[PATCH v2] Kconfig: clean up the efi configuration status
The EFI_LOADER and EFI config options are randomly scattered under lib/ making it cumbersome to navigate and enable options, unless you really know what you are doing. On top of that the existing options are in random order instead of a logical one.
So let's move things around a bit and move them under boot/. Present a generic UEFI entry where people can select Capsules, Protocols, Services, and an option to compile U-Boot as an EFI for X86
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v1: - Move the EFI Loader under boot/ instead of having it on the main menu - Fold in the U-Boot as an EFI app option under the new EFI menu boot/Kconfig | 2 + lib/Kconfig | 2 - lib/efi/Kconfig | 5 + lib/efi_loader/Kconfig | 204 +++++++++++++++++++++++------------------ 4 files changed, 124 insertions(+), 89 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 940389d4882f..a1477eb8c7e1 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -1,5 +1,7 @@ menu "Boot options"
+source "lib/efi_loader/Kconfig" + menu "Boot images"
config ANDROID_BOOT_IMAGE diff --git a/lib/Kconfig b/lib/Kconfig index 2059219a1207..06b4e9a73135 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -1081,8 +1081,6 @@ config SMBIOS_PARSER help A simple parser for SMBIOS data.
-source "lib/efi/Kconfig" -source "lib/efi_loader/Kconfig" source "lib/optee/Kconfig"
config TEST_FDTDEC diff --git a/lib/efi/Kconfig b/lib/efi/Kconfig index c2b9bb73f718..81ed3e66b34d 100644 --- a/lib/efi/Kconfig +++ b/lib/efi/Kconfig @@ -1,3 +1,6 @@ +menu "U-Boot as UEFI application" + depends on X86 + config EFI bool "Support running U-Boot from EFI" depends on X86 @@ -72,3 +75,5 @@ config EFI_RAM_SIZE use. U-Boot allocates this from EFI on start-up (along with a few other smaller amounts) and it can never be increased after that. It is used as the RAM size in with U-Boot. + +endmenu diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 6ffefa9103ff..0756be61d688 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -1,3 +1,5 @@ +menu "UEFI Support" + config EFI_LOADER bool "Support running UEFI applications" depends on OF_LIBFDT && ( \ @@ -41,13 +43,58 @@ config EFI_BINARY_EXEC You may enable CMD_BOOTEFI_BINARY so that you can use bootefi command to do that.
-config EFI_BOOTMGR - bool "UEFI Boot Manager" +config EFI_SECURE_BOOT + bool "Enable EFI secure boot support" + depends on EFI_LOADER && FIT_SIGNATURE + select HASH + select SHA256 + select RSA + select RSA_VERIFY_WITH_PKEY + select IMAGE_SIGN_INFO + select ASYMMETRIC_KEY_TYPE + select ASYMMETRIC_PUBLIC_KEY_SUBTYPE + select X509_CERTIFICATE_PARSER + select PKCS7_MESSAGE_PARSER + select PKCS7_VERIFY + select MSCODE_PARSER + select EFI_SIGNATURE_SUPPORT + help + Select this option to enable EFI secure boot support. + Once SecureBoot mode is enforced, any EFI binary can run only if + it is signed with a trusted key. To do that, you need to install, + at least, PK, KEK and db. + +config EFI_SIGNATURE_SUPPORT + bool + +menu "UEFI services" + +config EFI_GET_TIME + bool "GetTime() runtime service" + depends on DM_RTC default y help - Select this option if you want to select the UEFI binary to be booted - via UEFI variables Boot####, BootOrder, and BootNext. You should also - normally enable CMD_BOOTEFI_BOOTMGR so that the command is available. + Provide the GetTime() runtime service at boottime. This service + can be used by an EFI application to read the real time clock. + +config EFI_SET_TIME + bool "SetTime() runtime service" + depends on EFI_GET_TIME + default y if ARCH_QEMU || SANDBOX + help + Provide the SetTime() runtime service at boottime. This service + can be used by an EFI application to adjust the real time clock. + +config EFI_HAVE_RUNTIME_RESET + # bool "Reset runtime service is available" + bool + default y + depends on ARCH_BCM283X || FSL_LAYERSCAPE || PSCI_RESET || \ + SANDBOX || SYSRESET_SBI || SYSRESET_X86 + +endmenu + +menu "UEFI Variables"
choice prompt "Store for non-volatile UEFI variables" @@ -172,30 +219,18 @@ config EFI_VAR_BUF_SIZE
Minimum 4096, default 131072
-config EFI_GET_TIME - bool "GetTime() runtime service" - depends on DM_RTC - default y +config EFI_PLATFORM_LANG_CODES + string "Language codes supported by firmware" + default "en-US" help - Provide the GetTime() runtime service at boottime. This service - can be used by an EFI application to read the real time clock. + This value is used to initialize the PlatformLangCodes variable. Its + value is a semicolon (;) separated list of language codes in native + RFC 4646 format, e.g. "en-US;de-DE". The first language code is used + to initialize the PlatformLang variable.
-config EFI_SET_TIME - bool "SetTime() runtime service" - depends on EFI_GET_TIME - default y if ARCH_QEMU || SANDBOX - help - Provide the SetTime() runtime service at boottime. This service - can be used by an EFI application to adjust the real time clock. +endmenu
-config EFI_SCROLL_ON_CLEAR_SCREEN - bool "Avoid overwriting previous output on clear screen" - help - Instead of erasing the screen content when the console screen should - be cleared, emit blank new lines so that previous output is scrolled - out of sight rather than overwritten. On serial consoles this allows - to capture complete boot logs (except for interactive menus etc.) - and can ease debugging related issues. +menu "Capsule support"
config EFI_HAVE_CAPSULE_SUPPORT bool @@ -309,6 +344,10 @@ config EFI_CAPSULE_CRT_FILE embedded in the platform's device tree and used for capsule authentication at the time of capsule update.
+endmenu + +menu "UEFI protocol support" + config EFI_DEVICE_PATH_TO_TEXT bool "Device path to text protocol" default y @@ -362,39 +401,6 @@ config EFI_UNICODE_CAPITALIZATION
endif
-config EFI_LOADER_BOUNCE_BUFFER - bool "EFI Applications use bounce buffers for DMA operations" - help - Some hardware does not support DMA to full 64bit addresses. For this - hardware we can create a bounce buffer so that payloads don't have to - worry about platform details. - -config EFI_PLATFORM_LANG_CODES - string "Language codes supported by firmware" - default "en-US" - help - This value is used to initialize the PlatformLangCodes variable. Its - value is a semicolon (;) separated list of language codes in native - RFC 4646 format, e.g. "en-US;de-DE". The first language code is used - to initialize the PlatformLang variable. - -config EFI_HAVE_RUNTIME_RESET - # bool "Reset runtime service is available" - bool - default y - depends on ARCH_BCM283X || FSL_LAYERSCAPE || PSCI_RESET || \ - SANDBOX || SYSRESET_SBI || SYSRESET_X86 - -config EFI_GRUB_ARM32_WORKAROUND - bool "Workaround for GRUB on 32bit ARM" - default n if ARCH_BCM283X || ARCH_SUNXI || ARCH_QEMU - default y - depends on ARM && !ARM64 - help - GRUB prior to version 2.04 requires U-Boot to disable caches. This - workaround currently is also needed on systems with caches that - cannot be managed via CP15. - config EFI_RNG_PROTOCOL bool "EFI_RNG_PROTOCOL support" depends on DM_RNG @@ -447,29 +453,36 @@ config EFI_LOAD_FILE2_INITRD installed and Linux 5.7+ will ignore any initrd=<ramdisk> command line argument.
-config EFI_SECURE_BOOT - bool "Enable EFI secure boot support" - depends on EFI_LOADER && FIT_SIGNATURE - select HASH - select SHA256 - select RSA - select RSA_VERIFY_WITH_PKEY - select IMAGE_SIGN_INFO - select ASYMMETRIC_KEY_TYPE - select ASYMMETRIC_PUBLIC_KEY_SUBTYPE - select X509_CERTIFICATE_PARSER - select PKCS7_MESSAGE_PARSER - select PKCS7_VERIFY - select MSCODE_PARSER - select EFI_SIGNATURE_SUPPORT +config EFI_RISCV_BOOT_PROTOCOL + bool "RISCV_EFI_BOOT_PROTOCOL support" + default y + depends on RISCV help - Select this option to enable EFI secure boot support. - Once SecureBoot mode is enforced, any EFI binary can run only if - it is signed with a trusted key. To do that, you need to install, - at least, PK, KEK and db. + The EFI_RISCV_BOOT_PROTOCOL is used to transfer the boot hart ID + to the next boot stage. It should be enabled as it is meant to + replace the transfer via the device-tree. The latter is not + possible on systems using ACPI.
-config EFI_SIGNATURE_SUPPORT - bool +endmenu + +menu "Misc options" +config EFI_LOADER_BOUNCE_BUFFER + bool "EFI Applications use bounce buffers for DMA operations" + depends on ARM64 + help + Some hardware does not support DMA to full 64bit addresses. For this + hardware we can create a bounce buffer so that payloads don't have to + worry about platform details. + +config EFI_GRUB_ARM32_WORKAROUND + bool "Workaround for GRUB on 32bit ARM" + default n if ARCH_BCM283X || ARCH_SUNXI || ARCH_QEMU + default y + depends on ARM && !ARM64 + help + GRUB prior to version 2.04 requires U-Boot to disable caches. This + workaround currently is also needed on systems with caches that + cannot be managed via CP15.
config EFI_ESRT bool "Enable the UEFI ESRT generation" @@ -496,15 +509,26 @@ config EFI_EBBR_2_1_CONFORMANCE help Enabling this option adds the EBBRv2.1 conformance entry to the ECPT UEFI table.
-config EFI_RISCV_BOOT_PROTOCOL - bool "RISCV_EFI_BOOT_PROTOCOL support" +config EFI_SCROLL_ON_CLEAR_SCREEN + bool "Avoid overwriting previous output on clear screen" + help + Instead of erasing the screen content when the console screen should + be cleared, emit blank new lines so that previous output is scrolled + out of sight rather than overwritten. On serial consoles this allows + to capture complete boot logs (except for interactive menus etc.) + and can ease debugging related issues. + +endmenu + +menu "EFI bootmanager" + +config EFI_BOOTMGR + bool "UEFI Boot Manager" default y - depends on RISCV help - The EFI_RISCV_BOOT_PROTOCOL is used to transfer the boot hart ID - to the next boot stage. It should be enabled as it is meant to - replace the transfer via the device-tree. The latter is not - possible on systems using ACPI. + Select this option if you want to select the UEFI binary to be booted + via UEFI variables Boot####, BootOrder, and BootNext. You should also + normally enable CMD_BOOTEFI_BOOTMGR so that the command is available.
config EFI_HTTP_BOOT bool "EFI HTTP Boot support" @@ -514,5 +538,11 @@ config EFI_HTTP_BOOT help Enabling this option adds EFI HTTP Boot support. It allows to directly boot from network. +endmenu
endif + +source "lib/efi/Kconfig" + +endmenu + -- 2.45.2
On Fri, 30 Aug 2024 at 05:45, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Changes since v1:
On Fri, 30 Aug 2024 at 20:45, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Changes since v1:
menu "Boot images"
depends on X86
few
-config EFI_BOOTMGR
select HASH
select SHA256
select RSA
select PKCS7_VERIFY
help
install,
bool
booted
should also
available.
help
bool
default y
+endmenu
depends on DM_RTC
default y
variable. Its
native
used
help
+endmenu
help
should
scrolled
allows
etc.)
+endmenu
endif
help
this
have to
default "en-US"
help
variable. Its
native
used
bool
default y
default y
help
This
command line
argument.
select HASH
select SHA256
select RSA
select PKCS7_VERIFY
default y
install,
bool
+endmenu
depends on ARM64
help
this
have to
default y
help
This
ECPT UEFI table.
help
should
scrolled
allows
etc.)
+endmenu
+config EFI_BOOTMGR
booted
should also
available.
endif
While you might have already discussed the issue, it looks weird to me that lib/efi/Kconfig is contained in lib/efi_loader/Kconfig.
-Takahiro AKASHI
+endmenu
-- 2.45.2
Akashi-san
Changes since v1:
menu "Boot images"
depends on X86
-config EFI_BOOTMGR
select HASH
select SHA256
select RSA
select PKCS7_VERIFY
help
bool
help
bool
default y
+endmenu
depends on DM_RTC
default y
help
+endmenu
help
+endmenu
endif
help
default "en-US"
help
bool
default y
default y
help
select HASH
select SHA256
select RSA
select PKCS7_VERIFY
default y
bool
+endmenu
depends on ARM64
help
default y
help
help
+endmenu
+config EFI_BOOTMGR
endif
No, we haven't but that's just naming no? We can easily rename that
Thanks /Ilias
-Takahiro AKASHI
+endmenu
-- 2.45.2
Changes since v1:
menu "Boot images"
- depends on X86
- config EFI bool "Support running U-Boot from EFI" depends on X86
- config EFI_LOADER bool "Support running UEFI applications" depends on OF_LIBFDT && ( \
-config EFI_BOOTMGR
- select HASH
- select SHA256
- select RSA
- help
- bool
- depends on DM_RTC default y help
- help
- bool
- default y
+endmenu
- depends on DM_RTC
- default y
- default "en-US" help
- help
+endmenu
- help
+endmenu
- config EFI_DEVICE_PATH_TO_TEXT bool "Device path to text protocol" default y
endif
- help
- default "en-US"
- help
- bool
- default y
- default y
- help
- select HASH
- select SHA256
- select RSA
- default y
- bool
+endmenu
- depends on ARM64
Hello Ilias,
your merged patch revoked
dcd1b63b7072 ("efi_loader: allow EFI_LOADER_BOUNCE_BUFFER on all architectures")
which we need to fix problems on JH7110 boards with more than 4 GiB.
We need to add the revoked patch again.
Best regards
Heinrich
- help
default y
help
- help
+endmenu
+config EFI_BOOTMGR
- bool "UEFI Boot Manager" default y
endif
+endmenu
-- 2.45.2
Changes since v1:
menu "Boot images"
- depends on X86
-config EFI_BOOTMGR
- select HASH
- select SHA256
- select RSA
- help
- bool
- help
- bool
- default y
+endmenu
- depends on DM_RTC
- default y
- help
+endmenu
- help
+endmenu
endif
- help
- default "en-US"
- help
- bool
- default y
- default y
- help
- select HASH
- select SHA256
- select RSA
- default y
- bool
+endmenu
- depends on ARM64
Hello Ilias,
Can we do that as a "today" solution, and make EFI_LOADER_BOUNCE_BUFFER disappear and just be enabled by BOUNCE_BUFFER for v2025.04 please?
Changes since v1:
menu "Boot images"
- depends on X86
-config EFI_BOOTMGR
- select HASH
- select SHA256
- select RSA
- help
- bool
- help
- bool
- default y
+endmenu
- depends on DM_RTC
- default y
- help
+endmenu
- help
+endmenu
endif
- help
- default "en-US"
- help
- bool
- default y
- default y
- help
- select HASH
- select SHA256
- select RSA
- default y
- bool
+endmenu
- depends on ARM64
Hello Ilias,
Sure I'll send the patch in a bit
Thanks /Ilias
-- Tom
Changes since v1:
menu "Boot images"
- depends on X86
-config EFI_BOOTMGR
- select HASH
- select SHA256
- select RSA
- help
- bool
- help
- bool
- default y
+endmenu
- depends on DM_RTC
- default y
- help
+endmenu
- help
+endmenu
endif
- help
- default "en-US"
- help
- bool
- default y
- default y
- help
- select HASH
- select SHA256
- select RSA
- default y
- bool
+endmenu
- depends on ARM64
Hello Ilias,
As discussed with Simon the implementation of a bounce buffer should only exist in the block device layer and not in the UEFI sub-system. We should strive to make that change with the April release.
But as off today JH7110 board with more than 4 GiB fail to boot without this setting.
Best regards
Heinrich
Changes since v1:
menu "Boot images"
- depends on X86
-config EFI_BOOTMGR
- select HASH
- select SHA256
- select RSA
- help
- bool
- help
- bool
- default y
+endmenu
- depends on DM_RTC
- default y
- help
+endmenu
- help
+endmenu
endif
- help
- default "en-US"
- help
- bool
- default y
- default y
- help
- select HASH
- select SHA256
- select RSA
- default y
- bool
+endmenu
- depends on ARM64
Hello Ilias,
Also, another thing to check (probably with respective board maintainers) would be if we can remove the ram_top restriction on jh7110 boards. There is a comment in arch/riscv/cpu/jh7110/dram.c that the ram_top limit is to get 32 bit DMA capable devices to work. But that should not be an issue with bounce buffers enabled?
-sughosh
Best regards
Heinrich
participants (6)
Ilias Apalodimas
Sughosh Ganu
Takahiro AKASHI
