[U-Boot] [PATCH] tegra: override compiler flags for low level init code
Override -march setting for tegra to -march=armv4t for files that are necessary for low level init on tegra.
The recent change to use -march=armv7-a for armv7 caused a regression on tegra because tegra starts boot on a arm7tdmi processor before transferring control to the cortex-a9. While still executing on the arm7tdmi there are calls to getenv_ulong() and memset() that cause an illegal instruction exception if compiled for armv7.
Signed-off-by: Allen Martin amartin@nvidia.com --- arch/arm/cpu/armv7/tegra2/config.mk | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/config.mk b/arch/arm/cpu/armv7/tegra2/config.mk index fe9ef5b..4dd8cb8 100644 --- a/arch/arm/cpu/armv7/tegra2/config.mk +++ b/arch/arm/cpu/armv7/tegra2/config.mk @@ -24,10 +24,13 @@ # MA 02111-1307 USA #
-# Tegra has an ARMv4T CPU which runs board_init_f(), so we must build this -# file with compatible flags +# Tegra has an ARMv4T CPU which runs board_init_f(), so we must build these +# files with compatible flags ifdef CONFIG_TEGRA2 CFLAGS_arch/arm/lib/board.o += -march=armv4t +CFLAGS_arch/arm/lib/memset.o += -march=armv4t +CFLAGS_lib/string.o += -march=armv4t +CFLAGS_common/cmd_nvedit.o += -march=armv4t endif
USE_PRIVATE_LIBGCC = yes
Tested-by: Stephen Warren swarren@wwwdotorg.org
(This seems to be necessary to use gcc-4.6.1, but not gcc-4.5.3. The Whistler patches I just sent were tested with this fix in place)
Hi Tom, could you pick this up in u-boot-tegra? Without it tegra is currently broken in both u-boot-tegra and u-boot gits depending on the compiler you use.
-Allen
It's been there for a while, I believe, at least in u-boot-tegra/master.
Ah you're right sorry, my remote was stale. What's the next merge window to get this into u-boot/master? I imagine other people must be running into this too.
-Allen
Allen,
-----Original Message----- From: Allen Martin [mailto:amartin@nvidia.com] Sent: Monday, June 04, 2012 11:06 AM To: Stephen Warren Cc: Tom Warren; vapier@gentoo.org; wd@denx.de; u-boot@lists.denx.de Subject: Re: [PATCH] tegra: override compiler flags for low level init code
Sorry, not sure. Adding Wolfgang and Albert - it really depends on them. The pull request that contains this patch went out on Thursday.
Tom
-Allen
nvpublic
Allen Martin
Stephen Warren
Tom Warren
