[U-Boot] mtd: spi-nor: new NXP FlexSPI driver location & framework to use ?
Dear Jagan,
NXP is coming up with new FlexSPI controller. It is similar to existing QSPI with enhanced feature-set. We have the driver ready as per existing framework i.e. driver/spi.
From recend discussion, we go to know about framework change. Migration of qspi drivers in u-boot-spi/drivers/mtd/spi-nor/
git://git.denx.de/u-boot-spi.git branch mtd-spinor-working.
We are in dilemma for sending FlexSPI driver upstream. Do we follow existing framework i.e. driver/spi or new proposed framework i.e. u-boot-spi/drivers/mtd/spi-nor/
Also, do we have any timeline of u-boot-spi/drivers/mtd/spi-nor/ to become default.
We have sent RFC version in Linux upstream for review. Please refer below
Regards, Prabhakar
-----Original Message----- From: linux-mtd [mailto:linux-mtd-bounces@lists.infradead.org] On Behalf Of Yogesh Gaur Sent: Wednesday, April 4, 2018 3:36 PM To: linux-mtd@lists.infradead.org Cc: boris.brezillon@free-electrons.com; Yogesh Narayan Gaur yogeshnarayan.gaur@nxp.com; marek.vasut@gmail.com; frieder.schrempf@exceet.de; Suresh Gupta suresh.gupta@nxp.com; cyrille.pitchen@wedev4u.fr; Han Xu han.xu@nxp.com; computersforpeace@gmail.com; festevam@gmail.com Subject: [RFC PATCH 0/4] mtd: spi-nor: Add NXP FlexSPI driver
NXP uses FlexSPI controller. The FlexSPI(Flex Serial Peripheral controller) acts as an interface to external serial flash devices, maximum 4, each with upto 8 bidirectional data lines.
(1) The FlexSPI controller is driven by the LUT(Look-up Table) registers. The LUT registers are a look-up-table for sequences of instructions. A valid sequence consists of four LUT registers.
(2) The definition of the LUT register shows below: --------------------------------------------------- | INSTR1 | PAD1 | OPRND1 | INSTR0 | PAD0 | OPRND0 | ---------------------------------------------------
There are several types of INSTRx, such as: CMD : the SPI NOR command. ADDR : the address for the SPI NOR command. DUMMY : the dummy cycles needed by the SPI NOR command. ....
There are several types of PADx, such as: PAD1 : use single I/O line. PAD2 : use dual I/O lines. PAD4 : use quad I/O lines. PAD8 : use octal I/O lines. ....
(3) LUTs are being created at run-time based on the commands passed from the spi-nor framework.
(4) Mode [single, dual, quad or octal] bit information derived from device tree by parsing spi-rx-bus-width and spi-tx-bus-width property.
(5) Tested this driver with the mtd_debug utility on NXP LX2160 emulator platform.
This series added below patches: - Added entry for mt35xu512aba NOR flash in spi_nor_ids table - Add flags for Octal I/O data transfer in spi/spi.h - Add binding file for NXP FlexSPI driver - Add NXP FlexSPI driver in mtd interface
Yogesh Gaur (4): mtd: spi-nor: Add entry for mt35xu512aba flash spi: add flags for octal I/O data transfer dt-bindings: Add binding file for NXP FlexSPI driver mtd: spi-nor: Add NXP FlexSPI driver
.../devicetree/bindings/mtd/nxp-flexspi.txt | 40 + MAINTAINERS | 7 + drivers/mtd/spi-nor/Kconfig | 7 + drivers/mtd/spi-nor/Makefile | 1 + drivers/mtd/spi-nor/nxp-flexspi.c | 1508 ++++++++++++++++++++ drivers/mtd/spi-nor/spi-nor.c | 7 +- include/linux/mtd/cfi.h | 1 + include/linux/mtd/spi-nor.h | 1 + include/linux/spi/spi.h | 2 + 9 files changed, 1573 insertions(+), 1 deletion(-) create mode 100644 Documentation/devicetree/bindings/mtd/nxp-flexspi.txt create mode 100644 drivers/mtd/spi-nor/nxp-flexspi.c
-- 1.9.1
______________________________________________________ Linux MTD discussion mailing list https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.infr...
On Fri, May 11, 2018 at 11:08 AM, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
Dear Jagan,
From recend discussion, we go to know about framework change. Migration of qspi drivers in u-boot-spi/drivers/mtd/spi-nor/ git://git.denx.de/u-boot-spi.git branch mtd-spinor-working.
Idea is to move spi-nor, mtd-spinor-working is paused because of non-dm drivers accessing. We are clear that we can't create another legacy layer to access spi-nor for the sake of non-dm driver to work which eventually ended-up another mess and also no one take care of non-dm conversion to dm if we give such feasibility. So we exported a deadline for full SPI/SPI_FLASH DM conversion till v2018.09. Once all these relevant conversion done, will try to move.
[1] http://git.denx.de/?p=u-boot-spi.git;a=commitdiff;h=c4e68d3aa8178f6aa63a79c4...
Jagan.
Thanks Jagan
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Friday, May 11, 2018 11:31 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Jagan Teki jagan@amarulasolutions.com; York Sun york.sun@nxp.com; Yogesh Narayan Gaur yogeshnarayan.gaur@nxp.com; Poonam Aggrwal poonam.aggrwal@nxp.com; Ashish Kumar ashish.kumar@nxp.com; u- boot@lists.denx.de Subject: Re: mtd: spi-nor: new NXP FlexSPI driver location & framework to use ?
Dear Jagan,
become default.
This means, FlexSPI driver will not be accepted in driver/spi. It should follow u-boot-spi/drivers/mtd/spi-nor/ mtd-spinor-working branch
--pk
Hi Jagan,
On Fri, 11 May 2018 11:30:43 +0530 Jagan Teki jagannadh.teki@gmail.com wrote:
Dear Jagan,
Just for the record, the spi-mem interface has been accepted in Linux [1] (should be there in 4.18). From now on, I'll try to encourage people move existing spi-nor controller drivers to the SPI subsystem, and I'll definitely ask new QPSI drivers to use this interface (and extend it if needed).
So, I'm not sure creating this spi-nor subsystem in uboot is a good idea anymore. Of course, it's up to you to decide, but if you take this path you'll run into the same problem we had in Linux:
- how to support SPI NANDs in a clean and efficient way - how to support both memory-like operations and regular SPI transfers with the same driver
Regards,
Boris
[1]https://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi.git/commit/?h=fo...
Dear Jagan,
default.
Hello Jagan,
You have mentioned here http://git.denx.de/?p=u-boot-spi.git;a=commitdiff;h=c4e68d3aa8178f6aa63a79c4...
Snip from above link: +Partially converted: + drivers/spi/atcspi200_spi.c + drivers/spi/davinci_spi.c + drivers/spi/fsl_dspi.c + drivers/spi/fsl_qspi.c
That fsl_qspi.c is partial converted to DM model, is there any guide line to follow for missing stuff ?
Regards Ashish
[1] https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fgit.denx .de%2F%3Fp%3Du-boot- spi.git%3Ba%3Dcommitdiff%3Bh%3Dc4e68d3aa8178f6aa63a79c4f8f459c0e3ed 58e8&data=02%7C01%7Cashish.kumar%40nxp.com%7C2acd718de97d435bb5e c08d5b70489cd%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C63661 6152533412247&sdata=ury1R6ZYqoJbx5nuYTehZyMTo%2BFW3QPpLD1EIPUrcz g%3D&reserved=0
Jagan.
-- Jagan Teki Free Software Engineer | https://emea01.safelinks.protection.outlook.com/?url=www.openedev.com&d ata=02%7C01%7Cashish.kumar%40nxp.com%7C2acd718de97d435bb5ec08d5b7 0489cd%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636616152533 412247&sdata=gsoI52kSNfVEE6K%2F03CWs6%2FG2Xr1L9TEhDLGmqrRWRQ%3 D&reserved=0 U-Boot, Linux | Upstream Maintainer Hyderabad, India.
Dear Jagan,
default.
Hello Jagan,
We should fully convert the driver into dm, no #ifdef CONFIG_DM_SPI
Thanks Jagan,
Dear Jagan,
become default.
This means, flexspi controller driver should be upstream'ed via u-boot-spi/drivers/mtd/spi-nor branch mtd-spinor-working
--pk
Dear Jagan,
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Prabhakar Kushwaha Sent: Monday, May 14, 2018 6:55 PM To: Jagan Teki jagannadh.teki@gmail.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] mtd: spi-nor: new NXP FlexSPI driver location & framework to use ?
Thanks Jagan,
Dear Jagan,
become default.
This means, flexspi controller driver should be upstream'ed via u-boot- spi/drivers/mtd/spi-nor branch mtd-spinor-working
Please help me with the query. We don’t want to end up with 2 FlexSPI drivers being posted in upstream.
--pk
On Thu, May 17, 2018 at 4:49 PM, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
Dear Jagan,
Thanks Jagan,
Dear Jagan,
become default.
Let me understand is this FlexSPI is spi-nor controller, is it Linux upstreamed or ML? I think for now you can add it mtd/spi with UCLASS_SPI_FLASH driver, Since Boris mentioned about spi-mem(I still need to see the Linux framework for more details) which may be re-placer for spi-nor but once we decided to go with spi-mem or spi-nor then the flexspi can convert accordingly.
Jagan.
Dear Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Friday, May 18, 2018 10:24 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: u-boot@lists.denx.de Subject: Re: mtd: spi-nor: new NXP FlexSPI driver location & framework to use ?
Dear Jagan,
Thanks Jagan,
Dear Jagan,
become default.
RFC patch http://patchwork.ozlabs.org/patch/894918/ is under discussion. It is with assumption of driver/mtd/spi-nor
This means, FlexSPI should be part of driver/mtd/spi-nor for now. When You decide way forward(mtd/spi or spi-mem), flexSPI driver can move accordingly.
Thanks
--pk
On Fri, May 18, 2018 at 10:31 AM, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
Dear Jagan,
Dear Jagan,
Thanks Jagan,
Dear Jagan,
become default.
Ohh, there is chance to move this to spi-mem is it?
Due to spi-mem, I'm holding spi-nor driver as of now. we need some discussion to understand how we implement it in U-Boot and decide to move further. So I suggest you to use existing sf where we can write UCLASS_SPI_FLASH driver. Hope you understand.
Jagan.
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Friday, May 18, 2018 11:54 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: u-boot@lists.denx.de Subject: Re: mtd: spi-nor: new NXP FlexSPI driver location & framework to use ?
Dear Jagan,
Dear Jagan,
Thanks Jagan,
On Fri, May 11, 2018 at 11:08 AM, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote: > Dear Jagan, > > NXP is coming up with new FlexSPI controller. It is similar to > existing QSPI with enhanced feature-set. > We have the driver ready as per existing framework i.e. driver/spi. > > From recend discussion, we go to know about framework change. > Migration of qspi drivers in u-boot-spi/drivers/mtd/spi-nor/ git://git.denx.de/u-boot-spi.git branch mtd-spinor-working. > > We are in dilemma for sending FlexSPI driver upstream. > Do we follow existing framework i.e. driver/spi or new proposed framework i.e. u-boot-spi/drivers/mtd/spi-nor/ > > Also, do we have any timeline of > u-boot-spi/drivers/mtd/spi-nor/ to become default.
RFC patch
https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatchw ork.ozlabs.org%2Fpatch%2F894918%2F&data=02%7C01%7Cprabhakar.kushwah a%40nxp.com%7C32aaec29f75b416004ec08d5bc87f8f1%7C686ea1d3bc2b4c6f a92cd99c5c301635%7C0%7C0%7C636622214533987461&sdata=%2F8i9vHtQF1 S5Q6Bn65HVNPIMe%2FI6eSvP%2FKmKs1gxA8U%3D&reserved=0 is under discussion.
accordingly.
accordingly.
For now, sent FlexSPI driver as per current framework i.e. driver/mtd/spi.
Wait for the new framework(either spi-mem or driver/mtd) from you. Once framework available migrate to that one.
Is my understanding correct?
--pk
On Fri, May 18, 2018 at 3:46 PM, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
Hi Jagan,
Dear Jagan,
Dear Jagan,
Thanks Jagan,
> -----Original Message----- > From: Jagan Teki [mailto:jagannadh.teki@gmail.com] > Sent: Friday, May 11, 2018 11:31 AM > To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com > Cc: Jagan Teki jagan@amarulasolutions.com; York Sun > york.sun@nxp.com; Yogesh Narayan Gaur yogeshnarayan.gaur@nxp.com; > Poonam Aggrwal poonam.aggrwal@nxp.com; Ashish Kumar > ashish.kumar@nxp.com; u- boot@lists.denx.de > Subject: Re: mtd: spi-nor: new NXP FlexSPI driver location & > framework to use ? > > On Fri, May 11, 2018 at 11:08 AM, Prabhakar Kushwaha > prabhakar.kushwaha@nxp.com wrote: > > Dear Jagan, > > > > NXP is coming up with new FlexSPI controller. It is similar to > > existing QSPI > with enhanced feature-set. > > We have the driver ready as per existing framework i.e. driver/spi. > > > > From recend discussion, we go to know about framework change. > > Migration of qspi drivers in u-boot-spi/drivers/mtd/spi-nor/ > git://git.denx.de/u-boot-spi.git branch mtd-spinor-working. > > > > We are in dilemma for sending FlexSPI driver upstream. > > Do we follow existing framework i.e. driver/spi or new proposed > framework i.e. u-boot-spi/drivers/mtd/spi-nor/ > > > > Also, do we have any timeline of > > u-boot-spi/drivers/mtd/spi-nor/ to > become default. > > Idea is to move spi-nor, mtd-spinor-working is paused because of > non-dm drivers accessing.
RFC patch
accordingly.
accordingly.
Yes.
HI Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Monday, May 21, 2018 8:36 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: u-boot@lists.denx.de Subject: Re: mtd: spi-nor: new NXP FlexSPI driver location & framework to use ?
Hi Jagan,
use ?
Dear Jagan,
Dear Jagan,
> -----Original Message----- > From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of > Prabhakar Kushwaha > Sent: Monday, May 14, 2018 6:55 PM > To: Jagan Teki jagannadh.teki@gmail.com > Cc: u-boot@lists.denx.de > Subject: Re: [U-Boot] mtd: spi-nor: new NXP FlexSPI driver > location & framework to use ? > > Thanks Jagan, > > > -----Original Message----- > > From: Jagan Teki [mailto:jagannadh.teki@gmail.com] > > Sent: Friday, May 11, 2018 11:31 AM > > To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com > > Cc: Jagan Teki jagan@amarulasolutions.com; York Sun > > york.sun@nxp.com; Yogesh Narayan Gaur > yogeshnarayan.gaur@nxp.com; > > Poonam Aggrwal poonam.aggrwal@nxp.com; Ashish Kumar > > ashish.kumar@nxp.com; u- boot@lists.denx.de > > Subject: Re: mtd: spi-nor: new NXP FlexSPI driver location & > > framework to use ? > > > > On Fri, May 11, 2018 at 11:08 AM, Prabhakar Kushwaha > > prabhakar.kushwaha@nxp.com wrote: > > > Dear Jagan, > > > > > > NXP is coming up with new FlexSPI controller. It is similar > > > to existing QSPI > > with enhanced feature-set. > > > We have the driver ready as per existing framework i.e.
driver/spi.
change.
> > > Migration of qspi drivers in > > > u-boot-spi/drivers/mtd/spi-nor/ > > git://git.denx.de/u-boot-spi.git branch mtd-spinor-working. > > > > > > We are in dilemma for sending FlexSPI driver upstream. > > > Do we follow existing framework i.e. driver/spi or new
proposed
> > framework i.e. u-boot-spi/drivers/mtd/spi-nor/ > > > > > > Also, do we have any timeline of > > > u-boot-spi/drivers/mtd/spi-nor/ to > > become default. > > > > Idea is to move spi-nor, mtd-spinor-working is paused because > > of non-dm drivers accessing. > > This means, flexspi controller driver should be upstream'ed via > u-boot- spi/drivers/mtd/spi-nor branch mtd-spinor-working >
upstream.
RFC patch
chw
ork.ozlabs.org%2Fpatch%2F894918%2F&data=02%7C01%7Cprabhakar.kushw ah
under
discussion.
accordingly.
accordingly.
Sorry for confusion.
I meant sending patch under driver/spi for flexSPI and wait for your repos to get matured
--pk
Ashish Kumar
Boris Brezillon
Jagan Teki
Prabhakar Kushwaha
