[U-Boot] [PATCH-OMAP3 v2] OMAP3: Fix typo and cp_delay
Fix typo and cp_delay.
Note that most of ARM code uses for-loop as cp_delay() implementation. Scott Wood made some tests and volatile prevents gcc from optimizing loop away, so this implemention should be fine. For OMAP some nops are sufficent, though.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Changes in v2:
- Correct patch header style.
v2 of this patch makes previous version v1 obsolete.
cpu/arm_cortexa8/cpu.c | 5 ++--- cpu/arm_cortexa8/start.S | 2 +- 2 files changed, 3 insertions(+), 4 deletions(-)
Index: u-boot-arm/cpu/arm_cortexa8/start.S =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/start.S +++ u-boot-arm/cpu/arm_cortexa8/start.S @@ -394,7 +394,7 @@ irq: .align 5 fiq: get_fiq_stack - /* someone ought to write a more effiction fiq_save_user_regs */ + /* someone ought to write a more effective fiq_save_user_regs */ irq_save_user_regs bl do_fiq irq_restore_user_regs Index: u-boot-arm/cpu/arm_cortexa8/cpu.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/cpu.c +++ u-boot-arm/cpu/arm_cortexa8/cpu.c @@ -68,10 +68,9 @@ static void write_p15_c1(unsigned long v
static void cp_delay(void) { - volatile int i; - /* Many OMAP regs need at least 2 nops */ - for (i = 0; i < 100; i++) ; + asm("nop"); + asm("nop"); }
/* See also ARM Ref. Man. */
Changes in v2:
apply to u-boot-arm/omap3
dirk.behmeï¼ googlemail.com
Jean-Christophe PLAGNIOL-VILLARD
