[PATCH] rockchip: rk3399: Add Nanopi M4 2GB board support
commit b2f5da9dd068 ("rockchip: rk3399: Add Nanopi M4 board support") added support for Nanopi M4 board with Dual-Channel 4GB LPDDR3-1866 RAM. This patch adds another variant of NanoPi M4 board with Dual-Channel 2GB DDR3-1866 RAM.
Signed-off-by: Deepak Das deepakdas.linux@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-nanopi-m4-2gb-u-boot.dtsi | 8 +++ arch/arm/dts/rk3399-nanopi-m4-2gb.dts | 66 +++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 7 ++ configs/nanopi-m4-2gb-rk3399_defconfig | 63 ++++++++++++++++++ 5 files changed, 145 insertions(+) create mode 100644 arch/arm/dts/rk3399-nanopi-m4-2gb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-m4-2gb.dts create mode 100644 configs/nanopi-m4-2gb-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 59a2713cb2..2bc43a37b4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -123,6 +123,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-leez-p710.dtb \ rk3399-nanopc-t4.dtb \ rk3399-nanopi-m4.dtb \ + rk3399-nanopi-m4-2gb.dtb \ rk3399-nanopi-neo4.dtb \ rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ diff --git a/arch/arm/dts/rk3399-nanopi-m4-2gb-u-boot.dtsi b/arch/arm/dts/rk3399-nanopi-m4-2gb-u-boot.dtsi new file mode 100644 index 0000000000..a2f9786473 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-m4-2gb-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + * Copyright (C) 2020 Deepak Das deepakdas.linux@gmail.com + */ + +#include "rk3399-nanopi4-u-boot.dtsi" +#include "rk3399-sdram-ddr3-1866.dtsi" diff --git a/arch/arm/dts/rk3399-nanopi-m4-2gb.dts b/arch/arm/dts/rk3399-nanopi-m4-2gb.dts new file mode 100644 index 0000000000..60358ab8c7 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-m4-2gb.dts @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * FriendlyElec NanoPi M4 board device tree source + * + * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2019 Arm Ltd. + */ + +/dts-v1/; +#include "rk3399-nanopi4.dtsi" + +/ { + model = "FriendlyElec NanoPi M4"; + compatible = "friendlyarm,nanopi-m4", "rockchip,rk3399"; + + vdd_5v: vdd-5v { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v"; + regulator-always-on; + regulator-boot-on; + }; + + vcc5v0_core: vcc5v0-core { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_core"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_5v>; + }; + + vcc5v0_usb1: vcc5v0-usb1 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb1"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb2: vcc5v0-usb2 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb2"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&vcc3v3_sys { + vin-supply = <&vcc5v0_core>; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_usb1>; +}; + +&u2phy1_host { + phy-supply = <&vcc5v0_usb2>; +}; + +&vbus_typec { + regulator-always-on; + vin-supply = <&vdd_5v>; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 0834254f6d..792df1087f 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -42,6 +42,13 @@ S: Maintained F: configs/nanopi-m4-rk3399_defconfig F: arch/arm/dts/rk3399-nanopi-m4-u-boot.dtsi
+NANOPI-M4-2GB +M: Jagan Teki jagan@amarulasolutions.com +M: Deepak Das deepakdas.linux@gmail.com +S: Maintained +F: configs/nanopi-m4-2gb-rk3399_defconfig +F: arch/arm/dts/rk3399-nanopi-m4-2gb-u-boot.dtsi + NANOPI-NEO4 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopi-m4-2gb-rk3399_defconfig b/configs/nanopi-m4-2gb-rk3399_defconfig new file mode 100644 index 0000000000..93c8db979c --- /dev/null +++ b/configs/nanopi-m4-2gb-rk3399_defconfig @@ -0,0 +1,63 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4-2gb.dtb" +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-m4-2gb" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_KEYBOARD=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y
Deepak Das
