0 is 1, the next stage is decrypted using the built-in AES
- Bytes 1 to 4 hold the length of the next stage.
- The SHA-256 sum of the next stage is automatically calculated, and verified
- stage.
interrupts)
2.25.0
On 3/10/20 5:04 AM, Rick Chen wrote:
Hi Sean
As above, I just rebased against u-boot/master. I'm not sure what's causing the problem here.
Is there a preferred order for adding these? I will split them for v7.
Thanks, Rick
Hi Sean
Hi Sean
Maybe you can group them as two patchs
patch 19/20 arch/riscv/Kconfig board/sipeed/maix/Kconfig board/sipeed/maix/MAINTAINERS board/sipeed/maix/Makefile board/sipeed/maix/maix.c configs/sipeed_maix_bitm_defconfig include/configs/sipeed-maix.h
patch 19/20 doc/board/index.rst doc/board/sipeed/index.rst doc/board/sipeed/maix.rst
Thanks, Rick
Thanks, Rick
Rick Chen
Sean Anderson
