[U-Boot] [PATCH 1/2] armv8/ls1043a: fsl_qman: Implement device tree fixup for QBMan
Add support for device tree fixup for the QBMan nodes in ARM platforms
Signed-off-by: Roy Pledge Roy.Pledge@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 87 ++++++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 3 + .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 + include/configs/ls1043a_common.h | 2 + 4 files changed, 94 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index eafdd71..2a3e621 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -8,6 +8,8 @@ #include <libfdt.h> #include <fdt_support.h> #include <phy.h> +#include <asm/io.h> +#include <asm/arch/speed.h> #ifdef CONFIG_FSL_LSCH3 #include <asm/arch/fdt.h> #endif @@ -179,8 +181,86 @@ static void fdt_fixup_smmu(void *blob) } #endif
+#ifdef CONFIG_SYS_DPAA_QBMAN +#define BMAN_IP_REV_1 0xBF8 +#define BMAN_IP_REV_2 0xBFC +void fdt_fixup_bportals(void *blob) +{ + int off, err; + unsigned int maj, min; + unsigned int ip_cfg; + + u32 rev_1 = in_be32(CONFIG_SYS_FSL_BMAN_ADDR + BMAN_IP_REV_1); + u32 rev_2 = in_be32(CONFIG_SYS_FSL_BMAN_ADDR + BMAN_IP_REV_2); + char compat[64]; + int compat_len; + + maj = (rev_1 >> 8) & 0xff; + min = rev_1 & 0xff; + + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,bman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; + compat_len += sprintf(compat + compat_len, "fsl,bman-portal") + 1; + + off = fdt_node_offset_by_compatible(blob, -1, "fsl,bman-portal"); + while (off != -FDT_ERR_NOTFOUND) { + err = fdt_setprop(blob, off, "compatible", compat, compat_len); + if (err < 0) { + printf("ERROR: unable to create props for %s: %s\n", + fdt_get_name(blob, off, NULL), + fdt_strerror(err)); + return; + } + + off = fdt_node_offset_by_compatible(blob, off, + "fsl,bman-portal"); + } +} + +#define QMAN_IP_REV_1 0xBF8 +#define QMAN_IP_REV_2 0xBFC +void fdt_fixup_qportals(void *blob) +{ + int off, err; + unsigned int maj, min; + unsigned int ip_cfg; + u32 rev_1 = in_be32(CONFIG_SYS_FSL_QMAN_ADDR + QMAN_IP_REV_1); + u32 rev_2 = in_be32(CONFIG_SYS_FSL_QMAN_ADDR + QMAN_IP_REV_2); + char compat[64]; + int compat_len; + + maj = (rev_1 >> 8) & 0xff; + min = rev_1 & 0xff; + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,qman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; + compat_len += sprintf(compat + compat_len, "fsl,qman-portal") + 1; + + off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); + while (off != -FDT_ERR_NOTFOUND) { + err = fdt_setprop(blob, off, "compatible", compat, compat_len); + if (err < 0) { + printf("ERROR: unable to create props for %s: %s\n", + fdt_get_name(blob, off, NULL), + fdt_strerror(err)); + return; + } + + off = fdt_node_offset_by_compatible(blob, off, + "fsl,qman-portal"); + } +} +#endif + void ft_cpu_setup(void *blob, bd_t *bd) { + struct sys_info sysinfo; + + get_sys_info(&sysinfo); + #ifdef CONFIG_MP ft_fixup_cpu(blob); #endif @@ -201,4 +281,11 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_FSL_LSCH3 fdt_fixup_smmu(blob); #endif + +#ifdef CONFIG_SYS_DPAA_QBMAN + fdt_fixup_bportals(blob); + fdt_fixup_qportals(blob); + do_fixup_by_compat_u32(blob, "fsl,qman", + "clock-frequency", sysinfo.freq_qman, 1); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 6f6a588..99a9c36 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -117,6 +117,9 @@ void get_sys_info(struct sys_info *sys_info)
sys_info->freq_localbus = sys_info->freq_systembus / ccr; #endif +#ifdef CONFIG_SYS_DPAA_QBMAN + sys_info->freq_qman = sys_info->freq_systembus / 2; +#endif }
int get_clocks(void) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 21b803f..e3ca7cb 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -24,6 +24,8 @@ #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00ee00b0) #define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) #define CONFIG_SYS_FSL_FMAN_ADDR (CONFIG_SYS_IMMR + 0x00a00000) +#define CONFIG_SYS_FSL_BMAN_ADDR (CONFIG_SYS_IMMR + 0x00890000) +#define CONFIG_SYS_FSL_QMAN_ADDR (CONFIG_SYS_IMMR + 0x00880000) #define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) #define CONFIG_SYS_FSL_DCFG_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) #define CONFIG_SYS_FSL_CLK_ADDR (CONFIG_SYS_IMMR + 0x00ee1000) diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 677d281..8220f6b 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -209,6 +209,8 @@ #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) #endif
+#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ + /* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) #define CONFIG_ARCH_EARLY_INIT_R
1.Add fixup for fman clock. 2.Add fdt_fixup_fman_firmware() to insert the Fman ucode firmware into the device tree.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 121 ++++++++++++++++++++++++++++++++ 1 file changed, 121 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 2a3e621..c93aa18 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -19,6 +19,7 @@ #ifdef CONFIG_MP #include <asm/arch/mp.h> #endif +#include "../../../../../drivers/qe/qe.h" /* For struct qe_firmware */
int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) { @@ -255,6 +256,120 @@ void fdt_fixup_qportals(void *blob) } #endif
+#ifdef CONFIG_SYS_DPAA_FMAN +void fdt_fixup_fman_firmware(void *blob) +{ + int rc, fmnode, fwnode = -1; + uint32_t phandle; + struct qe_firmware *fmanfw; + const struct qe_header *hdr; + unsigned int length; + uint32_t crc; + const char *p; + + /* The first Fman we find will contain the actual firmware. */ + fmnode = fdt_node_offset_by_compatible(blob, -1, "fsl,fman"); + if (fmnode < 0) + /* Exit silently if there are no Fman devices */ + return; + + /* If we already have a firmware node, then also exit silently. */ + if (fdt_node_offset_by_compatible(blob, -1, "fsl,fman-firmware") > 0) + return; + + /* If the environment variable is not set, then exit silently */ + p = getenv("fman_ucode"); + if (!p) + return; + + fmanfw = (struct qe_firmware *)simple_strtoul(p, NULL, 16); + if (!fmanfw) + return; + + hdr = &fmanfw->header; + length = fdt32_to_cpu(hdr->length); + + /* Verify the firmware. */ + if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || + (hdr->magic[2] != 'F')) { + printf("Data at %p is not an Fman firmware\n", fmanfw); + return; + } + + if (length > CONFIG_SYS_QE_FMAN_FW_LENGTH) { + printf("Fman firmware at %p is too large (size=%u)\n", + fmanfw, length); + return; + } + + length -= sizeof(u32); /* Subtract the size of the CRC */ + crc = fdt32_to_cpu(*(u32 *)((void *)fmanfw + length)); + if (crc != crc32_no_comp(0, (void *)fmanfw, length)) { + printf("Fman firmware at %p has invalid CRC\n", fmanfw); + return; + } + + length += sizeof(u32); + + /* Increase the size of the fdt to make room for the node. */ + rc = fdt_increase_size(blob, length); + if (rc < 0) { + printf("Unable to make room for Fman firmware: %s\n", + fdt_strerror(rc)); + return; + } + + /* Create the firmware node. */ + fwnode = fdt_add_subnode(blob, fmnode, "fman-firmware"); + if (fwnode < 0) { + char s[64]; + fdt_get_path(blob, fmnode, s, sizeof(s)); + printf("Could not add firmware node to %s: %s\n", s, + fdt_strerror(fwnode)); + return; + } + rc = fdt_setprop_string(blob, fwnode, "compatible", + "fsl,fman-firmware"); + if (rc < 0) { + char s[64]; + fdt_get_path(blob, fwnode, s, sizeof(s)); + printf("Could not add compatible property to node %s: %s\n", s, + fdt_strerror(rc)); + return; + } + phandle = fdt_create_phandle(blob, fwnode); + if (!phandle) { + char s[64]; + fdt_get_path(blob, fwnode, s, sizeof(s)); + printf("Could not add phandle property to node %s: %s\n", s, + fdt_strerror(rc)); + return; + } + rc = fdt_setprop(blob, fwnode, "fsl,firmware", fmanfw, length); + if (rc < 0) { + char s[64]; + fdt_get_path(blob, fwnode, s, sizeof(s)); + printf("Could not add firmware property to node %s: %s\n", s, + fdt_strerror(rc)); + return; + } + + /* Find all other Fman nodes and point them to the firmware node. */ + while ((fmnode = fdt_node_offset_by_compatible(blob, fmnode, + "fsl,fman")) > 0) { + rc = fdt_setprop_cell(blob, fmnode, "fsl,firmware-phandle", + phandle); + if (rc < 0) { + char s[64]; + fdt_get_path(blob, fmnode, s, sizeof(s)); + printf("Could not add pointer property to node %s: %s\n", + s, fdt_strerror(rc)); + return; + } + } +} +#endif + void ft_cpu_setup(void *blob, bd_t *bd) { struct sys_info sysinfo; @@ -288,4 +403,10 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_compat_u32(blob, "fsl,qman", "clock-frequency", sysinfo.freq_qman, 1); #endif + +#ifdef CONFIG_SYS_DPAA_FMAN + do_fixup_by_compat_u32(blob, "fsl,fman", + "clock-frequency", sysinfo.freq_fman[0], 1); + fdt_fixup_fman_firmware(blob); +#endif }
Move the header to include/ if it's not private to drivers/qe.
Better yet, don't duplicate these fixups. Move the existing code out of arch/powerpc.
-Scott
Gong Qianyu
Scott Wood
