[PATCH 0/2] ANATOP regulator driver
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org
Anatop is an integrated regulator inside i.MX6 SoC. There are 3 digital regulators which controls PU, CORE (ARM), and SOC. And 3 analog regulators which controls 1P1, 2P5, 3P0 (USB). This patch adds the Anatop regulator driver.
Ying-Chun Liu (PaulLiu) (2): power: regulator: add driver for ANATOP regulator doc: device-tree-bindings: regulator: anatop regulator
.../regulator/fsl,anatop-regulator.txt | 45 +++ drivers/power/regulator/Kconfig | 10 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/anatop_regulator.c | 289 ++++++++++++++++++ 4 files changed, 345 insertions(+) create mode 100644 doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt create mode 100644 drivers/power/regulator/anatop_regulator.c
Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org --- drivers/power/regulator/Kconfig | 10 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/anatop_regulator.c | 289 +++++++++++++++++++++ 3 files changed, 300 insertions(+) create mode 100644 drivers/power/regulator/anatop_regulator.c
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index fbbea18c7d..1cd1f3f5ed 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -312,6 +312,16 @@ config DM_REGULATOR_STPMIC1 by the PMIC device. This driver is controlled by a device tree node which includes voltage limits.
+config DM_REGULATOR_ANATOP + bool "Enable driver for ANATOP regulators" + depends on DM_REGULATOR + select REGMAP + select SYSCON + help + Enable support for the Freescale i.MX on-chip ANATOP LDOs + regulators. It is recommended that this option be enabled on + i.MX6 platform. + config SPL_DM_REGULATOR_STPMIC1 bool "Enable driver for STPMIC1 regulators in SPL" depends on SPL_DM_REGULATOR && PMIC_STPMIC1 diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 9d58112dcb..e7198da911 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -30,3 +30,4 @@ obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS62360) += tps62360_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMIC1) += stpmic1.o obj-$(CONFIG_DM_REGULATOR_TPS65941) += tps65941_regulator.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_ANATOP) += anatop_regulator.o diff --git a/drivers/power/regulator/anatop_regulator.c b/drivers/power/regulator/anatop_regulator.c new file mode 100644 index 0000000000..2bb5cdbac5 --- /dev/null +++ b/drivers/power/regulator/anatop_regulator.c @@ -0,0 +1,289 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright (C) 2011 Freescale Semiconductor, Inc. All Rights Reserved. +// Copyright (C) 2021 Linaro + +#include <common.h> +#include <errno.h> +#include <dm.h> +#include <log.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <regmap.h> +#include <syscon.h> +#include <linux/bitops.h> +#include <linux/ioport.h> +#include <dm/device-internal.h> +#include <dm/device_compat.h> +#include <dm/read.h> + +#define LDO_RAMP_UP_UNIT_IN_CYCLES 64 /* 64 cycles per step */ +#define LDO_RAMP_UP_FREQ_IN_MHZ 24 /* cycle based on 24M OSC */ + +#define LDO_POWER_GATE 0x00 +#define LDO_FET_FULL_ON 0x1f + +struct anatop_regulator { + const char *name; + u32 control_reg; + u32 vol_bit_shift; + u32 vol_bit_width; + u32 min_bit_val; + u32 min_voltage; + u32 max_voltage; + u32 delay_reg; + u32 delay_bit_shift; + u32 delay_bit_width; +}; + +static u32 anatop_get_bits(struct udevice *dev, u32 addr, int bit_shift, + int bit_width) +{ + struct udevice *syscon; + struct regmap *regmap; + int err; + u32 val, mask; + + syscon = dev_get_parent(dev); + if (!syscon) { + dev_err(dev, "%s: unable to find syscon device\n", __func__); + return err; + } + + regmap = syscon_get_regmap(syscon); + if (IS_ERR(regmap)) { + dev_err(dev, "%s: unable to find regmap (%ld)\n", __func__, + PTR_ERR(regmap)); + return PTR_ERR(regmap); + } + + if (bit_width == 32) + mask = ~0; + else + mask = (1 << bit_width) - 1; + + err = regmap_read(regmap, addr, &val); + if (err) + return err; + + val = (val >> bit_shift) & mask; + + return val; +} + +void anatop_set_bits(struct udevice *dev, u32 addr, int bit_shift, + int bit_width, u32 data) +{ + struct udevice *syscon; + struct regmap *regmap; + int err; + u32 val, mask; + + syscon = dev_get_parent(dev); + if (!syscon) { + dev_err(dev, "%s: unable to find syscon device\n", __func__); + return; + } + + regmap = syscon_get_regmap(syscon); + if (IS_ERR(regmap)) { + dev_err(dev, + "%s: unable to find regmap (%ld)\n", __func__, + PTR_ERR(regmap)); + return; + } + + if (bit_width == 32) + mask = ~0; + else + mask = (1 << bit_width) - 1; + + err = regmap_read(regmap, addr, &val); + if (err) { + dev_err(dev, + "%s: cannot read reg (%d)\n", __func__, + err); + return; + } + val = val & ~(mask << bit_shift); + err = regmap_write(regmap, addr, (data << bit_shift) | val); + if (err) { + dev_err(dev, + "%s: cannot wrie reg (%d)\n", __func__, + err); + return; + } +} + +static int anatop_set_voltage(struct udevice *dev, int uV) +{ + const struct anatop_regulator *anatop_reg = dev_get_plat(dev); + u32 val; + u32 sel; + int delayus = 0; + int ret = 0; + int uv; + + uv = uV; + dev_dbg(dev, "%s: uv %d, min %d, max %d\n", __func__, + uv, anatop_reg->min_voltage, + anatop_reg->max_voltage); + + if (uv < anatop_reg->min_voltage) + return -EINVAL; + + if (!anatop_reg->control_reg) + return -ENOTSUPP; + + sel = DIV_ROUND_UP(uv - anatop_reg->min_voltage, 25000); + if (sel * 25000 + anatop_reg->min_voltage > anatop_reg->max_voltage) + return -EINVAL; + val = anatop_reg->min_bit_val + sel; + dev_dbg(dev, "%s: calculated val %d\n", __func__, val); + + /* check whether need to care about LDO ramp up speed */ + if (anatop_reg->delay_bit_width) { + /* + * the delay for LDO ramp up time is + * based on the register setting, we need + * to calculate how many steps LDO need to + * ramp up, and how much delay needed. (us) + */ + u32 old_sel; + u32 new_sel = sel; + + old_sel = anatop_get_bits(dev, + anatop_reg->control_reg, + anatop_reg->vol_bit_shift, + anatop_reg->vol_bit_width); + old_sel = old_sel - anatop_reg->min_bit_val; + + if (new_sel > old_sel) { + val = anatop_get_bits(dev, + anatop_reg->delay_reg, + anatop_reg->delay_bit_shift, + anatop_reg->delay_bit_width); + delayus = (new_sel - old_sel) * + (LDO_RAMP_UP_UNIT_IN_CYCLES << val) / + LDO_RAMP_UP_FREQ_IN_MHZ + 1; + } + } + + anatop_set_bits(dev, + anatop_reg->control_reg, + anatop_reg->vol_bit_shift, + anatop_reg->vol_bit_width, + val); + + if (delayus) + udelay(delayus); + + return ret; +} + +static int anatop_get_voltage(struct udevice *dev) +{ + const struct anatop_regulator *anatop_reg = dev_get_plat(dev); + u32 val; + u32 sel; + + val = anatop_get_bits(dev, + anatop_reg->control_reg, + anatop_reg->vol_bit_shift, + anatop_reg->vol_bit_width); + sel = val - anatop_reg->min_bit_val; + + return sel * 25000 + anatop_reg->min_voltage; +} + +static const struct dm_regulator_ops anatop_regulator_ops = { + .set_value = anatop_set_voltage, + .get_value = anatop_get_voltage, +}; + +static int anatop_regulator_probe(struct udevice *dev) +{ + struct anatop_regulator *sreg; + int ret = 0; + + sreg = dev_get_plat(dev); + if (!sreg) { + dev_err(dev, "failed to get plat data\n"); + return -ENOMEM; + } + + sreg->name = ofnode_read_string(dev_ofnode(dev), "regulator-name"); + if (!sreg->name) { + dev_err(dev, "failed to get a regulator-name\n"); + return -EINVAL; + } + + ret = ofnode_read_u32(dev_ofnode(dev), + "anatop-reg-offset", + &sreg->control_reg); + if (ret) { + dev_err(dev, "no anatop-reg-offset property set\n"); + return ret; + } + ret = ofnode_read_u32(dev_ofnode(dev), + "anatop-vol-bit-width", + &sreg->vol_bit_width); + if (ret) { + dev_err(dev, "no anatop-vol-bit-width property set\n"); + return ret; + } + ret = ofnode_read_u32(dev_ofnode(dev), + "anatop-vol-bit-shift", + &sreg->vol_bit_shift); + if (ret) { + dev_err(dev, "no anatop-vol-bit-shift property set\n"); + return ret; + } + ret = ofnode_read_u32(dev_ofnode(dev), + "anatop-min-bit-val", + &sreg->min_bit_val); + if (ret) { + dev_err(dev, "no anatop-min-bit-val property set\n"); + return ret; + } + ret = ofnode_read_u32(dev_ofnode(dev), + "anatop-min-voltage", + &sreg->min_voltage); + if (ret) { + dev_err(dev, "no anatop-min-voltage property set\n"); + return ret; + } + ret = ofnode_read_u32(dev_ofnode(dev), + "anatop-max-voltage", + &sreg->max_voltage); + if (ret) { + dev_err(dev, "no anatop-max-voltage property set\n"); + return ret; + } + + /* read LDO ramp up setting, only for core reg */ + ofnode_read_u32(dev_ofnode(dev), "anatop-delay-reg-offset", + &sreg->delay_reg); + ofnode_read_u32(dev_ofnode(dev), "anatop-delay-bit-width", + &sreg->delay_bit_width); + ofnode_read_u32(dev_ofnode(dev), "anatop-delay-bit-shift", + &sreg->delay_bit_shift); + + return 0; +} + +static const struct udevice_id of_anatop_regulator_match_tbl[] = { + { .compatible = "fsl,anatop-regulator", }, + { /* end */ } +}; + +U_BOOT_DRIVER(anatop_regulator) = { + .name = "anatop_regulator", + .id = UCLASS_REGULATOR, + .ops = &anatop_regulator_ops, + .of_match = of_anatop_regulator_match_tbl, + .plat_auto = sizeof(struct anatop_regulator), + .probe = anatop_regulator_probe, +};
Dear Ying-Chun
- bool "Enable driver for ANATOP regulators"
- depends on DM_REGULATOR
- select REGMAP
- select SYSCON
- help
- Enable support for the Freescale i.MX on-chip ANATOP LDOs
- regulators. It is recommended that this option be enabled on
- i.MX6 platform.
Well, i think that it can be removed more than now.
- const char *name;
- u32 control_reg;
- u32 vol_bit_shift;
- u32 vol_bit_width;
- u32 min_bit_val;
- u32 min_voltage;
- u32 max_voltage;
- u32 delay_reg;
- u32 delay_bit_shift;
- u32 delay_bit_width;
int bit_width)
- struct udevice *syscon;
- struct regmap *regmap;
- int err;
- u32 val, mask;
- syscon = dev_get_parent(dev);
- if (!syscon) {
return err;
- regmap = syscon_get_regmap(syscon);
- if (IS_ERR(regmap)) {
PTR_ERR(regmap));
- if (bit_width == 32)
Use macro instead of 32, plz.
mask = ~0;
- else
- err = regmap_read(regmap, addr, &val);
- if (err)
return err;
- val = (val >> bit_shift) & mask;
- return val;
static? doesn't it need to return int type? If there is a somehting failed, it seems that it needs to pass the error number. (get_bits is returend to error..but set_bits doesn't return. It's strange.)
And How about passing the struct anatop_regulator instead of each values? anatop_get/set_bits(struct anatop_regulator *regulator) { .. }
- int err;
- u32 val, mask;
- if (!syscon) {
return;
dev_err(dev,
PTR_ERR(regmap));
return;
mask = ~0;
- else
- if (err) {
dev_err(dev,
err);
return;
- val = val & ~(mask << bit_shift);
- err = regmap_write(regmap, addr, (data << bit_shift) | val);
- if (err) {
dev_err(dev,
err);
return;
- const struct anatop_regulator *anatop_reg = dev_get_plat(dev);
- u32 val;
- u32 sel;
- int delayus = 0;
- int ret = 0;
- int uv;
- uv = uV;
Not need to assign at here. Assign to above. int uv = uV;
- dev_dbg(dev, "%s: uv %d, min %d, max %d\n", __func__,
- if (uv < anatop_reg->min_voltage)
return -EINVAL;
- if (!anatop_reg->control_reg)
return -ENOTSUPP;
- sel = DIV_ROUND_UP(uv - anatop_reg->min_voltage, 25000);
What is 25000? If it's min value, use MACRO, plz.
- if (sel * 25000 + anatop_reg->min_voltage > anatop_reg->max_voltage)
return -EINVAL;
- val = anatop_reg->min_bit_val + sel;
- dev_dbg(dev, "%s: calculated val %d\n", __func__, val);
- /* check whether need to care about LDO ramp up speed */
- if (anatop_reg->delay_bit_width) {
u32 old_sel;
u32 new_sel = sel;
- anatop_set_bits(dev,
val);
- if (delayus)
udelay(delayus);
- return ret;
- u32 val;
- u32 sel;
- val = anatop_get_bits(dev,
- sel = val - anatop_reg->min_bit_val;
- return sel * 25000 + anatop_reg->min_voltage;
- .set_value = anatop_set_voltage,
- .get_value = anatop_get_voltage,
- struct anatop_regulator *sreg;
- int ret = 0;
- sreg = dev_get_plat(dev);
- if (!sreg) {
return -ENOMEM;
- sreg->name = ofnode_read_string(dev_ofnode(dev), "regulator-name");
- if (!sreg->name) {
return -EINVAL;
- ret = ofnode_read_u32(dev_ofnode(dev),
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
I don't know why anatop-min-voltage is need? Doesn't it use "regulator-min-microvolt"?
- if (ret) {
return ret;
Ditto.
Best Regards, Jaehoon Chung
- if (ret) {
return ret;
- /* read LDO ramp up setting, only for core reg */
- ofnode_read_u32(dev_ofnode(dev), "anatop-delay-reg-offset",
&sreg->delay_reg);
- ofnode_read_u32(dev_ofnode(dev), "anatop-delay-bit-width",
- ofnode_read_u32(dev_ofnode(dev), "anatop-delay-bit-shift",
- { .compatible = "fsl,anatop-regulator", },
- { /* end */ }
- .name = "anatop_regulator",
- .id = UCLASS_REGULATOR,
- .ops = &anatop_regulator_ops,
- .of_match = of_anatop_regulator_match_tbl,
- .plat_auto = sizeof(struct anatop_regulator),
- .probe = anatop_regulator_probe,
Hi Jaehoon,
Thanks for the review.
On Mon, 8 Mar 2021 at 07:03, Jaehoon Chung jh80.chung@samsung.com wrote:
Dear Ying-Chun
select REGMAP
select SYSCON
help
i.MX6 platform.
Will fix it in v2.
const char *name;
u32 control_reg;
u32 vol_bit_shift;
u32 vol_bit_width;
u32 min_bit_val;
u32 min_voltage;
u32 max_voltage;
u32 delay_reg;
int bit_width)
int err;
u32 val, mask;
if (!syscon) {
__func__);
return err;
PTR_ERR(regmap));
Will fix it in v2.
mask = ~0;
else
if (err)
return err;
return val;
Will fix it in v2.
Will fix it in v2.
int err;
u32 val, mask;
if (!syscon) {
__func__);
return;
dev_err(dev,
PTR_ERR(regmap));
return;
mask = ~0;
else
if (err) {
dev_err(dev,
err);
return;
if (err) {
dev_err(dev,
err);
return;
u32 val;
u32 sel;
int delayus = 0;
int ret = 0;
int uv;
uv = uV;
Will fix it in v2.
return -EINVAL;
return -ENOTSUPP;
It is "STEP" or "RESOLUTION". Sorry for my bad English. 25000 uV is the anatop regulator's "STEP" or "RESOLUTION". So the uV is register value * 25000 uV + min uV. I'll change it to use MACRO with a proper name to avoid confusion.
return -EINVAL;
u32 old_sel;
u32 new_sel = sel;
val);
if (delayus)
udelay(delayus);
return ret;
u32 val;
u32 sel;
int ret = 0;
if (!sreg) {
return -ENOMEM;
if (!sreg->name) {
return -EINVAL;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
It is needed. It is because the anatop-min-voltage is used to calculate the register value of anatop. But regulator-min-microvolt might not be equal to anatop-min-voltage. Because regulator-min-microvolt describes the device that consumes the regulator. So the device might need higher min-microvolt based on the hardware design and will be described in device tree settings. But the value to be written in the anatop register must be based on anatop-min-voltage.
if (ret) {
return ret;
Ditto.
if (ret) {
return ret;
&sreg->delay_reg);
{ /* end */ }
Yours,
Paul
On 3/8/21 10:04 PM, Paul Liu wrote:
Hi Jaehoon,
Dear Ying-Chun
select REGMAP
select SYSCON
help
i.MX6 platform.
Will fix it in v2.
const char *name;
u32 control_reg;
u32 vol_bit_shift;
u32 vol_bit_width;
u32 min_bit_val;
u32 min_voltage;
u32 max_voltage;
u32 delay_reg;
int bit_width)
int err;
u32 val, mask;
if (!syscon) {
__func__);
return err;
PTR_ERR(regmap));
Will fix it in v2.
mask = ~0;
else
if (err)
return err;
return val;
Will fix it in v2.
Will fix it in v2.
int err;
u32 val, mask;
if (!syscon) {
__func__);
return;
dev_err(dev,
PTR_ERR(regmap));
return;
mask = ~0;
else
if (err) {
dev_err(dev,
err);
return;
if (err) {
dev_err(dev,
err);
return;
u32 val;
u32 sel;
int delayus = 0;
int ret = 0;
int uv;
uv = uV;
Will fix it in v2.
return -EINVAL;
return -ENOTSUPP;
return -EINVAL;
u32 old_sel;
u32 new_sel = sel;
val);
if (delayus)
udelay(delayus);
return ret;
u32 val;
u32 sel;
int ret = 0;
if (!sreg) {
return -ENOMEM;
if (!sreg->name) {
return -EINVAL;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
Thanks for explanation. I guessed that it can be used regulator-min-microvolt after checked your [PATCH 2/2]. Because there are same value with regulator-microvolt and antop-min-voltage.
if (ret) {
return ret;
Ditto.
if (ret) {
return ret;
&sreg->delay_reg);
{ /* end */ }
Yours,
Paul
Document the bindings for fsl,anatop-regulator
Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org --- .../regulator/fsl,anatop-regulator.txt | 45 +++++++++++++++++++ 1 file changed, 45 insertions(+) create mode 100644 doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt
diff --git a/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt b/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt new file mode 100644 index 0000000000..2a60e4941b --- /dev/null +++ b/doc/device-tree-bindings/regulator/fsl,anatop-regulator.txt @@ -0,0 +1,45 @@ +ANATOP REGULATOR + +Anatop is an integrated regulator inside i.MX6 SoC. + +Required properties: +- compatible: Must be "fsl,anatop-regulator". +- regulator-name: Name of the regulator +- anatop-reg-offset: u32 value representing the anatop MFD register offset. +- anatop-vol-bit-shift: u32 value representing the bit shift for the register. +- anatop-vol-bit-width: u32 value representing the number of bits used in the + register. +- anatop-min-bit-val: u32 value representing the minimum value of this + register. +- anatop-min-voltage: u32 value representing the minimum voltage of this + regulator. +- anatop-max-voltage: u32 value representing the maximum voltage of this + regulator. + +Optional properties: +- anatop-delay-reg-offset: u32 value representing the anatop MFD step time + register offset. +- anatop-delay-bit-shift: u32 value representing the bit shift for the step + time register. +- anatop-delay-bit-width: u32 value representing the number of bits used in + the step time register. +- anatop-enable-bit: u32 value representing regulator enable bit offset. +- vin-supply: input supply phandle. + +Example: + regulator-vddpu { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddpu"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1300000>; + regulator-always-on; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <9>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <24>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1300000>; + };
Jaehoon Chung
Paul Liu
Ying-Chun Liu
