Re: [U-Boot] [PATCH 2/2] armv8/ls1046a: RGMII PHY requires internal delay on Tx
On 04/04/2017 04:44 AM, Madalin Bucur wrote:
Signed-off-by: Madalin Bucur madalin.bucur@nxp.com
drivers/net/fm/ls1046.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/fm/ls1046.c b/drivers/net/fm/ls1046.c index bf55554..6c91fb9 100644 --- a/drivers/net/fm/ls1046.c +++ b/drivers/net/fm/ls1046.c @@ -72,12 +72,12 @@ phy_interface_t fman_port_enet_if(enum fm_port port) if (port == FM1_DTSEC3) if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC1) == FSL_CHASSIS2_RCWSR13_EC1_DTSEC3_RGMII)
return PHY_INTERFACE_MODE_RGMII;
return PHY_INTERFACE_MODE_RGMII_TXID;
if (port == FM1_DTSEC4) if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC2) == FSL_CHASSIS2_RCWSR13_EC2_DTSEC4_RGMII)
/* handle SGMII, only MAC 2/5/6/9/10 available */ switch (port) {
I don't know what test you have run. This change breaks network on LS1043ARDB FM1@DTSEC3.
York
-----Original Message----- From: York Sun Sent: Wednesday, August 02, 2017 11:36 PM To: Madalin-cristian Bucur madalin.bucur@nxp.com; u-boot@lists.denx.de; joe.hershberger@ni.com Cc: Mingkai Hu mingkai.hu@nxp.com Subject: Re: [PATCH 2/2] armv8/ls1046a: RGMII PHY requires internal delay on Tx
York
Hi York,
You're likely using an old kernel, if you move to one that has removed the hardcoded internal delay for RGMII [1] you'll notice that RGMII no longer works with the old u-boot and you need this patch. We're in this situation because someone decided to hardcode internal delay for RGMII mode [2] in the Linux RTL8211F PHY driver. Someone else hardcoded the PHY fixup in u-boot to RGMII instead of RGMII_TXID [3] to align to that initial mistake. The issue with this u-boot fixup is that it overwrites device tree information, so one cannot correct this from the dts.
Regards, Madalin
[1] Linux kernel commit that removes hardcoded Tx internal delay for RTL8211F
commit e3230494b57ece68750e3e32d3e53d6b00917058 Author: Martin Blumenstingl martin.blumenstingl@googlemail.com Date: Fri Nov 25 14:12:01 2016 +0100
net: phy: realtek: fix enabling of the TX-delay for RTL8211F
The old logic always enabled the TX-delay when the phy-mode was set to PHY_INTERFACE_MODE_RGMII. There are dedicated phy-modes which tell the PHY driver to enable the RX and/or TX delays: - PHY_INTERFACE_MODE_RGMII should disable the RX and TX delay in the PHY (if required, the MAC should add the delays in this case) - PHY_INTERFACE_MODE_RGMII_ID should enable RX and TX delay in the PHY - PHY_INTERFACE_MODE_RGMII_TXID should enable the TX delay in the PHY - PHY_INTERFACE_MODE_RGMII_RXID should enable the RX delay in the PHY (currently not supported by RTL8211F)
With this patch we enable the TX delay for PHY_INTERFACE_MODE_RGMII_ID and PHY_INTERFACE_MODE_RGMII_TXID. Additionally we now explicity disable the TX-delay, which seems to be enabled automatically after a hard-reset of the PHY (by triggering it's reset pin) to get a consistent state (as defined by the phy-mode).
This fixes a compatibility problem with some SoCs where the TX-delay was also added by the MAC. With the TX-delay being applied twice the TX clock was off and TX traffic was broken or very slow (<10Mbit/s) on 1000Mbit/s links.
Signed-off-by: Martin Blumenstingl martin.blumenstingl@googlemail.com Reviewed-by: Florian Fainelli f.fainelli@gmail.com Signed-off-by: David S. Miller davem@davemloft.net
[2] Linux patch that hardcoded Tx ID for RGMII on RTL8211F
commit 3447cf2e9a11fd672de8b3cc613eabd97fe82053 Author: Shengzhou Liu Shengzhou.Liu@freescale.com Date: Thu Jun 18 16:42:47 2015 +0800
net/phy: Add support for Realtek RTL8211F
RTL8211F has different register definitions from RTL8211E. Specially it needs to enable TXDLY in case of RGMII.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com Signed-off-by: David S. Miller davem@davemloft.net
[3] u-boot commit that hardcoded RGMII instead of the required RGMII_TXID
commit 9d3b8bd166e6c23ab83d0dcd49d81c6f0bf39e17 Author: Mingkai Hu mingkai.hu@nxp.com Date: Tue Jul 5 16:01:56 2016 +0800
drivers: net/fm: Add Fman support for LS1046A
The Fman module on LS1046A is similiar with that on LS1043A but LS1046A has one more XFI (10GbE) interface.
Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com Reviewed-by: York Sun york.sun@nxp.com
York
Hi York,
Madalin,
There may be some gap. With this change, network doesn't work under U-Boot.
York
-----Original Message----- From: York Sun Sent: Thursday, August 03, 2017 7:14 PM To: Madalin-cristian Bucur madalin.bucur@nxp.com; u-boot@lists.denx.de; joe.hershberger@ni.com Cc: Mingkai Hu mingkai.hu@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; martin.blumenstingl@googlemail.com Subject: Re: [PATCH 2/2] armv8/ls1046a: RGMII PHY requires internal delay on Tx
boot@lists.denx.de;
delay
on Tx
port)
York
Hi York,
the
longer
situation
the
boot to
issue
one
Madalin,
There may be some gap. With this change, network doesn't work under U- Boot.
York
It solved the Linux issue but it is incomplete for u-boot as the RGMII_TXID is not supported by memac. I've sent a patch for that too.
Madalin
boot@lists.denx.de;
delay
on Tx
port)
return PHY_INTERFACE_MODE_RGMII_TXID; if (port == FM1_DTSEC4) if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC2) == FSL_CHASSIS2_RCWSR13_EC2_DTSEC4_RGMII)
return PHY_INTERFACE_MODE_RGMII_TXID; /* handle SGMII, only MAC 2/5/6/9/10 available */ switch (port) {
York
Hi York,
the
longer
situation
the
boot to
issue
one
Madalin,
York
Thank you. I will try it.
York
York Sun
