[U-Boot] Enabling POST for canyonlands board
Hi, Is the Power On Self Test enabled for the canyonlands board? What I want to know is whether I need to set any macro while compiling, to enable POST. I saw that there are some hot keys defined to start POST for certain boards. Is there anything defined like that for canyonlands board.How do I start the POST. Thanks in advance. Regards, Afzal Nadirshah
________________________________ http://www.mindtree.com/email/disclaimer.html
Hi Afzal,
A quick look at the canyonlands config header shows that it's not enabled.
What I
Yes. I suggest you take a look at the kilauea.h header. Here POST is enabled by default.
Some POST tests are run always after poweron, and some (longer) tests are only run under certain conditions. doc/README.POST should give you an overview here.
Best regards, Stefan
Afzal Nadirshah
Stefan Roese
