Re: [PATCH v2 1/3] fdtdec: optionally add property no-map to created reserved memory node
From: Patrice Chotard [mailto:patrice.chotard@st.com] Sent: Tuesday, August 25, 2020 7:29 PM To: u-boot@lists.denx.de Cc: Patrice CHOTARD; Patrick DELAUNAY; U-Boot STM32; Etienne Carriere; Atish Patra; Bin Meng; Bryan O'Donoghue; Heinrich Schuchardt; Rick Jian-Zhi Chen(陳建志); Simon Glass Subject: [PATCH v2 1/3] fdtdec: optionally add property no-map to created reserved memory node
Add boolean input argument @no_map to helper function fdtdec_add_reserved_memory() to add "no-map" property for an added reserved memory node. This is needed for example when the reserved memory relates to secure memory that the dear Linux kernel shall not even map unless what non-secure world speculative accesses of the CPU can violate the memory firmware configuration.
No function change. A later change will update to OPTEE library to add no-map property to OP-TEE reserved memory nodes.
Signed-off-by: Etienne Carriere etienne.carriere@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com
- fix dm fdtdec test and arch/riscv/lib/fdt_fixup.c with
fdtdec_add_reserved_memory() new parameter
(no changes since v1)
arch/riscv/lib/fdt_fixup.c | 2 +- include/fdtdec.h | 5 +++-- lib/fdtdec.c | 10 ++++++++-- lib/optee/optee.c | 2 +- test/dm/fdtdec.c | 6 +++--- 5 files changed, 16 insertions(+), 9 deletions(-)
Acked-by: Rick Chen rick@andestech.com
Rick Chen
