[PATCH v4 1/2] board/km/cent2: add include common.h
From: Christian Taedcke christian.taedcke@weidmueller.com
Including common.h before event.h is required, because the new fpga load event in event.h uses the size_t type.
Signed-off-by: Christian Taedcke christian.taedcke@weidmueller.com ---
Changes in v4: - add include common.h to kmcent2 board file
board/keymile/kmcent2/kmcent2.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/keymile/kmcent2/kmcent2.c b/board/keymile/kmcent2/kmcent2.c index ed552c57b5..6dbaaa5457 100644 --- a/board/keymile/kmcent2/kmcent2.c +++ b/board/keymile/kmcent2/kmcent2.c @@ -6,6 +6,7 @@ * Copyright 2013 Freescale Semiconductor, Inc. */
+#include <common.h> #include <event.h> #include <asm/cache.h> #include <asm/fsl_fdt.h>
This enables implementing custom logic after a bitstream was loaded into the fpga.
Signed-off-by: Christian Taedcke christian.taedcke@weidmueller.com Reviewed-by: Simon Glass sjg@chromium.org ---
(no changes since v3)
Changes in v3: - replace #if with if - remove previously added printf - return notification error from fpga_load() - fix static_assert checking event name list
Changes in v2: - replace __weak function with a new event
common/event.c | 3 +++ drivers/fpga/fpga.c | 20 ++++++++++++++++++++ include/event.h | 16 ++++++++++++++++ 3 files changed, 39 insertions(+)
diff --git a/common/event.c b/common/event.c index 164c95f8f5..20720c5283 100644 --- a/common/event.c +++ b/common/event.c @@ -36,6 +36,9 @@ const char *const type_name[] = { /* init hooks */ "misc_init_f",
+ /* Fpga load hook */ + "fpga_load", + /* fdt hooks */ "ft_fixup",
diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index 7f6b6bc73a..81e6d8ffc0 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -244,6 +244,21 @@ int fpga_loads(int devnum, const void *buf, size_t size, } #endif
+static int fpga_load_event_notify(const void *buf, size_t bsize, int result) +{ + if (CONFIG_IS_ENABLED(EVENT)) { + struct event_fpga_load load = { + .buf = buf, + .bsize = bsize, + .result = result + }; + + return event_notify(EVT_FPGA_LOAD, &load, sizeof(load)); + } + + return 0; +} + /* * Generic multiplexing code */ @@ -251,6 +266,7 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype, int flags) { int ret_val = FPGA_FAIL; /* assume failure */ + int ret_notify; const fpga_desc *desc = fpga_validate(devnum, buf, bsize, (char *)__func__);
@@ -284,6 +300,10 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype, } }
+ ret_notify = fpga_load_event_notify(buf, bsize, ret_val); + if (ret_notify) + return ret_notify; + return ret_val; }
diff --git a/include/event.h b/include/event.h index fe41080fa6..77124c2e73 100644 --- a/include/event.h +++ b/include/event.h @@ -31,6 +31,9 @@ enum event_t { /* Init hooks */ EVT_MISC_INIT_F,
+ /* Fpga load hook */ + EVT_FPGA_LOAD, + /* Device tree fixups before booting */ EVT_FT_FIXUP,
@@ -59,6 +62,19 @@ union event_data { struct udevice *dev; } dm;
+ /** + * struct event_fpga_load - fpga load event + * + * @buf: The buffer that was loaded into the fpga + * @bsize: The size of the buffer that was loaded into the fpga + * @result: Result of the load operation + */ + struct event_fpga_load { + const void *buf; + size_t bsize; + int result; + } fpga_load; + /** * struct event_ft_fixup - FDT fixup before booting *
On Wed, Jul 19, 2023 at 03:45:44PM +0200, christian.taedcke-oss@weidmueller.com wrote:
[snip]
- /* Fpga load hook */
- EVT_FPGA_LOAD,
- /* Device tree fixups before booting */ EVT_FT_FIXUP,
- struct event_fpga_load {
const void *buf;
size_t bsize;
int result;
- } fpga_load;
- struct event_ft_fixup - FDT fixup before booting
Since here is where you're introducing a size_t to event.h, here is where you also need to add <linux/types.h> to event.h
Changes in v4:
This is fine, but really we should fix event.h
- Copyright 2013 Freescale Semiconductor, Inc.
2.34.1
On Wed, Jul 19, 2023 at 03:45:43PM +0200, christian.taedcke-oss@weidmueller.com wrote:
Changes in v4:
No, we aren't adding common.h to more files. What in event.h needs some other part of common.h that it's not getting today? common.h has nothing more in it than other includes.
