[PATCH V2 00/17] Add support for J721E SK
Hi All, This series adds support for J721E SK [1]. Below is the detailed description of the J721E SoC and the SK board supporting features.
Changes in V2: Board name updated from EAIK to SK. * So changed the occurrences of EAIK to SK. * Rename files from eaik to sk.
[1] https://www.ti.com/tool/SK-TDA4VM
Sinthu Raja (17): common: make: Support show_board_info() as part of SPL build drivers: power: pmic: Add support for tps659412 PMIC drivers: power: regulator: tps65941_regulator: Add support for 3Phase buck board: ti: j721e: Guard functions with right #ifdef to avoid build warnings board: ti: j721e: Enable support for reading EEPROM at next alternate address board: ti: j721e: Add support to update board_name for j721e-sk board: ti: j721e: Disable probing of daughtercards board: ti: j721e: Add support for detecting multiple device trees arm: j721e: Add support for selecting DT based on EEPROM arm: dts: k3-j721e-r5-common-proc-board: Do not use power-domains for I2C arm: dts: k3-j721e-sk: Add initial A72 specific dts support arm: dts: k3-j721e-r5-sk: Add initial R5 specific dts support for j721e-sk configs: j721e_evm_r5: Enable support for building multiple dtbs into FIT configs: j721e_evm_a72: Add SK dtb as part of DTB FIT configs: j721e_evm_a72: Align OSPI partitions on erase block boundary configs: j721e_evm: Store env in MMC FAT partition include: configs: Update env for selecting right dtb
arch/arm/dts/Makefile | 4 +- .../arm/dts/k3-j721e-r5-common-proc-board.dts | 5 + arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi | 31 + arch/arm/dts/k3-j721e-r5-sk.dts | 646 ++++++++++++++ arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 280 +++++++ arch/arm/dts/k3-j721e-sk.dts | 791 ++++++++++++++++++ arch/arm/mach-k3/j721e_init.c | 62 ++ board/ti/j721e/evm.c | 46 +- common/Makefile | 3 +- configs/j721e_evm_a72_defconfig | 11 +- configs/j721e_evm_r5_defconfig | 4 + drivers/power/pmic/tps65941.c | 1 + drivers/power/regulator/tps65941_regulator.c | 2 + include/configs/j721e_evm.h | 4 + 14 files changed, 1876 insertions(+), 14 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-sk.dts create mode 100644 arch/arm/dts/k3-j721e-sk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-sk.dts
Enable support for show_board_info() in SPL build.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- common/Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/Makefile b/common/Makefile index e7839027b6..55e455c5b8 100644 --- a/common/Makefile +++ b/common/Makefile @@ -19,7 +19,6 @@ endif # # boards obj-y += board_f.o obj-y += board_r.o -obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-$(CONFIG_DISPLAY_BOARDINFO_LATE) += board_info.o
obj-$(CONFIG_CMD_BOOTM) += bootm.o bootm_os.o @@ -61,6 +60,8 @@ endif # !CONFIG_SPL_BUILD obj-$(CONFIG_$(SPL_TPL_)BOOTSTAGE) += bootstage.o obj-$(CONFIG_$(SPL_TPL_)BLOBLIST) += bloblist.o
+obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o + ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_DFU obj-$(CONFIG_DFU_OVER_USB) += dfu.o
OK, but why do we need this, and won't it cause every platform that has this defined to now grow in size?
Since TPS659412 and TPS659413 are both software compatible, add a compatible string for the same inside tps65941.c.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com Acked-by: Jaehoon Chung jh80.chung@samsung.com ---
No changes in V2.
drivers/power/pmic/tps65941.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/power/pmic/tps65941.c b/drivers/power/pmic/tps65941.c index 114ef4d238..83d0f83c64 100644 --- a/drivers/power/pmic/tps65941.c +++ b/drivers/power/pmic/tps65941.c @@ -71,6 +71,7 @@ static struct dm_pmic_ops tps65941_ops = {
static const struct udevice_id tps65941_ids[] = { { .compatible = "ti,tps659411", .data = TPS659411 }, + { .compatible = "ti,tps659412", .data = TPS659411 }, { .compatible = "ti,tps659413", .data = TPS659413 }, { .compatible = "ti,lp876441", .data = LP876441 }, { }
Buck regulator 1, 2 and 3 of TPS6594132 on j721e-sk is in 3 Phase confguration, in-order to support this, add configuring 3 Phase buck in tps65941 while driver probing.
No changes in V2.
drivers/power/regulator/tps65941_regulator.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/power/regulator/tps65941_regulator.c b/drivers/power/regulator/tps65941_regulator.c index d73f832483..89918c38fa 100644 --- a/drivers/power/regulator/tps65941_regulator.c +++ b/drivers/power/regulator/tps65941_regulator.c @@ -299,6 +299,8 @@ static int tps65941_buck_probe(struct udevice *dev) idx = 1; } else if (idx == 34) { idx = 3; + } else if (idx == 123) { + idx = 1; } else if (idx == 1234) { idx = 1; } else {
board_late_init(), setup_board_eeprom_env() and setup_serial() is called only under CONFIG_BOARD_LATE_INIT, so guard these functions with the same.
No chnages in V2.
board/ti/j721e/evm.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 077d83420c..9cdb963221 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -172,6 +172,7 @@ int checkboard(void) return 0; }
+#ifdef CONFIG_BOARD_LATE_INIT static void setup_board_eeprom_env(void) { char *name = "j721e"; @@ -210,6 +211,7 @@ static void setup_serial(void) snprintf(serial_string, sizeof(serial_string), "%016lx", board_serial); env_set("serial#", serial_string); } +#endif
/* * Declaration of daughtercards to probe. Note that when adding more @@ -413,6 +415,7 @@ void configure_serdes_torrent(void) printf("phy_power_on failed !!\n"); }
+#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { @@ -428,6 +431,7 @@ int board_late_init(void)
return 0; } +#endif
void spl_board_init(void) {
No chnages in V2.
We should probably re-order the code so that everything is under a single #ifdef.
J721E EVM has EEPROM populated at 0x50. J721E SK has EEPROM populated at next address 0x51 in order to be compatible with RBPi. So start looking for TI specific EEPROM at 0x50, if not found look for EEPROM at 0x51.
No changes in V2.
board/ti/j721e/evm.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 9cdb963221..989e15e666 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -152,9 +152,15 @@ int do_board_detect(void)
ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); - if (ret) - pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", - CONFIG_EEPROM_CHIP_ADDRESS, ret); + if (ret) { + printf("EEPROM not available at 0x%02x, trying to read at 0x%02x\n", + CONFIG_EEPROM_CHIP_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS + 1); + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, + CONFIG_EEPROM_CHIP_ADDRESS + 1); + if (ret) + pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", + CONFIG_EEPROM_CHIP_ADDRESS + 1, ret); + }
return ret; }
Minor, since I'm asking for other changes, please say "RPi" or "Raspberry Pi" not "RBPi".
Update setup_board_eeprom_env() to choose the right board name for j721e-sk.
Changes in V2: * J721E EAIK board name is changed to J721E SK, rename all occurrences of eaik to sk * Quite amount of SK boards are preprogrammed as EAIK in EEPROM, so retaining the condition to check the board name as eaik.
board/ti/j721e/evm.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 989e15e666..9d4609cfe9 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -30,6 +30,9 @@ #define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ board_ti_k3_is("J721EX-PM2-SOM"))
+#define board_is_j721e_sk() (board_ti_k3_is("J721EX-EAIK") || \ + board_ti_k3_is("J721EX-SK")) + #define board_is_j7200_som() (board_ti_k3_is("J7200X-PM1-SOM") || \ board_ti_k3_is("J7200X-PM2-SOM"))
@@ -188,6 +191,8 @@ static void setup_board_eeprom_env(void)
if (board_is_j721e_som()) name = "j721e"; + else if (board_is_j721e_sk()) + name = "j721e-sk"; else if (board_is_j7200_som()) name = "j7200"; else
j721e-sk doesn't have any daughter cards, so disable daughter card probing inside board_late_init() and spl_board_init() for j721e-sk.
Changes in V2: * J721E EAIK board name is changed to J721E SK, rename all occurrences of eaik to sk.
board/ti/j721e/evm.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 9d4609cfe9..cb491ad950 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -434,7 +434,8 @@ int board_late_init(void) setup_serial();
/* Check for and probe any plugged-in daughtercards */ - probe_daughtercards(); + if (!board_is_j721e_sk()) + probe_daughtercards(); }
if (board_is_j7200_som()) @@ -453,8 +454,10 @@ void spl_board_init(void)
if ((IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM)) && - IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) - probe_daughtercards(); + IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { + if (!board_is_j721e_sk()) + probe_daughtercards(); + }
#ifdef CONFIG_ESM_K3 if (board_ti_k3_is("J721EX-PM2-SOM")) {
Changes in V2:
- J721E EAIK board name is changed to J721E SK, rename all occurrences of eaik
to sk.
This should be a positive check for the board(s) which can even have daughtercards.
Hi Tom,
Changes in V2:
to sk.
Agreed, will update as positive check.
Regards Sinthu Raja
-- Tom
Update the board_fit_config_name_match() to choose the right dtb based on the board name read from EEPROM.
Also restrict multpile EEPROM reads by verifying if EEPROM is already read.
board/ti/j721e/evm.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index cb491ad950..31de53ea71 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -88,8 +88,17 @@ int dram_init_banksize(void) #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { - if (!strcmp(name, "k3-j721e-common-proc-board")) - return 0; + bool eeprom_read = board_ti_was_eeprom_read(); + + if (!eeprom_read || board_is_j721e_som()) { + if (!strcmp(name, "k3-j721e-common-proc-board") || + !strcmp(name, "k3-j721e-r5-common-proc-board")) + return 0; + } else if (board_is_j721e_sk()) { + if (!strcmp(name, "k3-j721e-sk") || + !strcmp(name, "k3-j721e-r5-sk")) + return 0; + }
return -1; } @@ -153,6 +162,9 @@ int do_board_detect(void) { int ret;
+ if (board_ti_was_eeprom_read()) + return 0; + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); if (ret) {
Enable support for selecting DTB from FIT within SPL based on the board name read from EEPROM. This will help to use single defconfig for both EVM and SK.
Also print FDT model name and board name read from EEPROM on SPL debug console. This is useful to verify that right dtb is loaded in each boot stage.
No changes in V2.
arch/arm/mach-k3/j721e_init.c | 62 +++++++++++++++++++++++++++++++++++ 1 file changed, 62 insertions(+)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 78d80be175..53ea4692f6 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -21,6 +21,7 @@ #include <dm/pinctrl.h> #include <mmc.h> #include <remoteproc.h> +#include <dm/root.h>
#ifdef CONFIG_SPL_BUILD #ifdef CONFIG_K3_LOAD_SYSFW @@ -135,6 +136,59 @@ static void store_boot_info_from_rom(void) sizeof(struct rom_extended_boot_data)); }
+#ifdef CONFIG_SPL_OF_LIST +void do_dt_magic(void) +{ + int ret, rescan, mmc_dev = -1; + static struct mmc *mmc; + + if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) + do_board_detect(); + + /* + * Board detection has been done. + * Let us see if another dtb wouldn't be a better match + * for our board + */ + if (IS_ENABLED(CONFIG_CPU_V7R)) { + ret = fdtdec_resetup(&rescan); + if (!ret && rescan) { + dm_uninit(); + dm_init_and_scan(true); + } + } + + /* + * Because of multi DTB configuration, the MMC device has + * to be re-initialized after reconfiguring FDT inorder to + * boot from MMC. Do this when boot mode is MMC and ROM has + * not loaded SYSFW. + */ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: + mmc_dev = 0; + break; + case BOOT_DEVICE_MMC2: + case BOOT_DEVICE_MMC2_2: + mmc_dev = 1; + break; + } + + if (mmc_dev > 0 && !is_rom_loaded_sysfw(&bootdata)) { + ret = mmc_init_device(mmc_dev); + if (!ret) { + mmc = find_mmc_device(mmc_dev); + if (mmc) { + ret = mmc_init(mmc); + if (ret) { + printf("mmc init failed with error: %d\n", ret); + } + } + } + } +} +#endif + void board_init_f(ulong dummy) { #if defined(CONFIG_K3_J721E_DDRSS) || defined(CONFIG_K3_LOAD_SYSFW) @@ -180,6 +234,10 @@ void board_init_f(ulong dummy) k3_sysfw_loader(is_rom_loaded_sysfw(&bootdata), k3_mmc_stop_clock, k3_mmc_restart_clock);
+#ifdef CONFIG_SPL_OF_LIST + do_dt_magic(); +#endif + /* * Force probe of clk_k3 driver here to ensure basic default clock * configuration is always done. @@ -210,6 +268,10 @@ void board_init_f(ulong dummy) preloader_console_init(); #endif
+#if defined(CONFIG_DISPLAY_BOARDINFO) + show_board_info(); +#endif + /* Output System Firmware version info */ k3_sysfw_print_ver();
No changes in V2.
The EEPROM scheme is not K3-generic, but rather TI reference platform specific, so this needs to be abstracted to exist and be called from under board/ti/j721e/.. thanks.
Hi Tom,
No changes in V2.
I guess the commit description is a little misleading. It just calls the board_detect function which is existed under the board/ti/j721e. Printing of board info is not required here which can be removed.
Regards, Sinthu Raja.
-- Tom
On Fri, Nov 12, 2021 at 07:02:49PM +0530, Sinthu Raja M wrote:
Hi Tom,
No changes in V2.
Right, but board/ti/j721e/ code is not relevant to non-TI reference platforms. The code under arch/arm/mach-k3/ needs to be SoC centric, and the TI reference platforms and their shared EEPROM stuff needs to be under board/ti/. It also needs to be as clear as possible how to remove it as custom platforms don't usually copy this EEPROM scheme and this adds confusion on their part.
Board ID I2C EEPROM will be probed before SYSFW is available. So drop the power-domains property for wakup_i2c0 on which board ID EEPROM is connected.
No Changes in V2.
arch/arm/dts/k3-j721e-r5-common-proc-board.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts index 4b2362a5dd..88a69bf066 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -361,3 +361,8 @@ &mcu_udmap { ti,sci = <&dm_tifs>; }; + +/* EEPROM might be read before SYSFW is available */ +&wkup_i2c0 { + /delete-property/ power-domains; +};
No Changes in V2.
- /delete-property/ power-domains;
Has this been queued up for linux-next or similar yet?
Hi Tom,
No Changes in V2.
Yes, this is queued in linux-next [1].
[1] https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/tree/arc...
-- Tom
On Fri, Nov 12, 2021 at 05:28:07PM +0530, Sinthu Raja M wrote:
Hi Tom,
No Changes in V2.
OK, since all of the dts stuff is queued up, that's good and important as it will also be re-synced later directly from kernel.org so anything not there must be in -u-boot.dtsi files and with very good reasoning.
J721E Starter Kit (SK)[1] is a low cost, small form factor board designed for TI’s J721E SoC. TI’s J721E SoC comprises of dual core A72, high performance vision accelerators, video codec accelerators, latest C71x and C66x DSP, high bandwidth real-time IPs for capture and display, GPU, dedicated safety island and security accelerators. The SoC is power optimized to provide best in class performance for industrial and automotive applications.
J721E SK supports the following interfaces: * 4 GB LPDDR4 RAM * x1 Gigabit Ethernet interface * x1 USB 3.0 Type-C port * x3 USB 3.0 Type-A ports * x1 PCIe M.2 E Key * x1 PCIe M.2 M Key * 512 Mbit OSPI flash * x2 CSI2 Camera interface (RPi and TI Camera connector) * 40-pin Raspberry Pi GPIO header
Add A72 specific dts for J721E-SK.
Changes in V2: * J721E EAIK board name is changed to J721E SK, rename all occurrences of eaik to sk. * Rename file from eaik to sk.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 280 ++++++++++ arch/arm/dts/k3-j721e-sk.dts | 791 +++++++++++++++++++++++++++ 3 files changed, 1073 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-j721e-sk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-sk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a88aecc5bd..8918dfc48e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1113,7 +1113,8 @@ dtb-$(CONFIG_SOC_K3_AM6) += \ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-r5-common-proc-board.dtb \ k3-j7200-common-proc-board.dtb \ - k3-j7200-r5-common-proc-board.dtb + k3-j7200-r5-common-proc-board.dtb \ + k3-j721e-sk.dtb dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ k3-am642-r5-evm.dtb \ k3-am642-sk.dtb \ diff --git a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi new file mode 100644 index 0000000000..94b9e09e30 --- /dev/null +++ b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi @@ -0,0 +1,280 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <dt-bindings/net/ti-dp83867.h> + +/ { + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + aliases { + ethernet0 = &cpsw_port1; + spi0 = &ospi0; + remoteproc0 = &mcu_r5fss0_core0; + remoteproc1 = &mcu_r5fss0_core1; + remoteproc2 = &main_r5fss0_core0; + remoteproc3 = &main_r5fss0_core1; + remoteproc4 = &main_r5fss1_core0; + remoteproc5 = &main_r5fss1_core1; + remoteproc6 = &c66_0; + remoteproc7 = &c66_1; + remoteproc8 = &c71_0; + i2c0 = &wkup_i2c0; + i2c1 = &mcu_i2c0; + i2c2 = &main_i2c0; + mmc1 = &main_sdhci1; /* SD Card */ + }; +}; + +&cbass_main{ + u-boot,dm-spl; + + main-navss { + u-boot,dm-spl; + }; +}; + +&cbass_mcu_wakeup { + u-boot,dm-spl; + + timer1: timer@40400000 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x40400000 0x0 0x80>; + ti,timer-alwon; + clock-frequency = <25000000>; + u-boot,dm-spl; + }; + + mcu-navss { + u-boot,dm-spl; + + ringacc@2b800000 { + reg = <0x0 0x2b800000 0x0 0x400000>, + <0x0 0x2b000000 0x0 0x400000>, + <0x0 0x28590000 0x0 0x100>, + <0x0 0x2a500000 0x0 0x40000>, + <0x0 0x28440000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; + u-boot,dm-spl; + }; + + dma-controller@285c0000 { + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x284c0000 0x0 0x4000>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x284a0000 0x0 0x4000>, + <0x0 0x2aa00000 0x0 0x40000>, + <0x0 0x28400000 0x0 0x2000>; + reg-names = "gcfg", "rchan", "rchanrt", "tchan", + "tchanrt", "rflow"; + u-boot,dm-spl; + }; + }; + + chipid@43000014 { + u-boot,dm-spl; + }; +}; + +&secure_proxy_main { + u-boot,dm-spl; +}; + +&dmsc { + u-boot,dm-spl; + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + u-boot,dm-spl; + }; +}; + +&k3_pds { + u-boot,dm-spl; +}; + +&k3_clks { + u-boot,dm-spl; +}; + +&k3_reset { + u-boot,dm-spl; +}; + +&wkup_pmx0 { + u-boot,dm-spl; +}; + +&main_pmx0 { + u-boot,dm-spl; +}; + +&main_uart0 { + u-boot,dm-spl; +}; + +&mcu_uart0 { + u-boot,dm-spl; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + u-boot,dm-spl; +}; + +&wiz3_pll1_refclk { + assigned-clocks = <&wiz3_pll1_refclk>, <&wiz3_pll0_refclk>; + assigned-clock-parents = <&k3_clks 295 0>, <&k3_clks 295 9>; +}; + +&main_usbss0_pins_default { + u-boot,dm-spl; +}; + +&usbss0 { + u-boot,dm-spl; +}; + +&usb0 { + dr_mode = "host"; + u-boot,dm-spl; +}; + +&wiz2_pll1_refclk { + assigned-clocks = <&wiz2_pll1_refclk>, <&wiz2_pll0_refclk>; + assigned-clock-parents = <&k3_clks 294 0>, <&k3_clks 294 11>; +}; + +&main_usbss1_pins_default { + u-boot,dm-spl; +}; + +&usbss1 { + u-boot,dm-spl; +}; + +&usb1 { + dr_mode = "host"; + u-boot,dm-spl; +}; + +&mcu_cpsw { + reg = <0x0 0x46000000 0x0 0x200000>, + <0x0 0x40f00200 0x0 0x2>; + reg-names = "cpsw_nuss", "mac_efuse"; + /delete-property/ ranges; + + cpsw-phy-sel@40f04040 { + compatible = "ti,am654-cpsw-phy-sel"; + reg= <0x0 0x40f04040 0x0 0x4>; + reg-names = "gmii-sel"; + }; +}; + +&main_mmc1_pins_default { + u-boot,dm-spl; +}; + +&wkup_i2c0_pins_default { + u-boot,dm-spl; +}; + +&wkup_i2c0 { + u-boot,dm-spl; +}; + +&mcu_i2c0 { + u-boot,dm-spl; +}; + +&mcu_i2c1 { + status = "disabled"; +}; + +&main_i2c0 { + status = "disabled"; +}; + +&main_i2c1 { + status = "disabled"; +}; + +&main_i2c2 { + status = "disabled"; +}; + +&main_i2c3 { + status = "disabled"; +}; + +&main_i2c4 { + status = "disabled"; +}; + +&main_i2c5 { + status = "disabled"; +}; + +&main_i2c6 { + status = "disabled"; +}; + +&mcu_i2c0_pins_default { + u-boot,dm-spl; +}; + +&mcu_fss0_ospi0_pins_default { + u-boot,dm-spl; +}; + +&fss { + u-boot,dm-spl; +}; + +&ospi0 { + u-boot,dm-spl; + + flash@0 { + u-boot,dm-spl; + + partition@3fc0000 { + label = "ospi.phypattern"; + reg = <0x3fc0000 0x40000>; + u-boot,dm-spl; + }; + }; +}; + +&serdes_ln_ctrl { + u-boot,mux-autoprobe; +}; + +&usb_serdes_mux { + u-boot,mux-autoprobe; +}; + +&pcie0_rc { + status = "disabled"; +}; + +&pcie1_rc { + status = "disabled"; +}; + +&pcie0_ep { + status = "disabled"; +}; + +&pcie1_ep { + status = "disabled"; +}; + +&dss { + status = "disabled"; +}; diff --git a/arch/arm/dts/k3-j721e-sk.dts b/arch/arm/dts/k3-j721e-sk.dts new file mode 100644 index 0000000000..4443cd0128 --- /dev/null +++ b/arch/arm/dts/k3-j721e-sk.dts @@ -0,0 +1,791 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721e.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/net/ti-dp83867.h> + +/ { + compatible = "ti,j721e-sk", "ti,j721e"; + model = "Texas Instruments J721E SK A72"; + + chosen { + stdout-path = "serial2:115200n8"; + bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; + }; + + memory@80000000 { + device_type = "memory"; + /* 4G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>, + <0x00000008 0x80000000 0x00000000 0x80000000>; + }; + + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + alignment = <0x1000>; + no-map; + }; + + mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa0000000 0x00 0x100000>; + no-map; + }; + + mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa0100000 0x00 0xf00000>; + no-map; + }; + + mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa1000000 0x00 0x100000>; + no-map; + }; + + mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa1100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa2000000 0x00 0x100000>; + no-map; + }; + + main_r5fss0_core0_memory_region: r5f-memory@a2100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa2100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa3000000 0x00 0x100000>; + no-map; + }; + + main_r5fss0_core1_memory_region: r5f-memory@a3100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa3100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss1_core0_dma_memory_region: r5f-dma-memory@a4000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa4000000 0x00 0x100000>; + no-map; + }; + + main_r5fss1_core0_memory_region: r5f-memory@a4100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa4100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss1_core1_dma_memory_region: r5f-dma-memory@a5000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa5000000 0x00 0x100000>; + no-map; + }; + + main_r5fss1_core1_memory_region: r5f-memory@a5100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa5100000 0x00 0xf00000>; + no-map; + }; + + c66_1_dma_memory_region: c66-dma-memory@a6000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa6000000 0x00 0x100000>; + no-map; + }; + + c66_0_memory_region: c66-memory@a6100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa6100000 0x00 0xf00000>; + no-map; + }; + + c66_0_dma_memory_region: c66-dma-memory@a7000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa7000000 0x00 0x100000>; + no-map; + }; + + c66_1_memory_region: c66-memory@a7100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa7100000 0x00 0xf00000>; + no-map; + }; + + c71_0_dma_memory_region: c71-dma-memory@a8000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa8000000 0x00 0x100000>; + no-map; + }; + + c71_0_memory_region: c71-memory@a8100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa8100000 0x00 0xf00000>; + no-map; + }; + + rtos_ipc_memory_region: ipc-memories@aa000000 { + reg = <0x00 0xaa000000 0x00 0x01c00000>; + alignment = <0x1000>; + no-map; + }; + }; + + vusb_main: fixedregulator-vusb-main5v0 { + /* USB MAIN INPUT 5V DC */ + compatible = "regulator-fixed"; + regulator-name = "vusb-main5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5141 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vusb_main>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_mmc1: fixedregulator-sd { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&vdd_mmc1_en_pins_default>; + regulator-name = "vdd_mmc1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + enable-active-high; + vin-supply = <&vsys_3v3>; + gpio = <&wkup_gpio0 8 GPIO_ACTIVE_HIGH>; + }; + + vdd_sd_dv_alt: gpio-regulator-tps659411 { + compatible = "regulator-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&vdd_sd_dv_alt_pins_default>; + regulator-name = "tps659411"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + vin-supply = <&vsys_3v3>; + gpios = <&wkup_gpio0 9 GPIO_ACTIVE_LOW>; + states = <3300000 0x0>, + <1800000 0x1>; + }; +}; + +&main_pmx0 { + main_mmc1_pins_default: main-mmc1-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */ + J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */ + J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ + J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */ + J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */ + J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */ + J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */ + >; + }; + + main_uart0_pins_default: main-uart0-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x1f0, PIN_INPUT, 0) /* (AC2) UART0_CTSn */ + J721E_IOPAD(0x1f4, PIN_OUTPUT, 0) /* (AB1) UART0_RTSn */ + J721E_IOPAD(0x1e8, PIN_INPUT, 0) /* (AB2) UART0_RXD */ + J721E_IOPAD(0x1ec, PIN_OUTPUT, 0) /* (AB3) UART0_TXD */ + >; + }; + + main_i2c0_pins_default: main-i2c0-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */ + J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */ + >; + }; + + main_i2c1_pins_default: main-i2c1-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */ + J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */ + >; + }; + + main_i2c3_pins_default: main-i2c3-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */ + J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */ + >; + }; + + mcu_i2c0_pins_default: mcu-i2c0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x100, PIN_INPUT, 0) /* (J26) MCU_I2C0_SCL */ + J721E_WKUP_IOPAD(0x104, PIN_INPUT, 0) /* (H25) MCU_I2C0_SDA */ + >; + }; + + main_usbss0_pins_default: main-usbss0-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */ + J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */ + >; + }; + + main_usbss1_pins_default: main-usbss1-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */ + >; + }; +}; + +&wkup_pmx0 { + mcu_cpsw_pins_default: mcu-cpsw-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x84, PIN_INPUT, 0) /* (B24) MCU_RGMII1_RD0 */ + J721E_WKUP_IOPAD(0x80, PIN_INPUT, 0) /* (A24) MCU_RGMII1_RD1 */ + J721E_WKUP_IOPAD(0x7c, PIN_INPUT, 0) /* (D24) MCU_RGMII1_RD2 */ + J721E_WKUP_IOPAD(0x78, PIN_INPUT, 0) /* (A25) MCU_RGMII1_RD3 */ + J721E_WKUP_IOPAD(0x74, PIN_INPUT, 0) /* (C24) MCU_RGMII1_RXC */ + J721E_WKUP_IOPAD(0x5c, PIN_INPUT, 0) /* (C25) MCU_RGMII1_RX_CTL */ + J721E_WKUP_IOPAD(0x6c, PIN_OUTPUT, 0) /* (B25) MCU_RGMII1_TD0 */ + J721E_WKUP_IOPAD(0x68, PIN_OUTPUT, 0) /* (A26) MCU_RGMII1_TD1 */ + J721E_WKUP_IOPAD(0x64, PIN_OUTPUT, 0) /* (A27) MCU_RGMII1_TD2 */ + J721E_WKUP_IOPAD(0x60, PIN_OUTPUT, 0) /* (A28) MCU_RGMII1_TD3 */ + J721E_WKUP_IOPAD(0x70, PIN_OUTPUT, 0) /* (B26) MCU_RGMII1_TXC */ + J721E_WKUP_IOPAD(0x58, PIN_OUTPUT, 0) /* (B27) MCU_RGMII1_TX_CTL */ + >; + }; + + mcu_mdio_pins_default: mcu-mdio1-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x8c, PIN_OUTPUT, 0) /* (F23) MCU_MDIO0_MDC */ + J721E_WKUP_IOPAD(0x88, PIN_INPUT, 0) /* (E23) MCU_MDIO0_MDIO */ + >; + }; + + mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 0) /* (E20) MCU_OSPI0_CLK */ + J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 0) /* (F19) MCU_OSPI0_CSn0 */ + J721E_WKUP_IOPAD(0xc, PIN_INPUT, 0) /* (D20) MCU_OSPI0_D0 */ + J721E_WKUP_IOPAD(0x10, PIN_INPUT, 0) /* (G19) MCU_OSPI0_D1 */ + J721E_WKUP_IOPAD(0x14, PIN_INPUT, 0) /* (G20) MCU_OSPI0_D2 */ + J721E_WKUP_IOPAD(0x18, PIN_INPUT, 0) /* (F20) MCU_OSPI0_D3 */ + J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 0) /* (F21) MCU_OSPI0_D4 */ + J721E_WKUP_IOPAD(0x20, PIN_INPUT, 0) /* (E21) MCU_OSPI0_D5 */ + J721E_WKUP_IOPAD(0x24, PIN_INPUT, 0) /* (B22) MCU_OSPI0_D6 */ + J721E_WKUP_IOPAD(0x28, PIN_INPUT, 0) /* (G21) MCU_OSPI0_D7 */ + J721E_WKUP_IOPAD(0x8, PIN_INPUT, 0) /* (D21) MCU_OSPI0_DQS */ + >; + }; + + vdd_mmc1_en_pins_default: vdd-mmc1-en-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xd0, PIN_OUTPUT, 7) /* (G27) WKUP_GPIO0_8 */ + >; + }; + + vdd_sd_dv_alt_pins_default: vdd-sd-dv-alt-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xd4, PIN_OUTPUT, 7) /* (G26) WKUP_GPIO0_9 */ + >; + }; + + wkup_i2c0_pins_default: wkup-i2c0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf8, PIN_INPUT_PULLUP, 0) /* (J25) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0xfc, PIN_INPUT_PULLUP, 0) /* (H24) WKUP_I2C0_SDA */ + >; + }; +}; + +&wkup_uart0 { + /* Wakeup UART is used by System firmware */ + status = "reserved"; +}; + +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; + /* Shared with ATF on this platform */ + power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; +}; + +&main_uart2 { + /* Brought out on RPi header */ + status = "disabled"; +}; + +&main_uart3 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart5 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart6 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart7 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart8 { + /* UART not brought out */ + status = "disabled"; +}; + +&main_uart9 { + /* Brought out on M.2 E Key */ + status = "disabled"; +}; + +&main_sdhci0 { + /* Unused */ + status = "disabled"; +}; + +&main_sdhci1 { + /* SD Card */ + vmmc-supply = <&vdd_mmc1>; + vqmmc-supply = <&vdd_sd_dv_alt>; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; +}; + +&main_sdhci2 { + /* Unused */ + status = "disabled"; +}; + +&ospi0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_fss0_ospi0_pins_default>; + + flash@0{ + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <8>; + spi-rx-bus-width = <8>; + spi-max-frequency = <25000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <4>; + cdns,phy-mode; + cdns,phy-tx-start = <18>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&ospi1 { + /* Unused */ + status = "disabled"; +}; + +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c1_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c3_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c4 { + /* Unused */ + status = "disabled"; +}; + +&main_i2c5 { + /* Brought out on RPi Header */ + status = "disabled"; +}; + +&main_i2c6 { + /* Unused */ + status = "disabled"; +}; + +&mcu_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_i2c0_pins_default>; + clock-frequency = <400000>; +}; + +&usb_serdes_mux { + idle-states = <1>, <1>; /* USB0 to SERDES3, USB1 to SERDES2 */ +}; + +&serdes_ln_ctrl { + idle-states = <J721E_SERDES0_LANE0_PCIE0_LANE0>, <J721E_SERDES0_LANE1_IP4_UNUSED>, + <J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>, + <J721E_SERDES2_LANE0_IP1_UNUSED>, <J721E_SERDES2_LANE1_USB3_1>, + <J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>, + <J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>, + <J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>; +}; + +&serdes_wiz3 { + typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>; + typec-dir-debounce-ms = <700>; /* TUSB321, tCCB_DEFAULT 133 ms */ +}; + +&serdes3 { + serdes3_usb_link: link@0 { + reg = <0>; + cdns,num-lanes = <2>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_USB3>; + resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>; + }; +}; + +&usbss0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss0_pins_default>; + ti,vbus-divider; +}; + +&usb0 { + dr_mode = "otg"; + maximum-speed = "super-speed"; + phys = <&serdes3_usb_link>; + phy-names = "cdns3,usb3-phy"; +}; + +&serdes2 { + serdes2_usb_link: link@1 { + reg = <1>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_USB3>; + resets = <&serdes_wiz2 2>; + }; +}; + +&usbss1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss1_pins_default>; + ti,vbus-divider; +}; + +&usb1 { + dr_mode = "host"; + maximum-speed = "super-speed"; + phys = <&serdes2_usb_link>; + phy-names = "cdns3,usb3-phy"; +}; + +&tscadc0 { + /* Unused */ + status = "disabled"; +}; + +&tscadc1 { + /* Unused */ + status = "disabled"; +}; + +&mcu_cpsw { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; +}; + +&davinci_mdio { + phy0: ethernet-phy@0 { + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&phy0>; +}; + +&dss { + assigned-clocks = <&k3_clks 152 1>, /* VP 1 pixel clock */ + <&k3_clks 152 4>, /* VP 2 pixel clock */ + <&k3_clks 152 9>, /* VP 3 pixel clock */ + <&k3_clks 152 13>; /* VP 4 pixel clock */ + assigned-clock-parents = <&k3_clks 152 2>, /* PLL16_HSDIV0 */ + <&k3_clks 152 6>, /* DPI0_EXT_CLKSEL_OUT0 */ + <&k3_clks 152 11>, /* PLL18_HSDIV0 */ + <&k3_clks 152 18>; /* DPI1_EXT_CLKSEL_OUT0 */ +}; + +&mcasp0 { + /* Unused */ + status = "disabled"; +}; + +&mcasp1 { + /* Unused */ + status = "disabled"; +}; + +&mcasp2 { + /* Unused */ + status = "disabled"; +}; + +&mcasp3 { + /* Unused */ + status = "disabled"; +}; + +&mcasp4 { + /* Unused */ + status = "disabled"; +}; + +&mcasp5 { + /* Unused */ + status = "disabled"; +}; + +&mcasp6 { + /* Brought out on RPi header */ + status = "disabled"; +}; + +&mcasp7 { + /* Unused */ + status = "disabled"; +}; + +&mcasp8 { + /* Unused */ + status = "disabled"; +}; + +&mcasp9 { + /* Unused */ + status = "disabled"; +}; + +&mcasp10 { + /* Unused */ + status = "disabled"; +}; + +&mcasp11 { + /* Brought out on M.2 E Key */ + status = "disabled"; +}; + +&pcie2_rc { + /* Unused */ + status = "disabled"; +}; + +&pcie2_ep { + /* Unused */ + status = "disabled"; +}; + +&pcie3_rc { + /* Unused */ + status = "disabled"; +}; + +&pcie3_ep { + /* Unused */ + status = "disabled"; +}; + +&mailbox0_cluster0 { + interrupts = <436>; + + mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster1 { + interrupts = <432>; + + mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster2 { + interrupts = <428>; + + mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster3 { + interrupts = <424>; + + mbox_c66_0: mbox-c66-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_c66_1: mbox-c66-1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster4 { + interrupts = <420>; + + mbox_c71_0: mbox-c71-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; +}; + +&mailbox0_cluster5 { + status = "disabled"; +}; + +&mailbox0_cluster6 { + status = "disabled"; +}; + +&mailbox0_cluster7 { + status = "disabled"; +}; + +&mailbox0_cluster8 { + status = "disabled"; +}; + +&mailbox0_cluster9 { + status = "disabled"; +}; + +&mailbox0_cluster10 { + status = "disabled"; +}; + +&mailbox0_cluster11 { + status = "disabled"; +}; + +&mcu_r5fss0_core0 { + mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>; + memory-region = <&mcu_r5fss0_core0_dma_memory_region>, + <&mcu_r5fss0_core0_memory_region>; +}; + +&mcu_r5fss0_core1 { + mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>; + memory-region = <&mcu_r5fss0_core1_dma_memory_region>, + <&mcu_r5fss0_core1_memory_region>; +}; + +&main_r5fss0_core0 { + mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>; + memory-region = <&main_r5fss0_core0_dma_memory_region>, + <&main_r5fss0_core0_memory_region>; +}; + +&main_r5fss0_core1 { + mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>; + memory-region = <&main_r5fss0_core1_dma_memory_region>, + <&main_r5fss0_core1_memory_region>; +}; + +&main_r5fss1_core0 { + mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>; + memory-region = <&main_r5fss1_core0_dma_memory_region>, + <&main_r5fss1_core0_memory_region>; +}; + +&main_r5fss1_core1 { + mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>; + memory-region = <&main_r5fss1_core1_dma_memory_region>, + <&main_r5fss1_core1_memory_region>; +}; + +&c66_0 { + mboxes = <&mailbox0_cluster3 &mbox_c66_0>; + memory-region = <&c66_0_dma_memory_region>, + <&c66_0_memory_region>; +}; + +&c66_1 { + mboxes = <&mailbox0_cluster3 &mbox_c66_1>; + memory-region = <&c66_1_dma_memory_region>, + <&c66_1_memory_region>; +}; + +&c71_0 { + mboxes = <&mailbox0_cluster4 &mbox_c71_0>; + memory-region = <&c71_0_dma_memory_region>, + <&c71_0_memory_region>; +};
Changes in V2:
to sk.
- Rename file from eaik to sk.
Has arch/arm/dts/k3-j721e-sk.dts been queued up in linux-next or similar yet?
Hi Tom,
Changes in V2:
to sk.
-- Tom
Add R5 specific dts for J721E-SK
arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi | 31 ++ arch/arm/dts/k3-j721e-r5-sk.dts | 646 ++++++++++++++++++++++++ 3 files changed, 679 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-sk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8918dfc48e..3581c925fc 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1114,7 +1114,8 @@ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-r5-common-proc-board.dtb \ k3-j7200-common-proc-board.dtb \ k3-j7200-r5-common-proc-board.dtb \ - k3-j721e-sk.dtb + k3-j721e-sk.dtb \ + k3-j721e-r5-sk.dtb dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ k3-am642-r5-evm.dtb \ k3-am642-sk.dtb \ diff --git a/arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi new file mode 100644 index 0000000000..71d16f193f --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-sk-u-boot.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-j721e-sk-u-boot.dtsi" + +/ { + chosen { + firmware-loader = &fs_loader0; + }; + + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a72_0; + remoteproc2 = &main_r5fss0_core0; + remoteproc3 = &main_r5fss0_core1; + }; + + fs_loader0: fs_loader@0 { + u-boot,dm-pre-reloc; + compatible = "u-boot,fs-loader"; + }; +}; + +&tps659412 { + esm: esm { + compatible = "ti,tps659413-esm"; + u-boot,dm-spl; + }; +}; diff --git a/arch/arm/dts/k3-j721e-r5-sk.dts b/arch/arm/dts/k3-j721e-r5-sk.dts new file mode 100644 index 0000000000..abce864fff --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-sk.dts @@ -0,0 +1,646 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721e.dtsi" +#include "k3-j721e-ddr-evm-lp4-4266.dtsi" +#include "k3-j721e-ddr.dtsi" + +/ { + model = "Texas Instruments J721E SK R5"; + + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a72_0; + }; + + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + memory@80000000 { + device_type = "memory"; + /* 4G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>, + <0x00000008 0x80000000 0x00000000 0x80000000>; + }; + + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + alignment = <0x1000>; + no-map; + }; + + mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa0000000 0x00 0x100000>; + no-map; + }; + + mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa0100000 0x00 0xf00000>; + no-map; + }; + + mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa1000000 0x00 0x100000>; + no-map; + }; + + mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa1100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa2000000 0x00 0x100000>; + no-map; + }; + + main_r5fss0_core0_memory_region: r5f-memory@a2100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa2100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa3000000 0x00 0x100000>; + no-map; + }; + + main_r5fss0_core1_memory_region: r5f-memory@a3100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa3100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss1_core0_dma_memory_region: r5f-dma-memory@a4000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa4000000 0x00 0x100000>; + no-map; + }; + + main_r5fss1_core0_memory_region: r5f-memory@a4100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa4100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss1_core1_dma_memory_region: r5f-dma-memory@a5000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa5000000 0x00 0x100000>; + no-map; + }; + + main_r5fss1_core1_memory_region: r5f-memory@a5100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa5100000 0x00 0xf00000>; + no-map; + }; + + c66_1_dma_memory_region: c66-dma-memory@a6000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa6000000 0x00 0x100000>; + no-map; + }; + + c66_0_memory_region: c66-memory@a6100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa6100000 0x00 0xf00000>; + no-map; + }; + + c66_0_dma_memory_region: c66-dma-memory@a7000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa7000000 0x00 0x100000>; + no-map; + }; + + c66_1_memory_region: c66-memory@a7100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa7100000 0x00 0xf00000>; + no-map; + }; + + c71_0_dma_memory_region: c71-dma-memory@a8000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa8000000 0x00 0x100000>; + no-map; + }; + + c71_0_memory_region: c71-memory@a8100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa8100000 0x00 0xf00000>; + no-map; + }; + + rtos_ipc_memory_region: ipc-memories@aa000000 { + reg = <0x00 0xaa000000 0x00 0x01c00000>; + alignment = <0x1000>; + no-map; + }; + }; + + a72_0: a72@0 { + compatible = "ti,am654-rproc"; + reg = <0x0 0x00a90000 0x0 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 202 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 202 0>; + clocks = <&k3_clks 61 1>; + assigned-clocks = <&k3_clks 202 2>, <&k3_clks 61 1>; + assigned-clock-rates = <2000000000>, <200000000>; + ti,sci = <&dmsc>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + u-boot,dm-spl; + }; + + clk_200mhz: dummy_clock_200mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + u-boot,dm-spl; + }; + + clk_19_2mhz: dummy_clock_19_2mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <19200000>; + u-boot,dm-spl; + }; +}; + +&cbass_mcu_wakeup { + mcu_secproxy: secproxy@28380000 { + u-boot,dm-spl; + compatible = "ti,am654-secure-proxy"; + reg = <0x0 0x2a380000 0x0 0x80000>, + <0x0 0x2a400000 0x0 0x80000>, + <0x0 0x2a480000 0x0 0x80000>; + reg-names = "rt", "scfg", "target_data"; + #mbox-cells = <1>; + }; + + sysctrler: sysctrler { + u-boot,dm-spl; + compatible = "ti,am654-system-controller"; + mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>; + mbox-names = "tx", "rx"; + }; + + wkup_vtm0: wkup_vtm@42040000 { + compatible = "ti,am654-vtm", "ti,j721e-avs"; + reg = <0x0 0x42040000 0x0 0x330>; + power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; + #thermal-sensor-cells = <1>; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <3>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&mcu_secproxy 21>, + <&mcu_secproxy 23>; + u-boot,dm-spl; + }; +}; + +&cbass_main { + main_esm: esm@700000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x700000 0x0 0x1000>; + ti,esm-pins = <344>, <345>; + u-boot,dm-spl; + }; +}; + +&dmsc { + mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mbox-names = "tx", "rx", "notify"; + ti,host-id = <4>; + ti,secure-host; +}; + +&wkup_pmx0 { + wkup_uart0_pins_default: wkup_uart0_pins_default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xa0, PIN_INPUT, 0) /* (J29) WKUP_UART0_RXD */ + J721E_WKUP_IOPAD(0xa4, PIN_OUTPUT, 0) /* (J28) WKUP_UART0_TXD */ + >; + }; + + mcu_uart0_pins_default: mcu_uart0_pins_default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf0, PIN_INPUT, 2) /* (D26) MCU_I3C0_SCL.MCU_UART0_CTSn */ + J721E_WKUP_IOPAD(0xf4, PIN_OUTPUT, 2)/* (D25) MCU_I3C0_SDA.MCU_UART0_RTSn */ + J721E_WKUP_IOPAD(0xe4, PIN_INPUT, 0) /* (H28) WKUP_GPIO0_13.MCU_UART0_RXD */ + J721E_WKUP_IOPAD(0xe0, PIN_OUTPUT, 0)/* (G29) WKUP_GPIO0_12.MCU_UART0_TXD */ + >; + }; + + wkup_i2c0_pins_default: wkup-i2c0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf8, PIN_INPUT_PULLUP, 0) /* (J25) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0xfc, PIN_INPUT_PULLUP, 0) /* (H24) WKUP_I2C0_SDA */ + >; + }; + + mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 0) /* (E20) MCU_OSPI0_CLK */ + J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 0) /* (F19) MCU_OSPI0_CSn0 */ + J721E_WKUP_IOPAD(0xc, PIN_INPUT, 0) /* (D20) MCU_OSPI0_D0 */ + J721E_WKUP_IOPAD(0x10, PIN_INPUT, 0) /* (G19) MCU_OSPI0_D1 */ + J721E_WKUP_IOPAD(0x14, PIN_INPUT, 0) /* (G20) MCU_OSPI0_D2 */ + J721E_WKUP_IOPAD(0x18, PIN_INPUT, 0) /* (F20) MCU_OSPI0_D3 */ + J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 0) /* (F21) MCU_OSPI0_D4 */ + J721E_WKUP_IOPAD(0x20, PIN_INPUT, 0) /* (E21) MCU_OSPI0_D5 */ + J721E_WKUP_IOPAD(0x24, PIN_INPUT, 0) /* (B22) MCU_OSPI0_D6 */ + J721E_WKUP_IOPAD(0x28, PIN_INPUT, 0) /* (G21) MCU_OSPI0_D7 */ + J721E_WKUP_IOPAD(0x8, PIN_INPUT, 0) /* (D21) MCU_OSPI0_DQS */ + >; + }; + + mcu_i2c0_pins_default: mcu_i2c0_pins_default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x100, PIN_INPUT, 0) /* (J26) MCU_I2C0_SCL */ + J721E_WKUP_IOPAD(0x104, PIN_INPUT, 0) /* (H25) MCU_I2C0_SDA */ + >; + }; +}; + +&main_pmx0 { + main_uart0_pins_default: main_uart0_pins_default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721E_IOPAD(0x1f0, PIN_INPUT, 0) /* (AC2) UART0_CTSn */ + J721E_IOPAD(0x1f4, PIN_OUTPUT, 0) /* (AB1) UART0_RTSn */ + J721E_IOPAD(0x1e8, PIN_INPUT, 0) /* (AB2) UART0_RXD */ + J721E_IOPAD(0x1ec, PIN_OUTPUT, 0) /* (AB3) UART0_TXD */ + >; + }; + + main_usbss0_pins_default: main_usbss0_pins_default { + pinctrl-single,pins = < + J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */ + J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */ + >; + }; + + main_usbss1_pins_default: main-usbss1-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */ + >; + }; + + main_mmc1_pins_default: main_mmc1_pins_default { + pinctrl-single,pins = < + J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */ + J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */ + J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ + J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */ + J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */ + J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */ + J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */ + >; + }; + + main_i2c0_pins_default: main-i2c0-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */ + J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */ + >; + }; + + main_i2c1_pins_default: main-i2c1-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */ + J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */ + >; + }; + + main_i2c2_pins_default: main-i2c2-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x158, PIN_INPUT_PULLUP, 2) /* (U23) RGMII5_TX_CTL.I2C2_SCL */ + J721E_IOPAD(0x15c, PIN_INPUT_PULLUP, 2) /* (U26) RGMII5_RX_CTL.I2C2_SDA */ + >; + }; + + main_i2c3_pins_default: main-i2c3-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */ + J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */ + >; + }; + + main_i2c5_pins_default: main-i2c5-pins-default { + pinctrl-single,pins = < + J721E_IOPAD(0x150, PIN_INPUT_PULLUP, 2) /* (Y26) PRG0_MDIO0_MDIO.I2C5_SCL */ + J721E_IOPAD(0x154, PIN_INPUT_PULLUP, 2) /* (AA27) PRG0_MDIO0_MDC.I2C5_SDA */ + >; + }; +}; + +&wkup_uart0 { + u-boot,dm-spl; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; + status = "okay"; +}; + +&mcu_uart0 { + /delete-property/ power-domains; + /delete-property/ clocks; + /delete-property/ clock-names; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; + status = "okay"; + clock-frequency = <48000000>; +}; + +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; + status = "okay"; + power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + ti,driver-strength-ohm = <50>; +}; + +&wkup_i2c0 { + u-boot,dm-spl; + tps659412: tps659412@48 { + reg = <0x48>; + compatible = "ti,tps659412"; + u-boot,dm-spl; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + regulators: regulators { + u-boot,dm-spl; + /* 3 Phase Buck */ + buck123_reg: buck123 { + /* VDD_CPU */ + regulator-name = "buck123"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1250000>; + regulator-always-on; + regulator-boot-on; + u-boot,dm-spl; + }; + }; + }; +}; + +&wkup_vtm0 { + vdd-supply-2 = <&buck123_reg>; + u-boot,dm-spl; +}; + +&usbss0 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + clocks = <&clk_19_2mhz>; + clock-names = "usb2_refclk"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss0_pins_default>; + ti,vbus-divider; +}; + +&usbss1 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + clocks = <&clk_19_2mhz>; + clock-names = "usb2_refclk"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss1_pins_default>; +}; + +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; +}; + +&ospi0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_fss0_ospi0_pins_default>; + + reg = <0x0 0x47040000 0x0 0x100>, + <0x0 0x50000000 0x0 0x8000000>; + + flash@0{ + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <8>; + spi-rx-bus-width = <8>; + spi-max-frequency = <25000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <4>; + cdns,phy-mode; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&ospi1 { + status = "disabled"; +}; + +&mcu_ringacc { + ti,sci = <&dm_tifs>; +}; + +&mcu_udmap { + ti,sci = <&dm_tifs>; +}; + +&mailbox0_cluster0 { + interrupts = <436>; + + mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster1 { + interrupts = <432>; + + mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster2 { + interrupts = <428>; + + mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster3 { + interrupts = <424>; + + mbox_c66_0: mbox-c66-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_c66_1: mbox-c66-1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster4 { + interrupts = <420>; + + mbox_c71_0: mbox-c71-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; +}; + +&mailbox0_cluster5 { + status = "disabled"; +}; + +&mailbox0_cluster6 { + status = "disabled"; +}; + +&mailbox0_cluster7 { + status = "disabled"; +}; + +&mailbox0_cluster8 { + status = "disabled"; +}; + +&mailbox0_cluster9 { + status = "disabled"; +}; + +&mailbox0_cluster10 { + status = "disabled"; +}; + +&mailbox0_cluster11 { + status = "disabled"; +}; + +&mcu_r5fss0_core0 { + mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>; + memory-region = <&mcu_r5fss0_core0_dma_memory_region>, + <&mcu_r5fss0_core0_memory_region>; +}; + +&mcu_r5fss0_core1 { + mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>; + memory-region = <&mcu_r5fss0_core1_dma_memory_region>, + <&mcu_r5fss0_core1_memory_region>; +}; + +&main_r5fss0_core0 { + mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>; + memory-region = <&main_r5fss0_core0_dma_memory_region>, + <&main_r5fss0_core0_memory_region>; +}; + +&main_r5fss0_core1 { + mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>; + memory-region = <&main_r5fss0_core1_dma_memory_region>, + <&main_r5fss0_core1_memory_region>; +}; + +&main_r5fss1_core0 { + mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>; + memory-region = <&main_r5fss1_core0_dma_memory_region>, + <&main_r5fss1_core0_memory_region>; +}; + +&main_r5fss1_core1 { + mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>; + memory-region = <&main_r5fss1_core1_dma_memory_region>, + <&main_r5fss1_core1_memory_region>; +}; + +&c66_0 { + mboxes = <&mailbox0_cluster3 &mbox_c66_0>; + memory-region = <&c66_0_dma_memory_region>, + <&c66_0_memory_region>; +}; + +&c66_1 { + mboxes = <&mailbox0_cluster3 &mbox_c66_1>; + memory-region = <&c66_1_dma_memory_region>, + <&c66_1_memory_region>; +}; + +&c71_0 { + mboxes = <&mailbox0_cluster4 &mbox_c71_0>; + memory-region = <&c71_0_dma_memory_region>, + <&c71_0_memory_region>; +}; + +/* EEPROM might be read before SYSFW is available */ +&wkup_i2c0 { + /delete-property/ power-domains; +};
Changes in V2:
to sk.
Has arch/arm/dts/k3-j721e-r5-sk.dts been queued up in linux-next or similar yet?
Hi Tom,
Changes in V2:
to sk.
-- Tom
Enable configs for building multiple dtbs into a single fit image and load the right dtb for next stage. This will help to use same defconfig for both J721E EVM and SK boards.
configs/j721e_evm_r5_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 1a58135da4..43bddfdb19 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -63,6 +63,9 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_OF_LIST="k3-j721e-r5-common-proc-board k3-j721e-r5-sk" +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y
Add k3-j721e-sk dtb along with other dtbs inside DTB FIT image.
configs/j721e_evm_a72_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index df1b850f42..81bd5937be 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -75,6 +75,8 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIST="k3-j721e-common-proc-board k3-j721e-sk" +CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y
S28HS512T on TI SK has sector size of 256KB, so update OSPI partition to align on 256KB sector size. Since the sector size for MT35XU512ABA on EVM is 128KB, partitions will remain aligned for EVM.
Also, now since the sector size is 256KB ospi.env.backup will collide with ospi.sysfw, so move ospi.env.backup to the padding space (0x7C0000) before ospi.rootfs partition.
No changes in V2.
configs/j721e_evm_a72_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 81bd5937be..18a66cb051 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -18,7 +18,7 @@ CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 +CONFIG_ENV_OFFSET_REDUND=0x7C0000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y @@ -69,7 +69,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set
Enable defconfigs relevant for storing env on FAT partion of MMC.
No changes in v2.
configs/j721e_evm_a72_defconfig | 5 +++-- configs/j721e_evm_r5_defconfig | 1 + 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 18a66cb051..1de4d85336 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -80,10 +80,11 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 43bddfdb19..38ac0b4296 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -67,6 +67,7 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="k3-j721e-r5-common-proc-board k3-j721e-r5-sk" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y
Now that single defconfig can be used for booting J721E EVM and SK, default device tree will not work for selecting dtb for kernel. Update the findfdt env to select right dtb based on board_name env variable.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com ---
No Changes in V2.
include/configs/j721e_evm.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index 10555d1a6c..f7e2962efd 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -67,6 +67,10 @@ "default_device_tree=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "findfdt=" \ "setenv name_fdt ${default_device_tree};" \ + "if test $board_name = j721e; then " \ + "setenv name_fdt k3-j721e-common-proc-board.dtb; fi;" \ + "if test $board_name = j721e-eaik || test $board_name = j721e-sk; then " \ + "setenv name_fdt k3-j721e-sk.dtb; fi;" \ "setenv fdtfile ${name_fdt}\0" \ "name_kern=Image\0" \ "console=ttyS2,115200n8\0" \
Sinthu Raja
Sinthu Raja M
