[PATCH 1/2] patman: Sort the command line options
Sort the existing command line options by:
- help comes first - option starts with '-' - option starts with '--'
Lower case followed by upper case letters, in alphabetical order.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
tools/patman/main.py | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/tools/patman/main.py b/tools/patman/main.py index f3d9c0c..72c67b8 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -36,11 +36,11 @@ parser.add_option('-c', '--count', dest='count', type='int', parser.add_option('-i', '--ignore-errors', action='store_true', dest='ignore_errors', default=False, help='Send patches email even if patch errors are found') +parser.add_option('-l', '--limit-cc', dest='limit', type='int', + default=None, help='Limit the cc list to LIMIT entries [default: %default]') parser.add_option('-m', '--no-maintainers', action='store_false', dest='add_maintainers', default=True, help="Don't cc the file maintainers automatically") -parser.add_option('-l', '--limit-cc', dest='limit', type='int', - default=None, help='Limit the cc list to LIMIT entries [default: %default]') parser.add_option('-n', '--dry-run', action='store_true', dest='dry_run', default=False, help="Do a dry run (create but don't email patches)") parser.add_option('-p', '--project', default=project.DetectProject(), @@ -52,10 +52,10 @@ parser.add_option('-s', '--start', dest='start', type='int', default=0, help='Commit to start creating patches from (0 = HEAD)') parser.add_option('-t', '--ignore-bad-tags', action='store_true', default=False, help='Ignore bad tags / aliases') -parser.add_option('--test', action='store_true', dest='test', - default=False, help='run tests') parser.add_option('-v', '--verbose', action='store_true', dest='verbose', default=False, help='Verbose output of errors and warnings') +parser.add_option('-T', '--thread', action='store_true', dest='thread', + default=False, help='Create patches as a single thread') parser.add_option('--cc-cmd', dest='cc_cmd', type='string', action='store', default=None, help='Output cc list for patch file (used by git)') parser.add_option('--no-check', action='store_false', dest='check_patch', @@ -65,8 +65,8 @@ parser.add_option('--no-tags', action='store_false', dest='process_tags', default=True, help="Don't process subject tags as aliaes") parser.add_option('--smtp-server', type='str', help="Specify the SMTP server to 'git send-email'") -parser.add_option('-T', '--thread', action='store_true', dest='thread', - default=False, help='Create patches as a single thread') +parser.add_option('--test', action='store_true', dest='test', + default=False, help='run tests')
parser.usage += """
Some mailing lists have size limits and when we add binary contents to our patches it's easy to exceed the size limits.
Git supports a command line option "--no-binary" to generate patches without any binary contents. Add an option in patman to handle this. Note with this option patches cannot be applied properly, but they are still useful for code review.
tools/patman/gitutil.py | 4 +++- tools/patman/main.py | 5 ++++- 2 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/tools/patman/gitutil.py b/tools/patman/gitutil.py index 770a051..72fc95d 100644 --- a/tools/patman/gitutil.py +++ b/tools/patman/gitutil.py @@ -254,7 +254,7 @@ def Fetch(git_dir=None, work_tree=None): if result.return_code != 0: raise OSError('git fetch: %s' % result.stderr)
-def CreatePatches(start, count, series): +def CreatePatches(start, count, ignore_binary, series): """Create a series of patches from the top of the current branch.
The patch files are written to the current directory using @@ -270,6 +270,8 @@ def CreatePatches(start, count, series): if series.get('version'): version = '%s ' % series['version'] cmd = ['git', 'format-patch', '-M', '--signoff'] + if ignore_binary: + cmd.append('--no-binary') if series.get('cover'): cmd.append('--cover-letter') prefix = series.GetPatchPrefix() diff --git a/tools/patman/main.py b/tools/patman/main.py index 72c67b8..2951836 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -58,6 +58,9 @@ parser.add_option('-T', '--thread', action='store_true', dest='thread', default=False, help='Create patches as a single thread') parser.add_option('--cc-cmd', dest='cc_cmd', type='string', action='store', default=None, help='Output cc list for patch file (used by git)') +parser.add_option('--no-binary', action='store_true', dest='ignore_binary', + default=False, + help="Do not output contents of changes in binary files") parser.add_option('--no-check', action='store_false', dest='check_patch', default=True, help="Don't check for patch compliance") @@ -144,7 +147,7 @@ else: if options.count: series = patchstream.GetMetaData(options.start, options.count) cover_fname, args = gitutil.CreatePatches(options.start, options.count, - series) + options.ignore_binary, series)
# Fix up the patch files to our liking, and insert the cover letter patchstream.FixPatches(series, args)
Can you also please update the docs?
- help comes first
Bin Meng
