[U-Boot] [PATCH v2 0/3] board: at91sam9260: convert the boards to support DM and DT
The purpose of the patch set is to convert the boards to support the Driver Model and the Device Tree.
Changes in v2: - Add missing conversion default config files for at91sam9xeek. - Improve the commit log.
Wenyou Yang (3): ARM: dts: at91: add dts file for at91sam9g20/at91sam9260 configs: at91sam9260: update for DT and DM support board: at91sam9260ek: clean up code
arch/arm/dts/Makefile | 5 + arch/arm/dts/at91sam9260.dtsi | 136 +++++++-------- arch/arm/dts/at91sam9260ek.dts | 211 +++++++++++++++++++++++ arch/arm/dts/at91sam9g20.dtsi | 4 +- arch/arm/dts/at91sam9g20ek.dts | 29 ++++ arch/arm/dts/at91sam9g20ek_2mmc.dts | 56 +++++++ arch/arm/dts/at91sam9g20ek_common.dtsi | 223 +++++++++++++++++++++++++ board/atmel/at91sam9260ek/at91sam9260ek.c | 73 -------- configs/at91sam9260ek_dataflash_cs0_defconfig | 15 +- configs/at91sam9260ek_dataflash_cs1_defconfig | 15 +- configs/at91sam9260ek_nandflash_defconfig | 15 +- configs/at91sam9g20ek_2mmc_defconfig | 16 +- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 16 +- configs/at91sam9g20ek_dataflash_cs0_defconfig | 15 +- configs/at91sam9g20ek_dataflash_cs1_defconfig | 15 +- configs/at91sam9g20ek_nandflash_defconfig | 16 +- configs/at91sam9xeek_dataflash_cs0_defconfig | 15 +- configs/at91sam9xeek_dataflash_cs1_defconfig | 15 +- configs/at91sam9xeek_nandflash_defconfig | 15 +- include/configs/at91sam9260ek.h | 9 - 20 files changed, 744 insertions(+), 170 deletions(-) create mode 100644 arch/arm/dts/at91sam9260ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek_2mmc.dts create mode 100644 arch/arm/dts/at91sam9g20ek_common.dtsi
The device tree source files of at91sam9g20ek and at91sam9260ek boards are copied from the Linux v4.10, do the changes below. - Fix the build error for the usb0 node. - Add the reg property for the pinctrl node. - Move the gpio (pioA, pioB, pioC ...) nodes as the pinctrl's slibling nodes, instead of the child nodes. - Add the clk pinctrl of the mmc0 node. - Fix the compile warnings.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v2: None
arch/arm/dts/Makefile | 5 + arch/arm/dts/at91sam9260.dtsi | 136 ++++++++++---------- arch/arm/dts/at91sam9260ek.dts | 211 +++++++++++++++++++++++++++++++ arch/arm/dts/at91sam9g20.dtsi | 4 +- arch/arm/dts/at91sam9g20ek.dts | 29 +++++ arch/arm/dts/at91sam9g20ek_2mmc.dts | 56 +++++++++ arch/arm/dts/at91sam9g20ek_common.dtsi | 223 +++++++++++++++++++++++++++++++++ 7 files changed, 596 insertions(+), 68 deletions(-) create mode 100644 arch/arm/dts/at91sam9260ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek.dts create mode 100644 arch/arm/dts/at91sam9g20ek_2mmc.dts create mode 100644 arch/arm/dts/at91sam9g20ek_common.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fce84b4e12..76dc6562ed 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -325,6 +325,11 @@ dtb-$(CONFIG_SOC_KEYSTONE) += k2hk-evm.dtb \ k2e-evm.dtb \ k2g-evm.dtb
+dtb-$(CONFIG_TARGET_AT91SAM9260EK) += \ + at91sam9260ek.dtb \ + at91sam9g20ek.dtb \ + at91sam9g20ek_2mmc.dtb + dtb-$(CONFIG_TARGET_AT91SAM9X5EK) += \ at91sam9g15ek.dtb \ at91sam9g25ek.dtb \ diff --git a/arch/arm/dts/at91sam9260.dtsi b/arch/arm/dts/at91sam9260.dtsi index d4884dd1c2..39205e9df1 100644 --- a/arch/arm/dts/at91sam9260.dtsi +++ b/arch/arm/dts/at91sam9260.dtsi @@ -134,7 +134,7 @@ clocks = <&slow_rc_osc>, <&slow_xtal>; };
- plla: pllack { + plla: pllack@0 { compatible = "atmel,at91rm9200-clk-pll"; #clock-cells = <0>; interrupts-extended = <&pmc AT91_PMC_LOCKA>; @@ -146,7 +146,7 @@ <150000000 240000000 2 1>; };
- pllb: pllbck { + pllb: pllbck@1 { compatible = "atmel,at91rm9200-clk-pll"; #clock-cells = <0>; interrupts-extended = <&pmc AT91_PMC_LOCKB>; @@ -180,13 +180,13 @@ interrupt-parent = <&pmc>; clocks = <&clk32k>, <&main>, <&plla>, <&pllb>;
- prog0: prog0 { + prog0: prog@0 { #clock-cells = <0>; reg = <0>; interrupts = <AT91_PMC_PCKRDY(0)>; };
- prog1: prog1 { + prog1: prog@1 { #clock-cells = <0>; reg = <1>; interrupts = <AT91_PMC_PCKRDY(1)>; @@ -198,25 +198,25 @@ #address-cells = <1>; #size-cells = <0>;
- uhpck: uhpck { + uhpck: uhpck@6 { #clock-cells = <0>; reg = <6>; clocks = <&usb>; };
- udpck: udpck { + udpck: udpck@7 { #clock-cells = <0>; reg = <7>; clocks = <&usb>; };
- pck0: pck0 { + pck0: pck0@8 { #clock-cells = <0>; reg = <8>; clocks = <&prog0>; };
- pck1: pck1 { + pck1: pck1@9 { #clock-cells = <0>; reg = <9>; clocks = <&prog1>; @@ -229,127 +229,127 @@ #size-cells = <0>; clocks = <&mck>;
- pioA_clk: pioA_clk { + pioA_clk: pioA_clk@2 { #clock-cells = <0>; reg = <2>; };
- pioB_clk: pioB_clk { + pioB_clk: pioB_clk@3 { #clock-cells = <0>; reg = <3>; };
- pioC_clk: pioC_clk { + pioC_clk: pioC_clk@4 { #clock-cells = <0>; reg = <4>; };
- adc_clk: adc_clk { + adc_clk: adc_clk@5 { #clock-cells = <0>; reg = <5>; };
- usart0_clk: usart0_clk { + usart0_clk: usart0_clk@6 { #clock-cells = <0>; reg = <6>; };
- usart1_clk: usart1_clk { + usart1_clk: usart1_clk@7 { #clock-cells = <0>; reg = <7>; };
- usart2_clk: usart2_clk { + usart2_clk: usart2_clk@8 { #clock-cells = <0>; reg = <8>; };
- mci0_clk: mci0_clk { + mci0_clk: mci0_clk@9 { #clock-cells = <0>; reg = <9>; };
- udc_clk: udc_clk { + udc_clk: udc_clk@10 { #clock-cells = <0>; reg = <10>; };
- twi0_clk: twi0_clk { + twi0_clk: twi0_clk@11 { reg = <11>; #clock-cells = <0>; };
- spi0_clk: spi0_clk { + spi0_clk: spi0_clk@12 { #clock-cells = <0>; reg = <12>; };
- spi1_clk: spi1_clk { + spi1_clk: spi1_clk@13 { #clock-cells = <0>; reg = <13>; };
- ssc0_clk: ssc0_clk { + ssc0_clk: ssc0_clk@14 { #clock-cells = <0>; reg = <14>; };
- tc0_clk: tc0_clk { + tc0_clk: tc0_clk@17 { #clock-cells = <0>; reg = <17>; };
- tc1_clk: tc1_clk { + tc1_clk: tc1_clk@18 { #clock-cells = <0>; reg = <18>; };
- tc2_clk: tc2_clk { + tc2_clk: tc2_clk@19 { #clock-cells = <0>; reg = <19>; };
- ohci_clk: ohci_clk { + ohci_clk: ohci_clk@20 { #clock-cells = <0>; reg = <20>; };
- macb0_clk: macb0_clk { + macb0_clk: macb0_clk@21 { #clock-cells = <0>; reg = <21>; };
- isi_clk: isi_clk { + isi_clk: isi_clk@22 { #clock-cells = <0>; reg = <22>; };
- usart3_clk: usart3_clk { + usart3_clk: usart3_clk@23 { #clock-cells = <0>; reg = <23>; };
- uart0_clk: uart0_clk { + uart0_clk: uart0_clk@24 { #clock-cells = <0>; reg = <24>; };
- uart1_clk: uart1_clk { + uart1_clk: uart1_clk@25 { #clock-cells = <0>; reg = <25>; };
- tc3_clk: tc3_clk { + tc3_clk: tc3_clk@26 { #clock-cells = <0>; reg = <26>; };
- tc4_clk: tc4_clk { + tc4_clk: tc4_clk@27 { #clock-cells = <0>; reg = <27>; };
- tc5_clk: tc5_clk { + tc5_clk: tc5_clk@28 { #clock-cells = <0>; reg = <28>; }; @@ -395,11 +395,48 @@ clock-names = "t0_clk", "t1_clk", "t2_clk", "slow_clk"; };
+ pioA: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + }; + + pioB: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + }; + + pioC: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + }; + pinctrl@fffff400 { #address-cells = <1>; #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x600>; + reg = <0xfffff400 0x200 /* pioA */ + 0xfffff600 0x200 /* pioB */ + 0xfffff800 0x200 /* pioC */ + >;
atmel,mux-mask = < /* A B */ @@ -719,39 +756,6 @@ atmel,pins = <AT91_PIOB 19 AT91_PERIPH_B AT91_PINCTRL_NONE>; }; }; - - pioA: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - }; - - pioB: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - }; - - pioC: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - }; };
dbgu: serial@fffff200 { diff --git a/arch/arm/dts/at91sam9260ek.dts b/arch/arm/dts/at91sam9260ek.dts new file mode 100644 index 0000000000..8ce2c776f6 --- /dev/null +++ b/arch/arm/dts/at91sam9260ek.dts @@ -0,0 +1,211 @@ +/* + * Device Tree file for Atmel at91sam9260 Evaluation Kit + * + * Copyright (C) 2016 Atmel, + * 2016 Nicolas Ferre nicolas.ferre@atmel.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; +#include "at91sam9260.dtsi" + +/ { + model = "Atmel at91sam9260ek"; + compatible = "atmel,at91sam9260ek", "atmel,at91sam9260", "atmel,at91sam9"; + + chosen { + stdout-path = &dbgu; + }; + + memory { + reg = <0x20000000 0x4000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <18432000>; + }; + }; + + ahb { + apb { + usb1: gadget@fffa4000 { + atmel,vbus-gpio = <&pioC 5 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + + mmc0: mmc@fffa8000 { + pinctrl-0 = < + &pinctrl_board_mmc0_slot1 + &pinctrl_mmc0_clk + &pinctrl_mmc0_slot1_cmd_dat0 + &pinctrl_mmc0_slot1_dat1_3>; + status = "okay"; + slot@1 { + reg = <1>; + bus-width = <4>; + cd-gpios = <&pioC 9 GPIO_ACTIVE_HIGH>; + }; + }; + + usart0: serial@fffb0000 { + pinctrl-0 = + <&pinctrl_usart0 + &pinctrl_usart0_rts + &pinctrl_usart0_cts + &pinctrl_usart0_dtr_dsr + &pinctrl_usart0_dcd + &pinctrl_usart0_ri>; + status = "okay"; + }; + + usart1: serial@fffb4000 { + status = "okay"; + }; + + ssc0: ssc@fffbc000 { + status = "okay"; + pinctrl-0 = <&pinctrl_ssc0_tx>; + }; + + macb0: ethernet@fffc4000 { + phy-mode = "rmii"; + status = "okay"; + }; + + spi0: spi@fffc8000 { + cs-gpios = <0>, <&pioC 11 0>, <0>, <0>; + mtd_dataflash@0 { + compatible = "atmel,at45", "atmel,dataflash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; + }; + + dbgu: serial@fffff200 { + status = "okay"; + }; + + pinctrl@fffff400 { + board { + pinctrl_board_mmc0_slot1: mmc0_slot1-board { + atmel,pins = + <AT91_PIOC 9 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; + }; + }; + }; + + shdwc@fffffd10 { + atmel,wakeup-counter = <10>; + atmel,wakeup-rtt-timer; + }; + + rtc@fffffd20 { + atmel,rtt-rtc-time-reg = <&gpbr 0x0>; + status = "okay"; + }; + + watchdog@fffffd40 { + status = "okay"; + }; + + gpbr: syscon@fffffd50 { + status = "okay"; + }; + }; + + usb0: ohci@00500000 { + num-ports = <2>; + status = "okay"; + }; + + nand0: nand@40000000 { + nand-bus-width = <8>; + nand-ecc-mode = "soft"; + nand-on-flash-bbt; + status = "okay"; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + btn3 { + label = "Button 3"; + gpios = <&pioA 30 GPIO_ACTIVE_LOW>; + linux,code = <0x103>; + wakeup-source; + }; + + btn4 { + label = "Button 4"; + gpios = <&pioA 31 GPIO_ACTIVE_LOW>; + linux,code = <0x104>; + wakeup-source; + }; + }; + + i2c-gpio-0 { + status = "okay"; + + 24c512@50 { + compatible = "24c512"; + reg = <0x50>; + }; + }; + + leds { + compatible = "gpio-leds"; + + ds1 { + label = "ds1"; + gpios = <&pioA 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + ds5 { + label = "ds5"; + gpios = <&pioA 6 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/arch/arm/dts/at91sam9g20.dtsi b/arch/arm/dts/at91sam9g20.dtsi index f593016181..e88d73ca8b 100644 --- a/arch/arm/dts/at91sam9g20.dtsi +++ b/arch/arm/dts/at91sam9g20.dtsi @@ -40,7 +40,7 @@ };
pmc: pmc@fffffc00 { - plla: pllack { + plla: pllack@0 { atmel,clk-input-range = <2000000 32000000>; atmel,pll-clk-output-ranges = <745000000 800000000 0 0>, <695000000 750000000 1 0>, @@ -52,7 +52,7 @@ <400000000 450000000 3 1>; };
- pllb: pllbck { + pllb: pllbck@1 { compatible = "atmel,at91sam9g20-clk-pllb"; atmel,clk-input-range = <2000000 32000000>; atmel,pll-clk-output-ranges = <30000000 100000000 0 0>; diff --git a/arch/arm/dts/at91sam9g20ek.dts b/arch/arm/dts/at91sam9g20ek.dts new file mode 100644 index 0000000000..bbfd753112 --- /dev/null +++ b/arch/arm/dts/at91sam9g20ek.dts @@ -0,0 +1,29 @@ +/* + * at91sam9g20ek.dts - Device Tree file for Atmel at91sam9g20ek board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2. + */ +/dts-v1/; +#include "at91sam9g20ek_common.dtsi" + +/ { + model = "Atmel at91sam9g20ek"; + compatible = "atmel,at91sam9g20ek", "atmel,at91sam9g20", "atmel,at91sam9"; + + leds { + compatible = "gpio-leds"; + + ds1 { + label = "ds1"; + gpios = <&pioA 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + ds5 { + label = "ds5"; + gpios = <&pioA 6 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/arch/arm/dts/at91sam9g20ek_2mmc.dts b/arch/arm/dts/at91sam9g20ek_2mmc.dts new file mode 100644 index 0000000000..7ea83b6de8 --- /dev/null +++ b/arch/arm/dts/at91sam9g20ek_2mmc.dts @@ -0,0 +1,56 @@ +/* + * at91sam9g20ek_2mmc.dts - Device Tree file for Atmel at91sam9g20ek 2 MMC board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2. + */ +/dts-v1/; +#include "at91sam9g20ek_common.dtsi" + +/ { + model = "Atmel at91sam9g20ek 2 mmc"; + compatible = "atmel,at91sam9g20ek_2mmc", "atmel,at91sam9g20", "atmel,at91sam9"; + + ahb { + apb{ + mmc0: mmc@fffa8000 { + /* clk already mux wuth slot0 */ + pinctrl-0 = < + &pinctrl_board_mmc0_slot0 + &pinctrl_mmc0_clk + &pinctrl_mmc0_slot0_cmd_dat0 + &pinctrl_mmc0_slot0_dat1_3>; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioC 2 GPIO_ACTIVE_HIGH>; + }; + }; + + pinctrl@fffff400 { + mmc0_slot0 { + pinctrl_board_mmc0_slot0: mmc0_slot0-board { + atmel,pins = + <AT91_PIOC 2 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PC2 gpio CD pin pull up and deglitch */ + }; + }; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + ds1 { + label = "ds1"; + gpios = <&pioB 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + ds5 { + label = "ds5"; + gpios = <&pioB 8 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/arch/arm/dts/at91sam9g20ek_common.dtsi b/arch/arm/dts/at91sam9g20ek_common.dtsi new file mode 100644 index 0000000000..60d1d59b5d --- /dev/null +++ b/arch/arm/dts/at91sam9g20ek_common.dtsi @@ -0,0 +1,223 @@ +/* + * at91sam9g20ek_common.dtsi - Device Tree file for Atmel at91sam9g20ek board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2. + */ +#include "at91sam9g20.dtsi" + +/ { + chosen { + stdout-path = &dbgu; + }; + + memory { + reg = <0x20000000 0x4000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <18432000>; + }; + }; + + ahb { + apb { + pinctrl@fffff400 { + board { + pinctrl_pck0_as_mck: pck0_as_mck { + atmel,pins = + <AT91_PIOC 1 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PC1 periph B */ + }; + + }; + + mmc0_slot1 { + pinctrl_board_mmc0_slot1: mmc0_slot1-board { + atmel,pins = + <AT91_PIOC 9 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PC9 gpio CD pin pull up and deglitch */ + }; + }; + }; + + dbgu: serial@fffff200 { + status = "okay"; + }; + + usart0: serial@fffb0000 { + pinctrl-0 = + <&pinctrl_usart0 + &pinctrl_usart0_rts + &pinctrl_usart0_cts + &pinctrl_usart0_dtr_dsr + &pinctrl_usart0_dcd + &pinctrl_usart0_ri>; + status = "okay"; + }; + + usart1: serial@fffb4000 { + status = "okay"; + }; + + macb0: ethernet@fffc4000 { + phy-mode = "rmii"; + status = "okay"; + }; + + usb1: gadget@fffa4000 { + atmel,vbus-gpio = <&pioC 5 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + + mmc0: mmc@fffa8000 { + pinctrl-0 = < + &pinctrl_board_mmc0_slot1 + &pinctrl_mmc0_clk + &pinctrl_mmc0_slot1_cmd_dat0 + &pinctrl_mmc0_slot1_dat1_3>; + status = "okay"; + slot@1 { + reg = <1>; + bus-width = <4>; + cd-gpios = <&pioC 9 GPIO_ACTIVE_HIGH>; + }; + }; + + ssc0: ssc@fffbc000 { + status = "okay"; + pinctrl-0 = <&pinctrl_ssc0_tx>; + }; + + spi0: spi@fffc8000 { + cs-gpios = <0>, <&pioC 11 0>, <0>, <0>; + mtd_dataflash@0 { + compatible = "atmel,at45", "atmel,dataflash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; + }; + + shdwc@fffffd10 { + atmel,wakeup-counter = <10>; + atmel,wakeup-rtt-timer; + }; + + rtc@fffffd20 { + atmel,rtt-rtc-time-reg = <&gpbr 0x0>; + status = "okay"; + }; + + watchdog@fffffd40 { + status = "okay"; + }; + + gpbr: syscon@fffffd50 { + status = "okay"; + }; + }; + + nand0: nand@40000000 { + nand-bus-width = <8>; + nand-ecc-mode = "soft"; + nand-on-flash-bbt; + status = "okay"; + + at91bootstrap@0 { + label = "at91bootstrap"; + reg = <0x0 0x20000>; + }; + + barebox@20000 { + label = "barebox"; + reg = <0x20000 0x40000>; + }; + + bareboxenv@60000 { + label = "bareboxenv"; + reg = <0x60000 0x20000>; + }; + + bareboxenv2@80000 { + label = "bareboxenv2"; + reg = <0x80000 0x20000>; + }; + + oftree@80000 { + label = "oftree"; + reg = <0xa0000 0x20000>; + }; + + kernel@a0000 { + label = "kernel"; + reg = <0xc0000 0x400000>; + }; + + rootfs@4a0000 { + label = "rootfs"; + reg = <0x4c0000 0x7800000>; + }; + + data@7ca0000 { + label = "data"; + reg = <0x7cc0000 0x8340000>; + }; + }; + + usb0: ohci@00500000 { + num-ports = <2>; + status = "okay"; + }; + }; + + i2c-gpio-0 { + status = "okay"; + + 24c512@50 { + compatible = "24c512"; + reg = <0x50>; + }; + + wm8731: wm8731@1b { + compatible = "wm8731"; + reg = <0x1b>; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + btn3 { + label = "Button 3"; + gpios = <&pioA 30 GPIO_ACTIVE_LOW>; + linux,code = <0x103>; + wakeup-source; + }; + + btn4 { + label = "Button 4"; + gpios = <&pioA 31 GPIO_ACTIVE_LOW>; + linux,code = <0x104>; + wakeup-source; + }; + }; + + sound { + compatible = "atmel,at91sam9g20ek-wm8731-audio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pck0_as_mck>; + + atmel,model = "wm8731 @ AT91SAMG20EK"; + + atmel,audio-routing = + "Ext Spk", "LHPOUT", + "Int Mic", "MICIN"; + + atmel,ssc-controller = <&ssc0>; + atmel,audio-codec = <&wm8731>; + }; +};
Support the device tree and enable CONFIG_CLK and CONFIG_PINCTRL options to support at91 clock driver and at91 pinctrl driver.
Enable DM_GPIO, DM_MMC and DM_ETH support, move CONFIG_AT91_GPIO, CONFIG_GENERIC_ATMEL_MCI and CONFIG_MACB config option to the default config files.
configs/at91sam9260ek_dataflash_cs0_defconfig | 15 +++++++++++++-- configs/at91sam9260ek_dataflash_cs1_defconfig | 15 +++++++++++++-- configs/at91sam9260ek_nandflash_defconfig | 15 +++++++++++++-- configs/at91sam9g20ek_2mmc_defconfig | 16 +++++++++++++++- configs/at91sam9g20ek_2mmc_nandflash_defconfig | 16 +++++++++++++++- configs/at91sam9g20ek_dataflash_cs0_defconfig | 15 +++++++++++++-- configs/at91sam9g20ek_dataflash_cs1_defconfig | 15 +++++++++++++-- configs/at91sam9g20ek_nandflash_defconfig | 16 ++++++++++++++-- configs/at91sam9xeek_dataflash_cs0_defconfig | 15 +++++++++++++-- configs/at91sam9xeek_dataflash_cs1_defconfig | 15 +++++++++++++-- configs/at91sam9xeek_nandflash_defconfig | 15 +++++++++++++-- include/configs/at91sam9260ek.h | 9 --------- 12 files changed, 148 insertions(+), 29 deletions(-)
diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 36423b2c73..2fe2a3908e 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 3b2817205e..cfbc87970c 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 4f88507b35..e38e9cb5a3 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 67c82326a4..4d49983dbc 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 6d2bfa1d6b..35e5b04e1b 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +20,18 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 4d94b84bd6..a9c42dde08 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index cbe0376b30..449837d9a3 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 1b53332759..022aa0bd99 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,17 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 4092bfa7cb..f42ae85ff3 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 5ff6902351..eb6a3d772a 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index fea620c476..dfbe2b84ac 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -1,7 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9260EK=y -# CONFIG_MMC is not set +CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" +# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -18,6 +19,16 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 022353c7fb..bed0adb269 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -45,7 +45,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ @@ -143,18 +142,10 @@ #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 #endif
-/* MMC */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_GENERIC_ATMEL_MCI -#endif - /* NOR flash - no real flash on this board */ #define CONFIG_SYS_NO_FLASH 1
/* Ethernet */ -#define CONFIG_MACB 1 -#define CONFIG_RMII 1 -#define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1 #define CONFIG_AT91_WANTS_COMMON_PHY
Since the introduction of the pinctrl and clk drivers and the device tree files, remove unneeded hard coded related code from the board file.
Changes in v2: None
board/atmel/at91sam9260ek/at91sam9260ek.c | 73 ------------------------------- 1 file changed, 73 deletions(-)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 98193bfdc6..e1bbc93924 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -13,12 +13,6 @@ #include <asm/arch/at91_common.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <atmel_mci.h> - -#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) -# include <net.h> -#endif -#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -67,63 +61,8 @@ static void at91sam9260ek_nand_hw_init(void) } #endif
-#ifdef CONFIG_MACB -static void at91sam9260ek_macb_hw_init(void) -{ - struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - - at91_periph_clk_enable(ATMEL_ID_EMAC0); - - /* - * Disable pull-up on: - * RXDV (PA17) => PHY normal mode (not Test mode) - * ERX0 (PA14) => PHY ADDR0 - * ERX1 (PA15) => PHY ADDR1 - * ERX2 (PA25) => PHY ADDR2 - * ERX3 (PA26) => PHY ADDR3 - * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 - * - * PHY has internal pull-down - */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - &pioa->pudr); - - at91_phy_reset(); - - /* Re-enable pull-up */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - &pioa->puer); - - /* Initialize EMAC=MACB hardware */ - at91_macb_hw_init(); -} -#endif - -#ifdef CONFIG_GENERIC_ATMEL_MCI -int board_mmc_init(bd_t *bd) -{ - at91_mci_hw_init(); - - return atmel_mci_init((void *)ATMEL_BASE_MCI); -} -#endif - int board_early_init_f(void) { - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_periph_clk_enable(ATMEL_ID_PIOB); - at91_periph_clk_enable(ATMEL_ID_PIOC); - return 0; }
@@ -139,9 +78,6 @@ int board_init(void) #ifdef CONFIG_HAS_DATAFLASH at91_spi0_hw_init((1 << 0) | (1 << 1)); #endif -#ifdef CONFIG_MACB - at91sam9260ek_macb_hw_init(); -#endif
return 0; } @@ -159,12 +95,3 @@ void reset_phy(void) { } #endif - -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00); -#endif - return rc; -}
Wenyou Yang
