[U-Boot] Problem in Building the Bootloader for the NAND Flash MPC8313ERDB Board
Hi all I am Working on the MPC 8313 ERDREVA4 Board. I need to boot the board from the NAND flash. Hence i have down loaded the copy of the u-boot-1.1.6 (the version was selected based on the LTIB configuration) and then issued the following commands from the u-boot directory as per the guidelines from the MPC 8313 ERD Board manual for booting from the NAND flash.
host-linux> cd $u-boot host-linux> make MPC8313ERDB_NAND_config host-linux> make
The problem i am facing is that the make is not happening and i get an error as the "make[1]: *** [hello_world.0]error 127" The complete output of the above commands is also attached with this mail for the reference.
Kindly provide the solution for the above problem at the earliest.
Thanks and Regards, Balu
[root@localhost ~]# cd /mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/ [root@localhost u-boot-1.1.6]# make MPC8313ERDB_NAND_config make: execvp: powerpc-linux-gcc: Not a directory ... NAND Configuring for MPC8313ERDB board... [root@localhost u-boot-1.1.6]# make make: execvp: powerpc-linux-gcc: Not a directory for dir in tools examples post post/cpu ; do make -C $dir _depend ; done make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: Entering directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/tools' make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: Entering directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/examples' /bin/sh: powerpc-linux-gcc: command not found dirname: missing operand Try `dirname --help' for more information. /bin/sh: powerpc-linux-gcc: command not found dirname: missing operand Try `dirname --help' for more information. make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/examples' make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: Entering directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/post' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/post' make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: Entering directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/post/cpu' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/post/cpu' make -C tools all make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: Entering directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/tools' gcc -g -Wall -pedantic -idirafter /mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -
idirafter /mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include2 -idirafter /mpc8313ltib/ltib
-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -DTEXT_BASE=0x01000000 -DUSE_HOSTCC -O -c -o
envcrc.o envcrc.c gcc -g -idirafter /mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -idirafter
/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include2 -idirafter /mpc8313ltib/ltib-
mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -DTEXT_BASE=0x01000000 -DUSE_HOSTCC -c -o
environment.o environment.c gcc -Wall -pedantic -idirafter /mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -idirafter
mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -DTEXT_BASE=0x01000000 -DUSE_HOSTCC -O -o
envcrc envcrc.o crc32.o environment.o make[1]: Leaving directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/tools' make -C examples all make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: Entering directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/examples' /bin/sh: powerpc-linux-gcc: command not found dirname: missing operand Try `dirname --help' for more information. /bin/sh: powerpc-linux-gcc: command not found dirname: missing operand Try `dirname --help' for more information. powerpc-linux-gcc -g -Os -fPIC -ffixed-r14 -meabi -D__KERNEL__ -DTEXT_BASE=0x01000000 -
I/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/include -fno-builtin -ffreestanding -nostdinc
-isystem -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_MPC83XX -DCONFIG_E300 -ffixed-r2 -ffixed-r29 -
msoft-float -Wall -Wstrict-prototypes -c -o hello_world.o hello_world.c make[1]: execvp: powerpc-linux-gcc: Not a directory make[1]: *** [hello_world.o] Error 127 make[1]: Leaving directory `/mpc8313ltib/ltib-mpc8313erdb-20070824/rpm/BUILD/u-boot-1.1.6/examples' make: *** [examples] Error 2 [root@localhost u-boot-1.1.6]# ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Dear Balu V,
In message 916b8fbd0911190121o7729bbc4ke7e9562779c91b3f@mail.gmail.com you wrote:
U-Boot 1.1.6 is ancient. Please update and use current code instead.
Balu V
