[U-Boot] [PATCH] x86: acpi: Fix build error with certain configuration
When CONFIG_EFI_PARTITION is not set, the following build error is seen in arch/x86/lib/acpi_s3.c:
error: expected declaration specifiers or '...' before '*' token static void asmlinkage (*acpi_do_wakeup)(void *vector) = (void*)WAKEUP_BASE;
This is actually caused by missing asmlinkage declaration, but with CONFIG_EFI_PARTITION on, the declaration comes from part.h which is included from common.h.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/lib/acpi_s3.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/lib/acpi_s3.c b/arch/x86/lib/acpi_s3.c index 3175da8..182379b 100644 --- a/arch/x86/lib/acpi_s3.c +++ b/arch/x86/lib/acpi_s3.c @@ -8,6 +8,7 @@ #include <asm/acpi_s3.h> #include <asm/acpi_table.h> #include <asm/post.h> +#include <linux/linkage.h>
DECLARE_GLOBAL_DATA_PTR;
Thanks, Stefan
diff --git a/arch/x86/lib/acpi_s3.c b/arch/x86/lib/acpi_s3.c index 3175da8..182379b 100644 --- a/arch/x86/lib/acpi_s3.c +++ b/arch/x86/lib/acpi_s3.c @@ -8,6 +8,7 @@ #include <asm/acpi_s3.h> #include <asm/acpi_table.h> #include <asm/post.h> +#include <linux/linkage.h> DECLARE_GLOBAL_DATA_PTR;
applied to u-boot-x86, thanks!
Bin Meng
Stefan Roese
