[PATCH v2 0/2] mtd: nand: omap_gpmc: Fix NAND for AM335x
These patches fix NAND and ELM for AM335x and related legacy platforms that use HW BCH and ELM modules.
All CI tests pass: https://github.com/u-boot/u-boot/pull/453
Changelog:
v2: - added __maybe_unused to omap_calculate_ecc_bch. fixes CI tests - Added Tested-by Tags - Explained about omap_elm single sector support in commit log
cheers, -roger
Roger Quadros (2): mtd: nand: omap_gpmc: Fix NAND in SPL for AM335x mtd: rawnand: omap_elm: Fix elm_init definition
drivers/mtd/nand/raw/omap_elm.c | 4 +- drivers/mtd/nand/raw/omap_elm.h | 6 -- drivers/mtd/nand/raw/omap_gpmc.c | 95 ++++++++++---------------------- 3 files changed, 31 insertions(+), 74 deletions(-)
base-commit: 2f0282922b2c458eea7f85c500a948a587437b63
AM335x uses a special driver "am335x_spl_bch.c" as SPL NAND loader. This driver expects 1 sector at a time ECC and doesn't work well with multi-sector ECC that was implemented in commit 04fcd2587321 ("mtd: rawnand: omap_gpmc: Fix BCH6/16 HW based correction")
Additionally, the omap_elm driver does not support multi sector ECC and will need more work and tests to get multi sector working correctly on all platforms.
Switch back to 1 sector at a time read/ECC.
Fixes: 04fcd2587321 ("mtd: rawnand: omap_gpmc: Fix BCH6/16 HW based correction") Signed-off-by: Roger Quadros rogerq@kernel.org Tested-by: Enrico Leto enrico.leto@siemens.com Tested-by: Heiko Schocher hs@denx.de --- drivers/mtd/nand/raw/omap_gpmc.c | 95 ++++++++++---------------------- 1 file changed, 29 insertions(+), 66 deletions(-)
diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index 1a5ed0de31..7345fd579b 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -293,7 +293,7 @@ static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, break; case OMAP_ECC_BCH8_CODE_HW: bch_type = 1; - nsectors = chip->ecc.steps; + nsectors = 1; if (mode == NAND_ECC_READ) { wr_mode = BCH_WRAPMODE_1; ecc_size0 = BCH8R_ECC_SIZE0; @@ -306,7 +306,7 @@ static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, break; case OMAP_ECC_BCH16_CODE_HW: bch_type = 0x2; - nsectors = chip->ecc.steps; + nsectors = 1; if (mode == NAND_ECC_READ) { wr_mode = 0x01; ecc_size0 = 52; /* ECC bits in nibbles per sector */ @@ -345,17 +345,16 @@ static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, }
/** - * _omap_calculate_ecc_bch - Generate BCH ECC bytes for one sector + * omap_calculate_ecc_bch - Generate BCH ECC bytes for one sector * @mtd: MTD device structure * @dat: The pointer to data on which ecc is computed * @ecc_code: The ecc_code buffer - * @sector: The sector number (for a multi sector page) * * Support calculating of BCH4/8/16 ECC vectors for one sector * within a page. Sector number is in @sector. */ -static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, - u8 *ecc_code, int sector) +static int __maybe_unused omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, + u8 *ecc_code) { struct nand_chip *chip = mtd_to_nand(mtd); struct omap_nand_info *info = nand_get_controller_data(chip); @@ -368,7 +367,7 @@ static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, case OMAP_ECC_BCH8_CODE_HW_DETECTION_SW: #endif case OMAP_ECC_BCH8_CODE_HW: - ptr = &gpmc_cfg->bch_result_0_3[sector].bch_result_x[3]; + ptr = &gpmc_cfg->bch_result_0_3[0].bch_result_x[3]; val = readl(ptr); ecc_code[i++] = (val >> 0) & 0xFF; ptr--; @@ -383,21 +382,21 @@ static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat,
break; case OMAP_ECC_BCH16_CODE_HW: - val = readl(&gpmc_cfg->bch_result_4_6[sector].bch_result_x[2]); + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[2]); ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; - val = readl(&gpmc_cfg->bch_result_4_6[sector].bch_result_x[1]); + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[1]); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; - val = readl(&gpmc_cfg->bch_result_4_6[sector].bch_result_x[0]); + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[0]); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; for (j = 3; j >= 0; j--) { - val = readl(&gpmc_cfg->bch_result_0_3[sector].bch_result_x[j] + val = readl(&gpmc_cfg->bch_result_0_3[0].bch_result_x[j] ); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; @@ -431,22 +430,6 @@ static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, return 0; }
-/** - * omap_calculate_ecc_bch - ECC generator for 1 sector - * @mtd: MTD device structure - * @dat: The pointer to data on which ecc is computed - * @ecc_code: The ecc_code buffer - * - * Support calculating of BCH4/8/16 ECC vectors for one sector. This is used - * when SW based correction is required as ECC is required for one sector - * at a time. - */ -static int __maybe_unused omap_calculate_ecc_bch(struct mtd_info *mtd, - const u_char *dat, u_char *ecc_calc) -{ - return _omap_calculate_ecc_bch(mtd, dat, ecc_calc, 0); -} - static inline void omap_nand_read_buf(struct mtd_info *mtd, uint8_t *buf, int len) { struct nand_chip *chip = mtd_to_nand(mtd); @@ -572,34 +555,6 @@ static void omap_nand_read_prefetch(struct mtd_info *mtd, uint8_t *buf, int len)
#ifdef CONFIG_NAND_OMAP_ELM
-/** - * omap_calculate_ecc_bch_multi - Generate ECC for multiple sectors - * @mtd: MTD device structure - * @dat: The pointer to data on which ecc is computed - * @ecc_code: The ecc_code buffer - * - * Support calculating of BCH4/8/16 ecc vectors for the entire page in one go. - */ -static int omap_calculate_ecc_bch_multi(struct mtd_info *mtd, - const u_char *dat, u_char *ecc_calc) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - int eccbytes = chip->ecc.bytes; - unsigned long nsectors; - int i, ret; - - nsectors = ((readl(&gpmc_cfg->ecc_config) >> 4) & 0x7) + 1; - for (i = 0; i < nsectors; i++) { - ret = _omap_calculate_ecc_bch(mtd, dat, ecc_calc, i); - if (ret) - return ret; - - ecc_calc += eccbytes; - } - - return 0; -} - /* * omap_reverse_list - re-orders list elements in reverse order [internal] * @list: pointer to start of list @@ -752,7 +707,6 @@ static int omap_read_page_bch(struct mtd_info *mtd, struct nand_chip *chip, { int i, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; - int ecctotal = chip->ecc.total; int eccsteps = chip->ecc.steps; uint8_t *p = buf; uint8_t *ecc_calc = chip->buffers->ecccalc; @@ -760,24 +714,30 @@ static int omap_read_page_bch(struct mtd_info *mtd, struct nand_chip *chip, uint32_t *eccpos = chip->ecc.layout->eccpos; uint8_t *oob = chip->oob_poi; uint32_t oob_pos; + u32 data_pos = 0;
/* oob area start */ oob_pos = (eccsize * eccsteps) + chip->ecc.layout->eccpos[0]; oob += chip->ecc.layout->eccpos[0];
- /* Enable ECC engine */ - chip->ecc.hwctl(mtd, NAND_ECC_READ); + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize, + oob += eccbytes) { + /* Enable ECC engine */ + chip->ecc.hwctl(mtd, NAND_ECC_READ);
- /* read entire page */ - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, 0, -1); - chip->read_buf(mtd, buf, mtd->writesize); + /* read data */ + chip->cmdfunc(mtd, NAND_CMD_RNDOUT, data_pos, -1); + chip->read_buf(mtd, p, eccsize);
- /* read all ecc bytes from oob area */ - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, oob_pos, -1); - chip->read_buf(mtd, oob, ecctotal); + /* read respective ecc from oob area */ + chip->cmdfunc(mtd, NAND_CMD_RNDOUT, oob_pos, -1); + chip->read_buf(mtd, oob, eccbytes); + /* read syndrome */ + chip->ecc.calculate(mtd, p, &ecc_calc[i]);
- /* Calculate ecc bytes */ - omap_calculate_ecc_bch_multi(mtd, buf, ecc_calc); + data_pos += eccsize; + oob_pos += eccbytes; + }
for (i = 0; i < chip->ecc.total; i++) ecc_code[i] = chip->oob_poi[eccpos[i]]; @@ -945,6 +905,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.hwctl = omap_enable_hwecc_bch; nand->ecc.correct = omap_correct_data_bch_sw; nand->ecc.calculate = omap_calculate_ecc_bch; + nand->ecc.steps = eccsteps; /* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; ecclayout->eccpos[0] = BADBLOCK_MARKER_LENGTH; @@ -987,6 +948,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; nand->ecc.read_page = omap_read_page_bch; + nand->ecc.steps = eccsteps; /* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; for (i = 0; i < ecclayout->eccbytes; i++) @@ -1020,6 +982,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; nand->ecc.read_page = omap_read_page_bch; + nand->ecc.steps = eccsteps; /* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; for (i = 0; i < ecclayout->eccbytes; i++)
The macro ELM_BASE is defined in mach/hardware.h and is not visible at the omap_elm.h header file. Avoid using it in omap_elm.h.
Reported-by: Hong Guan hguan@ti.com Fixes: 7363cf0581a3 ("mtd: rawnand: omap_elm: u-boot driver model support") Signed-off-by: Roger Quadros rogerq@kernel.org --- drivers/mtd/nand/raw/omap_elm.c | 4 ++-- drivers/mtd/nand/raw/omap_elm.h | 6 ------ 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/nand/raw/omap_elm.c b/drivers/mtd/nand/raw/omap_elm.c index 56a2c39e4f..015ec9bc2d 100644 --- a/drivers/mtd/nand/raw/omap_elm.c +++ b/drivers/mtd/nand/raw/omap_elm.c @@ -185,7 +185,6 @@ void elm_reset(void) ; }
-#ifdef ELM_BASE /** * elm_init - Initialize ELM module * @@ -194,10 +193,11 @@ void elm_reset(void) */ void elm_init(void) { +#ifdef ELM_BASE elm_cfg = (struct elm *)ELM_BASE; elm_reset(); -} #endif +}
#if CONFIG_IS_ENABLED(SYS_NAND_SELF_INIT)
diff --git a/drivers/mtd/nand/raw/omap_elm.h b/drivers/mtd/nand/raw/omap_elm.h index a7f7bacb15..f3db00d55d 100644 --- a/drivers/mtd/nand/raw/omap_elm.h +++ b/drivers/mtd/nand/raw/omap_elm.h @@ -74,12 +74,6 @@ int elm_check_error(u8 *syndrome, enum bch_level bch_type, u32 *error_count, u32 *error_locations); int elm_config(enum bch_level level); void elm_reset(void); -#ifdef ELM_BASE void elm_init(void); -#else -static inline void elm_init(void) -{ -} -#endif #endif /* __ASSEMBLY__ */ #endif /* __ASM_ARCH_ELM_H */
Changelog:
v2:
cheers, -roger
If no objections can this be Acked and picked up please? Without these NAND is broken on some TI platforms.
Thanks!
Hi
Changelog:
v2:
cheers, -roger
We will queue them and send over the weekend
Michael
Thanks!
-- cheers, -roger
Hi Roger And Michael,
On Thu, Jan 11, 2024 at 2:13 PM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Changelog:
v2:
cheers, -roger
Michael
Thanks!
-- cheers, -roger
Applied to nand-next.
Thanks and regards, Dario
Dario Binacchi
Roger Quadros
