[U-Boot] [PATCH 1/3] arm: baltos: remove TI board leftover
Remove unneeded pinmux configurations and TI EEPROM struct.
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- board/vscom/baltos/board.c | 1 - board/vscom/baltos/board.h | 55 ------------------------------------ board/vscom/baltos/mux.c | 69 ---------------------------------------------- 3 files changed, 125 deletions(-)
diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index 27056e1..dbf79a5 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -415,7 +415,6 @@ int board_eth_init(bd_t *bis) int rv, n = 0; uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo; - __maybe_unused struct am335x_baseboard_id header;
/* * Note here that we're using CPSW1 since that has a 1Gbit PHY while diff --git a/board/vscom/baltos/board.h b/board/vscom/baltos/board.h index bcdb648..40ddd90 100644 --- a/board/vscom/baltos/board.h +++ b/board/vscom/baltos/board.h @@ -11,24 +11,6 @@ #ifndef _BOARD_H_ #define _BOARD_H_
-/* - * TI AM335x parts define a system EEPROM that defines certain sub-fields. - * We use these fields to in turn see what board we are on, and what - * that might require us to set or not set. - */ -#define HDR_NO_OF_MAC_ADDR 3 -#define HDR_ETH_ALEN 6 -#define HDR_NAME_LEN 8 - -struct am335x_baseboard_id { - unsigned int magic; - char name[HDR_NAME_LEN]; - char version[4]; - char serial[12]; - char config[32]; - char mac_addr[HDR_NO_OF_MAC_ADDR][HDR_ETH_ALEN]; -}; - typedef struct _BSP_VS_HWPARAM // v1.0 { uint32_t Magic; @@ -41,37 +23,6 @@ typedef struct _BSP_VS_HWPARAM // v1.0 uint8_t MAC3[6]; // WL1271 WLAN } __attribute__ ((packed)) BSP_VS_HWPARAM;
-static inline int board_is_bone(struct am335x_baseboard_id *header) -{ - return !strncmp(header->name, "A335BONE", HDR_NAME_LEN); -} - -static inline int board_is_bone_lt(struct am335x_baseboard_id *header) -{ - return !strncmp(header->name, "A335BNLT", HDR_NAME_LEN); -} - -static inline int board_is_evm_sk(struct am335x_baseboard_id *header) -{ - return !strncmp("A335X_SK", header->name, HDR_NAME_LEN); -} - -static inline int board_is_idk(struct am335x_baseboard_id *header) -{ - return !strncmp(header->config, "SKU#02", 6); -} - -static inline int board_is_gp_evm(struct am335x_baseboard_id *header) -{ - return !strncmp("A33515BB", header->name, HDR_NAME_LEN); -} - -static inline int board_is_evm_15_or_later(struct am335x_baseboard_id *header) -{ - return (board_is_gp_evm(header) && - strncmp("1.5", header->version, 3) <= 0); -} - /* * We have three pin mux functions that must exist. We must be able to enable * uart0, for initial output and i2c0 to read the main EEPROM. We then have a @@ -79,12 +30,6 @@ static inline int board_is_evm_15_or_later(struct am335x_baseboard_id *header) * is required on the board. */ void enable_uart0_pin_mux(void); -void enable_uart1_pin_mux(void); -void enable_uart2_pin_mux(void); -void enable_uart3_pin_mux(void); -void enable_uart4_pin_mux(void); -void enable_uart5_pin_mux(void); -void enable_i2c0_pin_mux(void); void enable_i2c1_pin_mux(void); void enable_board_pin_mux(void); #endif diff --git a/board/vscom/baltos/mux.c b/board/vscom/baltos/mux.c index 8783b25..94410ae 100644 --- a/board/vscom/baltos/mux.c +++ b/board/vscom/baltos/mux.c @@ -27,36 +27,6 @@ static struct module_pin_mux uart0_pin_mux[] = { {-1}, };
-static struct module_pin_mux uart1_pin_mux[] = { - {OFFSET(uart1_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_RXD */ - {OFFSET(uart1_txd), (MODE(0) | PULLUDEN)}, /* UART1_TXD */ - {-1}, -}; - -static struct module_pin_mux uart2_pin_mux[] = { - {OFFSET(spi0_sclk), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART2_RXD */ - {OFFSET(spi0_d0), (MODE(1) | PULLUDEN)}, /* UART2_TXD */ - {-1}, -}; - -static struct module_pin_mux uart3_pin_mux[] = { - {OFFSET(spi0_cs1), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART3_RXD */ - {OFFSET(ecap0_in_pwm0_out), (MODE(1) | PULLUDEN)}, /* UART3_TXD */ - {-1}, -}; - -static struct module_pin_mux uart4_pin_mux[] = { - {OFFSET(gpmc_wait0), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART4_RXD */ - {OFFSET(gpmc_wpn), (MODE(6) | PULLUDEN)}, /* UART4_TXD */ - {-1}, -}; - -static struct module_pin_mux uart5_pin_mux[] = { - {OFFSET(lcd_data9), (MODE(4) | PULLUP_EN | RXACTIVE)}, /* UART5_RXD */ - {OFFSET(lcd_data8), (MODE(4) | PULLUDEN)}, /* UART5_TXD */ - {-1}, -}; - static struct module_pin_mux mmc0_pin_mux[] = { {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ @@ -68,14 +38,6 @@ static struct module_pin_mux mmc0_pin_mux[] = { {-1}, };
-static struct module_pin_mux i2c0_pin_mux[] = { - {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | - PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ - {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | - PULLUDEN | SLEWCTRL)}, /* I2C_SCLK */ - {-1}, -}; - static struct module_pin_mux i2c1_pin_mux[] = { {OFFSET(spi0_d1), (MODE(2) | RXACTIVE | PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ @@ -144,36 +106,6 @@ void enable_uart0_pin_mux(void) configure_module_pin_mux(uart0_pin_mux); }
-void enable_uart1_pin_mux(void) -{ - configure_module_pin_mux(uart1_pin_mux); -} - -void enable_uart2_pin_mux(void) -{ - configure_module_pin_mux(uart2_pin_mux); -} - -void enable_uart3_pin_mux(void) -{ - configure_module_pin_mux(uart3_pin_mux); -} - -void enable_uart4_pin_mux(void) -{ - configure_module_pin_mux(uart4_pin_mux); -} - -void enable_uart5_pin_mux(void) -{ - configure_module_pin_mux(uart5_pin_mux); -} - -void enable_i2c0_pin_mux(void) -{ - configure_module_pin_mux(i2c0_pin_mux); -} - void enable_i2c1_pin_mux(void) { configure_module_pin_mux(i2c1_pin_mux); @@ -181,7 +113,6 @@ void enable_i2c1_pin_mux(void)
void enable_board_pin_mux() { - /* Baltos */ configure_module_pin_mux(i2c1_pin_mux); configure_module_pin_mux(gpio0_7_pin_mux); configure_module_pin_mux(rgmii2_pin_mux);
Baltos devices provide a mPCIe slot, whose power is turned off by default. This patch activates mPCIe slot in U-Boot, so that for example GSM modem can be already available in user space.
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- board/vscom/baltos/board.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index dbf79a5..d3b1f15 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -39,6 +39,7 @@ DECLARE_GLOBAL_DATA_PTR; /* GPIO that controls power to DDR on EVM-SK */ #define GPIO_DDR_VTT_EN 7 #define DIP_S1 44 +#define MPCIE_SW 100
static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
@@ -330,6 +331,11 @@ int ft_board_setup(void *blob, bd_t *bd) return 0; }
+static struct module_pin_mux pcie_sw_pin_mux[] = { + {OFFSET(mii1_rxdv), (MODE(7) | PULLUDEN )}, /* GPIO3_4 */ + {-1}, +}; + static struct module_pin_mux dip_pin_mux[] = { {OFFSET(gpmc_ad12), (MODE(7) | RXACTIVE )}, /* GPIO1_12 */ {OFFSET(gpmc_ad13), (MODE(7) | RXACTIVE )}, /* GPIO1_13 */ @@ -355,6 +361,18 @@ int board_late_init(void) baltos_set_console(); } } + + /* turn power for the mPCIe slot */ + configure_module_pin_mux(pcie_sw_pin_mux); + if (gpio_request(MPCIE_SW, "mpcie_sw")) { + printf("failed to export GPIO %d\n", MPCIE_SW); + return -ENODEV; + } + if (gpio_direction_output(MPCIE_SW, 1)) { + printf("failed to set GPIO %d direction\n", MPCIE_SW); + return -ENODEV; + } + setenv("board_name", model); #endif
First of all U-Boot would search for a USB mass storage device with either uEnv.txt or kernel-fit.itb and boot.
If USB mass storage device is not available or doesn't provide these files then MMC will be tried.
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- include/configs/baltos.h | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 8efd513..06f5ceb 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -102,7 +102,9 @@ "optargs=\0" \ "mmcdev=0\0" \ "mmcroot=/dev/mmcblk0p2 ro\0" \ + "usbroot=/dev/sda2 ro\0" \ "mmcrootfstype=ext4 rootwait\0" \ + "usbrootfstype=ext4 rootwait\0" \ "rootpath=/export/rootfs\0" \ "nfsopts=nolock\0" \ "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \ @@ -114,6 +116,11 @@ "${mtdparts} " \ "root=${mmcroot} " \ "rootfstype=${mmcrootfstype}\0" \ + "usbargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "${mtdparts} " \ + "root=${usbroot} " \ + "rootfstype=${usbrootfstype}\0" \ "spiroot=/dev/mtdblock4 rw\0" \ "spirootfstype=jffs2\0" \ "spisrcaddr=0xe0000\0" \ @@ -130,15 +137,25 @@ "ip=dhcp\0" \ "bootenv=uEnv.txt\0" \ "loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "usbloadbootenv=load usb 0:1 ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \ "env import -t $loadaddr $filesize\0" \ + "usbimportbootenv=echo Importing environment from USB ...; " \ + "env import -t $loadaddr $filesize\0" \ "ramargs=setenv bootargs console=${console} " \ "${optargs} " \ "root=${ramroot} " \ "rootfstype=${ramrootfstype}\0" \ "loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz\0" \ "loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ + "usbloadimage=load usb 0:1 ${loadaddr} kernel-fit.itb\0" \ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ + "usbloados=run usbargs; " \ + "bootm ${loadaddr}#conf${board_name}; " \ + "if test $? -ne 0; then " \ + "echo Using default FIT configuration; " \ + "bootm ${loadaddr}; " \ + "fi;\0" \ "mmcloados=run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ @@ -153,6 +170,21 @@ "else " \ "bootz; " \ "fi;\0" \ + "usbboot=usb reset; " \ + "if usb storage; then " \ + "echo USB drive found;" \ + "if run usbloadbootenv; then " \ + "echo Loaded environment from ${bootenv};" \ + "run usbimportbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run usbloadimage; then " \ + "run usbloados;" \ + "fi;" \ + "fi;\0" \ "mmcboot=mmc dev ${mmcdev}; " \ "if mmc rescan; then " \ "echo SD/MMC found on device ${mmcdev};" \ @@ -190,6 +222,7 @@
#define CONFIG_BOOTCOMMAND \ "run findfdt; " \ + "run usbboot;" \ "run mmcboot;" \ "setenv mmcdev 1; " \ "setenv bootpart 1:2; " \
