[PATCH 0/6] riscv: Clean up timer drivers
This series cleans up the timer drivers in RISC-V and converts them to DM.
This series depends on [1]. This series needs to be tested! I have only tested it on QEMU and the K210. Notably, this means that the HiFive and anything Andes is completely untested. CI for this series is located at [2].
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=190862 [2] https://dev.azure.com/seanga2/u-boot/_build/results?buildId=4
Sean Anderson (6): riscv: Rework riscv timer driver to only support S-mode riscv: Rework Andes PLMT as a UCLASS_TIMER driver riscv: Clean up initialization in Andes PLIC riscv: Rework Sifive CLINT as UCLASS_TIMER driver riscv: Update Kendryte device tree for new CLINT driver riscv: Update SiFive device tree for new CLINT driver
arch/riscv/Kconfig | 8 --- arch/riscv/dts/ae350_32.dts | 1 + arch/riscv/dts/ae350_64.dts | 1 + arch/riscv/dts/fu540-c000-u-boot.dtsi | 7 +- arch/riscv/dts/k210.dtsi | 10 +-- arch/riscv/include/asm/global_data.h | 3 - arch/riscv/lib/Makefile | 1 - arch/riscv/lib/andes_plic.c | 58 +++++++---------- arch/riscv/lib/andes_plmt.c | 42 ++++++------ arch/riscv/lib/rdtime.c | 38 ----------- arch/riscv/lib/sifive_clint.c | 87 ++++++++++++++++--------- common/spl/spl_opensbi.c | 5 ++ drivers/clk/kendryte/clk.c | 4 ++ drivers/ram/sifive/Kconfig | 2 + drivers/timer/Kconfig | 6 +- drivers/timer/riscv_timer.c | 39 +++++------ include/dt-bindings/clock/k210-sysctl.h | 1 + 17 files changed, 151 insertions(+), 162 deletions(-) delete mode 100644 arch/riscv/lib/rdtime.c
The riscv-timer driver currently serves as a shim for several riscv timer drivers. This is not too desirable because it bypasses the usual timer selection via the driver model. There is no easy way to specify an alternate timing driver, or have the tick rate depend on the cpu's configured frequency. The timer drivers also do not have device structs, and so have to rely on storing parameters in gd_t. Lastly, there is no initialization call, so driver init is done in the same function which reads the time. This can result in confusing error messages. To a user, it looks like the driver failed when trying to read the time, whereas it may have failed while initializing.
This patch removes the shim functionality from the riscv-timer driver, and has it instead implement the former rdtime.c timer driver. This is because existing u-boot users who pass in a device tree (e.g. qemu) do not create a timer device for S-mode u-boot. The existing behavior of creating the riscv-timer device in the riscv cpu driver must be kept. The actual reading of the CSRs has been redone in the style of Linux's get_cycles64.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
arch/riscv/lib/Makefile | 1 - arch/riscv/lib/rdtime.c | 38 ------------------------------------ drivers/timer/Kconfig | 6 +++--- drivers/timer/riscv_timer.c | 39 +++++++++++++++++++------------------ 4 files changed, 23 insertions(+), 61 deletions(-) delete mode 100644 arch/riscv/lib/rdtime.c
diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 6c503ff2b2..10ac5b06d3 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -15,7 +15,6 @@ obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint.o obj-$(CONFIG_ANDES_PLIC) += andes_plic.o obj-$(CONFIG_ANDES_PLMT) += andes_plmt.o else -obj-$(CONFIG_RISCV_RDTIME) += rdtime.o obj-$(CONFIG_SBI) += sbi.o obj-$(CONFIG_SBI_IPI) += sbi_ipi.o endif diff --git a/arch/riscv/lib/rdtime.c b/arch/riscv/lib/rdtime.c deleted file mode 100644 index e128d7fce6..0000000000 --- a/arch/riscv/lib/rdtime.c +++ /dev/null @@ -1,38 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2018, Anup Patel anup@brainfault.org - * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com - * - * The riscv_get_time() API implementation that is using the - * standard rdtime instruction. - */ - -#include <common.h> - -/* Implement the API required by RISC-V timer driver */ -int riscv_get_time(u64 *time) -{ -#ifdef CONFIG_64BIT - u64 n; - - __asm__ __volatile__ ( - "rdtime %0" - : "=r" (n)); - - *time = n; -#else - u32 lo, hi, tmp; - - __asm__ __volatile__ ( - "1:\n" - "rdtimeh %0\n" - "rdtime %1\n" - "rdtimeh %2\n" - "bne %0, %2, 1b" - : "=&r" (hi), "=&r" (lo), "=&r" (tmp)); - - *time = ((u64)hi << 32) | lo; -#endif - - return 0; -} diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 637024445c..b85fa33e47 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -144,10 +144,10 @@ config OMAP_TIMER
config RISCV_TIMER bool "RISC-V timer support" - depends on TIMER && RISCV + depends on TIMER && RISCV_SMODE help - Select this to enable support for the timer as defined - by the RISC-V privileged architecture spec. + Select this to enable support for a generic RISC-V S-Mode timer + driver.
config ROCKCHIP_TIMER bool "Rockchip timer support" diff --git a/drivers/timer/riscv_timer.c b/drivers/timer/riscv_timer.c index 9f9f070e0b..449fcfcfd5 100644 --- a/drivers/timer/riscv_timer.c +++ b/drivers/timer/riscv_timer.c @@ -1,36 +1,37 @@ // SPDX-License-Identifier: GPL-2.0+ /* + * Copyright (C) 2020, Sean Anderson seanga2@gmail.com * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + * Copyright (C) 2018, Anup Patel anup@brainfault.org + * Copyright (C) 2012 Regents of the University of California * - * RISC-V privileged architecture defined generic timer driver + * RISC-V architecturally-defined generic timer driver * - * This driver relies on RISC-V platform codes to provide the essential API - * riscv_get_time() which is supposed to return the timer counter as defined - * by the RISC-V privileged architecture spec. - * - * This driver can be used in both M-mode and S-mode U-Boot. + * This driver provides generic timer support for S-mode U-Boot. */
#include <common.h> #include <dm.h> #include <errno.h> #include <timer.h> -#include <asm/io.h> - -/** - * riscv_get_time() - get the timer counter - * - * Platform codes should provide this API in order to make this driver function. - * - * @time: the 64-bit timer count as defined by the RISC-V privileged - * architecture spec. - * @return: 0 on success, -ve on error. - */ -extern int riscv_get_time(u64 *time); +#include <asm/csr.h>
static int riscv_timer_get_count(struct udevice *dev, u64 *count) { - return riscv_get_time(count); + if (IS_ENABLED(CONFIG_64BIT)) { + *count = csr_read(CSR_TIME); + } else { + u32 hi, lo; + + do { + hi = csr_read(CSR_TIMEH); + lo = csr_read(CSR_TIME); + } while (hi != csr_read(CSR_TIMEH)); + + *count = ((u64)hi << 32) | lo; + } + + return 0; }
static int riscv_timer_probe(struct udevice *dev)
Hi Sean
- Copyright (C) 2018, Anup Patel anup@brainfault.org
- Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com
- The riscv_get_time() API implementation that is using the
- standard rdtime instruction.
u64 n;
"rdtime %0"
: "=r" (n));
*time = n;
-#else
u32 lo, hi, tmp;
"1:\n"
"rdtimeh %0\n"
"rdtime %1\n"
"rdtimeh %2\n"
"bne %0, %2, 1b"
-#endif
config RISCV_RDTIME in arch/riscv/Kconfig shall be removed meanwhile.
Thanks, Rick
driver.
- Copyright (C) 2020, Sean Anderson seanga2@gmail.com
- Copyright (C) 2012 Regents of the University of California
- RISC-V privileged architecture defined generic timer driver
- RISC-V architecturally-defined generic timer driver
- This driver relies on RISC-V platform codes to provide the essential API
- riscv_get_time() which is supposed to return the timer counter as defined
- This driver can be used in both M-mode and S-mode U-Boot.
- This driver provides generic timer support for S-mode U-Boot.
- riscv_get_time() - get the timer counter
- Platform codes should provide this API in order to make this driver function.
- @time: the 64-bit timer count as defined by the RISC-V privileged
architecture spec.
- @return: 0 on success, -ve on error.
} else {
u32 hi, lo;
do {
2.27.0
On 7/28/20 5:11 AM, Rick Chen wrote:
Hi Sean
u64 n;
"rdtime %0"
: "=r" (n));
*time = n;
-#else
u32 lo, hi, tmp;
"1:\n"
"rdtimeh %0\n"
"rdtime %1\n"
"rdtimeh %2\n"
"bne %0, %2, 1b"
-#endif
Thanks, Rick
Ok, I will remove that in V2.
driver.
architecture spec.
} else {
u32 hi, lo;
do {
2.27.0
This converts the PLMT driver from the riscv-specific timer interface to be a DM-based UCLASS_TIMER driver.
Signed-off-by: Sean Anderson seanga2@gmail.com --- This patch builds but has NOT been tested.
arch/riscv/Kconfig | 4 --- arch/riscv/dts/ae350_32.dts | 1 + arch/riscv/dts/ae350_64.dts | 1 + arch/riscv/include/asm/global_data.h | 3 -- arch/riscv/lib/andes_plmt.c | 42 +++++++++++++--------------- 5 files changed, 22 insertions(+), 29 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 009a545fcf..502f27b92d 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -177,10 +177,6 @@ config ANDES_PLIC config ANDES_PLMT bool depends on RISCV_MMODE || SPL_RISCV_MMODE - select REGMAP - select SYSCON - select SPL_REGMAP if SPL - select SPL_SYSCON if SPL help The Andes PLMT block holds memory-mapped mtime register associated with timer tick. diff --git a/arch/riscv/dts/ae350_32.dts b/arch/riscv/dts/ae350_32.dts index 3f8525fe56..afcb9cfbbf 100644 --- a/arch/riscv/dts/ae350_32.dts +++ b/arch/riscv/dts/ae350_32.dts @@ -162,6 +162,7 @@ &CPU2_intc 7 &CPU3_intc 7>; reg = <0xe6000000 0x100000>; + clock-frequency = <60000000>; }; };
diff --git a/arch/riscv/dts/ae350_64.dts b/arch/riscv/dts/ae350_64.dts index 482c707503..1c37879049 100644 --- a/arch/riscv/dts/ae350_64.dts +++ b/arch/riscv/dts/ae350_64.dts @@ -162,6 +162,7 @@ &CPU2_intc 7 &CPU3_intc 7>; reg = <0x0 0xe6000000 0x0 0x100000>; + clock-frequency = <60000000>; }; };
diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index 2eb14815bc..0dec5e669e 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -24,9 +24,6 @@ struct arch_global_data { #ifdef CONFIG_ANDES_PLIC void __iomem *plic; /* plic base address */ #endif -#ifdef CONFIG_ANDES_PLMT - void __iomem *plmt; /* plmt base address */ -#endif #if CONFIG_IS_ENABLED(SMP) struct ipi_data ipi[CONFIG_NR_CPUS]; #endif diff --git a/arch/riscv/lib/andes_plmt.c b/arch/riscv/lib/andes_plmt.c index a7e90ca992..b0245d0b52 100644 --- a/arch/riscv/lib/andes_plmt.c +++ b/arch/riscv/lib/andes_plmt.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2019, Rick Chen rick@andestech.com + * Copyright (C) 2020, Sean Anderson seanga2@gmail.com * * U-Boot syscon driver for Andes's Platform Level Machine Timer (PLMT). * The PLMT block holds memory-mapped mtime register @@ -9,46 +10,43 @@
#include <common.h> #include <dm.h> -#include <regmap.h> -#include <syscon.h> +#include <timer.h> #include <asm/io.h> -#include <asm/syscon.h> #include <linux/err.h>
/* mtime register */ #define MTIME_REG(base) ((ulong)(base))
-DECLARE_GLOBAL_DATA_PTR; - -#define PLMT_BASE_GET(void) \ - do { \ - long *ret; \ - \ - if (!gd->arch.plmt) { \ - ret = syscon_get_first_range(RISCV_SYSCON_PLMT); \ - if (IS_ERR(ret)) \ - return PTR_ERR(ret); \ - gd->arch.plmt = ret; \ - } \ - } while (0) - -int riscv_get_time(u64 *time) +static int andes_plmt_get_count(struct udevice *dev, u64 *count) { - PLMT_BASE_GET(); + *count = readq((void __iomem *)MTIME_REG(dev->priv));
- *time = readq((void __iomem *)MTIME_REG(gd->arch.plmt)); + return 0; +} + +static const struct timer_ops andes_plmt_ops = { + .get_count = andes_plmt_get_count, +}; + +static int andes_plmt_probe(struct udevice *dev) +{ + dev->priv = dev_read_addr_ptr(dev); + if (!dev->priv) + return -EINVAL;
return 0; }
static const struct udevice_id andes_plmt_ids[] = { - { .compatible = "riscv,plmt0", .data = RISCV_SYSCON_PLMT }, + { .compatible = "riscv,plmt0" }, { } };
U_BOOT_DRIVER(andes_plmt) = { .name = "andes_plmt", - .id = UCLASS_SYSCON, + .id = UCLASS_TIMER, .of_match = andes_plmt_ids, + .ops = &andes_plmt_ops, + .probe = andes_plmt_probe, .flags = DM_FLAG_PRE_RELOC, };
Hi Sean,
select REGMAP
select SYSCON
Where is this value from?
- Copyright (C) 2019, Rick Chen rick@andestech.com
- U-Boot syscon driver for Andes's Platform Level Machine Timer (PLMT).
- The PLMT block holds memory-mapped mtime register
@@ -9,46 +10,43 @@
do { \
long *ret; \
if (IS_ERR(ret)) \
} while (0)
PLMT_BASE_GET();
if (!dev->priv)
return -EINVAL; return 0;
Regards, Bin
On 7/23/20 9:51 AM, Bin Meng wrote:
Hi Sean,
select REGMAP
select SYSCON
/cpus/timebase-frequency
@@ -9,46 +10,43 @@
do { \
long *ret; \
if (IS_ERR(ret)) \
} while (0)
PLMT_BASE_GET();
if (!dev->priv)
Regards, Bin
This merges the PLIC initialization code from two functions into one.
arch/riscv/lib/andes_plic.c | 58 ++++++++++++++++--------------------- 1 file changed, 25 insertions(+), 33 deletions(-)
diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c index 5cf29df670..267d6a191b 100644 --- a/arch/riscv/lib/andes_plic.c +++ b/arch/riscv/lib/andes_plic.c @@ -41,53 +41,45 @@ static int enable_ipi(int hart) return 0; }
-static int init_plic(void) +int riscv_init_ipi(void) { - struct udevice *dev; - ofnode node; int ret; + long *base = syscon_get_first_range(RISCV_SYSCON_PLIC); + ofnode node; + struct udevice *dev; u32 reg;
+ if (IS_ERR(base)) + return PTR_ERR(base); + gd->arch.plic = base; + ret = uclass_find_first_device(UCLASS_CPU, &dev); if (ret) return ret; + else if (!dev) + return -ENODEV;
- if (ret == 0 && dev) { - ofnode_for_each_subnode(node, dev_ofnode(dev->parent)) { - const char *device_type; + ofnode_for_each_subnode(node, dev_ofnode(dev->parent)) { + const char *device_type;
- device_type = ofnode_read_string(node, "device_type"); - if (!device_type) - continue; + device_type = ofnode_read_string(node, "device_type"); + if (!device_type) + continue;
- if (strcmp(device_type, "cpu")) - continue; + if (strcmp(device_type, "cpu")) + continue;
- /* skip if hart is marked as not available */ - if (!ofnode_is_available(node)) - continue; + /* skip if hart is marked as not available */ + if (!ofnode_is_available(node)) + continue;
- /* read hart ID of CPU */ - ret = ofnode_read_u32(node, "reg", ®); - if (ret == 0) - enable_ipi(reg); - } - - return 0; + /* read hart ID of CPU */ + ret = ofnode_read_u32(node, "reg", ®); + if (ret == 0) + enable_ipi(reg); }
- return -ENODEV; -} - -int riscv_init_ipi(void) -{ - long *ret = syscon_get_first_range(RISCV_SYSCON_PLIC); - - if (IS_ERR(ret)) - return PTR_ERR(ret); - gd->arch.plic = ret; - - return init_plic(); + return 0; }
int riscv_send_ipi(int hart)
This converts the clint driver from the riscv-specific interface to be a DM-based UCLASS_TIMER driver. We also need to re-add the initialization for IPI back into the SPL code. This was previously implicitly done when the timer was initialized. In addition, the SiFive DDR driver previously implicitly depended on the CLINT to select REGMAP.
Unlike Andes's PLMT/PLIC (which AFAIK never have anything pass it a dtb), the SiFive CLINT is part of the device tree passed in by qemu. This device tree doesn't have a clocks or clock-frequency property on clint, so we need to fall back on the timebase-frequency property. Perhaps in the future we can get a clock-frequency property added to the qemu dtb.
Signed-off-by: Sean Anderson seanga2@gmail.com f
--- This patch builds but has only been tested on the K210 and QEMU. It has NOT been tested on a HiFive.
arch/riscv/Kconfig | 4 -- arch/riscv/lib/sifive_clint.c | 87 +++++++++++++++++++++++------------ common/spl/spl_opensbi.c | 5 ++ drivers/ram/sifive/Kconfig | 2 + 4 files changed, 64 insertions(+), 34 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 502f27b92d..f2641ffc53 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -155,10 +155,6 @@ config 64BIT config SIFIVE_CLINT bool depends on RISCV_MMODE || SPL_RISCV_MMODE - select REGMAP - select SYSCON - select SPL_REGMAP if SPL - select SPL_SYSCON if SPL help The SiFive CLINT block holds memory-mapped control and status registers associated with software and timer interrupts. diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index b9a2c649cc..3345a17ad2 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -8,9 +8,9 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> -#include <regmap.h> -#include <syscon.h> +#include <timer.h> #include <asm/io.h> #include <asm/syscon.h> #include <linux/err.h> @@ -24,35 +24,19 @@
-int riscv_get_time(u64 *time) -{ - /* ensure timer register base has a sane value */ - riscv_init_ipi(); - - *time = readq((void __iomem *)MTIME_REG(gd->arch.clint)); - - return 0; -} - -int riscv_set_timecmp(int hart, u64 cmp) -{ - /* ensure timer register base has a sane value */ - riscv_init_ipi(); - - writeq(cmp, (void __iomem *)MTIMECMP_REG(gd->arch.clint, hart)); - - return 0; -} - int riscv_init_ipi(void) { - if (!gd->arch.clint) { - long *ret = syscon_get_first_range(RISCV_SYSCON_CLINT); + int ret; + struct udevice *dev;
- if (IS_ERR(ret)) - return PTR_ERR(ret); - gd->arch.clint = ret; - } + ret = uclass_get_device_by_driver(UCLASS_TIMER, + DM_GET_DRIVER(sifive_clint), &dev); + if (ret) + return ret; + + gd->arch.clint = dev_read_addr_ptr(dev); + if (!gd->arch.clint) + return -EINVAL;
return 0; } @@ -78,14 +62,57 @@ int riscv_get_ipi(int hart, int *pending) return 0; }
+static int sifive_clint_get_count(struct udevice *dev, u64 *count) +{ + *count = readq((void __iomem *)MTIME_REG(dev->priv)); + + return 0; +} + +static const struct timer_ops sifive_clint_ops = { + .get_count = sifive_clint_get_count, +}; + +static int sifive_clint_probe(struct udevice *dev) +{ + int ret; + ofnode cpu; + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + u32 rate; + + dev->priv = dev_read_addr_ptr(dev); + if (!dev->priv) + return -EINVAL; + + /* Did we get our clock rate from the device tree? */ + if (uc_priv->clock_rate) + return 0; + + /* Fall back to timebase-frequency */ + cpu = ofnode_path("/cpus"); + if (!ofnode_valid(cpu)) + return -EINVAL; + + ret = ofnode_read_u32(cpu, "timebase-frequency", &rate); + if (ret) + return ret; + + log_warning("missing clocks or clock-frequency property, falling back on timebase-frequency\n"); + uc_priv->clock_rate = rate; + + return 0; +} + static const struct udevice_id sifive_clint_ids[] = { - { .compatible = "riscv,clint0", .data = RISCV_SYSCON_CLINT }, + { .compatible = "riscv,clint0" }, { } };
U_BOOT_DRIVER(sifive_clint) = { .name = "sifive_clint", - .id = UCLASS_SYSCON, + .id = UCLASS_TIMER, .of_match = sifive_clint_ids, + .probe = sifive_clint_probe, + .ops = &sifive_clint_ops, .flags = DM_FLAG_PRE_RELOC, }; diff --git a/common/spl/spl_opensbi.c b/common/spl/spl_opensbi.c index 14f335f75f..3440bc0294 100644 --- a/common/spl/spl_opensbi.c +++ b/common/spl/spl_opensbi.c @@ -79,6 +79,11 @@ void spl_invoke_opensbi(struct spl_image_info *spl_image) invalidate_icache_all();
#ifdef CONFIG_SPL_SMP + /* Initialize the IPI before we use it */ + ret = riscv_init_ipi(); + if (ret) + hang(); + /* * Start OpenSBI on all secondary harts and wait for acknowledgment. * diff --git a/drivers/ram/sifive/Kconfig b/drivers/ram/sifive/Kconfig index 6aca22ab2a..31ad0a7e45 100644 --- a/drivers/ram/sifive/Kconfig +++ b/drivers/ram/sifive/Kconfig @@ -9,5 +9,7 @@ config SIFIVE_FU540_DDR bool "SiFive FU540 DDR driver" depends on RAM_SIFIVE default y if TARGET_SIFIVE_FU540 + select REGMAP + select SPL_REGMAP if SPL help This enables DDR support for the platforms based on SiFive FU540 SoC.
AFAIK because the K210 clock driver does not come up until after relocation, the clint will always use the clock-frequency parameter. Ideally, it should update itself after relocation to take into account the actual CPU frequency.
arch/riscv/dts/k210.dtsi | 10 ++++++---- drivers/clk/kendryte/clk.c | 4 ++++ include/dt-bindings/clock/k210-sysctl.h | 1 + 3 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/dts/k210.dtsi b/arch/riscv/dts/k210.dtsi index 2546c7d4e0..9583694c46 100644 --- a/arch/riscv/dts/k210.dtsi +++ b/arch/riscv/dts/k210.dtsi @@ -17,6 +17,8 @@ compatible = "kendryte,k210";
aliases { + cpu0 = &cpu0; + cpu1 = &cpu1; dma0 = &dmac0; gpio0 = &gpio0; gpio1 = &gpio1_0; @@ -40,7 +42,6 @@ cpus { #address-cells = <1>; #size-cells = <0>; - timebase-frequency = <7800000>; cpu0: cpu@0 { device_type = "cpu"; compatible = "kendryte,k210", "sifive,rocket0", "riscv"; @@ -126,14 +127,15 @@ read-only; };
- clint0: interrupt-controller@2000000 { + clint0: clint@2000000 { #interrupt-cells = <1>; compatible = "kendryte,k210-clint", "riscv,clint0"; reg = <0x2000000 0xC000>; - interrupt-controller; interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>, <&cpu1_intc 3>, <&cpu1_intc 7>; - clocks = <&sysclk K210_CLK_CPU>; + clocks = <&sysclk K210_CLK_CLINT>; + /* sysclk is only available post-relocation */ + clock-frequency = <7800000>; };
plic0: interrupt-controller@C000000 { diff --git a/drivers/clk/kendryte/clk.c b/drivers/clk/kendryte/clk.c index 981b3b7699..bb196961af 100644 --- a/drivers/clk/kendryte/clk.c +++ b/drivers/clk/kendryte/clk.c @@ -646,6 +646,10 @@ static int k210_clk_probe(struct udevice *dev) REGISTER_GATE(K210_CLK_RTC, "rtc", in0); #undef REGISTER_GATE
+ /* The MTIME register in CLINT runs at one 50th the CPU clock speed */ + clk_dm(K210_CLK_CLINT, + clk_register_fixed_factor(NULL, "clint", "cpu", 0, 1, 50)); + return 0; }
diff --git a/include/dt-bindings/clock/k210-sysctl.h b/include/dt-bindings/clock/k210-sysctl.h index 0e3ed3fb9f..fe852bbd92 100644 --- a/include/dt-bindings/clock/k210-sysctl.h +++ b/include/dt-bindings/clock/k210-sysctl.h @@ -55,5 +55,6 @@ #define K210_CLK_OTP 43 #define K210_CLK_RTC 44 #define K210_CLK_ACLK 45 +#define K210_CLK_CLINT 46
#endif /* CLOCK_K210_SYSCTL_H */
Hello Sean,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Sean Anderson Sent: Wednesday, July 22, 2020 9:21 PM To: u-boot@lists.denx.de Cc: Bin Meng bmeng.cn@gmail.com; Rick Chen rickchen36@gmail.com; Sean Anderson seanga2@gmail.com Subject: [PATCH 5/6] riscv: Update Kendryte device tree for new CLINT driver
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Can you please consider splitting the dt-bindings include into separate patch so as to avoid checkpatch warning.
Thanks & BR, Sagar
aliases {
cpu0 = &cpu0;
clock-frequency = <7800000>; }; plic0: interrupt-controller@C000000 {
diff --git a/include/dt-bindings/clock/k210-sysctl.h b/include/dt- bindings/clock/k210-sysctl.h index 0e3ed3fb9f..fe852bbd92 100644 --- a/include/dt-bindings/clock/k210-sysctl.h +++ b/include/dt-bindings/clock/k210-sysctl.h @@ -55,5 +55,6 @@ #define K210_CLK_OTP 43 #define K210_CLK_RTC 44 #define K210_CLK_ACLK 45 +#define K210_CLK_CLINT 46
2.27.0
On 7/23/20 7:49 AM, Sagar Kadam wrote:
Hello Sean,
If you'd like. AFAIK this is mostly a kernel thing since dt-bindings often have separate maintainers than the rest of the series. Can anyone comment on whether this applies to U-Boot as well?
--Sean
Hi Sean,
Hello Sean,
If the changes are from upstream Linux kernel, it's fine to keep the changes in the k210.dtsi. But if the changes are only needed in U-Boot, as Sagar mentioned they should be in k210-uboot.dtsi.
Regards, Bin
On 7/23/20 9:49 AM, Bin Meng wrote:
Hi Sean,
Hello Sean,
Here the question is whether the patch should be split, not what file the changes should go in. At the moment, the dts is not synced between U-Boot and Linux for the K210, so there is no need to have a separate device tree file.
--Sean
Hi Sean/Bin,
-----Original Message----- From: Sean Anderson seanga2@gmail.com Sent: Thursday, July 23, 2020 7:30 PM To: Bin Meng bmeng.cn@gmail.com Cc: Sagar Kadam sagar.kadam@sifive.com; u-boot@lists.denx.de; Rick Chen rickchen36@gmail.com Subject: Re: [PATCH 5/6] riscv: Update Kendryte device tree for new CLINT driver
Hi Sean,
Hello Sean,
Sorry if my statement turned confusing, (I didn't mean it to be into k210-uboot.dtsi), what I meant to say is we might consider splitting the dt-bindings header change into another patch within this series. cause the checkpatch show's a warning as below: #/scripts/checkpatch.pl 0005-riscv-Update-Kendryte-device-tree-for-new-CLINT-driv.patch WARNING: DT binding docs and includes should be a separate patch. See: Documentation/devicetree/bindings/submitting-patches.txt
total: 0 errors, 1 warnings, 0 checks, 49 lines checked
i.e IIUC, the changes in include/dt-bindings/clock/k210-sysctl.h is expected to be as a separate patch within this series. So the split of this patch can be as
-Patch 5 can be :" riscv: Update Kendryte device tree for new CLINT driver" arch/riscv/dts/k210.dtsi | 10 ++++++---- drivers/clk/kendryte/clk.c | 4 ++++
-Patch 6 can be something like: "dt-bindings: clk: k210: add clint clock identifier" include/dt-bindings/clock/k210-sysctl.h | 1 +
Thanks & BR, Sagar
--Sean
We may need to add a clock-frequency binding like for the K210.
arch/riscv/dts/fu540-c000-u-boot.dtsi | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index afdb4f4402..e56bfc7595 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -55,8 +55,13 @@ }; clint@2000000 { compatible = "riscv,clint0"; - interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7 &cpu1_intc 3 &cpu1_intc 7 &cpu2_intc 3 &cpu2_intc 7 &cpu3_intc 3 &cpu3_intc 7 &cpu4_intc 3 &cpu4_intc 7>; + interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7 + &cpu1_intc 3 &cpu1_intc 7 + &cpu2_intc 3 &cpu2_intc 7 + &cpu3_intc 3 &cpu3_intc 7 + &cpu4_intc 3 &cpu4_intc 7>; reg = <0x0 0x2000000 0x0 0xc0000>; + clocks = <&prci PRCI_CLK_COREPLL>; u-boot,dm-spl; }; dmc: dmc@100b0000 {
Hi Sean,
This looks wrong to me. The CLINT timer frequency should come from the RTC node.
+Pragnesh Patel
+Sagar Kadam
Regards, Bin
On 7/23/20 9:50 AM, Bin Meng wrote:
Hi Sean,
+Pragnesh Patel
+Sagar Kadam
On further review, I think you are right that this should be RTCCLK_FREQ.
Perhaps the clocks part should be moved into arch/riscv/dts/hifive-unleashed-a00-u-boot.dts and changed to something like
clocks = <&rtcclk>;
--Sean
Hi Sean,
-----Original Message----- From: Sean Anderson seanga2@gmail.com Sent: 23 July 2020 19:27 To: Bin Meng bmeng.cn@gmail.com; Pragnesh Patel pragnesh.patel@sifive.com; Sagar Kadam sagar.kadam@sifive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Rick Chen rickchen36@gmail.com Subject: Re: [PATCH 6/6] riscv: Update SiFive device tree for new CLINT driver
Hi Sean,
&cpu4_intc 3
- &cpu4_intc 7>; reg = <0x0 0x2000000 0x0 0xc0000>;
RTC node.
+Pragnesh Patel
+Sagar Kadam
Perhaps the clocks part should be moved into arch/riscv/dts/hifive- unleashed-a00-u-boot.dts and changed to something like
clocks = <&rtcclk>;
I am okay with your suggestion, better to add in "hifive-unleashed-a00-u-boot.dtsi".
--Sean
Hi Sean,
Hi Sean,
+Pragnesh Patel
+Sagar Kadam
clocks = <&rtcclk>;
How does the device tree look like in the upstream Linux to work with the new CLINT timer driver?
Regards, Bin
On 7/23/20 10:47 AM, Bin Meng wrote:
Hi Sean,
Hi Sean,
+Pragnesh Patel
+Sagar Kadam
clocks = <&rtcclk>;
Regards, Bin
Anup's patch doesn't change the device tree at all so I think they are still using timebase-frequency.
--Sean
Hello Sean,
-----Original Message----- From: Sean Anderson seanga2@gmail.com Sent: Thursday, July 23, 2020 8:22 PM To: Bin Meng bmeng.cn@gmail.com Cc: Pragnesh Patel pragnesh.patel@sifive.com; Sagar Kadam sagar.kadam@sifive.com; U-Boot Mailing List u-boot@lists.denx.de; Rick Chen rickchen36@gmail.com Subject: Re: [PATCH 6/6] riscv: Update SiFive device tree for new CLINT driver
Hi Sean,
Hi Sean,
&cpu4_intc 3
RTC node.
+Pragnesh Patel
+Sagar Kadam
clocks = <&rtcclk>;
Yes, CLINT is driven by RTC clock.
Regards, Bin
In that case I was wondering what would be better: 1. IMHO we can skip the property as in your patch [4/6] riscv: Rework Sifive CLINT as UCLASS_TIMER driver has a fallback to timebase-frequency, in case clock for clint is not specified and is falling back to timebase-frequency which is again set to RTCCLK_FREQ 2. OR Shift the clock part to board -uboot dts file as you are suggesting in order to keep it synonymous with other TIMER changes done as a part of this series.
Thanks & BR, Sagar
--Sean
On 7/23/20 12:51 PM, Sagar Kadam wrote:
Hello Sean,
Hi Sean,
Hi Sean,
&cpu4_intc 3
RTC node.
+Pragnesh Patel
+Sagar Kadam
clocks = <&rtcclk>;
Regards, Bin
- IMHO we can skip the property as in your patch [4/6] riscv: Rework Sifive CLINT as UCLASS_TIMER driver has a fallback to timebase-frequency, in case clock for clint is not specified and is falling back to timebase-frequency which is again set to RTCCLK_FREQ
- OR Shift the clock part to board -uboot dts file as you are suggesting in order to keep it synonymous with other TIMER changes done as a part of this series.
I prefer the second option for two reasons. First, properties which affect a device should be located near its binding in the device tree. Using timebase-frequency only really makes sense when the cpu itself is the timer device. This is the case when we read the time from a CSR, but not when there is a separate device. Second, it lets the device use the clock subsystem which adds flexibility. If the device is configured for a different clock speed, the timer can adjust itself.
--Sean
-----Original Message----- From: Sean Anderson seanga2@gmail.com Sent: Friday, July 24, 2020 1:58 AM To: Sagar Kadam sagar.kadam@sifive.com; Bin Meng bmeng.cn@gmail.com Cc: Pragnesh Patel pragnesh.patel@sifive.com; U-Boot Mailing List <u- boot@lists.denx.de>; Rick Chen rickchen36@gmail.com Subject: Re: [PATCH 6/6] riscv: Update SiFive device tree for new CLINT driver
Hello Sean,
Hi Sean,
Hi Sean,
wrote:
> > We may need to add a clock-frequency binding like for the K210. > > Signed-off-by: Sean Anderson seanga2@gmail.com > --- > This patch builds but has NOT been tested. > > arch/riscv/dts/fu540-c000-u-boot.dtsi | 7 ++++++- > 1 file changed, 6 insertions(+), 1 deletion(-) > > diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi > b/arch/riscv/dts/fu540-c000-u-boot.dtsi > index afdb4f4402..e56bfc7595 100644 > --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi > +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi > @@ -55,8 +55,13 @@ > }; > clint@2000000 { > compatible = "riscv,clint0"; > - interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7
> + interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7 > + &cpu1_intc 3 &cpu1_intc 7 > + &cpu2_intc 3 &cpu2_intc 7 > + &cpu3_intc 3 &cpu3_intc 7 > + &cpu4_intc 3 > + &cpu4_intc 7>; > reg = <0x0 0x2000000 0x0 0xc0000>; > + clocks = <&prci PRCI_CLK_COREPLL>;
RTC node.
+Pragnesh Patel
+Sagar Kadam
RTCCLK_FREQ.
clocks = <&rtcclk>;
Regards, Bin
Okay, agreed. Thanks for clarification.
BR, Sagar
--Sean
+Anup Patel
Hi Sean,
Hi Sean,
+Pragnesh Patel
+Sagar Kadam
clocks = <&rtcclk>;
Regards, Bin
Anup, could you please look at this and suggest whether we should add this in the kernel upstream DTS?
Regards, Bin
participants (5)
Bin Meng
Pragnesh Patel
Rick Chen
Sagar Kadam
Sean Anderson
