[U-Boot] [PATCH][AT91 rework 0/1] change common at91sam9g45 files
Signed-off-by: Asen Chavdarov Dimov dimov@ronetix.at --- .../cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 26 ++++++++++---------- arch/arm/include/asm/arch-at91/at91sam9g45.h | 2 + 2 files changed, 15 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 4ad9b1f..90085a5 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -26,42 +26,42 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> +#include <asm/io.h>
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 19, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTB, 18, 0); /* RXD0 */ - writel(1 << AT91SAM9G45_ID_US0, &pmc->pcer); + writel(1 << ATMEL_ID_USART0, &pmc->pcer); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTB, 5, 0); /* RXD1 */ - writel(1 << AT91SAM9G45_ID_US1, &pmc->pcer); + writel(1 << ATMEL_ID_USART1, &pmc->pcer); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 6, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTD, 7, 0); /* RXD2 */ - writel(1 << AT91SAM9G45_ID_US2, &pmc->pcer); + writel(1 << ATMEL_ID_USART2, &pmc->pcer); }
void at91_serial3_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTB, 13, 1); /* DTXD */ - writel(1 << AT91_ID_SYS, &pmc->pcer); + writel(1 << ATMEL_ID_SYS, &pmc->pcer); }
void at91_serial_hw_init(void) @@ -86,14 +86,14 @@ void at91_serial_hw_init(void) #ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* SPI0_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_SPI0, &pmc->pcer); + writel(1 << ATMEL_ID_SPI0, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 3, 0); @@ -123,14 +123,14 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 15, 0); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 16, 0); /* SPI1_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_SPI1, &pmc->pcer); + writel(1 << ATMEL_ID_SPI1, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 17, 0); diff --git a/arch/arm/include/asm/arch-at91/at91sam9g45.h b/arch/arm/include/asm/arch-at91/at91sam9g45.h index 364b86c..95e2a0f 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9g45.h +++ b/arch/arm/include/asm/arch-at91/at91sam9g45.h @@ -132,6 +132,8 @@ * Other misc defines */ #define ATMEL_PIO_PORTS 5 /* this SoCs has 5 PIO */ +#define ATMEL_ID_UHP ATMEL_ID_UHPHS +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* * Cpu Name
Signed-off-by: Asen Chavdarov Dimov dimov@ronetix.at --- Makefile | 4 ---- board/ronetix/pm9g45/pm9g45.c | 30 ++++++++++++++---------------- boards.cfg | 1 + include/configs/pm9g45.h | 16 +++++++++++----- 4 files changed, 26 insertions(+), 25 deletions(-)
diff --git a/Makefile b/Makefile index 64e47c7..777cb87 100644 --- a/Makefile +++ b/Makefile @@ -852,10 +852,6 @@ at91sam9g45ekes_config : unconfig fi; @$(MKCONFIG) -n $@ -a at91sam9m10g45ek arm arm926ejs at91sam9m10g45ek atmel at91
-pm9g45_config : unconfig - @mkdir -p $(obj)include - @$(MKCONFIG) -a pm9g45 arm arm926ejs pm9g45 ronetix at91 - SBC35_A9G20_NANDFLASH_config \ SBC35_A9G20_EEPROM_config \ SBC35_A9G20_config : unconfig diff --git a/board/ronetix/pm9g45/pm9g45.c b/board/ronetix/pm9g45/pm9g45.c index 79b7c9d..8d47b55 100644 --- a/board/ronetix/pm9g45/pm9g45.c +++ b/board/ronetix/pm9g45/pm9g45.c @@ -29,16 +29,14 @@
#include <common.h> #include <asm/sizes.h> -#include <asm/arch/at91sam9g45.h> +#include <asm/io.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/at91_matrix.h> -#include <asm/arch/at91_pio.h> +#include <asm/arch/gpio.h> #include <asm/arch/clk.h> -#include <asm/arch/io.h> -#include <asm/arch/hardware.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -54,9 +52,9 @@ DECLARE_GLOBAL_DATA_PTR; static void pm9g45_nand_hw_init(void) { unsigned long csa; - at91_smc_t *smc = (at91_smc_t *) AT91_SMC_BASE; - at91_matrix_t *matrix = (at91_matrix_t *) AT91_MATRIX_BASE; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* Enable CS3 */ csa = readl(&matrix->ccr[6]) | AT91_MATRIX_CSA_EBI_CS3A; @@ -80,7 +78,7 @@ static void pm9g45_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode);
- writel(1 << AT91SAM9G45_ID_PIOC, &pmc->pcer); + writel(1 << ATMEL_ID_PIOC, &pmc->pcer);
#ifdef CONFIG_SYS_NAND_READY_PIN /* Configure RDY/BSY */ @@ -95,7 +93,7 @@ static void pm9g45_nand_hw_init(void) #ifdef CONFIG_MACB static void pm9g45_macb_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* * PD2 enables the 50MHz oscillator for Ethernet PHY @@ -106,7 +104,7 @@ static void pm9g45_macb_hw_init(void) at91_set_pio_value(AT91_PIO_PORTD, 2, 1); /* 1- enable, 0 - disable */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_EMAC, &pmc->pcer); + writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
/* * Disable pull-up on: @@ -131,15 +129,15 @@ static void pm9g45_macb_hw_init(void)
int board_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* Enable Ctrlc */ console_init_f();
- writel((1 << AT91SAM9G45_ID_PIOA) | - (1 << AT91SAM9G45_ID_PIOB) | - (1 << AT91SAM9G45_ID_PIOC) | - (1 << AT91SAM9G45_ID_PIODE), &pmc->pcer); + writel((1 << ATMEL_ID_PIOA) | + (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC) | + (1 << ATMEL_ID_PIODE), &pmc->pcer);
/* arch number of AT91SAM9M10G45EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_PM9G45; @@ -188,7 +186,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91_EMAC_BASE, 0x01); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x01); #endif return rc; } diff --git a/boards.cfg b/boards.cfg index ac20c81..823035b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -101,6 +101,7 @@ otc570 arm arm926ejs otc570 esd otc570_dataflash arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_DATAFLASH pm9261 arm arm926ejs - ronetix at91 pm9263 arm arm926ejs - ronetix at91 +pm9g45 arm arm926ejs pm9g45 ronetix at91 pm9g45:AT91SAM9G45 da830evm arm arm926ejs da8xxevm davinci davinci da850evm arm arm926ejs da8xxevm davinci davinci hawkboard arm arm926ejs da8xxevm davinci davinci diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index ec51ccf..672f663 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -32,15 +32,20 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +/* + * SoC must be defined first, before hardware.h is included. + * In this case SoC is defined in boards.cfg. + */ +#include <asm/hardware.h> + #define CONFIG_PM9G45 1 /* It's an Ronetix PM9G45 */ -#define CONFIG_AT91SAM9G45 1 /* It's an Atmel AT91SAM9G45 SoC */ +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9G45"
/* ARM asynchronous clock */ #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_HZ 1000 -#define CONFIG_SYS_TEXT_BASE 0x73f00000 -#define CONFIG_AT91FAMILY +#define CONFIG_SYS_TEXT_BASE 0x73f00000
#define CONFIG_ARCH_CPU_INIT
@@ -55,7 +60,8 @@ */ #define CONFIG_AT91_GPIO 1 #define CONFIG_ATMEL_USART 1 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS
#define CONFIG_SYS_USE_NANDFLASH 1
Dear Asen Chavdarov Dimov,
Hand added removal from MAKEALL,
changed: at91_serial_hw_init --> at91_seriald_hw_init
Configuring for pm9g45 - Board: pm9g45, Options: AT91SAM9G45 text data bss dec hex filename 209627 5952 71792 287371 4628b ./u-boot
Applied result to u-boot-atmel/master, thanks, Reinhard
Reinhard Meyer
