[PATCH v3] Fix flashing of eMMC user area with Fastboot
'gpt' and 'mmc0' fastboot partitions have been treated as the same device, but it is wrong.
Signed-off-by: Oleh Kravchenko oleg@kaa.org.ua Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Marek Vasut marex@denx.de --- Changes for v2: - code cleanup; Changes for v3: - QA passed at https://github.com/u-boot/u-boot/pull/75;
drivers/fastboot/fb_mmc.c | 25 ++++++++++++++++++++----- 1 file changed, 20 insertions(+), 5 deletions(-)
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index 2f3837e559..647d3f6c1b 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -532,12 +532,7 @@ void fastboot_mmc_flash_write(const char *cmd, void *download_buffer, #endif
#if CONFIG_IS_ENABLED(EFI_PARTITION) -#ifndef CONFIG_FASTBOOT_MMC_USER_SUPPORT if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0) { -#else - if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0 || - strcmp(cmd, CONFIG_FASTBOOT_MMC_USER_NAME) == 0) { -#endif dev_desc = fastboot_mmc_get_dev(response); if (!dev_desc) return; @@ -599,9 +594,29 @@ void fastboot_mmc_flash_write(const char *cmd, void *download_buffer, } #endif
+#if CONFIG_IS_ENABLED(FASTBOOT_MMC_USER_SUPPORT) + if (strcmp(cmd, CONFIG_FASTBOOT_MMC_USER_NAME) == 0) { + dev_desc = fastboot_mmc_get_dev(response); + if (!dev_desc) + return; + + memset(&info, 0, sizeof(info)); + info.start = 0; + info.size = dev_desc->lba; + info.blksz = dev_desc->blksz; + strlcpy((char *)&info.name, cmd, sizeof(info.name)); + + goto write_image; + } +#endif + if (fastboot_mmc_get_part_info(cmd, &dev_desc, &info, response) < 0) return;
+#if CONFIG_IS_ENABLED(FASTBOOT_MMC_USER_SUPPORT) +write_image: +#endif + if (is_sparse_image(download_buffer)) { struct fb_mmc_sparse sparse_priv; struct sparse_storage sparse;
Hello guys, Could you please review and merge this patch?
PR successfully passed CI: https://github.com/u-boot/u-boot/pull/75
15.05.21 00:15, Oleh Kravchenko пише:
Changes for v2:
- code cleanup;
Changes for v3:
- if (strcmp(cmd, CONFIG_FASTBOOT_MMC_USER_NAME) == 0) {
if (!dev_desc)
return;
info.start = 0;
goto write_image;
- if (fastboot_mmc_get_part_info(cmd, &dev_desc, &info, response) < 0) return;
- if (is_sparse_image(download_buffer)) { struct fb_mmc_sparse sparse_priv; struct sparse_storage sparse;
Did you have any luck with the second suggestion [1] I made for your original patch?
[1] https://lists.denx.de/pipermail/u-boot/2021-May/449778.html
--Sean
Is it possible to use
if (CONFIG_IS_ENABLED(...)) { ... }
here?
if (!dev_desc)
return;
info.start = 0;
goto write_image;
Why do we need to skip get_part_info?
Is conditionally defining this label necessary?
--Sean
Hello Sean, Could you please clarify what you have mean?
I think you pointing to this?
fastboot_raw_partition_<raw partition name>=<offset> <size> [mmcpart <num>]
Because I don't have idea how aliases will help to flash.
15.05.21 00:45, Sean Anderson пише:
--Sean
here?
+ goto write_image;
+ } +#endif
--Sean
No, specifically I was requesting that you try "fastboot flash 0.1:0 foo.img" (or 1.1:0 depending on your mmc). And please send me the failing output from the U-Boot side.
(and please address the comments inline below as well)
--Sean
--Sean
here?
if (!dev_desc)
return;
info.start = 0;
goto write_image;
--Sean
This one works "0:0"
linux> fastboot flash 0:0 core-image-minimal.wic linux> target reported max download size of 419430400 bytes linux> Sending '0:0' (402048 KB)... linux> OKAY [ 12.613s] linux> Writing '0:0'... linux> OKAY [ 30.204s] linux> Finished. Total time: 42.842s
u-boot> ** Bad partition specification mmc 0:0_a ** u-boot> Couldn't find partition mmc 0:0_a u-boot> ** Unrecognized filesystem type ** u-boot> Starting download of 411697152 bytes u-boot> downloading of 411697152 bytes finished u-boot> Flashing Raw Image u-boot> ........ wrote 411697152 bytes to '0:0'
15.05.21 01:26, Sean Anderson пише:
--Sean
--Sean
here?
+ goto write_image;
+ } +#endif
--Sean
Hm,
So next mapping works: 0.0:0 mmc0 user area 0.1:0 mmc0 boot 1 0.2:0 mmc0 boot 2
linux> $ fastboot erase 0.1:0 linux> Erasing '0.1:0'... linux> OKAY [ 2.969s] linux> Finished. Total time: 2.990s linux> $ fastboot erase 0.2:0 linux> Erasing '0.2:0'... linux> OKAY [ 2.962s] linux> Finished. Total time: 2.985s linux> $ fastboot erase 0.0:0 linux> Erasing '0.0:0'... linux> OKAY [ 48.224s] linux> Finished. Total time: 48.239s
linux> $ fastboot flash -raw2sparse 0.0:0 core-image-minimal.wic linux> target reported max download size of 268435456 bytes linux> Invalid sparse file format at header magic linux> Sending sparse '0.0:0' 1/1 (221985 KB)... linux> OKAY [ 7.301s] linux> Writing '0.0:0' 1/1... linux> OKAY [ 31.904s] linux> Finished. Total time: 39.298s linux> $ fastboot flash -raw2sparse 0.1:0 u-boot.bin linux> target reported max download size of 268435456 bytes linux> Sending '0.1:0' (440 KB)... linux> OKAY [ 0.020s] linux> Writing '0.1:0'... linux> OKAY [ 0.113s] linux> Finished. Total time: 0.166s linux> $ fastboot flash -raw2sparse 0.2:0 u-boot.bin linux> target reported max download size of 268435456 bytes linux> Sending '0.2:0' (440 KB)... linux> OKAY [ 0.020s] linux> Writing '0.2:0'... linux> OKAY [ 0.113s] linux> Finished. Total time: 0.168s
15.05.21 01:34, Oleh Kravchenko пише:
--Sean
--Sean
here?
+ goto write_image;
+ } +#endif
--Sean
Hello Sean, Please see my comments below:
15.05.21 01:10, Oleh Kravchenko пише:
--Sean
Hey, I've just tested these:
uboot> setenv fastboot_raw_partition_user '0 3850371072 mmcpart 0' uboot> setenv fastboot_raw_partition_boot0 '0 16777216 mmcpart 1' uboot> setenv fastboot_raw_partition_boot1 '0 16777216 mmcpart 2'
linux> fastboot flash core-image-minimal.wic linux> fastboot flash boot0 u-boot.bin linux> fastboot flash boot1 u-boot.bin
And it works!
-- Oleh
here?
No, It will cause an error where CONFIG_FASTBOOT_MMC_USER_NAME not defined.
-- Oleh
+ goto write_image;
fastboot_mmc_get_part_info() doesn't check for CONFIG_FASTBOOT_MMC_USER_NAME.
+ } +#endif
--Sean
Yes, in other case some configuration causes error goto label is not used.
-- Oleh
Any updates on these?
15.05.21 00:26, Oleh Kravchenko пише:
Changes for v2:
- code cleanup;
Changes for v3:
if (!dev_desc)
return;
info.start = 0;
goto write_image;
Sorry, my reading of what you and Sean were saying left me with the impression no code changes were needed in the end, is that not the case?
Changes for v2:
- code cleanup;
Changes for v3:
if (!dev_desc)
return;
info.start = 0;
goto write_image;
Hello Tom,
18.05.21 15:21, Tom Rini пише:
Sean has proposed to flash and erase by mapping through 0.0:0 (user), 0.1:0 (boot0), 0.2:0 (boot1). This works.
But as I understand, we also can flash and erase eMMC hardware partitions by configuration defined labels: - CONFIG_FASTBOOT_MMC_BOOT1_NAME - CONFIG_FASTBOOT_MMC_BOOT2_NAME - CONFIG_FASTBOOT_MMC_USER_NAME Currently, this feature is broken, and these patches fix that.
Changes for v2:
- code cleanup;
Changes for v3:
if (!dev_desc)
return;
info.start = 0;
goto write_image;
On Tue, May 18, 2021 at 04:24:49PM +0300, Oleh Kravchenko wrote:
Hello Tom,
Ah, OK. And are both https://patchwork.ozlabs.org/project/uboot/patch/20210514210620.24715-1-oleg... and https://patchwork.ozlabs.org/project/uboot/patch/20210514211505.26722-1-oleg... relevant still or is the latter v3 of the former? Thanks.
Hello Tom,
18.05.21 16:40, Tom Rini пише:
Hello Tom,
Yes, they are still relevant.
if (!dev_desc)
return;
info.start = 0;
goto write_image;
This is still ugly; perhaps we can combine this with the above if statement. E.g.
if (!info.size && fastboot_mmc_get_part_info(cmd, &dev_desc, &info, response) < 0) return;
--Sean
Oleh Kravchenko
Sean Anderson
