[U-Boot] [PATCH v1 0/5] imx6, display: enhancements for upcoming aristainetos DM support
some small enhancements for display support for the DM conversion of the aristainetos port.
Travis build: https://travis-ci.org/hsdenx/u-boot-test/builds/559790510
Heiko Schocher (5): global_data: enable fb_base for DM_VIDEO mxc_ipuv3_fb.c: set gd->fb_base bdinfo: show fb base with DM_VIDEO mxc_ipuv3_fb.c: call display_enable mxc_ipuv3_fb.c: enable a backlight on a panel
cmd/bdinfo.c | 2 +- drivers/video/imx/mxc_ipuv3_fb.c | 20 ++++++++++++++++++++ include/asm-generic/global_data.h | 2 +- 3 files changed, 22 insertions(+), 2 deletions(-)
with CONFIG_VIDEO we store fb base address in global data fb_base variable. Do this also in DM_VIDEO case.
Signed-off-by: Heiko Schocher hs@denx.de
include/asm-generic/global_data.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 02a3ed6838..11bbe9b134 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -33,7 +33,7 @@ typedef struct global_data { /* We cannot bracket this with CONFIG_PCI due to mpc5xxx */ unsigned long pci_clk; unsigned long mem_clk; -#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) +#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) || defined(CONFIG_DM_VIDEO) unsigned long fb_base; /* Base address of framebuffer mem */ #endif #if defined(CONFIG_POST)
set gd->fb_base so it can be shown with bdinfo command.
Signed-off-by: Heiko Schocher hs@denx.de ---
drivers/video/imx/mxc_ipuv3_fb.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index 29ecac40a2..cf672156cd 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -609,6 +609,7 @@ void *video_hw_init(void)
ret = mxcfb_probe(gpixfmt, gdisp, gmode); debug("Framebuffer at 0x%x\n", (unsigned int)panel.frameAdrs); + gd->fb_base = panel.frameAdrs;
return (void *)&panel; } @@ -665,6 +666,7 @@ static int ipuv3_video_probe(struct udevice *dev) mmu_set_region_dcache_behaviour(fb_start, fb_end - fb_start, DCACHE_WRITEBACK); video_set_flush_dcache(dev, true); + gd->fb_base = fb_start;
return 0; }
show Framebuffer base with CONFIG_DM_VIDEO enabled.
cmd/bdinfo.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index f576e226ee..86c17dc427 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -328,7 +328,7 @@ static int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, print_num("reloc off", gd->reloc_off); print_num("irq_sp", gd->irq_sp); /* irq stack pointer */ print_num("sp start ", gd->start_addr_sp); -#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) +#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) || defined(CONFIG_DM_VIDEO) print_num("FB base ", gd->fb_base); #endif /*
call display_enable, so a display gets enabled.
drivers/video/imx/mxc_ipuv3_fb.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index cf672156cd..aca76bd9cc 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -24,6 +24,7 @@ #include "ipu.h" #include "mxcfb.h" #include "ipu_regs.h" +#include "display.h"
#include <dm.h> #include <video.h> @@ -637,6 +638,9 @@ static int ipuv3_video_probe(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); struct video_priv *uc_priv = dev_get_uclass_priv(dev); +#if defined(CONFIG_DISPLAY) + struct udevice *disp_dev; +#endif u32 fb_start, fb_end; int ret;
@@ -655,6 +659,15 @@ static int ipuv3_video_probe(struct udevice *dev) if (ret < 0) return ret;
+#if defined(CONFIG_DISPLAY) + ret = uclass_first_device(UCLASS_DISPLAY, &disp_dev); + if (disp_dev) { + ret = display_enable(disp_dev, 16, NULL); + if (ret < 0) + return ret; + } +#endif + uc_priv->xsize = gmode->xres; uc_priv->ysize = gmode->yres; uc_priv->bpix = LCD_MAX_LOG2_BPP;
check if we get a panel device, if so, enable the backlight on it.
drivers/video/imx/mxc_ipuv3_fb.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index aca76bd9cc..c64be38e49 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -25,6 +25,7 @@ #include "mxcfb.h" #include "ipu_regs.h" #include "display.h" +#include <panel.h>
#include <dm.h> #include <video.h> @@ -641,6 +642,7 @@ static int ipuv3_video_probe(struct udevice *dev) #if defined(CONFIG_DISPLAY) struct udevice *disp_dev; #endif + struct udevice *panel_dev; u32 fb_start, fb_end; int ret;
@@ -667,6 +669,9 @@ static int ipuv3_video_probe(struct udevice *dev) return ret; } #endif + ret = uclass_get_device(UCLASS_PANEL, 0, &panel_dev); + if (panel_dev) + panel_enable_backlight(panel_dev);
Hi Heiko,
On Mon, 22 Jul 2019 06:49:03 +0200 Heiko Schocher hs@denx.de wrote: ...
Series applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Heiko Schocher
