[U-Boot] [PATCH v2] Correct chip detect logic
The lan91c96_detect_chip routine is not correct according to the manual.
Signed-off-by: YanJun Yang yangyj.ee@gmail.com --- Changes for v2: - Avoid line wraps and ensure tabs - Don't define a new macro
drivers/net/lan91c96.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index bd6966e..883f3a7 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -780,7 +780,7 @@ static int lan91c96_detect_chip(struct eth_device *dev) u8 chip_id; int r; SMC_SELECT_BANK(dev, 3); - chip_id = SMC_inw(dev, 0xA) & LAN91C96_REV_REVID; + chip_id = (SMC_inw(dev, 0xA) & LAN91C96_REV_CHIPID) >> 4; SMC_SELECT_BANK(dev, 0); for (r = 0; r < sizeof(supported_chips) / sizeof(struct id_type); r++) if (chip_id == supported_chips[r].id)
Dear Yanjun Yang,
In message AANLkTi=YN=ADLKGTmsoFGBG5ZuaO=ASHhe_3O5kQvb1K@mail.gmail.com you wrote:
Changes for v2:
Applied, thanks.
Yanjun Yang
