[U-Boot] [PATCH] board: usb_a9263: Update to support DT and DM
Add the dts files to support deivce tree, update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively.
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com ---
arch/arm/dts/usb_a9263.dts | 144 ++++++++++++++++++++++++++++++++++ board/calao/usb_a9263/usb_a9263.c | 19 ----- configs/usb_a9263_dataflash_defconfig | 20 ++++- include/configs/usb_a9263.h | 27 ++----- 4 files changed, 168 insertions(+), 42 deletions(-) create mode 100644 arch/arm/dts/usb_a9263.dts
diff --git a/arch/arm/dts/usb_a9263.dts b/arch/arm/dts/usb_a9263.dts new file mode 100644 index 0000000000..bfc48a2724 --- /dev/null +++ b/arch/arm/dts/usb_a9263.dts @@ -0,0 +1,144 @@ +/* + * usb_a9263.dts - Device Tree file for Caloa USB A9293 board + * + * Copyright (C) 2012 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * Licensed under GPLv2 only + */ +/dts-v1/; +#include "at91sam9263.dtsi" + +/ { + model = "Calao USB A9263"; + compatible = "atmel,usb-a9263", "atmel,at91sam9263", "atmel,at91sam9"; + + chosen { + bootargs = "mem=64M console=ttyS0,115200 root=/dev/mtdblock5 rw rootfstype=ubifs"; + }; + + memory { + reg = <0x20000000 0x4000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <12000000>; + }; + }; + + ahb { + apb { + dbgu: serial@ffffee00 { + status = "okay"; + }; + + macb0: ethernet@fffbc000 { + phy-mode = "rmii"; + status = "okay"; + }; + + usb1: gadget@fff78000 { + atmel,vbus-gpio = <&pioB 11 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + + spi0: spi@fffa4000 { + cs-gpios = <&pioB 15 GPIO_ACTIVE_HIGH>; + status = "okay"; + mtd_dataflash@0 { + compatible = "atmel,at45", "atmel,dataflash"; + reg = <0>; + spi-max-frequency = <15000000>; + }; + }; + + shdwc@fffffd10 { + atmel,wakeup-counter = <10>; + atmel,wakeup-rtt-timer; + }; + }; + + nand0: nand@40000000 { + nand-bus-width = <8>; + nand-ecc-mode = "soft"; + nand-on-flash-bbt; + status = "okay"; + + at91bootstrap@0 { + label = "at91bootstrap"; + reg = <0x0 0x20000>; + }; + + barebox@20000 { + label = "barebox"; + reg = <0x20000 0x40000>; + }; + + bareboxenv@60000 { + label = "bareboxenv"; + reg = <0x60000 0x20000>; + }; + + bareboxenv2@80000 { + label = "bareboxenv2"; + reg = <0x80000 0x20000>; + }; + + oftree@80000 { + label = "oftree"; + reg = <0xa0000 0x20000>; + }; + + kernel@a0000 { + label = "kernel"; + reg = <0xc0000 0x400000>; + }; + + rootfs@4a0000 { + label = "rootfs"; + reg = <0x4c0000 0x7800000>; + }; + + data@7ca0000 { + label = "data"; + reg = <0x7cc0000 0x8340000>; + }; + }; + + usb0: ohci@00a00000 { + num-ports = <2>; + status = "okay"; + }; + }; + + leds { + compatible = "gpio-leds"; + + user_led { + label = "user_led"; + gpios = <&pioB 21 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + + user_pb { + label = "user_pb"; + gpios = <&pioB 10 GPIO_ACTIVE_LOW>; + linux,code = <28>; + wakeup-source; + }; + }; + + i2c-gpio-0 { + status = "okay"; + }; +}; diff --git a/board/calao/usb_a9263/usb_a9263.c b/board/calao/usb_a9263/usb_a9263.c index d627b240d0..ee8f5e8bef 100644 --- a/board/calao/usb_a9263/usb_a9263.c +++ b/board/calao/usb_a9263/usb_a9263.c @@ -18,25 +18,9 @@ #include <asm/io.h> #include <net.h> #include <netdev.h> -#include <dataflash.h>
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_HAS_DATAFLASH -AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; - -struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { - {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ -}; - -/*define the area offsets*/ -dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { - {0x00000000, 0x00001FFF, FLAG_PROTECT_SET, 0, "Bootstrap"}, - {0x00002000, 0x00003FFF, FLAG_PROTECT_CLEAR, 0, "Environment"}, - {0x00004000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "U-Boot"}, -}; -#endif - #ifdef CONFIG_CMD_NAND static void usb_a9263_nand_hw_init(void) { @@ -115,9 +99,6 @@ int board_init(void) #ifdef CONFIG_CMD_NAND usb_a9263_nand_hw_init(); #endif -#ifdef CONFIG_HAS_DATAFLASH - at91_spi0_hw_init(1 << 0); -#endif #ifdef CONFIG_MACB usb_a9263_macb_hw_init(); #endif diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 7a8005b6db..61392884af 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_USB_A9263=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="usb_a9263" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -11,10 +13,26 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set -CONFIG_OF_LIBFDT=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 57e22208c4..16b180e4d6 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -36,14 +36,6 @@ /* * Hardware drivers */ -#define CONFIG_AT91_GPIO - -/* serial console */ -#define CONFIG_ATMEL_USART -#define CONFIG_USART_BASE ATMEL_BASE_DBGU -#define CONFIG_USART_ID ATMEL_ID_SYS - - /* * BOOTP options */ @@ -63,16 +55,7 @@ #define CONFIG_SYS_SDRAM_SIZE 0x04000000
#define CONFIG_SYS_INIT_SP_ADDR \ - (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) - -/* DataFlash */ -#define CONFIG_ATMEL_DATAFLASH_SPI -#define CONFIG_HAS_DATAFLASH -#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 -#define AT91_SPI_CLK 8000000 -#define DATAFLASH_TCSS (0x1a << 16) -#define DATAFLASH_TCHS (0x1 << 24) + (ATMEL_BASE_SRAM1 + 16 * 1024 - GENERATED_GBL_DATA_SIZE)
/* NAND flash */ #ifdef CONFIG_CMD_NAND @@ -112,12 +95,12 @@ #define CONFIG_SYS_MEMTEST_END 0x23e00000
/* bootstrap + u-boot + env in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x4000) +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ - CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "nboot 21000000 0" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock1 " \
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com Reviewed-by: Simon Glass sjg@chromium.org
Wenyou Yang
