[U-Boot] [PATCH 0/4] ARM: DRA7: emif: Miscellaneous bug fixes
This series fixes miscellaneous bugs for the emif driver.
Lokesh Vutla (4): ARM: DRA7: emif: Fix updating of refresh ctrl shadow ARM: DRA7: emif: Fix DDR init sequence during warm reset ARM: DRA7: emif: Check for enable bits before updating leveling output ARM: DRA7: emif: Enable interleaving for higher address space
arch/arm/cpu/armv7/omap-common/emif-common.c | 50 ++++++++++++++++++---------- arch/arm/cpu/armv7/omap5/sdram.c | 34 ++++++++++++++----- arch/arm/include/asm/emif.h | 9 +++++ 3 files changed, 67 insertions(+), 26 deletions(-)
On DRA7, refresh ctrl shadow should be updated with the final value.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index bf7bf26..90c241a 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -163,7 +163,11 @@ void emif_update_timings(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base;
- writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + if (!is_dra7xx()) + writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + else + writel(regs->ref_ctrl_final, &emif->emif_sdram_ref_ctrl_shdw); + writel(regs->sdram_tim1, &emif->emif_sdram_tim_1_shdw); writel(regs->sdram_tim2, &emif->emif_sdram_tim_2_shdw); writel(regs->sdram_tim3, &emif->emif_sdram_tim_3_shdw);
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Commit (20fae0a - ARM: DRA7: DDR: Enable SR in Power Management Control) enables Self refresh mode by default and during warm reset the EMIF contents are preserved. After warm reset EMIF sees that it is idle and puts DDR in self-refresh. When in SR, leveling operations cannot be done as DDR can only accept SR exit command, so its hanging during warm reset. In order to fix this reset the power management control register before EMIF initialization if it is a warm reset.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index 90c241a..6b33b45 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -327,8 +327,10 @@ static void dra7_ddr3_init(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base;
- if (warm_reset()) + if (warm_reset()) { emif_reset_phy(base); + writel(0x0, &emif->emif_pwr_mgmt_ctrl); + } do_ext_phy_settings(base, regs);
writel(regs->ref_ctrl | EMIF_REG_INITREF_DIS_MASK,
Read and write leveling can be enabled independently. Check for these enable bits before updating the read and write leveling output values. This will allow to use the combination of software and hardware leveling.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 38 ++++++++++++++++------------ arch/arm/cpu/armv7/omap5/sdram.c | 34 +++++++++++++++++++------ arch/arm/include/asm/emif.h | 6 +++++ 3 files changed, 54 insertions(+), 24 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index 6b33b45..3673884 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -250,33 +250,39 @@ static void update_hwleveling_output(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base; u32 *emif_ext_phy_ctrl_reg, *emif_phy_status; - u32 reg, i; + u32 reg, i, phy;
emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[7]; + phy = readl(&emif->emif_ddr_phy_ctrl_1);
/* Update PHY_REG_RDDQS_RATIO */ emif_ext_phy_ctrl_reg = (u32 *)&emif->emif_ddr_ext_phy_ctrl_7; - for (i = 0; i < PHY_RDDQS_RATIO_REGS; i++) { - reg = readl(emif_phy_status++); - writel(reg, emif_ext_phy_ctrl_reg++); - writel(reg, emif_ext_phy_ctrl_reg++); - } + if (!(phy & EMIF_DDR_PHY_CTRL_1_RDLVL_MASK_MASK)) + for (i = 0; i < PHY_RDDQS_RATIO_REGS; i++) { + reg = readl(emif_phy_status++); + writel(reg, emif_ext_phy_ctrl_reg++); + writel(reg, emif_ext_phy_ctrl_reg++); + }
/* Update PHY_REG_FIFO_WE_SLAVE_RATIO */ emif_ext_phy_ctrl_reg = (u32 *)&emif->emif_ddr_ext_phy_ctrl_2; - for (i = 0; i < PHY_FIFO_WE_SLAVE_RATIO_REGS; i++) { - reg = readl(emif_phy_status++); - writel(reg, emif_ext_phy_ctrl_reg++); - writel(reg, emif_ext_phy_ctrl_reg++); - } + emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[12]; + if (!(phy & EMIF_DDR_PHY_CTRL_1_RDLVLGATE_MASK_MASK)) + for (i = 0; i < PHY_FIFO_WE_SLAVE_RATIO_REGS; i++) { + reg = readl(emif_phy_status++); + writel(reg, emif_ext_phy_ctrl_reg++); + writel(reg, emif_ext_phy_ctrl_reg++); + }
/* Update PHY_REG_WR_DQ/DQS_SLAVE_RATIO */ emif_ext_phy_ctrl_reg = (u32 *)&emif->emif_ddr_ext_phy_ctrl_12; - for (i = 0; i < PHY_REG_WR_DQ_SLAVE_RATIO_REGS; i++) { - reg = readl(emif_phy_status++); - writel(reg, emif_ext_phy_ctrl_reg++); - writel(reg, emif_ext_phy_ctrl_reg++); - } + emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[17]; + if (!(phy & EMIF_DDR_PHY_CTRL_1_WRLVL_MASK_MASK)) + for (i = 0; i < PHY_REG_WR_DQ_SLAVE_RATIO_REGS; i++) { + reg = readl(emif_phy_status++); + writel(reg, emif_ext_phy_ctrl_reg++); + writel(reg, emif_ext_phy_ctrl_reg++); + }
/* Disable Leveling */ writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1); diff --git a/arch/arm/cpu/armv7/omap5/sdram.c b/arch/arm/cpu/armv7/omap5/sdram.c index a8d63c2..c386e64 100644 --- a/arch/arm/cpu/armv7/omap5/sdram.c +++ b/arch/arm/cpu/armv7/omap5/sdram.c @@ -643,11 +643,12 @@ static void do_ext_phy_settings_dra7(u32 base, const struct emif_regs *regs) u32 *emif_ext_phy_ctrl_base = 0; u32 emif_nr; const u32 *ext_phy_ctrl_const_regs; - u32 i, hw_leveling, size; + u32 i, hw_leveling, size, phy;
emif_nr = (base == EMIF1_BASE) ? 1 : 2;
hw_leveling = regs->emif_rd_wr_lvl_rmp_ctl >> EMIF_REG_RDWRLVL_EN_SHIFT; + phy = regs->emif_ddr_phy_ctlr_1_init;
emif_ext_phy_ctrl_base = (u32 *)&(emif->emif_ddr_ext_phy_ctrl_1);
@@ -657,18 +658,35 @@ static void do_ext_phy_settings_dra7(u32 base, const struct emif_regs *regs) writel(ext_phy_ctrl_const_regs[0], &emif_ext_phy_ctrl_base[0]); writel(ext_phy_ctrl_const_regs[0], &emif_ext_phy_ctrl_base[1]);
- if (!hw_leveling) { - /* - * Copy the predefined PHY register values - * in case of sw leveling - */ - for (i = 1; i < 25; i++) { + /* + * Copy the predefined PHY register values + * if leveling is disabled. + */ + if (phy & EMIF_DDR_PHY_CTRL_1_RDLVLGATE_MASK_MASK) + for (i = 1; i < 6; i++) { writel(ext_phy_ctrl_const_regs[i], &emif_ext_phy_ctrl_base[i * 2]); writel(ext_phy_ctrl_const_regs[i], &emif_ext_phy_ctrl_base[i * 2 + 1]); } - } else { + + if (phy & EMIF_DDR_PHY_CTRL_1_RDLVL_MASK_MASK) + for (i = 6; i < 11; i++) { + writel(ext_phy_ctrl_const_regs[i], + &emif_ext_phy_ctrl_base[i * 2]); + writel(ext_phy_ctrl_const_regs[i], + &emif_ext_phy_ctrl_base[i * 2 + 1]); + } + + if (phy & EMIF_DDR_PHY_CTRL_1_WRLVL_MASK_MASK) + for (i = 11; i < 25; i++) { + writel(ext_phy_ctrl_const_regs[i], + &emif_ext_phy_ctrl_base[i * 2]); + writel(ext_phy_ctrl_const_regs[i], + &emif_ext_phy_ctrl_base[i * 2 + 1]); + } + + if (hw_leveling) { /* * Write the init value for HW levling to occur */ diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index 7986e6e..b03cf5a 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -478,6 +478,12 @@ #define EMIF_REG_DLL_SLAVE_DLY_CTRL_SHDW_MASK (0xFF << 4) #define EMIF_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_SHIFT 12 #define EMIF_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_MASK (0xFFFFF << 12) +#define EMIF_DDR_PHY_CTRL_1_WRLVL_MASK_SHIFT 25 +#define EMIF_DDR_PHY_CTRL_1_WRLVL_MASK_MASK (1 << 25) +#define EMIF_DDR_PHY_CTRL_1_RDLVLGATE_MASK_SHIFT 26 +#define EMIF_DDR_PHY_CTRL_1_RDLVLGATE_MASK_MASK (1 << 26) +#define EMIF_DDR_PHY_CTRL_1_RDLVL_MASK_SHIFT 27 +#define EMIF_DDR_PHY_CTRL_1_RDLVL_MASK_MASK (1 << 27)
/* DDR_PHY_CTRL_2 */ #define EMIF_REG_DDR_PHY_CTRL_2_SHIFT 0
Given that DRA7/OMAP5 SoCs can support more than 2GB of memory, enable interleaving for this higher memory to increase performance.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 2 ++ arch/arm/include/asm/emif.h | 3 +++ 2 files changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index 3673884..697d6e0 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -1329,6 +1329,8 @@ void dmm_init(u32 base) &hw_lisa_map_regs->dmm_lisa_map_1); writel(lisa_map_regs->dmm_lisa_map_0, &hw_lisa_map_regs->dmm_lisa_map_0); + + setbits_le32(MA_PRIORITY, MA_HIMEM_INTERLEAVE_UN_MASK); }
/* diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index b03cf5a..3183130 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -545,6 +545,9 @@
/* Memory Adapter */ #define MA_BASE 0x482AF040 +#define MA_PRIORITY 0x482A2000 +#define MA_HIMEM_INTERLEAVE_UN_SHIFT 8 +#define MA_HIMEM_INTERLEAVE_UN_MASK (1 << 8)
/* DMM_LISA_MAP */ #define EMIF_SYS_ADDR_SHIFT 24
Note that my board is still unable to boot from mainline with these applied but still works with the TI vendor tree.
Hmm..I guess you are talking about DRA72-evm. SPL even doesn't come up or U-boot is failing. Can I see the logs? And what switch settings are you using?(Ill try to reproduce in my place)
Thanks and regards, Lokesh
SPL doesn't even come up so no output. SD card boot settings. I can send you SW2/SW3/SW5 off-list in a bit.
Lokesh Vutla
Lokesh Vutla
