[U-Boot] [PATCH 0/4] smdkv310 modifications
These patches does the following things: uses CONFIG_MACH_TYPE generic macro to initialize machine id. Uses get_ram_size () to initialize DRAM bank size to accurate value Migrates mmc spl support from mmc_spl framework to spl framework Replace hardcoded value with a macro and removes typedef in board/samsung/smdkv310/mmc_boot.c file.
Chander Kashyap (4): SMDKV310: Initialize board id using CONFIG_MACH_TYPE SMDKV310: use get_ram_size() to validate dram size smdkv310: use spl framework for mmc spl smdkv310: use macro for mmc data read function address
board/samsung/smdkv310/Makefile | 19 ++++- .../board => board}/samsung/smdkv310/mmc_boot.c | 15 ++-- board/samsung/smdkv310/smdkv310.c | 13 ++- .../samsung/smdkv310/tools/mkv310_image.c | 0 include/configs/smdkv310.h | 8 ++- mmc_spl/board/samsung/smdkv310/Makefile | 106 -------------------- mmc_spl/board/samsung/smdkv310/u-boot.lds | 88 ---------------- 7 files changed, 41 insertions(+), 208 deletions(-) rename {mmc_spl/board => board}/samsung/smdkv310/mmc_boot.c (83%) rename {mmc_spl/board => board}/samsung/smdkv310/tools/mkv310_image.c (100%) delete mode 100644 mmc_spl/board/samsung/smdkv310/Makefile delete mode 100644 mmc_spl/board/samsung/smdkv310/u-boot.lds
Use CONFIG_MACH_TYPE generic macro to initialize board id.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/smdkv310/smdkv310.c | 1 - include/configs/smdkv310.h | 3 +++ 2 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index e0b89dd..4478b0b 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -57,7 +57,6 @@ int board_init(void)
smc9115_pre_init();
- gd->bd->bi_arch_number = MACH_TYPE_SMDKV310; gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); return 0; } diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 2f97bea..1c974ea 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -37,6 +37,9 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
+/* Mach Type */ +#define CONFIG_MACH_TYPE MACH_TYPE_SMDKV310 + /* Keep L2 Cache Disabled */ #define CONFIG_L2_OFF 1
smdkv310.c: in dram_init_banksize(void) function dram size was initialized without validation. get_ram_size() function will validate the bank size before initialization.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/smdkv310/smdkv310.c | 12 ++++++++---- 1 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 4478b0b..d9caca7 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -74,13 +74,17 @@ int dram_init(void) void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ + PHYS_SDRAM_1_SIZE); gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ + PHYS_SDRAM_2_SIZE); gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ + PHYS_SDRAM_3_SIZE); gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; + gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ + PHYS_SDRAM_4_SIZE); }
int board_eth_init(bd_t *bis)
smdkv310 board was using mmc_spl framework for mmc spl support. This patch migrates the framework from mmc_spl to spl.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/smdkv310/Makefile | 19 ++++- .../board => board}/samsung/smdkv310/mmc_boot.c | 0 .../samsung/smdkv310/tools/mkv310_image.c | 0 include/configs/smdkv310.h | 4 +- mmc_spl/board/samsung/smdkv310/Makefile | 106 -------------------- mmc_spl/board/samsung/smdkv310/u-boot.lds | 88 ---------------- 6 files changed, 21 insertions(+), 196 deletions(-) rename {mmc_spl/board => board}/samsung/smdkv310/mmc_boot.c (100%) rename {mmc_spl/board => board}/samsung/smdkv310/tools/mkv310_image.c (100%) delete mode 100644 mmc_spl/board/samsung/smdkv310/Makefile delete mode 100644 mmc_spl/board/samsung/smdkv310/u-boot.lds
diff --git a/board/samsung/smdkv310/Makefile b/board/samsung/smdkv310/Makefile index 8e9b703..1df0ead 100644 --- a/board/samsung/smdkv310/Makefile +++ b/board/samsung/smdkv310/Makefile @@ -26,16 +26,33 @@ LIB = $(obj)lib$(BOARD).o
SOBJS := mem_setup.o SOBJS += lowlevel_init.o +ifndef CONFIG_SPL_BUILD COBJS += smdkv310.o +endif + +ifdef CONFIG_SPL_BUILD +COBJS += mmc_boot.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
-all: $(obj).depend $(LIB) +ALL := $(obj).depend $(LIB) + +ifdef CONFIG_SPL_BUILD +ALL += $(OBJTREE)/tools/mk$(BOARD)spl +endif + +all: $(ALL)
$(LIB): $(OBJS) $(AR) $(ARFLAGS) $@ $(OBJS)
+ifdef CONFIG_SPL_BUILD +$(OBJTREE)/tools/mk$(BOARD)spl: tools/mkv310_image.c + $(HOSTCC) tools/mkv310_image.c -o $(OBJTREE)/tools/mk$(BOARD)spl +endif + #########################################################################
# defines $(obj).depend target diff --git a/mmc_spl/board/samsung/smdkv310/mmc_boot.c b/board/samsung/smdkv310/mmc_boot.c similarity index 100% rename from mmc_spl/board/samsung/smdkv310/mmc_boot.c rename to board/samsung/smdkv310/mmc_boot.c diff --git a/mmc_spl/board/samsung/smdkv310/tools/mkv310_image.c b/board/samsung/smdkv310/tools/mkv310_image.c similarity index 100% rename from mmc_spl/board/samsung/smdkv310/tools/mkv310_image.c rename to board/samsung/smdkv310/tools/mkv310_image.c diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 1c974ea..cf2ef17 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -90,7 +90,9 @@
#define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK -#define CONFIG_MMC_U_BOOT + +/* MMC SPL */ +#define CONFIG_SPL
#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
diff --git a/mmc_spl/board/samsung/smdkv310/Makefile b/mmc_spl/board/samsung/smdkv310/Makefile deleted file mode 100644 index 85f4838..0000000 --- a/mmc_spl/board/samsung/smdkv310/Makefile +++ /dev/null @@ -1,106 +0,0 @@ -# -# (C) Copyright 2006-2007 -# Stefan Roese, DENX Software Engineering, sr@denx.de. -# -# (C) Copyright 2008 -# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de -# -# (C) Copyright 2011 -# Chander Kashyap, Samsung Electronics, k.chander@samsung.com -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -CONFIG_MMC_SPL = y - -include $(TOPDIR)/config.mk - -LDSCRIPT= $(TOPDIR)/mmc_spl/board/$(BOARDDIR)/u-boot.lds -LDFLAGS = -Bstatic -T $(mmcobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(PLATFORM_LDFLAGS) -AFLAGS += -DCONFIG_MMC_SPL -AFLAGS += -DCONFIG_SPL_BUILD -CFLAGS += -DCONFIG_MMC_SPL -CFLAGS += -DCONFIG_SPL_BUILD - -SOBJS = start.o mem_setup.o lowlevel_init.o -COBJS = mmc_boot.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(OBJTREE)/mmc_spl/board/$(BOARDDIR) - -mmcobj := $(OBJTREE)/mmc_spl/ - - -MKV310_MMC_SPL_EXEC = mkv310_mmc_spl_exec -MMC_SPL_BIN = u-boot-mmc-spl.bin - -ALL = $(mmcobj)u-boot-spl $(mmcobj)u-boot-spl.bin $(mmcobj)$(MMC_SPL_BIN) - -all: $(obj).depend $(ALL) - -$(mmcobj)$(MMC_SPL_BIN): $(mmcobj)u-boot-spl.bin tools/$(MKV310_MMC_SPL_EXEC) - ./tools/$(MKV310_MMC_SPL_EXEC) $(mmcobj)u-boot-spl.bin $(mmcobj)$(MMC_SPL_BIN) - rm -f tools/$(MKV310_MMC_SPL_EXEC) - -tools/$(MKV310_MMC_SPL_EXEC): tools/mkv310_image.c - $(HOSTCC) tools/mkv310_image.c -o tools/$(MKV310_MMC_SPL_EXEC) - -$(mmcobj)u-boot-spl.bin: $(mmcobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ - -$(mmcobj)u-boot-spl: $(OBJS) $(mmcobj)u-boot.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ - -Map $(mmcobj)u-boot-spl.map \ - -o $(mmcobj)u-boot-spl - -$(mmcobj)u-boot.lds: $(LDSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ - -# create symbolic links for common files - -# from cpu directory -start.S: - @rm -f $@ - @ln -s $(TOPDIR)/arch/arm/cpu/armv7/start.S $@ - -# from board directory -mem_setup.S: - @rm -f $@ - @ln -s $(TOPDIR)/board/samsung/smdkv310/mem_setup.S $@ - -lowlevel_init.S: - @rm -f $@ - @ln -s $(TOPDIR)/board/samsung/smdkv310/lowlevel_init.S $@ - -######################################################################### - -$(obj)%.o: %.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: %.c - $(CC) $(CFLAGS) -c -o $@ $< - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/mmc_spl/board/samsung/smdkv310/u-boot.lds b/mmc_spl/board/samsung/smdkv310/u-boot.lds deleted file mode 100644 index 4a231d9..0000000 --- a/mmc_spl/board/samsung/smdkv310/u-boot.lds +++ /dev/null @@ -1,88 +0,0 @@ -/* - * (C) Copyright 2011 - * Chander Kashyap, Samsung Electronics, k.chander@samsung.com - * - * January 2004 - Changed to support H4 device - * Copyright (c) 2004-2008 Texas Instruments - * - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - __image_copy_end = .; - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -}
board/samsung/smdkv310/mmc_boot.c: Removed the typedef for "mmc data read API (copy_sd_mmc_to_mem)" as it is used only once and replaced hard-coded API address value by macro.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/smdkv310/mmc_boot.c | 15 ++++++++------- include/configs/smdkv310.h | 1 + 2 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/samsung/smdkv310/mmc_boot.c b/board/samsung/smdkv310/mmc_boot.c index 2f3e463..d3fc18d 100644 --- a/board/samsung/smdkv310/mmc_boot.c +++ b/board/samsung/smdkv310/mmc_boot.c @@ -23,15 +23,16 @@ #include<common.h> #include<config.h>
-typedef u32(*copy_sd_mmc_to_mem) \ - (u32 start_block, u32 block_count, u32 *dest_addr); - - +/* +* Copy U-boot from mmc to RAM: +* COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains +* API (Data transfer from mmc to ram) +*/ void copy_uboot_to_ram(void) { - copy_sd_mmc_to_mem copy_bl2 = (copy_sd_mmc_to_mem)(0x00002488); - copy_bl2(BL2_START_OFFSET,\ - BL2_SIZE_BLOC_COUNT, (u32 *)CONFIG_SYS_TEXT_BASE); + u32 (*copy_bl2)(u32, u32, u32) = (void *)COPY_BL2_FNPTR_ADDR; + + copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); }
void board_init_f(unsigned long bootflag) diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index cf2ef17..5cec9e3 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -93,6 +93,7 @@
/* MMC SPL */ #define CONFIG_SPL +#define COPY_BL2_FNPTR_ADDR 0x00002488
Dear Chander Kashyap,
On 21 September 2011 16:25, Chander Kashyap chander.kashyap@linaro.org wrote:
applied to u-boot-samsung
Thanks Minkyu Kang
Chander Kashyap
Minkyu Kang
